    4. Iobroker Oberfläche nicht mehr nutzbar
    • Ro75
      Ro75 @Kellerkind-86 last edited by
      @kellerkind-86 sagte in Iobroker Oberfläche nicht mehr nutzbar:
      daraufhin hab ich alles neuaufgespielt
      Backup (falls gemeint) wird nicht reichen - da muss ein neuer Datenträger rein.
      Ro75.
      K 2 Replies Last reply Reply Quote 1
        Kellerkind-86 @Ro75 last edited by
        @ro75 okay, dankeschön
          @ro75 so.. jetzt ne neue ssd drin. aber was sagen diese fehlermeldungen und wie kann ich sie beheben ?
          ========== Start marking the full check here ===========
          ```bash
          Script v.2025-02-23
          *** BASE SYSTEM ***
          Failed to query system properties: Connection timed out
          OS is similar to:
          model name      : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz
          Docker          : false
          Virtualization  : lxc
          Kernel          : x86_64
          Userland        : 64 bit
          Systemuptime and Load:
           09:20:31 up 50 min,  0 user,  load average: 0.32, 0.26, 0.27
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          Operating System is the current Debian stable version codenamed 'bookworm'!
          *** TIME AND TIMEZONES ***
          Failed to query server: Unit dbus-org.freedesktop.timedate1.service failed to load properly, please adjust/correct and reload service manager: File exists
          Failed to parse bus message: File exists
          *** Users and Groups ***
          User that called 'iob diag':
          tigger
          HOME=/home/tigger
          GROUPS=tigger users iobroker
          js-controller is not running
          *** DISPLAY-SERVER SETUP ***
          Display-Server: false
          Desktop:
          Terminal:
          *** MEMORY ***
          Mem:            8.6G        123M        7.4G         77K        1.0G        8.5G
          Swap:           2.1G          0B        2.1G
          Total:           10G        123M        9.6G
          Active iob-Instances:   1
                   8192 M total memory
                    118 M used memory
                    120 M active memory
                    874 M inactive memory
                   7099 M free memory
                      0 M buffer memory
                    974 M swap cache
                   2048 M total swap
                      0 M used swap
                   2048 M free swap
          top - 09:20:32 up 50 min,  0 user,  load average: 0.30, 0.26, 0.27
          Tasks:  29 total,   1 running,  28 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   8192.0 total,   7098.2 free,    119.6 used,    974.3 buff/cache
          MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   8072.4 avail Mem
          *** FAILED SERVICES ***
            UNIT                               LOAD   ACTIVE SUB    DESCRIPTION
          * iobroker.service                   loaded failed failed ioBroker Server
          * nftables.service                   loaded failed failed nftables
          * systemd-hostnamed.service          loaded failed failed Hostname Service
          * systemd-logind.service             loaded failed failed User Login Management
          * systemd-networkd.service           loaded failed failed Network Configuration
          * systemd-sysctl.service             loaded failed failed Apply Kernel Variables
          * systemd-sysusers.service           loaded failed failed Create System Users
          * systemd-timedated.service          masked failed failed systemd-timedated.service
          * systemd-tmpfiles-clean.service     loaded failed failed Cleanup of Temporary Directories
          * systemd-tmpfiles-setup-dev.service loaded failed failed Create Static Device Nodes in /dev
          * systemd-tmpfiles-setup.service     loaded failed failed Create System Files and Directories
          * systemd-networkd.socket            loaded failed failed Network Service Netlink Socket
          LOAD   = Reflects whether the unit definition was properly loaded.
          ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
          SUB    = The low-level unit activation state, values depend on unit type.
          12 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          Filesystem                       Type   Size  Used Avail Use% Mounted on
          /dev/mapper/pve-vm--103--disk--0 ext4    25G  7.0G   17G  31% /
          none                             tmpfs  492K  4.0K  488K   1% /dev
          tmpfs                            tmpfs  7.8G     0  7.8G   0% /dev/shm
          tmpfs                            tmpfs  3.2G   72K  3.2G   1% /run
          tmpfs                            tmpfs  5.0M     0  5.0M   0% /run/lock
          [Tue Apr 22 16:56:52 2025] EXT4-fs (dm-1): mounted filesystem 208af763-f721-4927-a9c2-c7e1b74a0dd0 ro with ordered data mode. Quota mode: none.
          [Tue Apr 22 16:56:53 2025] EXT4-fs (dm-1): re-mounted 208af763-f721-4927-a9c2-c7e1b74a0dd0 r/w. Quota mode: none.
          [Tue Apr 22 17:13:45 2025] EXT4-fs (loop0): mounted filesystem 43d49d75-3d08-481b-b503-83b22a667290 r/w with ordered data mode. Quota mode: none.
          [Tue Apr 22 17:16:34 2025] EXT4-fs (loop0): unmounting filesystem 43d49d75-3d08-481b-b503-83b22a667290.
          [Tue Apr 22 17:17:05 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 50 higher than expected, please wait.
          [Tue Apr 22 17:17:56 2025] EXT4-fs (loop0): I/O error while writing superblock
          [Tue Apr 22 17:17:56 2025] EXT4-fs (loop0): mount failed
          [Tue Apr 22 17:19:42 2025] EXT4-fs (loop0): mounted filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244 r/w with ordered data mode. Quota mode: none.
          [Tue Apr 22 17:20:40 2025] EXT4-fs (loop0): unmounting filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244.
          [Tue Apr 22 17:21:21 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 66 higher than expected, please wait.
          [Tue Apr 22 17:22:35 2025] EXT4-fs (loop0): I/O error while writing superblock
          [Tue Apr 22 17:22:35 2025] EXT4-fs (loop0): mount failed
          [Tue Apr 22 18:30:44 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
          [Tue Apr 22 18:31:27 2025] EXT4-fs warning (device loop0): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
          [Tue Apr 22 18:31:27 2025] EXT4-fs (loop0): I/O error while writing superblock
          [Tue Apr 22 22:41:44 2025] EXT4-fs (loop0): mounted filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244 r/w with ordered data mode. Quota mode: none.
          [Tue Apr 22 22:43:26 2025] EXT4-fs warning (device loop1): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
          [Tue Apr 22 22:44:09 2025] EXT4-fs warning (device loop1): ext4_clear_journal_err:6318: Filesystem error recorded from previous mount: IO failure
          [Tue Apr 22 22:44:09 2025] EXT4-fs (loop1): I/O error while writing superblock
          [Tue Apr 22 22:57:45 2025] EXT4-fs (loop0): unmounting filesystem 3570c406-03b5-4b6e-a1a0-00d86aa01244.
          [Tue Apr 22 23:12:23 2025] EXT4-fs warning (device loop0): ext4_multi_mount_protect:328: MMP interval 42 higher than expected, please wait.
