Node.js Downgrade in ioBroker (Docker Cont, Synology)
anbei noch der diagnose Auszug
v.2025-02-23 /home/iobroker/.diag.sh: line 979: hostnamectl: command not found Installation: Kernel: x86_64 Userland: 64 bit /home/iobroker/.diag.sh: line 988: timedatectl: command not found Timezone: User-ID: 0 Display-Server: false /home/iobroker/.diag.sh: line 995: systemctl: command not found Boot Target: Pending OS-Updates: 0 Pending iob updates: 0 Nodejs-Installation: /usr/bin/nodejs v22.15.0 /usr/bin/node v22.15.0 /usr/bin/npm 10.9.2 /usr/bin/npx 10.9.2 /usr/bin/corepack 0.32.0 Recommended versions are nodejs 20.19.1 and npm 10.8.2 nodeJS installation is correct MEMORY: total used free shared buff/cache available Mem: 3.9G 2.6G 623M 30M 715M 1.1G Swap: 4.4G 726M 3.7G Total: 8.4G 3.3G 4.3G Active iob-Instances: 18 Upgrade policy: none ioBroker Core: js-controller 7.0.7 admin 7.6.14 ioBroker Status: iobroker is running on this host. Objects type: jsonl States type: jsonl Status admin and web instance: + system.adapter.admin.0 : admin : buanet-iobroker1 - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.web.0 : web : buanet-iobroker1 - enabled, port: 8082, bind: 0.0.0.0, run as: admin Objects: 4455 States: 3890 Size of iob-Database: 35M /opt/iobroker/iobroker-data/objects.jsonl 8.8M /opt/iobroker/iobroker-data/objects.json.migrated8.8M /opt/iobroker/iobroker-data/objects.json.bak.migrated 7.0M /opt/iobroker/iobroker-data/states.jsonl 1.2M /opt/iobroker/iobroker-data/states.json.migrated 1.2M /opt/iobroker/iobroker-data/states.json.bak.migrated 0 /opt/iobroker/iobroker-data/states.json.broken Debian Release codenamed 'buster' reached its END OF LIFE and needs to be updated to the latest stable release 'bookworm' NOW! =================== END OF SUMMARY ====================
Ich hab im Moment eher die Vermutung dass da was krumm installiert ist. Mir fällt eigentlich nicht ein, auf welchem Weg der Parser Adapter (ioBroker.parser) da hap-nodejs einschleppen sollte.
HAP-NodeJS is an implementation of the HomeKit Accessory Server as specified in the HomeKit Accessory Protocol (HAP), which is defined by Apple as part of the HomeKit Framework.
hap-nodejs ist auch auf meiner eben erst erfolgten Testinstallation weder als file unter node_modules vorhanden noch in package-lock.json als indirelte dependency gelistet.
Dein iob diag ist leider nur die Zusammenfassung. Da sieht man nicht viel.In jedem Fall können dir aber andere beim npm dependency Problem besser helfen.
@entavio sagte in Node.js Downgrade in ioBroker (Docker Cont, Synology):
Zu alt. Da muss was lebendiges installiert werden.
das ist doch uralt was du da laufen hast.. zieh einen neuen Container
Mach doch einfach nen Rebuild mit aktuellem image. Wenn das nicht funktioniert, neu aufsetzen und backup. Das ist doch schnell erledigt.
Oder, wenn Du zukünftig weiterhin beta tests machen willst, setz Dir ein Linux auf und installier ioBroker dort. Container sind dazu ungeeignet.
@toralt einfach? hab ich noch nie gemacht muss ich mir erstmal anschauen was da zu sichern, im einzelnen zu tun ist
buanet-iobroker image scheint nur mit Debian-bullseye statt bookworm zur verfügung zu stehen?
@entavio
Seit Release 9 definitiv Debian 12https://github.com/buanet/ioBroker.docker/releases?page=2
Du musst natürlich das aktuelleste Image ziehen und nicht versuchen den alten Kram neu zu installieren
@samson71 na ja ich zieh mir ein neues buanet-iobroker latest image
wie gesagt steht direkt dabei das bullseye als Debian verwendet wird -
@entavio
Ne, da steht klar dabei dass es mit bookworm ist:
@jan1 ich kann nur in dem Docker Container auf der Synology hier das image laden und dann sieht das so aus
-entfernt-
außer ich gebe eine repository url ein, aber wie lautet die?
@entavio
bitte keine Bilder auf externen Servern ablegen sondern hier über die Zwischenablage oder die Uploadfunktion hochladen. -
wie gesagt steht direkt dabei das bullseye als Debian verwendet wirdMit Sicherheit nicht. Du ziehst offenbar das falsche Image.
