    4. Neuer Adapter für Roborock-Staubsauger
      Sepp last edited by
      @TomRacoon danke hat geklappt!
        Sepp last edited by
        Gibts eine Möglichkeit auf AI-Plan umzustellen oder allgemein auf die anderen Modi?
        • Duese123
          Duese123 last edited by Duese123
          bei mir crasht wie bei @matrose65 der Adapter jetzt schon länger wenn ich auf die Webpage gehe kommt folgendes 😞
          Zeit
          debug
          Nachricht
          host.iobroker
          2025-04-08 15:15:04.557	info	instance system.adapter.roborock.0 in version "0.6.19" started with pid 558172
          host.iobroker
          2025-04-08 15:14:34.349	info	Restart adapter system.adapter.roborock.0 because enabled
          host.iobroker
          2025-04-08 15:14:34.349	error	instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[2]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:601:18)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[2]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[2]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[2]: TypeError: Cannot read properties of undefined (reading 'productId')
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[2]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[1]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:562:26)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[1]: at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[1]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[1]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[1]: TypeError: Cannot read properties of undefined (reading 'productId')
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[1]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[0]: at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:559:17)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[0]: at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[0]: at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[0]: at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66)
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'productId')
          host.iobroker
          2025-04-08 15:14:34.349	error	Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          roborock.0
          2025-04-08 15:14:34.307	info	terminating
          roborock.0
          2025-04-08 15:14:34.174	warn	setTimeout called, but adapter is shutting down
          roborock.0
          2025-04-08 15:14:34.097	warn	setTimeout called, but adapter is shutting down
          roborock.0
          2025-04-08 15:14:34.017	warn	setTimeout called, but adapter is shutting down
          roborock.0
          2025-04-08 15:14:34.008	warn	setTimeout called, but adapter is shutting down
          roborock.0
          roborock.0
          2025-04-08 15:14:33.935	warn	setTimeout called, but adapter is shutting down
          roborock.0
          2025-04-08 15:14:33.866	warn	setTimeout called, but adapter is shutting down
          roborock.0
          2025-04-08 15:14:33.811	error	Cannot read properties of undefined (reading 'productId')
          roborock.0
          2025-04-08 15:14:33.811	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:601:18)
          roborock.0
          2025-04-08 15:14:33.810	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
          roborock.0
          2025-04-08 15:14:33.810	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2025-04-08 15:14:33.810	error	Cannot read properties of undefined (reading 'productId')
          roborock.0
          2025-04-08 15:14:33.810	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:562:26)
          roborock.0
          2025-04-08 15:14:33.809	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
          roborock.0
          2025-04-08 15:14:33.809	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2025-04-08 15:14:33.809	warn	setTimeout called, but adapter is shutting down
          roborock.0
          2025-04-08 15:14:33.807	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
          roborock.0
          2025-04-08 15:14:33.806	info	terminating
          roborock.0
          2025-04-08 15:14:33.801	error	Cannot read properties of undefined (reading 'productId')
          roborock.0
          2025-04-08 15:14:33.801	error	TypeError: Cannot read properties of undefined (reading 'productId') at http_api.getRobotModel (/opt/iobroker/node_modules/iobroker.roborock/lib/http_api.js:227:66) at Roborock.catchError (/opt/iobroker/node_modules/iobroker.roborock/main.js:871:43) at requests_handler.sendRequest (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:712:17) at requests_handler.getMap (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:559:17)
          roborock.0
          2025-04-08 15:14:33.800	error	unhandled promise rejection: Cannot read properties of undefined (reading 'productId')
          roborock.0
          2025-04-08 15:14:33.799	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          roborock.0
          2025-04-08 15:14:31.670	info	Starting adapter finished. Let's go!!!!!!!
            samsungfreak last edited by
            weiß jemand, wo die verfügbaren Werte dokumentiert sind vom Status "state"?
