    4. Yet another HomeKit adapter
    • wendy2702
      wendy2702 last edited by
      auch gerade mal das Update gemacht. Habe 5 Instanzen, laut log wurden nur die "Gerade Zahligen" 0,2,4 upgedated:
      $ iobroker upgrade yahka@1.1.2 --debug
      Update yahka from @1.1.1 to @1.1.2
      NPM version: 10.8.2
      Installing iobroker.yahka@1.1.2... (System call)
      npm warn deprecated @npmcli/move-file@2.0.1: This functionality has been moved to @npmcli/fs
      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
      npm warn deprecated gauge@4.0.4: This package is no longer supported.
      changed 1 package in 9s280 packages are looking for funding run `npm fund` for details
      Cannot install "pam-devel": WARNING: apt does not have a stable CLI interface. Use with caution in scripts.E: Unable to locate package pam-devel
      Updating objects from io-package.json for adapter "yahka" with version "1.1.2"
      Update "system.adapter.yahka.0"
      Update "system.adapter.yahka.2"
      Update "system.adapter.yahka.4"
      upload [9] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/css/yahka.admin.css css/yahka.admin.css text/css
      upload [8] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/ext/material/fonts/MaterialSymbolsOutlined_28pt-Regular.ttf ext/material/fonts/MaterialSymbolsOutlined_28pt-Regular.ttf font/ttf
      upload [7] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/favicon.ico favicon.ico image/vnd.microsoft.icon
      upload [6] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/home_icon_large.png home_icon_large.png image/png
      upload [5] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index.html index.html text/html
      upload [4] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/index_m.html index_m.html text/html
      upload [3] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/words.js words.js application/javascript
      upload [2] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js yahka.admin.js application/javascript
      upload [1] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.admin.js.map yahka.admin.js.map application/json
      upload [0] yahka.admin /opt/iobroker/node_modules/iobroker.yahka/admin/yahka.png yahka.png image/png
      Process exited with code 0
      Ist das jetzt ein Fehler im Admin, in Yahka oder wo soll ich suchen?
      Das neue Design ist zum bearbeiten existierender Geräte und einrichten von neuen Geräten leider wirklich suboptimal.
      Thomas Braun 1 Reply Last reply Reply Quote -1
        Thomas Braun Most Active @wendy2702 last edited by
        @wendy2702 sagte in Yet another HomeKit adapter:
        Solltest du nach installieren.
        • wendy2702
          @thomas-braun sagte in Yet another HomeKit adapter:
          Last login: Mon Apr 28 21:30:01 2025 from 192.168.178.162
          mirko@iobroker:~$ sudo apt install libpam0g-dev
          [sudo] password for mirko:
          Reading package lists... Done
          Building dependency tree... Done
          libpam0g-dev is already the newest version (1.5.2-6+deb12u1).
          0 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
          libpam0g is already the newest version (1.5.2-6+deb12u1).
          mirko@iobroker:~$
          Gibt es unter Bookworm noch ein anderes Paket das installiert werden muss.
            @wendy2702
            Ach sorry, das ist das 'falsch' benannte Paket. Bei Debian heißt das libpam0g-dev
            • wendy2702
              wendy2702 @Thomas Braun last edited by wendy2702
              @thomas-braun Genau das gibt es aber ja angeblich schon.
              Bezüglich der Geraden / Ungeraden instanzen scheint es ein Fehler im Upgrade log zu sein. Wenn ich die Instanzen neu starte gibt er mir die richtige Version aus im log.
                Logisch, denn die Instanzen können keine andere Version haben als der eigentliche Adapter.
                • tarikweiss
                  tarikweiss Developer @loverz last edited by
                  @loverz Hey, was wäre denn dein Vorschlag dazu die UI noch übersichtlicher zu gestalten? Die Problematik die vor allem besteht ist, dass letztes (?) [@simatec korrigiere mich gern] Jahr eine Responsive-Design-Offensive beschlossen wurde. Man könnte noch überlegen eine Suche einzubauen, um so schneller Geräte zu filtern. Aber die Verlagerung in ein Modal ist das, was man am besten noch machen konnte (da die Geräte vorher darunter angezeigt wurden, was ja berechtigterweise stark bemängelt wurde). Ich kann mal schauen, ob sich das Modal noch etwas größer ziehen lässt, aber viel mehr würde ich vermutlich auch nicht machen wollen.
                  Vielleicht kann man auch noch einen Expand-All Button einbauen, der auf einmal alle Services expanded. Der neue Adapter bringt halt auch noch Neuerungen mit sich, was die HAP-NodeJS-Implementierung angeht.
                  haselchen Asgothian 2 Replies Last reply Reply Quote 0
                  • haselchen
                    haselchen Most Active @tarikweiss last edited by
                    @tarikweiss
                    Was kannst Du zu dem „pam-devel“ Error im Log sagen nach dem Update?
