    4. [Blockly] Sonnenaufgang mit Tradfri
      Linedancer last edited by
      So,
      ich hab mein Script mal auf "Trigger by Timer" umgebaut.
      Export:
      <xml xmlns="http://www.w3.org/1999/xhtml"><block type="schedule" id="dxUTBqgrkFKZ]~k5IBBn" x="37" y="14"><field name="SCHEDULE">* * * * </field>
      <statement name="STATEMENT"><block type="controls_if" id="xTBHY%{rxf9+eGe!V+dV"><mutation elseif="1"></mutation>
      <value name="IF0"><block type="time_compare" id="Swj{fYmoBc1)_OMD0zCC"><mutation end_time="false"></mutation>
      <field name="OPTION">>=</field>
      <field name="START_TIME">06:30</field></block></value>
      <statement name="DO0"><block type="controls_if" id="mZ3DcMgfulL
      4h}~Xh8."><value name="IF0"><block type="logic_compare" id="Pnd|S|xJKjmf9p[1H%@"><field name="OP">EQ</field> <value name="A"><block type="get_value" id="kH^tzcB|x-=oHB/O^"><field name="ATTR">val</field>
      <field name="OID">javascript.0.SysVar.SV_Anwesenheit_Gerhard</field></block></value>
      <value name="B"><block type="logic_boolean" id="bBM2616pU1CV2OITas8P"><field name="BOOL">TRUE</field></block></value></block></value>
      <statement name="DO0"><block type="variables_set" id=")0+[:0OUzQO%hy#weso"><field name="VAR">Level</field> <value name="VALUE"><block type="math_arithmetic" id="QR|/N}C|z6,iA,fB)36|"><field name="OP">MINUS</field> <value name="A"><shadow type="math_number" id="|_*jOh}pjCIOT.N,gW#p"><field name="NUM">1</field></shadow> <block type="math_arithmetic" id="r]{hc/J~PL#Z8DFnll^l"><field name="OP">MULTIPLY</field> <value name="A"><shadow type="math_number" id=";u#12~+(|F@GpGKv1z"><field name="NUM">-2.5</field></shadow> <block type="time_get" id="4j|R#D*0w2qN,tpauBiX"><mutation format="false" language="false"></mutation> <field name="OPTION">mid</field></block></value> <value name="B"><shadow type="math_number" id="ZBPrfBpqKeP4B3=eW4iB"><field name="NUM">1.6667</field></shadow></value></block></value> <value name="B"><shadow type="math_number" id="jpiM!Kd1NiyqzZugVUY"><field name="NUM">650</field></shadow></value></block></value>
      <next><block type="control" id="6=(~l;}%6PNSIf6VW3IL"><mutation delay_input="false"></mutation>
      <field name="OID">hue.0.Philips_hue.Couch_Boden.level</field>
      <value name="VALUE"><block type="variables_get" id="n7Mo4EhAkk^yy39w[Rpu"><field name="VAR">Level</field></block></value></block></next></block></statement></block></statement>
      <value name="IF1"><block type="time_compare" id="._Y2MEEw^XB(?i0j(P#l"><mutation end_time="false"></mutation>
      <field name="START_TIME">07:30</field></block></value>
      <statement name="DO1"><block type="control" id="(SGd}elcZLUYo,x=xY2F"><mutation delay_input="false"></mutation>
      <value name="VALUE"><block type="math_number" id="2H2:1}!ZdBGKxx[he*d)"><field name="NUM">0</field></block></value></block></statement></block></statement></block></xml>
      Die lineare Gleichung basiert auf:
      Zeit Level
      06:30 0
      07:30 100
      • AlCalzone
        Ich steuere bei meinen die Farbtemperatur abhängig von Sonnenaufgang und Sonnenuntergang. Ist aber JavaScript und nicht blockly. Kann dir den Code morgen gerne Posten wenn ich daheim bin.
