Iobroker Oberfläche nicht mehr nutzbar
Also ich nehme dieses Template:
Baue damit den LXC (ohne Desktop oder sonstigen Firlefanz) und installiere ioBroker mit dem Einzeiler. -
@codierknecht okay, ich werde es nochmal heute abend machen.. ja.. iobroker hab ich auch so installiert.
@codierknecht okay, hat leider etwas länger gedauert.. jetzt sollte es laufen.. oder ?
========== Start marking the full check here =========== ```bash Script v.2025-02-23 *** BASE SYSTEM *** Static hostname: IO-Broker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.8.12-9-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i5-7500T CPU @ 2.70GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 23:34:57 up 48 min, 2 users, load average: 0.87, 0.53, 0.41 CPU threads: 4 *** LIFE CYCLE STATUS *** Operating System is the current Debian stable version codenamed 'bookworm'! *** TIME AND TIMEZONES *** Local time: Tue 2025-05-06 23:34:57 CEST Universal time: Tue 2025-05-06 21:34:57 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': tigger HOME=/home/tigger GROUPS=tigger sudo users iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: tty *** MEMORY *** total used free shared buff/cache available Mem: 8.6G 2.8G 4.6G 139K 1.2G 5.8G Swap: 2.1G 0B 2.1G Total: 10G 2.8G 6.8G Active iob-Instances: 42 8192 M total memory 2641 M used memory 2538 M active memory 994 M inactive memory 4398 M free memory 0 M buffer memory 1151 M swap cache 2048 M total swap 0 M used swap 2048 M free swap *** top - Table Of Processes *** top - 23:34:57 up 48 min, 2 users, load average: 0.87, 0.53, 0.41 Tasks: 72 total, 1 running, 71 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 50.0 sy, 0.0 ni, 50.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8192.0 total, 4396.9 free, 2643.6 used, 1151.6 buff/cache MiB Swap: 2048.0 total, 2048.0 free, 0.0 used. 5548.4 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION * run-rpc_pipefs.mount loaded failed failed RPC Pipe File System LOAD = Reflects whether the unit definition was properly loaded. ACTIVE = The high-level unit activation state, i.e. generalization of SUB. SUB = The low-level unit activation state, values depend on unit type. 1 loaded units listed. *** DMESG CRITICAL ERRORS *** dmesg: read kernel buffer failed: Operation not permitted No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--174--disk--0 ext4 16G 6.4G 8.5G 44% / none tmpfs 492K 4.0K 488K 1% /dev udev devtmpfs 7.8G 0 7.8G 0% /dev/tty tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs tmpfs 3.2G 132K 3.2G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs tmpfs 1.6G 0 1.6G 0% /run/user/1000 Messages concerning ext4 filesystem in dmesg: dmesg: read kernel buffer failed: Operation not permitted Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--174--disk--0 ext4 rw,relatime,stripe=16 Files in neuralgic directories: /var: 421M /var/ 250M /var/cache 246M /var/cache/apt 170M /var/cache/apt/archives 147M /var/lib Hint: You are currently not seeing messages from other users and the system. Users in groups 'adm', 'systemd-journal' can see all messages. Pass -q to turn off this notice. Archived and active journals take up 8.0M in the file system. /opt/iobroker/backups: 28M /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 1.4G /opt/iobroker/iobroker-data/files 1.4G /opt/iobroker/iobroker-data/ 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 38M /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map 35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map 27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map 26M /opt/iobroker/iobroker-data/files/echarts/static/js/main.41cee985.js.map 26M /opt/iobroker/iobroker-data/files/echarts.admin/chart/static/js/main.41cee985.js.map USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: tcp Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.1 /usr/bin/node v20.19.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.31.0 nodejs: Installed: 20.19.1-1nodesource1 Candidate: 20.19.1-1nodesource1 Version table: *** 20.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 20.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org bookworm-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: IO-Broker IO-Broker (version: 7.0.6, hostname: IO-Broker , alive, uptime: 2626) Core adapters versions js-controller: 7.0.6 admin: 7.6.3 javascript: 8.8.3 nodejs modules from github: 2 +-- iobroker.evcc@0.1.1 (git+ssh://git@github.com/Newan/ioBroker.evcc.git#47c01e1026b8011a8407e3cb5f039a22d92ef9b2) | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0) Adapter State + system.adapter.admin.0 : admin : IO-Broker - enabled, port: 8081, bind: 0.0.0.0, run as: admin system.adapter.alexa-shoppinglist.0 : alexa-shoppinglist : IO-Broker - disabled + system.adapter.alexa2.0 : alexa2 : IO-Broker - enabled + system.adapter.backitup.0 : backitup : IO-Broker - enabled system.adapter.birthdays.0 : birthdays : IO-Broker - enabled + system.adapter.bluelink.0 : bluelink : IO-Broker - enabled system.adapter.devices.0 : devices : IO-Broker - disabled + system.adapter.discovery.0 : discovery : IO-Broker - enabled system.adapter.dwd.0 : dwd : IO-Broker - enabled + system.adapter.echarts.0 : echarts : IO-Broker - enabled + system.adapter.ecovacs-deebot.0 : ecovacs-deebot : IO-Broker - enabled + system.adapter.energiefluss-erweitert.0 : energiefluss-erweitert: IO-Broker - enabled + system.adapter.evcc.0 : evcc : IO-Broker - enabled, port: 7070 system.adapter.feiertage.0 : feiertage : IO-Broker - enabled + system.adapter.fritzbox.0 : fritzbox : IO-Broker - enabled + system.adapter.fullybrowser.0 : fullybrowser : IO-Broker - enabled + system.adapter.harmony.0 : harmony : IO-Broker - enabled + system.adapter.hm-rega.0 : hm-rega : IO-Broker - enabled + system.adapter.hm-rpc.0 : hm-rpc : IO-Broker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : IO-Broker - enabled, port: 0 system.adapter.homekit-controller.0 : homekit-controller : IO-Broker - disabled system.adapter.ical.0 : ical : IO-Broker - enabled system.adapter.ical.1 : ical : IO-Broker - enabled system.adapter.influxdb.0 : influxdb : IO-Broker - disabled, port: 8086 + system.adapter.iot.0 : iot : IO-Broker - enabled + system.adapter.javascript.0 : javascript : IO-Broker - enabled system.adapter.luftdaten.0 : luftdaten : IO-Broker - enabled + system.adapter.mqtt-client.0 : mqtt-client : IO-Broker - enabled, port: 1883 + system.adapter.mqtt.0 : mqtt : IO-Broker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.octoprint.0 : octoprint : IO-Broker - enabled + system.adapter.onvif.0 : onvif : IO-Broker - enabled, port: 80, 7575, 8000, 8080, 8081, 8899 + system.adapter.pollenflug.0 : pollenflug : IO-Broker - enabled + system.adapter.renacidc.0 : renacidc : IO-Broker - enabled + system.adapter.scenes.0 : scenes : IO-Broker - enabled system.adapter.schoolfree.0 : schoolfree : IO-Broker - enabled + system.adapter.shelly.0 : shelly : IO-Broker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : IO-Broker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.shuttercontrol.0 : shuttercontrol : IO-Broker - enabled + system.adapter.synology.0 : synology : IO-Broker - enabled, port: 5000 + system.adapter.tankerkoenig.0 : tankerkoenig : IO-Broker - enabled + system.adapter.telegram.0 : telegram : IO-Broker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.text2command.0 : text2command : IO-Broker - enabled system.adapter.tr-064.0 : tr-064 : IO-Broker - disabled + system.adapter.trashschedule.0 : trashschedule : IO-Broker - enabled + system.adapter.unifi.0 : unifi : IO-Broker - enabled system.adapter.vis-2-widgets-energy.0 : vis-2-widgets-energy : IO-Broker - disabled system.adapter.vis-2-widgets-gauges.0 : vis-2-widgets-gauges : IO-Broker - disabled system.adapter.vis-2-widgets-material.0 : vis-2-widgets-material: IO-Broker - disabled + system.adapter.vis-2.0 : vis-2 : IO-Broker - enabled system.adapter.vis-google-fonts.0 : vis-google-fonts : IO-Broker - enabled system.adapter.vis-icontwo.0 : vis-icontwo : IO-Broker - disabled + system.adapter.vis-inventwo.0 : vis-inventwo : IO-Broker - enabled system.adapter.vis-metro.0 : vis-metro : IO-Broker - disabled system.adapter.vis-timeandweather.0 : vis-timeandweather : IO-Broker - disabled system.adapter.vis.0 : vis : IO-Broker - enabled system.adapter.weatherunderground.0 : weatherunderground : IO-Broker - enabled + system.adapter.web.0 : web : IO-Broker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.web.1 : web : IO-Broker - enabled, port: 20002, bind: 0.0.0.0, run as: admin + system.adapter.whatsapp-cmb.0 : whatsapp-cmb : IO-Broker - enabled + system.adapter.wiffi-wz.0 : wiffi-wz : IO-Broker - enabled + system.adapter.ws.0 : ws : IO-Broker - enabled, port: 8084, bind: 0.0.0.0, run as: admin system.adapter.yr.0 : yr : IO-Broker - enabled + system.adapter.zigbee.0 : zigbee : IO-Broker - enabled, port: tcp://192.168.178.165:6638 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : IO-Broker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.evcc.0 : evcc : IO-Broker - enabled, port: 7070 + system.adapter.hm-rpc.0 : hm-rpc : IO-Broker - enabled, port: 0 + system.adapter.hm-rpc.1 : hm-rpc : IO-Broker - enabled, port: 0 + system.adapter.mqtt-client.0 : mqtt-client : IO-Broker - enabled, port: 1883 + system.adapter.mqtt.0 : mqtt : IO-Broker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.onvif.0 : onvif : IO-Broker - enabled, port: 80, 7575, 8000, 8080, 8081, 8899 + system.adapter.shelly.0 : shelly : IO-Broker - enabled, port: 1880, bind: 0.0.0.0 + system.adapter.shelly.1 : shelly : IO-Broker - enabled, port: 1882, bind: 0.0.0.0 + system.adapter.synology.0 : synology : IO-Broker - enabled, port: 5000 + system.adapter.telegram.0 : telegram : IO-Broker - enabled, port: 8443, bind: 0.0.0.0 + system.adapter.web.0 : web : IO-Broker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.web.1 : web : IO-Broker - enabled, port: 20002, bind: 0.0.0.0, run as: admin + system.adapter.ws.0 : ws : IO-Broker - enabled, port: 8084, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : IO-Broker - enabled, port: tcp://192.168.178.165:6638 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: none Installed ioBroker-Adapters Used repository: stable Adapter "admin" : 7.6.3 , installed 7.6.3 Adapter "alexa-shoppinglist": 