          [Tue Apr 22 23:13:06 2025] EXT4-fs (loop0): I/O error while writing superblock
          [Tue Apr 22 23:13:06 2025] EXT4-fs (loop0): mount failed
          [Wed Apr 23 01:49:04 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
          [Wed Apr 23 01:49:36 2025] EXT4-fs (dm-16): unmounting filesystem 486ba40f-561e-4cb9-bd41-bf602213371e.
          [Wed Apr 23 01:50:25 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
          [Wed Apr 23 01:51:19 2025] EXT4-fs (dm-17): mounted filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9 r/w with ordered data mode. Quota mode: none.
          [Wed Apr 23 01:51:34 2025] EXT4-fs (dm-17): unmounting filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9.
          [Wed Apr 23 01:53:09 2025] EXT4-fs (dm-17): mounted filesystem f8361b57-07fd-43c1-a20c-aaa8badc47b9 r/w with ordered data mode. Quota mode: none.
          [Wed Apr 23 07:23:44 2025] EXT4-fs (dm-18): mounted filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d r/w with ordered data mode. Quota mode: none.
          [Wed Apr 23 07:23:57 2025] EXT4-fs (dm-18): unmounting filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d.
          [Wed Apr 23 07:24:04 2025] EXT4-fs (dm-18): mounted filesystem 2bc6f3ba-8f27-4855-8610-f9005235763d r/w with ordered data mode. Quota mode: none.
          [Wed Apr 23 08:29:19 2025] EXT4-fs (dm-16): unmounting filesystem 486ba40f-561e-4cb9-bd41-bf602213371e.
          [Wed Apr 23 08:29:34 2025] EXT4-fs (dm-16): mounted filesystem 486ba40f-561e-4cb9-bd41-bf602213371e r/w with ordered data mode. Quota mode: none.
          Show mounted filesystems:
          TARGET SOURCE                           FSTYPE OPTIONS
          /      /dev/mapper/pve-vm--103--disk--0 ext4   rw,relatime,stripe=16
          /var:
          497M    /var/
          282M    /var/cache
          278M    /var/cache/apt
          202M    /var/cache/apt/archives
          147M    /var/lib
                Users in the 'systemd-journal' group can see all messages. Pass -q to
                turn off this notice.
          Archived and active journals take up 8.0M in the file system.
          /opt/iobroker/backups:
          90M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          1.5G    /opt/iobroker/iobroker-data/
          1.4G    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
          35M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
          27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map
          26M     /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map
          USB-Devices by-id:
          No Devices found 'by-id'
          *** ZigBee Settings ***
          HINT:
          Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
          tcp
          Zigbee Network Settings on your coordinator/in nvbackup are:
          zigbee.X
          Extended Pan ID:
          *** MASKED ***
          Pan ID:
          *** MASKED ***
          Channel:
          *** MASKED ***
          Network Key:
          *** MASKED ***
          To unmask the settings run 'iob diag --unmask'
          *** NodeJS-Installation ***
          /usr/bin/nodejs         v20.19.1
          /usr/bin/node           v20.19.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.31.0
          nodejs:
            Installed: 20.19.1-1nodesource1
            Candidate: 20.19.1-1nodesource1
            Version table:
           *** 20.19.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                  100 /var/lib/dpkg/status
               20.19.0-1nodesource1 1001
               20.18.3-1nodesource1 1001
               20.18.2-1nodesource1 1001
               20.18.1-1nodesource1 1001
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
                  500 http://deb.debian.org/debian bookworm/main amd64 Packages
               18.19.0+dfsg-6~deb12u1 500
                  500 http://security.debian.org bookworm-security/main amd64 Packages
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          iobroker is not running on this host.
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 601)
          Core adapters versions
          js-controller:  7.0.6
          admin:          7.6.3
          javascript:     8.8.3
          nodejs modules from github:     2
          +-- iobroker.evcc@0.1.1 (git+ssh://git@github.com/Newan/ioBroker.evcc.git#47c01e1026b8011a8407e3cb5f039a22d92ef9b2)
          | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
          Adapter State
            system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.alexa-shoppinglist.0     : alexa-shoppinglist    : IO-Broker                                - disabled
            system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
            system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
            system.adapter.birthdays.0              : birthdays             : IO-Broker                                -  enabled
            system.adapter.bluelink.0               : bluelink              : IO-Broker                                -  enabled
            system.adapter.devices.0                : devices               : IO-Broker                                - disabled
            system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
            system.adapter.dwd.0                    : dwd                   : IO-Broker                                -  enabled
            system.adapter.echarts.0                : echarts               : IO-Broker                                -  enabled
            system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IO-Broker                                -  enabled
            system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker                                -  enabled
            system.adapter.evcc.0                   : evcc                  : IO-Broker                                -  enabled, port: 7070
            system.adapter.feiertage.0              : feiertage             : IO-Broker                                -  enabled
            system.adapter.fritzbox.0               : fritzbox              : IO-Broker                                - disabled
            system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
            system.adapter.harmony.0                : harmony               : IO-Broker                                -  enabled
            system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
            system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
            system.adapter.hm-rpc.1                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
            system.adapter.homekit-controller.0     : homekit-controller    : IO-Broker                                - disabled
            system.adapter.ical.0                   : ical                  : IO-Broker                                -  enabled
            system.adapter.ical.1                   : ical                  : IO-Broker                                -  enabled
            system.adapter.influxdb.0               : influxdb              : IO-Broker                                - disabled, port: 8086
            system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
            system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
            system.adapter.luftdaten.0              : luftdaten             : IO-Broker                                -  enabled
            system.adapter.mqtt-client.0            : mqtt-client           : IO-Broker                                -  enabled, port: 1883
            system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                -  enabled, port: 1883, bind: 0.0.0.0
            system.adapter.octoprint.0              : octoprint             : IO-Broker                                -  enabled
            system.adapter.onvif.0                  : onvif                 : IO-Broker                                - disabled, port: 80, 7575, 8000, 8080, 8081, 8899
            system.adapter.pollenflug.0             : pollenflug            : IO-Broker                                -  enabled
            system.adapter.renacidc.0               : renacidc              : IO-Broker                                -  enabled
            system.adapter.scenes.0                 : scenes                : IO-Broker                                -  enabled
            system.adapter.schoolfree.0             : schoolfree            : IO-Broker                                -  enabled
            system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1880, bind: 0.0.0.0
            system.adapter.shelly.1                 : shelly                : IO-Broker                                - disabled, port: 1882, bind: 0.0.0.0
            system.adapter.shuttercontrol.0         : shuttercontrol        : IO-Broker                                -  enabled
            system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
            system.adapter.tankerkoenig.0           : tankerkoenig          : IO-Broker                                -  enabled
            system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
            system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
