    4. System portieren und Zigbee Stick gleichzeitig wechseln
    • Asgothian
      Asgothian Developer last edited by
      @mr-x zeig mal bitte das log vom Start Versuch des zigbee Adapters. Bitte als Text in code tags, nicht als Screenshot.
      A.
        Mr.X @Asgothian last edited by Mr.X
        @asgothian
        Wie ist das mit den config files? muss ich die in einer VM anpassen oder reicht einfach hinzufügen?
        Das aus ioBroker meintest du:?
        zigbee.0
        2025-05-21 09:35:42.560	info	debug devices set to []
        zigbee.0
        2025-05-21 09:35:42.504	warn	Device 0x680ae2fffe71bc26 "HG06338" not found.
        zigbee.0
        2025-05-21 09:35:42.504	warn	Device 0xbc33acfffec5bc41 "HG06337" not found.
        zigbee.0
        2025-05-21 09:35:42.504	warn	Device 0xec1bbdfffed4fe44 "HG06338" not found.
        zigbee.0
        2025-05-21 09:35:42.504	warn	Device 0xbc33acfffe0ebd34 "HG06337" not found.
        zigbee.0
        2025-05-21 09:35:42.504	warn	Device 0xbc33acfffe0ebcf2 "HG06337" not found.
        zigbee.0
        2025-05-21 09:35:42.503	warn	Device 0x842e14fffe556652 "HG06338" not found.
        zigbee.0
        2025-05-21 09:35:42.501	warn	Device 0x5c0272fffecca442 "TS0201" not found.
        zigbee.0
        2025-05-21 09:35:42.500	warn	Device 0x2c1165fffe3f214c "HG08164" not found.
        zigbee.0
        2025-05-21 09:35:42.497	warn	Device 0x540f57fffe2b1fc5 "HG06620" not found.
        zigbee.0
        2025-05-21 09:35:42.496	warn	Device 0x588e81fffed4affa "TS0121_plug" not found.
        zigbee.0
        2025-05-21 09:35:42.495	warn	Device 0x842e14fffe3a4af8 "TS0121_plug" not found.
        zigbee.0
        2025-05-21 09:35:42.476	warn	Device 0x000b57fffec367c3 "LED1545G12" not found.
        zigbee.0
        2025-05-21 09:35:42.474	warn	Device 0xf0d1b80000148105 "4058075208414" not found.
        zigbee.0
        2025-05-21 09:35:42.474	warn	Device 0xf0d1b800001485c8 "4058075208414" not found.
        zigbee.0
        2025-05-21 09:35:42.474	warn	Device 0xf0d1b80000148327 "4058075208414" not found.
        zigbee.0
        2025-05-21 09:35:42.473	warn	Device 0xf0d1b800001482e1 "4058075208414" not found.
        zigbee.0
        2025-05-21 09:35:42.473	warn	Device 0xf0d1b80000148292 "4058075208414" not found.
        zigbee.0
        2025-05-21 09:35:42.472	warn	Device 0x7cb03eaa00aacf5b "AB32840" not found.
        zigbee.0
        2025-05-21 09:35:42.472	warn	Device 0x7cb03eaa00ae1974 "AB32840" not found.
        zigbee.0
        2025-05-21 09:35:42.472	warn	Device 0x7cb03eaa00ae1127 "AB32840" not found.
        zigbee.0
        2025-05-21 09:35:42.472	warn	Device 0x7cb03eaa00ae2265 "AB32840" not found.
        zigbee.0
        2025-05-21 09:35:42.472	warn	Device 0x04cf8cdf3c7d3acc "WXCJKG13LM" not found.
        zigbee.0
        2025-05-21 09:35:42.471	warn	Device 0x00158d00041d47f7 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 09:35:42.471	warn	Device 0x005043c9a3379498 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.471	warn	Device 0x005043c9a337968a "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.471	warn	Device 0x005043c90335618a "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.471	warn	Device 0x005043c903356313 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.471	warn	Device 0x005043c903383b13 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x005043c9a3311534 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x005043c903388f6d "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x0017880108b7ba14 "8718699673147" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x00158d000425298b "WSDCGQ01LM" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x00158d0004042192 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x005043c903386694 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.470	warn	Device 0x00158d0003f045f4 "WSDCGQ11LM" not found.
        zigbee.0
        2025-05-21 09:35:42.469	warn	Device 0x00158d0004252ae8 "WSDCGQ01LM" not found.
        zigbee.0
        2025-05-21 09:35:42.469	warn	Device 0x00158d0004041f71 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 09:35:42.469	warn	Device 0x005043c903241a3e "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.469	warn	Device 0x005043c903245474 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.469	warn	Device 0x005043c90324538e "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.468	warn	Device 0x005043c9032455a3 "HS1SA" not found.
        zigbee.0
        2025-05-21 09:35:42.468	warn	Device 0x00158d0002a374e8 "MFKZQ01LM" not found.
        zigbee.0
        2025-05-21 09:35:42.468	warn	Device 0x84182600000f74b5 "AC03641" not found.
        zigbee.0
        2025-05-21 09:35:42.468	warn	Device 0x000b57fffec1f6ec "E1524/E1810" not found.
        zigbee.0
        2025-05-21 09:35:42.467	warn	Device 0x000b57fffe2b7dea "ICTC-G-1" not found.
        zigbee.0
        2025-05-21 09:35:42.467	warn	Device 0x000b57fffe9e650d "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
        zigbee.0
        2025-05-21 09:35:42.467	warn	Device 0x00158d00041cd4e6 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 09:35:42.467	warn	Device 0x90fd9ffffe6d32bc "LED1546G12" not found.
        zigbee.0
        2025-05-21 09:35:42.464	info	terminating
        zigbee.0
        2025-05-21 09:35:42.447	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
        zigbee.0
        2025-05-21 09:35:42.287	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0
        2025-05-21 09:35:42.287	info	terminating
        zigbee.0
        2025-05-21 09:35:42.286	info	Saved local configuration data
        zigbee.0
        2025-05-21 09:35:42.286	info	local config saved
        zigbee.0
        2025-05-21 09:35:42.286	info	cleaned everything up...
        zigbee.0
        2025-05-21 09:35:42.285	error	undefined
        zigbee.0
        2025-05-21 09:35:42.285	error	unhandled promise rejection: undefined
        zigbee.0
        2025-05-21 09:35:42.285	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        2025-05-21 09:35:42.284	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open /dev/ttyUSB0
        zigbee.0
        2025-05-21 09:35:42.272	info	Unable to obtain herdsman settings
        zigbee.0
        zigbee.0
        2025-05-21 09:35:42.157	info	Starting Zigbee-Herdsman
        zigbee.0
        2025-05-21 09:35:42.156	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        zigbee.0
        2025-05-21 09:35:42.141	info	Starting Adapter npm ...
        zigbee.0
        2025-05-21 09:35:42.140	info	--- creating device debug ---
        zigbee.0
        2025-05-21 09:35:42.138	info	delete old Backup files. keep only last 10
        zigbee.0
        2025-05-21 09:35:42.134	info	--> transmitPower : normal
        zigbee.0
        2025-05-21 09:35:42.131	info	init localConfig
        zigbee.0
        2025-05-21 09:35:42.122	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        • Asgothian
          @mr-x sagte in System portieren und Zigbee Stick gleichzeitig wechseln:
          zigbee.0
          Das ist dein Fehler.