1.0.3, installed 1.0.3 Adapter "alexa2" : 3.26.5 , installed 3.26.5 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "birthdays" : 4.0.0 , installed 4.0.0 Adapter "bluelink" : 2.3.6 , installed 2.3.6 Adapter "devices" : 1.1.5 , installed 1.1.5 Adapter "discovery" : 5.0.0 , installed 5.0.0 Adapter "dwd" : 2.8.5 , installed 2.8.5 Adapter "echarts" : 1.9.2 , installed 1.9.2 Adapter "ecovacs-deebot": 1.4.15 , installed 1.4.15 Adapter "energiefluss-erweitert": 0.6.2, installed 0.6.2 Adapter "evcc" : 0.1.1 , installed 0.1.1 Adapter "feiertage" : 1.2.1 , installed 1.2.1 Adapter "fritzbox" : 0.6.0 , installed 0.6.0 Adapter "fullybrowser" : 3.1.1 , installed 3.1.1 Adapter "harmony" : 1.5.0 , installed 1.5.0 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "homekit-controller": 0.5.11, installed 0.5.11 Adapter "ical" : 1.16.1 , installed 1.16.1 Adapter "influxdb" : 4.0.2 , installed 4.0.2 Adapter "iot" : 3.3.0 , installed 3.3.0 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "luftdaten" : 4.0.0 , installed 4.0.0 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "mqtt-client" : 3.0.0 , installed 3.0.0 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "onvif" : 1.1.4 , installed 1.1.4 Adapter "pollenflug" : 2.0.0 , installed 2.0.0 Adapter "renacidc" : 0.1.4 , installed 0.1.4 Adapter "scenes" : 3.2.3 , installed 3.2.3 Adapter "schoolfree" : 1.1.9 , installed 1.1.9 Adapter "shelly" : 9.2.0 , installed 9.2.0 Adapter "shuttercontrol": 2.0.1 , installed 2.0.1 Adapter "socketio" : 6.7.1 , installed 7.0.8 Adapter "synology" : 3.1.0 , installed 3.1.0 Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0 Adapter "telegram" : 4.1.0 , installed 4.1.0 Adapter "text2command" : 3.0.3 , installed 3.0.3 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "unifi" : 0.7.0 , installed 0.7.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-2" : 2.9.64 , installed 2.9.64 Adapter "vis-2-widgets-energy": 1.0.2, installed 1.0.2 Adapter "vis-2-widgets-gauges": 1.1.0, installed 1.1.0 Adapter "vis-2-widgets-material": 1.4.10, installed 1.4.10 Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4 Adapter "vis-icontwo" : 1.11.0 , installed 1.11.0 Adapter "vis-inventwo" : 3.3.4 , installed 3.3.4 Adapter "vis-metro" : 1.2.0 , installed 1.2.0 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "weatherunderground": 3.7.0, installed 3.7.0 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "whatsapp-cmb" : 0.3.0 , installed 0.3.0 Adapter "wiffi-wz" : 2.2.1 , installed 2.2.1 Adapter "ws" : 2.6.2 , installed 3.0.19 Adapter "yr" : 5.3.0 , installed 5.3.0 Adapter "zigbee" : 2.0.5 , installed 2.0.5 Objects and States Please stand by - This may take a while Objects: 20154 States: 16138 *** OS-Repositories and Updates *** Hit:1 http://security.debian.org bookworm-security InRelease Hit:2 http://deb.debian.org/debian bookworm InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:5 https://repo.mosquitto.org/debian bookworm InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 45754451 1/init tcp 0 0 192.168.178.74:42001 0.0.0.0:* LISTEN 1001 45919336 4914/io.hm-rpc.0 tcp 0 0 192.168.178.74:42010 0.0.0.0:* LISTEN 1001 45921323 4929/io.hm-rpc.1 tcp 0 0 0.0.0.0:1882 0.0.0.0:* LISTEN 1001 45919548 4944/io.shelly.1 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 105 45916862 4883/mosquitto tcp 0 0 192.168.178.74:8181 0.0.0.0:* LISTEN 1001 45797552 3670/io.wiffi-wz.0 tcp 0 0 127.0.0.1:9001 0.0.0.0:* LISTEN 1001 45777028 1847/iobroker.js-co tcp 0 0 127.0.0.1:9000 0.0.0.0:* LISTEN 1001 45777033 1847/iobroker.js-co tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 45753745 294/master tcp6 0 0 :::20002 :::* LISTEN 1001 45796519 3655/io.web.1 tcp6 0 0 :::111 :::* LISTEN 0 45754453 1/init tcp6 0 0 ::1:25 :::* LISTEN 0 45753746 294/master tcp6 0 0 :::22 :::* LISTEN 0 45752838 1/init tcp6 0 0 :::1883 :::* LISTEN 105 45916863 4883/mosquitto tcp6 0 0 :::8084 :::* LISTEN 1001 45795819 3685/io.ws.0 tcp6 0 0 :::8082 :::* LISTEN 1001 45794286 3640/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 45777930 1866/io.admin.0 tcp6 0 0 :::61991 :::* LISTEN 1001 45779797 2171/io.harmony.0 udp 0 0 0.0.0.0:57269 0.0.0.0:* 1001 45786621 2607/io.shelly.0 udp 0 0 0.0.0.0:111 0.0.0.0:* 0 45754452 1/init udp 0 0 0.0.0.0:61991 0.0.0.0:* 1001 45779798 2171/io.harmony.0 udp 0 0 0.0.0.0:5683 0.0.0.0:* 1001 45783545 2607/io.shelly.0 udp6 0 0 :::111 :::* 0 45754454 1/init *** Log File - Last 25 Lines *** 2025-05-06 23:31:21.194 - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud 2025-05-06 23:31:30.051 - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25 2025-05-06 23:32:51.194 - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud 2025-05-06 23:33:15.985 - info: admin.0 (1866) <== Disconnect system.user.admin from ::ffff:192.168.178.25 javascript 2025-05-06 23:33:16.503 - info: admin.0 (1866) ==> Connected system.user.admin from ::ffff:192.168.178.25 2025-05-06 23:34:21.195 - info: renacidc.0 (2503) Adapter tries to retrieve data from the cloud ============ Mark until here for C&P =============
danke
@kellerkind-86
Sieht doch prinzipiell ganz gut aus.jetzt sollte es laufen.. oder ?