            Also Charging = Wert 8 usw.
            da_Woody jahnbes 2 Replies Last reply Reply Quote 0
            • da_Woody
              da_Woody @samsungfreak last edited by
              @samsungfreak
              https://github.com/copystring/ioBroker.roborock/wiki/Objekte-und-ihre-Bedeutung
              state - State
              Status
              Wert Bedeutung
              1 unbekannt
              2 schlafend, ohne laden
              3 inaktiv / idle
              5 reinigt
              6 Fahrt zur Ladestation
              7 Fernsteuerung
              8 laden
              10 Pause
              11 Punktreinigung
              12 Fehler
              16 Fahrt zum Ziel
              17 Zonenreinigung
              18 Raumreinigung
              22 Staubbehälter leeren (im Dock)
              23 Mopp waschen (im Dock)
              26 fahre Mopp waschen (im Dock)
              29 Karte erstellen
              • jahnbes
                jahnbes @samsungfreak last edited by jahnbes
                @samsungfreak
                wie immer stehen alle Angaben hier im Wiki.
                Viele Grüße, jahnbes.
                  Tom_W last edited by
                  bei mir läuft das Log voll mit folgender Meldung:
                  Failed to process get_status on robot 69MLydUJfX3n4mUt9S4WWy (roborock.vacuum.a97): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                  Weiß irgendjemand was das bedeutet und wie ich das weg bekomme?
                  Tom
                  U 1 Reply Last reply Reply Quote 1
                  • U
                    uwe72 @Tom_W last edited by
                    @tom_w
                    Bei mir leider auch
                    Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                    • VJ77
                      VJ77 last edited by
                      Moin zusammen,
                      ich habe meinen ioBroker von einem Windows-PC auf ein RPI umziehen lassen. Leider startet die Roborock-Instanz jetzt gar nicht mehr-
                      Eine komplette Neuinstallation des Adapters hat leider auch nichts gebracht.
                      Hat jemand eine Idee?
                        Thomas Braun Most Active @VJ77 last edited by
                        @vj77 sagte in Neuer Adapter für Roborock-Staubsauger:
                        Längeres Log posten. Ggfls. im debug modus.
                        Und KEINE Screenshots von log-Texten.
                        VJ77 1 Reply Last reply Reply Quote 0
                        • VJ77
                          VJ77 @Thomas Braun last edited by VJ77
                          Danke für die Info mit dem Screenshot. Ich habe sowohl die Roborock-Instanz, als auch den Host auf Debug stehen. Von der Instanz kommen gar keine Meldungen, und vom Host immer wieder die gleichen Meldungen
                          code_text
                          host.iobroker
                          	2025-05-03 07:17:03.485	info	instance system.adapter.sbfspot.0 having pid 2614 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.iobroker
                          	2025-05-03 07:17:00.030	info	instance system.adapter.sbfspot.0 in version "4.4.2" started with pid 2614
                          host.iobroker
                          	2025-05-03 07:16:53.482	info	Restart adapter system.adapter.roborock.1 because enabled
                          host.iobroker
                          	2025-05-03 07:16:53.482	info	instance system.adapter.roborock.1 terminated with code null ()
                          host.iobroker
                          	2025-05-03 07:16:53.482	warn	instance system.adapter.roborock.1 terminated due to SIGILL
                          host.iobroker
                          	2025-05-03 07:16:52.215	info	instance system.adapter.roborock.1 in version "0.6.19" started with pid 2585
                          host.iobroker
                          	2025-05-03 07:16:21.390	info	Restart adapter system.adapter.roborock.1 because enabled
                          host.iobroker
                          	2025-05-03 07:16:21.390	info	instance system.adapter.roborock.1 terminated with code null ()
                          host.iobroker
                          	2025-05-03 07:16:21.389	warn	instance system.adapter.roborock.1 terminated due to SIGILL
                          host.iobroker
                          	2025-05-03 07:16:20.160	info	instance system.adapter.roborock.1 in version "0.6.19" started with pid 2569
                          host.iobroker
                          	2025-05-03 07:16:03.562	info	instance system.adapter.sbfspot.0 having pid 2548 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.iobroker
                          	2025-05-03 07:16:00.071	info	instance system.adapter.sbfspot.0 in version "4.4.2" started with pid 2548
                          host.iobroker
                          	2025-05-03 07:15:49.373	info	Restart adapter system.adapter.roborock.1 because enabled
                          host.iobroker
                          	2025-05-03 07:15:49.373	info	instance system.adapter.roborock.1 terminated with code null ()
                          host.iobroker
                          	2025-05-03 07:15:49.373	warn	instance system.adapter.roborock.1 terminated due to SIGILL
                          host.iobroker
                          	2025-05-03 07:15:48.134	info	instance system.adapter.roborock.1 in version "0.6.19" started with pid 2518
                          host.iobroker
                          	2025-05-03 07:15:30.962	info	instance system.adapter.dwd.0 having pid 2501 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.iobroker
                          	2025-05-03 07:15:27.035	info	instance system.adapter.dwd.0 in version "2.8.5" started with pid 2501
                          host.iobroker
                          	2025-05-03 07:15:17.314	info	Restart adapter system.adapter.roborock.1 because enabled
                          host.iobroker
                          	2025-05-03 07:15:17.313	info	instance system.adapter.roborock.1 terminated with code null ()
                          host.iobroker
                          	2025-05-03 07:15:17.313	warn	instance system.adapter.roborock.1 terminated due to SIGILL
                          host.iobroker
