    4. Tester für Zigbee Adapter 2.0.x gesucht
      Homoran Global Moderator Administrators @Horst Böttcher last edited by Homoran
      @horst-böttcher sagte in Tester für Zigbee Adapter 2.0.x gesucht:
      aber
      da sind doch die Tastendrücke!
      (press)
      und die battery
      bevor fragen zum log kommen es steht nix drin
      zeigen!
      Instanz auf debug gestellt?
      Horst Böttcher Homoran 2 Replies Last reply Reply Quote 0
      • Horst Böttcher
        Horst Böttcher @Homoran last edited by Homoran
        @homoran .log.txt)
        MOD-EDIT: private Daten entfernt
          Homoran Global Moderator Administrators @Homoran last edited by Homoran
          @homoran sagte in Tester für Zigbee Adapter 2.0.x gesucht:
          und?
          und log vom Adapterstart bitte in code-tags gesetzt posten!
          Horst Böttcher 1 Reply Last reply Reply Quote 0
          • Horst Böttcher
            @homoran Ja den adapter auf debug
            datemmege zu gross
            zigbee.0
            2025-05-04 12:56:04.366	info	0x001788010bdb6285 (addr 58635): 929002398602 - Philips Hue dimmer switch (EndDevice)
            zigbee.0
            2025-05-04 12:56:04.366	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":20,"_applicationVersion":2,"_dateCode":"20210729","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":2096,"inputClusters":[0,1,3,64512,4096],"outputClusters":[25,0,3,4,6,8,5,4096],"profileID":260,"ID":1,"clusters":{"genPowerCfg":{"attributes":{"batteryPercentageRemaining":67}}},"deviceIeeeAddress":"0x001788010bdb6285","deviceNetworkAddress":58635,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x001788010bdb6285"}}],"_hardwareVersion":1,"_ieeeAddr":"0x001788010bdb6285","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1746355182186,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"RWL022","_networkAddress":58635,"_powerSource":"Battery","_softwareBuildID":"2.45.2_hF4400CA","_stackVersion":1,"_type":"EndDevice","_zclVersion":2,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{}},"mapped":{"zigbeeModel":["RWL022"],"model":"929002398602","vendor":"Philips","description":"Hue dimmer switch","fromZigbee":[{"cluster":"genOnOff","type":"commandOn"},{"cluster":"genOnOff","type":"commandOffWithEffect"},{"cluster":"genLevelCtrl","type":"commandStep"},{"cluster":"genLevelCtrl","type":"commandStop"},{"cluster":"manuSpecificPhilips","type":"commandHueNotification","options":[{"name":"simulated_brightness","label":"Simulated brightness","access":2,"type":"composite","property":"simulated_brightness","description":"Simulate a brightness value. If this device provides a brightness_move_up or brightness_move_down action it is possible to specify the update interval and delta. The action_brightness_delta indicates the delta for each interval.","features":[{"name":"delta","label":"Delta","access":2,"type":"numeric","property":"delta","description":"Delta per interval, 20 by default","value_min":0},{"name":"interval","label":"Interval","access":2,"type":"numeric","property":"interval","description":"Interval duration","unit":"ms","value_min":0}]}]},{"cluster":"genPowerCfg","type":["attributeReport","readResponse"]},{"cluster":"genScenes","type":"commandRecall"}],"exposes":[{"name":"battery","label":"Battery","access":1,"type":"numeric","property":"battery","description":"Remaining battery in %, can take up to 24 hours before reported","category":"diagnostic","unit":"%","value_max":100,"value_min":0},{"name":"action","label":"Action","access":1,"type":"enum","property":"action","description":"Triggered action (e.g. a button click)","category":"diagnostic","values":["on_press","on_hold","on_press_release","on_hold_release","off_press","off_hold","off_press_release","off_hold_release","up_press","up_hold","up_press_release","up_hold_release","down_press","down_hold","down_press_release","down_hold_release","recall_0","recall_1"]}],"toZigbee":[{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"ota":true,"options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x001788010bdb6285"}
            zigbee.0
            2025-05-04 12:56:04.365	info	0xa4c138f02d255d0b (addr 23243): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
            zigbee.0