Das kannst Du uns hoffentlich sagen
Was es mit dem
auf sich hat, kann vielleicht @Thomas-Braun sagen. Ich vermute ein Rechte-Problem.
Achtung:
admin.0
undonvif.0
verwenden beide Port 8081. Das könnte zu Problemen führen. -
@codierknecht sagte in Iobroker Oberfläche nicht mehr nutzbar:
Der user darf nicht in den Kernelringpuffer des Hosts schauen.
Ist bei einem LXC ja auch Sinn und Zweck, das solche Kisten weggekapselt sind. -
Und? Kann das Probleme bereiten oder kann das ignoriert werden? -
Kann bei LXCs ignoriert werden, das ist halt 'works as intended'.
Als der ioBroker bei mir in einem LXC lief, kam natürlich auch diese Fehlermeldung. Ich habe sie ignoriert und gut war.
Jetzt läuft der ioBroker in einer VM und die Meldung kommt natürlich nicht mehr.
@Thomas-Braun
Vielleicht kann das Skript ja so angepasst werden, dass die Prüfung bei einem Container nicht durchgeführt wird.
Das ist aus meiner Sicht zumindest eine kosmetische Lösung. -
Ich halte nix von kosmetischen Eingriffen.
Die Meldung kommt ja zu Recht. Die Bewertung obliegt dann demjenigen, der das Log interpretiert. -
Bei mir kommt die nicht. Dafür kann in meinem LXC das Release nicht sauber erkannt werdenScript v.2025-02-23 *** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.8.12-10-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 10:17:35 up 7 days, 4 min, 2 users, load average: 0.33, 0.36, 0.49 CPU threads: 2 *** LIFE CYCLE STATUS *** Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained. *** TIME AND TIMEZONES *** Local time: Wed 2025-05-07 10:17:35 CEST Universal time: Wed 2025-05-07 08:17:35 UTC RTC time: n/a Time zone: Europe/Berlin (CEST, +0200) System clock synchronized: yes NTP service: inactive RTC in local TZ: no *** Users and Groups *** User that called 'iob diag': codierknecht HOME=/home/codierknecht GROUPS=codierknecht adm sudo users systemd-journal iobroker User that is running 'js-controller': iobroker HOME=/home/iobroker GROUPS=iobroker tty dialout audio video plugdev *** DISPLAY-SERVER SETUP *** Display-Server: false Desktop: Terminal: *** MEMORY *** total used free shared buff/cache available Mem: 8.6G 2.4G 5.7G 397K 482M 6.2G Swap: 1.1G 512M 561M Total: 9.7G 2.9G 6.3G Active iob-Instances: 36 8192 M total memory 2289 M used memory 1102 M active memory 1506 M inactive memory 5443 M free memory 0 M buffer memory 459 M swap cache 1024 M total swap 488 M used swap 535 M free swap *** top - Table Of Processes *** top - 10:17:36 up 7 days, 4 min, 2 users, load average: 0.33, 0.36, 0.49 Tasks: 67 total, 1 running, 66 sleeping, 0 stopped, 0 zombie %Cpu(s): 0.0 us, 0.0 sy, 0.0 ni,100.0 id, 0.0 wa, 0.0 hi, 0.0 si, 0.0 st MiB Mem : 8192.0 total, 5441.1 free, 2291.2 used, 460.1 buff/cache MiB Swap: 1024.0 total, 535.6 free, 488.4 used. 5900.8 avail Mem *** FAILED SERVICES *** UNIT LOAD ACTIVE SUB DESCRIPTION 0 loaded units listed. *** DMESG CRITICAL ERRORS *** No critical errors detected *** FILESYSTEM *** Filesystem Type Size Used Avail Use% Mounted on /dev/mapper/pve-vm--104--disk--0 ext4 20G 9.6G 9.0G 52% / none tmpfs 492K 4.0K 488K 1% /dev tmpfs tmpfs 7.8G 0 7.8G 0% /dev/shm tmpfs tmpfs 3.2G 232K 3.2G 1% /run tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock Messages concerning ext4 filesystem in dmesg: [Wed Apr 30 10:12:42 2025] EXT4-fs (dm-1): mounted filesystem 35e403cc-3cb6-4691-937c-5b0dccb22862 ro with ordered data mode. Quota mode: none. [Wed Apr 30 10:12:42 2025] EXT4-fs (dm-1): re-mounted 35e403cc-3cb6-4691-937c-5b0dccb22862 r/w. Quota mode: none. [Wed Apr 30 10:12:51 2025] EXT4-fs (dm-6): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 r/w with ordered data mode. Quota mode: none. [Wed Apr 30 10:12:53 2025] EXT4-fs (dm-7): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 r/w with ordered data mode. Quota mode: none. [Wed Apr 30 10:12:55 2025] EXT4-fs (dm-8): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 r/w with ordered data mode. Quota mode: none. [Wed Apr 30 10:12:58 2025] EXT4-fs (dm-10): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 r/w with ordered data mode. Quota mode: none. [Thu May 1 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Thu May 1 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Thu May 1 03:01:33 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Thu May 1 03:01:33 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Thu May 1 03:01:33 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Thu May 1 03:03:11 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Thu May 1 03:03:12 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Thu May 1 03:03:12 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Thu May 1 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Thu May 1 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Thu May 1 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Thu May 1 03:07:08 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. [Fri May 2 03:00:03 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Fri May 2 03:00:03 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Fri May 2 03:01:35 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Fri May 2 03:01:36 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Fri May 2 03:01:36 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Fri May 2 03:03:17 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Fri May 2 03:03:17 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Fri May 2 03:03:17 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Fri May 2 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Fri May 2 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Fri May 2 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Fri