    4. Panasonic comfort cloud Adapter funktioniert nicht mehr
      emil70 @ecurb last edited by emil70
      @ecurb
      Was steht den, wenn du die Objekte löscht im Log nach Restart des Adapters?
      bei mir gerade getestet. Geht Alles. Ich nutzt die v3.0.3
      panasonic-comfort-cloud.0
      	2025-01-09 05:35:08.006	info	Device Klima Juliazimmer created.
      	2025-01-09 05:35:08.006	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:08.005	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:08.004	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:08.002	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:08.001	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:08.000	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.999	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.994	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.993	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.992	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.992	info	Method "createDevice" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.797	info	Device Klima Wohnzimmer created.
      	2025-01-09 05:35:07.795	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.794	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.793	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.792	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.791	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.790	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.789	info	Method "createDevice" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.722	info	Device Klima Schlafzimmer created.
      	2025-01-09 05:35:07.721	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.719	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.717	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.707	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.706	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.704	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.702	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.694	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.692	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.691	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.690	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.689	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.687	info	Method "createState" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:07.678	info	Method "createDevice" is deprecated and will be removed in js-controller 7.1, use "extendObject/setObjectNotExists" instead
      	2025-01-09 05:35:05.882	info	Login successful.
      	2025-01-09 05:35:02.108	info	Loaded app version from GitHub: 1.21.0
      	2025-01-09 05:35:01.747	info	starting. Version 3.0.3 (non-npm: marc2016/ioBroker.panasonic-comfort-cloud#09cd3d9de2d1d948dfd4956b4719f3167d5c03e7) in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v20.18.0, js-controller: 7.0.6
      	2025-01-09 05:34:54.381	info	terminating
      	2025-01-09 05:34:53.880	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      	2025-01-09 05:34:53.878	info	terminating
      	2025-01-09 05:34:53.877	info	cleaned everything up...
      	2025-01-09 05:34:53.865	info	Got terminate signal TERMINATE_YOURSELF
      • mcm1957
        mcm1957 @ecurb last edited by mcm1957
        @ecurb said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
        Kann mir jemand weiterhelfen?
        https://forum.iobroker.net/topic/51555/hinweise-für-gute-forenbeiträge
        Um sinnvoll zu helfen, bitte mal die Versionen der beteiligten Software angeben.
        Adapter?
        js-controller?
        Node ?
        Am besten den Output der LANGFASSUNG von ionb diag hier und unter code tags posten.
          ecurb @mcm1957 last edited by ecurb
          @emil70
          Hey Also das kommt wenn ich alles gelöscht habe und neu Starte:
             2025-01-09 21:48:16.258	error	Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid') at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:107:40 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:105:54 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:104:49) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
             2025-01-09 21:48:15.388	info	Login successful.
             2025-01-09 21:48:11.921	info	Loaded app version from GitHub: 1.21.0
             2025-01-09 21:48:11.692	info	starting. Version 3.0.3 (non-npm: marc2016/ioBroker.panasonic-comfort-cloud#2f7ea2238b31a5ebc0ad234f8145f1bbfcf3e802) in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v20.18.1, js-controller: 7.0.3
             2025-01-09 21:48:05.985	info	terminating
             2025-01-09 21:48:05.483	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
             2025-01-09 21:48:05.483	info	terminating
             2025-01-09 21:48:05.482	info	cleaned everything up...
             2025-01-09 21:48:05.480	info	Got terminate signal TERMINATE_YOURSELF
          @mcm1957
          ja hätte ich auch direkt mal mit senden können.
          Ist das so richtig? Bzw. welches von den beiden macht mehr sinn?
                                  v.2024-10-19
           Static hostname: PI
                 Icon name: computer
                    Kernel: Linux 6.6.51+rpt-rpi-v8
              Architecture: arm64
          Installation:           native
          Kernel:                 aarch64
          Userland:               64 bit
          Timezone:               Europe/Berlin (CET, +0100)
          User-ID:                1000
          Display-Server:         false
          Boot Target:            graphical.target
          Pending OS-Updates:     47
          Pending iob updates:    6
          Nodejs-Installation:
          /usr/bin/nodejs         v20.18.1
          /usr/bin/node           v20.18.1
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          /usr/bin/corepack       0.29.4
          Recommended versions are nodejs 20.18.1 and npm 10.8.2
          nodeJS installation is correct
          MEMORY:
          Mem:            4.0G        1.2G        890M         23M        2.0G        2.8G
          Swap:           536M          0B        536M
          Total:          4.5G        1.2G        1.4G
          Active iob-Instances:   5
          Upgrade policy: none
          ioBroker Core:          js-controller           7.0.3
                                  admin                   7.4.10
          Objects type: jsonl
          States  type: jsonl
          + system.adapter.admin.0                  : admin                 : PI                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            system.adapter.web.0                    : web                   : PI                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          Objects:                1433
          States:                 1170
          Size of iob-Database:
          6.5M    /opt/iobroker/iobroker-data/objects.jsonl
          648K    /opt/iobroker/iobroker-data/states.jsonl
          Operating System is the current Debian stable version codenamed 'bookworm'!
