Problem mit unzureichendem Speicherplatz
@codierknecht Hatte gerade versucht vom Backup Adapter aus eine neue Sicherung durchzuführen. Da gab es eine Fehlermeldung bei der Influx Sicherung. Nach einem 2. Durchlauf sieht es jetzt wie unten dargestellt aus. Es scheint, das alle Daten eben nur lokal gesichert werden?
Die Einstellungen in der Backup Instanz sieht so aus.
11:43:20.780INFOguiBackup gestartet ... 11:43:22.899DEBUGiobrokerhost.ioBroker 18075 objects saved 11:43:23.531DEBUGiobrokerhost.ioBroker 15235 states saved 11:43:23.533DEBUGiobrokerhost.ioBroker Validating backup ... 11:43:23.576DEBUGiobrokerhost.ioBroker "config.json" is valid 11:43:23.579DEBUGiobrokerhost.ioBroker "objects.jsonl" exists 11:43:23.664DEBUGiobrokerhost.ioBroker "states.jsonl" exists 11:43:23.826DEBUGiobrokerhost.ioBroker JSONL lines are valid 11:43:23.830DEBUGiobrokerhost.ioBroker The backup is valid! 11:43:24.212DEBUGiobrokerBackup created: /opt/iobroker/backups/iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz 11:43:24.217DEBUGiobrokerThis backup can only be restored with js-controller version 7.0 or higher 11:43:25.226DEBUGiobrokerdone 11:43:25.379DEBUGinfluxDBInfluxDB-Backup started ... 11:43:25.382DEBUGinfluxDBInfluxDB Backup tmp directory created 11:43:28.329DEBUGinfluxDBTry deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker" 11:43:28.352DEBUGinfluxDB2025/03/10 11:43:25 backing up metastore to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/meta.00 2025/03/10 11:43:25 backing up db=iobroker 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1283 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01283.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1291 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01291.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1299 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01299.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1307 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01307.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1315 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01315.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1323 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01323.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:25 backing up db=iobroker rp=autogen shard=1331 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01331.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1339 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01339.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1347 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01347.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1355 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01355.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1363 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01363.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1371 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01371.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1379 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01379.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1387 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01387.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1395 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01395.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1403 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01403.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:26 backing up db=iobroker rp=autogen shard=1411 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01411.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1419 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01419.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1427 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01427.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1435 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01435.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1443 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01443.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1451 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01451.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1459 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01459.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1467 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01467.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1475 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01475.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:27 backing up db=iobroker rp=autogen shard=1483 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01483.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1491 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01491.