    4. Adapter Hyundai (Bluelink) oder KIA (UVO)
      @baeckerman83 installier nochmal bitte
      da sollte jetzt ein warning kommen.. den mal posten bitte
        A Former User @baeckerman83 last edited by
        @baeckerman83
        und mach bitte die iobroker updates.. das ist ja n Sack voll... js-controller v6.x
        auf beiden, du hast ja Master/Slave..
          marchusar last edited by
          Hallo, leider geht bei mir die 3.1.2 (und 3.1.1) auch nicht, nur die 3.1.0 läuft einwandfrei.
          Kann jemand helfen?
          2025-04-30 12:20:46.720 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" started with pid 13114
          2025-04-30 12:20:50.090 - info: bluelink.0 (13114) starting. Version 3.1.2 in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
          2025-04-30 12:20:50.120 - info: bluelink.0 (13114) Login to api
          2025-04-30 12:20:52.354 - info: bluelink.0 (13114) 1 Vehicles found
          2025-04-30 12:20:52.518 - info: bluelink.0 (13114) Read new update for KNAC381xxx from the server
          2025-04-30 12:20:53.510 - error: bluelink.0 (13114) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-04-30 12:20:53.511 - error: bluelink.0 (13114) unhandled promise rejection: The state contains the forbidden properties day, time!
          2025-04-30 12:20:53.514 - error: bluelink.0 (13114) Error: The state contains the forbidden properties day, time!
          at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:299:13)
          at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4984:21)
          at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4962:17)
          at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:133:30)
          at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:21)
          at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17)
          at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
          2025-04-30 12:20:53.514 - error: bluelink.0 (13114) The state contains the forbidden properties day, time!
          2025-04-30 12:20:53.523 - info: bluelink.0 (13114) Adapter bluelink cleaned up everything...
          2025-04-30 12:20:53.524 - info: bluelink.0 (13114) terminating
          2025-04-30 12:20:53.526 - warn: bluelink.0 (13114) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-04-30 12:20:53.532 - error: bluelink.0 (13114) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-04-30 12:20:53.533 - error: bluelink.0 (13114) unhandled promise rejection: The state contains the forbidden properties day, time!
          2025-04-30 12:20:53.534 - error: bluelink.0 (13114) Error: The state contains the forbidden properties day, time!
          2025-04-30 12:20:53.535 - error: bluelink.0 (13114) The state contains the forbidden properties day, time!
          2025-04-30 12:20:54.027 - info: bluelink.0 (13114) terminating
          2025-04-30 12:20:54.035 - warn: bluelink.0 (13114) get state error: Connection is closed.
          2025-04-30 12:20:54.041 - warn: bluelink.0 (13114) get state error: Connection is closed.
          2025-04-30 12:20:54.046 - error: bluelink.0 (13114) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.smartKeyBatteryWarning": DB closed
          2025-04-30 12:20:54.048 - warn: bluelink.0 (13114) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.windowOpen.backLeft: DB closed
          2025-04-30 12:20:54.049 - warn: bluelink.0 (13114) get state error: Connection is closed.
          2025-04-30 12:20:54.050 - error: bluelink.0 (13114) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
          2025-04-30 12:20:54.051 - error: bluelink.0 (13114) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.smartKeyBatteryWarning: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.smartKeyBatteryWarning": DB closed
          2025-04-30 12:20:54.054 - error: bluelink.0 (13114) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.washerFluidStatus": Connection is closed.
          2025-04-30 12:20:54.057 - error: bluelink.0 (13114) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
          2025-04-30 12:20:54.058 - error: bluelink.0 (13114) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.washerFluidStatus: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.washerFluidStatus": Connection is closed.
          2025-04-30 12:20:54.247 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2025-04-30 12:20:54.248 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
          2025-04-30 12:20:54.248 - warn: host.raspberrypi4 Do not restart adapter system.adapter.bluelink.0 because restart loop detected
          iob diag
           Static hostname: raspberrypi4
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 12 (bookworm)
                    Kernel: Linux 5.10.103-v7l+
              Architecture: arm
          Installation:           native
          Kernel:                 armv7l
          Userland:               32 bit
          Timezone:               Europe/Berlin (CEST, +0200)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            multi-user.target
          Pending OS-Updates:     0
          Pending iob updates:    1
          Nodejs-Installation:
          /usr/bin/nodejs         v20.19.1
          /usr/bin/node           v20.19.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.31.0
          Recommended versions are nodejs 20.19.1 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            4.0G        1.8G        1.4G        1.1M        990M        2.3G
          Swap:           209M          0B        209M
          Total:          4.2G        1.8G        1.6G
          Active iob-Instances:   19
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.6
                                  admin                   7.6.3
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : raspberrypi4                             -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          + system.adapter.admin.1                  : admin                 : raspberrypi4                             -  enabled, port: 11443, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.web.0                    : web                   : raspberrypi4                             -  enabled, port: 11444, bind: 0.0.0.0 (SSL), run as: admin
          + system.adapter.web.1                    : web                   : raspberrypi4                             -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
          Objects:                4326
          States:                 3543
          Size of iob-Database:
          23M     /opt/iobroker/iobroker-data/objects.jsonl
          7.8M    /opt/iobroker/iobroker-data/objects.json.migrated
          7.8M    /opt/iobroker/iobroker-data/objects.json.bak.migrated
          2.9M    /opt/iobroker/iobroker-data/states.jsonl
          836K    /opt/iobroker/iobroker-data/states.json.migrated
          836K    /opt/iobroker/iobroker-data/states.json.bak.migrated
          Operating System is the current Debian stable version codenamed 'bookworm'!
          ? Meister Mopper 2 Replies Last reply Reply Quote 0
            A Former User @marchusar last edited by
            @marchusar
            welches Fahrzeug?
            • Meister Mopper
              Meister Mopper @marchusar last edited by
              @marchusar
              Schick mal bitte die Langfassung von iob diag .
                marchusar @Guest last edited by
                @neuschwansteini Kia EV6 2024 (vor FL)
                  @marchusar
                  bei Kia kenn ich mich nich aus, ist das mit ccNC Infotainment? was bedeutet (vor FL) ???
                    @neuschwansteini Vor Facelift, also noch das alte Entertainment System.
                      marchusar @Meister Mopper last edited by marchusar
                      *** iob diag is starting up, please wait ***
                      iob diag needs to be updated. Please execute 'iobroker fix' first.
                      *** ioBroker Diagnosis ***
                      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
                      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                      https://forum.iobroker.net
                      Just copy and paste the Summary Page, including the ``` characters at start and end.
                      It helps us to help you!
