    4. Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed
      trojanhector @OliverIO last edited by
      @oliverio
      Das scheint sich auch auf das JSON Widget 0.1.9 auszuwirken. Habe hier auch Fehlermeldungen mit Bezug auf RSS-FEED (3.3.1).
      Hier der Log aus der Console.
      load script:41
                 GET http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js net::ERR_ABORTED 404 (Not Found)
      (anonymous) @ load script:41
      (anonymous) @ jsonp chunk loading:43
      (anonymous) @ ensure chunk:6
      (anonymous) @ ensure chunk:5
      ./RSSArticleMarqueeV5 @ container-entry:6
      a @ container-entry:28
      (anonymous) @ visLoadWidgets.tsx:144
      await in (anonymous)
      (anonymous) @ visLoadWidgets.tsx:177
      a @ visLoadWidgets.tsx:173
      (anonymous) @ visLoadWidgets.tsx:326
      Promise.then
      (anonymous) @ visLoadWidgets.tsx:254
      Promise.then
      r @ visLoadWidgets.tsx:225
      (anonymous) @ visWidgetsCatalog.tsx:302
      c @ helpers.ts:98
      setTimeout
      (anonymous) @ browserapierrors.ts:109
      (anonymous) @ visWidgetsCatalog.tsx:301
      collectRxInformation @ visWidgetsCatalog.tsx:300
      onWidgetsLoaded @ Editor.jsx:813
      onLoaded @ Editor.jsx:1028
      loadWidgets @ visEngine.jsx:1529
      await in loadWidgets
      (anonymous) @ visEngine.jsx:208
      Promise.then
      O @ visEngine.jsx:196
      cs @ react-dom.production.min.js:184
      Vs @ react-dom.production.min.js:197
      Hi @ react-dom.production.min.js:291
      Ml @ react-dom.production.min.js:279
      gl @ react-dom.production.min.js:279
      fl @ react-dom.production.min.js:279
      rl @ react-dom.production.min.js:267
      S @ scheduler.production.min.js:13
      T @ scheduler.production.min.js:14Understand this errorAI
      load script:41
                 GET http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_colors_blue_js-node_modules_mui_material_colors_common_js-n-6f5860.f842f4ec.chunk.js net::ERR_ABORTED 404 (Not Found)
      Promise.then
      Promise.then
      c @ helpers.ts:98
      setTimeout
      Promise.then
      console.ts:40 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: ChunkLoadError: Loading chunk vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64 failed.
      (error: http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js)
      (anonymous) @ console.ts:40
      (anonymous) @ visLoadWidgets.tsx:197
      Promise.catch
      (anonymous) @ visLoadWidgets.tsx:196
      Promise.then
      Promise.then
      c @ helpers.ts:98
      setTimeout
      Promise.then
      console.ts:40 Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {"message":"Loading chunk vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64 failed.\n(error: http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js)","name":"ChunkLoadError","type":"error","request":"http://192.168.178.62:8082/vis-2/widgets/vis-2-widgets-rssfeed/static/js/vendors-node_modules_mui_material_styles_styled_js-node_modules_mui_material_styles_useThemeP-598e64.71a877cf.chunk.js"}
      • OliverIO
        OliverIO @trojanhector last edited by OliverIO
        @trojanhector
        Ja
        Das neue Widget wurde in der kompilation nicht mit übernommen.
        Irgendwas wurde an den basisbibliotheken für den Build verändert, was ich aber noch herausfinden muss.
        Bluefox will/hat auf ein komplett neues Build-System umstellen (vite), hat aber bisher erst für typescript adapter Beispiele. Für JavaScript müsste es auch funktionieren, benötige da aber wieder mal F+E Zeit, die gerade nicht da ist.
        Daher aktuell bitte noch v4 verwenden. Da fehlt halt daspopup Feature. Die neue Version v5 habe ich gemacht, das der Wechsel bewusst erfolgt, da nun mehr Eigenschaften für das Widget eingegeben werden müssen.
        • OliverIO
          Neue Version rssfeed 3.5.0
          Das Update betrifft aktuell nur den rssfeed adapter + die vis1 widgets, nicht den vis-2 adapter
          • in den templates des jsonTemplate widgets können nun auch async/await funktionen verwendet werden. Siehe Beispiel in der Dokumentation: JSON Template mit async/await
          • OliverIO
            OliverIO last edited by OliverIO
            Neue Version vis-2-widgets-rssfeed 1.1.2
            Die build-Probleme konnte ich beheben, auch wenn mir die Ursache dafür unerklärlich ist.
            Somit wäre das popup-Feature für das Marquee Widget (widget version 5) auch funktionsfähig.
            @Oli Bitte testen
            @trojanhector sagte in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
            Das JSON widget dürfte das unter vis2 nicht betreffen, da dieses widget sich nun im adapter vis-2-widgets-ovarous befindet. Aber du hast wahrscheinlich beide installiert, somit siehst du die rssfeed fehlermeldungen.