May 2 03:07:25 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. [Sat May 3 03:00:05 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sat May 3 03:00:05 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Sat May 3 03:01:39 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Sat May 3 03:01:40 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sat May 3 03:01:40 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Sat May 3 03:03:22 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Sat May 3 03:03:23 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sat May 3 03:03:23 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Sat May 3 03:03:49 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Sat May 3 03:03:50 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sat May 3 03:03:50 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Sat May 3 03:07:19 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. [Sun May 4 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sun May 4 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Sun May 4 03:01:36 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Sun May 4 03:01:37 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sun May 4 03:01:37 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Sun May 4 03:03:15 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Sun May 4 03:03:15 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sun May 4 03:03:15 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Sun May 4 03:03:38 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Sun May 4 03:03:39 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Sun May 4 03:03:39 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Sun May 4 03:07:14 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. [Mon May 5 03:00:03 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Mon May 5 03:00:03 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Mon May 5 03:01:26 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Mon May 5 03:01:26 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Mon May 5 03:01:26 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Mon May 5 03:02:56 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Mon May 5 03:02:57 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Mon May 5 03:02:57 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Mon May 5 03:03:28 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Mon May 5 03:03:29 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Mon May 5 03:03:29 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Mon May 5 03:07:00 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. [Tue May 6 03:00:02 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Tue May 6 03:00:02 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Tue May 6 03:01:38 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Tue May 6 03:01:39 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Tue May 6 03:01:39 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Tue May 6 03:03:14 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Tue May 6 03:03:15 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Tue May 6 03:03:15 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Tue May 6 03:03:43 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Tue May 6 03:03:44 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Tue May 6 03:03:44 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Tue May 6 03:07:24 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. [Wed May 7 03:00:01 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Wed May 7 03:00:01 2025] EXT4-fs (dm-14): mounted filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3 ro without journal. Quota mode: none. [Wed May 7 03:01:42 2025] EXT4-fs (dm-14): unmounting filesystem a11f86ac-a4e4-488c-bc2c-2db75e997cc3. [Wed May 7 03:01:43 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Wed May 7 03:01:43 2025] EXT4-fs (dm-14): mounted filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853 ro without journal. Quota mode: none. [Wed May 7 03:03:23 2025] EXT4-fs (dm-14): unmounting filesystem 8b461bc5-aaae-4f92-b9dc-1b253ff32853. [Wed May 7 03:03:24 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Wed May 7 03:03:24 2025] EXT4-fs (dm-14): mounted filesystem 5df1d13b-e057-4349-be14-0c7f7caea850 ro without journal. Quota mode: none. [Wed May 7 03:03:54 2025] EXT4-fs (dm-14): unmounting filesystem 5df1d13b-e057-4349-be14-0c7f7caea850. [Wed May 7 03:03:55 2025] EXT4-fs (dm-14): write access unavailable, skipping orphan cleanup [Wed May 7 03:03:55 2025] EXT4-fs (dm-14): mounted filesystem 9482b979-29f0-4d0f-bed4-b25049069e15 ro without journal. Quota mode: none. [Wed May 7 03:07:32 2025] EXT4-fs (dm-14): unmounting filesystem 9482b979-29f0-4d0f-bed4-b25049069e15. Show mounted filesystems: TARGET SOURCE FSTYPE OPTIONS / /dev/mapper/pve-vm--104--disk--0 ext4 rw,relatime,stripe=16 Files in neuralgic directories: /var: 3.2G /var/ 2.1G /var/log/journal/c56b513cffd54f1394845d28e4aeddf1 2.1G /var/log/journal 2.1G /var/log 954M /var/cache Archived and active journals take up 2.0G in the file system. /opt/iobroker/backups: 4.0K /opt/iobroker/backups/ /opt/iobroker/iobroker-data: 991M /opt/iobroker/iobroker-data/ 857M /opt/iobroker/iobroker-data/files 617M /opt/iobroker/iobroker-data/files/javascript.admin 560M /opt/iobroker/iobroker-data/files/javascript.admin/static 558M /opt/iobroker/iobroker-data/files/javascript.admin/static/js The five largest files in iobroker-data are: 29M /opt/iobroker/iobroker-data/objects.jsonl 24M /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map 24M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map 17M /opt/iobroker/iobroker-data/files/scheduler.admin/static/js/main.64d9ecc7.js.map 9.3M /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js USB-Devices by-id: USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id': No Devices found 'by-id' *** ZigBee Settings *** HINT: Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting: tcp Zigbee Network Settings on your coordinator/in nvbackup are: zigbee.X Extended Pan ID: *** MASKED *** Pan ID: *** MASKED *** Channel: *** MASKED *** Network Key: *** MASKED *** To unmask the settings run 'iob diag --unmask' *** NodeJS-Installation *** /usr/bin/nodejs v20.19.1 /usr/bin/node v20.19.1 /usr/bin/npm 10.8.2 /usr/bin/npx 10.8.2 /usr/bin/corepack 0.31.0 nodejs: Installed: 20.19.1-1nodesource1 Candidate: 20.19.1-1nodesource1 Version table: *** 20.19.