    3. Einsteigerfragen
    4. uraltete ioBroker Installation geschickt updaten?
    • lost in translation
      lost in translation @Codierknecht last edited by
      @codierknecht said in uraltete ioBroker Installation geschickt updaten?:
      @lost-in-translation sagte in uraltete ioBroker Installation geschickt updaten?:
      Wo muss ich anfangen?
      Die Langfassung von
      iob diag
      könnte schon mal helfen.
      Wobei ich mir nicht sicher bin, ob das in Deiner Steinzeitversion überhaupt schon enthalten ist.
      Sieht nicht so aus: pi@ioBroker-RasPi:/opt/iobroker $ iob diag
      Commands:
      iobroker setup [--objects <host>] [--states <host>] [custom]
      iobroker start
      iobroker stop
      iobroker start <adapter>
      iobroker stop <adapter>
      iobroker start all
      Viele Grüße
      Frank
        Die Langfassung von
        iob diag
        iob fix hat iob diag hervorgezaubert:
        Script v.2025-02-23
        *** BASE SYSTEM ***
        ========== Start marking the full check here ===========
        ```bash
        Script v.2025-02-23
        *** BASE SYSTEM ***
           Static hostname: ioBroker-RasPi
                 Icon name: computer
          Operating System: Raspbian GNU/Linux 9 (stretch)
                    Kernel: Linux 4.14.98-v7+
              Architecture: arm
        OS is similar to: debian
        model name      : ARMv7 Processor rev 4 (v7l)
        Docker          : false
        Virtualization  : none
        Kernel          : armv7l
        Userland        : 32 bit
        Systemuptime and Load:
         09:30:31 up 21:33,  1 user,  load average: 0.63, 0.52, 0.36
        CPU threads: 4
        *** LIFE CYCLE STATUS ***
        Unknown release codenamed 'stretch'. Please check yourself if the Operating System is actively maintained.
        *** RASPBERRY THROTTLING ***
        Current issues:
        ~ Under-voltage detected
        Previously detected issues:
        ~ Under-voltage has occurred
        *** TIME AND TIMEZONES ***
              Local time: Tue 2025-05-13 09:30:31 CEST
          Universal time: Tue 2025-05-13 07:30:31 UTC
                RTC time: n/a
         Network time on: yes
        NTP synchronized: yes
         RTC in local TZ: no
        Unknown operation show
        *** Users and Groups ***
        User that called 'iob diag':
        pi
        HOME=/home/pi
        GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
        js-controller is not running
        *** DISPLAY-SERVER SETUP ***
        Display-Server: false
        Desktop:
        Terminal:
        System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
        *** MEMORY ***
        Mem:           949M         38M        479M         21M        431M        823M
        Swap:          102M         24M         77M
        Total:         1.1G         63M        556M
        Active iob-Instances:   1
                  927 M total memory
                   37 M used memory
                  254 M active memory
                  121 M inactive memory
                  467 M free memory
                   91 M buffer memory
                  330 M swap cache
                   99 M total swap
                   24 M used swap
                   75 M free swap
        top - 09:30:32 up 21:33,  1 user,  load average: 0.66, 0.53, 0.37
        Tasks: 105 total,   1 running,  60 sleeping,   0 stopped,   0 zombie
        %Cpu(s):  4.4 us,  0.8 sy,  0.0 ni, 94.4 id,  0.3 wa,  0.0 hi,  0.1 si,  0.0 st
        KiB Mem :   949448 total,   478936 free,    38416 used,   432096 buff/cache
        KiB Swap:   102396 total,    77564 free,    24832 used.   823660 avail Mem
        *** FAILED SERVICES ***
          UNIT             LOAD   ACTIVE SUB    DESCRIPTION
        * iobroker.service loaded failed failed ioBroker Server
        LOAD   = Reflects whether the unit definition was properly loaded.
        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
        SUB    = The low-level unit activation state, values depend on unit type.
        1 loaded units listed. Pass --all to see loaded but inactive units, too.
        To show all installed unit files use 'systemctl list-unit-files'.