          Schau mal bitte nach ob der Stick am Container ankommt. Am einfachsten durch ls /dev/serial/by-id
          A.
            @asgothian
            Sorry, mein Fehler, weil ich rumgespielt habe:
            zigbee.0
            2025-05-21 09:51:54.821	info	debug devices set to []
            zigbee.0
            2025-05-21 09:51:54.761	warn	Device 0x680ae2fffe71bc26 "HG06338" not found.
            zigbee.0
            2025-05-21 09:51:54.761	warn	Device 0xbc33acfffec5bc41 "HG06337" not found.
            zigbee.0
            2025-05-21 09:51:54.761	warn	Device 0xec1bbdfffed4fe44 "HG06338" not found.
            zigbee.0
            2025-05-21 09:51:54.761	warn	Device 0xbc33acfffe0ebd34 "HG06337" not found.
            zigbee.0
            2025-05-21 09:51:54.761	warn	Device 0xbc33acfffe0ebcf2 "HG06337" not found.
            zigbee.0
            2025-05-21 09:51:54.761	warn	Device 0x842e14fffe556652 "HG06338" not found.
            zigbee.0
            2025-05-21 09:51:54.759	warn	Device 0x5c0272fffecca442 "TS0201" not found.
            zigbee.0
            2025-05-21 09:51:54.758	warn	Device 0x2c1165fffe3f214c "HG08164" not found.
            zigbee.0
            2025-05-21 09:51:54.755	warn	Device 0x540f57fffe2b1fc5 "HG06620" not found.
            zigbee.0
            2025-05-21 09:51:54.754	warn	Device 0x588e81fffed4affa "TS0121_plug" not found.
            zigbee.0
            2025-05-21 09:51:54.754	warn	Device 0x842e14fffe3a4af8 "TS0121_plug" not found.
            zigbee.0
            2025-05-21 09:51:54.735	warn	Device 0x000b57fffec367c3 "LED1545G12" not found.
            zigbee.0
            2025-05-21 09:51:54.733	warn	Device 0xf0d1b80000148105 "4058075208414" not found.
            zigbee.0
            2025-05-21 09:51:54.733	warn	Device 0xf0d1b800001485c8 "4058075208414" not found.
            zigbee.0
            2025-05-21 09:51:54.733	warn	Device 0xf0d1b80000148327 "4058075208414" not found.
            zigbee.0
            2025-05-21 09:51:54.733	warn	Device 0xf0d1b800001482e1 "4058075208414" not found.
            zigbee.0
            2025-05-21 09:51:54.733	warn	Device 0xf0d1b80000148292 "4058075208414" not found.
            zigbee.0
            2025-05-21 09:51:54.732	warn	Device 0x7cb03eaa00aacf5b "AB32840" not found.
            zigbee.0
            2025-05-21 09:51:54.732	warn	Device 0x7cb03eaa00ae1974 "AB32840" not found.
            zigbee.0
            2025-05-21 09:51:54.731	warn	Device 0x7cb03eaa00ae1127 "AB32840" not found.
            zigbee.0
            2025-05-21 09:51:54.731	warn	Device 0x7cb03eaa00ae2265 "AB32840" not found.
            zigbee.0
            2025-05-21 09:51:54.731	warn	Device 0x04cf8cdf3c7d3acc "WXCJKG13LM" not found.
            zigbee.0
            2025-05-21 09:51:54.731	warn	Device 0x00158d00041d47f7 "MCCGQ11LM" not found.
            zigbee.0
            2025-05-21 09:51:54.731	warn	Device 0x005043c9a3379498 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.731	warn	Device 0x005043c9a337968a "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.730	warn	Device 0x005043c90335618a "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.730	warn	Device 0x005043c903356313 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.730	warn	Device 0x005043c903383b13 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.730	warn	Device 0x005043c9a3311534 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.730	warn	Device 0x005043c903388f6d "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.730	warn	Device 0x0017880108b7ba14 "8718699673147" not found.
            zigbee.0
            2025-05-21 09:51:54.729	warn	Device 0x00158d000425298b "WSDCGQ01LM" not found.
            zigbee.0
            2025-05-21 09:51:54.729	warn	Device 0x00158d0004042192 "MCCGQ11LM" not found.
            zigbee.0
            2025-05-21 09:51:54.729	warn	Device 0x005043c903386694 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.729	warn	Device 0x00158d0003f045f4 "WSDCGQ11LM" not found.
            zigbee.0
            2025-05-21 09:51:54.729	warn	Device 0x00158d0004252ae8 "WSDCGQ01LM" not found.
            zigbee.0
            2025-05-21 09:51:54.729	warn	Device 0x00158d0004041f71 "MCCGQ11LM" not found.
            zigbee.0
            2025-05-21 09:51:54.728	warn	Device 0x005043c903241a3e "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.728	warn	Device 0x005043c903245474 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.728	warn	Device 0x005043c90324538e "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.728	warn	Device 0x005043c9032455a3 "HS1SA" not found.
            zigbee.0
            2025-05-21 09:51:54.728	warn	Device 0x00158d0002a374e8 "MFKZQ01LM" not found.
            zigbee.0
            2025-05-21 09:51:54.727	warn	Device 0x84182600000f74b5 "AC03641" not found.
            zigbee.0
            2025-05-21 09:51:54.727	warn	Device 0x000b57fffec1f6ec "E1524/E1810" not found.
            zigbee.0
            2025-05-21 09:51:54.727	warn	Device 0x000b57fffe2b7dea "ICTC-G-1" not found.
            zigbee.0
            2025-05-21 09:51:54.727	warn	Device 0x000b57fffe9e650d "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
            zigbee.0
            2025-05-21 09:51:54.727	warn	Device 0x00158d00041cd4e6 "MCCGQ11LM" not found.
            zigbee.0
            2025-05-21 09:51:54.726	warn	Device 0x90fd9ffffe6d32bc "LED1546G12" not found.
