    4. Mitsubishi Heavy Industries Split Klimaanlage
      saeft_2003 Most Active @hacki11 last edited by
      @hacki11
      geht heute bei mir so weiter... das andere Gerät (extra Instanz) im Wohnzimmer verhält sich ruhig.
      mhi-wfrac.1
      	2025-05-15 07:42:24.218	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 06:44:56.697	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 06:44:04.089	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 06:43:11.514	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 06:42:18.297	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:49:06.617	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:48:13.145	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:47:19.673	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:46:26.713	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:45:33.241	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:44:40.282	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:43:46.777	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:42:53.369	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 05:41:59.897	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 04:41:57.049	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 02:41:50.521	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 01:42:04.185	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
      mhi-wfrac.1
      	2025-05-15 00:41:40.378	error	Schlafzimmer: Could not get Data: Error: connect EHOSTUNREACH 192.168.178.32:51443
        hacki11 last edited by hacki11
        Ich hab mal ein Monitoring auf meine Geräte aktiviert.
        Hier sieht man durchaus ein paar Peaks (Monitoring geht auf Max, nicht auf Mittelwert - man sieht also immer den schlechtesten).
        Wenn man genauer reinzoomt, erkennt man, dass diese für einen Ping anhalten und der nächste Ping (10s später) geht wieder schnell:
        Das heißt, wenn das ein Restart gewesen sein sollte, geht er in <10s und hat dann auch wieder die Verbindung aufgebaut. Bei mir sehe ich die Log Einträge nicht, auch lässt sich dieses Stundenmuster nicht aus dem Monitoring ableiten.
        Unifi Client Daten sind nicht hervorragend, man sieht ein paar gelbe Striche aber in Summe Ok.
        Wie sieht eure Verbindungsqualität aus? Wie lange dauert es bei euch, bis das Gerät wieder erreichbar ist? Evtl. trägt die Verbindungsqualität dazu bei, dass das Gerät länger offline ist? Evtl. ist der reconnect langsamer?
          saeft_2003 Most Active @hacki11 last edited by saeft_2003
          @hacki11
          So siehts bei mir aus. Bei dem kurzen Aussetzer bin ich auf einen anderen AP gewechselt der zwar weiter weg ist, aber im Moment scheint es stabiler zu laufen.
            hacki11 @saeft_2003 last edited by
            @saeft_2003 Sieht ja nicht so schlecht aus - kannst du ein Monitoring aufsetzen um die Dauer der Reconnects zu messen?
              @hacki11
              Wüsste jetzt auf anhieb nicht wie ich das mache. Wenn dann müsstest du mir mal grob sagen wie genau das geht...
              Noch eine andere Frage. Wenn der Adapter gelb ist, versucht dieser dann in einem bestimmten Intervall sich wieder zu verbinden? Weil ich hatte es vor kurzem das der Adapter gelb war, hab diesen dann neugestartet und zack grün.
                Ich habe eine telegraf config für influxdb erstellt und visualisiere dann mit Grafana.
                Es scheint aber auch einen ping Adapter zu geben, das zusammen mit dem History Feature von iobroker sollte ein ähnliches Ergebnis liefern.
                  @saeft_2003 Es wird im angegebenen Interval abgefragt. Bei einer erfolgreichen Abfrage wird der Datenpunkt "online" auf true gesetzt. Bei jedem Intervall werden am Ende alle online Datenpunkte evaluiert und sofern alle true sind, wird der Gesamstatus auch aktualisiert. So sollte sich der Zustand auch ohne Neustart wieder fangen. Du könntest das nächste mal schauen, ob alle online Datenpunkte der aktiven Geräte true sind und der Adapterzustand dennoch gelb.
                    @hacki11 sagte in Mitsubishi Heavy Industries Split Klimaanlage:
                    Den ping andapter hab ich laufen, aber woher kommt die Zeit wie lang der ping gebraucht hat? Beim Adapter bekomme ich doch nur true oder false?
                      Alles klar falls das wieder vorkommt mache ich das.
                        saeft_2003 Most Active last edited by
                        Denke ich habs. Intervall ping alle 60 sek?
                          @saeft_2003 Jede Sekunde
                            @hacki11
                            Das lässt der ping adapter nicht zu. kürzester intervall sind alle 5 sek.
                              @saeft_2003 passt auch noch
                                @hacki11
                                Alles klar ich lass das mal bis morgen so laufen und schau ob ich in grafana was sehe und melde mich.
                                  @hacki11
                                  So was war jetzt um 11:42 43 und 44? Keine Verbindung? Wieso?