            system.adapter.tr-064.0                 : tr-064                : IO-Broker                                - disabled
            system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
            system.adapter.unifi.0                  : unifi                 : IO-Broker                                - disabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : IO-Broker                                - disabled
            system.adapter.vis-2-widgets-gauges.0   : vis-2-widgets-gauges  : IO-Broker                                - disabled
            system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IO-Broker                                - disabled
            system.adapter.vis-2.0                  : vis-2                 : IO-Broker                                -  enabled
            system.adapter.vis-google-fonts.0       : vis-google-fonts      : IO-Broker                                -  enabled
            system.adapter.vis-icontwo.0            : vis-icontwo           : IO-Broker                                - disabled
            system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
            system.adapter.vis-metro.0              : vis-metro             : IO-Broker                                - disabled
            system.adapter.vis-timeandweather.0     : vis-timeandweather    : IO-Broker                                - disabled
            system.adapter.vis.0                    : vis                   : IO-Broker                                -  enabled
            system.adapter.weatherunderground.0     : weatherunderground    : IO-Broker                                -  enabled
            system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            system.adapter.web.1                    : web                   : IO-Broker                                -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
            system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IO-Broker                                - disabled
            system.adapter.wiffi-wz.0               : wiffi-wz              : IO-Broker                                -  enabled
            system.adapter.ws.0                     : ws                    : IO-Broker                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
            system.adapter.yr.0                     : yr                    : IO-Broker                                -  enabled
            system.adapter.zigbee.0                 : zigbee                : IO-Broker                                -  enabled, port: tcp://192.168.178.165:6638
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Upgrade policy: none
          Installed ioBroker-Adapters
          Used repository: stable
          Adapter    "admin"        : 7.6.3    , installed 7.6.3
          Adapter    "alexa-shoppinglist": 1.0.3, installed 1.0.3
          Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
          Adapter    "backitup"     : 3.0.31   , installed 3.0.31
          Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
          Adapter    "bluelink"     : 2.3.6    , installed 2.3.6
          Adapter    "echarts"      : 1.9.2    , installed 1.9.2
          Adapter    "ecovacs-deebot": 1.4.15  , installed 1.4.15
          Adapter    "energiefluss-erweitert": 0.6.2, installed 0.6.2
          Adapter    "evcc"         : 0.1.1    , installed 0.1.1
          Adapter    "feiertage"    : 1.2.1    , installed 1.2.1
          Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
          Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
          Adapter    "harmony"      : 1.5.0    , installed 1.5.0
          Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
          Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
          Adapter    "homekit-controller": 0.5.11, installed 0.5.11
          Adapter    "ical"         : 1.16.1   , installed 1.16.1
          Adapter    "iot"          : 3.3.0    , installed 3.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.6
          Adapter    "luftdaten"    : 4.0.0    , installed 4.0.0
          Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
          Adapter    "mqtt-client"  : 3.0.0    , installed 3.0.0
          Adapter    "octoprint"    : 5.1.0    , installed 5.1.0
          Adapter    "onvif"        : 1.1.4    , installed 1.1.4
          Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
          Adapter    "renacidc"     : 0.1.4    , installed 0.1.4
          Adapter    "scenes"       : 3.2.3    , installed 3.2.3
          Adapter    "schoolfree"   : 1.1.9    , installed 1.1.9
          Adapter    "shelly"       : 9.2.0    , installed 9.2.0
          Adapter    "shuttercontrol": 2.0.1   , installed 2.0.1
          Adapter    "socketio"     : 6.7.1    , installed 7.0.8
          Adapter    "synology"     : 3.1.0    , installed 3.1.0
          Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
          Adapter    "telegram"     : 4.1.0    , installed 4.1.0
          Adapter    "text2command" : 3.0.3    , installed 3.0.3
          Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
          Adapter    "trashschedule": 3.3.0    , installed 3.3.0
          Adapter    "unifi"        : 0.7.0    , installed 0.7.0
          Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
          Adapter    "vis-2-widgets-gauges": 1.1.0, installed 1.1.0
          Adapter    "vis-2-widgets-material": 1.4.10, installed 1.4.10
          Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
          Adapter    "vis-inventwo" : 3.3.4    , installed 3.3.4
          Adapter    "weatherunderground": 3.7.0, installed 3.7.0
          Adapter    "web"          : 7.0.8    , installed 7.0.8
          Adapter    "whatsapp-cmb" : 0.3.0    , installed 0.3.0
          Adapter    "wiffi-wz"     : 2.2.1    , installed 2.2.1
          Adapter    "ws"           : 2.6.2    , installed 3.0.19
          Adapter    "yr"           : 5.3.0    , installed 5.3.0
          Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
          Objects and States
          Objects:        19956
          States:         15607
          Hit:1 http://security.debian.org bookworm-security InRelease
          Hit:2 http://deb.debian.org/debian bookworm InRelease
          Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
          Hit:4 https://repo.mosquitto.org/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 0
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        1664487    155/mosquitto
          tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          1664324    1/init
          tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          1664587    313/master
          tcp6       0      0 :::1883                 :::*                    LISTEN      105        1664488    155/mosquitto
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1663846    1/init
          tcp6       0      0 :::111                  :::*                    LISTEN      0          1662748    1/init
          tcp6       0      0 ::1:25                  :::*                    LISTEN      0          1664588    313/master
          udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          1664325    1/init
          udp6       0      0 :::111                  :::*                                0          1661881    1/init
          2025-04-23 06:39:47.888  - info: host.IO-Broker instance system.adapter.zigbee.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.888  - info: host.IO-Broker instance system.adapter.bluelink.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.evcc.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.iot.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.907  - info: host.IO-Broker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.921  - info: host.IO-Broker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.921  - info: host.IO-Broker instance system.adapter.hm-rega.0 terminated with code 0 (NO_ERROR)
          2025-04-23 06:39:47.921  - info: host.IO-Broker All instances are stopped.
          2025-04-23 06:39:48.054  - warn: host.IO-Broker instance system.adapter.telegram.0 terminated due to SIGKILL
          2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.telegram.0 terminated with code null ()
          2025-04-23 06:39:48.055  - info: host.IO-Broker All instances are stopped.
          2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.echarts.0 terminated due to SIGKILL
          2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.echarts.0 terminated with code null ()
          2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.text2command.0 terminated due to SIGKILL
          2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.text2command.0 terminated with code null ()
          2025-04-23 06:39:48.055  - warn: host.IO-Broker instance system.adapter.web.0 terminated due to SIGKILL
          2025-04-23 06:39:48.055  - info: host.IO-Broker instance system.adapter.web.0 terminated with code null ()
          2025-04-23 06:39:48.060  - warn: host.IO-Broker instance system.adapter.web.1 terminated due to SIGKILL
          2025-04-23 06:39:48.060  - info: host.IO-Broker instance system.adapter.web.1 terminated with code null ()
          2025-04-23 06:39:48.060  - info: host.IO-Broker All instances are stopped.