        *** DMESG CRITICAL ERRORS ***
        No critical errors detected
        *** FILESYSTEM ***
        /dev/root      ext4      7.3G  2.6G  4.5G  37% /
        devtmpfs       devtmpfs  460M     0  460M   0% /dev
        tmpfs          tmpfs     464M     0  464M   0% /dev/shm
        tmpfs          tmpfs     464M   36M  429M   8% /run
        tmpfs          tmpfs     464M     0  464M   0% /sys/fs/cgroup
        /dev/mmcblk0p1 vfat       42M   22M   20M  53% /boot
        tmpfs          tmpfs      93M     0   93M   0% /run/user/1000
        [Mon May 12 11:56:57 2025] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUUID=9c63c4e6-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
        [Mon May 12 11:56:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [Mon May 12 11:56:58 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
        [Mon May 12 11:57:00 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Show mounted filesystems:
        findmnt: unrecognized option '--real'
        Usage:
         findmnt [options]
         findmnt [options] <device> | <mountpoint>
         findmnt [options] <device> <mountpoint>
         findmnt [options] [--source <device>] [--target <path> | --mountpoint <dir>]
        Find a (mounted) filesystem.
        Options:
         -s, --fstab            search in static table of filesystems
         -m, --mtab             search in table of mounted filesystems
         -k, --kernel           search in kernel table of mounted
                                  filesystems (default)
         -p, --poll[=<list>]    monitor changes in table of mounted filesystems
         -w, --timeout <num>    upper limit in milliseconds that --poll will block
         -A, --all              disable all built-in filters, print all filesystems
         -a, --ascii            use ASCII chars for tree formatting
         -b, --bytes            print sizes in bytes rather than in human readable format
         -C, --nocanonicalize   don't canonicalize when comparing paths
         -c, --canonicalize     canonicalize printed paths
         -D, --df               imitate the output of df(1)
         -d, --direction <word> direction of search, 'forward' or 'backward'
         -e, --evaluate         convert tags (LABEL,UUID,PARTUUID,PARTLABEL)
                                  to device names
         -F, --tab-file <path>  alternative file for -s, -m or -k options
         -f, --first-only       print the first found filesystem only
         -i, --invert           invert the sense of matching
         -J, --json             use JSON output format
         -l, --list             use list format output
         -N, --task <tid>       use alternative namespace (/proc/<tid>/mountinfo file)
         -n, --noheadings       don't print column headings
         -O, --options <list>   limit the set of filesystems by mount options
         -o, --output <list>    the output columns to be shown
         -P, --pairs            use key="value" output format
         -R, --submounts        print all submounts for the matching filesystems
         -r, --raw              use raw output format
         -S, --source <string>  the device to mount (by name, maj:min,
                                  LABEL=, UUID=, PARTUUID=, PARTLABEL=)
         -T, --target <path>    the path to the filesystem to use
         -M, --mountpoint <dir> the mountpoint directory
         -t, --types <list>     limit the set of filesystems by FS types
         -U, --uniq             ignore filesystems with duplicate target
         -u, --notruncate       don't truncate text in columns
         -v, --nofsroot         don't print [/dir] for bind or btrfs mounts
         -x, --verify           verify mount table content (default is fstab)
             --verbose          print more details
         -h, --help     display this help and exit
         -V, --version  output version information and exit
        Available columns:
              SOURCE  source device
              TARGET  mountpoint
              FSTYPE  filesystem type
             OPTIONS  all mount options
         VFS-OPTIONS  VFS specific mount options
          FS-OPTIONS  FS specific mount options
               LABEL  filesystem label
                UUID  filesystem UUID
           PARTLABEL  partition label
            PARTUUID  partition UUID
             MAJ:MIN  major:minor device number
              ACTION  action detected by --poll
          OLD-TARGET  old mountpoint saved by --poll
         OLD-OPTIONS  old mount options saved by --poll
                SIZE  filesystem size
               AVAIL  filesystem size available
                USED  filesystem size used
                USE%  filesystem use percentage
              FSROOT  filesystem root
                 TID  task ID
                  ID  mount ID
          OPT-FIELDS  optional mount fields
         PROPAGATION  VFS propagation flags
                FREQ  dump(8) period in days [fstab only]
              PASSNO  pass number on parallel fsck(8) [fstab only]
        For more details see findmnt(8).