            zigbee.0
            2025-05-21 09:51:54.724	info	terminating
            zigbee.0
            2025-05-21 09:51:54.708	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
            zigbee.0
            2025-05-21 09:51:54.564	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
            zigbee.0
            2025-05-21 09:51:54.564	info	terminating
            zigbee.0
            2025-05-21 09:51:54.563	info	Saved local configuration data
            zigbee.0
            2025-05-21 09:51:54.563	info	local config saved
            zigbee.0
            2025-05-21 09:51:54.563	info	cleaned everything up...
            zigbee.0
            2025-05-21 09:51:54.562	error	undefined
            zigbee.0
            2025-05-21 09:51:54.562	error	unhandled promise rejection: undefined
            zigbee.0
            2025-05-21 09:51:54.562	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
            zigbee.0
            2025-05-21 09:51:54.561	error	Starting zigbee-herdsman problem : startup failed - configuration-adapter mismatch - see logs above for more information
            zigbee.0
            2025-05-21 09:51:54.545	warn	Network parameters on Coordinator: panID=6754 channel=11 extendedPanID=b161d432004b1200
            zigbee.0
            2025-05-21 09:51:54.545	warn	Network parameters in Config : panID=6755 channel=11 extendedPanID=b0de1007014c1301
            zigbee.0
            2025-05-21 09:51:54.252	info	Starting Zigbee-Herdsman
            zigbee.0
            2025-05-21 09:51:54.252	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
            zigbee.0
            2025-05-21 09:51:54.238	info	Starting Adapter npm ...
            zigbee.0
            2025-05-21 09:51:54.237	info	--- creating device debug ---
            zigbee.0
            2025-05-21 09:51:54.236	info	delete old Backup files. keep only last 10
            zigbee.0
            2025-05-21 09:51:54.232	info	--> transmitPower : normal
            zigbee.0
            2025-05-21 09:51:54.229	info	init localConfig
            zigbee.0
            2025-05-21 09:51:54.222	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
            • Asgothian
              Asgothian Developer @Mr.X last edited by
              zigbee.0
              zigbee.0
              zigbee.0
              • Was steht bei Dir in der Konfiguration des Adapters ?
              • as passiert wenn du die Werte aus dieser Zeile in Deine Konfiguration einträgst ? panID=6754 channel=11 extendedPanID=b161d432004b1200
              A.
                @asgothian
                • Asgothian
                  @mr-x Bitte abändern auf
                  panID: 6754
                  extPanId: b161d432004b1200
                  Dann versuchen zu starten.
                  A,
                    @asgothian, Danke.
                    hab ich gemacht, Wo kommen die Werte denn her?
                    Ursprünglich hast du gesagt, ich solle versuchen die Pan - ID vom alten System zu übertragen.
                    das ist im log.
                    unten ein Fotos von der Geräteübersicht:
                    zigbee.0
                    2025-05-21 10:08:46.665	info	Timeout trying to configure 0x000b57fffe2b7dea ICTC-G-1 (starting CoM).
                    zigbee.0
                    2025-05-21 10:08:46.655	info	Configuring 0x000b57fffec1f6ec E1524/E1810
                    zigbee.0
                    2025-05-21 10:08:46.655	info	DeviceConfigureQueue configuring 0x000b57fffec1f6ec TRADFRI remote control
                    zigbee.0
                    2025-05-21 10:08:41.655	info	Configuring 0x540f57fffe2b1fc5 HG06620
                    zigbee.0
                    2025-05-21 10:08:41.655	info	DeviceConfigureQueue configuring 0x540f57fffe2b1fc5 TS0101
                    zigbee.0
                    2025-05-21 10:08:38.217	info	Failed to ping 0x000b57fffec367c3 TRADFRI bulb E27 WS opal 980lm
                    zigbee.0
                    2025-05-21 10:08:37.717	info	Failed to ping 0x680ae2fffe71bc26 TS011F
                    zigbee.0
                    2025-05-21 10:08:37.216	info	Failed to ping 0xbc33acfffec5bc41 TS011F
                    zigbee.0
                    2025-05-21 10:08:36.716	info	Failed to ping 0xf0d1b80000148105 B40 TW Z3
                    zigbee.0
                    2025-05-21 10:08:36.654	info	Configuring 0x000b57fffe2b7dea ICTC-G-1
                    zigbee.0
                    2025-05-21 10:08:36.654	info	DeviceConfigureQueue configuring 0x000b57fffe2b7dea TRADFRI wireless dimmer
                    zigbee.0
                    2025-05-21 10:08:36.216	info	Failed to ping 0xf0d1b800001485c8 B40 TW Z3
                    zigbee.0
                    2025-05-21 10:08:35.716	info	Failed to ping 0xf0d1b80000148327 B40 TW Z3
                    zigbee.0
                    2025-05-21 10:08:35.219	info	Failed to ping 0xf0d1b800001482e1 B40 TW Z3
                    zigbee.0
                    2025-05-21 10:08:34.719	info	Failed to ping 0xf0d1b80000148292 B40 TW Z3
                    zigbee.0
                    2025-05-21 10:08:34.215	info	Failed to ping 0x7cb03eaa00aacf5b Classic B40 TW - LIGHTIFY
                    zigbee.0
                    2025-05-21 10:08:33.715	info	Failed to ping 0x7cb03eaa00ae1974 Classic B40 TW - LIGHTIFY
                    zigbee.0
                    2025-05-21 10:08:33.213	info	Failed to ping 0x7cb03eaa00ae1127 Classic B40 TW - LIGHTIFY
                    zigbee.0
                    2025-05-21 10:08:32.713	info	Failed to ping 0x7cb03eaa00ae2265 Classic B40 TW - LIGHTIFY
                    zigbee.0
                    2025-05-21 10:08:32.216	info	Failed to ping 0xec1bbdfffed4fe44 TS011F
                    zigbee.0
                    2025-05-21 10:08:31.715	info	Failed to ping 0x588e81fffed4affa TS0121
                    zigbee.0
                    2025-05-21 10:08:31.665	info	Failed to ping 0x0017880108b7ba14 LWA001
                    zigbee.0
                    2025-05-21 10:08:31.654	info	Configuring 0x842e14fffe556652 HG06338
                    zigbee.0
                    2025-05-21 10:08:31.654	info	DeviceConfigureQueue configuring 0x842e14fffe556652 TS011F
                    zigbee.0
                    2025-05-21 10:08:31.215	info	Failed to ping 0x842e14fffe3a4af8 TS0121
                    zigbee.0
                    2025-05-21 10:08:31.001	info	Failed to ping 0xbc33acfffe0ebd34 TS011F
                    zigbee.0
                    2025-05-21 10:08:30.460	info	Failed to ping 0xbc33acfffe0ebcf2 TS011F
                    zigbee.0
                    2025-05-21 10:08:30.304	info	Failed to ping 0x84182600000f74b5 Classic A60 W clear - LIGHTIFY
                    zigbee.0
                    zigbee.0
                    2025-05-21 10:08:29.467	info	Failed to ping 0x540f57fffe2b1fc5 TS0101
                    zigbee.0
                    2025-05-21 10:08:29.168	info	Failed to ping 0x000b57fffe9e650d TRADFRI transformer 30W
                    zigbee.0