                    Die Meldung habe ich auch bekommen, dass ich das Paket manuell installieren soll.
                    tarikweiss wendy2702 2 Replies Last reply Reply Quote 0
                    • Asgothian
                      Asgothian Developer @tarikweiss last edited by
                      @tarikweiss sagte in Yet another HomeKit adapter:
                      Vorweg erst einmal eine Frage: Übernimmt HomeKit die Strukturierung nach Räumen inzwischen aus dem ioBroker, oder muss man das immer noch über die Home-App einstellen ?
                      Als zweites mein Vorschlag: Das UI aufbauen wie den Objektbaum.
                      Oberste Ebene - die 'Gruppierung'
                      Nächste Ebene - die 'Devices' (mit einem 'edit' button wie im Objektbaum zum Anpassen der Objekt spezifischen Parameter in einem 'Modal')
                      Nächste Ebene - die 'Services', sowie die device spezifischen Parameter wie 'Datenpunkte', um die zur Not einzeln 'inline' ändern zu können. An den Pseudo-Kanälen für die 'Characteristics' dann wieder einen Edit Button der in ein Modal verweist über das die Einstellungen der Characteristics angepasst werden können.
                      unterste Ebene - die 'Charakteristics' wie 'Datenpunkte' im Objektbaum - hier wieder mit inline Edit Fähigkeit
                      Durch so einen Aufbau bekommt man ein Hybrid-UI, welches vollständig über Responsive Design eingestellt werden kann, welches aber auch wie der Objektbaum genutzt werden kann.
                      Zusätzlich die Option schaffen einem HomeKit Gerät einen 'Channel' oder ein 'Device' im ioBroker Zuzuweisen. Dieses kann dann (sofern zugewiesen) im responsive Modal als Anker für einen auszuwählenden State genutzt werden.
                      Ich hoffe die Beschreibung macht Sinn.
                      A.
                      tarikweiss 2 Replies Last reply Reply Quote 0
                      • tarikweiss
                        tarikweiss Developer @Asgothian last edited by
                        @asgothian Ich denke mal drüber nach. Vielen Dank!
                        • tarikweiss
                          tarikweiss Developer @haselchen last edited by
                          @haselchen Gerade nichts. Wenn du mal ein Log hast, gerne nochmal ins Issue packen, dann schaue ich heute Abend.
                            @tarikweiss
                            Also was mich am meisten stört, ist, dass die linke Bar fehlt.
                            Ich sehe es aus der Brille eines normales users, der nicht weiß was ein Modal ist und was hier an „responsive-design“ beschlossen wurde.
                            Die Linke Bar, mit der Übersicht der Gruppen ist für die Übersicht total wichtig, siehe mein Screenshot unten.
                            Die Editierung der Einzelnen Geräte kann von mir aus gern mit dem neuen Design sein.
                            @loverz sagte in Yet another HomeKit adapter:
                            Zur Erinnerung:
                            ALT:
                            NEU:
                            tarikweiss 1 Reply Last reply Reply Quote 0
                            • haselchen
                              @tarikweiss
                              • wendy2702
                                wendy2702 @haselchen last edited by
                                @haselchen War das bei dir, wie bei mir, denn auch schon installiert?
                                • haselchen
                                  haselchen Most Active @wendy2702 last edited by
                                  @wendy2702
                                  Genau das Gleiche.
                                  Vor allem komisch , weil es das Paket, so wie es in der Meldung formuliert ist, nicht gibt .
                                  • tarikweiss
                                    @asgothian Wenn ich mich nicht täusche, dann kann die Strukturierung nicht aus dem Adapter heraus erfolgen. Also das muss immer in der Home-App passieren.
                                    • tarikweiss
                                      @loverz Aber die "linke Bar" ist nun einfach über den ganzen Bildschirm gezogen. Ich verstehe das Problem gerade nicht. Also ist nicht gut genug erkennbar was Gruppe und was Gerät ist, oder was ist das konkrete Problem? Wenn dann mach auch gern ein neues Issue im Adapter dazu auf. Danke!
                                      • tarikweiss
                                        tarikweiss Developer last edited by tarikweiss
                                        @haselchen sagte in Yet another HomeKit adapter:
                                        pam-devel
                                        Hast du mal libpam0g installiert?
                                        EDIT: Respektive noch libpam0g-dev.
                                        • wendy2702
                                          wendy2702 @tarikweiss last edited by wendy2702
                                          @tarikweiss bin zwar nicht @haselchen hatte aber die gleiche Meldung obwohl bei mir diese beiden Pakete bereits installiert waren.
                                          Edit: siehe hier https://forum.iobroker.net/post/1269517
                                            loverz @tarikweiss last edited by loverz
                                            Die Linke Bar ist tatsächlich nicht das größte Problem, aber hilft, da man damit zwischen den Geräten hin und herspringen kann.
                                            Die gesamte Übersicht ist meiner Meinung nach in der neuen Version katastophal.
                                            In der neuen Ansicht bin ich nur am rumscrollen, alles ist verschachtelt und ich habe überhaupt keine Gesamtübersicht auf meine Devices. Mal kurz "abschauen" wie ich es an einem anderen Gerät eingerichtet habe nahezu unmöglich.
                                            Hier mal zwei Videos, die das veranschaulichen.
                                            1.2k
                                            80.8k
                                            1761
                                            794438
