    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
      Lucky_ESA Developer Most Active @AFi last edited by Lucky_ESA
      @afi sagte in Adapter Worx Landroid v3.x.x:
      @lucky_esa Hi es scheint im moment zu funktionieren, habe es gerade auch getestet. Habe es seit unserem Test immer direkt im Objekt oder an der APP eingegeben nicht über blockly. Es scheint nicht zuverlässig zu sein. Kannst Du mir zeigen auf was ich im Debug Protokoll achten muss? VG Axel
      Der erste Eintrag sendet und die anderen 2 kommen als Bestätigung
      2025-04-21 13:19:24.603 - debug: worx.0 (1797618) sendData: {"id":23583,"cmd":0,"lg":"it","sn":"xxx","tm":"13:19:24","dt":"21/04/2025","sc":{"m":1,"p":-100,"d":[["09:00",0,0],["10:00",420,0],["10:00",480,0],["09:00",0,0],["10:00",480,0],["10:00",480,0],["09:30",150,0]]}}
      2025-04-21 13:19:25.172 - debug: worx.0 (1797618) Mower MQTT: {"cfg":{"id":23583,"lg":"it","tm":"13:19:24","dt":"21/04/2025","sc":{"m":1,"p":-100,"d":[["09:00",0,0],["10:00",420,0],["10:00",480,0],["09:00",0,0],["10:00",480,0],["10:00",480,0],["09:30",150,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"xxx"},"dat":{"mac":"xxx","fw":3.52,"bt":{"t":26.1,"v":19.41,"p":66,"nr":1296,"c":1,"m":0},"dmp":[7.6,1.8,137.4],"st":{"b":74402,"d":1343894,"wt":81845},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
      2025-04-21 13:19:25.222 - debug: worx.0 (1797618) GET MQTT DATA from API: {"cfg":{"id":23583,"lg":"it","tm":"13:19:24","dt":"21/04/2025","sc":{"m":1,"p":-100,"d":[["09:00",0,0],["10:00",420,0],["10:00",480,0],["09:00",0,0],["10:00",480,0],["10:00",480,0],["09:30",150,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"xxx"},"dat":{"mac":"xxx","fw":3.52,"bt":{"t":26.1,"v":19.41,"p":66,"nr":1296,"c":1,"m":0},"dmp":[7.6,1.8,137.4],"st":{"b":74402,"d":1343894,"wt":81845},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
      Hierauf dann achten. Wenn du Blockly verwendest dann darauf achten, dass du eine Zahl setzt und kein string.
      "p":-100
      Gruß//Lucky
      AFi 1 Reply Last reply Reply Quote 0
      • AFi
        AFi @Lucky_ESA last edited by
        @lucky_esa Hi, vielen Dank für die Unterstützung, werde dies beobachten. Axel
          BlueTang last edited by
          Ich habe mir nochmal den Zeitlich limitierten Party Modus angeschaut. Während dessen Aktivierung wird am Mobiltelefon in der Landroid App der Status Party Modus bis zum Ablauf des Timers angezeigt. Dies sollte auch im Status der AvaDesktopApp so angezeigt werden. Also "Daheim Party Modus" anstelle von "Daheim". Nach Ablauf des Timers wäre es sinnvoll den Party Modus im PartyMode Plugin (v3.1) der AvaDesktopApp zurück auf "Current Party Mode setting off" zu setzen. Dieser bleibt zur Zeit auf "limited on" gesetzt obwohl der Party Modus beendet wurde.
          Das sind meine Beobachtungen. Bitte mal überprüfen.
          MfG
          BlueTang
          hsteinme 1 Reply Last reply Reply Quote 0
          • hsteinme
            hsteinme @BlueTang last edited by
            @bluetang Dieses Forum bzw. dieser Thread haben den ioBroker bzw. dessen Worx Adapter zum Thema, keineswegs die AvaDesktopApp. Deren Entwickler liest hier nicht mit. Der Diskussionsplatz für die AvaDesktopApp befindet sich im Roboter-Forum: https://www.roboter-forum.com/threads/alternative-app-fuer-worx-kress-und-landxcape-ava-desk-app.67392/
            Es gäbe also mehr Sinn, Deine Hinweise dort zu platzieren.