          Script v.2024-10-19
          *** BASE SYSTEM ***
           Static hostname: PI
                 Icon name: computer
              Architecture: arm64
          OS is similar to:
          Model           : Raspberry Pi 4 Model B Rev 1.5
          Docker          : false
          Virtualization  : none
          Kernel          : aarch64
          Userland        : 64 bit
          Systemuptime and Load:
           21:52:42 up 4 days,  7:23,  4 users,  load average: 0.33, 0.68, 0.55
          CPU threads: 4
          *** LIFE CYCLE STATUS ***
          *** RASPBERRY THROTTLING ***
          Current issues:
          Previously detected issues:
          *** TIME AND TIMEZONES ***
                         Local time: Thu 2025-01-09 21:52:42 CET
                     Universal time: Thu 2025-01-09 20:52:42 UTC
                           RTC time: n/a
                        NTP service: active
                    RTC in local TZ: no
          *** Users and Groups ***
          User that called 'iob diag':
          IO-Broker_Matthias
          HOME=/home/IO-Broker_Matthias
          GROUPS=IO-Broker_Matthias adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin gpio i2c spi iobroker
          iobroker
          HOME=/home/iobroker
          GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
          *** DISPLAY-SERVER SETUP ***
          Desktop:
          Terminal:       tty
          System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
          *** MEMORY ***
          Mem:            4.0G        1.2G        902M         23M        2.0G        2.8G
          Swap:           536M          0B        536M
          Active iob-Instances:   14
                   3791 M total memory
                   1139 M used memory
                   1413 M active memory
                   1249 M inactive memory
                    860 M free memory
                    153 M buffer memory
                   1736 M swap cache
                    511 M total swap
                      0 M used swap
                    511 M free swap
          top - 21:52:43 up 4 days,  7:23,  4 users,  load average: 0.33, 0.68, 0.55
          Tasks: 224 total,   1 running, 223 sleeping,   0 stopped,   0 zombie
          %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
          MiB Mem :   3792.0 total,    860.5 free,   1139.6 used,   1889.7 buff/cache
          MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2652.4 avail Mem
          *** FAILED SERVICES ***
          0 loaded units listed.
          *** DMESG CRITICAL ERRORS ***
          No critical errors detected
          *** FILESYSTEM ***
          udev           devtmpfs  1.6G     0  1.6G   0% /dev
          tmpfs          tmpfs     380M  1.3M  378M   1% /run
          /dev/mmcblk0p2 ext4       57G  8.8G   46G  17% /
          tmpfs          tmpfs     1.9G  216K  1.9G   1% /dev/shm
          /dev/mmcblk0p1 vfat      510M   76M  435M  15% /boot/firmware
          tmpfs          tmpfs     380M   48K  380M   1% /run/user/1000
          [Sun Jan  5 14:28:58 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=D8:3A:DD:96:40:AB vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=5756260d-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
          [Sun Jan  5 14:29:05 2025] EXT4-fs (mmcblk0p2): mounted filesystem a36be96c-66be-4487-a7a6-0481bca99d89 ro with ordered data mode. Quota mode: none.
          [Sun Jan  5 14:29:08 2025] EXT4-fs (mmcblk0p2): re-mounted a36be96c-66be-4487-a7a6-0481bca99d89 r/w. Quota mode: none.
          Show mounted filesystems:
          TARGET               SOURCE         FSTYPE      OPTIONS
          /                    /dev/mmcblk0p2 ext4        rw,noatime
          |-/run/user/1000/doc portal         fuse.portal rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
          `-/boot/firmware     /dev/mmcblk0p1 vfat        rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
          /var:
          1.5G    /var/
          618M    /var/log
          523M    /var/log/journal/7329095d68b04839a916655656349e19
          195M    /var/lib
          Archived and active journals take up 522.8M in the file system.