          2025-04-23 06:39:48.124  - info: host.IO-Broker terminated
            Thomas Braun Most Active @Kellerkind-86 last edited by Thomas Braun
            *** BASE SYSTEM *** Failed to query system properties: Connection timed out
            Das ist schon der erste Fehler. Da kann iob diag schon nicht die grundlegenden Systeminformationen abrufen.
            Hat mit dem ioBroker nix zu tun.
            Ist was mit dem Dateisystem.
            Zu LXCs kann ich aber weiter nix sagen, muss dir wer anders helfen.
            Codierknecht 1 Reply Last reply Reply Quote 1
            • Codierknecht
              Codierknecht Developer Most Active @Thomas Braun last edited by
              @thomas-braun sagte in Iobroker Oberfläche nicht mehr nutzbar:
              @Kellerkind-86
              Was hast Du da für ein Template verwendet? Das Standard-Debian12 von Proxmox?
                @codierknecht
                tigger@IO-Broker:~$ lsb_release -a
                No LSB modules are available.
                Distributor ID: Debian
                Description: Debian GNU/Linux 12 (bookworm)
                Release: 12
                Codename: bookworm
                tigger@IO-Broker:~$
                genau.
                echt mal komisch
                • Codierknecht
                  Codierknecht Developer Most Active @Kellerkind-86 last edited by
                  @kellerkind-86
                  Also ich nehme dieses Template:
                  Baue damit den LXC (ohne Desktop oder sonstigen Firlefanz) und installiere ioBroker mit dem Einzeiler.
                  K 2 Replies Last reply Reply Quote 0
                    Kellerkind-86 @Codierknecht last edited by
                    @codierknecht okay, ich werde es nochmal heute abend machen.. ja.. iobroker hab ich auch so installiert.
                      @codierknecht okay, hat leider etwas länger gedauert.. jetzt sollte es laufen.. oder ?
                      ```bash
                      Script v.2025-02-23
                      *** BASE SYSTEM ***
                       Static hostname: IO-Broker
                             Icon name: computer-container
                               Chassis: container ☐
                        Virtualization: lxc
                                Kernel: Linux 6.8.12-9-pve
                          Architecture: x86-64
                      OS is similar to:
                      Docker          : false
                      Kernel          : x86_64
                      Userland        : 64 bit
                       23:34:57 up 48 min,  2 users,  load average: 0.87, 0.53, 0.41
                      CPU threads: 4
                                     Local time: Tue 2025-05-06 23:34:57 CEST
                                 Universal time: Tue 2025-05-06 21:34:57 UTC
                                       RTC time: n/a
                                    NTP service: inactive
                                RTC in local TZ: no
                      tigger
                      HOME=/home/tigger
                      GROUPS=tigger sudo users iobroker
                      iobroker
                      HOME=/home/iobroker
                      GROUPS=iobroker tty dialout audio video plugdev
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.6G        2.8G        4.6G        139K        1.2G        5.8G
                      Swap:           2.1G          0B        2.1G
                      Total:           10G        2.8G        6.8G
                      Active iob-Instances:   42
                               8192 M total memory
                               2641 M used memory
                               2538 M active memory
                                994 M inactive memory
                               4398 M free memory
                                  0 M buffer memory
                               1151 M swap cache
                               2048 M total swap
                                  0 M used swap
                               2048 M free swap
                      top - 23:34:57 up 48 min,  2 users,  load average: 0.87, 0.53, 0.41
                      Tasks:  72 total,   1 running,  71 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us, 50.0 sy,  0.0 ni, 50.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   8192.0 total,   4396.9 free,   2643.6 used,   1151.6 buff/cache
                      MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.   5548.4 avail Mem
                      * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System
                      1 loaded units listed.
                      dmesg: read kernel buffer failed: Operation not permitted
                      *** FILESYSTEM ***
                      /dev/mapper/pve-vm--174--disk--0 ext4       16G  6.4G  8.5G  44% /
                      udev                             devtmpfs  7.8G     0  7.8G   0% /dev/tty
                      tmpfs                            tmpfs     3.2G  132K  3.2G   1% /run
                      tmpfs                            tmpfs     1.6G     0  1.6G   0% /run/user/1000
                      /      /dev/mapper/pve-vm--174--disk--0 ext4   rw,relatime,stripe=16
                      /var:
                      421M    /var/
                      250M    /var/cache
                      246M    /var/cache/apt
                      170M    /var/cache/apt/archives
                      147M    /var/lib
                      28M     /opt/iobroker/backups/
                      USB-Devices by-id:
                      HINT:
                      tcp
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      /usr/bin/npm            10.8.2
                      /usr/bin/npx            10.8.2
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      Hosts:
                      IO-Broker           IO-Broker (version: 7.0.6, hostname: IO-Broker     , alive, uptime: 2626)
                      admin:          7.6.3
                      javascript:     8.8.3
                      Adapter State
                      + system.adapter.admin.0                  : admin                 : IO-Broker                                -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                      + system.adapter.alexa2.0                 : alexa2                : IO-Broker                                -  enabled
                      + system.adapter.backitup.0               : backitup              : IO-Broker                                -  enabled
                      + system.adapter.bluelink.0               : bluelink              : IO-Broker                                -  enabled
                      + system.adapter.discovery.0              : discovery             : IO-Broker                                -  enabled
                      + system.adapter.echarts.0                : echarts               : IO-Broker                                -  enabled
                      + system.adapter.ecovacs-deebot.0         : ecovacs-deebot        : IO-Broker                                -  enabled
                      + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker                                -  enabled
                      + system.adapter.evcc.0                   : evcc                  : IO-Broker                                -  enabled, port: 7070
                      + system.adapter.fritzbox.0               : fritzbox              : IO-Broker                                -  enabled
                      + system.adapter.fullybrowser.0           : fullybrowser          : IO-Broker                                -  enabled
                      + system.adapter.harmony.0                : harmony               : IO-Broker                                -  enabled
                      + system.adapter.hm-rega.0                : hm-rega               : IO-Broker                                -  enabled
                      + system.adapter.hm-rpc.0                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
                      + system.adapter.hm-rpc.1                 : hm-rpc                : IO-Broker                                -  enabled, port: 0
                      + system.adapter.iot.0                    : iot                   : IO-Broker                                -  enabled
                      + system.adapter.javascript.0             : javascript            : IO-Broker                                -  enabled
                      + system.adapter.mqtt-client.0            : mqtt-client           : IO-Broker                                -  enabled, port: 1883
                      + system.adapter.mqtt.0                   : mqtt                  : IO-Broker                                -  enabled, port: 1883, bind: 0.0.0.0
                      + system.adapter.octoprint.0              : octoprint             : IO-Broker                                -  enabled
                      + system.adapter.onvif.0                  : onvif                 : IO-Broker                                -  enabled, port: 80, 7575, 8000, 8080, 8081, 8899
