    4. div. 404 Fehler im IOB (Admin)
      wsvd @Thomas Braun last edited by
      Dass letzte Backup war vom 29.01.25 und am 28. hatte ich die Adapter upgedated. Kann dann nicht auseinander sein.
        Thomas Braun Most Active @wsvd last edited by
        @wsvd
        Dann die Langfassung von
        iob diag
        Auch wenn die Zusammenfassung eigentlich keinen Hinweis auf was 'krummes' liefert.
          ========== Start marking the full check here ===========
          ```bash
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: odroid-m1-iob
                 Icon name: computer
                    Kernel: Linux 6.1.0-odroid-arm64
              Architecture: arm64
          OS is similar to:
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           18:47:57 up 7 min,  2 users,  load average: 1.22, 1.01, 0.51
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** TIME AND TIMEZONES ***
                         Local time: Sat 2025-02-01 18:47:57 CET
                     Universal time: Sat 2025-02-01 17:47:57 UTC
                           RTC time: Sat 2025-02-01 17:47:57
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          mario
          HOME=/home/mario
          GROUPS=mario cdrom floppy audio dip video plugdev users netdev iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:       tty
          *** MEMORY ***
          Mem:            7.8G        1.3G        6.0G        9.4M        618M        6.5G
          Swap:           5.0G          0B        5.0G
          Total:           12G        1.3G         11G
          Active iob-Instances:   13
                   7449 M total memory
                   1286 M used memory
                   1125 M active memory
                    352 M inactive memory
                   5743 M free memory
                     52 M buffer memory
                    537 M swap cache
                   4790 M total swap
                      0 M used swap
                   4790 M free swap
          top - 18:47:57 up 7 min,  2 users,  load average: 1.22, 1.01, 0.51
          Tasks: 152 total,   1 running, 151 sleeping,   0 stopped,   0 zombie
          %Cpu(s): 14.3 us, 14.3 sy,  0.0 ni, 57.1 id,  0.0 wa, 14.3 hi,  0.0 si,  0.0 st
          MiB Mem :   7449.3 total,   5743.1 free,   1286.2 used,    589.5 buff/cache
          MiB Swap:   4791.0 total,   4791.0 free,      0.0 used.   6163.1 avail Mem
          *** FAILED SERVICES ***
            UNIT                LOAD   ACTIVE SUB    DESCRIPTION
          * odroid-alsa.service loaded failed failed ODROID ALSA Setup Service
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          1 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  3.7G     0  3.7G   0% /dev
          tmpfs          tmpfs     745M  9.0M  736M   2% /run
          /dev/nvme0n1p2 ext4      112G  5.7G  101G   6% /
          tmpfs          tmpfs     3.7G     0  3.7G   0% /dev/shm
          tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
          tmpfs          tmpfs     128M   12K  128M   1% /var/log
          /dev/nvme0n1p1 ext2      457M   27M  406M   7% /boot
          tmpfs          tmpfs     745M     0  745M   0% /run/user/1000
          [Sat Feb  1 18:40:43 2025] EXT4-fs (nvme0n1p2): mounted filesystem with ordered data mode. Quota mode: none.
          [Sat Feb  1 18:40:44 2025] EXT4-fs (nvme0n1p2): re-mounted. Quota mode: none.
          Show mounted filesystems:
          TARGET  SOURCE                                                 FSTYPE OPTIONS
          /       /dev/disk/by-uuid/7d46186d-d54a-4af5-90d0-1567fa2a316b ext4   rw,relatime,errors=remount-ro
          `-/boot /dev/nvme0n1p1                                         ext2   rw,relatime,errors=continue
          /var:
          266M    /var/
          184M    /var/lib
          142M    /var/lib/apt/lists
          142M    /var/lib/apt
          83M     /var/cache
          No journal files were opened due to insufficient permissions.
