    4. Wieder mal der Fully ...
    • Dr.Pie
      Dr.Pie @Dr.Pie last edited by Dr.Pie
      jens
      HOME=/home/jens
      GROUPS=jens cdrom floppy sudo audio dip video plugdev users netdev iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:             16G        3.9G         11G        1.0M        1.8G         12G
      Swap:           1.0G          0B        1.0G
      Total:           17G        3.9G         12G
      Active iob-Instances:   31
              15876 M total memory
               3741 M used memory
                973 M active memory
               3729 M inactive memory
              10774 M free memory
                582 M buffer memory
               1103 M swap cache
                975 M total swap
                  0 M used swap
                975 M free swap
      top - 19:51:25 up 7 days,  9:42,  2 users,  load average: 0.55, 0.95, 0.81
      Tasks: 142 total,   1 running, 141 sleeping,   0 stopped,   0 zombie
      %Cpu(s): 33.3 us,  0.0 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :  15876.2 total,  10774.6 free,   3741.7 used,   1686.1 buff/cache
      MiB Swap:    976.0 total,    976.0 free,      0.0 used.  12134.4 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  7.8G     0  7.8G   0% /dev
      tmpfs          tmpfs     1.6G  792K  1.6G   1% /run
      /dev/nvme0n1p1 ext4      116G   13G   98G  12% /
      tmpfs          tmpfs     7.8G     0  7.8G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      tmpfs          tmpfs     1.6G     0  1.6G   0% /run/user/1000
      [Fri Apr 25 10:08:56 2025] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Quota mode: none.
      [Fri Apr 25 10:08:57 2025] EXT4-fs (nvme0n1p1): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET SOURCE         FSTYPE OPTIONS
      /      /dev/nvme0n1p1 ext4   rw,relatime,errors=remount-ro
      /var:
      2.8G    /var/
      2.2G    /var/log/journal/71f4ccb046934bb889999d75429a60cc
      2.2G    /var/log
      379M    /var/cache
      Archived and active journals take up 71.7M in the file system.
      /opt/iobroker/backups:
      2.5G    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      64M     /opt/iobroker/iobroker-data/states.jsonl
      53M     /opt/iobroker/iobroker-data/objects.jsonl
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M     /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      USB-Devices by-id:
      No Devices found 'by-id'
      *** ZigBee Settings ***
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.0
      /usr/bin/node           v20.19.0
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.0-1nodesource1
        Candidate: 20.19.1-1nodesource1
        Version table:
           20.19.1-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
       *** 20.19.0-1nodesource1 1001
              100 /var/lib/dpkg/status
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      nuc                 nuc (version: 7.0.6, hostname: nuc           , alive, uptime: 639736)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     5
      +-- iobroker.bambulab@0.3.2 (git+ssh://git@github.com/Joylancer/ioBroker.bambulab.git#e45a2b4644fa2af1f0532352ac7da71ee3257c84)
      +-- iobroker.parcel@0.2.10 (git+ssh://git@github.com/TA2k/ioBroker.parcel.git#7504e1cbfc79a62e49ebc2e0502cb958d01008be)
      +-- iobroker.smartthings@0.1.2 (git+ssh://git@github.com/TA2k/ioBroker.smartthings.git#0921ba9cef4d6b62375f339126457f3429d0448f)
      +-- iobroker.sourceanalytix@0.4.15-alpha.1 (git+ssh://git@github.com/DrozmotiX/ioBroker.sourceanalytix.git#1010e11d126dc2e9639b70f17b79d082dead83ba)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
      + system.adapter.admin.0                  : admin                 : nuc                                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : nuc                                      -  enabled
      + system.adapter.bambulab.0               : bambulab              : nuc                                      -  enabled, port: 8883
        system.adapter.bambulab.1               : bambulab              : nuc                                      - disabled, port: 8883
        system.adapter.daswetter.0              : daswetter             : nuc                                      -  enabled
        system.adapter.daswetter.1              : daswetter             : nuc                                      -  enabled
      + system.adapter.denon.0                  : denon                 : nuc                                      -  enabled
      + system.adapter.discovery.0              : discovery             : nuc                                      -  enabled
      + system.adapter.fb-checkpresence.0       : fb-checkpresence      : nuc                                      -  enabled
      + system.adapter.fullybrowser.0           : fullybrowser          : nuc                                      -  enabled
      + system.adapter.harmony.0                : harmony               : nuc                                      -  enabled
      + system.adapter.heos.0                   : heos                  : nuc                                      -  enabled
      + system.adapter.history.0                : history               : nuc                                      -  enabled