                      + system.adapter.pollenflug.0             : pollenflug            : IO-Broker                                -  enabled
                      + system.adapter.renacidc.0               : renacidc              : IO-Broker                                -  enabled
                      + system.adapter.scenes.0                 : scenes                : IO-Broker                                -  enabled
                      + system.adapter.shelly.0                 : shelly                : IO-Broker                                -  enabled, port: 1880, bind: 0.0.0.0
                      + system.adapter.shelly.1                 : shelly                : IO-Broker                                -  enabled, port: 1882, bind: 0.0.0.0
                      + system.adapter.shuttercontrol.0         : shuttercontrol        : IO-Broker                                -  enabled
                      + system.adapter.synology.0               : synology              : IO-Broker                                -  enabled, port: 5000
                      + system.adapter.tankerkoenig.0           : tankerkoenig          : IO-Broker                                -  enabled
                      + system.adapter.telegram.0               : telegram              : IO-Broker                                -  enabled, port: 8443, bind: 0.0.0.0
                      + system.adapter.text2command.0           : text2command          : IO-Broker                                -  enabled
                      + system.adapter.trashschedule.0          : trashschedule         : IO-Broker                                -  enabled
                      + system.adapter.unifi.0                  : unifi                 : IO-Broker                                -  enabled
                      + system.adapter.vis-2.0                  : vis-2                 : IO-Broker                                -  enabled
                      + system.adapter.vis-inventwo.0           : vis-inventwo          : IO-Broker                                -  enabled
                      + system.adapter.web.0                    : web                   : IO-Broker                                -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      + system.adapter.web.1                    : web                   : IO-Broker                                -  enabled, port: 20002, bind: 0.0.0.0, run as: admin
                      + system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : IO-Broker                                -  enabled
                      + system.adapter.wiffi-wz.0               : wiffi-wz              : IO-Broker                                -  enabled
                      + system.adapter.ws.0                     : ws                    : IO-Broker                                -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
                      + system.adapter.zigbee.0                 : zigbee                : IO-Broker                                -  enabled, port: tcp://192.168.178.165:6638
                      + instance is alive
                      Objects and States
                      Objects:        20154
                      States:         16138
                      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
                      Hit:5 https://repo.mosquitto.org/debian bookworm InRelease
                      Pending Updates: 0
                      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          45754451   1/init
                      tcp        0      0 192.168.178.74:42001    0.0.0.0:*               LISTEN      1001       45919336   4914/io.hm-rpc.0
                      tcp        0      0 192.168.178.74:42010    0.0.0.0:*               LISTEN      1001       45921323   4929/io.hm-rpc.1
                      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       45919548   4944/io.shelly.1
                      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      105        45916862   4883/mosquitto
                      tcp        0      0 192.168.178.74:8181     0.0.0.0:*               LISTEN      1001       45797552   3670/io.wiffi-wz.0
                      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       45777028   1847/iobroker.js-co
                      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       45777033   1847/iobroker.js-co
                      tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          45753745   294/master
                      tcp6       0      0 :::20002                :::*                    LISTEN      1001       45796519   3655/io.web.1
                      tcp6       0      0 :::111                  :::*                    LISTEN      0          45754453   1/init
                      tcp6       0      0 ::1:25                  :::*                    LISTEN      0          45753746   294/master
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          45752838   1/init
                      tcp6       0      0 :::1883                 :::*                    LISTEN      105        45916863   4883/mosquitto
                      tcp6       0      0 :::8084                 :::*                    LISTEN      1001       45795819   3685/io.ws.0
                      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       45794286   3640/io.web.0
                      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       45777930   1866/io.admin.0
                      tcp6       0      0 :::61991                :::*                    LISTEN      1001       45779797   2171/io.harmony.0
                      udp        0      0 0.0.0.0:57269           0.0.0.0:*                           1001       45786621   2607/io.shelly.0
                      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          45754452   1/init
                      udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       45779798   2171/io.harmony.0
                      udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       45783545   2607/io.shelly.0
                      udp6       0      0 :::111                  :::*                                0          45754454   1/init
                      2025-05-06 23:31:21.194  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                      2025-05-06 23:31:30.051  - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25
                      2025-05-06 23:32:51.194  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                      2025-05-06 23:33:15.985  - info: admin.0 (1866) <== Disconnect system.user.admin from ::ffff:192.168.178.25 javascript
                      2025-05-06 23:33:16.503  - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25
                      2025-05-06 23:34:21.195  - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud
                      danke
                      • Codierknecht
                        @kellerkind-86
                        Sieht doch prinzipiell ganz gut aus.
                        Das kannst Du uns hoffentlich sagen 😉
                        Was es mit dem
                        auf sich hat, kann vielleicht @Thomas-Braun sagen. Ich vermute ein Rechte-Problem.
                        Achtung: admin.0 und onvif.0 verwenden beide Port 8081. Das könnte zu Problemen führen.
                          Thomas Braun Most Active @Codierknecht last edited by
                          @codierknecht sagte in Iobroker Oberfläche nicht mehr nutzbar:
                          Der user darf nicht in den Kernelringpuffer des Hosts schauen.
                          Ist bei einem LXC ja auch Sinn und Zweck, das solche Kisten weggekapselt sind.
                          • Codierknecht
                            Und? Kann das Probleme bereiten oder kann das ignoriert werden?
                            Thomas Braun Meister Mopper 2 Replies Last reply Reply Quote 0
                              @codierknecht
                              Kann bei LXCs ignoriert werden, das ist halt 'works as intended'.
                              • Meister Mopper
                                Meister Mopper @Codierknecht last edited by
                                Als der ioBroker bei mir in einem LXC lief, kam natürlich auch diese Fehlermeldung. Ich habe sie ignoriert und gut war.
                                Jetzt läuft der ioBroker in einer VM und die Meldung kommt natürlich nicht mehr.
                                @Thomas-Braun
                                Vielleicht kann das Skript ja so angepasst werden, dass die Prüfung bei einem Container nicht durchgeführt wird.
                                Das ist aus meiner Sicht zumindest eine kosmetische Lösung.
                                  Thomas Braun Most Active @Meister Mopper last edited by
                                  @meister-mopper
                                  Ich halte nix von kosmetischen Eingriffen.