          /opt/iobroker/backups:
          66M     /opt/iobroker/backups/
          /opt/iobroker/iobroker-data:
          936M    /opt/iobroker/iobroker-data/
          866M    /opt/iobroker/iobroker-data/files
          617M    /opt/iobroker/iobroker-data/files/javascript.admin
          560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
          558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
          24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
          12M     /opt/iobroker/iobroker-data/files/backitup.admin/static/js/main.bd24114f.js
          8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
          8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
          8.5M    /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js
          USB-Devices by-id:
          No Devices found 'by-id'
          *** NodeJS-Installation ***
          /usr/bin/npm            10.8.2
          /usr/bin/npx            10.8.2
          nodejs:
            Installed: 20.18.1-1nodesource1
            Candidate: 20.18.1-1nodesource1
            Version table:
           *** 20.18.1-1nodesource1 1001
                  500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                  100 /var/lib/dpkg/status
               20.18.0-1nodesource1 1001
               20.17.0-1nodesource1 1001
               20.16.0-1nodesource1 1001
               20.15.1-1nodesource1 1001
               20.15.0-1nodesource1 1001
               20.14.0-1nodesource1 1001
               20.13.1-1nodesource1 1001
               20.13.0-1nodesource1 1001
               20.12.2-1nodesource1 1001
               20.12.1-1nodesource1 1001
               20.12.0-1nodesource1 1001
               20.11.1-1nodesource1 1001
               20.11.0-1nodesource1 1001
               20.10.0-1nodesource1 1001
               20.9.0-1nodesource1 1001
               20.8.1-1nodesource1 1001
               20.8.0-1nodesource1 1001
               20.7.0-1nodesource1 1001
               20.6.1-1nodesource1 1001
               20.6.0-1nodesource1 1001
               20.5.1-1nodesource1 1001
               20.5.0-1nodesource1 1001
               20.4.0-1nodesource1 1001
               20.3.1-1nodesource1 1001
               20.3.0-1nodesource1 1001
               20.2.0-1nodesource1 1001
               20.1.0-1nodesource1 1001
               20.0.0-1nodesource1 1001
               18.19.0+dfsg-6~deb12u2 500
               18.19.0+dfsg-6~deb12u1 500
          No problems detected
          Errors in npm tree: 0
          *** ioBroker-Installation ***
          ioBroker Status
          Objects type: jsonl
          States  type: jsonl
          Hosts:
          PI         PI (version: 7.0.3, hostname: PI   , alive, uptime: 332)
          Core adapters versions
          admin:          7.4.10
          javascript:     8.8.3
          nodejs modules from github:     2
          +-- iobroker.panasonic-comfort-cloud@3.0.3 (git+ssh://git@github.com/marc2016/ioBroker.panasonic-comfort-cloud.git#2f7ea2238b31a5ebc0ad234f8145f1bbfcf3e802)
          +-- iobroker.repositories@1.0.4 (git+ssh://git@github.com/ioBroker/ioBroker.repositories.git#b565a6ffd7e97de5d097524c05d7fb97b06071a7)
          Adapter State
          + system.adapter.backitup.0               : backitup              : PI                              -  enabled
            system.adapter.bshb.0                   : bshb                  : PI                              - disabled
          + system.adapter.discovery.0              : discovery             : PI                              -  enabled
            system.adapter.flot.0                   : flot                  : PI                              -  enabled
          + system.adapter.history.0                : history               : PI                              -  enabled
          + system.adapter.javascript.0             : javascript            : PI                              -  enabled
          + system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: PI                              -  enabled
          + system.adapter.ping.0                   : ping                  : PI                              -  enabled
          + system.adapter.rpi2.0                   : rpi2                  : PI                              -  enabled
          + system.adapter.shelly.0                 : shelly                : PI                              -  enabled, port: 1882, bind: 0.0.0.0
            system.adapter.sun2000-modbus.0         : sun2000-modbus        : PI                              - disabled, port: 502
          + system.adapter.sun2000.0                : sun2000               : PI                              -  enabled, port: 502
          + system.adapter.tibberlink.0             : tibberlink            : PI                              -  enabled
          + system.adapter.tuya.0                   : tuya                  : PI                              -  enabled
            system.adapter.vis-2-widgets-energy.0   : vis-2-widgets-energy  : PI                              -  enabled
            system.adapter.vis-history.0            : vis-history           : PI                              -  enabled
            system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : PI                              -  enabled