                                  Thomas Braun H 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @saeft_2003 last edited by
                                    @saeft_2003
                                    Das sieht mir nach einer schlechten WLAN-Verbindung aus.
                                      @saeft_2003 Nimm mal den alive mit in die history auf. Aber man sieht schon schön ne Lücke in dem Graphen. Vermutlich gab’s keine Werte und es wird linear mit dem ersten Ping der wiederkommt verbunden? Zumindest würde das den Graphen erklären.
                                        Ich hab die Klima jetzt wieder auf den AP gelockt der theoretisch am besten ist. Normalerweise muss die Verbindung hier top sein. Luftlinie ist der nur 2m weg und nur dünne Wände dazwischen. Andere Geräte zum Teil weiter weg haben null Probleme.
                                          @saeft_2003 Mein IG nimmt auch immer den weiter entfernten AP statt dem der 4m entfernt steht. Roaming ist in dem WLAN deaktiviert, da viele IOT Geräte damit nicht klar kommen. Das IG vermutlich gleich dreimal nicht.
                                          MrLarodos 1 Reply Last reply Reply Quote 0
                                          • MrLarodos
                                            MrLarodos @hacki11 last edited by MrLarodos
                                            @hacki11 Ich habe das WLAN so konfiguriert, dass die Geräte in einem separaten WLAN in 2.4Ghz am jeweils nächstliegenden AP eingesperrt sind. Habe kurz ein Shellscript für Linux mit Chat GPT entwickelt, was ne csv mitloggt (im Subfolder "Log" im Scriptordner. Inhalt der CSV:
                                            Name;Zeitstempel;Erreichbar;Zeit(ms)
                                            Klima-Spitzboden;2025-05-15 13:39:18;True;30.4
                                            Klima-K1;2025-05-15 13:39:18;True;85.3
                                            Klima-K2;2025-05-15 13:39:18;True;95.8
                                            Ist auch ein Billigfrontend drauf:
                                            Hier das Script (IPs und Aliase anpassen!):
                                            #!/bin/bash
                                            # Intervall in Sekunden
                                            INTERVAL=5
                                            # IP-Adressen und Aliasnamen
                                            IPS=("192.168.120.135" "192.168.120.138" "192.168.120.137" "192.168.120.136" "192.168.120.166")
                                            ALIASES=("Klima-Spitzboden" "Klima-K1" "Klima-K2" "Klima-Esszimmer" "Klima-Buero")
                                            # Logging-Verzeichnis und -Datei
                                            SCRIPT_DIR="$(cd "$(dirname "${BASH_SOURCE[0]}")" && pwd)"
                                            LOG_DIR="$SCRIPT_DIR/log"
                                            CSV_FILE="$LOG_DIR/ping_log.csv"
                                            mkdir -p "$LOG_DIR"
                                            # CSV-Datei initialisieren, falls noch nicht vorhanden
                                            if [ ! -f "$CSV_FILE" ]; then
                                                echo "Name;Zeitstempel;Erreichbar;Zeit(ms)" >> "$CSV_FILE"
                                            fi
                                            # Statusspeicher
                                            declare -A LAST_RESPONSE
                                            declare -A LAST_SEEN_DOWN
                                            # Spaltenbreiten
                                            WIDTH_ALIAS=20
                                            WIDTH_REACH=12
                                            WIDTH_TIME=10
                                            WIDTH_LASTDOWN=25
                                            # Initialisieren
                                            for alias in "${ALIASES[@]}"; do
                                                LAST_RESPONSE["$alias"]="-"
                                                LAST_SEEN_DOWN["$alias"]="-"
                                            done
                                            # Letzte bekannte False-Zeiten aus CSV rekonstruieren
                                            if [ -f "$CSV_FILE" ]; then
                                                    last_false=$(grep "^$alias;" "$CSV_FILE" | grep ";False;" | tail -n 1 | cut -d';' -f2)
                                                    if [ -n "$last_false" ]; then
                                                        epoch=$(date -d "$last_false" +%s 2>/dev/null)
                                                        if [ -n "$epoch" ]; then
                                                            LAST_SEEN_DOWN["$alias"]=$epoch
                                                        fi
                                                    fi
                                                done
                                            fi
                                            # Funktion für menschenlesbare Zeitangabe
                                            time_diff_human() {
                                                local last_time=$1
                                                [[ "$last_time" == "-" ]] && echo "-" && return
                                                local now=$(date +%s)
                                                local diff=$((now - last_time))
                                                (( diff < 60 )) && echo "vor $diff Sek." && return
                                                (( diff < 3600 )) && echo "vor $((diff / 60)) Min." && return
                                                echo "vor $((diff / 3600)) Std."
