    4. [Aufruf] modbus 1.1.0 testen (Serialport upgrade)
    • wendy2702
      wendy2702 last edited by
      Ne Idee warum ich den Smartmeter Adapter in der GIT Auswahl auf meinem Slave nicht angezeigt bekomme obwohl die Verion 1.0.0 dort installiert ist?
      EDIT: hab manuell per Link installiert. Jetzt noch Modbus und dann mal abwarten
      Modbus installiert… weiß allerdings noch nicht was ich von dem log halten soll :shock:
      iobroker 2018-01-26 15:28:57.460 info exit 0
      iobroker 2018-01-26 15:28:57.443 error Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter
      iobroker 2018-01-26 15:28:57.359 info npm ERR! Please include the following file with any support request:npm ERR! /home/npm-debug.log
      iobroker 2018-01-26 15:28:57.353 info
      iobroker 2018-01-26 15:28:54.218 info npm ERR! There is likely additional logging output above.
      iobroker 2018-01-26 15:28:54.218 info npm ERR! npm owner ls serialport
      iobroker 2018-01-26 15:28:54.218 info npm ERR! Or if that isn't available, you can get their info via:
      iobroker 2018-01-26 15:28:54.218 info npm ERR! npm bugs serialport
      iobroker 2018-01-26 15:28:54.218 info npm ERR! You can get information on how to open an issue for this project with:
      iobroker 2018-01-26 15:28:54.218 info npm ERR! node-pre-gyp install --fallback-to-build
      iobroker 2018-01-26 15:28:54.218 info npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
      iobroker 2018-01-26 15:28:54.206 info npm ERR! This is most likely a problem with the serialport package,
      iobroker 2018-01-26 15:28:54.206 info npm ERR! Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.
      iobroker 2018-01-26 15:28:54.191 info npm ERR!
      iobroker 2018-01-26 15:28:54.191 info npm ERR! Exit status 1
      iobroker 2018-01-26 15:28:54.191 info npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
      iobroker 2018-01-26 15:28:54.191 info npm ERR! code ELIFECYCLE
      iobroker 2018-01-26 15:28:54.191 info npm ERR! npm v2.15.11
      iobroker 2018-01-26 15:28:54.191 info npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.modbus/tarball/master" "--production" "--prefix" "/opt/iobroker"npm ERR! node v4.8.7
      iobroker 2018-01-26 15:28:54.181 info Linux 4.9.35-v7+
      iobroker 2018-01-26 15:28:54.174 info ERR!
      iobroker 2018-01-26 15:28:54.168 info
      iobroker 2018-01-26 15:28:54.162 info npm
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! not ok
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! node-pre-gyp -v v0.6.32
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! node -v v4.8.7
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! System Linux 4.9.35-v7+
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:862:16)
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! stack at emitTwo (events.js:87:13)
      iobroker 2018-01-26 15:28:53.350 info node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.
      iobroker 2018-01-26 15:28:53.324 info ERR! build error
      iobroker 2018-01-26 15:28:53.323 info node-pre-gyp
      iobroker 2018-01-26 15:28:53.323 info gyp ERR! not ok
      iobroker 2018-01-26 15:28:53.323 info gyp ERR! node -v v4.8.7gyp ERR! node-gyp -v v3.4.0
      iobroker 2018-01-26 15:28:53.310 info gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
      iobroker 2018-01-26 15:28:53.310 info gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmod
      iobroker 2018-01-26 15:28:53.310 info gyp ERR! System Linux 4.9.35-v7+
      iobroker 2018-01-26 15:28:53.310 info gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:211:12)
      iobroker 2018-01-26 15:28:53.310 info gyp ERR! stack at ChildProcess.emit (events.js:172:7)
      iobroker 2018-01-26 15:28:53.310 info gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13)
      iobroker 2018-01-26 15:28:53.295 info gyp ERR! stack Error: make failed with exit code: 2
      iobroker 2018-01-26 15:28:53.272 info ERR! build error
      iobroker 2018-01-26 15:28:53.266 info
      iobroker 2018-01-26 15:28:53.249 info gyp
      iobroker 2018-01-26 15:28:53.227 info make: *** No rule to make target '../.node-gyp/4.8.7/include/node/common.gypi', needed by 'Makefile'. Schluss.