            system.adapter.vis-justgage.0           : vis-justgage          : PI                              -  enabled
            system.adapter.vis.0                    : vis                   : PI                              -  enabled
          + system.adapter.web.0                    : web                   : PI                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
          + instance is alive
          ioBroker-Repositories
          Active repo(s): stable
          Installed ioBroker-Instances
          Used repository: stable
          Adapter    "admin"        : 7.4.10   , installed 7.4.10
          Adapter    "backitup"     : 3.0.31   , installed 3.0.25 [Updatable]
          Adapter    "bshb"         : 0.3.0    , installed 0.3.0
          Adapter    "javascript"   : 8.8.3    , installed 8.8.3
          Controller "js-controller": 7.0.6    , installed 7.0.3  [Updatable]
          Adapter    "panasonic-comfort-cloud": 3.0.3, installed 3.0.3
          Adapter    "rpi2"         : 2.2.1    , installed 2.0.0  [Updatable]
          Adapter    "shelly"       : 8.5.1    , installed 8.2.1  [Updatable]
          Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
          Adapter    "socketio"     : 6.7.1    , installed 6.6.1  [Updatable]
          Adapter    "sun2000"      : 0.17.1   , installed 0.17.1
          Adapter    "sun2000-modbus": 0.1.3   , installed 0.1.3
          Adapter    "tibberlink"   : 4.1.0    , installed 4.1.0
          Adapter    "tuya"         : 3.16.0   , installed 3.16.0
          Adapter    "vis-2-widgets-energy": 1.0.2, installed 1.0.2
          Adapter    "vis-justgage" : 2.1.7    , installed 2.1.7
          Adapter    "ws"           : 2.6.2    , installed 2.5.11 [Updatable]
          Objects and States
          Objects:        1433
          States:         1170
          Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
          Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
          Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
          Reading package lists...
          Pending Updates: 47
          *** Listening Ports ***
          tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       5013782    511268/io.shelly.0
          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1881       676/sshd: /usr/sbin
          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       5011350    511063/iobroker.js-
          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5011345    511063/iobroker.js-
          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3986659    403880/cupsd
          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       5014996    511474/io.web.0
          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       5012441    511081/io.admin.0
          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3986658    403880/cupsd
          tcp6       0      0 :::22                   :::*                    LISTEN      0          1883       676/sshd: /usr/sbin
          udp        0      0 0.0.0.0:35640           0.0.0.0:*                           104        6353       476/avahi-daemon: r
          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6351       476/avahi-daemon: r
          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       5013861    511392/io.tuya.0
          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       5013862    511392/io.tuya.0
          udp6       0      0 :::5353                 :::*                                104        6352       476/avahi-daemon: r
          udp6       0      0 :::44274                :::*                                104        6354       476/avahi-daemon: r
          udp6       0      0 fe80::de9e:cfdf:b68:546 :::*                                0          7736       601/NetworkManager
          2025-01-09 21:48:05.482  - info: panasonic-comfort-cloud.0 (511212) cleaned everything up...
          2025-01-09 21:48:05.483  - info: panasonic-comfort-cloud.0 (511212) terminating
          2025-01-09 21:48:05.483  - info: panasonic-comfort-cloud.0 (511212) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-01-09 21:48:05.527  - info: host.PI stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal
          2025-01-09 21:48:05.985  - info: panasonic-comfort-cloud.0 (511212) terminating
          2025-01-09 21:48:06.027  - info: host.PI instance system.adapter.panasonic-comfort-cloud.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-01-09 21:48:09.339  - info: host.PI instance system.adapter.panasonic-comfort-cloud.0 in version "3.0.3" (non-npm: marc2016/ioBroker.panasonic-comfort-cloud#2f7ea2238b31a5ebc0ad234f8145f1bbfcf3e802) started with pid 511512
          2025-01-09 21:48:11.692  - info: panasonic-comfort-cloud.0 (511512) starting. Version 3.0.3 (non-npm: marc2016/ioBroker.panasonic-comfort-cloud#2f7ea2238b31a5ebc0ad234f8145f1bbfcf3e802) in /opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud, node: v20.18.1, js-controller: 7.0.3
          2025-01-09 21:48:11.921  - info: panasonic-comfort-cloud.0 (511512) Loaded app version from GitHub: 1.21.0
          2025-01-09 21:48:15.388  - info: panasonic-comfort-cloud.0 (511512) Login successful.