        /var:
        530M    /var/
        283M    /var/cache
        278M    /var/cache/apt
        227M    /var/cache/apt/archives
        81M     /var/lib
        Archived and active journals take up 34.7M in the file system.
        /opt/iobroker/backups:
        17M     /opt/iobroker/backups/
        /opt/iobroker/iobroker-data:
        229M    /opt/iobroker/iobroker-data/
        148M    /opt/iobroker/iobroker-data/backup-objects
        57M     /opt/iobroker/iobroker-data/files
        31M     /opt/iobroker/iobroker-data/files/javascript.admin
        21M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js
        12M     /opt/iobroker/iobroker-data/objects.json.bak
        4.8M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.bc7716ef.chunk.js.map
        4.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.7e0b7583.chunk.js.map
        4.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/2.0e618607.chunk.js.map
        USB-Devices by-id:
        No Devices found 'by-id'
        Zigbee Network Settings on your coordinator/in nvbackup are:
        zigbee.X
        Extended Pan ID:
        *** MASKED ***
        Pan ID:
        *** MASKED ***
        Channel:
        *** MASKED ***
        Network Key:
        *** MASKED ***
        To unmask the settings run 'iob diag --unmask'
        *** NodeJS-Installation ***
        /usr/bin/nodejs         v10.20.1
        /usr/bin/node           v10.20.1
        internal/modules/cjs/loader.js:638
            throw err;
        Error: Cannot find module 'node:path'
            at Function.Module._resolveFilename (internal/modules/cjs/loader.js:636:15)
            at Function.Module._load (internal/modules/cjs/loader.js:562:25)
            at Module.require (internal/modules/cjs/loader.js:692:17)
            at require (internal/modules/cjs/helpers.js:25:18)
            at Object.<anonymous> (/usr/lib/node_modules/npm/lib/cli.js:10:18)
            at Module._compile (internal/modules/cjs/loader.js:778:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
            at Module.load (internal/modules/cjs/loader.js:653:32)
            at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
            at Function.Module._load (internal/modules/cjs/loader.js:585:3)
        /usr/bin/npm
            throw err;
            throw err;
        /usr/bin/npx
            throw err;
        corepack:       N/A
        *** nodejs is NOT correctly installed ***
        nodejs:
          Installed: 10.20.1-1nodesource1
          Candidate: 10.24.1-1nodesource1
          Version table:
             10.24.1-1nodesource1 500
                500 https://deb.nodesource.com/node_10.x stretch/main armhf Packages
         *** 10.20.1-1nodesource1 100
                100 /var/lib/dpkg/status
             8.11.1~dfsg-2~bpo9+1 500
                500 http://archive.raspberrypi.org/debian stretch/main armhf Packages
             4.8.2~dfsg-1 500
                500 http://raspbian.raspberrypi.org/raspbian stretch/main armhf Packages
        No problems detected
        Errors in npm tree: 0
        *** ioBroker-Installation ***
        ioBroker Status
        iobroker is not running on this host.
        No iobroker host is running.
        Objects type: file
        States  type: redis
        Hosts:
        ioBroker-RasPi      ioBroker-RasPi (version: 2.2.9, hostname: ioBroker-RasPi,  dead, uptime: 71254)
        Core adapters versions
        js-controller:  2.2.9
        admin:          4.2.1
        javascript:     4.8.4
        nodejs modules from github:     0
        Adapter State
          system.adapter.admin.0                 : admin                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
          system.adapter.alexa2.0                : alexa2                -  enabled
          system.adapter.backitup.0              : backitup              -  enabled
          system.adapter.broadlink2.0            : broadlink2            -  enabled
          system.adapter.cloud.0                 : cloud                 - disabled
          system.adapter.discovery.0             : discovery             - disabled
          system.adapter.email.0                 : email                 -  enabled
          system.adapter.flot.0                  : flot                  -  enabled
          system.adapter.history.0               : history               -  enabled
          system.adapter.info.0                  : info                  - disabled
          system.adapter.javascript.0            : javascript            -  enabled
          system.adapter.lgtv11.0                : lgtv11                -  enabled, port: 8080
          system.adapter.mobile.0                : mobile                - disabled
          system.adapter.netatmo.0               : netatmo               -  enabled
          system.adapter.onvif-alt.0             : onvif-alt             -  enabled
          system.adapter.rpi2.0                  : rpi2                  - disabled
          system.adapter.socketio.0              : socketio              -  enabled, port: 8084, bind: 0.0.0.0, run as: admin
          system.adapter.telegram.0              : telegram              - disabled, port: 8443, bind: 0.0.0.0
          system.adapter.terminal.0              : terminal              - disabled, port: 8088, bind: 0.0.0.0, run as: admin
          system.adapter.tr-064-community.0      : tr-064-community      - disabled
          system.adapter.tr-064.0                : tr-064                -  enabled
          system.adapter.vis.0                   : vis                   -  enabled
          system.adapter.web.0                   : web                   -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        + instance is alive
        ioBroker-Repositories
        default    : http://download.iobroker.net/sources-dist.json
        latest     : http://download.iobroker.net/sources-dist-latest.json
        Active repo: default
        Installed ioBroker-Adapters
        Used repository: default
        hash changed or no sources cached => force download of new sources
        Cannot get any information of "_repoInfo". Ignored.