      iobroker 2018-01-26 15:28:45.356 info WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.7"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modb
      iobroker 2018-01-26 15:28:45.352 info
      iobroker 2018-01-26 15:28:45.348 info gyp
      iobroker 2018-01-26 15:28:42.406 info node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.7 (node-v46 ABI) (falling back to source compile with node-gyp)
      iobroker 2018-01-26 15:28:42.402 info node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz
      iobroker 2018-01-26 15:28:03.216 info gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
      iobroker 2018-01-26 15:28:03.214 info WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.7"
      iobroker 2018-01-26 15:28:03.211 info
      iobroker 2018-01-26 15:28:03.207 info gyp
      iobroker 2018-01-26 15:28:00.882 info EACCES: permission denied, access '/root/.npm'
      iobroker 2018-01-26 15:28:00.880 info install
      iobroker 2018-01-26 15:28:00.878 info WARN
      iobroker 2018-01-26 15:28:00.876 info prebuild-install
      iobroker 2018-01-26 15:28:00.867 info looking for local prebuild @ prebuilds/serialport-v6.0.4-node-v46-linux-arm.tar.gz
      iobroker 2018-01-26 15:28:00.864 info info
      iobroker 2018-01-26 15:28:00.862 info prebuild-install
      iobroker 2018-01-26 15:28:00.839 info info begin Prebuild-install version 2.5.0
      iobroker 2018-01-26 15:28:00.837 info
      iobroker 2018-01-26 15:28:00.833 info prebuild-install
      iobroker 2018-01-26 15:26:27.915 info npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --prefix "/opt/iobroker" (System call)
      iobroker 2018-01-26 15:26:27.562 info install https://github.com/ioBroker/ioBroker.modbus/tarball/master
      iobroker 2018-01-26 15:26:26.099 info url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus
        apollon77 last edited by
        Passiert manchmal nach github installs oder so das die nicht in der liste sind. EInfach per URL installieren: https://github.com/Apollon77/ioBroker.smartmeter
        Log ist kooooomisch … auch weil da serialport 4.0.7 nochmal steht ...
        • wendy2702
          Never touch a running system…
          Habe gerade die Logausgabe für den Modbus Adapter von "Info" nach "Debug" gestellt. Nach dem Automatischen neustart des Adapters kommt jetzt das:
          pi@pi-iobroker:~ $ tail -f /opt/iobroker/log/iobroker.2018-01-26.log
          2018-01-26 17:08:53.301 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:09:04.374 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:09:15.585 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:09:26.621 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:09:37.814 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:09:48.672 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:09:59.653 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:10:10.310 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:10:20.970 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:10:31.471 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:10:42.021 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:10:52.626 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:11:02.764 - info: host.pi-iobroker object change system.adapter.modbus.3
          2018-01-26 17:11:02.779 - info: host.pi-iobroker stopInstance system.adapter.modbus.3
          2018-01-26 17:11:02.782 - info: host.pi-iobroker stopInstance system.adapter.modbus.3 killing pid 1366
          2018-01-26 17:11:02.806 - info: modbus.3 terminating
          2018-01-26 17:11:02.834 - info: host.pi-iobroker instance system.adapter.modbus.3 terminated with code 0 (OK)
          2018-01-26 17:11:03.114 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:11:05.303 - warn: host.pi-iobroker startInstance cannot find adapter "modbus". Try to install it... 1 attempt
          2018-01-26 17:11:05.304 - info: iobroker install modbus
          2018-01-26 17:11:09.013 - info: iobroker npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
          2018-01-26 17:11:13.677 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:11:24.280 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:11:34.994 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:11:42.787 - info: iobroker prebuild-install
          2018-01-26 17:11:42.794 - info: iobroker
          2018-01-26 17:11:42.799 - info: iobroker info begin Prebuild-install version 2.5.0
          2018-01-26 17:11:42.818 - info: iobroker prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.0.4-node-v46-linux-arm.tar.gz
          2018-01-26 17:11:42.832 - info: iobroker prebuild-install WARN install EACCES: permission denied, access '/root/.npm'
          2018-01-26 17:11:45.689 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:11:50.249 - info: iobroker gyp
          2018-01-26 17:11:50.253 - info: iobroker
          2018-01-26 17:11:50.255 - info: iobroker WARN
          2018-01-26 17:11:50.256 - info: iobroker
          2018-01-26 17:11:50.258 - info: iobroker EACCES
          2018-01-26 17:11:50.260 - info: iobroker user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.7"
          2018-01-26 17:11:50.262 - info: iobroker gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
          2018-01-26 17:11:56.452 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:12:07.645 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:12:18.879 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:12:30.063 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:12:40.985 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:12:52.059 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:12:58.993 - info: iobroker node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz
          2018-01-26 17:12:58.999 - info: iobroker node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.7 (node-v46 ABI) (falling back to source compile with node-gyp)
          2018-01-26 17:13:01.836 - info: iobroker gyp
          2018-01-26 17:13:01.839 - info: iobroker
          2018-01-26 17:13:01.842 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.7"gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/.node-gyp"
          ! 2018-01-26 17:13:03.021 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:13:06.395 - info: iobroker make: *** No rule to make target '../.node-gyp/4.8.7/include/node/common.gypi', needed by 'Makefile'. Schluss.