                                  Die Meldung kommt ja zu Recht. Die Bewertung obliegt dann demjenigen, der das Log interpretiert.
                                  • Codierknecht
                                    Codierknecht Developer Most Active @Thomas Braun last edited by Codierknecht
                                    Bei mir kommt die nicht. Dafür kann in meinem LXC das Release nicht sauber erkannt werden 😉
                                    Script v.2025-02-23
                                    *** BASE SYSTEM ***
                                     Static hostname: iobroker
                                      Virtualization: lxc
                                              Kernel: Linux 6.8.12-10-pve
                                    OS is similar to:
                                    model name      : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz
                                    Docker          : false
                                    Kernel          : x86_64
                                    Userland        : 64 bit
                                     10:17:35 up 7 days, 4 min,  2 users,  load average: 0.33, 0.36, 0.49
                                    CPU threads: 2
                                    Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
                                                   Local time: Wed 2025-05-07 10:17:35 CEST
                                               Universal time: Wed 2025-05-07 08:17:35 UTC
                                                     RTC time: n/a
                                              RTC in local TZ: no
                                    codierknecht
                                    HOME=/home/codierknecht
                                    GROUPS=codierknecht adm sudo users systemd-journal iobroker
                                    iobroker
                                    HOME=/home/iobroker
                                    Desktop:
                                    Terminal:
                                    *** MEMORY ***
                                    Mem:            8.6G        2.4G        5.7G        397K        482M        6.2G
                                    Swap:           1.1G        512M        561M
                                    Total:          9.7G        2.9G        6.3G
                                    Active iob-Instances:   36
                                             8192 M total memory
                                             2289 M used memory
                                             1102 M active memory
                                             1506 M inactive memory
                                             5443 M free memory
                                                0 M buffer memory
                                              459 M swap cache
                                             1024 M total swap
                                              488 M used swap
                                              535 M free swap
                                    top - 10:17:36 up 7 days, 4 min,  2 users,  load average: 0.33, 0.36, 0.49
                                    Tasks:  67 total,   1 running,  66 sleeping,   0 stopped,   0 zombie
                                    MiB Mem :   8192.0 total,   5441.1 free,   2291.2 used,    460.1 buff/cache
                                    MiB Swap:   1024.0 total,    535.6 free,    488.4 used.   5900.8 avail Mem
                                    0 loaded units listed.
                                    *** FILESYSTEM ***
                                    /dev/mapper/pve-vm--104--disk--0 ext4    20G  9.6G  9.0G  52% /
                                    tmpfs                            tmpfs  3.2G  232K  3.2G   1% /run
                                    [Wed Apr 30 10:12:42 2025] EXT4-fs (dm-1): mounted filesystem 35e403cc-3cb6-4691-937c-5b0dccb22862 ro with ordered data mode. Quota mode: none.
                                    [Wed Apr 30 10:12:42 2025] EXT4-fs (dm-1): re-mounted 35e403cc-3cb6-4691-937c-5b0dccb22862 r/w. Quota mode: none.
                                    [Wed Apr 30 10:12:51 2025] EXT4-fs (dm-6): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 r/w with ordered data mode. Quota mode: none.
                                    [Wed Apr 30 10:12:53 2025] EXT4-fs (dm-7): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 r/w with ordered data mode. Quota mode: none.
                                    [Wed Apr 30 10:12:55 2025] EXT4-fs (dm-8): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 r/w with ordered data mode. Quota mode: none.
                                    [Wed Apr 30 10:12:58 2025] EXT4-fs (dm-10): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 r/w with ordered data mode. Quota mode: none.
                                    [Thu May  1 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Thu May  1 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Thu May  1 03:01:33 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Thu May  1 03:01:33 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Thu May  1 03:01:33 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Thu May  1 03:03:11 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Thu May  1 03:03:12 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Thu May  1 03:03:12 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Thu May  1 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Thu May  1 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Thu May  1 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Thu May  1 03:07:08 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    [Fri May  2 03:00:03 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Fri May  2 03:00:03 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Fri May  2 03:01:35 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Fri May  2 03:01:36 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Fri May  2 03:01:36 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Fri May  2 03:03:17 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Fri May  2 03:03:17 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Fri May  2 03:03:17 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Fri May  2 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Fri May  2 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Fri May  2 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Fri May  2 03:07:25 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    [Sat May  3 03:00:05 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sat May  3 03:00:05 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Sat May  3 03:01:39 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Sat May  3 03:01:40 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sat May  3 03:01:40 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Sat May  3 03:03:22 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Sat May  3 03:03:23 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sat May  3 03:03:23 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Sat May  3 03:03:49 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Sat May  3 03:03:50 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sat May  3 03:03:50 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Sat May  3 03:07:19 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    [Sun May  4 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sun May  4 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Sun May  4 03:01:36 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Sun May  4 03:01:37 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sun May  4 03:01:37 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Sun May  4 03:03:15 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Sun May  4 03:03:15 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sun May  4 03:03:15 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Sun May  4 03:03:38 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Sun May  4 03:03:39 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Sun May  4 03:03:39 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Sun May  4 03:07:14 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    [Mon May  5 03:00:03 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Mon May  5 03:00:03 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Mon May  5 03:01:26 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Mon May  5 03:01:26 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Mon May  5 03:01:26 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Mon May  5 03:02:56 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Mon May  5 03:02:57 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Mon May  5 03:02:57 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Mon May  5 03:03:28 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Mon May  5 03:03:29 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Mon May  5 03:03:29 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Mon May  5 03:07:00 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    [Tue May  6 03:00:02 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Tue May  6 03:00:02 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Tue May  6 03:01:38 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Tue May  6 03:01:39 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Tue May  6 03:01:39 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Tue May  6 03:03:14 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Tue May  6 03:03:15 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Tue May  6 03:03:15 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Tue May  6 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Tue May  6 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Tue May  6 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Tue May  6 03:07:24 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    [Wed May  7 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Wed May  7 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none.
                                    [Wed May  7 03:01:42 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3.
                                    [Wed May  7 03:01:43 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Wed May  7 03:01:43 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none.
                                    [Wed May  7 03:03:23 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853.
                                    [Wed May  7 03:03:24 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Wed May  7 03:03:24 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none.
                                    [Wed May  7 03:03:54 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850.
                                    [Wed May  7 03:03:55 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup
                                    [Wed May  7 03:03:55 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none.
                                    [Wed May  7 03:07:32 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15.
                                    /      /dev/mapper/pve-vm--104--disk--0 ext4   rw,relatime,stripe=16
                                    /var:
                                    3.2G    /var/
                                    2.1G    /var/log/journal/c56b513cffd54f1394845d28e4aeddf1
                                    2.1G    /var/log
                                    954M    /var/cache
                                    Archived and active journals take up 2.0G in the file system.