                          	2025-05-03 07:15:16.108	info	instance system.adapter.roborock.1 in version "0.6.19" started with pid 2489
                          host.iobroker
                          	2025-05-03 07:15:03.897	info	instance system.adapter.sbfspot.0 having pid 2471 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                          host.iobroker
                          	2025-05-03 07:15:00.098	info	instance system.adapter.sbfspot.0 in version "4.4.2" started with pid 2471
                          host.iobroker
                          	2025-05-03 07:14:45.117	info	Restart adapter system.adapter.roborock.1 because enabled
                          host.iobroker
                          	2025-05-03 07:14:45.117	info	instance system.adapter.roborock.1 terminated with code null ()
                          host.iobroker
                          	2025-05-03 07:14:45.117	warn	instance system.adapter.roborock.1 terminated due to SIGILL
                          host.iobroker
                          	2025-05-03 07:14:43.904	info	instance system.adapter.roborock.1 in version "0.6.19" started with pid 2442
                          host.iobroker
                          	2025-05-03 07:14:13.013	info	Restart adapter system.adapter.roborock.1 because enabled
                          U D 2 Replies Last reply Reply Quote 0
                          • U
                            uwe72 @VJ77 last edited by uwe72
                            @Thomas-Braun
                            Einige Leuten einschließlich mir, bekommen ja diese Fehlermeldung. Gibts hier Ideen woher bzw. warum diese kommen? Dankeschön.
                            borock.0
                            2025-05-04 11:11:49.203	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:11:48.599	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:10:49.009	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:10:48.619	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:09:49.200	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:09:48.575	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:08:49.061	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:08:48.540	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:07:48.846	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:07:48.330	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:06:48.529	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:06:48.281	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:05:48.804	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:05:48.274	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:04:48.696	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:04:48.486	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:03:48.922	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at runNextTicks (node:internal/process/task_queues:60:5) at processImmediate (node:internal/timers:454:9) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:03:48.387	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:02:48.885	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                            2025-05-04 11:02:48.306	error	Failed to process get_status on robot 15BGaiuMta5YcTl8IY1yWx (roborock.vacuum.a70): TypeError: Cannot read properties of undefined (reading 'dss') at requests_handler.getDockingStationStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:184:50) at requests_handler.getParameter (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:252:43) at requests_handler.getStatus (/opt/iobroker/node_modules/iobroker.roborock/lib/requests_handler.js:114:4) at /opt/iobroker/node_modules/iobroker.roborock/main.js:104:8
                            roborock.0
                              docsnyder7 @VJ77 last edited by
                              @vj77
                              host.evccpi
                              	2025-05-08 12:12:01.585	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:12:01.584	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:12:01.382	info	stopInstance system.adapter.roborock.0 send kill signal
                              host.evccpi
                              	2025-05-08 12:12:01.330	info	stopInstance system.adapter.roborock.0 (force=false, process=true)
                              host.evccpi
                              	2025-05-08 12:12:01.329	info	"system.adapter.roborock.0" disabled
                              host.evccpi
                              	2025-05-08 12:11:59.398	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214464
                              host.evccpi
                              	2025-05-08 12:11:57.925	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:57.925	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:57.924	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:56.195	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214455
                              host.evccpi
                              	2025-05-08 12:11:54.716	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:54.716	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:54.716	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:53.223	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214446
                              host.evccpi
                              	2025-05-08 12:11:51.831	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:51.831	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:51.830	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:50.185	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214437
                              host.evccpi
                              	2025-05-08 12:11:48.715	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:48.715	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:48.714	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:47.174	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214429
                              host.evccpi
                              	2025-05-08 12:11:45.607	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:45.606	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:45.606	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:43.982	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214422
                              host.evccpi