          2018-01-26 17:13:06.405 - info: iobroker gyp
          2018-01-26 17:13:06.410 - info: iobroker
          2018-01-26 17:13:06.412 - info: iobroker ERR! build error
          2018-01-26 17:13:06.425 - info: iobroker gyp ERR! stack Error: make failed with exit code: 2
          2018-01-26 17:13:06.426 - info: iobroker gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)
          2018-01-26 17:13:06.431 - info: iobroker gyp ERR! stack at emitTwo (events.js:87:13)gyp ERR! stack at ChildProcess.emit (events.js:172:7)
          ! 2018-01-26 17:13:06.438 - info: iobroker gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
          gyp ERR! not ok
          ! 2018-01-26 17:13:06.461 - info: iobroker node-pre-gyp ERR! build error node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release' (1)
          node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          node-pre-gyp ERR!
          2018-01-26 17:13:06.464 - info: iobroker cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
          2018-01-26 17:13:06.464 - info: iobroker node-pre-gyp ERR! node -v
          2018-01-26 17:13:06.466 - info: iobroker v4.8.7
          2018-01-26 17:13:06.467 - info: iobroker node-pre-gyp
          2018-01-26 17:13:06.468 - info: iobroker ERR!
          2018-01-26 17:13:06.470 - info: iobroker node-pre-gyp -v v0.6.32node-pre-gyp
          2018-01-26 17:13:06.471 - info: iobroker ERR!
          2018-01-26 17:13:06.472 - info: iobroker
          2018-01-26 17:13:06.475 - info: iobroker not ok
          2018-01-26 17:13:06.518 - info: iobroker npm
          2018-01-26 17:13:06.538 - info: iobroker ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.modbus" "--production" "--prefix" "/opt/iobroker"
          ! 2018-01-26 17:13:06.546 - info: iobroker npm
          2018-01-26 17:13:06.547 - info: iobroker ERR!
          2018-01-26 17:13:06.549 - info: iobroker node
          2018-01-26 17:13:06.550 - info: iobroker v4.8.7
          2018-01-26 17:13:06.552 - info: iobroker npm
          2018-01-26 17:13:06.552 - info: iobroker ERR!
          2018-01-26 17:13:06.565 - info: iobroker npm v2.15.11npm ERR! code ELIFECYCLE
          ! npm ERR! serialport@4.0.7 install: node-pre-gyp install --fallback-to-build
          npm ERR!
          ! 2018-01-26 17:13:06.567 - info: iobroker npm
          2018-01-26 17:13:06.571 - info: iobroker ERR! Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.npm ERR! This is most likely a problem with the serialport package,
          ! 2018-01-26 17:13:06.580 - info: iobroker npm ERR! not with npm itself.npm ERR! Tell the author that this fails on your system:
          ! 2018-01-26 17:13:06.586 - info: iobroker npm ERR! node-pre-gyp install --fallback-to-buildnpm ERR! You can get information on how to open an issue for this project with:
          npm ERR!
          ! 2018-01-26 17:13:10.036 - info: iobroker
          2018-01-26 17:13:10.042 - info: iobroker npm ERR! Please include the following file with any support request:npm ERR! /home/npm-debug.log
          ! 2018-01-26 17:13:10.078 - error: iobroker host.pi-iobroker Adapter directory "/opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus" does not exists
          2018-01-26 17:13:10.122 - error: iobroker Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json'
          2018-01-26 17:13:10.140 - info: iobroker exit 0
          2018-01-26 17:13:11.143 - warn: host.pi-iobroker startInstance cannot find adapter "modbus". Try to install it... 2 attempt
          2018-01-26 17:13:11.144 - info: iobroker install modbus
          2018-01-26 17:13:13.553 - info: iobroker npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
          2018-01-26 17:13:14.060 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:13:25.133 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:13:36.423 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:13:47.869 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:13:58.785 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:14:09.600 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:14:20.519 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:14:21.305 - info: iobroker node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.7 (node-v46 ABI) (falling back to source compile with node-gyp)
          ! 2018-01-26 17:14:24.262 - info: iobroker gyp
          2018-01-26 17:14:31.338 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:14:24.266 - info: iobroker
          2018-01-26 17:14:24.267 - info: iobroker WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.7"
          2018-01-26 17:14:24.268 - info: iobroker gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/.node-gyp"
          2018-01-26 17:14:36.915 - info: iobroker make: *** No rule to make target '../.node-gyp/4.8.7/include/node/common.gypi', needed by 'Makefile'. Schluss.