                    2025-05-21 10:08:28.498	info	Failed to ping 0x90fd9ffffe6d32bc TRADFRI bulb E27 WS clear 950lm
                    zigbee.0
                    2025-05-21 10:08:28.401	info	Failed to ping 0x842e14fffe556652 TS011F
                    zigbee.0
                    2025-05-21 10:08:26.719	info	debug devices set to []
                    zigbee.0
                    2025-05-21 10:08:26.670	info	DeviceConfigure 0x680ae2fffe71bc26 HG06338 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.669	info	DeviceConfigure 0x2c1165fffe3f214c HG08164 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.669	info	DeviceConfigure 0xbc33acfffec5bc41 HG06337 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.666	info	DeviceConfigure 0xec1bbdfffed4fe44 HG06338 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.666	info	DeviceConfigure 0x04cf8cdf3c7d3acc WXCJKG13LM needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.665	info	DeviceConfigure 0x588e81fffed4affa TS0121_plug needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.664	info	DeviceConfigure 0x842e14fffe3a4af8 TS0121_plug needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.664	info	DeviceConfigure 0x005043c9a3379498 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.664	info	DeviceConfigure 0x005043c9a337968a HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.663	info	DeviceConfigure 0x005043c90335618a HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.663	info	DeviceConfigure 0x005043c903356313 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.663	info	DeviceConfigure 0x005043c903383b13 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.662	info	DeviceConfigure 0x005043c9a3311534 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.662	info	DeviceConfigure 0x005043c903388f6d HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.661	info	DeviceConfigure 0x005043c903386694 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.660	info	DeviceConfigure 0x005043c903241a3e HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.659	info	DeviceConfigure 0x005043c903245474 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.659	info	DeviceConfigure 0x005043c90324538e HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.658	info	DeviceConfigure 0x005043c9032455a3 HS1SA needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.658	info	DeviceConfigure 0xbc33acfffe0ebd34 HG06337 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.657	info	DeviceConfigure 0xbc33acfffe0ebcf2 HG06337 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.656	info	DeviceConfigure 0x000b57fffec1f6ec E1524/E1810 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.655	info	DeviceConfigure 0x540f57fffe2b1fc5 HG06620 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.655	info	DeviceConfigure 0x000b57fffe2b7dea ICTC-G-1 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.654	info	DeviceConfigure 0x842e14fffe556652 HG06338 needed - Device added to Configuration Queue
                    zigbee.0
                    2025-05-21 10:08:26.641	info	Zigbee started
                    zigbee.0
                    2025-05-21 10:08:26.640	info	Currently 48 devices are joined:
                    zigbee.0
                    2025-05-21 10:08:26.640	info	0x000b57fffec367c3 (addr 48984): LED1545G12 - IKEA TRADFRI bulb E26/E27, white spectrum, globe, opal, 980 lm (Router)
                    zigbee.0
                    2025-05-21 10:08:26.640	info	0x680ae2fffe71bc26 (addr 64569): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
                    zigbee.0
                    2025-05-21 10:08:26.639	info	0x2c1165fffe3f214c (addr 25696): HG08164 - Lidl Silvercrest smart button (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.638	info	0xbc33acfffec5bc41 (addr 51323): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.0
                    2025-05-21 10:08:26.638	info	0xf0d1b80000148105 (addr 59896): 4058075208414 - LEDVANCE SMART+ candle E14 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.637	info	0xf0d1b800001485c8 (addr 27763): 4058075208414 - LEDVANCE SMART+ candle E14 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.637	info	0xf0d1b80000148327 (addr 48989): 4058075208414 - LEDVANCE SMART+ candle E14 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.636	info	0xf0d1b800001482e1 (addr 47048): 4058075208414 - LEDVANCE SMART+ candle E14 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.636	info	0xf0d1b80000148292 (addr 43984): 4058075208414 - LEDVANCE SMART+ candle E14 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.624	info	0x5c0272fffecca442 (addr 57000): TS0201 - Tuya Temperature & humidity sensor with display (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.621	info	0x7cb03eaa00aacf5b (addr 55109): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.620	info	0x7cb03eaa00ae1974 (addr 56002): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.619	info	0x7cb03eaa00ae1127 (addr 51948): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.619	info	0x7cb03eaa00ae2265 (addr 27385): AB32840 - OSRAM LIGHTIFY LED Classic B40 tunable white (Router)
                    zigbee.0
                    2025-05-21 10:08:26.618	info	0xec1bbdfffed4fe44 (addr 17084): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
                    zigbee.0
                    2025-05-21 10:08:26.617	info	0x04cf8cdf3c7d3acc (addr 51506): WXCJKG13LM - Aqara Opple wireless switch (triple band) (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.616	info	0x588e81fffed4affa (addr 29403): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router)
                    zigbee.0
                    2025-05-21 10:08:26.615	info	0x842e14fffe3a4af8 (addr 62033): TS0121_plug - Tuya 10A UK or 16A EU smart plug (Router)
                    zigbee.0
                    2025-05-21 10:08:26.614	info	0x00158d00041d47f7 (addr 20683): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.613	info	0x005043c9a3379498 (addr 34977): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.613	info	0x005043c9a337968a (addr 60068): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.612	info	0x005043c90335618a (addr 42085): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.612	info	0x005043c903356313 (addr 5555): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.611	info	0x005043c903383b13 (addr 65300): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.611	info	0x005043c9a3311534 (addr 15328): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.610	info	0x005043c903388f6d (addr 55574): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.609	info	0x0017880108b7ba14 (addr 33377): 8718699673147 - Philips Hue white A60 bulb E27 bluetooth (Router)
                    zigbee.0