                              	2025-05-08 12:11:42.498	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:42.498	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:42.497	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:40.949	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214415
                              host.evccpi
                              	2025-05-08 12:11:39.442	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:39.441	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:39.441	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:37.963	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214408
                              host.evccpi
                              	2025-05-08 12:11:36.465	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:36.465	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:36.465	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:34.934	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214401
                              host.evccpi
                              	2025-05-08 12:11:33.426	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:33.425	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:33.425	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:31.915	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214394
                              host.evccpi
                              	2025-05-08 12:11:30.433	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:30.432	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:30.432	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:28.950	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214385
                              host.evccpi
                              	2025-05-08 12:11:27.453	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:27.453	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:27.452	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:25.692	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214378
                              host.evccpi
                              	2025-05-08 12:11:24.216	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:24.215	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:24.215	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:22.751	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214370
                              host.evccpi
                              	2025-05-08 12:11:21.188	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:21.187	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:21.187	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:19.574	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214334
                              host.evccpi
                              	2025-05-08 12:11:17.830	info	Restart adapter system.adapter.roborock.0 because enabled
                              host.evccpi
                              	2025-05-08 12:11:17.830	info	instance system.adapter.roborock.0 terminated with code null ()
                              host.evccpi
                              	2025-05-08 12:11:17.829	warn	instance system.adapter.roborock.0 terminated due to SIGILL
                              host.evccpi
                              	2025-05-08 12:11:15.348	info	instance system.adapter.roborock.0 in version "0.6.18" started with pid 214324
                              host.evccpi
                              	2025-05-08 12:11:14.691	info	"system.adapter.roborock.0" enabled
                              jetzt hat es mich erwischt... wollte leichtsinnig auf die 0.6.19 gehen und bekomme den Adapter nicht mehr ans Laufen. Auch ein retour auf die 0.6.18 verändert die Lage nicht.
                              Falls ich mit Daten dienen darf, immer her damit
                              Node.js: v20.19.1
                              NPM: 10.8.2
                              JS: 7.0.6
                              Rpi4 mit aktuellem OS
                                Manolo last edited by Manolo
                                Habe das Problem gefunden.
                                Einmal die App öffnen und die neuen Datenschutzrichtlinien akzeptieren, dann wird auch der Adapter wieder grün.
                                Da haben die von Roborock aber nen bösen Fallstrick eingebaut...
                                  docsnyder7 @Manolo last edited by docsnyder7
                                  @manolo Danke für den Tip!
                                  Hat bei mir leider keinen Erfolg...
                                  was bedeutet der Warneintrag "SIGILL" im Log?
                                  Thomas Braun M 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @docsnyder7 last edited by Thomas Braun
                                    @docsnyder7 sagte in Neuer Adapter für Roborock-Staubsauger:
                                    SIGILL
                                    Ist ein SIGnal einer ILLegalen Anweisung.
                                    https://dsa.cs.tsinghua.edu.cn/oj/static/unix_signal.html
                                      docsnyder7 @Thomas Braun last edited by
                                      @thomas-braun kann das mit den Datenschutzgeschichte zu tun haben?
                                      Thomas Braun VJ77 3 Replies Last reply Reply Quote 0
                                        @docsnyder7
                                        Möglich.
                                        • VJ77
                                          VJ77 @docsnyder7 last edited by
                                          glaube ich nicht. Zum einen startet der Adapter ja im Grunde überhaupt nicht, Zum anderen kann ich bei mir auf dem Windows-System problemlos den Adapter starten. Nur auf meinem RPI geht es nicht.
                                          • VJ77
                                            @docsnyder7 schau mal hier: https://github.com/copystring/ioBroker.roborock/issues/815
                                            fonebone42 created this issue in copystring/ioBroker.roborock
                                            closed [BUG] instance system.adapter.roborock.0 terminated due to SIGILL #815
                                            916
                                            304092