          2018-01-26 17:14:36.926 - info: iobroker gyp
          2018-01-26 17:14:36.934 - info: iobroker ERR! build error
          2018-01-26 17:14:36.950 - info: iobroker gyp ERR! stack Error: make failed with exit code: 2
          2018-01-26 17:14:36.952 - info: iobroker gyp ERR! stack at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:276:23)gyp ERR! stack at emitTwo (events.js:87:13)
          ! 2018-01-26 17:14:36.954 - info: iobroker gyp ERR! System Linux 4.9.35-v7+
          2018-01-26 17:14:36.959 - info: iobroker gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release"gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport
          gyp ERR! not ok
          ! 2018-01-26 17:14:36.979 - info: iobroker node-pre-gyp ERR! build error
          2018-01-26 17:14:36.981 - info: iobroker node-pre-gyp
          2018-01-26 17:14:36.982 - info: iobroker
          2018-01-26 17:14:36.983 - info: iobroker ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/build/Release' (1)node-pre-gyp ERR! stack at ChildProcess. <anonymous>(/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
          ! 2018-01-26 17:14:36.987 - info: iobroker node-pre-gyp ERR! stack at emitTwo (events.js:87:13)node-pre-gyp ERR! stack at ChildProcess.emit (events.js:172:7)
          node-pre-gyp
          2018-01-26 17:14:36.989 - info: iobroker ERR! stack at maybeClose (internal/child_process.js:862:16)node-pre-gyp
          2018-01-26 17:14:36.990 - info: iobroker ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:222:5)
          2018-01-26 17:14:36.991 - info: iobroker node-pre-gyp ERR! System Linux 4.9.35-v7+
          2018-01-26 17:14:36.993 - info: iobroker node-pre-gyp
          2018-01-26 17:14:36.994 - info: iobroker ERR!
          2018-01-26 17:14:36.998 - info: iobroker command "/usr/bin/node" "/opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
          2018-01-26 17:14:37.000 - info: iobroker node-pre-gyp ERR! cwd /opt/iobroker/node_modules/iobroker.modbus/node_modules/jsmodbus/node_modules/serialportnode-pre-gyp ERR! node -v v4.8.7
          node-pre-gyp ERR!
          2018-01-26 17:14:37.002 - info: iobroker not ok
          2018-01-26 17:14:38.179 - info: iobroker prebuild-install
          2018-01-26 17:14:38.184 - info: iobroker
          2018-01-26 17:14:38.185 - info: iobroker info
          2018-01-26 17:14:38.185 - info: iobroker begin Prebuild-install version 2.5.0
          2018-01-26 17:14:38.198 - info: iobroker prebuild-install
          2018-01-26 17:14:38.199 - info: iobroker info looking for local prebuild @ prebuilds/serialport-v6.0.4-node-v46-linux-arm.tar.gz
          2018-01-26 17:14:38.206 - info: iobroker prebuild-install
          2018-01-26 17:14:38.207 - info: iobroker WARN install EACCES: permission denied, access '/root/.npm'
          2018-01-26 17:14:40.164 - info: iobroker gyp
          2018-01-26 17:14:40.168 - info: iobroker
          2018-01-26 17:14:40.169 - info: iobroker WARN
          2018-01-26 17:14:40.170 - info: iobroker
          2018-01-26 17:14:40.171 - info: iobroker EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/4.8.7"
          2018-01-26 17:14:40.172 - info: iobroker gyp
          2018-01-26 17:14:40.173 - info: iobroker WARN
          2018-01-26 17:14:40.174 - info: iobroker EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport/.node-gyp"
          2018-01-26 17:14:42.202 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:14:53.069 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:15:03.885 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:15:04.683 - info: iobroker npm
          2018-01-26 17:15:04.685 - info: iobroker
          2018-01-26 17:15:04.687 - info: iobroker ERR! Linux 4.9.35-v7+
          2018-01-26 17:15:04.688 - info: iobroker npm
          2018-01-26 17:15:04.689 - info: iobroker ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.modbus" "--production" "--prefix" "/opt/iobroker"
          2018-01-26 17:15:04.689 - info: iobroker npm
          2018-01-26 17:15:04.690 - info: iobroker ERR! node v4.8.7
          2018-01-26 17:15:04.691 - info: iobroker npm ERR! npm v2.15.11
          2018-01-26 17:15:04.700 - info: iobroker npm ERR! code ELIFECYCLE
          npm ERR!
          npm ERR!
          2018-01-26 17:15:04.701 - info: iobroker Failed at the serialport@4.0.7 install script 'node-pre-gyp install --fallback-to-build'.npm ERR! This is most likely a problem with the serialport package,
          ! 2018-01-26 17:15:04.702 - info: iobroker npm ERR! not with npm itself.
          2018-01-26 17:15:04.703 - info: iobroker npm ERR!
          2018-01-26 17:15:04.704 - info: iobroker Tell the author that this fails on your system:
          2018-01-26 17:15:04.705 - info: iobroker npm ERR! node-pre-gyp install --fallback-to-buildnpm ERR!
          2018-01-26 17:15:04.706 - info: iobroker You can get information on how to open an issue for this project with:
          2018-01-26 17:15:04.727 - info: iobroker npm ERR! npm bugs serialportnpm ERR! Or if that isn't available, you can get their info via:
          npm ERR!
