    4. [Gelöst]VIS FLOAT Verbindung Rückwärts
    • Haifeif 0
      Haifeif 0 @bahnuhr last edited by Homoran
      @bahnuhr
      http://192.168.178.101:8082/flot/index.html?l%5B0%5D%5Bid%5D=zigbee.0.84ba20fffee21b92.target_temperature&l%5B0%5D%5Binstance%5D=history.0&l%5B0%5D%5Boffset%5D=0&l%5B0%5D%5Baggregate%5D=minmax&l%5B0%5D%5Bcolor%5D=%23addbff&l%5B0%5D%5Bmin%5D=5&l%5B0%5D%5Bmax%5D=35&l%5B0%5D%5Bthickness%5D=3&l%5B0%5D%5Bshadowsize%5D=3&l%5B0%5D%5Bunit%5D=+%C2%B0C&l%5B0%5D%5Bname%5D=Ventil&l%5B0%5D%5Bxmove%5D=0&l%5B0%5D%5Byaxe%5D=right&l%5B0%5D%5Bxaxe%5D=bottom&l%5B0%5D%5BafterComma%5D=0&l%5B0%5D%5Bdashes%5D=false&l%5B0%5D%5BdashLength%5D=10&l%5B0%5D%5BspaceLength%5D=10&l%5B0%5D%5Bmultiplicator%5D=1&l%5B0%5D%5BchartType%5D=line&l%5B0%5D%5Bpoints%5D=false&l%5B1%5D%5Bid%5D=zigbee.0.ec1bbdfffeac2e9a.opened&l%5B1%5D%5Binstance%5D=history.0&l%5B1%5D%5Boffset%5D=0&l%5B1%5D%5Baggregate%5D=minmax&l%5B1%5D%5Bcolor%5D=%23ff00de&l%5B1%5D%5Bmin%5D=0&l%5B1%5D%5Bmax%5D=1&l%5B1%5D%5Bthickness%5D=1&l%5B1%5D%5Bshadowsize%5D=1&l%5B1%5D%5Bxmove%5D=0&l%5B1%5D%5Byaxe%5D=off&l%5B1%5D%5BcommonYAxis%5D=2&l%5B1%5D%5BafterComma%5D=2&l%5B1%5D%5Bdashes%5D=true&l%5B1%5D%5BdashLength%5D=10&l%5B1%5D%5BspaceLength%5D=10&l%5B1%5D%5Bmultiplicator%5D=1&l%5B1%5D%5ByOffset%5D=0&l%5B1%5D%5Bxaxe%5D=off&l%5B1%5D%5BchartType%5D=line&l%5B1%5D%5Bfill%5D=0.2&l%5B1%5D%5Bname%5D=Fenster+offen&l%5B2%5D%5Bid%5D=zigbee.0.00158d0007558147.temperature&l%5B2%5D%5Binstance%5D=history.0&l%5B2%5D%5Boffset%5D=0&l%5B2%5D%5Baggregate%5D=minmax&l%5B2%5D%5Bcolor%5D=%2321ff00&l%5B2%5D%5Bmin%5D=5&l%5B2%5D%5Bmax%5D=35&l%5B2%5D%5Bthickness%5D=3&l%5B2%5D%5Bshadowsize%5D=3&l%5B2%5D%5Bname%5D=Raum&l%5B2%5D%5Bxmove%5D=0&l%5B2%5D%5Byaxe%5D=off&l%5B2%5D%5Bxaxe%5D=off&l%5B3%5D%5Bid%5D=zigbee.0.84ba20fffee21b92.local_temp&l%5B3%5D%5Binstance%5D=history.0&l%5B3%5D%5Boffset%5D=0&l%5B3%5D%5Baggregate%5D=minmax&l%5B3%5D%5Bcolor%5D=%23FFFF00&l%5B3%5D%5Bmin%5D=5&l%5B3%5D%5Bmax%5D=35&l%5B3%5D%5Bthickness%5D=3&l%5B3%5D%5Bshadowsize%5D=3&l%5B3%5D%5Bname%5D=HKN&l%5B3%5D%5Bxmove%5D=0&l%5B3%5D%5Byaxe%5D=off&l%5B3%5D%5Bxaxe%5D=bottom&timeType=relative&relativeEnd=now&range=2880&aggregateType=step&aggregateSpan=300&hoverDetail=false&useComma=false&zoom=false&noedit=false&animation=0&live=3600&start=2022-01-05&start_time=04%3A00&end=2022-01-05&end_time=00%3A00&width=700&height=295&noBorder=noborder&window_bg=%23000000&x_labels_color=%23ffffff&y_labels_color=%23ffffff&barColor=%23000000&barLabels=topover&barFontColor=%23fefefe&titleColor=%2331ff12&titleSize=28&legColumns=3&legBgOpacity=0.5&legBg=%23ffffff&timeFormat=%25H%3A%25M+%3Cbr%3E+%25d.%25m&border_color=%23faf7f7&grid_color=%23bebbbb&barWidth=0.05&barFontSize=%23ffffff&legend=nw&bg=2&title=CO2+Gehalt
      Meinst Du das?