                                            # Hauptschleife
                                            while true; do
                                                clear
                                                printf "%-${WIDTH_ALIAS}s | %-${WIDTH_REACH}s | %-${WIDTH_TIME}s | %-${WIDTH_LASTDOWN}s\n" "Alias" "Erreichbar" "Zeit(ms)" "Nicht erreichbar vor"
                                                printf "%-${WIDTH_ALIAS}s-+-%-${WIDTH_REACH}s-+-%-${WIDTH_TIME}s-+-%-${WIDTH_LASTDOWN}s\n" \
                                                    "$(printf '─%.0s' $(seq 1 $WIDTH_ALIAS))" \
                                                    "$(printf '─%.0s' $(seq 1 $WIDTH_REACH))" \
                                                    "$(printf '─%.0s' $(seq 1 $WIDTH_TIME))" \
                                                    "$(printf '─%.0s' $(seq 1 $WIDTH_LASTDOWN))"
                                                for i in "${!IPS[@]}"; do
                                                    IP=${IPS[$i]}
                                                    NAME=${ALIASES[$i]}
                                                    TIMESTAMP_HUMAN=$(date '+%Y-%m-%d %H:%M:%S')
                                                    TIMESTAMP_EPOCH=$(date +%s)
                                                    PING_OUTPUT=$(ping -c 1 -W 1 "$IP" 2>/dev/null)
                                                    if echo "$PING_OUTPUT" | grep -q "1 received"; then
                                                        TIME_MS=$(echo "$PING_OUTPUT" | grep "time=" | sed -E 's/.*time=([0-9.]+) ms/\1/')
                                                        LAST_RESPONSE["$NAME"]=$TIME_MS
                                                        REACH="Ja"
                                                        DOWNTIME=$(time_diff_human "${LAST_SEEN_DOWN[$NAME]}")
                                                        echo "$NAME;$TIMESTAMP_HUMAN;True;$TIME_MS" >> "$CSV_FILE"
                                                    else
                                                        REACH="Nein"
                                                        TIME_MS="-"
                                                        if [[ "${LAST_SEEN_DOWN[$NAME]}" == "-" ]]; then
                                                            LAST_SEEN_DOWN["$NAME"]=$TIMESTAMP_EPOCH
                                                        fi
                                                        echo "$NAME;$TIMESTAMP_HUMAN;False;" >> "$CSV_FILE"
                                                    fi
                                                    printf "%-${WIDTH_ALIAS}s | %-${WIDTH_REACH}s | %-${WIDTH_TIME}s | %-${WIDTH_LASTDOWN}s\n" \
                                                        "$NAME" "$REACH" "${LAST_RESPONSE[$NAME]}" "$DOWNTIME"
                                                done
                                                sleep "$INTERVAL"
                                            done
                                            Falls Ihr irgendwo Linux habt, könnt Ihr das da laufen lassen.
                                            Und hier das Script, um die CSV als Bild darzustellen:
                                            #!/usr/bin/env python3
                                            import pandas as pd
                                            import matplotlib.pyplot as plt
                                            from datetime import timedelta
                                            import matplotlib.dates as mdates
                                            import os
                                            # 🕒 Benutzerabfrage zum Stundenbereich
                                            try:
                                                user_input = input("Wie viele Stunden zurück anzeigen? [Default: 24]: ").strip()
                                                MAX_HOURS = int(user_input) if user_input else 24
                                            except Exception:
                                                MAX_HOURS = 24
                                            # 📥 CSV einlesen
                                            CSV_PATH = "./log/ping_log.csv"
                                            df = pd.read_csv(CSV_PATH, sep=';')
                                            df['Zeitstempel'] = pd.to_datetime(df['Zeitstempel'], format="%Y-%m-%d %H:%M:%S")
                                            df['Farbe'] = df['Erreichbar'].apply(lambda x: 'green' if str(x).strip().lower() == 'true' else 'red')
                                            df['Erreichbar_bool'] = df['Erreichbar'].apply(lambda x: str(x).strip().lower() == 'true')
                                            # 🧭 Zeitbereich setzen
                                            latest_time = df['Zeitstempel'].max()
                                            earliest_time = df['Zeitstempel'].min()
                                            start_time = max(earliest_time, latest_time - timedelta(hours=MAX_HOURS))
                                            df = df[df['Zeitstempel'] >= start_time].copy()
                                            # 📋 Aliasnamen extrahieren
                                            aliases = df['Name'].unique()
                                            aliases_sorted = list(aliases)
                                            # 📁 Diagrammverzeichnis erstellen
                                            output_dir = "./diagramm_pix"
                                            os.makedirs(output_dir, exist_ok=True)
                                            # 📊 Plot vorbereiten
                                            fig, ax = plt.subplots(figsize=(14, len(aliases_sorted) * 1.2))
                                            def plot_status_blocks(data, y_pos):
                                                current_color = None