                    2025-05-21 10:08:26.579	info	0x00158d000425298b (addr 57410): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.579	info	0x00158d0004042192 (addr 39612): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.578	info	0x005043c903386694 (addr 15095): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.578	info	0x00158d0003f045f4 (addr 22531): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.577	info	0x00158d0004252ae8 (addr 90): WSDCGQ01LM - Xiaomi Mi temperature and humidity sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.576	info	0x00158d0004041f71 (addr 38427): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.576	info	0x005043c903241a3e (addr 50884): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.576	info	0x005043c903245474 (addr 22184): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.575	info	0x005043c90324538e (addr 446): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.574	info	0x005043c9032455a3 (addr 8029): HS1SA - HEIMAN Smoke detector (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.570	info	0xbc33acfffe0ebd34 (addr 16210): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.0
                    2025-05-21 10:08:26.569	info	0xbc33acfffe0ebcf2 (addr 58954): HG06337 - Lidl Silvercrest smart plug (EU, CH, FR, BS, DK) (Router)
                    zigbee.0
                    2025-05-21 10:08:26.568	info	0x00158d0002a374e8 (addr 27750): MFKZQ01LM - Aqara Cube (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.566	info	0x84182600000f74b5 (addr 48893): AC03641 - OSRAM LIGHTIFY LED Classic A60 clear (Router)
                    zigbee.0
                    2025-05-21 10:08:26.562	info	0x000b57fffec1f6ec (addr 2874): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.562	info	0x540f57fffe2b1fc5 (addr 57216): HG06620 - Lidl Silvercrest garden spike with 2 sockets (Router)
                    zigbee.0
                    2025-05-21 10:08:26.560	info	0x000b57fffe2b7dea (addr 40157): ICTC-G-1 - IKEA TRADFRI wireless dimmer (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.559	info	0x000b57fffe9e650d (addr 3426): ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2 - IKEA TRADFRI LED driver, 30 w (Router)
                    zigbee.0
                    2025-05-21 10:08:26.558	info	0x00158d00041cd4e6 (addr 46501): MCCGQ11LM - Aqara Door and window sensor (EndDevice)
                    zigbee.0
                    2025-05-21 10:08:26.531	info	0x90fd9ffffe6d32bc (addr 20002): LED1546G12 - IKEA TRADFRI bulb E26/E27, white spectrum, globe, clear, 950 lm (Router)
                    zigbee.0
                    2025-05-21 10:08:26.513	info	0x842e14fffe556652 (addr 50450): HG06338 - Lidl Silvercrest 3 gang switch, with 4 USB (EU, FR, CZ, BS) (Router)
                    zigbee.0
                    2025-05-21 10:08:26.435	info	Unable to disable LED, unsupported function.
                    zigbee.0
                    2025-05-21 10:08:26.434	info	Zigbee-Herdsman started successfully with Coordinator firmware version: {"type":"zStack3x0","meta":{"transportrev":2,"product":1,"majorrel":2,"minorrel":7,"maintrel":1,"revision":20210708}}
                    zigbee.0
                    2025-05-21 10:08:26.097	info	Starting Zigbee-Herdsman
                    zigbee.0
                    2025-05-21 10:08:26.096	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
                    zigbee.0
                    2025-05-21 10:08:26.081	info	Starting Adapter npm ...
                    zigbee.0
                    2025-05-21 10:08:26.081	info	--- creating device debug ---
                    zigbee.0
                    2025-05-21 10:08:26.080	info	delete old Backup files. keep only last 10
                    zigbee.0
                    2025-05-21 10:08:26.076	info	--> transmitPower : normal
                    zigbee.0
                    2025-05-21 10:08:26.073	info	init localConfig
                    zigbee.0
                    2025-05-21 10:08:26.065	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                    zigbee.0
                    2025-05-21 10:06:08.239	warn	get state error: Connection is closed.
                    zigbee.0
                    zigbee.0
                    2025-05-21 10:06:08.235	info	terminating
                    zigbee.0
                    2025-05-21 10:06:08.209	info	Closing Zigbee network, 0 seconds remaining
                    zigbee.0
                    2025-05-21 10:06:07.972	info	Closing Zigbee network, 0 seconds remaining
                    zigbee.0
                    2025-05-21 10:06:07.736	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                    zigbee.0
                    2025-05-21 10:06:07.735	info	terminating
                    zigbee.0
                    2025-05-21 10:06:07.735	info	Saved local configuration data
                    zigbee.0
                    2025-05-21 10:06:07.735	info	local config saved
                    zigbee.0
                    2025-05-21 10:06:07.735	info	cleaned everything up...
                    zigbee.0
                    2025-05-21 10:06:07.734	info	Got terminate signal TERMINATE_YOURSELF
                    zigbee.0
                    2025-05-21 10:05:59.229	warn	DeviceConfigure:0x680ae2fffe71bc26 TS011F Failed to configure. --> ZCL command 0x680ae2fffe71bc26/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                    zigbee.0
                    2025-05-21 10:05:54.465	warn	DeviceConfigure:0x2c1165fffe3f214c TS004F Failed to configure. --> ZCL command 0x2c1165fffe3f214c/1 genBasic.read([4,0,1,5,7,65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                    zigbee.0
                    2025-05-21 10:05:45.086	warn	DeviceConfigure:0xec1bbdfffed4fe44 TS011F Failed to configure. --> ZCL command 0xec1bbdfffed4fe44/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                    zigbee.0
                    2025-05-21 10:05:42.916	info	Handled all devices Queued for configuration.
                    zigbee.0
                    2025-05-21 10:05:40.093	warn	DeviceConfigure:0x04cf8cdf3c7d3acc lumi.remote.b686opcn01 Failed to configure. --> ZCL command 0x04cf8cdf3c7d3acc/1 manuSpecificLumi.write({"mode":1}, {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":4447,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                    zigbee.0
                    2025-05-21 10:05:37.932	info	Timeout trying to configure 0xbc33acfffec5bc41 HG06337 (starting CoM).
                    zigbee.0
                    2025-05-21 10:05:37.915	info	Configuring 0x680ae2fffe71bc26 HG06338
                    zigbee.0
                    2025-05-21 10:05:37.915	info	DeviceConfigureQueue configuring 0x680ae2fffe71bc26 TS011F
                    zigbee.0
                    2025-05-21 10:05:32.915	info	Configuring 0x2c1165fffe3f214c HG08164
                    zigbee.0
                    2025-05-21 10:05:32.915	info	DeviceConfigureQueue configuring 0x2c1165fffe3f214c TS004F
                    zigbee.0
                    2025-05-21 10:05:27.914	info	Configuring 0xbc33acfffec5bc41 HG06337
                    zigbee.0
                    2025-05-21 10:05:27.914	info	DeviceConfigureQueue configuring 0xbc33acfffec5bc41 TS011F
                    zigbee.0
                    2025-05-21 10:05:22.929	info	Timeout trying to configure 0x588e81fffed4affa TS0121_plug (starting CoM).