          ! 2018-01-26 17:15:07.840 - info: iobroker
          2018-01-26 17:15:07.841 - info: iobroker npm ERR! Please include the following file with any support request:npm ERR! /home/npm-debug.log
          ! 2018-01-26 17:15:07.882 - error: iobroker host.pi-iobroker Adapter directory "/opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus" does not exists
          2018-01-26 17:15:08.108 - error: iobroker Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json'
          2018-01-26 17:15:08.120 - info: iobroker exit 0
          2018-01-26 17:15:09.123 - warn: host.pi-iobroker startInstance cannot find adapter "modbus". Try to install it... 3 attempt
          2018-01-26 17:15:09.124 - info: iobroker install modbus
          2018-01-26 17:15:11.369 - info: iobroker npm install iobroker.modbus --production --prefix "/opt/iobroker" (System call)
          2018-01-26 17:15:14.702 - info: smartmeter.0 Received 10 values, 3 updated
          2018-01-26 17:15:16.783 - info: host.pi-iobroker object change system.adapter.modbus.3
          2018-01-26 17:15:16.784 - info: host.pi-iobroker "system.adapter.modbus.3" disabled
          ^C
          pi@pi-iobroker:~ $</anonymous></anonymous>
          Jemand eine Idee wie ich das retten kann?
          EDIT: ich gebe es für heute erstmal auf. MODBUS 1.1.0 lässt sich auf meinem Slave PI3 nicht installieren nachdem ich jetzt die neueste Version von Smartmeter installiert habe mit dem Fehler aus dem log.
          Sind eventuell meine Node und NPM Versionen zu alt:
          pi@pi-iobroker:/opt/iobroker $ node -v
          v4.8.7
          pi@pi-iobroker:/opt/iobroker $ npm -v
          2.15.11
          Kann mir jemand sagen wie die rechte für root und pi user für .npm und .node-gyp auf einem funktionieren System stehen?
            Auf was stehen die Verzeichnisse denn rechtemäßig bei Dir?
            • wendy2702
              Hier die rechte einmal für den PI User:
              Und für den Root User:
                Mal ein chmod 777 machen damit da alle user das dürfen? Bei den Verzeichnissen vllt verkraftbar
                • Q
                  Qlink last edited by
                  Hi Leute,
                  nach einem Upgrade des Modbus Adapters von 0.5.3 auf 1.0.3 bekomme ich folgende Fehlermeldung:
                  host.iobroker	2018-01-27 22:42:51.398	error	startInstance modbus.0: cannot find start file!
                  host.iobroker	2018-01-27 22:42:51.398	info	object change system.adapter.modbus.0
                  host.iobroker	2018-01-27 22:42:43.981	info	object change system.adapter.modbus.0
                  host.iobroker	2018-01-27 22:41:54.021	error	startInstance modbus.0: cannot find start file!
                  host.iobroker	2018-01-27 22:41:53.913	info	object change system.adapter.modbus.0
                  Der Adapter startet nicht mehr seit dem Upgrade.
                  Bei einem Rollback zu 0.5.3 startet er wieder ganz normal und läuft ohne Probleme …
                  Hat jemand eine Idee?
                  • wendy2702
                    @apollon77:
                    Mal ein chmod 777 machen damit da alle user das dürfen? Bei den Verzeichnissen vllt verkraftbar `
                    Habe die mal noch nicht geändert da ja upgrades bisher immer so funktioniert haben.
                    Hatte am Freitag den Fallback auf 0.5.4 gemacht und das lief ja auf Anhieb wieder.
                    Dann gerade mal wieder upgrade auf 1.1.0 und siehe da… zumindest der Upgrade lief durch und der Adapter läuft.
                    Allerdings bin ich mir nicht sicher ob wirklich die neue Serialport Version verwendet wird:
                    ! 2018-01-29 09:45:54.173 - [32minfo[39m: host.pi-iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json" 2018-01-29 10:10:39.013 - [32minfo[39m: iobroker url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus 2018-01-29 10:10:40.460 - [32minfo[39m: iobroker install https://github.com/ioBroker/ioBroker.modbus/tarball/master 2018-01-29 10:10:40.829 - [32minfo[39m: iobroker npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --prefix "/opt/iobroker" (System call) 2018-01-29 10:12:32.353 - [32minfo[39m: iobroker prebuild-install 2018-01-29 10:12:32.358 - [32minfo[39m: iobroker 2018-01-29 10:12:32.359 - [32minfo[39m: iobroker info begin Prebuild-install version 2.5.0 2018-01-29 10:12:32.375 - [32minfo[39m: iobroker prebuild-install 2018-01-29 10:12:32.378 - [32minfo[39m: iobroker info looking for local prebuild @ prebuilds/serialport-v6.0.4-node-v46-linux-arm.tar.gz 2018-01-29 10:12:32.388 - [32minfo[39m: iobroker prebuild-install 2018-01-29 10:12:32.391 - [32minfo[39m: iobroker info looking for cached prebuild @ /root/.npm/_prebuilds/https-github.com-EmergingTechnologyAdvisors-node-serialport-releases-download-v6.0.4-serialport-v6.0.4-node-v46-linux-arm.tar.gz 2018-01-29 10:12:32.397 - [32minfo[39m: iobroker prebuild-install http request GET