                      * Some output is masked. For full results please use 'iob diag --unmask' *
                      Press any key to continue
                      ========== Start marking the full check here ===========
                      ```bash
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                             Icon name: computer
                          Architecture: arm
                      OS is similar to: debian
                      Model		: Raspberry Pi 4 Model B Rev 1.1
                      Docker          : false
                      Virtualization  : none
                      Kernel          : armv7l
                      Userland        : 32 bit
                      Systemuptime and Load:
                       16:20:36 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** TIME AND TIMEZONES ***
                                     Local time: Wed 2025-04-30 16:20:36 CEST
                                 Universal time: Wed 2025-04-30 14:20:36 UTC
                                       RTC time: n/a
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      pi
                      HOME=/home/pi
                      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                      *** DISPLAY-SERVER SETUP ***
                      Desktop:
                      Terminal: 	tty
                      *** MEMORY ***
                      Mem:            4.0G        1.7G        1.5G        1.1M        1.0G        2.3G
                      Swap:           209M          0B        209M
                      Total:          4.2G        1.7G        1.7G
                               3837 M total memory
                               1647 M used memory
                                449 M active memory
                               1820 M inactive memory
                               1397 M free memory
                                295 M buffer memory
                                662 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      top - 16:20:37 up 35 days,  5:56,  2 users,  load average: 0.21, 0.44, 0.39
                      Tasks: 196 total,   1 running, 195 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 22.2 sy,  0.0 ni, 77.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   3837.7 total,   1396.7 free,   1648.8 used,    957.9 buff/cache
                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   2189.0 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      Filesystem                    Type      Size  Used Avail Use% Mounted on
                      /dev/root                     ext4      917G   16G  865G   2% /
                      devtmpfs                      devtmpfs  1.8G     0  1.8G   0% /dev
                      tmpfs                         tmpfs     1.9G     0  1.9G   0% /dev/shm
                      tmpfs                         tmpfs     768M  928K  767M   1% /run
                      tmpfs                         tmpfs     5.0M   16K  5.0M   1% /run/lock
                      /dev/sda1                     vfat      253M   49M  204M  20% /boot
                      //192.168.178.5/Data/ioBroker cifs      3.6T  3.1T  567G  85% /opt/iobroker/backups
                      tmpfs                         tmpfs     384M     0  384M   0% /run/user/1000
                      Show mounted filesystems:
                      TARGET                  SOURCE                        FSTYPE OPTIONS
                      /                       /dev/sda2                     ext4   rw,noatime
                      |-/boot                 /dev/sda1                     vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
                      `-/opt/iobroker/backups //192.168.178.5/Data/ioBroker cifs   rw,relatime,vers=3.0,cache=strict,username=marc,uid=1001,forceuid,gid=1001,forcegid,addr=192.168.178.5,file_mode=0777,dir_mode=0777,soft,nounix,serverino,mapposix,rsize=4194304,wsize=4194304,bsize=1048576,echo_interval=60,actimeo=1
                      /var:
                      3.8G	/var/
                      2.4G	/var/log/journal/416a7ba8464c4fd4b4fcb0daf197cbfb
                      2.4G	/var/log
                      665M	/var/lib
                      Archived and active journals take up 2.3G in the file system.
                      /opt/iobroker/backups:
                      285M	/opt/iobroker/backups/
                      20K	/opt/iobroker/backups/cert
                      0	/opt/iobroker/backups/redistmp
                      /opt/iobroker/iobroker-data:
                      1.4G	/opt/iobroker/iobroker-data/
                      831M	/opt/iobroker/iobroker-data/files
                      617M	/opt/iobroker/iobroker-data/files/javascript.admin
                      560M	/opt/iobroker/iobroker-data/files/javascript.admin/static
                      558M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      19M	/opt/iobroker/iobroker-data/files/iot.admin/static/js/main.904d455f.js.map
                      17M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/2.e96554dd.chunk.js.map
                      8.7M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                      8.6M	/opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                      USB-Devices by-id:
                      /dev/serial/by-id/usb-Texas_Instruments_CC2538_USB_CDC-if00
                      *** ZigBee Settings ***
                      HINT:
                      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
                      /dev/ttyACM0
                      Zigbee Network Settings on your coordinator/in nvbackup are:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      To unmask the settings run 'iob diag --unmask'
                      *** NodeJS-Installation ***
                      /usr/bin/npm 		10.8.2
                      /usr/bin/npx 		10.8.2
                      nodejs:
                        Installed: 20.19.1-1nodesource1
                        Candidate: 20.19.1-1nodesource1
                        Version table:
                       *** 20.19.1-1nodesource1 1001
                              500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
                              100 /var/lib/dpkg/status
                           20.19.0-1nodesource1 1001
                           20.18.3-1nodesource1 1001
                           20.18.2-1nodesource1 1001
                           20.18.1-1nodesource1 1001
                           20.18.0-1nodesource1 1001
                           20.17.0-1nodesource1 1001
                           20.16.0-1nodesource1 1001
                           20.15.1-1nodesource1 1001
                           20.15.0-1nodesource1 1001
                           20.14.0-1nodesource1 1001
                           20.13.1-1nodesource1 1001
                           20.13.0-1nodesource1 1001
                           20.12.2-1nodesource1 1001
                           20.12.1-1nodesource1 1001
                           20.12.0-1nodesource1 1001
                           20.11.1-1nodesource1 1001
                           20.11.0-1nodesource1 1001
                           20.10.0-1nodesource1 1001
                           20.9.0-1nodesource1 1001
                           20.8.1-1nodesource1 1001
                           20.8.0-1nodesource1 1001
                           20.7.0-1nodesource1 1001
                           20.6.1-1nodesource1 1001
                           20.6.0-1nodesource1 1001
                           20.5.1-1nodesource1 1001
                           20.5.0-1nodesource1 1001
                           20.4.0-1nodesource1 1001
                           20.3.1-1nodesource1 1001
                           20.3.0-1nodesource1 1001
                           20.2.0-1nodesource1 1001
                           20.1.0-1nodesource1 1001
                           20.0.0-1nodesource1 1001
                           18.19.0+dfsg-6~deb12u2+rpi1 500
                              500 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm/main armhf Packages
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      raspberrypi4        raspberrypi4 (version: 7.0.6, hostname: raspberrypi4  , alive, uptime: 3045397)
                      Core adapters versions
                      admin: 		7.6.3
                      javascript: 	8.8.3
                      nodejs modules from github: 	0
                      Adapter State
                      + system.adapter.backitup.0               : backitup              : raspberrypi4                             -  enabled
                        system.adapter.bluelink.0               : bluelink              : raspberrypi4                             -  enabled
                        system.adapter.chromecast.0             : chromecast            : raspberrypi4                             - disabled
                        system.adapter.discovery.0              : discovery             : raspberrypi4                             - disabled
                        system.adapter.flot.0                   : flot                  : raspberrypi4                             - disabled
                      + system.adapter.history.0                : history               : raspberrypi4                             -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi4                             -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12001
                      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi4                             -  enabled, port: 12010
                        system.adapter.ical.0                   : ical                  : raspberrypi4                             -  enabled
                        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4                             -  enabled
                        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : raspberrypi4                             - disabled
                      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4                             -  enabled
                      + system.adapter.javascript.0             : javascript            : raspberrypi4                             -  enabled
                      + system.adapter.node-red.0               : node-red              : raspberrypi4                             -  enabled, port: 1880, bind: 0.0.0.0 (SSL)
                      + system.adapter.radar2.0                 : radar2                : raspberrypi4                             -  enabled
                      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4                             -  enabled
                        system.adapter.sayit.0                  : sayit                 : raspberrypi4                             - disabled
                        system.adapter.sayit.1                  : sayit                 : raspberrypi4                             - disabled
                      + system.adapter.sonoff.0                 : sonoff                : raspberrypi4                             -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.tuya.0                   : tuya                  : raspberrypi4                             -  enabled
                        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : raspberrypi4                             - disabled
                        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : raspberrypi4                             - disabled
                        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : raspberrypi4                             - disabled
                        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : raspberrypi4                             - disabled
                        system.adapter.vis-justgage.0           : vis-justgage          : raspberrypi4                             - disabled
                        system.adapter.vis-map.0                : vis-map               : raspberrypi4                             -  enabled
                        system.adapter.vis-metro.0              : vis-metro             : raspberrypi4                             - disabled
                        system.adapter.vis-rgraph.0             : vis-rgraph            : raspberrypi4                             - disabled
                        system.adapter.vis-timeandweather.0     : vis-timeandweather    : raspberrypi4                             - disabled
                        system.adapter.vis.0                    : vis                   : raspberrypi4                             -  enabled
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : raspberrypi4                             -  enabled
                      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4                             -  enabled, port: /dev/ttyACM0
                      + instance is alive
                      ioBroker-Repositories
                      Active repo(s): stable
                      Installed ioBroker-Adapters
                      Used repository: stable
                      Adapter    "admin"        : 7.6.3    , installed 7.6.3
                      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                      Adapter    "bluelink"     : 2.3.6    , installed 3.1.2
                      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
                      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
                      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
                      Adapter    "ical"         : 1.16.1   , installed 1.16.1
                      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
                      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
                      Controller "js-controller": 7.0.6    , installed 7.0.6
                      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
                      Adapter    "radar2"       : 2.2.0    , installed 2.2.0
                      Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                      Adapter    "sayit"        : 5.0.0    , installed 5.0.0
                      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                      Adapter    "synochat"     : 1.3.3    , installed 1.3.3
                      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
                      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                      Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
                      Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                      Adapter    "web"          : 7.0.8    , installed 7.0.8
                      Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
                      Adapter    "ws"           : 2.6.2    , installed 2.6.2
                      Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
                      Objects and States
                      Objects: 	4326
                      States: 	3542
                      Hit:1 http://ftp.halifax.rwth-aachen.de/raspbian/raspbian bookworm InRelease
                      Hit:2 http://archive.raspberrypi.org/debian bookworm InRelease
                      Hit:3 http://raspbian.raspberrypi.org/raspbian bookworm InRelease
                      Hit:4 https://apt.pivccu.de/piVCCU stable InRelease
                      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Reading package lists...
