    4. Object.<anonymous> finden?
    • SMS
      SMS @haus-automatisierung last edited by
      var Uhrzeit, Auto_Ein_bei, Steckdose_Dauerein, Hand, Wartezeit_Verbindungsaufbau, Wartezeit, Wartezeit3, Wartezeit2;
      on({ id: [].concat(['homeconnect.0.013060393307000289.programs.active.options.BSH_Common_Option_StartInRelative']), change: 'ne' }, async (obj) => {
        let value = obj.state.val;
        setState('0_userdata.0.Küche.Siemens_Spülmaschine_Startzeit_Stunden' /* Siemens Spülmaschine Startzeit Stunden */, (getState('homeconnect.0.013060393307000289.programs.active.options.BSH_Common_Option_StartInRelative').val / 3600), true);
        setState('0_userdata.0.Küche.Siemens_Spülmaschine_Startzeit_Minuten' /* Siemens Spülmaschine Startzeit Minuten */, (getState('homeconnect.0.013060393307000289.programs.active.options.BSH_Common_Option_StartInRelative').val / 60), true);
      on({ id: [].concat(['sonoff.0.Spülmaschine.alive']), change: 'ne' }, async (obj) => {
        if ((obj.state ? obj.state.val : '') == false) {
          setState('0_userdata.0.Küche.SD_Spülmaschine_am_Leben' /* SD Spülmaschine am Leben */, false, true);
        } else {
          setState('0_userdata.0.Küche.SD_Spülmaschine_am_Leben' /* SD Spülmaschine am Leben */, true, true);
      schedule("0,30 * * * *", async () => {
        setState('0_userdata.0.Küche.Siemens_Spülmaschine_Verbrauch' /* Siemens_Spülmaschine_Verbrauch */, (getState('sonoff.0.Spülmaschine.ENERGY_Total').val - 405.155), true);
      on({ id: [].concat(['homeconnect.0.013060393307000289.status.BSH_Common_Status_OperationState']), change: 'ne' }, async (obj) => {
        if ((obj.state ? obj.state.val : '') == 'BSH.Common.EnumType.OperationState.Run') {
          setState('0_userdata.0.Küche.Spülgänge' /* Spülgänge */, (getState('0_userdata.0.Küche.Spülgänge').val + 1), true);
        if ((obj.state ? obj.state.val : '') == 'BSH.Common.EnumType.OperationState.Ready') {
          setStateDelayed('0_userdata.0.Küche.Siemens_Spülmaschine_Durchnittskosten' /* Siemens Spülmaschine Durchnittskosten */, (getState('0_userdata.0.Küche.Spülmaschine_Verbrauchskosten').val / getState('0_userdata.0.Küche.Spülgänge').val), true, 60000, false);
        setState('0_userdata.0.Küche.Spülmaschine_Verbrauchskosten' /* Spülmaschine Verbrauchskosten */, (getState('0_userdata.0.Küche.Siemens_Spülmaschine_Verbrauch').val * getState('javascript.0.Meine_Datenpunkte.Strom.Kosten.Arbeitspreis_/kWh_Bezug_Energieversorger').val), true);
      on({ id: [].concat(['homeconnect.0.013060393307000289.programs.active.options.BSH_Common_Option_RemainingProgramTime']), change: 'ne' }, async (obj) => {
        setState('0_userdata.0.Küche.Siemens_Spülmaschine_Restlaufzeit' /* Siemens Spülmaschine Restlaufzeit */, (getState('homeconnect.0.013060393307000289.programs.active.options.BSH_Common_Option_RemainingProgramTime').val / 60), true);
      scheduleById('0_userdata.0.Haushaltsgeraete.01_Uhrzeit_Spuelmaschine' /* 01_Uhrzeit Spuelmaschine */, async () => {
        if (Uhrzeit) {
          setState('alias.0.Küche.Spülmaschine.SET' /* Set-Spülmaschine */, true);
      on({ id: [].concat(['0_userdata.0.Küche.Siemens_Spülmaschine_Auto_ein_bei']), change: 'ne' }, async (obj) => {
        if ((obj.state ? obj.state.val : '') == 1) {
          Auto_Ein_bei = 1500;