        Gesendet von unterwegs
          @AlCalzone:
          Kann dir den Code morgen gerne Posten wenn ich daheim bin. `
          Bin mit dem Sonnenaufgang auch schon weiter. Ich wollte mit Hue und Sat arbeiten, das hat aber nur geflackert, wenn die Änderungen zu oft kamen. Dann kam noch ein coap Error dazu.
          Muss mal mit der Transition Time und ggf. Mit virtuellen Gruppen versuchen, wenn ich wieder Zeit habe.
          Abgesehen davon ändert sich je nach Farbe auch die Helligkeit bei der RGB birne enorm.
          Ich darf also nur in einem bestimmten Spektrum bkeiben.
          Gruß Rainer
          • AlCalzone
            Ich aktualisiere jede Minute den Wert mit einer transitiontime von 10s. Das reicht für einen unmerkbaren Übergang. Was für einen coap Fehler meinst du?
              @AlCalzone:
              Was für einen coap Fehler meinst du? `
              :oops: Wusste ich nicht mehr auswendig.
              Habe die logdatei von gestern durchsucht:
              `2018-01-26 19:57:32.127  - [31merror[39m: tradfri.0 unhandled promise rejection: CoapClient was reset
              2018-01-26 19:57:32.128  - [31merror[39m: tradfri.0 unhandled promise rejection: CoapClient was reset
              2018-01-26 19:57:32.128  - [31merror[39m: tradfri.0 unhandled promise rejection: CoapClient was reset[/code]`
              Allerdings hatte ich zum Testen den Turbo aktiviert -> alle 200msec!
              Habe es jetzt wieder runtergesetzt - muss wie oben schon gesagt nochmal mit der transition Time versuchen:
               ![144_sonnenaufgang011.jpg](/assets/uploads/files/144_sonnenaufgang011.jpg)
              Rainer
              • AlCalzone
                Ah, das kommt bei nem verbindungsabbruch. Vermutlich wollte das Gateway nicht mehr deine Spielchen mitmachen [emoji23]
                  @AlCalzone:
                  Vermutlich wollte das Gateway nicht mehr deine Spielchen mitmachen `
                  Meinst du? Kann ich gar nicht verstehen 😄
                  Aber das wird es sein.
                  `2018-01-26 19:56:46.427  - [31merror[39m: tradfri.0 > stack: Error: Retransmit counter exceeded[/code]`
                  Rainer
                  • AlCalzone
                    Hier das versprochene Skript:
                    // Tradfri-Farbtemperatur in Abhängigkeit der Uhrzeit festlegen
                    ! const MIN_TEMP = 0; // Minimale Farbtemperatur (kaltes Licht)
                    const MAX_TEMP = 100; // Maximale Farbtemperatur (warmes Licht)
                    // wieviele Stunden vor(-)/nach(+) sunrise soll der Übergang auf kalte Farbtemperatur starten/enden?
                    const sunriseStartOffset = hours2ms(0);
                    const sunriseEndOffset = hours2ms(2);
                    // wieviele Stunden vor(-)/nach(+) sunset soll der Übergang auf warme Farbtemperatur starten/enden?