https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/v6.0.4/serialport-v6.0.4-node-v46-linux-arm.tar.gz 2018-01-29 10:12:33.658 - [32minfo[39m: iobroker prebuild-install 2018-01-29 10:12:33.660 - [32minfo[39m: iobroker http 404 https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/v6.0.4/serialport-v6.0.4-node-v46-linux-arm.tar.gz 2018-01-29 10:12:33.671 - [32minfo[39m: iobroker prebuild-install 2018-01-29 10:12:33.673 - [32minfo[39m: iobroker WARN install No prebuilt binaries found (target=4.8.7 runtime=node arch=arm platform=linux) 2018-01-29 10:13:12.027 - [32minfo[39m: iobroker node-pre-gyp 2018-01-29 10:13:12.030 - [32minfo[39m: iobroker 2018-01-29 10:13:12.032 - [32minfo[39m: iobroker ERR! 2018-01-29 10:13:12.036 - [32minfo[39m: iobroker Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v46-linux-arm.tar.gz node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@4.8.7 (node-v46 ABI) (falling back to source compile with node-gyp) 2018-01-29 10:14:02.649 - [32minfo[39m: iobroker got /opt/iobroker/node_modules/iobroker.modbus/admin 2018-01-29 10:14:02.677 - [32minfo[39m: iobroker upload [20] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/words.js words.js application/javascript 2018-01-29 10:14:02.798 - [32minfo[39m: iobroker upload [19] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/modbus.png modbus.png image/png 2018-01-29 10:14:02.865 - [32minfo[39m: iobroker upload [18] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.min.js lib/js/jsgrid.min.js application/javascript 2018-01-29 10:14:02.937 - [32minfo[39m: iobroker upload [17] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/jsgrid.js lib/js/jsgrid.js application/javascript 2018-01-29 10:14:03.025 - [32minfo[39m: iobroker upload [16] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-ru.js lib/js/grid.locale-ru.js application/javascript 2018-01-29 10:14:03.097 - [32minfo[39m: iobroker upload [15] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/js/grid.locale-de.js lib/js/grid.locale-de.js application/javascript 2018-01-29 10:14:03.157 - [32minfo[39m: iobroker upload [14] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.min.css lib/css/jsgrid.min.css text/css 2018-01-29 10:14:03.218 - [32minfo[39m: iobroker upload [13] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid.css lib/css/jsgrid.css text/css 2018-01-29 10:14:03.280 - [32minfo[39m: iobroker upload [12] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.min.css lib/css/jsgrid-theme.min.css text/css 2018-01-29 10:14:03.371 - [32minfo[39m: iobroker upload [11] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/lib/css/jsgrid-theme.css lib/css/jsgrid-theme.css text/css 2018-01-29 10:14:03.458 - [32minfo[39m: iobroker upload [10] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/index.html index.html text/html 2018-01-29 10:14:03.556 - [32minfo[39m: iobroker upload [9] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/img/plc_back.png img/plc_back.png image/png 2018-01-29 10:14:03.660 - [32minfo[39m: iobroker upload [8] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/ru/translations.json i18n/ru/translations.json application/json 2018-01-29 10:14:03.727 - [32minfo[39m: iobroker upload [7] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/pt/translations.json i18n/pt/translations.json application/json 2018-01-29 10:14:03.796 - [32minfo[39m: iobroker upload [6] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/pl/translations.json i18n/pl/translations.json application/json 2018-01-29 10:14:03.872 - [32minfo[39m: iobroker upload [5] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/nl/translations.json i18n/nl/translations.json application/json 2018-01-29 10:14:03.933 - [32minfo[39m: iobroker upload [4] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/it/translations.json i18n/it/translations.json application/json 2018-01-29 10:14:03.995 - [32minfo[39m: iobroker upload [3] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/fr/translations.json i18n/fr/translations.json application/json 2018-01-29 10:14:04.058 - [32minfo[39m: iobroker upload [2] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/es/translations.json i18n/es/translations.json application/json 2018-01-29 10:14:04.140 - [32minfo[39m: iobroker upload [1] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/en/translations.json i18n/en/translations.json application/json 2018-01-29 10:14:04.227 - [32minfo[39m: iobroker upload [0] modbus.admin /opt/iobroker/node_modules/iobroker.modbus/admin/i18n/de/translations.json i18n/de/translations.json application/json 2018-01-29 10:14:04.342 - [32minfo[39m: iobroker exit 0 2018-01-29 10:14:05.345 - [32minfo[39m: host.pi-iobroker Update repository "latest" under "http://download.iobroker.net/sources-dist-latest.json" 2018-01-29 10:14:15.375 - [33mwarn[39m: host.pi-iobroker warning: Cannot read "http://download.iobroker.net/sources-dist-latest.json" !
                    Was meinst du?