        } else if ((obj.state ? obj.state.val : '') == 2) {
          Auto_Ein_bei = 2000;
        } else if ((obj.state ? obj.state.val : '') == 3) {
          Auto_Ein_bei = 3000;
        } else if ((obj.state ? obj.state.val : '') == 4) {
          Auto_Ein_bei = 4000;
        } else if ((obj.state ? obj.state.val : '') == 0) {
          Auto_Ein_bei = false;
        setState('0_userdata.0.Küche.Auto_ein_bei' /* Auto ein bei */, Auto_Ein_bei, true);
      on({ id: [].concat(['0_userdata.0.Küche.Spülmaschine_Ein/Aus']), change: 'ne' }, async (obj) => {
        Uhrzeit = false;
        setState('0_userdata.0.Küche.Siemens_Spülmaschine_Auto' /* Siemens Spülmaschine Auto */, false, true);
        Hand = false;
          Uhrzeit = true;
          setState('0_userdata.0.Küche.Siemens_Spülmaschine_Auto' /* Siemens Spülmaschine Auto */, true, true);
        } else if ((obj.state ? obj.state.val : '') == 1) {
          Hand = true;
          (() => { if (Auto_Ein_bei) { clearInterval(Auto_Ein_bei); Auto_Ein_bei = null; }})();
          setState('alias.0.Küche.Spülmaschine.SET' /* Set-Spülmaschine */, false);
        Steckdose_Dauerein = false;
          Steckdose_Dauerein = true;
      on({ id: '0_userdata.0.Strom.Stromerzeugung_gesamt' /* Stromerzeugung gesamt */, change: 'ne' }, async (obj) => {
        if (getState('0_userdata.0.Küche.Siemens_Spülmaschine_Auto').val == true) {
          if ((obj.state ? obj.state.val : '') >= getState('0_userdata.0.Küche.Auto_ein_bei').val && getState('0_userdata.0.Strom.Batterie.Batterie___60%').val == true) {
            setStateDelayed('0_userdata.0.Küche.Siemens_Spülmaschine_Auto_ein_bei' /* Siemens Spülmaschine Auto ein bei */, false, true, 120000, false);
      on({ id: [].concat(['alias.0.Küche.Spülmaschine.SET']), change: 'ne' }, async (obj) => {
        if ((obj.state ? obj.state.val : '') && getState('0_userdata.0.Küche.Spülmaschine_Ein/Aus').val != 1 && getState('0_userdata.0.Küche.Spülmaschine_Ein/Aus').val != 4) {
          (() => { if (Wartezeit) { clearInterval(Wartezeit); Wartezeit = null; }})();
          Wartezeit_Verbindungsaufbau = 90;
          setState('0_userdata.0.Küche.Siemens_Spülmaschine_Verbindungszeit' /* Siemens Spülmaschine Verbindungszeit */, Wartezeit_Verbindungsaufbau, true);
          Wartezeit = setInterval(async () => {
            Wartezeit_Verbindungsaufbau = (typeof Wartezeit_Verbindungsaufbau === 'number' ? Wartezeit_Verbindungsaufbau : 0) + -1;
            if (Wartezeit_Verbindungsaufbau <= 0 && getState('alias.0.Küche.Spülmaschine.SET').val == true) {
              setState('homeconnect.0.013060393307000289.programs.active.BSH_Common_Root_ActiveProgram' /* BSH_Common_Root_ActiveProgram */, 'Dishcare.Dishwasher.Program.Eco50');
              setState('homeconnect.0.013060393307000289.settings.BSH_Common_Setting_PowerState' /* Energiezustand */, 'BSH.Common.EnumType.OperationState.On');
              if (obj.id && obj?.state && !obj.state.ack) {
                await setStateAsync(obj.id, { val: obj.state.val, ack: true });
          }, 1000);
        if ((obj.state ? obj.state.val : '') && getState('0_userdata.0.Küche.Spülmaschine_Ein/Aus').val == 1) {
          (() => { if (Wartezeit3) { clearInterval(Wartezeit3); Wartezeit3 = null; }})();
          Wartezeit3 = setInterval(async () => {
            if (Wartezeit_Verbindungsaufbau <= 0) {