        update done
        Adapter    "admin"         : 7.6.3    , installed 4.2.1 [Updateable]
        Adapter    "alexa2"        : 3.26.5   , installed 3.8.1 [Updateable]
        Adapter    "backitup"      : 3.0.31   , installed 1.7.0 [Updateable]
        Adapter    "broadlink2"    : 2.3.0    , installed 2.0.3 [Updateable]
        Adapter    "cloud"         : 5.0.1    , installed 4.0.4 [Updateable]
        Adapter    "discovery"     : 5.0.0    , installed 2.5.0 [Updateable]
        Adapter    "email"         : 2.0.3    , installed 1.0.9 [Updateable]
        Adapter    "flot"          : 1.12.0   , installed 1.10.6 [Updateable]
        Adapter    "history"       : 3.0.1    , installed 1.9.12 [Updateable]
        Adapter    "javascript"    : 8.8.3    , installed 4.8.4 [Updateable]
        Controller "js-controller" : 7.0.6    , installed 2.2.9 [Updateable]
        Adapter    "lgtv11"        : 1.0.5    , installed 1.0.5
        Adapter    "mobile"        : 1.0.1    , installed 1.0.1
        Adapter    "netatmo"       : 3.1.0    , installed 1.3.3 [Updateable]
        Adapter    "rpi2"          : 2.4.0    , installed 1.2.0 [Updateable]
        Adapter    "simple-api"    : 2.8.0    , installed 2.5.3 [Updateable]
        Adapter    "socketio"      : 6.7.1    , installed 3.1.4 [Updateable]
        Adapter    "telegram"      : 4.1.0    , installed 1.7.0 [Updateable]
        Adapter    "terminal"      : 1.0.0    , installed 0.1.2 [Updateable]
        Adapter    "tr-064"        : 4.3.0    , installed 4.2.4 [Updateable]
        Adapter    "vis"           : 1.5.6    , installed 1.3.4 [Updateable]
        Adapter    "web"           : 7.0.8    , installed 3.2.3 [Updateable]
        Objects and States
        Objects:        4412
        States:         3712
        E: The repository 'http://raspbian.raspberrypi.org/raspbian stretch Release' does no longer have a Release file.