            2025-05-04 12:56:04.365	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":19,"_applicationVersion":77,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":2,"switchType":0}},"genBasic":{"attributes":{"65503":"]��/\u0013^��/\u0012Ds�/\u0012","65506":54,"65508":0,"65534":0,"zclVersion":3,"manufacturerName":"_TZ3000_w0qqde0g","appVersion":77,"modelId":"TS011F","powerSource":1}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"rmsCurrent":273,"activePower":62,"rmsVoltage":229}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":153552,"status":0}}},"deviceIeeeAddress":"0xa4c138f02d255d0b","deviceNetworkAddress":23243,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":257}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138f02d255d0b"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138f02d255d0b","deviceNetworkAddress":23243,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138f02d255d0b"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138f02d255d0b","_interviewCompleted":false,"_interviewing":false,"_lastSeen":1746356124446,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_w0qqde0g","_modelID":"TS011F","_networkAddress":23243,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","countdown"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"countdown","label":"Countdown","access":7,"type":"numeric","property":"countdown","description":"Countdown to turn device off after a certain time","unit":"s","value_max":43200,"value_min":0,"value_step":1},{"name":"power_outage_memory","label":"Power outage memory","access":7,"type":"enum","property":"power_outage_memory","description":"Recover state after power outage","values":["on","off","restore"]},{"name":"indicator_mode","label":"Indicator mode","access":7,"type":"enum","property":"indicator_mode","description":"LED indicator mode","values":["off","off/on","on/off","on"]},{"name":"power","label":"Power","access":1,"type":"numeric","property":"power","description":"Instantaneous measured power","category":"diagnostic","unit":"W"},{"name":"current","label":"Current","access":1,"type":"numeric","property":"current","description":"Instantaneous measured electrical current","category":"diagnostic","unit":"A"},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Measured electrical potential value","category":"diagnostic","unit":"V"},{"name":"energy","label":"Energy","access":1,"type":"numeric","property":"energy","description":"Sum of consumed energy","unit":"kWh"},{"name":"child_lock","label":"Child lock","access":3,"type":"binary","property":"child_lock","description":"Enables/disables physical input on the device","value_on":"LOCK","value_off":"UNLOCK"}],"ota":true,"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"Tuya","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"Neo","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"},{"vendor":"Aubess","model":"TS011F_plug_1"},{"vendor":"Nous","model":"A1Z","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_2putqrmw"},{"manufacturerName":"_TZ3000_ksw8qtmt"}]},{"vendor":"Moes","model":"MOES_plug","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_yujkchbz"}]},{"vendor":"Moes","model":"ZK-EU","description":"Smart wallsocket (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_ss98ec5d"}]},{"vendor":"Elivco","model":"LSPA9","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_okaz9tjs"}]},{"vendor":"PSMART","model":"T440","description":"Smart wallsocket (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_y4ona9me"}]},{"vendor":"Nous","model":"A6Z","description":"Outdoor smart socket","fingerprint":[{"manufacturerName":"_TZ3000_266azbg3"}]},{"vendor":"Nedis","model":"ZBPO130FWT","description":"Outdoor smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_3ias4w4o"}]},{"vendor":"Nous","model":"A9Z","description":"Smart ZigBee Socket","fingerprint":[{"manufacturerName":"_TZ3210_ddigca5n"}]}],"options":[{"name":"power_calibration","label":"Power calibration","access":2,"type":"numeric","property":"power_calibration","description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"name":"power_precision","label":"Power precision","access":2,"type":"numeric","property":"power_precision","description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"current_calibration","label":"Current calibration","access":2,"type":"numeric","property":"current_calibration","description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"name":"current_precision","label":"Current