          }, 1000);
        if ((obj.state ? obj.state.val : '') && getState('0_userdata.0.Küche.Spülmaschine_Ein/Aus').val == 4) {
          (() => { if (Wartezeit2) { clearInterval(Wartezeit2); Wartezeit2 = null; }})();
          Wartezeit2 = setInterval(async () => {
          }, 1000);
        if ((obj.state ? obj.state.val : '') == 'BSH.Common.EnumType.OperationState.Run' || (obj.state ? obj.state.val : '') == 'BSH.Common.EnumType.OperationState.Ready') {
          setStateDelayed('0_userdata.0.Küche.Siemens_Spülmaschine_läuft' /* Siemens_Spülmaschine_läuft */, true, true, 30000, false);
      on({ id: [].concat(['0_userdata.0.Küche.Siemens_Spülmaschine_Restlaufzeit']), change: 'ne' }, async (obj) => {
        if ((obj.state ? obj.state.val : '') <= 0 && getState('0_userdata.0.Küche.Siemens_Spülmaschine_läuft').val == true && getState('0_userdata.0.Küche.Siemens_Spülmaschine_Restlaufzeit').val <= 0) {
          setState('0_userdata.0.Küche.Siemens_Spülmaschine_läuft' /* Siemens_Spülmaschine_läuft */, false, true);
          setState('0_userdata.0.Küche.Spülmaschine_Ein/Aus' /* Spülmaschine Ein/Aus */, 0, true);
          setStateDelayed('alias.0.Küche.Spülmaschine.SET' /* Set-Spülmaschine */, false, 300000, false);
      • Codierknecht
        Codierknecht Developer Most Active @haus-automatisierung last edited by
        @haus-automatisierung sagte in Object.<anonymous> finden?:
        Das kann man schon so machen
        OT: Ich hatte mal einen Kollegen, der seinen Code eher so "hingerotzt" hat.
        Für den hatte ich mir Spezialkleidung besorgt:
        Was soll ich sagen ... der war nicht mehr lange "Kollege" 😁
        SMS 1 Reply Last reply Reply Quote 0
        • SMS
          SMS @Codierknecht last edited by
          @codierknecht Ich habe ja nicht gesagt das es perfekt ist. Das war für mich die Lösung damit da nicht 0 steht. Ich könnte natürlich auch einen Zahlenwert reinschreiben, den ich eh nie erreichen werde.
          paul53 Codierknecht 2 Replies Last reply Reply Quote 0
            paul53 @SMS last edited by
            @sms sagte: Das war für mich die Lösung damit da nicht 0 steht.
            Wie wäre es mit Strings?
            • SMS
              SMS @paul53 last edited by SMS
              @paul53 Wie müsste es dann aussehen? Trotzdem Zahlenwerte und true und false gemischt?
              • Codierknecht
                Codierknecht Developer Most Active @SMS last edited by
                @sms sagte in Object.<anonymous> finden?:
                Deswegen ja auch "OT". War nicht an Dich adressiert.
                Wäre eine Möglichkeit.
                Das Problem ist ja hier, dass eine rein Logische Aussage zusammen mit quantitativen Aussagen in einem einzigen DP zusammen abgebildet werden sollen.
                @paul53 sagte in Object.<anonymous> finden?:
                Fände ich fast noch unschöner.
                Ich würde einen bestimmten - unter normalen Umständen niemals erreichbaren - Zahlenwert bevorzugen.
                Oder aber z.B. -1 und diesen Sonderfall nochmal explizit prüfen, bevor da etwas losgetreten wird.
                Alternative wäre ein Objekt. Mit "On/Off" als Bool und den Zahlenwerten als Number. Fände ich am saubersten.
                  paul53 @SMS last edited by paul53
                  @sms sagte: Wie müsste es dann aussehen?
