    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. ESPHome .yaml Fehlermeldung Pillow Version
      Thomas Braun Most Active @wibear last edited by
      @wibear
      Möglich, dass der Adapter nun nochmal neu gegen diese Versionen gebaut werden muss.
        arteck Developer Most Active @wibear last edited by
        @wibear
        poste mal die yaml
          wibear @arteck last edited by
          @arteck sagte in ESPHome .yaml Fehlermeldung Pillow Version:
          poste mal die yaml
          Guten Morgen,
          hier ist die .yaml:
          esphome:
            friendly_name: DisplayTFT
          esp32:
            board: esp32dev
            framework:
              type: arduino
          # Enable logging
          logger:
          # Enable Home Assistant API
          api:
            encryption:
              key: "IO4KEPOkPtz/jTPUSMm0g/cXfLLVaASBj0sPdVqBXIA="
          ota:
            - platform: esphome
              password: "496d71850f34c0a977a7758765a1371b"
          wifi:
            ssid: !secret wifi_ssid
            password: !secret wifi_password
            # Enable fallback hotspot (captive portal) in case wifi connection fails
            ap:
              ssid: "Displaytft Fallback Hotspot"
              password: "IGrMeYGG3HaB"
          captive_portal:
          # Enable MQTT
          mqtt:
              discovery: true
              broker: 192.168.178.10
              port: 1883
              username: !secret mqtt_username
              password: !secret mqtt_password
              client_id: DisplayTFT
              topic_prefix: esphome
          # Subscribe data
          text_sensor:
            - platform: mqtt_subscribe
              topic: esphome/Display/PV/Einspeisung_Aktuell
              topic: esphome/Display/Netz/Verbrauch_Aktuell
              topic: esphome/Display/PV/Einspeisung_Monat
              topic: esphome/Display/Netz/Verbrauch_Monat
          # PSRAM an
          psram:
            mode: octal
            speed: 80MHz
          font:
            - file: "Fonts/Verdana.ttf"
              glyphs:
                ['&', '@', '!', ',', '.', '?', '"', '%', '(', ')', '+', '-', '_', ':', '°', '0',
                 '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
                 'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
                 'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
                 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
                 'u', 'v', 'w', 'x', 'y', 'z','å', 'Ä', 'ä', 'Ö', 'ö', 'Ü', 'ü', '/']
              glyphs:
              glyphs:
            - file: "Fonts/Verdana_Bold.ttf"
              glyphs:
            - file: "Fonts/materialdesignicons.ttf"
              glyphs:
              - "\U000F1A74" # Solar
              - "\U000F1904" # Haus
              - "\U000F1AAF" # Heizung
              - "\U000F058F" # Wasserhahn
          # Display configuration
          spi:
            clk_pin: GPIO22 # SCK
            mosi_pin: GPIO21 # SDA
          display:
            - platform: ili9xxx
              model: ILI9488
              dc_pin: GPIO19 # Register select / data-command
              reset_pin: GPIO4 # Chip select
              cs_pin: GPIO18
              device_width: 480
              device_height: 320
              rotation: 0
              col_start: 0
              row_start: 0
              invert_colors: false
              show_test_card: true
              eight_bit_color: true
              update_interval: 1s
          Danke und Grüße
            @wibear hast du die Fonts enstperechend runtergeladen und abgelegt ?
              wibear @arteck last edited by wibear
              @arteck
              Ja, die Fonts sind abgelegt. Ich habe es auch mit Google gfonts versucht: der gleiche Fehler.
                @wibear passen auch die rechte ??
                  @arteck
                  Guten Morgen, die Rechte habe ich nicht geändert.
                  Was meinst Du konkret bzw was soll ich überprüfen?
                    @arteck
                    Kann man im Code nachvollziehen, wann diese Fehlermeldung kommt?
                      @wibear sagte in ESPHome .yaml Fehlermeldung Pillow Version:
                      @arteck
                      das hab ich mir garnicht angeschaut.. zuerst sollten die parameter stimmen bevor ich anfange den Fehler zu suchen wo vielleicht keiner sit
                      also pass die rechte an
                      oder lass den
                      iob fix
                      laufen
                        @arteck
                        Welche Rechte konkret meinst Du?
                        Wie gesagt, ich habe keine geändert.
                        • simonf04
                          simonf04 last edited by simonf04
                          @wibear
                          Der Adapter verwendet sein eigenes venv in /home/iobroker/.cache/autopy/venv/esphome. Damit hier keine externen Abhängigkeiten bestehen.
                          Um das Permission Problem zu loesen am besten einfach komplett loeschen, Adapter erstellt es eh wieder neu:
                          sudo rm -rf /home/iobroker/.cache/autopy/venv/esphome.
                          Um eine aktuelle pillow version zu haben kannste meinen Branch testen:
                          https://github.com/SimonFischer04/ioBroker.esphome/tree/beta
                          W 2 Replies Last reply Reply Quote 0
                            wibear @simonf04 last edited by wibear
                            @simon42
                            Hallo Simon, nach der 1. Installation zeigte die Seite esphome: die Verbindung wurde abgelehnt. Dann deinstallierte ich ds und installierte es neu. Der Adapter erscheint zwar in der Adapterliste, nicht aber bei den Instanzen:
                            Danke und Grüße
                            simonf04 1 Reply Last reply Reply Quote 0
                            • simonf04
                              simonf04 @wibear last edited by
                              @wibear Fuer per Github installierte Adapter muss man extra eine Instanz anlegen, wird keine per default bei der Installation angelegt.
                                @simon42
                                Die Instanz angelegt, die Verbindung wird aber weiterhin abgelehnt:
                                  @simon42
                                  eine Warnmeldung:
                                  admin.0
                                  2025-05-18 13:32:21.637	warn	esphome has an invalid jsonConfig: [{"instancePath":"/items/devices/items/encryptionKey","schemaPath":"#/definitions/passwordProps/additionalProperties","keyword":"additionalProperties","params":{"additionalProperty":"freeSolo"},"message":"must NOT have additional properties"},{"instancePath":"/items/devices","schemaPath":"#/properties/items/patternProperties/%5E.%2B/allOf/9/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"},{"instancePath":"","schemaPath":"#/if","keyword":"if","params":{"failingKeyword":"then"},"message":"must match \"then\" schema"}]
                                    wibear @wibear last edited by
                                    auf einmal ist die Verbindung da...
                                      @simon42
                                      Vielen Dank, es werden mit Deiner Version keine Fehler in yaml mehr angezeigt. Jetzt muss ich suchen, warum das Display nichts anzegt. Grüße und einen schönen Sonntag.
                                      • simonf04
                                        @wibear ja, der braucht etwas beim ersten Start bzw. wennst die Dashboard Version änderst.
                                        Dashboard wird erst beim Adapter start dynamisch heruntergeladen.
                                        • simonf04
                                          @wibear Gern geschehen, ebenfalls schoenen Tag noch.
                                          • simonf04
                                            simonf04 @simonf04 last edited by
                                            @wibear Falls du es mit dem Display zum laufen bekommst waer ich tatsaechlich am yaml, ... interressiert.
                                            Muss auch bald was mit Display bauen und hab displays in esphome noch nicht wirklich verstanden.
                                            1.4k
                                            3735