precision","access":2,"type":"numeric","property":"current_precision","description":"Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"voltage_calibration","label":"Voltage calibration","access":2,"type":"numeric","property":"voltage_calibration","description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"name":"voltage_precision","label":"Voltage precision","access":2,"type":"numeric","property":"voltage_precision","description":"Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"energy_calibration","label":"Energy calibration","access":2,"type":"numeric","property":"energy_calibration","description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."},{"name":"energy_precision","label":"Energy precision","access":2,"type":"numeric","property":"energy_precision","description":"Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},"[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xa4c138f02d255d0b"}
            zigbee.0
            2025-05-04 12:56:04.363	info	0xa4c138832d4863f6 (addr 18772): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
            zigbee.0
            2025-05-04 12:56:04.363	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":15,"_applicationVersion":77,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":266,"inputClusters":[3,4,5,6,1794,2820,57344,57345,0],"outputClusters":[25,10],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"65503":"Z��/\u0013[��/\u0012�r�/\u0012","65506":54,"65508":0,"65534":0,"stackVersion":0,"dateCode":"","zclVersion":3,"manufacturerName":"_TZ3000_w0qqde0g","appVersion":77,"modelId":"TS011F","powerSource":1}},"genOnOff":{"attributes":{"32768":0,"onOff":1,"onTime":0,"offWaitTime":0,"tuyaBacklightMode":1,"moesStartUpOnOff":2,"tuyaBacklightSwitch":1}},"manuSpecificTuya_3":{"attributes":{"53248":0,"53249":0,"53250":0,"53251":0,"53252":0,"53253":0,"powerOnBehavior":2,"switchType":0}},"haElectricalMeasurement":{"attributes":{"acCurrentDivisor":1000,"acCurrentMultiplier":1,"activePower":7,"rmsCurrent":119,"rmsVoltage":228}},"seMetering":{"attributes":{"divisor":100,"multiplier":1,"currentSummDelivered":29238,"status":0}}},"deviceIeeeAddress":"0xa4c138832d4863f6","deviceNetworkAddress":18772,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1},{"cluster":2820,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1},{"cluster":1794,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1}],"_configuredReportings":[{"cluster":2820,"attrId":1285,"minRepIntval":5,"maxRepIntval":3600,"repChange":5},{"cluster":2820,"attrId":1288,"minRepIntval":5,"maxRepIntval":3600,"repChange":50},{"cluster":2820,"attrId":1291,"minRepIntval":5,"maxRepIntval":3600,"repChange":10},{"cluster":1794,"attrId":0,"minRepIntval":5,"maxRepIntval":3600,"repChange":257}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0xa4c138832d4863f6"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0xa4c138832d4863f6","deviceNetworkAddress":18772,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0xa4c138832d4863f6"}}],"_hardwareVersion":1,"_ieeeAddr":"0xa4c138832d4863f6","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1746356124456,"_manufacturerID":4417,"_manufacturerName":"_TZ3000_w0qqde0g","_modelID":"TS011F","_networkAddress":18772,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","countdown"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["child_lock"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"haElectricalMeasurement","type":["attributeReport","readResponse"]},{"cluster":"seMetering","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"countdown","label":"Countdown","access":7,"type":"numeric","property":"countdown","description":"Countdown to turn device off after a certain time","unit":"s","value_max":43200,"value_min":0,"value_step":1},{"name":"power_outage_memory","label":"Power outage memory","access":7,"type":"enum","property":"power_outage_memory","description":"Recover state after power outage","values":["on","off","restore"]},{"name":"indicator_mode","label":"Indicator mode","access":7,"type":"enum","property":"indicator_mode","description":"LED indicator mode","values":["off","off/on","on/off","on"]},{"name":"power","label":"Power","access":1,"type":"numeric","property":"power","description":"Instantaneous measured