        Pending Updates: 80
        *** Listening Ports ***
        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          12427      513/sshd
        tcp        0      0 127.0.0.1:6379          0.0.0.0:*               LISTEN      109        12063      519/redis-server 12
        tcp6       0      0 :::22                   :::*                    LISTEN      0          12429      513/sshd
        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          9616       497/dhcpcd
        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        9592       304/avahi-daemon: r
        udp        0      0 0.0.0.0:54092           0.0.0.0:*                           108        9594       304/avahi-daemon: r
        udp6       0      0 :::546                  :::*                                0          9620       497/dhcpcd
        udp6       0      0 :::52307                :::*                                108        9595       304/avahi-daemon: r
        udp6       0      0 :::5353                 :::*                                108        9593       304/avahi-daemon: r
        2025-05-13 09:27:37.396  - info: onvif-alt.0 (19124) Got terminate signal TERMINATE_YOURSELF
        2025-05-13 09:27:37.398  - info: admin.0 (18896) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2025-05-13 09:27:37.396  - info: web.0 (18911) Got terminate signal TERMINATE_YOURSELF
        2025-05-13 09:27:37.399  - info: onvif-alt.0 (19124) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2025-05-13 09:27:37.402  - info: web.0 (18911) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2025-05-13 09:27:37.406  - info: socketio.0 (18922) Got terminate signal TERMINATE_YOURSELF
        2025-05-13 09:27:37.410  - info: socketio.0 (18922) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2025-05-13 09:27:37.404  - info: alexa2.0 (18988) Got terminate signal TERMINATE_YOURSELF
        2025-05-13 09:27:37.413  - info: alexa2.0 (18988) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2025-05-13 09:27:37.429  - info: history.0 (18952) Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason
        2025-05-13 09:27:37.504  - info: javascript.0 (18971) Got terminate signal TERMINATE_YOURSELF
        2025-05-13 09:27:37.873  - info: host.ioBroker-RasPi instance system.adapter.lgtv11.0 terminated with code 156 (156)
        2025-05-13 09:27:37.892  - info: host.ioBroker-RasPi instance system.adapter.backitup.0 terminated with code 156 (156)
        2025-05-13 09:27:38.000  - info: host.ioBroker-RasPi instance system.adapter.email.0 terminated with code 156 (156)
        2025-05-13 09:27:38.001  - info: host.ioBroker-RasPi instance system.adapter.broadlink2.0 terminated with code 156 (156)
        2025-05-13 09:27:38.001  - info: host.ioBroker-RasPi instance system.adapter.web.0 terminated with code 156 (156)
        2025-05-13 09:27:38.002  - info: host.ioBroker-RasPi instance system.adapter.socketio.0 terminated with code 156 (156)
        2025-05-13 09:27:38.002  - info: host.ioBroker-RasPi instance system.adapter.alexa2.0 terminated with code 156 (156)
        2025-05-13 09:27:38.003  - info: host.ioBroker-RasPi instance system.adapter.tr-064.0 terminated with code 156 (156)
        2025-05-13 09:27:38.004  - info: host.ioBroker-RasPi instance system.adapter.onvif-alt.0 terminated with code 156 (156)
        2025-05-13 09:27:38.040  - info: host.ioBroker-RasPi instance system.adapter.admin.0 terminated with code 156 (156)
        2025-05-13 09:27:38.041  - info: host.ioBroker-RasPi instance system.adapter.history.0 terminated with code 156 (156)
        2025-05-13 09:27:38.042  - info: host.ioBroker-RasPi instance system.adapter.javascript.0 terminated with code 156 (156)
        2025-05-13 09:27:38.043  - info: host.ioBroker-RasPi All instances are stopped.
        2025-05-13 09:27:38.209  - info: host.ioBroker-RasPi terminated
          Homoran Global Moderator Administrators @lost in translation last edited by
          das hab ich mir gedacht!
          vollkommen veraltet und daher nicht mehr in irgendeiner Weise zu "pflegen", da die Quellen nicht mehr existieren
          da hilft nur komplette Neuinstallation
          lost in translation 1 Reply Last reply Reply Quote 0
            lost in translation @Homoran last edited by
            @homoran said in uraltete ioBroker Installation geschickt updaten?:
            heisst auch, dass ich mit den Backups nichts anfangen kann?
            Oder ist die Hardware jetzt auch so veraltet, dass ich da sowieso an was neues denken muss?
            Viele Grüße
            Frank
            • Asgothian
              Asgothian Developer last edited by Asgothian
              @codierknecht sagte in uraltete ioBroker Installation geschickt updaten?:
              Bei einem dermaßen alten System gibt es keine Möglichkeit das OS "upzudaten".
              Die richtige Vorgehensweise wäre:
              • alles so weit möglich auf Stand bringen
              • Backup ziehen
              • Neuinstallation mit Debian-12 (64-Bit, ohne Desktop)
              • Backup wiederherstellen
              Lies Dir den von @David-G verlinkten Thread durch. Das sollte auf jeden Fall weiterhelfen.