          /opt/iobroker/backups:
          23M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.1G    /opt/iobroker/iobroker-data/
          1018M   /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          24M     /opt/iobroker/iobroker-data/files/echarts.admin/static/js/main.70a15e1f.js.map
          18M     /opt/iobroker/iobroker-data/files/echarts/preview/static/js/main.5fe9c7da.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.18.2
          /usr/bin/node           v20.18.2
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          nodejs:
            Installed: 20.18.2-1nodesource1
            Candidate: 20.18.2-1nodesource1
            Version table:
           *** 20.18.2-1nodesource1 500
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.1-1nodesource1 500
               20.18.0-1nodesource1 500
               20.17.0-1nodesource1 500
               20.16.0-1nodesource1 500
               20.15.1-1nodesource1 500
               20.15.0-1nodesource1 500
               20.14.0-1nodesource1 500
               20.13.1-1nodesource1 500
               20.13.0-1nodesource1 500
               20.12.2-1nodesource1 500
               20.12.1-1nodesource1 500
               20.12.0-1nodesource1 500
               20.11.1-1nodesource1 500
               20.11.0-1nodesource1 500
               20.10.0-1nodesource1 500
               20.9.0-1nodesource1 500
               20.8.1-1nodesource1 500
               20.8.0-1nodesource1 500
               20.7.0-1nodesource1 500
               20.6.1-1nodesource1 500
               20.6.0-1nodesource1 500
               20.5.1-1nodesource1 500
               20.5.0-1nodesource1 500
               20.4.0-1nodesource1 500
               20.3.1-1nodesource1 500
               20.3.0-1nodesource1 500
               20.2.0-1nodesource1 500
               20.1.0-1nodesource1 500
               20.0.0-1nodesource1 500
               18.19.0+dfsg-6~deb12u2 500
                  500 http://ftp.gwdg.de/debian bookworm/main arm64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org/debian-security bookworm-security/main arm64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          odroid-m1-iob       odroid-m1-iob (version: 7.0.6, hostname: odroid-m1-iob , alive, uptime: 425)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.4.10
          javascript:     8.8.3
          nodejs modules from github:     0
          Adapter State
          + system.adapter.admin.0                  : admin                 : odroid-m1-iob                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.backitup.0               : backitup              : odroid-m1-iob                            - disabled
          + system.adapter.discovery.0              : discovery             : odroid-m1-iob                            -  enabled
          + system.adapter.echarts.0                : echarts               : odroid-m1-iob                            -  enabled
            system.adapter.feiertage.0              : feiertage             : odroid-m1-iob                            -  enabled
          + system.adapter.hm-rega.0                : hm-rega               : odroid-m1-iob                            -  enabled
          + system.adapter.hm-rpc.0                 : hm-rpc                : odroid-m1-iob                            -  enabled
          + system.adapter.hm-rpc.1                 : hm-rpc                : odroid-m1-iob                            -  enabled
          + system.adapter.influxdb.0               : influxdb              : odroid-m1-iob                            -  enabled, port: 8086
          + system.adapter.javascript.0             : javascript            : odroid-m1-iob                            -  enabled
          + system.adapter.mqtt.0                   : mqtt                  : odroid-m1-iob                            -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.shelly.0                 : shelly                : odroid-m1-iob                            - disabled, port: 1884, bind: 0.0.0.0
          + system.adapter.sonoff.0                 : sonoff                : odroid-m1-iob                            -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.vis-bars.0               : vis-bars              : odroid-m1-iob                            - disabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : odroid-m1-iob                            - disabled
          + system.adapter.vis-inventwo.0           : vis-inventwo          : odroid-m1-iob                            -  enabled
            system.adapter.vis.0                    : vis                   : odroid-m1-iob                            -  enabled
          + system.adapter.web.0                    : web                   : odroid-m1-iob                            -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "shelly"       : 8.5.1    , installed 8.5.1
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.7.1
          Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
          Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "ws"           : 2.6.2    , installed 2.6.2
          Objects and States
          Objects:        1950
          States:         1591
          Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
          Hit:2 http://ftp.gwdg.de/debian bookworm InRelease
          Hit:3 http://ftp.gwdg.de/debian bookworm-updates InRelease
          Hit:4 https://repos.influxdata.com/debian stable InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Hit:6 http://ppa.linuxfactory.or.kr bookworm InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          2215       1/init
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11020      1223/sshd: /usr/sbi
          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        10048      1203/influxd
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       11289      1350/io.mqtt.0
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1642       1335/io.sonoff.0
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       10085      1242/iobroker.js-co
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1541       1242/iobroker.js-co
          tcp        0      0 192.168.230.199:2010    0.0.0.0:*               LISTEN      1001       12363      1414/io.hm-rpc.1
          tcp        0      0 192.168.230.199:2001    0.0.0.0:*               LISTEN      1001       1666       1399/io.hm-rpc.0
          tcp6       0      0 :::111                  :::*                    LISTEN      0          9538       1/init
          tcp6       0      0 :::22                   :::*                    LISTEN      0          11029      1223/sshd: /usr/sbi
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1686       1444/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1578       1262/io.admin.0
          tcp6       0      0 :::8086                 :::*                    LISTEN      999        10061      1203/influxd
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1266       1/init
          udp6       0      0 :::111                  :::*                                0          2216       1/init
          2025-02-01 18:41:27.235  - info: hm-rega.0 (1384) time difference local-ccu 0s
          2025-02-01 18:41:29.555  - info: hm-rega.0 (1384) request state values
          2025-02-01 18:41:30.779  - info: hm-rpc.0 (1399) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.2, js-controller: 7.0.6
          2025-02-01 18:41:31.153  - info: hm-rpc.0 (1399) xmlrpc server is trying to listen on 192.168.230.199:2001
          2025-02-01 18:41:31.156  - info: hm-rpc.0 (1399) xmlrpc client is trying to connect to 192.168.230.210:2001/ with ["http://192.168.230.211:2001","odroid-m1-iob:hm-rpc.0:e17154b5a40c67e5d6bab12d82c83565"]
          2025-02-01 18:41:31.267  - info: hm-rpc.0 (1399) Connected
          2025-02-01 18:41:31.587  - info: hm-rega.0 (1384) Updated all datapoints
          2025-02-01 18:41:32.089  - info: hm-rega.0 (1384) added/updated 1 objects
          2025-02-01 18:41:32.113  - info: hm-rega.0 (1384) got 9 variables
          2025-02-01 18:41:33.171  - info: hm-rega.0 (1384) added/updated 9 variables
          2025-02-01 18:41:33.174  - info: hm-rega.0 (1384) deleted 0 variables
          2025-02-01 18:41:33.323  - info: hm-rega.0 (1384) got 11 programs
          2025-02-01 18:41:34.303  - info: hm-rega.0 (1384) added/updated 11 programs
          2025-02-01 18:41:34.306  - info: hm-rega.0 (1384) deleted 0 programs
          2025-02-01 18:41:34.340  - info: hm-rega.0 (1384) update rooms to enum.rooms
          2025-02-01 18:41:34.401  - info: hm-rega.0 (1384) update functions to enum.functions
          2025-02-01 18:41:34.449  - info: hm-rega.0 (1384) update favorites to enum.favorites
          2025-02-01 18:41:34.840  - info: hm-rpc.1 (1414) starting. Version 2.0.2 in /opt/iobroker/node_modules/iobroker.hm-rpc, node: v20.18.2, js-controller: 7.0.6
          2025-02-01 18:41:35.101  - info: hm-rpc.1 (1414) xmlrpc server is trying to listen on 192.168.230.199:2010
          2025-02-01 18:41:35.104  - info: hm-rpc.1 (1414) xmlrpc client is trying to connect to 192.168.230.210:2010/ with ["http://192.168.230.211:2010","odroid-m1-iob:hm-rpc.1:049c08b7ce16b0b492e6b313c51d3859"]
          2025-02-01 18:41:35.220  - info: hm-rpc.1 (1414) Connected
          2025-02-01 18:41:38.407  - info: discovery.0 (1429) starting. Version 5.0.0 in /opt/iobroker/node_modules/iobroker.discovery, node: v20.18.2, js-controller: 7.0.6
          2025-02-01 18:41:45.343  - info: vis.0 (1459) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.18.2, js-controller: 7.0.6
          2025-02-01 18:41:47.310  - info: vis.0 (1459) Terminated (NO_ERROR): Without reason
          2025-02-01 18:41:52.665  - info: vis-inventwo.0 (1489) starting. Version 3.3.4 in /opt/iobroker/node_modules/iobroker.vis-inventwo, node: v20.18.2, js-controller: 7.0.6
          iob diag has finished.