power","category":"diagnostic","unit":"W"},{"name":"current","label":"Current","access":1,"type":"numeric","property":"current","description":"Instantaneous measured electrical current","category":"diagnostic","unit":"A"},{"name":"voltage","label":"Voltage","access":1,"type":"numeric","property":"voltage","description":"Measured electrical potential value","category":"diagnostic","unit":"V"},{"name":"energy","label":"Energy","access":1,"type":"numeric","property":"energy","description":"Sum of consumed energy","unit":"kWh"},{"name":"child_lock","label":"Child lock","access":3,"type":"binary","property":"child_lock","description":"Enables/disables physical input on the device","value_on":"LOCK","value_off":"UNLOCK"}],"ota":true,"zigbeeModel":["TS011F"],"model":"TS011F_plug_1","description":"Smart plug (with power monitoring)","vendor":"Tuya","whiteLabel":[{"vendor":"LELLKI","model":"TS011F_plug"},{"vendor":"Neo","model":"NAS-WR01B"},{"vendor":"BlitzWolf","model":"BW-SHP15"},{"vendor":"BlitzWolf","model":"BW-SHP13"},{"vendor":"MatSee Plus","model":"PJ-ZSW01"},{"vendor":"MODEMIX","model":"MOD037"},{"vendor":"MODEMIX","model":"MOD048"},{"vendor":"Coswall","model":"CS-AJ-DE2U-ZG-11"},{"vendor":"Aubess","model":"TS011F_plug_1"},{"vendor":"Nous","model":"A1Z","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_2putqrmw"},{"manufacturerName":"_TZ3000_ksw8qtmt"}]},{"vendor":"Moes","model":"MOES_plug","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_yujkchbz"}]},{"vendor":"Moes","model":"ZK-EU","description":"Smart wallsocket (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_ss98ec5d"}]},{"vendor":"Elivco","model":"LSPA9","description":"Smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_okaz9tjs"}]},{"vendor":"PSMART","model":"T440","description":"Smart wallsocket (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_y4ona9me"}]},{"vendor":"Nous","model":"A6Z","description":"Outdoor smart socket","fingerprint":[{"manufacturerName":"_TZ3000_266azbg3"}]},{"vendor":"Nedis","model":"ZBPO130FWT","description":"Outdoor smart plug (with power monitoring)","fingerprint":[{"manufacturerName":"_TZ3000_3ias4w4o"}]},{"vendor":"Nous","model":"A9Z","description":"Smart ZigBee Socket","fingerprint":[{"manufacturerName":"_TZ3210_ddigca5n"}]}],"options":[{"name":"power_calibration","label":"Power calibration","access":2,"type":"numeric","property":"power_calibration","description":"Calibrates the power value (percentual offset), takes into effect on next report of device."},{"name":"power_precision","label":"Power precision","access":2,"type":"numeric","property":"power_precision","description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"current_calibration","label":"Current calibration","access":2,"type":"numeric","property":"current_calibration","description":"Calibrates the current value (percentual offset), takes into effect on next report of device."},{"name":"current_precision","label":"Current precision","access":2,"type":"numeric","property":"current_precision","description":"Number of digits after decimal point for current, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"voltage_calibration","label":"Voltage calibration","access":2,"type":"numeric","property":"voltage_calibration","description":"Calibrates the voltage value (percentual offset), takes into effect on next report of device."},{"name":"voltage_precision","label":"Voltage precision","access":2,"type":"numeric","property":"voltage_precision","description":"Number of digits after decimal point for voltage, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},{"name":"energy_calibration","label":"Energy calibration","access":2,"type":"numeric","property":"energy_calibration","description":"Calibrates the energy value (percentual offset), takes into effect on next report of device."},{"name":"energy_precision","label":"Energy precision","access":2,"type":"numeric","property":"energy_precision","description":"Number of digits after decimal point for energy, takes into effect on next report of device. This option can only decrease the precision, not increase it.","value_max":3,"value_min":0},"[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0xa4c138832d4863f6"}
            zigbee.0
            2025-05-04 12:56:04.361	info	0x842e14fffeefed35 (addr 39923): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