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1499 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01499.00 since 0001-01-01T00:00:00Z 2025/03/10 11:43:28 backing up db=iobroker rp=autogen shard=1507 to /opt/iobroker/backups/influxDB_2025_03_10-11_43_25_backupiobroker/iobroker.autogen.01507.00 since 0001-01-01T00:00:00Z 11:43:28.401DEBUGinfluxDBdone 11:43:29.246DEBUGzigbeefound zigbee database: zigbee.0,zigbee.1 11:43:29.289DEBUGzigbeedone 11:43:29.550DEBUGgrafanaStart Grafana Backup ... 11:43:29.553DEBUGgrafanaCreated dashboards_manually_restore directory 11:43:29.557DEBUGgrafanastart Grafana request ... 11:43:29.599DEBUGgrafanaGrafana is available ... Status: 200 11:43:29.603DEBUGgrafanafound Dashboard: heizung 11:43:29.605DEBUGgrafanafound Dashboard: new-dashboard-copy 11:43:29.608DEBUGgrafanafound Dashboard: espeasy-2 11:43:29.652DEBUGgrafanafound Dashboard: 1-dashboard 11:43:29.712DEBUGgrafanastart Grafana backup compress ... 11:43:34.723DEBUGgrafanaTry deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp" 11:43:34.769DEBUGgrafanadone 11:43:34.875DEBUGjarvisCreated jarvis_tmp directory: "/opt/iobroker/backups/tmpJavis0" 11:43:34.878DEBUGjarvisfound Jarvis Instance: 0 11:43:34.892DEBUGjarvisstart Jarvis Backup for Instance 0... 11:43:34.893DEBUGjarvis/opt/iobroker/iobroker-data/jarvis/0 copy success! 11:43:34.924DEBUGjarvisCreated states_tmp directory: "/opt/iobroker/backups/tmpJavis0/states" 11:43:35.025DEBUGjarvisTry deleting the Jarvis tmp directory: "/opt/iobroker/backups/tmpJavis0" 11:43:35.030DEBUGjarvisJarvis tmp directory "/opt/iobroker/backups/tmpJavis0" successfully deleted 11:43:35.071DEBUGjarvisBackup created: /opt/iobroker/backups/jarvis.0_2025_03_10-11_43_34_backupiobroker.tar.gz 11:43:35.073DEBUGjarvisdone 11:43:35.345DEBUGjavascriptsCreated javascript_tmp directory: "/opt/iobroker/backups/tmpScripts" 11:43:35.408DEBUGjavascriptsfound Script: Wama_und_Trockner_Meldung 11:43:35.516DEBUGjavascriptsfound Script: Alias_anlegen 11:43:35.667DEBUGjavascriptsfound Script: Gaszähler 11:43:35.818DEBUGjavascriptsfound Script: Stromüberschuss3 11:43:35.969DEBUGjavascriptsfound Script: Wasserverbrauch2 11:43:36.120DEBUGjavascriptsfound Script: Stromüberschuss_Kühlschank 11:43:36.271DEBUGjavascriptsfound Script: Wasserverbrauch 11:43:36.422DEBUGjavascriptsfound Script: Gasverbrauch 11:43:36.572DEBUGjavascriptsfound Script: Einspeisung 11:43:36.723DEBUGjavascriptsfound Script: Brunnenwasser 11:43:36.875DEBUGjavascriptsfound Script: Nur_Brunnenwasser 11:43:37.026DEBUGjavascriptsfound Script: Brunnenwasser_alt 11:43:37.175DEBUGjavascriptsfound Script: Gesamtverbräuche 11:43:37.325DEBUGjavascriptsfound Script: Stromüberschuss_Heizer 11:43:37.475DEBUGjavascriptsfound Script: Steckdose_Robo 11:43:37.628DEBUGjavascriptsfound Script: Windberechnung 11:43:37.777DEBUGjavascriptsfound Script: Licht_Esszimmer 11:43:37.927DEBUGjavascriptsfound Script: Watchdog_Adapter1 11:43:38.083DEBUGjavascriptsfound Script: Gefrierschrank 11:43:38.231DEBUGjavascriptsfound Script: Drucker_an_aus 11:43:38.383DEBUGjavascriptsfound Script: Garage_korrigierter_Verbrauch 11:43:38.534DEBUGjavascriptsfound Script: Ost_West_zusammenfassung 11:43:38.684DEBUGjavascriptsfound Script: _beide_Anlagen 11:43:38.834DEBUGjavascriptsfound Script: Deckenventilator 11:43:38.985DEBUGjavascriptsfound Script: Stromüberschuss_Deckenlüfter_Terrasse_ 11:43:39.135DEBUGjavascriptsfound Script: 1i 11:43:39.284DEBUGjavascriptsfound Script: 1j 11:43:39.435DEBUGjavascriptsfound Script: 1k 11:43:39.586DEBUGjavascriptsfound Script: Schalter_Stube_Ikea_ 11:43:39.737DEBUGjavascriptsfound Script: Schalter_Terrasse_Ikea_ 11:43:39.887DEBUGjavascriptsfound Script: Gewächshaus 11:43:40.039DEBUGjavascriptsfound Script: Stromüberschuss_Lüfter_Keller 11:43:40.189DEBUGjavascriptsfound Script: Shelly_Temp_Brunnenpumpe1 11:43:40.339DEBUGjavascriptsfound Script: Shelly_Temp_Garagenboden1 11:43:40.490DEBUGjavascriptsfound Script: Staubsauger_Garage 11:43:40.641DEBUGjavascriptsfound Script: Brunnenwasser_neu 11:43:40.803DEBUGjavascriptsfound Script: Stromkosten_täglich 11:43:40.941DEBUGjavascriptsfound Script: Jalousie 11:43:41.093DEBUGjavascriptsfound Script: Jalousie_Test 11:43:41.244DEBUGjavascriptsfound Script: Kostenersparnis 11:43:41.395DEBUGjavascriptsfound Script: Lüfter_WR 11:43:41.545DEBUGjavascriptsfound Script: _Dach 11:43:41.694DEBUGjavascriptsfound Script: Berechnung_Hausverbrauch 11:43:41.855DEBUGjavascriptsJavascript tmp directory "/opt/iobroker/backups/tmpScripts" successfully deleted 11:43:41.900DEBUGjavascriptsBackup created: /opt/iobroker/backups/javascripts_2025_03_10-11_43_35_backupiobroker.tar.gz 11:43:41.901DEBUGjavascriptsdone 11:43:43.210DEBUGgoogledriveGoogle Drive: Copy iobroker_2025_03_10-11_43_20_backupiobroker.tar.gz... -
@bastler sagte in Problem mit unzureichendem Speicherplatz:
das ist normal, wenn es nicht am Ziel ankommt.
backup.dir dürfte nicht der Pfad zu Google sein
... wäre wahrscheinlich das wichtigste
@paul53 sagte in Problem mit unzureichendem Speicherplatz:
@bastler sagte:
/dev/sda1 ext4 31G 29G 470M 99% /zuerst platz machen, solange deine Platte voll ist, geht auch kein backup.. er kanns ja nicht zwischenspeichern..