                      Pending Updates: 0
                      *** Listening Ports ***
                      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          15423      931/dnsmasq
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          13750      924/sshd: /usr/sbin
                      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       23465327   7089/node-red
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       19535      2327/io.sonoff.0
                      tcp        0      0 192.168.178.6:12001     0.0.0.0:*               LISTEN      1001       19761      2406/io.hm-rpc.0
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       15040      856/iobroker.js-con
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       15035      856/iobroker.js-con
                      tcp        0      0 192.168.178.6:12010     0.0.0.0:*               LISTEN      1001       18305      2537/io.hm-rpc.1
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       10403573   13791/io.admin.0
                      tcp6       0      0 :::11443                :::*                    LISTEN      1001       23463646   6962/io.admin.1
                      tcp6       0      0 :::8083                 :::*                    LISTEN      1001       10394353   12831/io.web.1
                      tcp6       0      0 :::11444                :::*                    LISTEN      1001       23463849   7041/io.web.0
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          15404      924/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:47941           0.0.0.0:*                           108        13544      477/avahi-daemon: r
                      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       18362      2657/io.tuya.0
                      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       18363      2657/io.tuya.0
                      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          15422      931/dnsmasq
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           1001       16377      2315/io.radar2.0
                      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          15419      931/dnsmasq
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        13542      477/avahi-daemon: r
                      udp6       0      0 :::51335                :::*                                108        13545      477/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                108        13543      477/avahi-daemon: r
                      2025-04-30 16:17:36.147  - error: bluelink.0 (26380) Error: The state contains the forbidden properties day, time!
                      2025-04-30 16:17:36.148  - error: bluelink.0 (26380) The state contains the forbidden properties day, time!
                      2025-04-30 16:17:36.640  - info: bluelink.0 (26380) terminating
                      2025-04-30 16:17:36.650  - warn: bluelink.0 (26380) get state error: Connection is closed.
                      2025-04-30 16:17:36.656  - warn: bluelink.0 (26380) get state error: Connection is closed.
                      2025-04-30 16:17:36.664  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
                      2025-04-30 16:17:36.666  - warn: bluelink.0 (26380) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.breakOilStatus: DB closed
                      2025-04-30 16:17:36.667  - warn: bluelink.0 (26380) get state error: Connection is closed.
                      2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.[object Object]
                      2025-04-30 16:17:36.668  - error: bluelink.0 (26380) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.time": DB closed
                      2025-04-30 16:17:36.672  - error: bluelink.0 (26380) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.remoteWaitingTimeAlert": Connection is closed.
                      2025-04-30 16:17:36.848  - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2025-04-30 16:17:36.848  - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
                      2025-04-30 16:17:36.849  - warn: host.raspberrypi4 Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                      2025-04-30 16:20:00.015  - info: javascript.0 (2234) script.js.common.Kia.Update_from_Server: Refresh vehicle status from Server.
                      iob diag has finished.
                        @marchusar probier dann mal die Stable 2.3.6, bzw 2.3.7 die sind mit dem alten Infotainment gut gelaufen.
                        Darauf achten, dass die Daten vom Server geholt werden, sonst zieht's dir die 12V leer...
                          @neuschwansteini Die 3.1.0 läuft bei mir einwandfrei. Nur die 3.1.1 und 3.1.2 laufen nicht. Und ich hatte mich auf die Streckendaten gefreut, die nun wieder drin sein sollen
                            @marchusar
                            achsooooooooooooooooooooo...
                            na, das ist noch im Dev... das kann dauern.. kommt drauf an, wie @arteck Zeit und Lust hat..
                              @neuschwansteini Wäre schön ... es schreiben halt ein paar, dass es bei denen läuft nachdem sie PIN und Passwort neu gesetzt haben - das habe ich schon versucht... dann bleibe ich bei 3.1.0 bis ich was anderes lese ...
                              • Meister Mopper
                                @marchusar
                                Ich habe einen Niro EV '22 und bleibe auch erstmal bei der v3.1.0 im stable, weil die nachfolgenden Versionen noch nicht verlässlich funktionieren.
                                Mit der v3.1.0 bekomme ich zumindest von den Kia-Servern mehr oder weniger regelmäßig Daten (Kia ist offenbar ständig am basteln). Das Fzg steuern kann ich jedoch mit der v3.1.0 zuverlässig.
                                Hat zwar vermutlich nichts mit deinem Problem zu tun, aber:
                                Warum fährst du auf dem RPI4 ein 32-Bit System?
                                Warum sind zwei Admin installiert?
                                Wozu verwendest du den web.1?
                                Das solltest du anpassen:
                                HINT:
                                /dev/ttyACM0
                                  arteck Developer Most Active @marchusar last edited by arteck
                                  @marchusar sagte in Adapter Hyundai (Bluelink) oder KIA (UVO):
                                  installier mal die GIT
                                  https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck
                                  im LOG wird jetzt ein error mit dem anfange PARSECHECK stehen..
                                  poste mal die Zeilen vor dem abbruch.. vielleicht kann ich da schon was sehen
                                  sonst
                                  brauch ich deine Login Daten . das Problem ist mir bekannt aber ich kann es nicht nachstellen da mein PHEV in diesen Teil des sources nicht reinläuft..