                      Interessant allemal Er versucht die 6.0.4 als Prebuild runterzuladen. Das geht nicht weil ARM nicht da ist (was ok ist) und dann sagt er das er die 4.0.7 versucht …
                      Schau mal in /opt/iobroker/node_modules/iobroker.modbus/node_modules/serialport was in der package.json steht ... Die Version zählt am Ende
                      • wendy2702
                        Hi Ingo,
                        das sieht gut aus:
                         "name": "serialport",
                          "version": "6.0.4",
                        Mirko
                          Dann wäre mein "guess": passt 🙂
                          Es sollte das "lokale "node_modules" vor dem anderen Vorrang haben.
                          • wendy2702
                            Zumindest friert der PI /SSH nicht mehr ein wie ich zu beginn hatte.
                            • wendy2702
                              muss leider meine letzte Aussage revidieren.
                              Heute morgen wieder kein SSH Zugriff mehr möglich.
                              Ich werde jetzt mal versuchen den Modbus wieder auf 0.5.4 zu bringen.
                                Wäre ja echt mal interessant was genau das Problem ist … kannst Du irgendwie dauerhaft ein "top" auf nem Bildschirm mitlaufen lassen? Bzw was seind denn so die letzten ioBroker logausgaben? Steht in /var/log/syslog irgendwas verwertbares?
                                • wendy2702
                                  da kein SSH möglich war habe ich erstmal gedacht:
                                  1. reboot über iobroker Terminal –> kein SSH über Putty, TOP geht leider nicht im iobroker Terminal oder ich weiß nicht wie.
                                  2. Versuch Downgrade Modbus Adapter. --> ausgeführt, Adapter läuft mit 0.5.4-> immer noch kein SSH
                                  3. reboot über iobroker Terminal --> weiterhin kein SSH über Putty
                                  4. downgrade Smartmeter Adapter (wegen Serialport) --> Adapter 1.0.0 läuft --> immer noch kein SSH
                                  5. reboot über iobroker Terminal --> weiterhin kein SSH über Putty
                                  6. shutdown über iobroker Terminal. Strom aus, 30 sek. gewartet, Strom an --> SSH OK!!!
                                  Im Syslog kann ich nur sehen das gestern Abend gegen 21:20 mal die WLAN Verbindung unterbrochen war und das heute morgen der Cron:
                                  pi-iobroker CRON[6184]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily ))
                                  lief.
                                  Würde mal vermuten das die Fehlende WLAN Verbindung nicht das SSH Problem verursachen sollte da ich das WLAN schon mal häufiger abgeschaltet habe im zuge von SW Upgrades der Box und APs.
                                  Ich lassen das jetzt mal mit Top Fenster und den alten Adapter Versionen laufen. Mal sehen ob morgen SSH noch geht. Wenn nicht liegt es an etwas anderem… nur an was 😞
                                  • wendy2702
                                    Moin,
                                    ich wieder. Nachdem ich einen Workaround wegen meinem SSH Problem gefunden habe wollte ich nochmal die neue Modbus version testen.
                                    Habe dazu um sicher zu gehen das meine Node und NPM Versionen nicht zu alt sind dies zuerst upgedated auf:
                                    v6.12.3
                                    3.10.10
                                    Danach dann das````
                                    reinstall.sh
                                    Wenn ich jetzt sage "Adapter aus GIT installieren" und Modbus auswähle kommt das:
                                    $ ./iobroker url "https://github.com/ioBroker/ioBroker.modbus/tarball/master" modbus
                                    npm
                                    ERR! Linux 4.9.35-v7+npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "https://github.com/ioBroker/ioBroker.modbus/tarball/master" "--production" "--prefix" "/opt/iobroker"
                                    npm ERR! node v6.12.3
                                    npm ERR! npm v3.10.10
                                    npm
                                    ERR! path /opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/bin/uuidnpm ERR! code ENOENT
                                    npm ERR! errno -2
                                    npm ERR! syscall chmod
                                    npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/bin/uuid'npm ERR! enoent ENOENT: no such file or directory, chmod '/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/node_modules/request/node_modules/uuid/bin/uuid'
                                    npm ERR! enoent This is most likely not a problem with npm itself
                                    npm ERR!
                                    enoent and is related to npm not being able to find a file.npm ERR! enoent
                                    npm ERR! Please include the following file with any support request:npm ERR! /opt/npm-debug.log
                                    npm ERR! code 1
                                    ERROR: Cannot parse /opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json:Error: ENOENT: no such file or directory, open '/opt/iobroker/node_modules/iobroker.js-controller/adapter/modbus/io-package.json'
                                    process exited with code 0
                                    Lustiger weise sagt mir der neue Admin "Erfolgreich" :?
                                     ![999_admin_modbus_erfolgreich_.jpg](/assets/uploads/files/999_admin_modbus_erfolgreich_.jpg)
                                    Das werde ich im Admin Thread aber als "Bug" melden.
                                    Wie bekomme ich denn jetzt den Modbus wieder ans laufen ohne das ich meine Register Einstellungen verliere?