          2025-01-09 21:48:16.258  - error: panasonic-comfort-cloud.0 (511512) Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid')
          2025-01-09 21:48:32.748  - info: tuya.0 (511392) bf0445af0a9326dqja8: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.73:6668
          2025-01-09 21:48:34.153  - info: tuya.0 (511392) bf2ab0ecafb19b4vptt: Error on Reconnect (5): connect EHOSTUNREACH 192.168.178.123:6668
          2025-01-09 21:49:35.816  - info: tuya.0 (511392) bf0445af0a9326dqja8: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.73:6668
          2025-01-09 21:49:37.223  - info: tuya.0 (511392) bf2ab0ecafb19b4vptt: Error on Reconnect (7): connect EHOSTUNREACH 192.168.178.123:6668
          Habe gerade noch den js-controller von 7.0.3 auf 7.0.6 gemacht. Fehler bleibt bestehen.
          • mcm1957
            nodejs modules from github: 2 +-- iobroker.panasonic-comfort-cloud@3.0.3 (git+ssh://git@github.com/marc2016/ioBroker.panasonic-comfort-cloud.git#2f7ea2238b31a5ebc0ad234f8145f1bbfcf3e802)
            **Warum installierst du von GITHUB? **
            Der Adapter ist ganz normal in beiden Repositories verfügbar. Wenn du kein Tester bist und nicht auf Aufforderung des Maintainers was ausprobieren sollt Hände weg von GitHub installationen.
            Installier den Adapter mal sauber.
            Warum installierst du iobroker.repositories?
            Keine Ahnung wie du das geschafft hast zu installieren (iobroker.repositories@1.0.4 ). Lass es uns bitte wissen. Das Repo ist kein adapter und kann nur mehr oder weniger massive Problem auslösen wenn es am Zielsystem installiert wird. Schau dass du es deinstallierst.
            Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
            GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
            Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
            Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
            Und falls es irgendwie unklar ist:
            ioBroker unterstützt folgende Arten von Installation:
            • aus dem STABLE Repository
              Das sind Adapter Releases die keine groben Fehler aufweisen (sollten). Natürlich kann es auch dort Fehler geben, die Behebung davon obliegt dem jeweiligen Dev und kann ggF auch dauern.
            • aus dem LATEST Repository
              Das sind Adapter Releases die neu erstellt wurden und nur rudimentär getestet sind - oft auch als BETA Releases bezeichnet. Releases aus dem LATEST sind primär für unsere zahlreichen freiwilligen Tester gedacht. BETA / LATEST Releases können durchaus Fehler aufweisen - auch wenn ich davon ausgehe dass jeder aintainer dies zu vermeiden versucht. Vom Einsatz auf produktiven Systemen wird abgeraten außer man braucht irgenein neues Feature (z.B. neues Gerät) unbedingt. Hier muss dann jeder Entscheiden was ihm wichtig ist.
            • direkt von GITHUB
              Von Installationen direkt aus Giuthub wird definitiv abgeraten außer auf Anweisung des Maintainers und für den Fall dass man gemeinsam mit diesem etwas testen will. Details siehe oben.
            • direkt von npm
              Diese Installation kann erforderlich sein, wenn man eine bestimmte Version installieren möchte / muss. Im Normalfall sollte man direkte npm Installationen ebenso meiden wie direkte GitHub Installationen - ausgenommen um z.B. zu einer bekannten Version downzugraden - obwohl hier wenigstens ein definierter Stand garantiert ist.
            Adapter die NUR via npm und/oder nur via GitHub installierbar sind sollte man meiden - diese wurden nicht mal einem rudimentären Review unterzogen und sollten mit dem Attribut "vollständig auf eigenes Risiko verwenden" installiert werden. Hier empfiehlt es sich den Developer zu ersuchen eine Aufnahme in die Repos zu veranlassen. Wenn dieser darauf nicht reagiert sollte man von einer eher kurzen und unklaren Lebensdauer des Adapters ausgehen. Support meiner-/unsererseits für solche Adapter ist mit sicherheit minimalistisch.
            @mcm1957
            Comment
            Leave a comment
            Footer
              ecurb last edited by ecurb
              @mcm1957 said in Panasonic comfort cloud Adapter funktioniert nicht mehr:
              weil ich schon sehr viel rumprobiert habe. Ich habe erst alle möglichen Versionen direkt über IObroker getestet und gesucht im internet. Irgend wo bin ich auf einen eintrag gestoßen das die Hinterlegte Version fehlerhaft sei und man es über GitHub versuchen solle.