@neuschwansteini Ich habe den Fehler entdeckt, Google Drive war zu voll! Kann mich aber nicht an eine Fehlermeldung erinnern. Es ist dann wohl so, dass das Backup auf dem lokalen Laufwerk durchgeführt wird.
Gibt es eine Möglichkeit über so ein Problem (Google Speicher voll) informiert zu werden?Danke an alle Helfer!
ja!
@homoran sagte in Problem mit unzureichendem Speicherplatz:
Bekommt man da nicht unabhängig vom Smarthome eine Mail, da benachrichtigt dich doch Google.
@crunchip Nein, nur direkt in Google Drive wurde mir angezeigt, dass nur noch 83% frei sind und ein Speichern von weiteren Dateien nicht mehr möglich ist.
@homoran Der Backup Vorgang läuft scheinbar nicht weiter? Google Drive ist mit 8GB belegt von 17GB. Die alten Backups im lokalen LW und auch im Google Drive habe ich gelöscht. Wenn ich direkt in Google Drive nachschaue, ist das Verzeichnis noch leer. Bin ich zu ungeduldig? Aber 700MB sollten doch in 15 Minuten locker hochgeladen werden?
Habe jetzt den Vorgang gestoppt, den ioBroker neu gestartet und noch einmal den Upload angeschoben. Sieht nicht anders aus. Oben im Fenster läuft der blaue Balken von links nach rechts, mehr passiert nicht.
Habe nun den Token versucht neu anzufordern, war aber nicht nötig, da der Zugriff möglich war. Allerdings schien da doch etwas geklemmt zu haben, denn danach klappte die Sicherung.
ich hänge mich hier mal dran mit einem ähnlichen Problem. Hatte dieselbe Meldung und hab nach einiger Recherche schonmal ein paar Caches und Backups gelöscht.
Nun kondensiert sich das Ganze im Wesentlichen auf Javascript:--- / ----------------------------------------------------------------------------------------------------------------------- 3.0 GiB [#################] /opt 1.2 GiB [###### ] /usr 324.5 MiB [# ] /home . 249.2 MiB [# ] /var . 3.2 MiB [ ] /etcund weiter
--- /opt/iobroker ----------------------------------------------------------------------------------------------------------- /.. 1.4 GiB [#################] /node_modules 920.9 MiB [########## ] /iobroker-data 453.7 MiB [##### ] /backups 1.5 MiB [ ] /logIn den beiden größten Foldern sind jeweils javascript Unterordner die Maßgeblichen:
--- /opt/iobroker/node_modules ---------------------------------------------------------------------------------------------- /.. 621.7 MiB [#################] /iobroker.javascript 181.0 MiB [#### ] /canvas 152.2 MiB [#### ] /iobroker.echarts 84.0 MiB [## ] /iobroker.adminund
--- /opt/iobroker/iobroker-data/files --------------------------------------------------------------------------------------- /.. 616.2 MiB [#################] /javascript.admin 66.2 MiB [# ] /echarts.admin 60.5 MiB [# ] /echartsKann mir jemand sagen woran das liegt und wie ich hier ein bisschen entschlacken kann?
Vielen Dank & viele Grüße
Marco -
Such mal hier im Forum. Irgendeine JS Version belegt sehr viel Speicher. Da kannst nix direkt machen außer aktualisisern.
Hab den diesbezüglichen Thread aber nicht ium Kopf.Und mit Proxmox hat das eigentlich nix zu tun ...
EDIT:
8.8.3 belegt 648MB
https://www.npmjs.com/package/iobroker.javascript/v/8.8.38.9.2 belehgt nur 34,8MB
https://www.npmjs.com/package/iobroker.javascript/v/8.9.2Ich kann aber keinerlei Empfehlungen zum Update / Downgrade geben.
@mcm1957 Guter Hinweis! Zumindest habe ich die 8.8.3 installiert. Ist offenbar auch die stable. Vielleicht beobachte ich das erstmal, meine Befürchtung war dass das immer weiter anschwillt. Wenn das mehr oder weniger fix ist und beim nächsten Upgrade schmäler wird reicht mir das.
Danke! -
Bei dieser Version dürften was beim Bau 'unglücklich' gelaufen sein, Eine dedizieret Ursachenforschung ist m.E. nicht sinnvoll, da die neueren Versionen alle wieder normale Speicheranforderungen habn.