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 100 /var/lib/dpkg/status 20.19.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.3-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.18.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.17.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.16.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.15.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.14.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.13.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.2-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.12.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.11.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.10.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.9.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.8.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.7.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.6.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.5.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.4.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.1-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.3.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.2.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.1.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 20.0.0-1nodesource1 1001 500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages 18.19.0+dfsg-6~deb12u2 500 500 http://deb.debian.org/debian bookworm/main amd64 Packages 18.19.0+dfsg-6~deb12u1 500 500 http://security.debian.org bookworm-security/main amd64 Packages Temp directories causing deletion problem: 0 No problems detected Errors in npm tree: 0 No problems detected *** ioBroker-Installation *** ioBroker Status iobroker is running on this host. Objects type: jsonl States type: jsonl Hosts: iobroker iobroker (version: 7.0.6, hostname: iobroker , alive, uptime: 605072) Core adapters versions js-controller: 7.0.6 admin: 7.6.3 javascript: 8.8.3 nodejs modules from github: 2 +-- iobroker.linux-control@1.1.6 (git+ssh://git@github.com/Scrounger/ioBroker.linux-control.git#59f578f3402850684ba8767a24a9ff288b05a3f0) +-- iobroker.renault@0.0.22 (git+ssh://git@github.com/TA2k/ioBroker.renault.git#860bde5a0d4828af5e85cc4569c56d740523d767) Adapter State + system.adapter.adguard.0 : adguard : iobroker - enabled + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.backitup.0 : backitup : iobroker - enabled + system.adapter.boschindego.0 : boschindego : iobroker - enabled + system.adapter.denon.0 : denon : iobroker - enabled + system.adapter.device-watcher.0 : device-watcher : iobroker - enabled + system.adapter.email.0 : email : iobroker - enabled + system.adapter.energiefluss.0 : energiefluss : iobroker - enabled + system.adapter.fritzdect.0 : fritzdect : iobroker - enabled + system.adapter.hm-rega.0 : hm-rega : iobroker - enabled + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 system.adapter.ical.0 : ical : iobroker - enabled system.adapter.ical.1 : ical : iobroker - enabled system.adapter.ical.2 : ical : iobroker - enabled system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled + system.adapter.javascript.0 : javascript : iobroker - enabled + system.adapter.lgtv.0 : lgtv : iobroker - enabled + system.adapter.linux-control.0 : linux-control : iobroker - enabled + system.adapter.lupusec.0 : lupusec : iobroker - enabled + system.adapter.modbus.0 : modbus : iobroker - enabled + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.nina.0 : nina : iobroker - enabled system.adapter.octoprint.0 : octoprint : iobroker - disabled + system.adapter.opendtu.0 : opendtu : iobroker - enabled system.adapter.openweathermap.0 : openweathermap : iobroker - enabled + system.adapter.paperless-ngx.0 : paperless-ngx : iobroker - enabled, port: 8000 + system.adapter.parser.0 : parser : iobroker - enabled + system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006 + system.adapter.pushover.0 : pushover : iobroker - enabled + system.adapter.renault.0 : renault : iobroker - enabled + system.adapter.scenes.0 : scenes : iobroker - enabled system.adapter.scheduler.0 : scheduler : iobroker - disabled + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sql.0 : sql : iobroker - enabled, port: 3306 + system.adapter.tr-064.0 : tr-064 : iobroker - enabled + system.adapter.trashschedule.0 : trashschedule : iobroker - enabled + system.adapter.unifi.0 : unifi : iobroker - enabled + system.adapter.upnp.0 : upnp : iobroker - enabled system.adapter.vis-bars.0 : vis-bars : iobroker - disabled system.adapter.vis-canvas-gauges.0 : vis-canvas-gauges : iobroker - disabled system.adapter.vis-hqwidgets.0 : vis-hqwidgets : iobroker - disabled system.adapter.vis-jqui-mfd.0 : vis-jqui-mfd : iobroker - disabled system.adapter.vis-map.0 : vis-map : iobroker - disabled