              Warum ich das repositories installiert habe weiß ich mittlerweile auch nicht mehr. Ich denke das selbe weil ich es irgend wo gelesen habe.
              Egal ich habe den Panasonic adapter löschen können. Beim Repositories konnte ich nur den Ordner direkt im PI löschen.
              Hier weiß ich jetzt aber nicht ob es wirklich gelöscht ist.
              Nach dem Restart vom IO-Broker und einiger zeit taucht das Repositories wieder auf.
              Ich werde mal einen neuen PI aufsetzen und nur diesen einen Adapter instalieren. Mal schauen was dann passiert.
                habe gerade einen PI neu aufgesetzt.
                Es ist ein älteres model aber das sollte ja nicht die rolle spielen.
                IO-Broker haben ich mit dem befehl "curl -sLf https://iobroker.net/install.sh | bash -" instaliert.
                Das sagt der Adapter wenn er neu gestartet wird:
                	2025-01-10 21:09:26.568	error	Unknown error: TypeError: Cannot set properties of undefined (setting 'guid'). Stack: TypeError: Cannot set properties of undefined (setting 'guid') at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:99:40 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at /opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:97:54 at arrayMap (/opt/iobroker/node_modules/lodash/lodash.js:653:23) at Function.map (/opt/iobroker/node_modules/lodash/lodash.js:9622:14) at ComfortCloudClient.getGroups (/opt/iobroker/node_modules/panasonic-comfort-cloud-client/dist/src/ComfortCloudClient.js:96:49) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async PanasonicComfortCloud.onReady (/opt/iobroker/node_modules/iobroker.panasonic-comfort-cloud/build/main.js:72:24)
                	2025-01-10 21:09:25.887	info	Login successful.
                	2025-01-10 21:09:21.992	info	Loaded app version from GitHub: 1.21.0
                Script v.2024-10-19
                *** BASE SYSTEM ***
                 Static hostname: IO-PI
                       Icon name: computer
                    Architecture: arm64
                OS is similar to:
                Model           : Raspberry Pi 3 Model B Rev 1.2
                Docker          : false
                Kernel          : aarch64
                Userland        : 64 bit
                 21:13:43 up 30 min,  2 users,  load average: 0.58, 0.64, 0.84
                CPU threads: 4
                Current issues:
                               Local time: Fri 2025-01-10 21:13:43 CET
                           Universal time: Fri 2025-01-10 20:13:43 UTC
                                 RTC time: n/a
                              NTP service: active
                          RTC in local TZ: no
                Test
                HOME=/home/Test
                GROUPS=Test adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                js-controller is not running
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            951M        152M        517M        196K        349M        799M
                Swap:           536M         18M        518M
                Total:          1.5G        170M        1.0G
                          907 M total memory
                          144 M used memory
                          113 M active memory
                          186 M inactive memory
                          493 M free memory
                           13 M buffer memory
                          319 M swap cache
                          511 M total swap
                           17 M used swap
                          494 M free swap
                top - 21:13:44 up 30 min,  2 users,  load average: 0.58, 0.64, 0.84
                Tasks: 147 total,   1 running, 146 sleeping,   0 stopped,   0 zombie
                MiB Mem :    907.3 total,    492.8 free,    145.6 used,    333.3 buff/cache
                MiB Swap:    512.0 total,    494.7 free,     17.2 used.    761.7 avail Mem
                  UNIT             LOAD   ACTIVE SUB    DESCRIPTION
                * iobroker.service loaded failed failed ioBroker Server
                LOAD   = Reflects whether the unit definition was properly loaded.
                ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                SUB    = The low-level unit activation state, values depend on unit type.
                1 loaded units listed.
                *** FILESYSTEM ***
                udev           devtmpfs  318M     0  318M   0% /dev
                tmpfs          tmpfs      91M 1008K   90M   2% /run
                /dev/mmcblk0p2 ext4       15G  3.6G  9.8G  27% /
                tmpfs          tmpfs     454M     0  454M   0% /dev/shm
                tmpfs          tmpfs     5.0M   12K  5.0M   1% /run/lock
                /dev/mmcblk0p1 vfat      510M   64M  447M  13% /boot/firmware
                tmpfs          tmpfs      91M     0   91M   0% /run/user/1000
                [Fri Jan 10 20:42:44 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=4cb582d8-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                [Fri Jan 10 20:42:48 2025] EXT4-fs (mmcblk0p2): mounted filesystem ce208fd3-38a8-424a-87a2-cd44114eb820 ro with ordered data mode. Quota mode: none.