            zigbee.0
            2025-05-04 12:56:04.361	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":11,"_applicationVersion":66,"_dateCode":"","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":266,"inputClusters":[0,3,4,5,6],"outputClusters":[25,10],"profileID":260,"ID":11,"clusters":{"genBasic":{"attributes":{"stackVersion":0,"dateCode":"","zclVersion":3}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x842e14fffeefed35","deviceNetworkAddress":39923,"_binds":[{"cluster":6,"type":"endpoint","deviceIeeeAddress":"0x00212effff098603","endpointID":1}],"_configuredReportings":[{"cluster":6,"attrId":0,"minRepIntval":0,"maxRepIntval":3600,"repChange":0}],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x842e14fffeefed35"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x842e14fffeefed35","deviceNetworkAddress":39923,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x842e14fffeefed35"}}],"_hardwareVersion":1,"_ieeeAddr":"0x842e14fffeefed35","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1746356123438,"_manufacturerID":4098,"_manufacturerName":"_TZ3000_kdi2o9m6","_modelID":"TS011F","_networkAddress":39923,"_powerSource":"Mains (single phase)","_stackVersion":0,"_type":"Router","_zclVersion":3,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","on_time","off_wait_time"]},{"key":["power_on_behavior","power_outage_memory"]},{"key":["backlight_mode","indicator_mode"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"switch","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of the switch","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"}]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss","category":"config","values":["off","previous","on"]},{"name":"indicator_mode","label":"Indicator mode","access":7,"type":"enum","property":"indicator_mode","description":"LED indicator mode","values":["off","off/on","on/off","on"]}],"fingerprint":[{"manufacturerName":"_TZ3000_kdi2o9m6"},{"modelID":"TS011F","manufacturerName":"_TZ3000_plyvnuf5"},{"modelID":"TS011F","manufacturerName":"_TZ3000_wamqdr3f"},{"modelID":"TS011F","manufacturerName":"_TZ3000_00mk2xzy"},{"modelID":"TS011F","manufacturerName":"_TZ3000_upjrsxh1"},{"manufacturerName":"_TZ3000_00mk2xzy"}],"model":"HG06337","vendor":"Lidl","description":"Silvercrest smart plug (EU, CH, FR, BS, DK)","options":["[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x842e14fffeefed35"}
            zigbee.0
            2025-05-04 12:56:04.284	info	0x00158d00031d7e3a (addr 44829): 404006/404008/404004 - Müller Licht Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white (Router)
            zigbee.0
            2025-05-04 12:56:04.284	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":10,"_applicationVersion":1,"_dateCode":"20180404-42","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":268,"inputClusters":[0,3,4,5,6,8,768,4096],"outputClusters":[25],"profileID":260,"ID":1,"clusters":{"genBasic":{"attributes":{"zclVersion":2}},"genOnOff":{"attributes":{"onOff":0}}},"deviceIeeeAddress":"0x00158d00031d7e3a","deviceNetworkAddress":44829,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":1,"deviceIeeeAddress":"0x00158d00031d7e3a"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":102,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x00158d00031d7e3a","deviceNetworkAddress":44829,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x00158d00031d7e3a"}}],"_hardwareVersion":1,"_ieeeAddr":"0x00158d00031d7e3a","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1746356122935,"_manufacturerID":4635,"_manufacturerName":"MLI","_modelID":"ZBT-ColorTemperature","_networkAddress":44829,"_powerSource":"Mains (single phase)","_softwareBuildID":"2.0","_stackVersion":1,"_type":"Router","_zclVersion":2,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","brightness","brightness_percent","on_time","off_wait_time"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["transition"]},{"key":["level_config"]},{"key":["rate"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_temp","color_temp_percent"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false},{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_mode"]},{"key":["color_options"]},{"key":["colortemp_move","color_temp_move"]},{"key":["color_temp_step"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["color_temp_startup"]},{"key":["effect","alert","flash"]},{"key":["power_on_behavior"]},{"key":["tint_scene"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"lightingColorCtrl","type":["attributeReport","readResponse"],"options":[{"name":"color_sync","label":"Color