                                                block_start = None
                                                for _, row in data.iterrows():
                                                    color = row['Farbe']
                                                    timestamp = row['Zeitstempel']
                                                    if color != current_color:
                                                        if current_color is not None:
                                                            duration = (timestamp - block_start).total_seconds()
                                                            ax.barh(
        y=y_pos,
        width=duration / 3600,
        left=block_start,
        height=0.6,
        color=current_color,
        edgecolor='none'
                                                        block_start = timestamp
                                                        current_color = color
                                                if block_start is not None and current_color is not None:
                                                    duration = (latest_time - block_start).total_seconds()
                                                    ax.barh(
                                                        y=y_pos,
                                                        left=block_start,
                                                        height=0.6,
                                                        edgecolor='none'
                                            for i, alias in enumerate(aliases_sorted):
                                                data = df[df['Name'] == alias].sort_values(by='Zeitstempel')
                                                plot_status_blocks(data, i)
                                            # 📐 Achsen und Format
                                            ax.set_yticks(range(len(aliases_sorted)))
                                            ax.set_yticklabels(aliases_sorted)
                                            ax.set_xlim(start_time, latest_time)
                                            ax.invert_yaxis()
                                            ax.xaxis.set_major_formatter(mdates.DateFormatter('%H:%M'))
                                            ax.set_xlabel("Uhrzeit")
                                            ax.set_title("Erreichbarkeit der IPs – zusammenhängende Zustandsbereiche")
                                            plt.grid(axis='x', linestyle='--', alpha=0.5)
                                            plt.tight_layout()
                                            # 💾 Bild speichern
                                            image_filename = f"{output_dir}/ping_status_{latest_time.strftime('%Y%m%d_%H%M%S')}.png"
                                            plt.savefig(image_filename)
                                            plt.show()
                                            # 📋 Zusammenfassung pro Alias
                                            print("\nZusammenfassung:")
                                            total_minutes = MAX_HOURS * 60
                                            for alias in aliases_sorted:
                                                alias_data = df[df['Name'] == alias].sort_values(by='Zeitstempel')
                                                alias_data['diff'] = alias_data['Zeitstempel'].diff().dt.total_seconds().fillna(0)
                                                # Statuswechsel ermitteln
                                                alias_data['is_new_block'] = (alias_data['Erreichbar_bool'] != alias_data['Erreichbar_bool'].shift())
                                                alias_data['block_id'] = alias_data['is_new_block'].cumsum()
                                                # Offline-Blöcke
                                                false_blocks = alias_data[alias_data['Erreichbar_bool'] == False]
                                                grouped = false_blocks.groupby('block_id')
                                                total_offline_secs = grouped['diff'].sum().sum()
                                                total_offline_minutes = round(total_offline_secs / 60, 2)
                                                total_outages = grouped.ngroups
                                                outages_per_hour = round(total_outages / MAX_HOURS, 2)
                                                avg_offline_per_hour = round(total_offline_minutes / MAX_HOURS, 2)
                                                # Antwortzeiten nur bei True
                                                true_responses = alias_data[alias_data['Erreichbar_bool'] == True].copy()
                                                true_responses['Zeit(ms)'] = pd.to_numeric(true_responses['Zeit(ms)'], errors='coerce')
                                                min_time = round(true_responses['Zeit(ms)'].min(), 2)
                                                avg_time = round(true_responses['Zeit(ms)'].mean(), 2)
                                                max_time = round(true_responses['Zeit(ms)'].max(), 2)
                                                print(f"{alias}:")
                                                print(f"  Gesamtofflinezeit:       {total_offline_minutes:.2f} Min")
                                                print(f"  Ø Offlinezeit/Stunde:    {avg_offline_per_hour:.2f} Min")
                                                print(f"  Gesamtzahl Ausfälle:     {total_outages}")
                                                print(f"  Ø Ausfälle/Stunde:       {outages_per_hour}")
                                                print(f"  Antwortzeit (Min/Ø/Max): {min_time:.2f} / {avg_time:.2f} / {max_time:.2f} ms\n")
                                            81.1k
                                            253
                                            44465