system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - disabled system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - enabled system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled system.adapter.vis.0 : vis : iobroker - enabled + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.yahka.0 : yahka : iobroker - enabled + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: tcp://192.168.179.141:6638 + instance is alive Enabled adapters with bindings + system.adapter.admin.0 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin + system.adapter.hm-rpc.0 : hm-rpc : iobroker - enabled, port: 0 + system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1886, bind: 0.0.0.0 + system.adapter.paperless-ngx.0 : paperless-ngx : iobroker - enabled, port: 8000 + system.adapter.proxmox.0 : proxmox : iobroker - enabled, port: 8006 + system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8083, bind: 0.0.0.0, run as: admin + system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0 + system.adapter.sql.0 : sql : iobroker - enabled, port: 3306 + system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin + system.adapter.zigbee.0 : zigbee : iobroker - enabled, port: tcp://192.168.179.141:6638 ioBroker-Repositories ┌─────────┬──────────┬─────────────────────────────────────────────────────────┬──────────────┐ │ (index) │ name │ url │ auto upgrade │ ├─────────┼──────────┼─────────────────────────────────────────────────────────┼──────────────┤ │ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ true │ │ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │ └─────────┴──────────┴─────────────────────────────────────────────────────────┴──────────────┘ Active repo(s): stable Upgrade policy: minor Installed ioBroker-Adapters Used repository: stable Adapter "adguard" : 1.0.1 , installed 1.0.1 Adapter "admin" : 7.6.3 , installed 7.6.3 Adapter "backitup" : 3.0.31 , installed 3.0.31 Adapter "boschindego" : 1.3.9 , installed 1.3.9 Adapter "denon" : 1.15.12 , installed 1.15.12 Adapter "device-watcher": 2.12.1 , installed 2.12.1 Adapter "email" : 2.0.3 , installed 2.0.3 Adapter "energiefluss" : 3.6.2 , installed 3.6.2 Adapter "fritzdect" : 2.6.1 , installed 2.6.1 Adapter "hm-rega" : 5.1.0 , installed 5.1.0 Adapter "hm-rpc" : 2.0.2 , installed 2.0.2 Adapter "ical" : 1.16.1 , installed 1.16.1 Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0 Adapter "javascript" : 8.8.3 , installed 8.8.3 Controller "js-controller": 7.0.6 , installed 7.0.6 Adapter "lgtv" : 2.4.0 , installed 2.4.0 Adapter "linux-control": 1.1.5 , installed 1.1.6 Adapter "lupusec" : 2.0.7 , installed 2.0.7 Adapter "modbus" : 6.3.2 , installed 6.3.2 Adapter "mqtt" : 6.1.2 , installed 6.1.2 Adapter "nina" : 0.0.25 , installed 0.0.25 Adapter "octoprint" : 5.1.0 , installed 5.1.0 Adapter "opendtu" : 3.1.0 , installed 3.1.0 Adapter "openweathermap": 1.1.2 , installed 1.1.2 Adapter "paperless-ngx": 0.4.4 , installed 0.4.4 Adapter "parser" : 2.2.4 , installed 2.2.4 Adapter "proxmox" : 2.4.0 , installed 2.4.0 Adapter "pushover" : 4.1.0 , installed 4.1.0 Adapter "scenes" : 3.2.3 , installed 3.2.3 Adapter "scheduler" : 1.4.1 , installed 1.4.1 Adapter "simple-api" : 2.8.0 , installed 2.8.0 Adapter "socketio" : 6.7.1 , installed 6.7.1 Adapter "sonoff" : 3.1.2 , installed 3.1.2 Adapter "sql" : 3.0.1 , installed 3.0.1 Adapter "tr-064" : 4.3.0 , installed 4.3.0 Adapter "trashschedule": 3.3.0 , installed 3.3.0 Adapter "unifi" : 0.7.0 , installed 0.7.0 Adapter "upnp" : 1.1.0 , installed 1.1.0 Adapter "vis" : 1.5.6 , installed 1.5.6 Adapter "vis-bars" : 0.1.4 , installed 0.1.4 Adapter "vis-canvas-gauges": 1.0.1, installed 1.0.1 Adapter "vis-hqwidgets": 1.5.1 , installed 1.5.1 Adapter "vis-jqui-mfd" : 1.1.1 , installed 1.1.1 Adapter "vis-map" : 1.1.2 , installed 1.1.2 Adapter "vis-material-advanced": 1.7.4, installed 1.7.4 Adapter "vis-materialdesign": 0.5.9, installed 0.5.9 Adapter "vis-timeandweather": 1.2.2, installed 1.2.2 Adapter "web" : 7.0.8 , installed 7.0.8 Adapter "ws" : 2.6.2 , installed 2.6.2 Adapter "yahka" : 1.0.3 , installed 1.0.3 Adapter "zigbee" : 2.0.5 , installed 2.0.5 Objects and States Please stand by - This may take a while Objects: 10034 States: 7944 *** OS-Repositories and Updates *** Hit:1 http://deb.debian.org/debian bookworm InRelease Hit:2 http://security.debian.org bookworm-security InRelease Hit:3 http://deb.debian.org/debian bookworm-updates InRelease Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease Hit:5 https://packagecloud.io/ookla/speedtest-cli/debian bookworm InRelease Reading package lists... Pending Updates: 0 *** Listening Ports *** Active Internet connections (only servers) Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name tcp 0 0 127.0.0.1:39603 0.0.0.0:* LISTEN 1001 52141433 1353/io.yahka.0 tcp 0 0 0.0.0.0:38509 0.0.0.0:* LISTEN 1001 36404 1353/io.yahka.0 tcp 0 0 127.0.0.1:37835 0.0.0.0:* LISTEN 1001 52138637 1353/io.yahka.0 tcp 0 0 127.0.0.1:38711 0.0.0.0:* LISTEN 1001 52138642 1353/io.yahka.0 tcp 0 0 0.0.0.0:8087 0.0.0.0:* LISTEN 1001 34556 1152/io.lupusec.0 tcp 0 0 0.0.0.0:40401 0.0.0.0:* LISTEN 1001 36422 1353/io.yahka.0 tcp 0 0 0.0.0.0:9001 0.0.0.0:* LISTEN 1001 20512 145/iobroker.js-con tcp 0 0 0.0.0.0:9000 0.0.0.0:* LISTEN 1001 20517 145/iobroker.js-con tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 17811 1/init tcp 0 0 0.0.0.0:33273 0.0.0.0:* LISTEN 1001 36414 1353/io.yahka.0 tcp 0 0 0.0.0.0:2010 0.0.0.0:* LISTEN 1001 21281 538/io.hm-rpc.0 tcp 0 0 0.0.0.0:10050 0.0.0.0:* LISTEN 105 27697967 578950/zabbix_agent tcp 0 0 0.0.0.0:1886 0.0.0.0:* LISTEN 1001 26164 649/io.mqtt.0 tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN 1001 29931 