                    zigbee.0
                    2025-05-21 10:05:22.913	info	Configuring 0xec1bbdfffed4fe44 HG06338
                    zigbee.0
                    2025-05-21 10:05:22.913	info	DeviceConfigureQueue configuring 0xec1bbdfffed4fe44 TS011F
                    zigbee.0
                    2025-05-21 10:05:17.930	info	Timeout trying to configure 0x842e14fffe3a4af8 TS0121_plug (starting CoM).
                    zigbee.0
                    2025-05-21 10:05:17.913	info	Configuring 0x04cf8cdf3c7d3acc WXCJKG13LM
                    zigbee.0
                    2025-05-21 10:05:17.912	info	DeviceConfigureQueue configuring 0x04cf8cdf3c7d3acc lumi.remote.b686opcn01
                    zigbee.0
                    2025-05-21 10:05:12.929	info	Timeout trying to configure 0x005043c9a3379498 HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:05:12.912	info	Configuring 0x588e81fffed4affa TS0121_plug
                    zigbee.0
                    2025-05-21 10:05:12.912	info	DeviceConfigureQueue configuring 0x588e81fffed4affa TS0121
                    zigbee.0
                    2025-05-21 10:05:07.927	info	Timeout trying to configure 0x005043c9a337968a HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:05:07.911	info	Configuring 0x842e14fffe3a4af8 TS0121_plug
                    zigbee.0
                    2025-05-21 10:05:07.911	info	DeviceConfigureQueue configuring 0x842e14fffe3a4af8 TS0121
                    zigbee.0
                    2025-05-21 10:05:02.927	info	Timeout trying to configure 0x005043c90335618a HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:05:02.911	info	Configuring 0x005043c9a3379498 HS1SA
                    zigbee.0
                    2025-05-21 10:05:02.911	info	DeviceConfigureQueue configuring 0x005043c9a3379498 SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:57.927	info	Timeout trying to configure 0x005043c903356313 HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:57.911	info	Configuring 0x005043c9a337968a HS1SA
                    zigbee.0
                    2025-05-21 10:04:57.910	info	DeviceConfigureQueue configuring 0x005043c9a337968a SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:52.926	info	Timeout trying to configure 0x005043c903383b13 HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:52.909	info	Configuring 0x005043c90335618a HS1SA
                    zigbee.0
                    2025-05-21 10:04:52.909	info	DeviceConfigureQueue configuring 0x005043c90335618a SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:47.926	info	Timeout trying to configure 0x005043c9a3311534 HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:47.909	info	Configuring 0x005043c903356313 HS1SA
                    zigbee.0
                    2025-05-21 10:04:47.909	info	DeviceConfigureQueue configuring 0x005043c903356313 SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:42.928	info	Timeout trying to configure 0x005043c903388f6d HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:42.909	info	Configuring 0x005043c903383b13 HS1SA
                    zigbee.0
                    2025-05-21 10:04:42.909	info	DeviceConfigureQueue configuring 0x005043c903383b13 SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:37.919	info	Timeout trying to configure 0x005043c903386694 HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:37.909	info	Configuring 0x005043c9a3311534 HS1SA
                    zigbee.0
                    2025-05-21 10:04:37.908	info	DeviceConfigureQueue configuring 0x005043c9a3311534 SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:32.921	info	Timeout trying to configure 0x005043c903241a3e HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:32.907	info	Configuring 0x005043c903388f6d HS1SA
                    zigbee.0
                    2025-05-21 10:04:32.907	info	DeviceConfigureQueue configuring 0x005043c903388f6d SMOK_YDLV10
                    zigbee.0
                    2025-05-21 10:04:27.918	info	Timeout trying to configure 0x005043c903245474 HS1SA (starting CoM).
                    zigbee.0
                    2025-05-21 10:04:27.902	info	Configuring 0x005043c903386694 HS1SA
                    zigbee.0
                    2025-05-21 10:04:27.902	info	DeviceConfigureQueue configuring 0x005043c903386694 SMOK_YDLV10
                      Mr.X last edited by Mr.X
                      FYI:
                      ein neues Gerät konnte ich anlernen. (mit deinen letzten ID´s angelernt)
                      Die alten bleiben disconnected
                        @asgothian sagte in System portieren und Zigbee Stick gleichzeitig wechseln:
                        @mr-x Mit dem Lan Koordinator kann der Slave in Rente gehen, ja. Du brauchst einfach nur eine weitere zigbee Instanz auf dem Master der dann den LAN Koordinator in der Garage anspricht.
                        Zum Thema Umzug vom Zigbee:
                        so wie es aussieht solltest du einfach folgendes machen können:
                        • Zigbee Instanz im Container installieren. Wichtig: nicht starten. Sollte sie automatisch gestartet werden - anhalten.
                        • von deiner bestehenden Installation die Dateien shepherd.db (und sofern vorhanden) nvbackup.json und dev_names.json in das Datenverzeichnis der neuen Zigbee Instanz kopieren liegt unter /opt/iobroker/iobroker-data/zigbee_x (wobei x die Instanz Nummer ist)
                        • Konfiguration des Adapters öffnen, die Werte sonder alten Instanz eintragen. Einzig den Port musst du anpassen
                          -- bei Verwendung des Sonoff Sticks da das 'device' eintragen an das du den USB Stick weitergereicht hast.
                          Wichtig: Entgegen der Aussage von @Thomas-Braun ist es in diesem Setup Sinnvoll einfach das erzeugte Device zu nehmen (/dev/ttyUSB0 oder so) und nicht das Device unter /dev/serial/by-id) - Grund dafür ist das die Weiterleitung an den Container ja bereits auf der USB ID basiert. Damit ist also sichergestellt das immer nur das für den Container vorgesehene USB Gerät weiter gegeben wird. Solltest Du in der Zukunft also den Stick austauschen, müsstest Du nur die Weiterleitung an den Container anpassen.
                          -- Bei Verwendung des Cod.M Lan Koordinators muss da tcp://<IP>:<PORT> rein.Die Werte für IP und Port findest du im Web-Interface des Cod.M
                        • Adapter auf der alten Installation anhalten und USB Stick abziehen Dieser Schritt ist Wichtig, incl. des Abziehen des Koordinators.
                        • Adapter starten. Wenn alles korrekt konfiguriert ist sollte der Adapter durchstarten und auch gleich alle Geräte Ansteuern können. In einzelfaellen kann es notwendig sein Geräte neu zu konfigurieren (ueber die Kachel).
                        auf die gleiche Methode kannst du die Zigbee-Instanz vom Slave auf den neuen ioBroker übertragen (manuell)
                        Generell würde ich Dir empfehlen die 3.0.1 aus dem Latest zu installieren, da sie gegenüber der aktuellen 2.0.5 aus dem Stable einige Vorteile bietet, incl. detaillierter Anleitung zur Konfiguration (im Readme auf Github verlinkt)
                        A.