                                  die und pin nicht vergessen
                                  @Neuschwansteini FL = FaceLift
                                  MaBu59 M 3 Replies Last reply Reply Quote 0
                                  • MaBu59
                                    MaBu59 @arteck last edited by MaBu59
                                    @arteck
                                    Ich verfolge schon länger die Posts hier. Bei mir läuft auch nur die Version 3.1.0, Ich habe den Adapter kompett gelöscht und mit deiner URL frisch installiert.
                                    Das sind die Zeilen aus dem Log.
                                    Ich hoffe, sie helfen dir weiter.
                                    Den Adapter finde ich richtig toll. Danke für deinen unermüdlichen Einsatz SUPER!!
                                    Manfred
                                    2025-05-02 18:57:13.468 - info: host.iobroker-pi iobroker url https://github.com/Newan/ioBroker.bluelink/tarball/parsecheck --host iobroker-pi --debug
                                    2025-05-02 18:57:15.779 - info: host.iobroker-pi iobroker install Newan/ioBroker.bluelink#parsecheck
                                    2025-05-02 18:57:16.119 - info: host.iobroker-pi iobroker NPM version: 10.8.2
                                    2025-05-02 18:57:16.121 - info: host.iobroker-pi iobroker Installing Newan/ioBroker.bluelink#parsecheck... (System call)
                                    2025-05-02 18:57:27.369 - info: host.iobroker-pi iobroker
                                    2025-05-02 18:57:27.370 - info: host.iobroker-pi iobroker removed 120 packages, and changed 1 package in 11s
                                    2025-05-02 18:57:27.372 - info: host.iobroker-pi iobroker 280 packages are looking for funding run `npm fund` for details
                                    2025-05-02 18:57:27.464 - info: host.iobroker-pi iobroker upload [1] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/bluelink.png bluelink.png image/png
                                    2025-05-02 18:57:27.479 - info: host.iobroker-pi iobroker upload [0] bluelink.admin /opt/iobroker/node_modules/iobroker.bluelink/admin/jsonConfig.json jsonConfig.json application/json
                                    2025-05-02 18:57:27.492 - info: host.iobroker-pi iobroker Updating objects from io-package.json for adapter "bluelink" with version "3.1.2"
                                    2025-05-02 18:57:28.547 - info: host.iobroker-pi iobroker exit 0
                                    2025-05-02 18:58:01.723 - info: host.iobroker-pi iobroker add bluelink auto --host iobroker-pi --debug
                                    2025-05-02 18:58:04.052 - info: host.iobroker-pi iobroker host.iobroker-pi create instance bluelink
                                    2025-05-02 18:58:04.066 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.alive created
                                    2025-05-02 18:58:04.074 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.connected created
                                    2025-05-02 18:58:04.082 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.compactMode created
                                    2025-05-02 18:58:04.089 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cpu created
                                    2025-05-02 18:58:04.097 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.cputime created
                                    2025-05-02 18:58:04.104 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapUsed created
                                    2025-05-02 18:58:04.114 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memHeapTotal created
                                    2025-05-02 18:58:04.124 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.memRss created
                                    2025-05-02 18:58:04.132 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.uptime created
                                    2025-05-02 18:58:04.141 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.inputCount created
                                    2025-05-02 18:58:04.147 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.outputCount created
                                    2025-05-02 18:58:04.155 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.eventLoopLag created
                                    2025-05-02 18:58:04.162 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.sigKill created
                                    2025-05-02 18:58:04.172 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0.logLevel created
                                    2025-05-02 18:58:04.178 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info created
                                    2025-05-02 18:58:04.184 - info: host.iobroker-pi iobroker host.iobroker-pi object bluelink.0.info.connection created
                                    2025-05-02 18:58:04.190 - info: host.iobroker-pi iobroker host.iobroker-pi Set default value of bluelink.0.info.connection: false
                                    2025-05-02 18:58:04.206 - info: host.iobroker-pi iobroker host.iobroker-pi object system.adapter.bluelink.0 created
                                    2025-05-02 18:58:05.250 - info: host.iobroker-pi iobroker exit 0
                                    2025-05-02 18:58:08.043 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3381411
                                    2025-05-02 18:58:10.920 - info: bluelink.0 (3381411) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                    2025-05-02 18:58:10.947 - error: bluelink.0 (3381411) Check Settings. No Username set
                                    2025-05-02 19:01:47.770 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 (force=false, process=true)
                                    2025-05-02 19:01:47.780 - info: bluelink.0 (3381411) Got terminate signal TERMINATE_YOURSELF
                                    2025-05-02 19:01:47.782 - info: bluelink.0 (3381411) Adapter bluelink cleaned up everything...
                                    2025-05-02 19:01:47.783 - info: bluelink.0 (3381411) terminating
                                    2025-05-02 19:01:47.784 - info: bluelink.0 (3381411) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    2025-05-02 19:01:47.819 - info: host.iobroker-pi stopInstance system.adapter.bluelink.0 send kill signal
                                    2025-05-02 19:01:48.286 - info: bluelink.0 (3381411) terminating
                                    2025-05-02 19:01:48.345 - info: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                                    2025-05-02 19:01:52.136 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3386355
                                    2025-05-02 19:01:54.595 - info: bluelink.0 (3386355) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                    2025-05-02 19:01:54.625 - info: bluelink.0 (3386355) Login to api
                                    2025-05-02 19:01:57.529 - info: bluelink.0 (3386355) 1 Vehicles found
                                    2025-05-02 19:01:58.384 - info: bluelink.0 (3386355) Read new update for KNACT811XXXXXXXXX from the server
                                    2025-05-02 19:01:58.783 - error: bluelink.0 (3386355) PARSECHECK [object Object] coord [object Object]
                                    2025-05-02 19:01:58.934 - error: bluelink.0 (3386355) PARSECHECK [object Object] speed [object Object]
                                    2025-05-02 19:01:59.034 - error: bluelink.0 (3386355) PARSECHECK [object Object] accuracy [object Object]
                                    2025-05-02 19:01:59.082 - error: bluelink.0 (3386355) PARSECHECK [object Object] vehicleLocation [object Object]
                                    2025-05-02 19:01:59.430 - error: bluelink.0 (3386355) PARSECHECK [object Object] doorOpen [object Object]
                                    2025-05-02 19:01:59.638 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:01:59.990 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc1 [object Object]
                                    2025-05-02 19:02:00.111 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc2 [object Object]
                                    2025-05-02 19:02:00.215 - error: bluelink.0 (3386355) PARSECHECK [object Object] etc3 [object Object]
                                    2025-05-02 19:02:00.278 - error: bluelink.0 (3386355) PARSECHECK [object Object] atc [object Object]
                                    2025-05-02 19:02:00.279 - error: bluelink.0 (3386355) PARSECHECK [object Object] remainTime2 [object Object]
                                    2025-05-02 19:02:00.394 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:02:00.498 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:02:00.499 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:02:00.726 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                                    2025-05-02 19:02:00.727 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                                    2025-05-02 19:02:00.977 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                                    2025-05-02 19:02:01.074 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                    2025-05-02 19:02:01.075 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfo [object Object]
                                    2025-05-02 19:02:01.190 - error: bluelink.0 (3386355) PARSECHECK [object Object] starttime [object Object]
                                    2025-05-02 19:02:01.290 - error: bluelink.0 (3386355) PARSECHECK [object Object] endtime [object Object]
                                    2025-05-02 19:02:01.291 - error: bluelink.0 (3386355) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                    2025-05-02 19:02:01.342 - error: bluelink.0 (3386355) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                    2025-05-02 19:02:01.513 - error: bluelink.0 (3386355) PARSECHECK [object Object] time [object Object]
                                    2025-05-02 19:02:01.514 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservInfo [object Object]
                                    2025-05-02 19:02:01.779 - error: bluelink.0 (3386355) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:02:01.886 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservFatcSet [object Object]
                                    2025-05-02 19:02:01.887 - error: bluelink.0 (3386355) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                    2025-05-02 19:02:01.888 - error: bluelink.0 (3386355) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                    2025-05-02 19:02:02.023 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2025-05-02 19:02:02.025 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                                    at Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:140:34)
                                    at async Json2iob.parse (/opt/iobroker/node_modules/iobroker.bluelink/lib/json2iob.js:97:25)
                                    2025-05-02 19:02:02.028 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:02.046 - info: bluelink.0 (3386355) Adapter bluelink cleaned up everything...