sync","access":2,"type":"binary","property":"color_sync","description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","value_on":true,"value_off":false}]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"light","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of this light","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"},{"name":"brightness","label":"Brightness","access":7,"type":"numeric","property":"brightness","description":"Brightness of this light","value_max":254,"value_min":0},{"name":"color_temp","label":"Color temp","access":7,"type":"numeric","property":"color_temp","description":"Color temperature of this light","unit":"mired","value_max":370,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warmest","value":370,"description":"Warmest temperature supported"}]},{"name":"color_temp_startup","label":"Color temp startup","access":7,"type":"numeric","property":"color_temp_startup","description":"Color temperature after cold power on of this light","unit":"mired","value_max":370,"value_min":153,"presets":[{"name":"coolest","value":153,"description":"Coolest temperature supported"},{"name":"cool","value":250,"description":"Cool temperature (250 mireds / 4000 Kelvin)"},{"name":"neutral","value":370,"description":"Neutral temperature (370 mireds / 2700 Kelvin)"},{"name":"warmest","value":370,"description":"Warmest temperature supported"},{"name":"previous","value":65535,"description":"Restore previous color_temp on cold power on"}]}]},{"name":"effect","label":"Effect","access":2,"type":"enum","property":"effect","description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss","category":"config","values":["off","on","toggle","previous"]}],"meta":{},"zigbeeModel":["ZBT-ColorTemperature"],"model":"404006/404008/404004","vendor":"Müller Licht","description":"Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white","options":["[Circular]","[Circular]","[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x00158d00031d7e3a"}
            zigbee.0
            2025-05-04 12:56:04.274	info	0x0017880104b83bb0 (addr 28557): 8718696449691 - Philips Hue White A60 Single bulb E27/B22 (Router)
            zigbee.0
            2025-05-04 12:56:04.273	debug	New device event: {"type":"device","device":{"_events":{},"_eventsCount":0,"_maxListeners":100,"ID":8,"_applicationVersion":2,"_dateCode":"20230606","_endpoints":[{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":256,"inputClusters":[0,3,4,5,6,8,4096,64515,64516],"outputClusters":[25],"profileID":49246,"ID":11,"clusters":{"genBasic":{"attributes":{"zclVersion":1,"modelId":"LWB010","manufacturerName":"Signify Netherlands B.V.","powerSource":1,"appVersion":2,"stackVersion":1,"hwVersion":1,"dateCode":"20230606","swBuildId":"1.108.5"}},"genOnOff":{"attributes":{"onOff":1}}},"deviceIeeeAddress":"0x0017880104b83bb0","deviceNetworkAddress":28557,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":11,"deviceIeeeAddress":"0x0017880104b83bb0"}},{"_events":{},"_eventsCount":0,"_maxListeners":100,"deviceID":97,"inputClusters":[33],"outputClusters":[33],"profileID":41440,"ID":242,"clusters":{},"deviceIeeeAddress":"0x0017880104b83bb0","deviceNetworkAddress":28557,"_binds":[],"_configuredReportings":[],"meta":{},"pendingRequests":{"sendInProgress":false,"ID":242,"deviceIeeeAddress":"0x0017880104b83bb0"}}],"_hardwareVersion":1,"_ieeeAddr":"0x0017880104b83bb0","_interviewCompleted":true,"_interviewing":false,"_lastSeen":1746356038426,"_manufacturerID":4107,"_manufacturerName":"Signify Netherlands B.V.","_modelID":"LWB010","_networkAddress":28557,"_powerSource":"Mains (single