                        Hey,
                        ich habe die VM nochmal zurück gespielt und gehe die Anleitung gerade nochmal schritt für schritt durch.
                        zwei Fragen
                        • Wo in deiner Anleitung soll ich das Backup einspielen?
                          Oder ist das mit dem kopieren der Files aus dem alten schon erledigt?
                        • Welche ID meinst du, dass es ausreicht die einzutragen? die 4 stellige oder die alte. Oder doch beide?
                        • Asgothian
                          Hey,
                          zwei Fragen
                          Das kopieren der Dateien ist die Eine Hälfte des Backup zurück spielen.
                          Das Eintragen der Konfiguration ist die andere Hälfte.
                            @asgothian
                            Wie erwähnt habe ich Zigbee nochmal neu auf ein frisches System installiert.
                            Sogar den alten Stick dran gemacht.
                            die drei Datein vom alten System rüber kopiert und die alten damit überschrieben.
                            Beide ID´s vom alten System eingetragen.
                            Und neu gestartet.
                            Es waren keine Geräte vorhanden.
                            zigbee.0
                            2025-05-21 15:33:47.303	info	terminating
                            zigbee.0
                            2025-05-21 15:33:47.085	info	debug devices set to []
                            zigbee.0
                            2025-05-21 15:33:47.037	warn	Device 0x680ae2fffe71bc26 "HG06338" not found.
                            zigbee.0
                            2025-05-21 15:33:47.037	warn	Device 0xbc33acfffec5bc41 "HG06337" not found.
                            zigbee.0
                            2025-05-21 15:33:47.037	warn	Device 0xec1bbdfffed4fe44 "HG06338" not found.
                            zigbee.0
                            2025-05-21 15:33:47.037	warn	Device 0xbc33acfffe0ebd34 "HG06337" not found.
                            zigbee.0
                            2025-05-21 15:33:47.037	warn	Device 0xbc33acfffe0ebcf2 "HG06337" not found.
                            zigbee.0
                            2025-05-21 15:33:47.036	warn	Device 0x842e14fffe556652 "HG06338" not found.
                            zigbee.0
                            2025-05-21 15:33:47.035	warn	Device 0x5c0272fffecca442 "TS0201" not found.
                            zigbee.0
                            2025-05-21 15:33:47.026	warn	Device 0x2c1165fffe3f214c "HG08164" not found.
                            zigbee.0
                            2025-05-21 15:33:47.022	warn	Device 0x540f57fffe2b1fc5 "HG06620" not found.
                            zigbee.0
                            2025-05-21 15:33:47.021	warn	Device 0x588e81fffed4affa "TS0121_plug" not found.
                            zigbee.0
                            2025-05-21 15:33:47.021	warn	Device 0x842e14fffe3a4af8 "TS0121_plug" not found.
                            zigbee.0
                            2025-05-21 15:33:47.000	warn	Device 0x000b57fffec367c3 "LED1545G12" not found.
                            zigbee.0
                            2025-05-21 15:33:46.998	warn	Device 0xf0d1b80000148105 "4058075208414" not found.
                            zigbee.0
                            2025-05-21 15:33:46.998	warn	Device 0xf0d1b800001485c8 "4058075208414" not found.
                            zigbee.0
                            2025-05-21 15:33:46.997	warn	Device 0xf0d1b80000148327 "4058075208414" not found.
                            zigbee.0
                            2025-05-21 15:33:46.997	warn	Device 0xf0d1b800001482e1 "4058075208414" not found.
                            zigbee.0
                            2025-05-21 15:33:46.997	warn	Device 0xf0d1b80000148292 "4058075208414" not found.
                            zigbee.0
                            2025-05-21 15:33:46.996	warn	Device 0x7cb03eaa00aacf5b "AB32840" not found.
                            zigbee.0
                            2025-05-21 15:33:46.996	warn	Device 0x7cb03eaa00ae1974 "AB32840" not found.
                            zigbee.0
                            2025-05-21 15:33:46.995	warn	Device 0x7cb03eaa00ae1127 "AB32840" not found.
                            zigbee.0
                            2025-05-21 15:33:46.995	warn	Device 0x7cb03eaa00ae2265 "AB32840" not found.
                            zigbee.0
                            2025-05-21 15:33:46.995	warn	Device 0x04cf8cdf3c7d3acc "WXCJKG13LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.995	warn	Device 0x005043c9a3379498 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x005043c9a337968a "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x005043c90335618a "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x005043c903356313 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x005043c903383b13 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x005043c9a3311534 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x005043c903388f6d "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.994	warn	Device 0x0017880108b7ba14 "8718699673147" not found.
                            zigbee.0
                            2025-05-21 15:33:46.993	warn	Device 0x00158d000425298b "WSDCGQ01LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.993	warn	Device 0x00158d0004042192 "MCCGQ11LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.993	warn	Device 0x005043c903386694 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.993	warn	Device 0x00158d0003f045f4 "WSDCGQ11LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.993	warn	Device 0x00158d0004252ae8 "WSDCGQ01LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.993	warn	Device 0x00158d0004041f71 "MCCGQ11LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.992	warn	Device 0x005043c903241a3e "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.992	warn	Device 0x005043c903245474 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.992	warn	Device 0x005043c90324538e "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.992	warn	Device 0x005043c9032455a3 "HS1SA" not found.
                            zigbee.0
                            2025-05-21 15:33:46.992	warn	Device 0x00158d0002a374e8 "MFKZQ01LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.991	warn	Device 0x84182600000f74b5 "AC03641" not found.
                            zigbee.0
                            2025-05-21 15:33:46.991	warn	Device 0x000b57fffec1f6ec "E1524/E1810" not found.
                            zigbee.0
                            2025-05-21 15:33:46.991	warn	Device 0x000b57fffe2b7dea "ICTC-G-1" not found.
                            zigbee.0
                            2025-05-21 15:33:46.991	warn	Device 0x000b57fffe9e650d "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
                            zigbee.0
                            2025-05-21 15:33:46.991	warn	Device 0x00158d00041cd4e6 "MCCGQ11LM" not found.
                            zigbee.0
                            2025-05-21 15:33:46.990	warn	Device 0x90fd9ffffe6d32bc "LED1546G12" not found.
                            zigbee.0
                            2025-05-21 15:33:46.987	info	terminating
                            zigbee.0
                            2025-05-21 15:33:46.966	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                            zigbee.0
                            2025-05-21 15:33:46.802	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                            zigbee.0
                            2025-05-21 15:33:46.801	info	terminating
                            zigbee.0
                            2025-05-21 15:33:46.801	info	Saved local configuration data
                            zigbee.0
                            2025-05-21 15:33:46.801	info	local config saved
                            zigbee.0
                            2025-05-21 15:33:46.801	info	cleaned everything up...