                  Datenpunkt-Typ: "string".
                  • SMS
                    @paul53 werde ich mal ausprobieren
                    • Codierknecht
                      Codierknecht Developer Most Active @Codierknecht last edited by
                      @codierknecht sagte in Object.<anonymous> finden?:
                      In etwa so:
                      Da hätte man Bool'sche und Zahlenwerte sauber getrennt.
                      Kann man jetzt noch weiter optimieren, so dass das Objekt zur Laufzeit nur noch im RAM existiert und man das nicht ständig neu einlesen muss.
                      • SMS
                        @codierknecht Guten Morgen,
                        ich habe mal die Variablen rausgemacht und etwas umprogrammiert, jetzt kommt die Meldung nicht mehr.
                        Du hast zwar eine schöne Anleitung geschrieben, nur leider finde ich den Fall nicht den ich brauche:
                        Funktioniert das hier so:
                        Ich möchte, wenn alle Stufen aus sind, das die Meldung "Heizstab eingeschaltet" weg geht.
                        Oder ist es so besser:
                        Oder eine der beiden Varianten und bei "wurde geändert" "ist unwahr" auswählen und das "nicht" weg machen?
                        Danke!
                        • Codierknecht
                          @sms
                          Variante 1 auf keinen Fall.
                          An einen Trigger kommen Objekt-ID's - kein bool'scher Ausdruck!
                          Wir sind hier aber jetzt plötzlich bei einer völlig anderen Anwendung, oder?
                          Was willst Du erreichen?
                          • SMS
                            SMS @Codierknecht last edited by SMS
                            @codierknecht Ja andere Anwendung. Da ich aber gesehen habe das du eine Anleitung https://forum.iobroker.net/topic/70481/blockly-for-dummies-starthilfe-und-tipps geschrieben hast und man dort nicht antworten soll, dachte ich ich schreibe hier bevor ich ein neues Thema aufmache.
                            Hier soll, sobald ein Heizstab angeht die Meldung "Heizstab eingeschaltet" ausgegeben werden:
                            Sind alle Stufen aus, soll die Meldung wieder weg gehen.
                            haus-automatisierung Homoran Codierknecht 3 Replies Last reply Reply Quote 0
                            • haus-automatisierung
                              haus-automatisierung Developer Most Active @SMS last edited by
                              Dann musst Du auf das Zahnrad vor "Falls Objekte" klicken und mehr Trigger auf die andere Seite ziehen. Dann dort mehrere Objekt IDs angeben. Der Oder-Baustein hat dort nichts zu suchen.
                              Homoran SMS 2 Replies Last reply Reply Quote 0
                                Homoran Global Moderator Administrators @SMS last edited by Homoran
                                @sms im Trigger niemals Logik!
                                nur IDs
                                der Block WERT bezieht sich auf den Wert des Triggernden Datenpunkts.
                                was genau willst du mit dem Wert?
                                  Homoran Global Moderator Administrators @haus-automatisierung last edited by Homoran
                                  @haus-automatisierung aber
                                  wird damit doch nie abgefangen!
                                  Dazu braucht's eine komplexere Logik
                                  • SMS
                                    SMS @haus-automatisierung last edited by SMS
                                    @haus-automatisierung Das hier ist dann eine ODER Verknüpfung?
                                    Sprich, sobald ein Objekt ID den Wert "true" sendet wird das Ergebnis ebenfalls "true" (in meinem Fall)
                                    Aber wie bekomme ich eine UND Verknüpfung hin?
                                      nicht im Trigger!
                                      @homoran sagte in Object.<anonymous> finden?:
                                      zusätzlich auch ein "sonst" oder "sonst falls" um
                                      zu realisieren
                                      • SMS
                                        SMS @Homoran last edited by
                                        @homoran Ich probiere es mal so:
                                          fast!
                                          jetzt noch statt WERT, dieses Konstrukt
                                          • Codierknecht
                                            Wenn es egal ist, welcher Heizstab und die Meldung nur kommen soll, wenn einer der drei auf true wechselt:
                                            2915