phase)","_softwareBuildID":"1.108.5","_stackVersion":1,"_type":"Router","_zclVersion":1,"_skipDefaultResponse":false,"_pendingRequestTimeout":0,"_customClusters":{},"meta":{"configured":332242049}},"mapped":{"toZigbee":[{"key":["state","brightness","brightness_percent","on_time","off_wait_time"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["transition"]},{"key":["level_config"]},{"key":["rate"]},{"key":["brightness_move","brightness_move_onoff"]},{"key":["brightness_step","brightness_step_onoff"],"options":[{"name":"transition","label":"Transition","access":2,"type":"numeric","property":"transition","description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","value_min":0}]},{"key":["power_on_behavior"]},{"key":["hue_power_on_behavior"]},{"key":["hue_power_on_brightness","hue_power_on_color_temperature","hue_power_on_color"]},{"key":["effect"]},{"key":["scene_store"]},{"key":["scene_recall"]},{"key":["scene_add"]},{"key":["scene_remove"]},{"key":["scene_remove_all"]},{"key":["scene_rename"]},{"key":["read"]},{"key":["write"]},{"key":["command"]},{"key":["reset"]},{"key":["zclcommand"]}],"fromZigbee":[{"cluster":"genOnOff","type":["attributeReport","readResponse"],"options":[{"name":"state_action","label":"State action","access":2,"type":"binary","property":"state_action","description":"State actions will also be published as 'action' when true (default false).","value_on":true,"value_off":false}]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genBasic","type":["attributeReport","readResponse"]},{"cluster":"genLevelCtrl","type":["attributeReport","readResponse"]},{"cluster":"genOnOff","type":["attributeReport","readResponse"]}],"exposes":[{"type":"light","features":[{"name":"state","label":"State","access":7,"type":"binary","property":"state","description":"On/off state of this light","value_on":"ON","value_off":"OFF","value_toggle":"TOGGLE"},{"name":"brightness","label":"Brightness","access":7,"type":"numeric","property":"brightness","description":"Brightness of this light","value_max":254,"value_min":0}]},{"name":"power_on_behavior","label":"Power-on behavior","access":7,"type":"enum","property":"power_on_behavior","description":"Controls the behavior when the device is powered on after power loss","category":"config","values":["off","on","toggle","previous"]},{"name":"effect","label":"Effect","access":2,"type":"enum","property":"effect","values":["blink","breathe","okay","channel_change","candle","finish_effect","stop_effect","stop_hue_effect"]}],"meta":{"turnsOffAtBrightness1":true},"ota":true,"zigbeeModel":["LWB010"],"model":"8718696449691","vendor":"Philips","description":"Hue White A60 Single bulb E27/B22","options":["[Circular]","[Circular]"]},"endpoint":"[Circular]","endpoints":"[Circular]","name":"0x0017880104b83bb0"}
            zigbee.0
            2025-05-04 12:56:04.222	info	Unable to disable LED, unsupported function.
            zigbee.0
            2025-05-04 12:56:04.222	debug	Network parameters: panID=6754 channel=11 extendedPanID=dddddddddddddddd
            zigbee.0
            2025-05-04 12:56:04.222	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"ConBee2/RaspBee2","meta":{"transportrev":0,"product":0,"majorrel":38,"minorrel":120,"maintrel":0,"revision":"0x26780700"}}
            zigbee.0
            2025-05-04 12:56:03.997	info	Starting Zigbee-Herdsman
            zigbee.0
            2025-05-04 12:56:03.997	debug	Starting zigbee-herdsman...
            zigbee.0
            2025-05-04 12:56:03.996	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
            zigbee.0
            2025-05-04 12:56:03.994	debug	Backup /opt/iobroker/iobroker-data/zigbee_0/backup_2025_05_04-12_56_03.tar.gz success
            zigbee.0
            2025-05-04 12:56:03.978	info	Starting Adapter npm ...
            zigbee.0
            2025-05-04 12:56:03.977	info	--- creating device debug ---
            zigbee.0
            2025-05-04 12:56:03.976	info	delete old Backup files. keep only last 10
            zigbee.0
            2025-05-04 12:56:03.971	info	--> transmitPower : normal
            zigbee.0
            2025-05-04 12:56:03.968	info	init localConfig
            zigbee.0
            2025-05-04 12:56:03.959	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.0, js-controller: 7.0.6
            zigbee.0
            2025-05-04 12:56:03.888	debug	Plugin sentry Do not initialize Plugin (enabled=false)
              AlexHaxe @Horst Böttcher last edited by
              @horst-böttcher said in Tester für Zigbee Adapter 2.0.x gesucht:
              @homoran Ich weiss ja nicht was ich zeigen soll aber
              f1fe6e34-c0c1-4ef5-9eb3-581009b66b5f-image.png d6f9feb1-9d05-46c1-8670-6144088a960c-image.png
              wurde mal versucht die Teile über die Kacheln neu zu konfigurieren?