                    const sunsetStartOffset = hours2ms(-2);
                    const sunsetEndOffset = hours2ms(0);
                    ! let prevTemp;
                    ! schedule("* * * * *", colorChange); // jede Minute neue Farbtemperatur berechnen
                    colorChange(); // außerdem beim Skriptstart
                    ! function colorChange() {
                    // aktuelle Uhrzeiten berechnen, damit wir nicht vom Datum abhängig sind
                    const sunrise = getAstroDate("sunrise");
                    const sunriseStart = new Date(sunrise.getTime() + sunriseStartOffset).getTime();
                    const sunriseEnd = new Date(sunrise.getTime() + sunriseEndOffset).getTime();
                    const sunset = getAstroDate("sunset");
                    const sunsetStart = new Date(sunset.getTime() + sunsetStartOffset).getTime();
                    const sunsetEnd = new Date(sunset.getTime() + sunsetEndOffset).getTime();
                    const now = new Date().getTime();
                    // neue Farbtemperatur berechnen
                    let targetTemp;
                    if (now < sunriseStart || now > sunsetEnd) {
                        // warmes Licht in der Nacht
                        targetTemp = MAX_TEMP;
                    } else if (now >= sunriseStart && now <= sunriseEnd) {
                        // sanfter Übergang auf kaltes Licht am Morgen
                        targetTemp = interpolate(now, sunriseStart, sunriseEnd, MAX_TEMP, MIN_TEMP);
                    } else if (now > sunriseEnd && now < sunsetStart) {
                        // kaltes Licht am Tag
                        targetTemp = MIN_TEMP;
                    } else if (now >= sunsetStart && now <= sunsetEnd) {
                        // sanfter Übergang auf warmes Licht am Abend
                        targetTemp = interpolate(now, sunsetStart, sunsetEnd, MIN_TEMP, MAX_TEMP);
                    ! // und diese festlegen, wenn sich etwas geändert hat
                    if (targetTemp !== prevTemp) {
                    prevTemp = targetTemp;
                    setState("tradfri.0.G-195804.transitionDuration", 10);
                    setState("tradfri.0.G-195804.colorTemperature", targetTemp);
                    ! // interpoliert linear zwischen zwei Punkten
                    function interpolate(x, x1, x2, y1, y2) {
                    return Math.round(y1 + (y2 - y1) / (x2 - x1) * (x - x1));
                    ! function hours2ms(hours) {
                    return hours * 3600 * 1000;
                    Ich hoffe mit den Kommentaren ist es halbwegs selbsterklären, selbst wenn es kein Blockly ist. Die Idee ist, dass in einem Zeitrahmen um den Sonnenaufgang die Farbtemperatur langsam auf kalt wechselt und in einem Zeitrahmen um Sonnenuntergang wieder auf warm. Die Intervalle konfigurierst du am Anfang.
                      C1500 last edited by
                      Servus,
                      ich versuch mich auch schon sehr lange an einer guten Lösung um das Aufwach angenehmer zu machen.
                      Gibt es denn beim Tradfri die Möglichkeit die Farbe "weich" bzw. "fadend" zu wechseln, das er also in einer bestimmbaren Zeit von blau nach rot wechselt und nicht abrupt?
                      Für MiLight gab es bei FHEM die "Queue"
                      Dort sah es als HSV so aus:
                      set led HSV 240,100,0;
                      set led HSV 240,20,80 600 q;
                      set led HSV 0,20,80 120 q;
                      set led HSV 0,80,100 120 q;
                      set led HSV 55,40,100 300 q;
                      set led HSV 55,0,100 300 q
                      Oder als Beispiel folgende RGB Werte:
                      0,0,0
                      26,3,94
                      70,12,244
                      151,12,244
                      244,12,140
                      244,12,66
                      244,120,12
                      244,229,12
                      237,244,176
                      255,255,255
                      Hier zu finden: https://forum.fhem.de/index.php/topic,4 … 98113.html
                      Mit dem Homematic RGB (HM-LC-RGBW-WM) sind leider keinerlei Farbverläufe möglich.
                      Den MiLight Adapter von ioBroker hab ich noch nicht ausprobiert.
                      Und die Ikea Lampen hab ich (noch) nicht.
                      Bin gespannt wie es weiter geht....
                      Gruß Peer
                        @C1500:
                        Gibt es denn beim Tradfri die Möglichkeit die Farbe "weich" bzw. "fadend" zu wechseln `
                        Dafür ist eigentlich der Punkt "Transition Time".
                        Ob das mit der Farbe auch geht wollte ich am Wochenende testen, bin aber nicht dazu gekommen.
                        Rainer
                          Servus Rainer,
                          Das klingt schon mal vielversprechend.
                          Dann bleibt noch die Frage ob der HSV Farbkreis abgefahren wird oder der Wechsle direkt also "durch" den Farbkreis geht.
