    3. Einsteigerfragen
    4. Warnungen im Log - was bedeuten die ?
    • dogfight76
      dogfight76 @Thomas Braun last edited by Homoran
      wenn ich das Log herunterlade dann erscheint die Chronologie so herum:
      2025-05-09 18:08:54.344 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.23" not found (3)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:08:54.345 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:08:54.346 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:08:54.346 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.23" not found (3)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:08:54.347 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:10:59.436 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.22" not found (3)
      2025-05-09 18:10:59.439 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
      2025-05-09 18:10:59.439 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:10:59.439 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:10:59.440 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:10:59.440 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:10:59.440 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.22" not found (3)
      2025-05-09 18:10:59.442 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
      2025-05-09 18:10:59.443 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:10:59.444 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:10:59.444 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:10:59.444 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:20:24.537 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.21" not found (3)
      2025-05-09 18:20:24.539 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
      2025-05-09 18:20:24.540 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:20:24.540 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:20:24.541 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:20:24.541 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      2025-05-09 18:20:24.541 - warn: javascript.0 (788) getState "0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.21" not found (3)
      2025-05-09 18:20:24.543 - warn: javascript.0 (788) at Object. (script.js.common.Meine_Geraete.Heizung.Akt_VL:10:137)
      2025-05-09 18:20:24.544 - warn: javascript.0 (788) at Object.callback (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1452:38)
      2025-05-09 18:20:24.544 - warn: javascript.0 (788) at Object.stateChange (/opt/iobroker/node_modules/iobroker.javascript/main.js:645:29)
      2025-05-09 18:20:24.544 - warn: javascript.0 (788) at Immediate._onImmediate (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:11048:62)
      2025-05-09 18:20:24.545 - warn: javascript.0 (788) at processImmediate (node:internal/timers:483:21)
      Und die Einträge
      sind komisch weil die Heizkurve von -15 bis +20 Grad geht, weiß nicht was da nach Temperaturen oberhalb von 20 Grad sucht.
        paul53 @dogfight76 last edited by paul53
        @dogfight76 sagte: weiß nicht was da nach Temperaturen oberhalb von 20 Grad sucht.
        Dann prüfe mal die Schleife im Skript.
        Oder hast du bei der ID-Konstruktion keine Begrenzung vorgesehen?
        dogfight76 1 Reply Last reply Reply Quote 0
        • dogfight76
          dogfight76 @paul53 last edited by
          Das Script der Heizkurve ist das:
          Heizkurve.txt
            Homoran Global Moderator Administrators @dogfight76 last edited by
            @dogfight76 da muss vorher ein ERROR stehen
            • dogfight76
              dogfight76 @Homoran last edited by
              @homoran Ist kein "Error" Eintrag im Protokoll, nur die "normalen" Meldungen und die "warn"
                @dogfight76 sagte in Warnungen im Log - was bedeuten die ?:
                gar keiner, oder nur nicht bei javascript?
                  @dogfight76
                  Das Thema hatten wir doch schon!!
                  https://forum.iobroker.net/post/1262976
                  mcm1957 dogfight76 2 Replies Last reply Reply Quote 0
                  • dogfight76
                    Kein einziger Error !
                    Aber immer die gleichen warn:
                    Der Eintrag verweist auf das Script: Akt_VL , richtig ?
                    2025-05-09 18:20:24.539 warn at Object.<anonymous> (script.js.common.Meine_Geraete.Heizung.Akt_VL:9:21)
                    Auf die Zeile 9 in dem Script ?
                    var Temp;
                    on({ id: [].concat(['mqtt.0.Waermepumpe.main.Outside_Temp']).concat(['0_userdata.0.Waermepumpe.Empf_VL_Temp']).concat(['mqtt.0.Waermepumpe.commands.SetZ1HeatRequestTemperature']).concat(['0_userdata.0.Waermepumpe.Heizkurve.Neigung']).concat(['0_userdata.0.Waermepumpe.Parallelverschiebung']).concat(['0_userdata.0.Waermepumpe.Nachtabsenkung']), change: 'ne' }, async (obj) => {
                      if (getState('0_userdata.0.Waermepumpe.Nachtabsenkung_EinAus').val == false) {
                        if (!(getState('mqtt.0.Waermepumpe.commands.SetOperationMode').val == 4)) {
                          Temp = '0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.' + String(getState('mqtt.0.Waermepumpe.main.Outside_Temp').val);
                          console.debug(getState(Temp).val);
                          setState('mqtt.0.Waermepumpe.commands.SetZ1HeatRequestTemperature' /* mqtt.0.Waermepumpe.commands.SetZ1HeatRequestTemperature */, getState(Temp).val);
                    Da steht:
                    Aber was hat das (wenn ich überhaupt richtig liege mit meiner Vermutung) mit dem Ordner der VL-Temperaturen in dem Pfad 0_userdat_0........... zu tun ?