Nimm als Tag das
:latest-v10
@codierknecht hab das bild / url wieder entfernt
hab jetzt latest v-10 gezogen, die Beschreibung bleibt gleich
Die Beschreibung auf Docker Hub ist noch falsch. Es ist Bookworm.
Ergänzung: Ich habe einen PR eingestellt. Mal schauen, wann André das aufnehmen kann.
also konnte das neue image installieren, meine Daten wieder einfügen und komme auch wieder auf die admin Oberfläche.
der parser Adapter lässt sich jetzt einwandfrei installieren (den Adapter selbst schaue ich mir dann an)leider macht aber jetzt der yahka Adapter Probleme und startet nicht mehr
im log werden jetzt unzählige Fehler geworfen
Und die sind geheim und dürfen nicht bekannt gemacht werden?
Dann wird dir wohl auch niemand helfen können und dürfen. -
@thomas-braun natürlich nicht sry. geht nicht alles so schnell
das sich an der Namensgebung der gerate gestört wird, sehe ich selbst..... wundere mich nur warum es vorhin noch ging
reicht es aus alles umzubenennen?!2025-05-06 12:52:23.456 - info: yahka.0 (2824) publishing bridge yahka on 0.0.0.0 using bonjour-hap 2025-05-06 12:52:23.464 - info: yahka.0 (2824) publishing device DG-Schlafzimmer Fernseher on 0.0.0.0 using avahi 2025-05-06 12:52:23.759 - info: yahka.0 (2824) publishing device OG-Wohnzimmer Fernseher on 0.0.0.0 using avahi 2025-05-06 12:52:23.823 - error: yahka.0 (2824) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2025-05-06 12:52:23.824 - error: yahka.0 (2824) unhandled promise rejection: EISDIR: illegal operation on a directory, read 2025-05-06 12:52:24.185 - error: yahka.0 (2824) Error: EISDIR: illegal operation on a directory, read at Object.readFileSync (node:fs:449:20) at LocalStorage.parseDirSync (/opt/iobroker/node_modules/hap-nodejs/node_modules/node-persist/src/local-storage.js:637:35) at LocalStorage.parseDataDirSync (/opt/iobroker/node_modules/hap-nodejs/node_modules/node-persist/src/local-storage.js:572:21) at LocalStorage.initSync (/opt/iobroker/node_modules/hap-nodejs/node_modules/node-persist/src/local-storage.js:145:14) at HAPStorage.storage (/opt/iobroker/node_modules/hap-nodejs/src/lib/model/HAPStorage.ts:28:25) at Function.storage (/opt/iobroker/node_modules/hap-nodejs/src/lib/model/HAPStorage.ts:16:26) at Function.load (/opt/iobroker/node_modules/hap-nodejs/src/lib/model/AccessoryInfo.ts:278:30) at Bridge.publish (/opt/iobroker/node_modules/hap-nodejs/src/lib/Accessory.ts:1126:41) at devicesToPublish (/opt/iobroker/node_modules/iobroker.yahka/webpack:/yahka.homekit-bridge.ts:34:35) at /opt/iobroker/node_modules/iobroker.yahka/webpack:/yahka.homekit-bridge.ts:77:41 2025-05-06 12:52:24.186 - error: yahka.0 (2824) Exception-Code: EISDIR: EISDIR: illegal operation on a directory, read 2025-05-06 12:52:24.235 - info: yahka.0 (2824) cleaning up ... 2025-05-06 12:52:24.236 - info: yahka.0 (2824) cleaned up ... 2025-05-06 12:52:24.238 - info: yahka.0 (2824) terminating 2025-05-06 12:52:24.240 - warn: yahka.0 (2824) Terminated (UNCAUGHT_EXCEPTION): Without reason 2025-05-06 12:52:24.745 - info: yahka.0 (2824) terminating 2025-05-06 12:52:24.875 - error: host.buanet-iobroker1 Caught by controller[0]: HAP-NodeJS WARNING: The accessory 'DG-Schlafzimmer Ventilator' has an invalid 'Name' characteristic ('DG-Schlafzimmer Ventilator'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.875 - error: host.buanet-iobroker1 Caught by controller[1]: HAP-NodeJS WARNING: The accessory 'DG-Schlafzimmer Ventilator' has an invalid 'Name' characteristic ('DG-Schlafzimmer Ventilator'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.876 - error: host.buanet-iobroker1 Caught by controller[2]: HAP-NodeJS WARNING: The accessory 'OG-Wohnzimmer Stehlampe' has an invalid 'Name' characteristic ('OG-Wohnzimmer Stehlampe'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.877 - error: host.buanet-iobroker1 Caught by controller[3]: HAP-NodeJS WARNING: The accessory 'OG-Wohnzimmer Stehlampe' has an invalid 'Name' characteristic ('OG-Wohnzimmer Stehlampe'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.877 - error: host.buanet-iobroker1 Caught by controller[4]: HAP-NodeJS WARNING: The accessory 'DG-Schlafzimmer Fernseher' has an invalid 'Name' characteristic ('DG-Schlafzimmer Fernseher'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.878 - error: host.buanet-iobroker1 Caught by controller[5]: HAP-NodeJS WARNING: The accessory 'DG-Schlafzimmer Fernseher' has an invalid 'Name' characteristic ('DG-Schlafzimmer Fernseher'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.878 - error: host.buanet-iobroker1 Caught by controller[6]: HAP-NodeJS WARNING: The accessory 'OG-Wohnzimmer Fernseher' has an invalid 'Name' characteristic ('OG-Wohnzimmer Fernseher'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.879 - error: host.buanet-iobroker1 Caught by controller[7]: HAP-NodeJS WARNING: The accessory 'OG-Wohnzimmer Fernseher' has an invalid 'Name' characteristic ('OG-Wohnzimmer Fernseher'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.879 - error: host.buanet-iobroker1 Caught by controller[8]: HAP-NodeJS WARNING: The accessory '' has an invalid 'Name' characteristic (''). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.880 - error: host.buanet-iobroker1 Caught by controller[9]: HAP-NodeJS WARNING: The accessory 'DG-Schlafzimmer Fernseher 47C3' has an invalid 'Name' characteristic ('DG-Schlafzimmer Fernseher 47C3'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.880 - error: host.buanet-iobroker1 Caught by controller[10]: HAP-NodeJS WARNING: The accessory 'OG-Wohnzimmer Fernseher 2564' has an invalid 'Name' characteristic ('OG-Wohnzimmer Fernseher 2564'). Please use only alphanumeric, space, and apostrophe characters. Ensure it starts and ends with an alphabetic or numeric character, and avoid emojis. This may prevent the accessory from being added in the Home App or cause unresponsiveness. 2025-05-06 12:52:24.881 - error: host.buanet-iobroker1 Caught by controller[11]: [DG-Schlafzimmer Fernseher 47C3] The selected advertiser, "avahi", isn't available on this platform. Reverting to "ciao" 2025-05-06 12:52:24.881 - error: host.buanet-iobroker1 Caught by controller[12]: [OG-Wohnzimmer Fernseher 2564] The selected advertiser, "avahi", isn't available on this platform. Reverting to "ciao" 2025-05-06 12:52:24.882 - error: host.buanet-iobroker1 Caught by controller[13]: [yahka 818C@DG-Schlafzimmer Ventilator@DG-Schlafzimmer Ventilator@Lock Physical Controls] characteristic value expected valid finite number and received "undefined" (undefined) 2025-05-06 12:52:24.882 - error: host.buanet-iobroker1 Caught by controller[14]: [yahka 818C@DG-Schlafzimmer Ventilator@DG-Schlafzimmer Ventilator@Swing Mode] characteristic value expected valid finite number and received "undefined" (undefined) 2025-05-06 12:52:24.882 - error: host.buanet-iobroker1 Caught by controller[15]: [yahka 818C@DG-Schlafzimmer Ventilator@DG-Schlafzimmer Ventilator@Active] characteristic value expected valid finite number and received "undefined" (undefined) 2025-05-06 12:52:24.883 - error: host.buanet-iobroker1 Caught by controller[16]: [yahka 818C@Schlafzimmer Rack@Schlafzimmer Rack@Name] characteristic was supplied illegal value: number instead of string, supplying illegal values will throw errors in the future 2025-05-06 12:52:24.883 - error: host.buanet-iobroker1 Caught by controller[17]: [yahka 818C@Schlafzimmer Rack 2@Schlafzimmer Rack 2@Name] characteristic was supplied illegal value: number instead of string, supplying illegal values will throw errors in the future 2025-05-06 12:52:24.884 - error: host.buanet-iobroker1 instance system.adapter.yahka.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2025-05-06 12:52:24.885 - info: host.buanet-iobroker1 Restart adapter system.adapter.yahka.0 because enabled 2025-05-06 12:52:24.885 - warn: host.buanet-iobroker1 Do not restart adapter system.adapter.yahka.0 because restart loop detected
@entavio
Du musst im Container die UmgebungsvariableAVAHI
auf "true" setzen.Hier mal meine Projekteinstellungen:
services: iobroker: container_name: iobroker image: buanet/iobroker:latest hostname: iobroker volumes: - /volume1/docker/iobroker:/opt/iobroker ports: - "8089:8081" - "3022:22" - "2010:2010" environment: PACKAGES: "nano openssh-server" AVAHI: "true" tty: true stdin_open: true restart: unless-stopped
@codierknecht die variable hab ich gesetzt, immer noch der Fehler
ggfs. weil ich jetzt mit dem neuen image wieder auf node.js Version 20 bin und yahka sich irgendwas von der 22. Version gemerkt hat?!