                                    4.0K    /opt/iobroker/backups/
                                    991M    /opt/iobroker/iobroker-data/
                                    857M    /opt/iobroker/iobroker-data/files
                                    29M     /opt/iobroker/iobroker-data/objects.jsonl
                                    24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                    24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                    17M     /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.64d9ecc7.js.map
                                    9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                                    USB-Devices by-id:
                                    HINT:
                                    tcp
                                    zigbee.X
                                    Extended Pan ID:
                                    *** MASKED ***
                                    Pan ID:
                                    *** MASKED ***
                                    Channel:
                                    *** MASKED ***
                                    Network Key:
                                    *** MASKED ***
                                    /usr/bin/npm            10.8.2
                                    /usr/bin/npx            10.8.2
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    Hosts:
                                    iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 605072)
                                    admin:          7.6.3
                                    javascript:     8.8.3
                                    +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0)
                                    +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#860bde5a0d4828af5e85cc4569c56d740523d767)
                                    Adapter State
                                    + system.adapter.adguard.0                : adguard               : iobroker                                 -  enabled
                                    + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                                    + system.adapter.boschindego.0            : boschindego           : iobroker                                 -  enabled
                                    + system.adapter.denon.0                  : denon                 : iobroker                                 -  enabled
                                    + system.adapter.device-watcher.0         : device-watcher        : iobroker                                 -  enabled
                                    + system.adapter.email.0                  : email                 : iobroker                                 -  enabled
                                    + system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
                                    + system.adapter.fritzdect.0              : fritzdect             : iobroker                                 -  enabled
                                    + system.adapter.hm-rega.0                : hm-rega               : iobroker                                 -  enabled
                                    + system.adapter.hm-rpc.0                 : hm-rpc                : iobroker                                 -  enabled, port: 0
                                      system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.ical.2                   : ical                  : iobroker                                 -  enabled
                                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
                                    + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                                    + system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
                                    + system.adapter.linux-control.0          : linux-control         : iobroker                                 -  enabled
                                    + system.adapter.lupusec.0                : lupusec               : iobroker                                 -  enabled
                                    + system.adapter.modbus.0                 : modbus                : iobroker                                 -  enabled
                                    + system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1886, bind: 0.0.0.0
                                    + system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
                                      system.adapter.octoprint.0              : octoprint             : iobroker                                 - disabled
                                    + system.adapter.opendtu.0                : opendtu               : iobroker                                 -  enabled
                                      system.adapter.openweathermap.0         : openweathermap        : iobroker                                 -  enabled
                                    + system.adapter.paperless-ngx.0          : paperless-ngx         : iobroker                                 -  enabled, port: 8000
                                    + system.adapter.parser.0                 : parser                : iobroker                                 -  enabled
                                    + system.adapter.proxmox.0                : proxmox               : iobroker                                 -  enabled, port: 8006
                                    + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                                    + system.adapter.renault.0                : renault               : iobroker                                 -  enabled
                                    + system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
                                      system.adapter.scheduler.0              : scheduler             : iobroker                                 - disabled
                                    + system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8083, bind: 0.0.0.0, run as: admin
                                    + system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
                                    + system.adapter.sql.0                    : sql                   : iobroker                                 -  enabled, port: 3306
                                    + system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
                                    + system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
                                    + system.adapter.unifi.0                  : unifi                 : iobroker                                 -  enabled
                                    + system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
                                      system.adapter.vis-bars.0               : vis-bars              : iobroker                                 - disabled
                                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : iobroker                                 - disabled
                                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                                      system.adapter.vis-map.0                : vis-map               : iobroker                                 - disabled
                                      system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
                                      system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 -  enabled
                                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                                      system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                                    + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                    + system.adapter.yahka.0                  : yahka                 : iobroker                                 -  enabled
                                    + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled, port: tcp://192.168.179.141:6638
                                    + instance is alive
                                    │ 0       │ 'stable' │ 'http://download.iobroker.net/sources-dist.json'        │ true         │
                                    Upgrade policy: minor
                                    Adapter    "adguard"      : 1.0.1    , installed 1.0.1
                                    Adapter    "boschindego"  : 1.3.9    , installed 1.3.9
                                    Adapter    "denon"        : 1.15.12  , installed 1.15.12
                                    Adapter    "device-watcher": 2.12.1  , installed 2.12.1
                                    Adapter    "email"        : 2.0.3    , installed 2.0.3
                                    Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
                                    Adapter    "fritzdect"    : 2.6.1    , installed 2.6.1
                                    Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
                                    Adapter    "linux-control": 1.1.5    , installed 1.1.6
                                    Adapter    "lupusec"      : 2.0.7    , installed 2.0.7
                                    Adapter    "modbus"       : 6.3.2    , installed 6.3.2
                                    Adapter    "nina"         : 0.0.25   , installed 0.0.25
                                    Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
                                    Adapter    "openweathermap": 1.1.2   , installed 1.1.2
                                    Adapter    "paperless-ngx": 0.4.4    , installed 0.4.4
                                    Adapter    "parser"       : 2.2.4    , installed 2.2.4
                                    Adapter    "proxmox"      : 2.4.0    , installed 2.4.0
                                    Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                                    Adapter    "scheduler"    : 1.4.1    , installed 1.4.1
                                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                                    Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                                    Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
                                    Adapter    "sql"          : 3.0.1    , installed 3.0.1
                                    Adapter    "upnp"         : 1.1.0    , installed 1.1.0
                                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                                    Adapter    "vis-map"      : 1.1.2    , installed 1.1.2
                                    Adapter    "ws"           : 2.6.2    , installed 2.6.2
                                    Adapter    "yahka"        : 1.0.3    , installed 1.0.3
                                    Objects and States
                                    Objects:        10034
                                    States:         7944
                                    Hit:2 http://security.debian.org bookworm-security InRelease
                                    Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease
                                    Pending Updates: 0
                                    tcp        0      0 127.0.0.1:39603         0.0.0.0:*               LISTEN      1001       52141433   1353/io.yahka.0
                                    tcp        0      0 0.0.0.0:38509           0.0.0.0:*               LISTEN      1001       36404      1353/io.yahka.0
                                    tcp        0      0 127.0.0.1:37835         0.0.0.0:*               LISTEN      1001       52138637   1353/io.yahka.0
                                    tcp        0      0 127.0.0.1:38711         0.0.0.0:*               LISTEN      1001       52138642   1353/io.yahka.0
                                    tcp        0      0 0.0.0.0:8087            0.0.0.0:*               LISTEN      1001       34556      1152/io.lupusec.0
                                    tcp        0      0 0.0.0.0:40401           0.0.0.0:*               LISTEN      1001       36422      1353/io.yahka.0
                                    tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       20512      145/iobroker.js-con
                                    tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       20517      145/iobroker.js-con
                                    tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          17811      1/init
                                    tcp        0      0 0.0.0.0:33273           0.0.0.0:*               LISTEN      1001       36414      1353/io.yahka.0
                                    tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       21281      538/io.hm-rpc.0
                                    tcp        0      0 0.0.0.0:10050           0.0.0.0:*               LISTEN      105        27697967   578950/zabbix_agent
                                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       26164      649/io.mqtt.0
                                    tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       29931      703/io.sonoff.0
                                    tcp        0      0 127.0.0.1:33163         0.0.0.0:*               LISTEN      1001       52141438   1353/io.yahka.0
                                    tcp        0      0 127.0.0.1:25            0.0.0.0:*               LISTEN      0          18295      315/master
                                    tcp        0      0 0.0.0.0:43447           0.0.0.0:*               LISTEN      1001       36418      1353/io.yahka.0
                                    tcp6       0      0 ::1:25                  :::*                    LISTEN      0          18296      315/master
                                    tcp6       0      0 :::8083                 :::*                    LISTEN      1001       37981      1264/io.simple-api.