        system.adapter.homeconnect.0            : homeconnect           : nuc                                      - disabled
        system.adapter.ical.0                   : ical                  : nuc                                      -  enabled
        system.adapter.ical.1                   : ical                  : nuc                                      -  enabled
        system.adapter.ical.2                   : ical                  : nuc                                      -  enabled
        system.adapter.ical.3                   : ical                  : nuc                                      -  enabled
      + system.adapter.javascript.0             : javascript            : nuc                                      -  enabled
      + system.adapter.parcel.0                 : parcel                : nuc                                      -  enabled
      + system.adapter.parcel.1                 : parcel                : nuc                                      -  enabled
      + system.adapter.parcel.2                 : parcel                : nuc                                      -  enabled
        system.adapter.parcel.3                 : parcel                : nuc                                      - disabled
        system.adapter.parcel.4                 : parcel                : nuc                                      - disabled
      + system.adapter.shelly.0                 : shelly                : nuc                                      -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.shelly.1                 : shelly                : nuc                                      -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.smartthings.0            : smartthings           : nuc                                      - disabled
      + system.adapter.sourceanalytix.0         : sourceanalytix        : nuc                                      -  enabled
      + system.adapter.sql.0                    : sql                   : nuc                                      -  enabled
      + system.adapter.synology.0               : synology              : nuc                                      -  enabled, port: 5000
      + system.adapter.synology.1               : synology              : nuc                                      -  enabled, port: 5002
      + system.adapter.synology.2               : synology              : nuc                                      -  enabled, port: 5003
      + system.adapter.tankerkoenig.0           : tankerkoenig          : nuc                                      -  enabled
      + system.adapter.tankerkoenig.1           : tankerkoenig          : nuc                                      -  enabled
      + system.adapter.telegram.0               : telegram              : nuc                                      -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.tr-064.0                 : tr-064                : nuc                                      -  enabled
      + system.adapter.tr-064.2                 : tr-064                : nuc                                      -  enabled
      + system.adapter.upnp.0                   : upnp                  : nuc                                      -  enabled
        system.adapter.vis-2.0                  : vis-2                 : nuc                                      - disabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : nuc                                      -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : nuc                                      -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : nuc                                      -  enabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : nuc                                      -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : nuc                                      -  enabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : nuc                                      -  enabled
        system.adapter.vis.0                    : vis                   : nuc                                      -  enabled
      + system.adapter.web.0                    : web                   : nuc                                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      + system.adapter.wled.0                   : wled                  : nuc                                      -  enabled
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "chromecast"   : 4.0.0    , installed 4.0.0
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "denon"        : 1.15.12  , installed 1.15.12
      Adapter    "fb-checkpresence": 1.3.1 , installed 1.3.1
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "harmony"      : 1.5.0    , installed 1.5.0
      Adapter    "heos"         : 2.2.1    , installed 2.2.1
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "shelly"       : 9.2.0    , installed 9.2.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
      Adapter    "vis-lcars"    : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Objects and States
      Objects:        37111
      States:         30457
      Hit:1 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:2 http://deb.debian.org/debian bookworm InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
      Reading package lists...