                                    2025-05-02 19:02:02.047 - info: bluelink.0 (3386355) terminating
                                    2025-05-02 19:02:02.051 - warn: bluelink.0 (3386355) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2025-05-02 19:02:02.063 - error: bluelink.0 (3386355) PARSECHECK [object Object] ect [object Object]
                                    2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2025-05-02 19:02:02.064 - error: bluelink.0 (3386355) unhandled promise rejection: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:02.065 - error: bluelink.0 (3386355) Error: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:02.066 - error: bluelink.0 (3386355) The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:02.202 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:02:02.301 - error: bluelink.0 (3386355) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:02:02.302 - error: bluelink.0 (3386355) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:02:02.350 - error: bluelink.0 (3386355) PARSECHECK [object Object] dte [object Object]
                                    2025-05-02 19:02:02.553 - info: bluelink.0 (3386355) terminating
                                    2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.evModeRange.[object Object]
                                    2025-05-02 19:02:02.565 - error: bluelink.0 (3386355) Error: Connection is closed.
                                    2025-05-02 19:02:02.566 - error: bluelink.0 (3386355) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:02:02.568 - error: bluelink.0 (3386355) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                                    2025-05-02 19:02:02.570 - error: bluelink.0 (3386355) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.reservChargeInfos.targetSOClist02.dte.rangeByFuel.totalAvailableRange": Connection is closed.
                                    2025-05-02 19:02:02.619 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2025-05-02 19:02:02.620 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                                    2025-05-02 19:02:33.340 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3387262
                                    2025-05-02 19:02:35.793 - info: bluelink.0 (3387262) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                    2025-05-02 19:02:35.822 - info: bluelink.0 (3387262) Login to api
                                    2025-05-02 19:02:37.874 - info: bluelink.0 (3387262) 1 Vehicles found
                                    2025-05-02 19:02:38.224 - info: bluelink.0 (3387262) Read new update for KNACT811XXXXXXXXX from the server
                                    2025-05-02 19:02:38.516 - error: bluelink.0 (3387262) PARSECHECK [object Object] coord [object Object]
                                    2025-05-02 19:02:38.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] speed [object Object]
                                    2025-05-02 19:02:38.621 - error: bluelink.0 (3387262) PARSECHECK [object Object] accuracy [object Object]
                                    2025-05-02 19:02:38.624 - error: bluelink.0 (3387262) PARSECHECK [object Object] vehicleLocation [object Object]
                                    2025-05-02 19:02:38.775 - error: bluelink.0 (3387262) PARSECHECK [object Object] doorOpen [object Object]
                                    2025-05-02 19:02:38.837 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:02:39.033 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc1 [object Object]
                                    2025-05-02 19:02:39.081 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc2 [object Object]
                                    2025-05-02 19:02:39.129 - error: bluelink.0 (3387262) PARSECHECK [object Object] etc3 [object Object]
                                    2025-05-02 19:02:39.177 - error: bluelink.0 (3387262) PARSECHECK [object Object] atc [object Object]
                                    2025-05-02 19:02:39.178 - error: bluelink.0 (3387262) PARSECHECK [object Object] remainTime2 [object Object]
                                    2025-05-02 19:02:39.230 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:02:39.281 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                                    2025-05-02 19:02:39.393 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                                    2025-05-02 19:02:39.511 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:02:39.520 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                                    2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                    2025-05-02 19:02:39.521 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfo [object Object]
                                    2025-05-02 19:02:39.574 - error: bluelink.0 (3387262) PARSECHECK [object Object] starttime [object Object]
                                    2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] endtime [object Object]
                                    2025-05-02 19:02:39.625 - error: bluelink.0 (3387262) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                    2025-05-02 19:02:39.629 - error: bluelink.0 (3387262) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                    2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] time [object Object]
                                    2025-05-02 19:02:39.727 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservInfo [object Object]
                                    2025-05-02 19:02:39.828 - error: bluelink.0 (3387262) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:02:39.834 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservFatcSet [object Object]
                                    2025-05-02 19:02:39.835 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                    2025-05-02 19:02:39.836 - error: bluelink.0 (3387262) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                    2025-05-02 19:02:39.889 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2025-05-02 19:02:39.891 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:39.893 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:39.894 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:39.898 - info: bluelink.0 (3387262) Adapter bluelink cleaned up everything...
                                    2025-05-02 19:02:39.900 - info: bluelink.0 (3387262) terminating
                                    2025-05-02 19:02:39.901 - warn: bluelink.0 (3387262) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2025-05-02 19:02:39.911 - error: bluelink.0 (3387262) PARSECHECK [object Object] ect [object Object]
                                    2025-05-02 19:02:39.913 - error: bluelink.0 (3387262) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2025-05-02 19:02:39.914 - error: bluelink.0 (3387262) unhandled promise rejection: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:39.918 - error: bluelink.0 (3387262) Error: The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:39.919 - error: bluelink.0 (3387262) The state contains the forbidden properties day, time!
                                    2025-05-02 19:02:39.993 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:02:40.041 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:02:40.045 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                                    2025-05-02 19:02:40.164 - error: bluelink.0 (3387262) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:02:40.275 - error: bluelink.0 (3387262) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:02:40.327 - error: bluelink.0 (3387262) PARSECHECK [object Object] dte [object Object]
                                    2025-05-02 19:02:40.374 - error: bluelink.0 (3387262) PARSECHECK [object Object] reservChargeInfos [object Object]
                                    2025-05-02 19:02:40.403 - info: bluelink.0 (3387262) terminating
                                    2025-05-02 19:02:40.415 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                                    2025-05-02 19:02:40.416 - error: bluelink.0 (3387262) Error: Connection is closed.
                                    2025-05-02 19:02:40.418 - error: bluelink.0 (3387262) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                                    2025-05-02 19:02:40.421 - error: bluelink.0 (3387262) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.[object Object]
                                    2025-05-02 19:02:40.422 - error: bluelink.0 (3387262) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batterySoh": Connection is closed.