              Vielen Dank für den Hinweis. Ich habe den Thread ins Roboter-Forum gestellt. Könnte dies nicht auch Auswirkungen auf das Iobroker Obect mowerActive haben?
              • hsteinme
                @bluetang Nööh!
                • AFi
                  AFi @hsteinme last edited by
                  Hi zusammen, bin eigentlich am verzweifel mit dem Adapter, es scheint er funktioniert und funktioniert nicht. Dies gilt für die Arbeitszeitverkürzung bzw. Verlängerung als auch die direkte Startzeiteingabe, Arbeitszeiteingabe und Kantenschnittvorgabe. Derzeit bin ich am letzteren und habe die Vorgaben in extra Variablen, die ich zur Zeit x übertrage per Blockly:
                  Protokoll Ausschnitte:
                  worx.0
                  	2025-04-26 18:23:50.485	debug	Test Status: 1
                  worx.0
                  	2025-04-26 18:23:50.397	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"18:23:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.1,"v":19.64,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7,1.2,141.2],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
                  worx.0
                  	2025-04-26 18:23:50.266	debug	Set new timestamp
                  worx.0
                  	2025-04-26 18:23:50.266	debug	Worxcloud MQTT get Message for mower fifi (20183019090500523351)
                  worx.0
                  	2025-04-26 18:23:50.266	debug	getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                  worx.0
                  	2025-04-26 18:23:50.266	debug	topic: DB510/F0FE6BB1AA86/commandOut
                  worx.0
                  	2025-04-26 18:23:50.265	debug	Mower MQTT: {"cfg":{"id":0,"lg":"it","tm":"18:23:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.1,"v":19.64,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7,1.2,141.2],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
                  worx.0
                  	2025-04-26 18:20:12.223	debug	Update this.deviceArray: 0
                  worx.0
                  	2025-04-26 18:20:12.223	debug	Index Update: 0
                  worx.0
                  	2025-04-26 18:20:12.126	debug	Test Status: 1
                  worx.0
                  	2025-04-26 18:20:12.041	debug	GET MQTT DATA from API: {"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:13:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}
                  worx.0
                  	2025-04-26 18:20:12.034	debug	{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":null,"test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":null,"capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":null,"app_settings":null,"warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":null,"auto_schedule_settings":{"boost":0,"grass_type":null,"irrigation":null,"nutrition":null,"soil_type":null},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"timestamp":"2025-04-26 16:13:50","payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:13:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":null}
                  worx.0
                  	2025-04-26 18:13:50.487	debug	Test Status: 1
                  worx.0
                  	2025-04-26 18:13:50.389	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"18:13:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
                  worx.0
                  	2025-04-26 18:13:50.241	debug	Set new timestamp
                  worx.0
                  	2025-04-26 18:13:50.240	debug	Worxcloud MQTT get Message for mower fifi (20183019090500523351)
                  worx.0
                  	2025-04-26 18:13:50.240	debug	getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                  worx.0
                  	2025-04-26 18:13:50.240	debug	topic: DB510/F0FE6BB1AA86/commandOut
                  worx.0
                  	2025-04-26 18:13:50.239	debug	Mower MQTT: {"cfg":{"id":0,"lg":"it","tm":"18:13:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":22.8,"v":19.71,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,140.8],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
                  worx.0
                  	2025-04-26 18:06:00.106	debug	test cfg: 6 valID: 2 val: true sval: 1
                  worx.0
                  	2025-04-26 18:06:00.106	debug	Mowing time change at d to: {"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,1]],"p":0}
                  worx.0