703/io.sonoff.0 tcp 0 0 127.0.0.1:33163 0.0.0.0:* LISTEN 1001 52141438 1353/io.yahka.0 tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 0 18295 315/master tcp 0 0 0.0.0.0:43447 0.0.0.0:* LISTEN 1001 36418 1353/io.yahka.0 tcp6 0 0 ::1:25 :::* LISTEN 0 18296 315/master tcp6 0 0 :::8083 :::* LISTEN 1001 37981 1264/io.simple-api. tcp6 0 0 :::8082 :::* LISTEN 1001 38176 1336/io.web.0 tcp6 0 0 :::8081 :::* LISTEN 1001 20594 326/io.admin.0 tcp6 0 0 :::8000 :::* LISTEN 1001 38540 1302/io.upnp.0 tcp6 0 0 :::41527 :::* LISTEN 1001 36407 1353/io.yahka.0 tcp6 0 0 :::22 :::* LISTEN 0 18822 1/init tcp6 0 0 :::111 :::* LISTEN 0 17813 1/init tcp6 0 0 :::10050 :::* LISTEN 105 27697968 578950/zabbix_agent tcp6 0 0 :::35443 :::* LISTEN 1001 36409 1353/io.yahka.0 tcp6 0 0 :::34843 :::* LISTEN 1001 36405 1353/io.yahka.0 udp 0 0 0.0.0.0:1900 0.0.0.0:* 1001 38251 1302/io.upnp.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36419 1353/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36415 1353/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36411 1353/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36410 1353/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36408 1353/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36406 1353/io.yahka.0 udp 0 0 0.0.0.0:5353 0.0.0.0:* 1001 36401 1353/io.yahka.0 udp 0 0 0.0.0.0:55640 0.0.0.0:* 1001 36205 1302/io.upnp.0 udp 0 0 0.0.0.0:68 0.0.0.0:* 0 18746 87/dhclient udp 0 0 0.0.0.0:111 0.0.0.0:* 0 17812 1/init udp6 0 0 :::111 :::* 0 17814 1/init *** Log File - Last 25 Lines *** 2025-05-07 09:23:53.981 - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json" 2025-05-07 09:23:56.819 - info: admin.0 (326) Repository received successfully. 2025-05-07 09:23:57.175 - info: host.iobroker Check for available automatic adapter upgrades 2025-05-07 09:32:00.012 - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 1128208 2025-05-07 09:32:06.894 - info: host.iobroker instance system.adapter.ical.0 having pid 1128208 terminated with code 0 (NO_ERROR) 2025-05-07 09:34:00.009 - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 1128302 2025-05-07 09:34:07.823 - info: host.iobroker instance system.adapter.ical.1 having pid 1128302 terminated with code 0 (NO_ERROR) 2025-05-07 09:36:00.010 - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 1128749 2025-05-07 09:36:07.257 - info: host.iobroker instance system.adapter.ical.2 having pid 1128749 terminated with code 0 (NO_ERROR) 2025-05-07 09:45:44.384 - info: javascript.0 (392) script.js.common.Informationen.Renault: Austral-Standort: 387, Friedrich-Ebert-Straße, Stadtwald, Bockum, Krefeld, North Rhine-Westphalia, 47800, Germany 2025-05-07 09:47:37.009 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1129921 2025-05-07 09:47:53.163 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 1129921 terminated with code 0 (NO_ERROR) 2025-05-07 09:52:00.024 - info: javascript.0 (392) script.js.common.Informationen.Speedtest: Speedtest mit Server 54504 gestartet! Der Test dauert zwischen 10 - 20 Sekunden! 2025-05-07 09:52:17.539 - info: javascript.0 (392) script.js.common.Informationen.Speedtest: Speedtest durchgeführt. Ergebnisse: Download: 49.1 MB/s | Upload: 24.5 MB/s | Ping: 7.983ms 2025-05-07 10:02:00.013 - info: host.iobroker instance system.adapter.ical.0 in version "1.16.1" started with pid 1131604 2025-05-07 10:02:06.805 - info: host.iobroker instance system.adapter.ical.0 having pid 1131604 terminated with code 0 (NO_ERROR) 2025-05-07 10:04:00.015 - info: host.iobroker instance system.adapter.ical.1 in version "1.16.1" started with pid 1131698 2025-05-07 10:04:07.751 - info: host.iobroker instance system.adapter.ical.1 having pid 1131698 terminated with code 0 (NO_ERROR) 2025-05-07 10:06:00.012 - info: host.iobroker instance system.adapter.ical.2 in version "1.16.1" started with pid 1132140 2025-05-07 10:06:07.131 - info: host.iobroker instance system.adapter.ical.2 having pid 1132140 terminated with code 0 (NO_ERROR) 2025-05-07 10:13:00.948 - info: javascript.0 (392) script.js.common.Informationen.Aktienkurs: Aktienkurs ENR.DE: 72.82 € 2025-05-07 10:13:00.948 - info: javascript.0 (392) script.js.common.Informationen.Aktienkurs: Aktienkurs SIE.DE: 209.55 € 2025-05-07 10:13:11.339 - info: admin.0 (326) Adapter rating updated 2025-05-07 10:17:37.015 - info: host.iobroker instance system.adapter.openweathermap.0 in version "1.1.2" started with pid 1133590 2025-05-07 10:17:43.169 - info: host.iobroker instance system.adapter.openweathermap.0 having pid 1133590 terminated with code 0 (NO_ERROR)
Dann dürfte da ein Paket fehlen. Ich meine das sollte auch bei LXCs funktionieren. Jag den
iob fix
mal drüber.
Hilft nicht wirklich*** BASE SYSTEM *** Static hostname: iobroker Icon name: computer-container Chassis: container ☐ Virtualization: lxc Operating System: Debian GNU/Linux 12 (bookworm) Kernel: Linux 6.8.12-10-pve Architecture: x86-64 OS is similar to: model name : Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz Docker : false Virtualization : lxc Kernel : x86_64 Userland : 64 bit Systemuptime and Load: 10:28:21 up 7 days, 15 min, 2 users, load average: 1.16, 0.89, 0.68 CPU threads: 2 *** LIFE CYCLE STATUS *** Unknown release codenamed ''. Please check yourself if the Operating System is actively maintained.
ist aber auch nur Kosmetik. Oben hat er ja erkannt, dass es sich um "bookworm" handelt. Und ich weiß es ja auch.
Aber ich will hier nicht den Thread des TE kapern. also zurück zum Thema.
@Kellerkind-86
Läuft das jetzt zu Deiner Zufriedenheit? -
jap, das hatte ich gestern gegooglet.. kann ignoriert werden.. danke für die Hilfe hier immer wieder thumps up dafür. danke wiedermals..