                          Außenrum Abfahren wäre dann ziemlich doof.
                          Gruß Peer
                          • AlCalzone
                            @Homoran:
                            Ob das mit der Farbe auch geht wollte ich am Wochenende testen, bin aber nicht dazu gekommen. `
                            Na, ich hoffe doch. Mit Helligkeit und Farbtemperatur (Weißspektrum) gehts. Bei einer älteren Version hab ich dafür die X/Y-Farbe missbraucht, auf die für RGB auch zurück gegriffen wird.
                            @C1500:
                            Dann bleibt noch die Frage ob der HSV Farbkreis abgefahren wird oder der Wechsle direkt also "durch" den Farbkreis geht. `
                            Wenn du H, S, V einzeln setzt, bin ich mir nicht sicher, wie das Gateway es handhabt. Du kannst aber H/S/V in RGB umrechnen, dann müsste alles gleichzeitig interpoliert werden.
                            Alternativ lassen sich mit https://github.com/AlCalzone/iobroker.tradfri/#sending-custom-coap-packets mehrere Eigenschaften gleichzeitig setzen, da müsste ich daheim nochmal nachschauen wie das payload auszusehen hat.
                              @AlCalzone:
                              Mit Helligkeit und Farbtemperatur (Weißspektrum) gehts. `
                              Bestätigt! Aber eben nur das 😉
                              @AlCalzone:
                              Wenn du H, S, V einzeln setzt, bin ich mir nicht sicher, wie das Gateway es handhabt. `
                              Bescheuert! es blinkt und blitzt und ändert tlw. abrupt die Farben um sofort wieder zurückzuspringen 😞
                              Ich dachte es sei eine gute Idee mit diesen vorhandenen Punkten zu arbeiten, aber das kommt nicht so gut bei der besseren Hälfte an.
                              Du meinst also mit einer längeren transition time (was ist da eigentlich das Maximum?) könnte ich sanft von FF0000 nach 0000FF wechseln?
                              Rainer
                              • AlCalzone
                                @Homoran:
                                Bescheuert! es blinkt und blitzt und ändert tlw. abrupt die Farben um sofort wieder zurückzuspringen 😞 `
                                Uggghhh. Ich schick dir heute Abend mal ein Code-Schnipsel. Damit bitte mal testen, ob der Übergang sanfter verläuft.
                                Wenn das funktioniert, kann ich eine kleine Verbesserung einbauen.
                                @Homoran:
                                Du meinst also mit einer längeren transition time (was ist da eigentlich das Maximum?) könnte ich sanft von FF0000 nach 0000FF wechseln? `
                                Sollte möglich sein. Ich hab nicht explizit getestet, wo das Limit liegt. Ab nem gewissen Punkt lässt es sich auch nicht wirklich feststellen wo das Ende ist. Rein theoretisch: Die maximalen Werte (u.a. bei Hue/Sat intern verwendet) scheinen 65279 zu sein (warum dieser Wert - k.A.). Das würde 6527,9 Sekunden oder 1,8h entsprechen.
                                EDIT: Kommando zurück… Hab gerade mal selbst getestet. Zwei Eigenschaften gleichzeitig lassen sich nicht animieren.
                                Ich sehe 2 Optionen:
                                1. Nur color animieren
                                2. Im Skript in einem Intervall meherer Werte selbst interpolieren. Dabei kleine Schritte benutzen, damit es nicht auffällt; nicht zu schnell, damit das Gateway nicht aussteigt; und transitionTime = 0!