                  	2025-04-26 18:06:00.106	debug	state change: id_____ worx.0.20183019090500523351.calendar.saturday.borderCut Mower 20183019090500523351_____borderCut______{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":"","capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":"","auto_schedule_settings":{"boost":0,"grass_type":"","irrigation":"","nutrition":{"n":0,"p":0,"k":0},"soil_type":""},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":""}
                  worx.0
                  	2025-04-26 18:06:00.106	debug	this.modules! {"20183019090500523351":{"edgeCut":false,"notify":true}}
                  worx.0
                  	2025-04-26 18:06:00.105	debug	test cfg: 6 valID: 1 val: 240 sval: 240
                  worx.0
                  	2025-04-26 18:06:00.105	debug	Mowing time change at d to: {"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,0]],"p":0}
                  worx.0
                  	2025-04-26 18:06:00.105	debug	state change: id_____ worx.0.20183019090500523351.calendar.saturday.workTime Mower 20183019090500523351_____workTime______{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":"","capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":"","auto_schedule_settings":{"boost":0,"grass_type":"","irrigation":"","nutrition":{"n":0,"p":0,"k":0},"soil_type":""},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":""}
                  worx.0
                  	2025-04-26 18:06:00.104	debug	this.modules! {"20183019090500523351":{"edgeCut":false,"notify":true}}
                  worx.0
                  	2025-04-26 18:06:00.097	debug	test cfg: 6 valID: 0 val: 15:00 sval: 15:00
                  worx.0
                  	2025-04-26 18:06:00.097	debug	Mowing time change at d to: {"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",0,0]],"p":0}
                  worx.0
                  	2025-04-26 18:06:00.097	debug	h: 15 m: 00
                  worx.0
                  	2025-04-26 18:06:00.097	debug	state change: id_____ worx.0.20183019090500523351.calendar.saturday.startTime Mower 20183019090500523351_____startTime______{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":"","test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":"","capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":"","app_settings":"","warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":"","auto_schedule_settings":{"boost":0,"grass_type":"","irrigation":"","nutrition":{"n":0,"p":0,"k":0},"soil_type":""},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":""}
                  worx.0
                  	2025-04-26 18:06:00.096	debug	this.modules! {"20183019090500523351":{"edgeCut":false,"notify":true}}
                  worx.0
                  	2025-04-26 18:05:12.160	debug	Update this.deviceArray: 0
                  worx.0
                  	2025-04-26 18:05:12.160	debug	Index Update: 0
                  worx.0
                  	2025-04-26 18:05:12.056	debug	Test Status: 1
                  worx.0
                  	2025-04-26 18:05:11.973	debug	GET MQTT DATA from API: {"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}
                  worx.0
                  	2025-04-26 18:05:11.967	debug	{"id":254680,"uuid":"96c52dac-c81c-4002-add9-e8bfdaeab50e","product_id":37,"user_id":156658,"serial_number":"20183019090500523351","mac_address":"F0FE6BB1AA86","locked":false,"firmware_version":"3.52.0+1","firmware_auto_upgrade":true,"sim":null,"test":false,"iot_registered":true,"mqtt_registered":true,"registered_at":"2019-03-17 00:00:00","online":true,"protocol":0,"pending_radio_link_validation":null,"capabilities":["follow_border","lock","mqtt","multi_zone","multi_zone_percentage","ota_upgrade","pairing_smartlink","rain_delay","unrestricted_mowing_time"],"capabilities_available":[],"mqtt_endpoint":"iot.eu-west-1.worxlandroid.com","mqtt_topics":{"command_in":"DB510/F0FE6BB1AA86/commandIn","command_out":"DB510/F0FE6BB1AA86/commandOut"},"name":"fifi","blade_height_shift":0,"push_notifications":false,"push_notifications_level":"warning","pin_code":null,"app_settings":null,"warranty_registered":true,"purchased_at":"2018-10-14 00:00:00","warranty_expires_at":"2020-10-14 00:00:00","setup_location":{"latitude":48.4928994,"longitude":12.0277211},"city":{"id":2811600,"country_id":276,"name":"Weixerau","latitude":48.5,"longitude":12.01667,"created_at":"2018-02-15 22:26:05","updated_at":"2018-02-15 