                                    2025-05-02 19:02:40.472 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2025-05-02 19:02:40.472 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                                    2025-05-02 19:03:11.070 - info: host.iobroker-pi instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 3388073
                                    2025-05-02 19:03:13.585 - info: bluelink.0 (3388073) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                    2025-05-02 19:03:13.614 - info: bluelink.0 (3388073) Login to api
                                    2025-05-02 19:03:15.038 - info: bluelink.0 (3388073) 1 Vehicles found
                                    2025-05-02 19:03:15.320 - info: bluelink.0 (3388073) Read new update for KNACT811XXXXXXXXX from the server
                                    2025-05-02 19:03:15.617 - error: bluelink.0 (3388073) PARSECHECK [object Object] coord [object Object]
                                    2025-05-02 19:03:15.673 - error: bluelink.0 (3388073) PARSECHECK [object Object] speed [object Object]
                                    2025-05-02 19:03:15.722 - error: bluelink.0 (3388073) PARSECHECK [object Object] accuracy [object Object]
                                    2025-05-02 19:03:15.726 - error: bluelink.0 (3388073) PARSECHECK [object Object] vehicleLocation [object Object]
                                    2025-05-02 19:03:15.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] doorOpen [object Object]
                                    2025-05-02 19:03:15.942 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:03:16.094 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc1 [object Object]
                                    2025-05-02 19:03:16.141 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc2 [object Object]
                                    2025-05-02 19:03:16.188 - error: bluelink.0 (3388073) PARSECHECK [object Object] etc3 [object Object]
                                    2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] atc [object Object]
                                    2025-05-02 19:03:16.237 - error: bluelink.0 (3388073) PARSECHECK [object Object] remainTime2 [object Object]
                                    2025-05-02 19:03:16.290 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:03:16.337 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:03:16.442 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                                    2025-05-02 19:03:16.443 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                                    2025-05-02 19:03:16.551 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:03:16.559 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                                    2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                    2025-05-02 19:03:16.560 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfo [object Object]
                                    2025-05-02 19:03:16.614 - error: bluelink.0 (3388073) PARSECHECK [object Object] starttime [object Object]
                                    2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] endtime [object Object]
                                    2025-05-02 19:03:16.661 - error: bluelink.0 (3388073) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                    2025-05-02 19:03:16.665 - error: bluelink.0 (3388073) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                    2025-05-02 19:03:16.765 - error: bluelink.0 (3388073) PARSECHECK [object Object] time [object Object]
                                    2025-05-02 19:03:16.766 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservInfo [object Object]
                                    2025-05-02 19:03:16.872 - error: bluelink.0 (3388073) PARSECHECK [object Object] airTemp [object Object]
                                    2025-05-02 19:03:16.880 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservFatcSet [object Object]
                                    2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                    2025-05-02 19:03:16.881 - error: bluelink.0 (3388073) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                    2025-05-02 19:03:16.933 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2025-05-02 19:03:16.934 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                                    2025-05-02 19:03:16.936 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                                    2025-05-02 19:03:16.937 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                                    2025-05-02 19:03:16.941 - info: bluelink.0 (3388073) Adapter bluelink cleaned up everything...
                                    2025-05-02 19:03:16.942 - info: bluelink.0 (3388073) terminating
                                    2025-05-02 19:03:16.943 - warn: bluelink.0 (3388073) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                    2025-05-02 19:03:16.946 - error: bluelink.0 (3388073) PARSECHECK [object Object] ect [object Object]
                                    2025-05-02 19:03:16.947 - error: bluelink.0 (3388073) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                    2025-05-02 19:03:16.948 - error: bluelink.0 (3388073) unhandled promise rejection: The state contains the forbidden properties day, time!
                                    2025-05-02 19:03:16.949 - error: bluelink.0 (3388073) Error: The state contains the forbidden properties day, time!
                                    2025-05-02 19:03:16.950 - error: bluelink.0 (3388073) The state contains the forbidden properties day, time!
                                    2025-05-02 19:03:17.008 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:03:17.057 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:03:17.061 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                                    2025-05-02 19:03:17.162 - error: bluelink.0 (3388073) PARSECHECK [object Object] evModeRange [object Object]
                                    2025-05-02 19:03:17.213 - error: bluelink.0 (3388073) PARSECHECK [object Object] totalAvailableRange [object Object]
                                    2025-05-02 19:03:17.214 - error: bluelink.0 (3388073) PARSECHECK [object Object] rangeByFuel [object Object]
                                    2025-05-02 19:03:17.217 - error: bluelink.0 (3388073) PARSECHECK [object Object] dte [object Object]
                                    2025-05-02 19:03:17.221 - error: bluelink.0 (3388073) PARSECHECK [object Object] reservChargeInfos [object Object]
                                    2025-05-02 19:03:17.445 - info: bluelink.0 (3388073) terminating
                                    2025-05-02 19:03:17.462 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.evStatus.batteryPower.[object Object]
                                    2025-05-02 19:03:17.463 - error: bluelink.0 (3388073) Error: Connection is closed.
                                    2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] batteryPower [object Object]
                                    2025-05-02 19:03:17.464 - error: bluelink.0 (3388073) PARSECHECK [object Object] evStatus [object Object]
                                    2025-05-02 19:03:17.468 - error: bluelink.0 (3388073) Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                                    2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error extract objectKeys: KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.[object Object]
                                    2025-05-02 19:03:17.470 - error: bluelink.0 (3388073) Error: Could not check object existence of bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3: Cannot check object existence of "bluelink.0.KNACT811XXXXXXXXX.vehicleStatusRaw.vehicleStatus.ign3": Connection is closed.
                                    2025-05-02 19:03:17.524 - error: host.iobroker-pi instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                    2025-05-02 19:03:17.524 - info: host.iobroker-pi Restart adapter system.adapter.bluelink.0 because enabled
                                    2025-05-02 19:03:17.524 - warn: host.iobroker-pi Do not restart adapter system.adapter.bluelink.0 because restart loop detected
                                    • MaBu59
                                      @arteck
                                      Ich glaube, ich habe dir zu viele Zeilen gesendet. War mein erster Versuch. Sorry!!