                    • mcm1957
                      mcm1957 @Homoran last edited by
                      Seh ich das falsch oder bedeuten die Meldung
                      nicht ganz klar:
                      Der State 0_userdata.0.Waermepumpe.Heizkurve.VL_Temp.23 wird nicht gefunden und zwar vom Script an der Stelle script.js.common.Meine_Geraete.Heizung.Akt_VL:9:2 ?
                      dogfight76 1 Reply Last reply Reply Quote 1
                      • dogfight76
                        Da hast du recht, aber weil da soviel durcheinader gekommen ist dachte ich das ich es einfacher halt.
                        Sonst gerne einfach da anhängen, wenn ein Admin das kann. Danke
                        • dogfight76
                          dogfight76 @mcm1957 last edited by
                          @mcm1957
                          Darum habe ich die Zeile des Script Akt_VL ja gepostet. Weil ich das auch so verstehe.....
                          • mcm1957
                            mcm1957 @dogfight76 last edited by mcm1957
                            @dogfight76
                            Und was ist dann noch das Problem?
                            Gibts den State? Oder gibts ihn nicht?
                            Die Zeilen mit "at" sind ein Traceback damit man die entsprechende Stelle im Code finden kann.
                            • mcm1957
                              mcm1957 @mcm1957 last edited by mcm1957
                              @mcm1957
                              Am Ende der ZEILE 9 hast du ein gestState und das versucht von 0_userdata_0 zu lesen. SChau mal wie TEMP zusammengesetzt wird (2 Zeilen weiter oben)
                              und der debug Output versucht das auch. Bei mehr als 21 Grad außentremperatur dürftem die 0_userdate_0 Werte fehlen. Oder du musst die Außentemperatur begrenzen ...
                                @dogfight76 sagte: Das Script der Heizkurve ist das:
                                Die Variable Temp, die eine ID enthält, hat keine Begrenzung, sondern verwendet direkt den Wert der Außentemperatur, die zudem auch noch in ganzen Grad auflösen muss.
                                • dogfight76
                                  @mcm1957 said in Warnungen im Log - was bedeuten die ?:
                                  Ok, weil ich für die Steuerung über die Heizkurve nur die Temp von -15 bis +20 Grad benötige, (weil ab 21 Grad Aussentemp schaltet die Wärmepumpoe ja ab) würde die Begrenzung ab 21 Grad ja helfen damit die Warn-Meldung nicht mehr erscheinen, weil im Pfad:
                                  dann nicht mehr nach Temp oberhalb von 20 Grad gesucht werden, Korrekt ?
                                  Und die warn-Meldungen tauchen nicht mehr auf ?!
                                  • dogfight76
                                    @paul53 said in Warnungen im Log - was bedeuten die ?:
                                    Wie bekomme ich das Script die Begrnezung rein ?
                                    • mcm1957
                                      @dogfight76
                                      Die (Einzahl) Warnmeldung besagt dass du versuchst einen State zu lesen den es nicht gibt. Die Zeilen mit at sind untrennbare Fortsetzungszeilen der Warnmeldung ohne 'at' die dazu dienen die betreffende Codezeile zu identifizieren.
                                      Wenn du dein Script so korrigierts dass es keine nicht existenten State versucht zu lsene ist die getStte Warnung und die nachfolgenden at's weg.
                                        @dogfight76 sagte: Wie bekomme ich das Script die Begrnezung rein ?
                                        Z.B. so:
                                        • dogfight76
                                          Der gesamte Baustein vom Screenshot muss an welche Stelle in meinem Script ?
                                            @dogfight76 sagte: muss an welche Stelle in meinem Script ?
                                            Ich habe nur die Bildung von Temp oberhalb des "steuere" mit der zusätzlichen Variablen AT angepasst.
                                            EDIT: Der Teil zur Ermittlung der aktuellen VL-Temperatur gehört nicht in die Schleife. Besser so:
                                            4494