                [Fri Jan 10 20:42:51 2025] EXT4-fs (mmcblk0p2): re-mounted ce208fd3-38a8-424a-87a2-cd44114eb820 r/w. Quota mode: none.
                /var:
                917M    /var/
                205M    /var/cache
                200M    /var/cache/apt
                164M    /var/lib
                135M    /var/lib/apt/lists
                Archived and active journals take up 36.0M in the file system.
                4.0K    /opt/iobroker/backups/
                181M    /opt/iobroker/iobroker-data/
                176M    /opt/iobroker/iobroker-data/files
                158M    /opt/iobroker/iobroker-data/files/admin.admin
                157M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js
                7.4M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_iobroker_adapter-react-v5_node_modules_mui_icons-material_esm_index_js.d7ed606b.chunk.js.map
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.e5b40573.chunk.js.map
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.8219fdd8.chunk.js.map
                7.0M    /opt/iobroker/iobroker-data/files/admin.admin/custom/static/js/vendors-node_modules_mui_icons-material_esm_index_js.358dc38e.chunk.js.map
                6.8M    /opt/iobroker/iobroker-data/files/backitup.admin/custom/static/js/vendors-node_modules_file-saver_dist_FileSaver_min_js-node_modules_react-icons_di_index_mjs-n-0fd47d.a444afaa.chunk.js
                USB-Devices by-id:
                /usr/bin/npm            10.8.2
                /usr/bin/npx            10.8.2
                nodejs:
                  Version table:
                ioBroker Status
                iobroker is not running on this host.
                Objects type: jsonl
                States  type: jsonl
                Hosts:
                IO-PI         IO-PI (version: 7.0.6, hostname: IO-PI   , alive, uptime: 652)
                admin:          7.4.10
                javascript:     "javascript" not found
                nodejs modules from github:     0
                Adapter State
                  system.adapter.admin.0                  : admin                 : IO-PI                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  system.adapter.backitup.0               : backitup              : IO-PI                              -  enabled
                  system.adapter.discovery.0              : discovery             : IO-PI                              -  enabled
                  system.adapter.panasonic-comfort-cloud.0: panasonic-comfort-cloud: IO-PI                              -  enabled
                + instance is alive
                Adapter    "backitup"     : 3.0.31   , installed 3.0.31
                Controller "js-controller": 7.0.6    , installed 7.0.6
                Objects and States
                Objects:        170
                States:         87
                Pending Updates: 12
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          2534       548/sshd: /usr/sbin
                tcp6       0      0 :::22                   :::*                    LISTEN      0          2536       548/sshd: /usr/sbin
                udp        0      0 0.0.0.0:39976           0.0.0.0:*                           104        4733       380/avahi-daemon: r
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4731       380/avahi-daemon: r
                udp6       0      0 fe80::670f:5c02:79f:546 :::*                                0          5547       441/NetworkManager
                udp6       0      0 :::51930                :::*                                104        4734       380/avahi-daemon: r
                udp6       0      0 :::5353                 :::*                                104        4732       380/avahi-daemon: r
                2025-01-10 21:12:34.664  - info: panasonic-comfort-cloud.0 (9739) Got terminate signal TERMINATE_YOURSELF
                2025-01-10 21:12:34.660  - info: discovery.0 (9515) Got terminate signal TERMINATE_YOURSELF
                2025-01-10 21:12:34.676  - info: discovery.0 (9515) terminating
                2025-01-10 21:12:34.679  - info: admin.0 (9489) Got terminate signal TERMINATE_YOURSELF
                2025-01-10 21:12:34.682  - info: host.IO-PI stopInstance system.adapter.admin.0 send kill signal
                2025-01-10 21:12:34.681  - info: discovery.0 (9515) Terminated (NO_ERROR): Without reason
                2025-01-10 21:12:34.684  - info: host.IO-PI stopInstance system.adapter.backitup.0 send kill signal
                2025-01-10 21:12:34.685  - info: host.IO-PI stopInstance system.adapter.discovery.0 send kill signal
                2025-01-10 21:12:34.686  - info: host.IO-PI stopInstance system.adapter.panasonic-comfort-cloud.0 send kill signal