              • Horst Böttcher
                Horst Böttcher @AlexHaxe last edited by
                @alexhaxe ja
                  @alexhaxe ja
                  erfolgreich? Timeout? Fehlermeldung im Log?
                  • Horst Böttcher
                    Horst Böttcher @AlexHaxe last edited by Horst Böttcher
                    @alexhaxe leiner ohne erfolg und ohne fehler meldung
                    ich glaub ich werde mal das ganze netzwerk neumachen 😞
                      Flugschüler last edited by
                      Ich habe das Gerät gekauft. Die Datenpunkte aktuallisieren sich exakt alle 2 Minuten. Kann mir vielleicht einer sagen wie ich den aktuallisierungszeitraum verkürtzen kann?
                      Ich habe gelesen man kann bei dem datenpunkt send_payload z.b. das hier eingeben {"update_frequency":5} hab ich versucht, aber funktioniert nicht.
                        Homoran Global Moderator Administrators @Flugschüler last edited by Homoran
                        @flugschüler sagte in Tester für Zigbee Adapter 2.0.x gesucht:
                        heisst?
                        Was steht denn jetzt im entsprechenden Datenpunkt?
                        https://www.zigbee2mqtt.io/devices/SPM02V3.html#update-frequency-numeric
                          Flugschüler @Homoran last edited by Flugschüler
                          {"update_frequency": 5} das steht im Datenpunkt. Er sollte jetzt alle 5 Sekunden aktuallisieren. Macht er aber nicht.
                            in welchem?
                            laut der verlinkten Anleitung müsste es einen entsprechenden Datenpunkt geben
                            Update frequency (numeric)
                            Update frequency. Value can be found in the published state on the update_frequency property.
                              Ja genau, in dem steht es drin.
                                bitte zeigen
                                nach meinem Verständnis hat da nur die 5 drin zu stehen
                                  Entschuldigung war eine Falschmeldung. Es steht in send_payload.Screenshot 2025-05-07 190430.pngScreenshot 2025-05-07 190710.png
                                  Wenn ich drauf klicke sieht das so aus.
                                  Asgothian Homoran 2 Replies Last reply Reply Quote 0
                                  • Asgothian
                                    Asgothian Developer @Flugschüler last edited by
                                    @flugschüler Was erscheint im Log nachdem du den Datenpunkt aktualisiert hast ?
                                      hattest du bestätigt angehakt beim Senden?
                                        Flugschüler @Asgothian last edited by Homoran
                                        @asgothian
                                        Send command to 0xe406bffffefc4c1c failed with no error code (undefined)
                                          Nein.
                                          Wenn ich auf bestädigt anhake kommt das im log.
                                          Device query for '0xa4c1380a33a809b7' done
                                          • Asgothian
                                            @asgothian
                                            Wilkommen bei dem Wahnsinn der sich TuYa Nennt:
                                            • was gleich aussieht meldet sich nicht gleich an
                                            • was sich gleich anmeldet funktioniert nicht gleich
                                            • was unterschiedlich aussieht meldet sich vielleicht gleich an
                                            • ob / wie es funktioniert ist lotto.
                                            Die Meldung bedeutet das das System die Nachricht akzeptiert hat - es gibt im ZHC das Schlüsselwort update_frequency. Aber das Gerät beantwortet die Nachricht nicht. Wenn es nicht reagiert geht die Meldung ggf. ins Nirvana, sprich, die Firmware deines Gerätes verweigert die Nachricht.
                                            A.
                                            zigbee 2.0.1
                                            50
                                            525
                                            73403