            @wsvd sagte in div. 404 Fehler im IOB (Admin):
            Setz den mario in die Gruppe adm rein:
            sudo usermod -a -G adm mario
            exit
            Was ist das? Was odroid-spezifisches?
            Ansonsten sehe ich da nix ungewöhnliches.
              wsvd @Thomas Braun last edited by wsvd
              Ja genau. Vom Hersteller.
              PS:
              Da fehlt doch definitiv was (Icons).
                wsvd @wsvd last edited by wsvd
                Noch was Neues:
                Klicke ich auf Return to Home dann ist plötzlich alles wieder verfügbar.
                Also ich kann es mir nicht erklären 😞
                • O
                  Oceanwaves @wsvd last edited by
                  Ich habe hier seit kurzem ein ähnliches Problem.
                  Ich will mich an ioBroker anmelden, habe dafür im Firefox ein Lesezeichen, das http://<ip des pi5>:8081 aufruft.
                  Im Browser see ich dann eine Weiterleitung auf http://<ip des pi5>:8081/login?href=#tab-intro und bekomme dann die Fehlermeldung
                  404
                  Oops! The page you're looking for can't be found. 😔
                  File /login?href= not found
                  Darunter ein Link "Return to Home", der wieder auf http://<ip des pi5>:8081 verweist. Wenn ich den dann anklicke, läuft die Anmeldung sauber durch und ich lande in der Übersicht.
                  • O
                    Oceanwaves @Oceanwaves last edited by Homoran
                    Habe die Ursache meines Problems wohl zufällig gefunden, als ich auf der Suche danach war, warum ich im Log immer wieder "error socket.io [init] Cannot detect user" gefunden habe. Kam wohl mit admin-7.6.3. Mit 7.6.4 scheint das socket.io-Problem behoben zu sein. Aber mit 7.6.3 kam gleichzeitig ein Problem beim Login, wenn man einen Passwort-Manager benutzt (hier Enpass).
                    Beschrieben ist das Problem hier: [bug]: Login with password manager no longer possible]: https://github.com/ioBroker/ioBroker.admin/issues/3047
                    Soll mit 7.6.7 behoben sein, habe ich aber noch nicht installiert, momentan kann ich damit leben, muss ich halt das PW über Copy/Paste einfügen...
                    UncleSamSwiss created this issue in ioBroker/ioBroker.admin
                    closed [bug]: Login with password manager no longer possible #3047
                    • Codierknecht
                      Codierknecht Developer Most Active @Oceanwaves last edited by Codierknecht
                      @oceanwaves sagte in div. 404 Fehler im IOB (Admin):
                      oder alternativ auf die Anmeldung verzichten.
                      Wenn im Haus keine böswilligen Pupertisten wohnen, kann man ja wohl darauf verzichten.
                        da stimmt was mit den internen iobroker rechten nicht für den user
                        zeigmal die benutzer .. und deren rechte
                        • O
                          Oceanwaves @Codierknecht last edited by
                          @codierknecht said in div. 404 Fehler im IOB (Admin):
                          So oft melde ich mich nicht an. Und an dem Problem mit dem PW-Manager wird ja gearbeitet.
                          • Codierknecht
                            @oceanwaves
                            Da unsere Vögelchen bereits ausgeflogen sind, kann ich auf einen Login verzichten. Eine potenzielle Fehlerquelle weniger 😉
                            1379