      Pending Updates: 6
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       19769      530/iobroker.js-con
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       19764      530/iobroker.js-con
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14099      556/sshd: /usr/sbin
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1368       1/init
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       21706      865/io.shelly.1
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      104        19691      529/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14101      556/sshd: /usr/sbin
      tcp6       0      0 :::111                  :::*                    LISTEN      0          1370       1/init
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       8553803    33339/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       21325      585/io.admin.0
      tcp6       0      0 :::8086                 :::*                    LISTEN      104        16220      529/influxd
      tcp6       0      0 :::8000                 :::*                    LISTEN      1001       26610      1126/io.upnp.0
      tcp6       0      0 :::61991                :::*                    LISTEN      1001       21569      741/io.harmony.0
      udp        0      0 0.0.0.0:56846           0.0.0.0:*                           1001       23941      1126/io.upnp.0
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13951      410/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1369       1/init
      udp        0      0 192.168.178.28:123      0.0.0.0:*                           0          8517977    33058/ntpd
      udp        0      0 127.0.0.1:123           0.0.0.0:*                           0          8517975    33058/ntpd
      udp        0      0 0.0.0.0:123             0.0.0.0:*                           0          8517971    33058/ntpd
      udp        0      0 0.0.0.0:33737           0.0.0.0:*                           1001       20373      1069/io.heos.0
      udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       24668      1126/io.upnp.0
      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       21570      741/io.harmony.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       22943      1175/io.wled.0
      udp        0      0 192.168.178.28:5353     0.0.0.0:*                           1001       20120      955/io.tr-064.0
      udp        0      0 0.0.0.0:5678            0.0.0.0:*                           1001       17512576   1039/io.discovery.0
      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       22571      820/io.shelly.0
      udp6       0      0 :::111                  :::*                                0          1371       1/init
      udp6       0      0 fe80::96c6:91ff:fea:123 :::*                                0          8517983    33058/ntpd
      udp6       0      0 2a02:8109:1800:4200:123 :::*                                0          8517981    33058/ntpd
      udp6       0      0 ::1:123                 :::*                                0          8517979    33058/ntpd
      udp6       0      0 :::123                  :::*                                0          8517968    33058/ntpd
      2025-05-02 19:50:52.377  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
      2025-05-02 19:50:55.776  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:05.780  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:05.958  - warn: fullybrowser.0 (66868) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
      2025-05-02 19:51:06.082  - warn: fullybrowser.0 (66868) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
      2025-05-02 19:51:15.777  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:20.778  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:20.833  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:20.836  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:20.839  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:21.882  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:25.722  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
      2025-05-02 19:51:25.773  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:30.780  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:30.928  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:31.950  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:35.778  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:36.883  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:37.012  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:38.045  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:45.779  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:46.951  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:47.055  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:47.153  - info: web.0 (33339) <== Disconnect system.user.admin from ::ffff:192.168.178.44
      2025-05-02 19:51:50.991  - info: web.0 (33339) ==> Connected system.user.admin from ::ffff:192.168.178.44
      • Meister Mopper
        Meister Mopper @Dr.Pie last edited by
        @dr-pie
        Mal abgesehen davon, dass du in graphical target bootest, nicht in der adm group bist und 6 OS updates anstehen ist bei diesen beiden devices was im Argen:
        Dr.Pie 1 Reply Last reply Reply Quote 0
        • Dr.Pie
          Dr.Pie @Meister Mopper last edited by Dr.Pie
          @meister-mopper
          Das Tab mit IP 16 ist das alte Tab.
          Das neue hat IP 44 und Android 14
          • Dr.Pie
            ========== Start marking the full check here ===========
            ```bash
            Script v.2025-02-23
            *** BASE SYSTEM ***
             Static hostname: nuc
                   Icon name: computer-desktop
                     Chassis: desktop 🖥️
                      Kernel: Linux 6.1.0-32-amd64
                Architecture: x86-64
             Hardware Vendor: Intel Corporation
              Hardware Model: NUC7i3BNK
            Firmware Version: BNKBL357.86A.0083.2020.0714.1344
            OS is similar to:
            model name      : Intel(R) Core(TM) i3-7100U CPU @ 2.40GHz
            Docker          : false
            Virtualization  : none
            Kernel          : x86_64
            Userland        : 64 bit
            Systemuptime and Load:
             21:16:00 up 7 days, 11:07,  2 users,  load average: 0.53, 0.57, 0.57
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Operating System is the current Debian stable version codenamed 'bookworm'!