                2025-01-10 21:12:34.702  - info: admin.0 (9489) terminating
                2025-01-10 21:12:34.705  - info: admin.0 (9489) Terminated (NO_ERROR): Without reason
                2025-01-10 21:12:34.718  - info: backitup.0 (9496) terminating
                2025-01-10 21:12:34.722  - info: backitup.0 (9496) Terminated (NO_ERROR): Without reason
                2025-01-10 21:12:34.726  - info: panasonic-comfort-cloud.0 (9739) terminating
                2025-01-10 21:12:34.729  - info: panasonic-comfort-cloud.0 (9739) Terminated (NO_ERROR): Without reason
                2025-01-10 21:12:35.126  - info: discovery.0 (9515) terminating
                2025-01-10 21:12:35.135  - info: backitup.0 (9496) terminating
                2025-01-10 21:12:35.142  - info: panasonic-comfort-cloud.0 (9739) terminating
                2025-01-10 21:12:35.174  - info: admin.0 (9489) terminating
                2025-01-10 21:12:35.288  - info: host.IO-PI instance system.adapter.discovery.0 terminated with code 0 (NO_ERROR)
                2025-01-10 21:12:35.343  - info: host.IO-PI instance system.adapter.admin.0 terminated with code 0 (NO_ERROR)
                2025-01-10 21:12:35.375  - info: host.IO-PI instance system.adapter.backitup.0 terminated with code 0 (NO_ERROR)
                2025-01-10 21:12:35.415  - info: host.IO-PI instance system.adapter.panasonic-comfort-cloud.0 terminated with code 0 (NO_ERROR)
                2025-01-10 21:12:35.416  - info: host.IO-PI All instances are stopped.
                2025-01-10 21:12:35.511  - info: host.IO-PI terminated
                • mcm1957
                  @ecurb
                  Sieht nach diesem Issue aus
                  https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/60
                  Infos dazu kann nur der dev geben.
                  filiprozanski created this issue in marc2016/ioBroker.panasonic-comfort-cloud
                  open Cannot set properties of undefined (setting 'guid'). #60
                    rainereglinsky last edited by
                    Heute hat Panasonic mal wieder was geändert, neue Datenschutzrichtlinie und natürlich wohl Änderungen am System. Der aktuelle Adapter v3.0.3 aus dem Github von Marc2016 verbindet sich nicht mehr.
                      emil70 last edited by Homoran
                      issue: (https://github.com/marc2016/ioBroker.panasonic-comfort-cloud/issues/79) ist dazu schon eröffnet
                      DevForGit created this issue in marc2016/ioBroker.panasonic-comfort-cloud
                      open iobroker-adapter panasonic-comfort-cloud cannot connect to panasonic cloud #79
                        Mit 2.1.0 geht es
                          grombiegel last edited by
                          mit 2.1.0 werden die Objekte bei mir angelegt, aber leider wird kein Status mit der Klima ausgetauscht.
                          Egal ob ein/aus oder connected oder Temperatursensor - da verändert sich nichts, die Klima wird damit nicht ausgelesen.
                          Hat jemand noch eine Idee?
                          Deinstalliert und sämtliche andere Versionen haben nicht funktioniert.
                          Es ist echt ein Mist, gefühlt alle 6 Monate geht nix mehr....
                            emil70 @grombiegel last edited by
                            @grombiegel
                            Geht hier ohne Probleme. Ob mit App geschaltet oder über Alexa und meinem Blockly
                            Hast du lang genug gewartet?
                            Was hast du in den Einstellungen bei "Aktualisierungsintervall" eingestellt?
                              1 Minute, die Instanz ist sofort da, aber die Objekte werden nicht installiert - eben dachte ich das passt, Klima war an. Hab dann Temperatur geändert und ca. 5 Minuten später ausgeschaltet. connect wird angezeigt, jedoch steht operate jetzt immer noch auf On...temp set steht auch noch unverändert
                                emil70 @grombiegel last edited by emil70
                                @grombiegel
                                nutzt du das App und den Adapter mit den gleichem Benutzer und PW?
                                Oder hast du dir ein Zweitaccount gemacht?
                                  App und Adapter mit selben Zugangsdaten, App funktioniert auch korrekt
                                    nanu, jetzt funktioniert die Kommunikation, hatte nochmals die App aufgerufen eine Änderung durchgeführt und jetzt werden die Daten auch im Adapter aktualisiert - danke für die Unterstützung
                                    71
                                    7993