            O OliverIO 3 Replies Last reply Reply Quote 0
            • OliverIO
              Ich poste das hier auch mal rein.
              das Widget JSON Template für vis-2 befindet sich ja nun im Adapter vis-2-widgets-ovarious
              dafür gibt es nun ein Update
              Neue Version 1.0
              • das feature async/await wurde ergänzt, d.h. auch hier können nun Funktionen mit async/await definiert und verwendet werden.
              • OliverIO
                Der Usecase für die interaktive Todolist mit direkter Datenbank-Kommunikation wurde nun hinzugefügt
                https://github.com/oweitman/ioBroker.rssfeed?tab=readme-ov-file#use-case-for-a-database-supported-task-list
                vlg auch hier
                https://forum.iobroker.net/topic/80347/button-wert-aus-der-vis-in-sql-eintragen-speichern/11?_=1742498938735
                • O
                  Oli @OliverIO last edited by
                  @oliverio
                  sorry für die späte Antwort. Das neue "marquee widget 5" wird jetzt mit angezeigt
                  • OliverIO
                    OliverIO @Oli last edited by
                    @oli
                    • OliverIO
                      OliverIO @OliverIO last edited by
                      Die Version 1.1.2 befindet sich nun im stable
                      @oliverio sagte in Test/Support für Adapter rssfeed und vis-2-widgets-rssfeed:
                      @Oli Bitte testen
                      • OliverIO
                        Diese Version ist nun auf Stable verfügbar
                        Neue Version rssfeed 3.5.2
                        • OliverIO
                          Neue Version iobroker.vis-2-widgets-rssfeed 1.2.0
                          • Das compiler framework wurde von CRA auf vite umgestellt
                          • Das deprecated widget RSSMarquee wurde entfernt. RSSMarquee5 ist bereits seit einigen Versionen verfügbar
                          Es wäre schön, wenn das noch jemand bei sich testen könnte, da die zugrundeliegenden Änderungen umfangreich waren. An der Nutzerfunktionalität dürfte sich nichts geändert haben.
                          • OliverIO
                            Diese Version befindet sich nun auch im stable repository
                              @oliverio Servus,
                              bei mir verschwinden die Widgets bei v 1.2.0. Sowohl im Editor für VIS als auch auf der Homepage.
                              Nach Rückstellen auf 1.1.2 sind sie wieder da.
                              Verfügbar: 7.0.6
                              Installiert: 7.0.6
                              Plattform: linux
                              Betriebssystem: linux
                              Architektur: arm64
                              Node.js: v20.19.3
                              RSS Feed: 3.5.2
                              NPM: 10.8.2
                              _npmNewest: 10.8.2
                              _nodeNewestNext: 20.19.3
                              _nodeNewest: 20.19.3
                              _npmCurrent: 10.8.2
                              _npmNewestNext: 10.8.2
                              _nodeCurrent: 20.19.3
                              • OliverIO
                                @trojanhector
                                Bitte einmal auf der Konsole
                                iob upload all
                                Und wenn dann immer noch nicht, dann bitte
                                Evtl Fehlermeldungen auf der Browser Konsole mit f12 schauen
                                  @oliverio
                                  es geht nacht iob updload all leider immer noch nicht.
                                  Der Browser wirft folgende Fehlermeldungen:
                                  • OliverIO
                                    @trojanhector
                                    Ja das ist eigentlich der Fehler der mit Upload sich erledigt.
                                    Diendatei ist im aktuellen Paket auch enthalten und wurde im Beta bereits mehrfach installiert
                                    Starte bitte auch mal noch den vis-2 Adapter neu
                                    Iob Upload all dauert auch eine weile
                                    T O 2 Replies Last reply Reply Quote 0
                                      @oliverio
                                      Der Adapter wurde neu gestartet, die Homepage neu aufgerufen. Es gibt keine Änderung.
                                      T OliverIO 2 Replies Last reply Reply Quote 0
                                      • O
                                        @oliverio
                                        ich habe das gleiche Problem wie @trojanhector, ein "iob upload all" und ein Neustart des VIS-2 Adapters bringt keinen Erfolg.
                                        Installierte VIS-Version: 2.9.64
                                        Uncaught SyntaxError: Cannot use import statement outside a module
                                        visLoadWidgets.tsx:197  Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: Error: Cannot load vis2rssfeedWidgets from ./widgets/vis-2-widgets-rssfeed/customWidgets.js
                                        visLoadWidgets.tsx:198  Cannot load widget system.adapter.vis-2-widgets-rssfeed.0: {}
                                        (anonymous) @ visLoadWidgets.tsx:198
                                          trojanhector @trojanhector last edited by
                                          @trojanhector
                                          Ich habe auf VIS-2 2.12.10 upgedatet. Da sind die Widgets wieder da.
                                          • OliverIO
                                            @trojanhector
                                            Ich versuche morgen oder übermorgen mal das nachzustellen.
                                            Ok ich schaue mal ob es an vis2 2.9.64 liegt und muss dann ggfs. Die requirements noch anpassen.
                                            adapter atom feed iobroker.rssfeed rdf rss vis widget
                                            34
                                            674
                                            140618