            *** TIME AND TIMEZONES ***
                           Local time: Fri 2025-05-02 21:16:00 CEST
                       Universal time: Fri 2025-05-02 19:16:00 UTC
                             RTC time: Fri 2025-05-02 19:16:00
                          NTP service: n/a
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            jens
            HOME=/home/jens
            iobroker
            HOME=/home/iobroker
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:             16G        4.0G         11G        1.0M        1.9G         12G
            Swap:           1.0G          0B        1.0G
            Total:           17G        4.0G         12G
                     3811 M used memory
                      545 M active memory
                     4304 M inactive memory
                    10613 M free memory
                       21 M buffer memory
                     1771 M swap cache
                      975 M total swap
                        0 M used swap
                      975 M free swap
            top - 21:16:00 up 7 days, 11:07,  2 users,  load average: 0.53, 0.57, 0.57
            Tasks: 144 total,   2 running, 142 sleeping,   0 stopped,   0 zombie
            %Cpu(s): 75.0 us, 25.0 sy,  0.0 ni,  0.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :  15876.2 total,  10613.5 free,   3811.6 used,   1792.2 buff/cache
            MiB Swap:    976.0 total,    976.0 free,      0.0 used.  12064.5 avail Mem
            *** FILESYSTEM ***
            /var:
            2.7G    /var/
            2.2G    /var/log
            379M    /var/cache
            32M     /opt/iobroker/iobroker-data/objects.jsonl
            28M     /opt/iobroker/iobroker-data/states.jsonl
            USB-Devices by-id:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            /usr/bin/nodejs         v20.19.1
            /usr/bin/node           v20.19.1
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            nodejs:
              Installed: 20.19.1-1nodesource1
              Version table:
             *** 20.19.1-1nodesource1 1001
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            nuc                 nuc (version: 7.0.6, hostname: nuc           , alive, uptime: 644824)
            admin:          7.6.3
            javascript:     8.8.3
            Adapter State
            + instance is alive
            Objects and States
            Objects:        37111
            States:         30455
            Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
            Pending Updates: 0
            2025-05-02 21:14:19.970  - warn: fullybrowser.0 (69498) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
            2025-05-02 21:14:21.973  - warn: fullybrowser.0 (69498) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
            2025-05-02 21:14:25.562  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
            2025-05-02 21:14:59.100  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
            2025-05-02 21:15:02.018  - info: host.nuc instance system.adapter.daswetter.1 in version "3.2.3" started with pid 82109
            2025-05-02 21:15:03.213  - info: daswetter.1 (82109) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.1, js-controller: 7.0.6
            2025-05-02 21:15:07.477  - info: daswetter.1 (82109) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-05-02 21:15:07.993  - info: daswetter.1 (82109) cleaned everything up...