                                    Danke und Gruß
                                    Mirko
                                    EDIT: Wenn ich es mit sudo davor versuche sieht es so aus:
                                     sudo npm install https://github.com/ioBroker/ioBroker.modbus/tarball/master --production --prefix "/opt/iobroker"
                                    >! > serialport@4.0.7 install /opt/iobroker/node_modules/jsmodbus/node_modules/serialport
                                    >! node-pre-gyp ERR! Tried to download(404): https://github.com/EmergingTechnologyAdvisors/node-serialport/releases/download/4.0.7/serialport-v4.0.7-node-v48-linux-arm.tar.gz
                                    node-pre-gyp ERR! Pre-built binaries not found for serialport@4.0.7 and node@6.12.3 (node-v48 ABI) (falling back to source compile with node-gyp)
                                    gyp WARN EACCES user "root" does not have permission to access the dev dir "/root/.node-gyp/6.12.3"
                                    gyp WARN EACCES attempting to reinstall using temporary dev dir "/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/.node-gyp"
                                    make: Entering directory '/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/build'
                                    make: *** No rule to make target '../.node-gyp/6.12.3/include/node/common.gypi', needed by 'Makefile'.  Schluss.
                                    make: Leaving directory '/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/build'
                                    gyp ERR! stack Error: `make` failed with exit code: 2
                                    gyp ERR! stack     at ChildProcess.onExit (/opt/iobroker/node_modules/npm/node_modules/node-gyp/lib/build.js:285:23)
                                    gyp ERR! stack     at emitTwo (events.js:106:13)
                                    gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                                    gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:219:12)
                                    gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "build" "--fallback-to-build" "--module=/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node" "--module_name=serialport" "--module_path=/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/build/Release"
                                    gyp ERR! cwd /opt/iobroker/node_modules/jsmodbus/node_modules/serialport
                                    gyp ERR! node -v v6.12.3
                                    gyp ERR! node-gyp -v v3.6.0
                                    gyp ERR! not ok
                                    node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /opt/iobroker/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js build --fallback-to-build --module=/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/build/Release/serialport.node --module_name=serialport --module_path=/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/build/Release' (1)
                                    node-pre-gyp ERR! stack     at ChildProcess. <anonymous>(/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
                                    node-pre-gyp ERR! stack     at emitTwo (events.js:106:13)
                                    node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:191:7)
                                    node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:920:16)
                                    node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:230:5)
                                    node-pre-gyp ERR! command "/usr/bin/node" "/opt/iobroker/node_modules/jsmodbus/node_modules/serialport/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
                                    node-pre-gyp ERR! cwd /opt/iobroker/node_modules/jsmodbus/node_modules/serialport
                                    node-pre-gyp ERR! node -v v6.12.3
                                    iobroker.core@0.1.0 /opt/iobroker
                                    └── (empty)
                                    >! npm ERR! Linux 4.9.35-v7+
                                    >! npm ERR! serialport@4.0.7 install: `node-pre-gyp install --fallback-to-build`
                                    npm ERR!
                                    npm ERR! Make sure you have the latest version of node.js and npm installed.
                                    npm ERR! If you do, this is most likely a problem with the serialport package,
                                    >! npm ERR! Please include the following file with any support request:
                                    npm ERR!     /opt/iobroker/npm-debug.log
                                    npm ERR! code 1
                                    pi@pi-iobroker:/opt/iobroker $</anonymous>
                                      mal npm cache clean versucht?
                                      ansonsten lösche doch mal alles in /opt/iobroker/node_modules/jsmodbus/ (inklusiv dem verzeichnis) weil wird ja an sich eh neu erzeugt
                                      • wendy2702
                                        und was nach dem npm cache clean?
                                        Update des Adapters über Browser?
                                        Update/installation über konsole mit oder ohne sudo?
                                        erneutes reinstall.sh?
                                        Bin ja immer ungeduldig 😛
                                        Nach npm cache clean gerade mal installieren von GIT gemacht und das scheint diesmal geklappt zu haben:
                                          jupp sieht gut aus
                                            edno-bommel77 last edited by
                                            ich bräuchte auch Hilfe seit update auf 1.0.3 und dann nach Anleitung von hier auf 1.1.0 läuft der Modbus nicht mehr habe es auch schon alles wie hier erwähnt probiert. Bin kein Profi muss ich dazusagen aber mit 0.5.4 lief es. Habe aber keinen PI sondern ein apu board wo ich mit proxmox iobroker Visualisiere. Habe auch versucht auf 0.5.4 zurück zukommen hilft auch nicht. Hat jemand noch eine Idee was ich machen kann ausser einen alten Snapshot einzuspielen wo dann meine Arbeit der letzten zwei Monaten weg ist. Habe auch ehrlich vergessen einen neuen Snapshot zu erstellen vor dem update. :oops:
                                            danke schone einmal.
                                            Gruß Markus
                                            5154