                                  Ich habe mal was probiert:
                                  leider passiert (fast) nichts:
                                  javascript.0	2018-01-31 16:25:30.626	info	script.js.Sonnenuntergang: Die Farbe ist f5faf6%
                                  javascript.0	2018-01-31 16:25:30.625	info	script.js.Sonnenuntergang: Die Helligkeit ist 100%
                                  javascript.0	2018-01-31 16:25:00.624	info	script.js.Sonnenuntergang: Die Farbe ist f5faf6%
                                  javascript.0	2018-01-31 16:25:00.624	info	script.js.Sonnenuntergang: Die Helligkeit ist 100%
                                  javascript.0	2018-01-31 16:24:30.624	info	script.js.Sonnenuntergang: Die Farbe ist f5faf6%
                                  javascript.0	2018-01-31 16:24:30.623	info	script.js.Sonnenuntergang: Die Helligkeit ist 100%
                                  javascript.0	2018-01-31 16:24:00.623	info	script.js.Sonnenuntergang: Die Farbe ist f5faf6%
                                  javascript.0	2018-01-31 16:24:00.622	info	script.js.Sonnenuntergang: Die Helligkeit ist 100%
                                  javascript.0	2018-01-31 16:23:30.621	info	script.js.Sonnenuntergang: Die Farbe ist ffe0b5%
                                  javascript.0	2018-01-31 16:23:30.621	info	script.js.Sonnenuntergang: Die Helligkeit ist 1%
                                  nach dem ersten Umschalten bleibt es.
                                  Habe jetzt erst dein EDIT gelesen -> siehe nächsten Post
                                  Rainer
                                    @AlCalzone:
                                    2. Im Skript in einem Intervall meherer Werte selbst interpolieren. Dabei kleine Schritte benutzen, damit es nicht auffällt; nicht zu schnell, damit das Gateway nicht aussteigt; und transitionTime = 0! `
                                    Hier mein erster Versuch:
                                    Und hier blitzt immer wieder der "Endzustand" zwischendrin auf.
                                    Rainer
                                    • AlCalzone
                                      @Homoran:
                                      Und hier blitzt immer wieder der "Endzustand" zwischendrin auf. `
                                      Sieht erst mal logisch aus. Steuerst du eine Lampe oder Gruppen? Wenn ersteres, fürchte ich dass das Zurücksetzen der TransitionTime dir einen Strich durch die Rechnung macht. Probiers mal an einer virtuellen oder echten Gruppe.
                                        Im Moment ist es in beiden Fällen die Lampe (tradfri.0.L-65539)
                                        Ich teste das jetzt mal bei dem Sonnenuntergang erst mit der G- und dann mit der VG-
                                        Bis später
                                        Rainer
                                          Habe jetzt mit Lampe, Gruppe und virtueller Gruppe getestet:
                                          Zur Sicherheit habe ich noch Verzögerungen eingebaut (ich hoffe das bewirkt nicht das Gegenteil des gewünschten)
                                          Lampe:
                                          Die color RGB geht auf -> ffbb52 und dabei bleibt es
                                          die Helligkeit geht auf 100% und dabei bleibt es auch.
                                          javascript.0	2018-01-31 17:38:30.054	info	script.js.Sonnenuntergang: Die Farbe ist ffbb52%
                                          javascript.0	2018-01-31 17:38:30.053	info	script.js.Sonnenuntergang: Die Helligkeit ist 100%
                                          Gruppe:
                                          es passiert gar nichts
                                          virtuelle Gruppe:
                                          ist identisch wie bei der Lampe
                                          Rainer
                                          • AlCalzone
                                            Das Skript macht so leider keinen Sinn.
                                            Überlappende Übergänge gehen nicht, das Gateway kann immer nur einen Wert animieren. Und die Endwerte werden soweit ich mich richtig erinnere auch erst am Schluss zurück gemeldet, d.h. dein Log läuft ins Leere.
                                            Hier mal was ich meinte mit "selbst animieren":
                                            So geht ein "fast" flüssiger Übergang von dunkel+kalt auf hell+warm mit einer Weißspektrumlampe.
                                            Für RGB musst du etwas mehr Logik zum Berechnen der Zwischenwerte spendieren als ("erhöhe um 1").
                                            Edit: Holy shit, das Rumgeklicke bis so ein einfaches Skript zusammengebaut ist :shock:
                                            14271