                                        arteck Developer Most Active @MaBu59 last edited by
                                        @mabu59 der knallt bei
                                        reserveChargeInfo2
                                        was immer da auch drin steht .. ich brauch die Login Daten..sonst wird das nix
                                          marchusar @arteck last edited by marchusar
                                          @arteck
                                          Sorry, war nicht am PC - hier jetzt die Log:
                                          2025-05-04 15:53:55.158 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23102
                                          2025-05-04 15:53:59.236 - info: bluelink.0 (23102) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                          2025-05-04 15:53:59.266 - info: bluelink.0 (23102) Login to api
                                          2025-05-04 15:54:01.542 - info: bluelink.0 (23102) 1 Vehicles found
                                          2025-05-04 15:54:01.674 - info: bluelink.0 (23102) Read new update for KNAC381xxx from the server
                                          2025-05-04 15:54:01.984 - error: bluelink.0 (23102) PARSECHECK [object Object] coord [object Object]
                                          2025-05-04 15:54:02.008 - error: bluelink.0 (23102) PARSECHECK [object Object] speed [object Object]
                                          2025-05-04 15:54:02.021 - error: bluelink.0 (23102) PARSECHECK [object Object] accuracy [object Object]
                                          2025-05-04 15:54:02.027 - error: bluelink.0 (23102) PARSECHECK [object Object] vehicleLocation [object Object]
                                          2025-05-04 15:54:02.111 - error: bluelink.0 (23102) PARSECHECK [object Object] doorOpen [object Object]
                                          2025-05-04 15:54:02.134 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                                          2025-05-04 15:54:02.220 - error: bluelink.0 (23102) PARSECHECK [object Object] etc1 [object Object]
                                          2025-05-04 15:54:02.232 - error: bluelink.0 (23102) PARSECHECK [object Object] etc2 [object Object]
                                          2025-05-04 15:54:02.285 - error: bluelink.0 (23102) PARSECHECK [object Object] etc3 [object Object]
                                          2025-05-04 15:54:02.298 - error: bluelink.0 (23102) PARSECHECK [object Object] atc [object Object]
                                          2025-05-04 15:54:02.299 - error: bluelink.0 (23102) PARSECHECK [object Object] remainTime2 [object Object]
                                          2025-05-04 15:54:02.318 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                                          2025-05-04 15:54:02.375 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                                          2025-05-04 15:54:02.376 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                                          2025-05-04 15:54:02.407 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                                          2025-05-04 15:54:02.408 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                                          2025-05-04 15:54:02.478 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                                          2025-05-04 15:54:02.490 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                                          2025-05-04 15:54:02.491 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                          2025-05-04 15:54:02.492 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfo [object Object]
                                          2025-05-04 15:54:02.517 - error: bluelink.0 (23102) PARSECHECK [object Object] starttime [object Object]
                                          2025-05-04 15:54:02.575 - error: bluelink.0 (23102) PARSECHECK [object Object] endtime [object Object]
                                          2025-05-04 15:54:02.576 - error: bluelink.0 (23102) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                          2025-05-04 15:54:02.585 - error: bluelink.0 (23102) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                          2025-05-04 15:54:02.655 - error: bluelink.0 (23102) PARSECHECK [object Object] time [object Object]
                                          2025-05-04 15:54:02.656 - error: bluelink.0 (23102) PARSECHECK [object Object] reservInfo [object Object]
                                          2025-05-04 15:54:02.727 - error: bluelink.0 (23102) PARSECHECK [object Object] airTemp [object Object]
                                          2025-05-04 15:54:02.737 - error: bluelink.0 (23102) PARSECHECK [object Object] reservFatcSet [object Object]
                                          2025-05-04 15:54:02.738 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                          2025-05-04 15:54:02.739 - error: bluelink.0 (23102) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                          2025-05-04 15:54:02.806 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2025-05-04 15:54:02.807 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:02.810 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:02.810 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:02.821 - info: bluelink.0 (23102) Adapter bluelink cleaned up everything...
                                          2025-05-04 15:54:02.824 - info: bluelink.0 (23102) terminating
                                          2025-05-04 15:54:02.825 - warn: bluelink.0 (23102) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2025-05-04 15:54:02.830 - error: bluelink.0 (23102) PARSECHECK [object Object] ect [object Object]
                                          2025-05-04 15:54:02.831 - error: bluelink.0 (23102) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2025-05-04 15:54:02.832 - error: bluelink.0 (23102) unhandled promise rejection: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:02.833 - error: bluelink.0 (23102) Error: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:02.834 - error: bluelink.0 (23102) The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:02.927 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                                          2025-05-04 15:54:02.939 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                                          2025-05-04 15:54:02.940 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                                          2025-05-04 15:54:02.947 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                                          2025-05-04 15:54:02.976 - error: bluelink.0 (23102) PARSECHECK [object Object] evModeRange [object Object]
                                          2025-05-04 15:54:02.991 - error: bluelink.0 (23102) PARSECHECK [object Object] totalAvailableRange [object Object]
                                          2025-05-04 15:54:02.992 - error: bluelink.0 (23102) PARSECHECK [object Object] rangeByFuel [object Object]
                                          2025-05-04 15:54:02.998 - error: bluelink.0 (23102) PARSECHECK [object Object] dte [object Object]
                                          2025-05-04 15:54:03.004 - error: bluelink.0 (23102) PARSECHECK [object Object] reservChargeInfos [object Object]
                                          2025-05-04 15:54:03.035 - error: bluelink.0 (23102) PARSECHECK [object Object] batteryPower [object Object]
                                          2025-05-04 15:54:03.036 - error: bluelink.0 (23102) PARSECHECK [object Object] evStatus [object Object]
                                          2025-05-04 15:54:03.173 - error: bluelink.0 (23102) PARSECHECK [object Object] tirePressureLamp [object Object]
                                          2025-05-04 15:54:03.194 - error: bluelink.0 (23102) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                                          2025-05-04 15:54:03.201 - error: bluelink.0 (23102) PARSECHECK [object Object] battery [object Object]
                                          2025-05-04 15:54:03.217 - error: bluelink.0 (23102) PARSECHECK [object Object] stopLamp [object Object]
                                          2025-05-04 15:54:03.247 - error: bluelink.0 (23102) PARSECHECK [object Object] headLamp [object Object]
                                          2025-05-04 15:54:03.328 - info: bluelink.0 (23102) terminating
                                          2025-05-04 15:54:03.396 - warn: bluelink.0 (23102) get state error: Connection is closed.
                                          2025-05-04 15:54:03.425 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                                          2025-05-04 15:54:03.427 - warn: bluelink.0 (23102) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightFrontLamp: DB closed
                                          2025-05-04 15:54:03.428 - warn: bluelink.0 (23102) get state error: Connection is closed.
                                          2025-05-04 15:54:03.429 - error: bluelink.0 (23102) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                                          2025-05-04 15:54:03.430 - error: bluelink.0 (23102) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": DB closed
                                          2025-05-04 15:54:03.430 - error: bluelink.0 (23102) PARSECHECK [object Object] turnSignalLamp [object Object]
                                          2025-05-04 15:54:03.431 - error: bluelink.0 (23102) PARSECHECK [object Object] lampWireStatus [object Object]
                                          2025-05-04 15:54:03.435 - error: bluelink.0 (23102) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.windowOpen": Connection is closed.