              Ich rate dringendst davon ab das bei einem so alten System zu versuchen. Besser ist es, das System von Grund auf neu aufzusetzen, und die Daten der einzelnen Adapter von Hand umzuziehen.
              Du musst bei einem so alten System damit rechnen das bei Versuch das System ‘soweit möglich’ auf Stand zu bringen Dinge nicht funktionieren.
              Solltest du diesen Weg gehen musst du als erstes von der sdkarte ein Image ziehen damit du das System wieder herstellen kannst wenn es zu Komplikationen kommt.
              Der oben verlinkte thread sollte einen Einblick geben wie aufwändig das werden kann es mit dem hochziehen.
              A.
                Homoran Global Moderator Administrators @Asgothian last edited by
                @asgothian sagte in uraltete ioBroker Installation geschickt updaten?:
                ...oder/und bei dem Alter sowieso eine neue Karte nehmen und due alte als Hardwarebackup behalten
                  was ist es denn?
                  ist definitiv knapp.
                  die aktuellen Versionen benötigen mehr RAM als damals.
                  Wenn es dann noch ein Pi2 mit nur 32Bit ist, solltest du dir die Anschaffung eines Pi4/5 mit mind. 4GB RAM überlegen.
                  Dann kannst du in Ruhe parallel neu aufbauen
                    @asgothian
                    kann man denn bei
                    schon die Instanzenkonfig downloaden?
                    • Asgothian
                      @homoran wahrscheinlich nicht. Deswegen halte ich ein neu aufsetzen und Adapter manuell entsprechend konfigurieren für unumgänglich.
                      A.
                        Thomas Braun Most Active @lost in translation last edited by Thomas Braun
                        Da das System ja offenbar nicht wichtig ist:
                        Setz es komplett neu auf neuer/aktueller Hardware auf. Mit 1GB RAM auf einem Raspberry 3 kommst du ohnehin nicht weit.
                        BTW:
                        Das Netzteil scheint mir aber immer noch zu wackelig zu sein:
                        Current issues:
                          @asgothian
                          kann man denn bei
                          Nicht das ich das sehen würde. Wahrscheinlich ist Neuinstallation das geschickteste. Nur zweifel ich grade, ob ein RASPI dann überhaupt noch das richtige ist. Den aktuellen sehe ich mit 27W und 44W USB-C Netzteil. Was nimmt man denn da am besten?
                          Und braucht der wirklich so viel Strom? Oder nehme ich besser nen Mini-PC? Von der Größe wäre es ja grade mal doppelt so groß.
                          Büchse der Pandorra geöffnet, zumindest fühlt es sich so an 🙂
                          Viele Grüße
                          Frank
                          Winni 1 Reply Last reply Reply Quote 0
                            lost in translation @Thomas Braun last edited by
                            @thomas-braun said in uraltete ioBroker Installation geschickt updaten?:
                            BTW:
                            Current issues:
                            Das ist ja nervig 😞 Beim Hochfahren hat er es nicht mehr angezeigt. Gibt es da eine Empfehlung für ein taugliches Micro-SD Netzteil, oder nehm ich das jetzt einfach hin? Hatte extra bei Amazon eins mit guten Bewertungen ausgesucht.
                            Viele Grüße
                            Frank
                              Kauf das originale direkt bei Raspberry. Das funktioniert.
                              • Winni
                                Winni @lost in translation last edited by Winni
                                @asgothian
                                kann man denn bei
                                Viele Grüße
                                Frank
                                Ich würde dieses Netzteil nehmen:
                                https://www.berrybase.de/raspberry-pi-27w-usb-c-power-supply-netzteil-schwarz
                                Und der Raspberry Pi 5 braucht deutlich weniger Strom wie ein Mini-PC. Meiner läuft mit ioBroker, USB Zigbee-Dongle und 2tb SSD unter 5 W. Mein brandneuer Minisforum UN100P liegt über 10 W
                                Edit: ohne Tastatur und Maus geht es runter auf unter 7 Watt, ist aber immernoch deutlich mehr als der Pi5.
                                  Thomas Braun Most Active @Winni last edited by
                                  @winni sagte in uraltete ioBroker Installation geschickt updaten?:
                                  Das ist ja offenbar auch das offizielle Original-Teil.
                                  1357