                                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       38176      1336/io.web.0
                                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       20594      326/io.admin.0
                                    tcp6       0      0 :::8000                 :::*                    LISTEN      1001       38540      1302/io.upnp.0
                                    tcp6       0      0 :::41527                :::*                    LISTEN      1001       36407      1353/io.yahka.0
                                    tcp6       0      0 :::22                   :::*                    LISTEN      0          18822      1/init
                                    tcp6       0      0 :::111                  :::*                    LISTEN      0          17813      1/init
                                    tcp6       0      0 :::10050                :::*                    LISTEN      105        27697968   578950/zabbix_agent
                                    tcp6       0      0 :::35443                :::*                    LISTEN      1001       36409      1353/io.yahka.0
                                    tcp6       0      0 :::34843                :::*                    LISTEN      1001       36405      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1001       38251      1302/io.upnp.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36419      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36415      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36411      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36410      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36408      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36406      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       36401      1353/io.yahka.0
                                    udp        0      0 0.0.0.0:55640           0.0.0.0:*                           1001       36205      1302/io.upnp.0
                                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          18746      87/dhclient
                                    udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          17812      1/init
                                    udp6       0      0 :::111                  :::*                                0          17814      1/init
                                    2025-05-07 09:23:53.981  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
                                    2025-05-07 09:23:56.819  - info: admin.0 (326) Repository received successfully.
                                    2025-05-07 09:23:57.175  - info: host.iobroker Check for available automatic adapter upgrades
                                    2025-05-07 09:32:00.012  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 1128208
                                    2025-05-07 09:32:06.894  - info: host.iobroker instance system.adapter.ical.0 having pid 1128208 terminated with code 0 (NO_ERROR)
                                    2025-05-07 09:34:00.009  - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 1128302
                                    2025-05-07 09:34:07.823  - info: host.iobroker instance system.adapter.ical.1 having pid 1128302 terminated with code 0 (NO_ERROR)
                                    2025-05-07 09:36:00.010  - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 1128749
                                    2025-05-07 09:36:07.257  - info: host.iobroker instance system.adapter.ical.2 having pid 1128749 terminated with code 0 (NO_ERROR)
                                    2025-05-07 09:45:44.384  - info: javascript.0 (392) script.js.common.Informationen.Renault: Austral-Standort: 387, Friedrich-Ebert-Straße, Stadtwald, Bockum, Krefeld, North Rhine-Westphalia, 47800, Germany
                                    2025-05-07 09:47:37.009  - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1129921
                                    2025-05-07 09:47:53.163  - info: host.iobroker instance system.adapter.openweathermap.0 having pid 1129921 terminated with code 0 (NO_ERROR)
                                    2025-05-07 09:52:00.024  - info: javascript.0 (392) script.js.common.Informationen.Speedtest: Speedtest mit Server 54504 gestartet! Der Test dauert zwischen 10 - 20 Sekunden!
                                    2025-05-07 09:52:17.539  - info: javascript.0 (392) script.js.common.Informationen.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 49.1 MB/s | Upload: 24.5 MB/s | Ping: 7.983ms
                                    2025-05-07 10:02:00.013  - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 1131604
                                    2025-05-07 10:02:06.805  - info: host.iobroker instance system.adapter.ical.0 having pid 1131604 terminated with code 0 (NO_ERROR)
                                    2025-05-07 10:04:00.015  - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 1131698
                                    2025-05-07 10:04:07.751  - info: host.iobroker instance system.adapter.ical.1 having pid 1131698 terminated with code 0 (NO_ERROR)
                                    2025-05-07 10:06:00.012  - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 1132140
                                    2025-05-07 10:06:07.131  - info: host.iobroker instance system.adapter.ical.2 having pid 1132140 terminated with code 0 (NO_ERROR)
                                    2025-05-07 10:13:00.948  - info: javascript.0 (392) script.js.common.Informationen.Aktienkurs: Aktienkurs ENR.DE: 72.82 €
                                    2025-05-07 10:13:00.948  - info: javascript.0 (392) script.js.common.Informationen.Aktienkurs: Aktienkurs SIE.DE: 209.55 €
                                    2025-05-07 10:13:11.339  - info: admin.0 (326) Adapter rating updated
                                    2025-05-07 10:17:37.015  - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1133590
                                    2025-05-07 10:17:43.169  - info: host.iobroker instance system.adapter.openweathermap.0 having pid 1133590 terminated with code 0 (NO_ERROR)
                                      Dann dürfte da ein Paket fehlen. Ich meine das sollte auch bei LXCs funktionieren. Jag den
                                      iob fix
                                      mal drüber.
                                      • Codierknecht
                                        Hilft nicht wirklich
                                        *** BASE SYSTEM ***
                                          Virtualization: lxc
                                        OS is similar to:
                                        Docker          : false
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                         10:28:21 up 7 days, 15 min,  2 users,  load average: 1.16, 0.89, 0.68
                                        CPU threads: 2
                                        ist aber auch nur Kosmetik. Oben hat er ja erkannt, dass es sich um "bookworm" handelt. Und ich weiß es ja auch.
                                        Aber ich will hier nicht den Thread des TE kapern. also zurück zum Thema.
                                        @Kellerkind-86
                                        Läuft das jetzt zu Deiner Zufriedenheit?
                                          jap, das hatte ich gestern gegooglet.. kann ignoriert werden.. danke für die Hilfe hier immer wieder thumps up dafür. danke wiedermals..
                                          992