                                          2025-05-04 15:54:03.684 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2025-05-04 15:54:03.685 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because enabled
                                          2025-05-04 15:54:34.900 - info: host.raspberrypi4 instance system.adapter.bluelink.0 in version "3.1.2" (non-npm: Newan/ioBroker.bluelink#parsecheck) started with pid 23155
                                          2025-05-04 15:54:38.281 - info: bluelink.0 (23155) starting. Version 3.1.2 (non-npm: Newan/ioBroker.bluelink#parsecheck) in /opt/iobroker/node_modules/iobroker.bluelink, node: v20.19.1, js-controller: 7.0.6
                                          2025-05-04 15:54:38.315 - info: bluelink.0 (23155) Login to api
                                          2025-05-04 15:54:41.016 - info: bluelink.0 (23155) 1 Vehicles found
                                          2025-05-04 15:54:41.199 - info: bluelink.0 (23155) Read new update for KNAC381xxx from the server
                                          2025-05-04 15:54:41.518 - error: bluelink.0 (23155) PARSECHECK [object Object] coord [object Object]
                                          2025-05-04 15:54:41.538 - error: bluelink.0 (23155) PARSECHECK [object Object] speed [object Object]
                                          2025-05-04 15:54:41.595 - error: bluelink.0 (23155) PARSECHECK [object Object] accuracy [object Object]
                                          2025-05-04 15:54:41.602 - error: bluelink.0 (23155) PARSECHECK [object Object] vehicleLocation [object Object]
                                          2025-05-04 15:54:41.639 - error: bluelink.0 (23155) PARSECHECK [object Object] doorOpen [object Object]
                                          2025-05-04 15:54:41.665 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                                          2025-05-04 15:54:41.747 - error: bluelink.0 (23155) PARSECHECK [object Object] etc1 [object Object]
                                          2025-05-04 15:54:41.805 - error: bluelink.0 (23155) PARSECHECK [object Object] etc2 [object Object]
                                          2025-05-04 15:54:41.818 - error: bluelink.0 (23155) PARSECHECK [object Object] etc3 [object Object]
                                          2025-05-04 15:54:41.833 - error: bluelink.0 (23155) PARSECHECK [object Object] atc [object Object]
                                          2025-05-04 15:54:41.834 - error: bluelink.0 (23155) PARSECHECK [object Object] remainTime2 [object Object]
                                          2025-05-04 15:54:41.885 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                                          2025-05-04 15:54:41.935 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                                          2025-05-04 15:54:41.936 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                                          2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                                          2025-05-04 15:54:41.965 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                                          2025-05-04 15:54:42.035 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                                          2025-05-04 15:54:42.046 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                                          2025-05-04 15:54:42.047 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                          2025-05-04 15:54:42.048 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfo [object Object]
                                          2025-05-04 15:54:42.069 - error: bluelink.0 (23155) PARSECHECK [object Object] starttime [object Object]
                                          2025-05-04 15:54:42.082 - error: bluelink.0 (23155) PARSECHECK [object Object] endtime [object Object]
                                          2025-05-04 15:54:42.083 - error: bluelink.0 (23155) PARSECHECK [object Object] offPeakPowerTime1 [object Object]
                                          2025-05-04 15:54:42.091 - error: bluelink.0 (23155) PARSECHECK [object Object] offpeakPowerInfo [object Object]
                                          2025-05-04 15:54:42.115 - error: bluelink.0 (23155) PARSECHECK [object Object] time [object Object]
                                          2025-05-04 15:54:42.116 - error: bluelink.0 (23155) PARSECHECK [object Object] reservInfo [object Object]
                                          2025-05-04 15:54:42.186 - error: bluelink.0 (23155) PARSECHECK [object Object] airTemp [object Object]
                                          2025-05-04 15:54:42.200 - error: bluelink.0 (23155) PARSECHECK [object Object] reservFatcSet [object Object]
                                          2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfoDetail [object Object]
                                          2025-05-04 15:54:42.203 - error: bluelink.0 (23155) PARSECHECK [object Object] reserveChargeInfo2 [object Object]
                                          2025-05-04 15:54:42.266 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2025-05-04 15:54:42.267 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:42.269 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                                          at Validator.validateSetStateObjectArgument (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/validator.js:299:13)
                                          at Bluelink._setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4984:21)
                                          at Bluelink.setState (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:4962:17)
                                          at async Bluelink.readStatusVin (/opt/iobroker/node_modules/iobroker.bluelink/main.js:391:17)
                                          at async Bluelink.readStatus (/opt/iobroker/node_modules/iobroker.bluelink/main.js:355:13)
                                          2025-05-04 15:54:42.270 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:42.275 - info: bluelink.0 (23155) Adapter bluelink cleaned up everything...
                                          2025-05-04 15:54:42.276 - info: bluelink.0 (23155) terminating
                                          2025-05-04 15:54:42.278 - warn: bluelink.0 (23155) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2025-05-04 15:54:42.282 - error: bluelink.0 (23155) PARSECHECK [object Object] ect [object Object]
                                          2025-05-04 15:54:42.284 - error: bluelink.0 (23155) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2025-05-04 15:54:42.285 - error: bluelink.0 (23155) unhandled promise rejection: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:42.286 - error: bluelink.0 (23155) Error: The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:42.287 - error: bluelink.0 (23155) The state contains the forbidden properties day, time!
                                          2025-05-04 15:54:42.357 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                                          2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                                          2025-05-04 15:54:42.373 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                                          2025-05-04 15:54:42.380 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                                          2025-05-04 15:54:42.447 - error: bluelink.0 (23155) PARSECHECK [object Object] evModeRange [object Object]
                                          2025-05-04 15:54:42.460 - error: bluelink.0 (23155) PARSECHECK [object Object] totalAvailableRange [object Object]
                                          2025-05-04 15:54:42.461 - error: bluelink.0 (23155) PARSECHECK [object Object] rangeByFuel [object Object]
                                          2025-05-04 15:54:42.469 - error: bluelink.0 (23155) PARSECHECK [object Object] dte [object Object]
                                          2025-05-04 15:54:42.475 - error: bluelink.0 (23155) PARSECHECK [object Object] reservChargeInfos [object Object]
                                          2025-05-04 15:54:42.553 - error: bluelink.0 (23155) PARSECHECK [object Object] batteryPower [object Object]
                                          2025-05-04 15:54:42.554 - error: bluelink.0 (23155) PARSECHECK [object Object] evStatus [object Object]
                                          2025-05-04 15:54:42.656 - error: bluelink.0 (23155) PARSECHECK [object Object] tirePressureLamp [object Object]
                                          2025-05-04 15:54:42.679 - error: bluelink.0 (23155) PARSECHECK [object Object] batSignalReferenceValue [object Object]
                                          2025-05-04 15:54:42.686 - error: bluelink.0 (23155) PARSECHECK [object Object] battery [object Object]
                                          2025-05-04 15:54:42.699 - error: bluelink.0 (23155) PARSECHECK [object Object] stopLamp [object Object]
                                          2025-05-04 15:54:42.774 - error: bluelink.0 (23155) PARSECHECK [object Object] headLamp [object Object]
                                          2025-05-04 15:54:42.780 - info: bluelink.0 (23155) terminating
                                          2025-05-04 15:54:42.791 - warn: bluelink.0 (23155) get state error: Connection is closed.
                                          2025-05-04 15:54:42.800 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                                          2025-05-04 15:54:42.803 - warn: bluelink.0 (23155) Could not perform strict object check of state bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftFrontLamp: DB closed
                                          2025-05-04 15:54:42.805 - warn: bluelink.0 (23155) get state error: Connection is closed.
                                          2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                                          2025-05-04 15:54:42.807 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.leftRearLamp": DB closed
                                          2025-05-04 15:54:42.814 - error: bluelink.0 (23155) Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                                          2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error extract objectKeys: KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.[object Object]
                                          2025-05-04 15:54:42.818 - error: bluelink.0 (23155) Error: Could not check object existence of bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp: Cannot check object existence of "bluelink.0.KNAC381xxx.vehicleStatusRaw.vehicleStatus.lampWireStatus.turnSignalLamp.rightRearLamp": Connection is closed.
                                          2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] turnSignalLamp [object Object]
                                          2025-05-04 15:54:42.819 - error: bluelink.0 (23155) PARSECHECK [object Object] lampWireStatus [object Object]
                                          2025-05-04 15:54:43.003 - error: host.raspberrypi4 instance system.adapter.bluelink.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2025-05-04 15:54:43.003 - info: host.raspberrypi4 Restart adapter system.adapter.bluelink.0 because
                                            marchusar @Meister Mopper last edited by marchusar
                                            @meister-mopper
                                            Bei mir läuft u.a. die Homematic nicht, wenn ich auf 64bit umstelle. Gerade nochmal versucht...
                                            Mein Zigbee läuft und bietet den Direktlink in der Config selbst so an. Auch hier hatte ich mit dem by-id Link schon mal Schwierigkeiten und seitdem ich es so nutze läuft es stabil.
                                            Die je 2 Instanzen sind für lokalen Zugriff ohne Passwort und externen Zugriff mit SSL und Passwort. Das funktioniert auch einwandfrei.
                                            1.0k
                                            2316
                                            865233