            2025-05-02 21:15:08.017  - info: host.nuc instance system.adapter.daswetter.1 having pid 82109 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-05-02 21:15:19.972  - warn: fullybrowser.0 (69498) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
            2025-05-02 21:15:21.976  - warn: fullybrowser.0 (69498) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
            2025-05-02 21:15:32.473  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
            2025-05-02 21:15:38.352  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 3(firetvwz/10:BF:67:01:BF:29) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-05-02 21:15:39.966  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 30(firetv-sz/B4:B7:42:F6:BE:B4) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-05-02 21:15:41.400  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 58(Schrank/A4:CF:12:BF:35:65) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-05-02 21:15:42.837  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 79(TVBoard/A4:CF:12:BF:2F:3C) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-05-02 21:15:43.059  - info: tr-064.0 (955) forEachConfiguredDevice: in GetSpecificHostEntry 82(Vitrine/A4:CF:12:BF:30:54) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
            2025-05-02 21:15:55.033  - info: host.nuc instance system.adapter.daswetter.0 in version "3.2.3" started with pid 82233
            2025-05-02 21:15:56.761  - info: daswetter.0 (82233) starting. Version 3.2.3 in /opt/iobroker/node_modules/iobroker.daswetter, node: v20.19.1, js-controller: 7.0.6
            2025-05-02 21:16:03.694  - info: daswetter.0 (82233) Terminated (ADAPTER_REQUESTED_TERMINATION): All data handled, adapter stopped until next scheduled moment
            2025-05-02 21:16:04.204  - info: daswetter.0 (82233) cleaned everything up...
            2025-05-02 21:16:04.223  - info: host.nuc instance system.adapter.daswetter.0 having pid 82233 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
            2025-05-02 21:16:05.887  - info: synology.0 (876) Connecting to Synology 192.168.178.201:5000
            2025-05-02 21:16:19.972  - warn: fullybrowser.0 (69498) [REST] 192.168.178.16: Sending command get axiosGetDevicesInfo  failed: No response
            2025-05-02 21:16:21.975  - warn: fullybrowser.0 (69498) [REST] 192.168.178.44: Sending command get axiosGetDevicesInfo  failed: No response
            • Dr.Pie
              Und das noch hinterher
              ```bash
                                      v.2025-02-23
                       Chassis: desktop 🖥️
              Installation:           native
              Kernel:                 x86_64
              Userland:               64 bit
              Timezone:               Europe/Berlin (CEST, +0200)
              User-ID:                1000
              Boot Target:            graphical.target
              Pending OS-Updates:     0
              Pending iob updates:    0
              Nodejs-Installation:
              /usr/bin/npm            10.8.2
              /usr/bin/npx            10.8.2
              Recommended versions are nodejs 20.19.1 and npm 10.8.2
              nodeJS installation is correct
              MEMORY:
              Mem:             16G        3.9G         11G        1.1M        1.9G         12G
              Swap:           1.0G          0B        1.0G
              Total:           17G        3.9G         12G
              ioBroker Core:          js-controller           7.0.6
                                      admin                   7.6.3
              Objects type: jsonl
              States  type: jsonl
              Objects:                37111
              States:                 30455
              Size of iob-Database:
              33M     /opt/iobroker/iobroker-data/objects.jsonl
              29M     /opt/iobroker/iobroker-data/states.jsonl
              Aber was meinst du mit "adm group bist" ?
              Würde das weiterhelfen ?
              Wie kommt man da hin ?
              • Meister Mopper
                @dr-pie sagte in Wieder mal der Fully ...:
                Nein, helfen würde es nicht. Wenn du in der Gruppe adm bist, kannst du alle Log-Dateien einsehen.
                  A Former User @Dr.Pie last edited by A Former User
                  Moin
                  nun habe ich ein neues Tab mit Android 14 ... aber auch das funktioniert nicht ... der lädt und lädt und lädt .... es ist zum ******
                  Das Übertragen der Lizenz hat problemlos funktioniert.
                  funktionieren denn andere views von iobroker oder der iobroker admin einwandfrei auf den Tablets?
                  Wifi verbindung auch wirklich ok?
                  Oder ist dein Server zu sehr ausgelastet, um das zu providen?
                  viel hilft viel.. nur mal so.. 🙂
                  Edit:
                  Ich hab auch zwei Tab A, die laden auch keine Vis2 bei mir, liegt wohl am alten Android 8, ich nutze daher zu 80% auf den Tablets MinuVIS, das braucht kaum ressourcen und funktioniert auch mit aelteren Devices gut.