22:26:05"},"time_zone":"Europe/Berlin","lawn_size":300,"lawn_perimeter":null,"auto_schedule_settings":{"boost":0,"grass_type":null,"irrigation":null,"nutrition":null,"soil_type":null},"auto_schedule":false,"improvement":true,"diagnostic":true,"distance_covered":1365164,"mower_work_time":83098,"blade_work_time":75558,"blade_work_time_reset":37646,"blade_work_time_reset_at":"2022-05-20 17:26:10","battery_charge_cycles":1311,"battery_charge_cycles_reset":813,"battery_charge_cycles_reset_at":"2022-05-20 17:26:06","created_at":"2018-07-16 06:41:33","updated_at":"2024-04-30 18:37:10","last_status":{"timestamp":"2025-04-26 16:03:50","payload":{"cfg":{"id":0,"sn":"20183019090500523351","dt":"26/04/2025","tm":"18:03:50","lg":"it","cmd":0,"sc":{"m":1,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]],"p":0},"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"ls":1,"le":0,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"rsi":-47,"lk":0,"lz":8}}},"last_gps_status":null}
                  worx.0
                  	2025-04-26 18:03:50.524	debug	Test Status: 1
                  worx.0
                  	2025-04-26 18:03:50.433	debug	GET MQTT DATA from API: {"cfg":{"id":0,"lg":"it","tm":"18:03:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
                  worx.0
                  	2025-04-26 18:03:50.340	debug	Set new timestamp
                  worx.0
                  	2025-04-26 18:03:50.340	debug	Worxcloud MQTT get Message for mower fifi (20183019090500523351)
                  worx.0
                  	2025-04-26 18:03:50.340	debug	getQueueStatistics: {"incompleteOperationCount":0,"incompleteOperationSize":0,"unackedOperationCount":0,"unackedOperationSize":0}
                  worx.0
                  	2025-04-26 18:03:50.339	debug	topic: DB510/F0FE6BB1AA86/commandOut
                  worx.0
                  	2025-04-26 18:03:50.339	debug	Mower MQTT: {"cfg":{"id":0,"lg":"it","tm":"18:03:50","dt":"26/04/2025","sc":{"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0]]},"cmd":0,"mz":[0,0,0,0],"mzv":[0,0,0,0,0,0,0,0,0,0],"rd":0,"sn":"20183019090500523351"},"dat":{"mac":"F0FE6BB1AA86","fw":3.52,"bt":{"t":23.5,"v":19.78,"p":100,"nr":1312,"c":0,"m":0},"dmp":[7.1,1.3,138.6],"st":{"b":75671,"d":1367361,"wt":83240},"ls":1,"le":0,"lz":8,"rsi":-47,"lk":0}}
                  worx.0
                  	2025-04-26 17:59:00.162	debug	test cfg: 6 valID: 2 val: true sval: 1
                  worx.0
                  	2025-04-26 17:59:00.162	debug	Mowing time change at d to: {"m":1,"p":0,"d":[["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["09:00",0,0],["15:00",240,1]]}
                  VG Axel
                    @afi Wie man States absetzt ist in der Anleitung genau beschrieben. Wenn du da was nicht verstehst, dann frage bitte nach.
                    So setzt man die Zeiten.
                    Bei deinem Blockly fehlt das Versenden deiner Eingabe.
                    Gruß//Lucky
                    • AFi
                      @lucky_esa Hi, danke für die Antwort, die 1,1 s zwischen den Befehlen im Blockly habe ich inzwischen verstanden, aber der notwendige Befehl der Versendung im Blockly erschließt sich mir leider nicht. Mir ist damit auch nicht klar, ob ich den Befehl am Schluß senden muss oder dazwischen. VG Axel
                        @afi Du musst erst alle Zeiten per Blockly schreiben und wenn du fertig bist, den State worx.0.xxxx.calendar.calJson_tosend auf true setzen. Alle Befehle ohne Pause. Nur zwischen 2 aktiven Befehle muss man 1,1 Sekunden Pause einhalten (siehe rot oder grüner Punkt).
                        Aber ACHTUNG! Die Zeiten sollten ohne Pause gesetzt werden weil, kommt in der Zeit zwischen Zeiten setzen und worx.0.xxxx.calendar.calJson_tosend auf true setzen ein Update vom Mower, dann werden aller deine Änderung wieder überschrieben und dann werden keine Änderungen versendet.
                        Deine Änderungen der Zeiten kannst du in worx.0.xxx.calendar.calJson_tosend beobachten.
                        Gruß//Lucky
                        • AFi
                          @lucky_esa Danke, werde dies morgen testen. VG Axel
                            seid wann schmeisst der Adapter Benachrichtigungn raus im Admin
                            wozu ??
                              bommel_030 last edited by
                              Regenverzögerung ist ihm neuerdings auch ne Fehlerbenachrichtigung im Admin wert?!?