      • bahnuhr
        bahnuhr Forum Testing Most Active @Haifeif 0 last edited by
        @haifeif-0
        Ja,
        du nimmst diesen link und änderst am Anfang das Wort index in edit ab und dann kommst du in den flot edit modus.
        Haifeif 0 1 Reply Last reply Reply Quote 0
        • Haifeif 0
          @bahnuhr Ja, natürlich. Mein Fehler, ich meine flot.
          • Haifeif 0
            @bahnuhr
            Ok, das funktioniert. Aber ich habe doch in FLOT dutzende Grafiken mit Namen abgespeichert. Wie kann ich den Namen einer Grafik in VIS herausfinden, um dann die Datei über den gespeicherten Namen in FLOT zu öffnen?
            • bahnuhr
              @haifeif-0
              Ich benutze die Speicherung in flot nicht.
              Ist mir zu umständlich.
              Ich gehe immer den gezeigten Weg, dann weiß ich auch, dass ich die letzte in vis gezeigte Version habe.
              Und dann halt einfach auf edit ändern, fertig.
              Haifeif 0 1 Reply Last reply Reply Quote 1
              • Haifeif 0
                @bahnuhr Danke für den Hinweis. Manche meiner Grafiken haben einen blauen Pfeil(?), wenn ich den anklicke, bin ich sofort im Editor, ohne die Index/Editor Änderung. Mal schauen, ob ich die EInstellung finde, mit der ich das Ding einschalten kann. Denn nicht alle Grafiken haben ihn ...
                Aber Danke für Deine Hilfe!
                • bahnuhr
                  @haifeif-0 sagte in VIS FLOAT Verbindung Rückwärts:
                  bitte hardcopy zeigen
                  • Haifeif 0
                    Oben rechts, zwischen 35° und 30°
                    • bahnuhr
                      @haifeif-0
                      habe ich bei mir in keiner flot Grafik.
                      Aber schau doch mal in den Optionen im flot editor
                      • Haifeif 0
                        @bahnuhr Hab ich gerade, auch nix gefunden.
                        bahnuhr Haifeif 0 2 Replies Last reply Reply Quote 0
                        • bahnuhr
                          bahnuhr Forum Testing Most Active @Haifeif 0 last edited by bahnuhr
                          ich schon!
                          Könnte doch dies sein.
                          Ich finde dies aber nicht schön.
                          • Haifeif 0
                            Haifeif 0 @Haifeif 0 last edited by
                            @haifeif-0 Ich frag mal die KI ...
                            Chat weiß vieles:
                            ...&noedit=false...
                            Wenn das im Text steht, erscheint das Symbol und DU kannst die Grafik direkt editieren.
                            • Haifeif 0
                              @haifeif-0 Funktioniert! Wenn ich in Vis auf Quelle gehe und in der langen URL angabe nach &noedit= suche und das true durch false ersetze, erscheint beim Aufruf der Grafik oben rechts ein dunkelblaues Symbol. Das ist der Link in den Editor! Warum das aber machmal an und manchmal aus ist? Keine Ahnung. Ebenso finde ich keine korrespondierende Einstellung.
                              • Haifeif 0
                                @bahnuhr Stimmt! Augen auf hilft! Alles klar, wieder was gelernt.
                                Danke, schönen Abend noch!
                                1.0k
                                654