                  Wobei bei mir die Tablets nur Anzeigemedien sind, bedienen tut da keiner was mit, das geht automatisch, wofuer hab ich ein Smarthome wenn ich irgendwo rumklicken muss.. ? 🙂
                  • Dr.Pie
                    Dr.Pie @Guest last edited by
                    @neuschwansteini sagte in Wieder mal der Fully ...:
                    Moin
                    Da ja permanent der Ladebalken dreht, kann natürlich keine einzige View angezeigt werden.
                    Die WLan Verbindung ist exzellent da ich ja alles andere machen kann. Von Mails über Bankgeschäfte. Alle anderen Apps und Anwendungen funktionieren.
                    Da ja auch andere Browser dieses Verhalten haben wenn ich auf den iob zugreifen will, nehme ich mal an das es nicht wirklich am Tab als solches liegt, denn das neue Tab ist schon ziemlich aktuell .... was die Software betrifft.
                      Homoran Global Moderator Administrators @Dr.Pie last edited by
                      @dr-pie du hast ja zu beiden Tabs keine Verbindung!
                      liegt also am Netzwerk, fitewall, pihole oder....ä
                      • Dr.Pie
                        Dr.Pie @Homoran last edited by
                        @homoran sagte in Wieder mal der Fully ...:
                        Wo muss ich denn da nachschauen ?
                        Vom PC oder Laptop komme ich problemlos mit dem Firefox oder Chrome auf die Vis.
                        Da werden alle Views, Edit's und die Tabs in Millisekunden geladen.
                        • Dr. Bakterius
                          Dr. Bakterius Most Active @Dr.Pie last edited by
                          @dr-pie Welche IP hat denn der ioBroker?
                          • Dr.Pie
                            Dr.Pie @Dr. Bakterius last edited by
                            @dr-bakterius sagte in Wieder mal der Fully ...:
                            Der nuc auf dem ich den iob installiert habe ist: 192.168.178.28
                            • Dr. Bakterius
                              @dr-pie Und mit einem normalen Browser am Tablet kannst du die VIS aufrufen?
                              • Dr.Pie
                                Dr.Pie @Dr. Bakterius last edited by Dr.Pie
                                Mit dem Fully geht es auch nach 10 Minuten nicht.
                                Der Firefox dauert auch teilweise 15 Minuten bis er die Vis geladen hat. Dann dauert aber jeder View-Wechsel ebenfalls mehrere Minuten.
                                Und der Samsung Browser funktioniert auch nicht.
                                Nutze ich die Browser aber um damit ins Internet zu kommen, werden die Seiten im Millisekunden geladen.
                                Bankgeschäfte, EMails, Webseiten ... alles seeeehr flink.
                                Auch auf meine 3 Server (Synology) alles schnell ... so wie ich mir das vorstelle.
                                Am PC und am Laptop werden alle Seiten der Vis razfaz geladen.
                                Mit der Vis arbeite ich üblicherweise mit dem Chrome.
                                  Homoran Global Moderator Administrators @Dr.Pie last edited by Homoran
                                  @dr-pie und was schließt du daraus?
                                  dass die Verbindung der Tablets zum ioBroker Server klemmt?
                                  • Dr.Pie
                                    Diese Erkenntnis habe ich schon seit Monaten ... nur eben eine Lösung nicht.
                                      Du bist der einzige der deine Topologie kennt
                                      • Dr.Pie
                                        Ich musste erst mal nach dem Wort googlen ...
                                        "Lehre von der Lage und Anordnung geometrischer Gebilde im Raum"
                                        Wieder etwas schlauer geworden... Danke
                                        Dr.Pie Homoran 2 Replies Last reply Reply Quote 0
                                        • Dr.Pie
                                          Nochwas .... falls von Bedeutung:
                                          Starte ich den Fully an den Tabs, kann ich im iob sehen das der dazugehörige Datenpunkt "true" anzeigt und das WLan Zeichen grün ist
                                            in diesem Fall (Netzwerktopologie) geht es um den Aubau deines Netzwerks.
                                            Was hängt wo an welchem Gerät usw.
                                            1819