                                Lucky_ESA Developer Most Active @arteck last edited by
                                @arteck Seit dem 04.11.2024 - Warum? Für mich wichtig solche Fehler sofrt zu sehen
                                @bommel_030 Weil es eine Fehlermeldung ist
                                Wie bereits ein paar posts vorher beschrieben könnt ihr diese Meldung deaktivieren.
                                Gruß//Lucky
                                mcm1957 B arteck 3 Replies Last reply Reply Quote 0
                                • mcm1957
                                  mcm1957 @Lucky_ESA last edited by
                                  @lucky_esa said in Adapter Worx Landroid v3.x.x:
                                  Gruß//Lucky
                                  Eine Verzögerung weilsregnet ist aber m.E
                                  als notification grenzwertig. Das Notificatoon system soöl nicht das logfile ersetzen oder jrde Info als notificatoon den Admin - provokant formuliert - zumüllen.
                                  Notifications sollten im allgemeinen eine Info an den User sein damit dieser was tut.
                                  @apollon77
                                  Gibt wo eine best praxis / empfehlung was als notificaton ok / gewünscht / eher übertrieben ist?
                                    bommel_030 @Lucky_ESA last edited by
                                    @lucky_esa
                                    Das mit dem abschalten ist schon klar, meiner Meinung nach ist Regen halt kein "Fehler". Bei außerhalb der Begrenzung würde ich das noch verstehen, da muss man manuell eingreifen.
                                    Wenn die Meldungen von dir so gewünscht sind passt es ja und ist kein "Bug" im Adapter. Auf jeden Fall danke für deine Entwicklung.
                                    • mcm1957
                                      mcm1957 @bommel_030 last edited by
                                      @Lucky_ESA
                                      Bitte um Info wo man die Notifications abschalten kann. Ich habe in jsonConfig.json keinen entsprechenden Punkt gesehen (aber vielleicht übersehen).
                                        Lucky_ESA Developer Most Active @mcm1957 last edited by
                                        @mcm1957 Hier und hier
                                        Steht alles in der Description. Die Benachrichtigung kann man mit einen State aktivieren/deaktivieren. Das ist besser als in der Instanz Einstellungen.
                                        Ich könnte noch ein Object hinzufügen wo der User die ID`s eintragen kann, welche Meldung nicht erwünscht ist.
                                        Welche Meldungen wären den nicht gewünscht?
                                        Möglich Fehler ID`s kann man auch in der Description erlesen.
                                        Gruß//Lucky
                                        • mcm1957
                                          mcm1957 @Lucky_ESA last edited by mcm1957
                                          @lucky_esa
                                          Danke für die Rückmeldung. Steht diese Information auch im Readme? Oder auf welche Description verweist du?
                                          Eine Konfiguration sollte IMMER - zumindest auch - via adminUI erfolgen. Dort sucht man die möglichen Einstellungen zuerst. Und dies ist auch das Konzept von Iobroker betreffend Konfiguration. (Weil im Kern könnte man natürlich admin UI auch ganz weglassen und alles via States / Files lösen 🙂 ).
                                          Bitte ergänze die adminUI - via Component STATE kannst du einen State direkt setzen - damit sollte das voll kompatibel verbesserbar sein. Wenn es wer via Script / VIA anpassen will, dann geht das via State und adminUI setzt auch den State. Damit ist keine Codeänderung notwendig,
                                          Siehe
                                          https://github.com/ioBroker/ioBroker.admin/blob/master/packages/jsonConfig/README.md#state
                                          https://github.com/ioBroker/ioBroker.admin/blob/master/packages/jsonConfig/README.md#setstate
                                          Bitte auch eine Konfiguration von nicht erwünschten Infos jedenfalls den Support in Admin einbauen. Wir wollen definitiv nicht in Zeiten vor Admin UI zurückfallen und die Konfiguration jetzt außerhalb vornehmen.
                                            arteck Developer Most Active @Lucky_ESA last edited by arteck
                                            @lucky_esa sagte in Adapter Worx Landroid v3.x.x:
                                            dann mach es bitte zusätzlich per Admin UI schaltbar. vor allem da es einfluss auf die Admin UI nimmt
                                            1.0k
                                            788
                                            123512