                            zigbee.0
                            2025-05-21 15:33:46.800	error	undefined
                            zigbee.0
                            2025-05-21 15:33:46.800	error	unhandled promise rejection: undefined
                            zigbee.0
                            2025-05-21 15:33:46.800	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                            zigbee.0
                            2025-05-21 15:33:46.799	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open /dev/ttyUSB0
                            zigbee.0
                            2025-05-21 15:33:46.784	info	Unable to obtain herdsman settings
                            zigbee.0
                            2025-05-21 15:33:46.644	info	Starting Zigbee-Herdsman
                            zigbee.0
                            2025-05-21 15:33:46.643	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
                            zigbee.0
                            2025-05-21 15:33:46.619	info	Starting Adapter npm ...
                            zigbee.0
                            2025-05-21 15:33:46.618	info	--- creating device debug ---
                            zigbee.0
                            2025-05-21 15:33:46.614	info	--> transmitPower : normal
                            zigbee.0
                            2025-05-21 15:33:46.609	info	init localConfig
                            zigbee.0
                            2025-05-21 15:33:46.601	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                              Mr.X last edited by
                              Danach über Backup Adapter das Backup eingspielt und neu gestartet:
                              Log-Größe: 8.7 KB
                              zigbee.0
                              Zeit
                              debug
                              Nachricht
                              zigbee.0
                              2025-05-21 15:36:39.021	info	terminating
                              zigbee.0
                              2025-05-21 15:36:38.764	info	debug devices set to []
                              zigbee.0
                              2025-05-21 15:36:38.717	warn	Device 0x680ae2fffe71bc26 "HG06338" not found.
                              zigbee.0
                              2025-05-21 15:36:38.717	warn	Device 0xbc33acfffec5bc41 "HG06337" not found.
                              zigbee.0
                              2025-05-21 15:36:38.717	warn	Device 0xec1bbdfffed4fe44 "HG06338" not found.
                              zigbee.0
                              2025-05-21 15:36:38.716	warn	Device 0xbc33acfffe0ebd34 "HG06337" not found.
                              zigbee.0
                              2025-05-21 15:36:38.716	warn	Device 0xbc33acfffe0ebcf2 "HG06337" not found.
                              zigbee.0
                              2025-05-21 15:36:38.716	warn	Device 0x842e14fffe556652 "HG06338" not found.
                              zigbee.0
                              2025-05-21 15:36:38.714	warn	Device 0x5c0272fffecca442 "TS0201" not found.
                              zigbee.0
                              2025-05-21 15:36:38.713	warn	Device 0x2c1165fffe3f214c "HG08164" not found.
                              zigbee.0
                              2025-05-21 15:36:38.710	warn	Device 0x540f57fffe2b1fc5 "HG06620" not found.
                              zigbee.0
                              2025-05-21 15:36:38.709	warn	Device 0x588e81fffed4affa "TS0121_plug" not found.
                              zigbee.0
                              2025-05-21 15:36:38.708	warn	Device 0x842e14fffe3a4af8 "TS0121_plug" not found.
                              zigbee.0
                              2025-05-21 15:36:38.688	warn	Device 0x000b57fffec367c3 "LED1545G12" not found.
                              zigbee.0
                              2025-05-21 15:36:38.687	warn	Device 0xf0d1b80000148105 "4058075208414" not found.
                              zigbee.0
                              2025-05-21 15:36:38.686	warn	Device 0xf0d1b800001485c8 "4058075208414" not found.
                              zigbee.0
                              2025-05-21 15:36:38.686	warn	Device 0xf0d1b80000148327 "4058075208414" not found.
                              zigbee.0
                              2025-05-21 15:36:38.686	warn	Device 0xf0d1b800001482e1 "4058075208414" not found.
                              zigbee.0
                              2025-05-21 15:36:38.686	warn	Device 0xf0d1b80000148292 "4058075208414" not found.
                              zigbee.0
                              2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00aacf5b "AB32840" not found.
                              zigbee.0
                              2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00ae1974 "AB32840" not found.
                              zigbee.0
                              2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00ae1127 "AB32840" not found.
                              zigbee.0
                              2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00ae2265 "AB32840" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x04cf8cdf3c7d3acc "WXCJKG13LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x00158d00041d47f7 "MCCGQ11LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x005043c9a3379498 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x005043c9a337968a "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x005043c90335618a "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x005043c903356313 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.684	warn	Device 0x005043c903383b13 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.683	warn	Device 0x005043c9a3311534 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.683	warn	Device 0x005043c903388f6d "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.683	warn	Device 0x0017880108b7ba14 "8718699673147" not found.
                              zigbee.0
                              2025-05-21 15:36:38.683	warn	Device 0x00158d000425298b "WSDCGQ01LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.683	warn	Device 0x00158d0004042192 "MCCGQ11LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.683	warn	Device 0x005043c903386694 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.682	warn	Device 0x00158d0003f045f4 "WSDCGQ11LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.682	warn	Device 0x00158d0004252ae8 "WSDCGQ01LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.682	warn	Device 0x00158d0004041f71 "MCCGQ11LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.682	warn	Device 0x005043c903241a3e "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.682	warn	Device 0x005043c903245474 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.682	warn	Device 0x005043c90324538e "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.681	warn	Device 0x005043c9032455a3 "HS1SA" not found.
                              zigbee.0
                              2025-05-21 15:36:38.681	warn	Device 0x00158d0002a374e8 "MFKZQ01LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.681	warn	Device 0x84182600000f74b5 "AC03641" not found.
                              zigbee.0
                              2025-05-21 15:36:38.681	warn	Device 0x000b57fffec1f6ec "E1524/E1810" not found.
                              zigbee.0
                              2025-05-21 15:36:38.681	warn	Device 0x000b57fffe2b7dea "ICTC-G-1" not found.
                              zigbee.0
                              2025-05-21 15:36:38.680	warn	Device 0x000b57fffe9e650d "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
                              zigbee.0
                              2025-05-21 15:36:38.680	warn	Device 0x00158d00041cd4e6 "MCCGQ11LM" not found.
                              zigbee.0
                              2025-05-21 15:36:38.680	warn	Device 0x90fd9ffffe6d32bc "LED1546G12" not found.
                              zigbee.0
                              2025-05-21 15:36:38.678	info	terminating
                              zigbee.0
                              2025-05-21 15:36:38.665	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                              zigbee.0
                              2025-05-21 15:36:38.520	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                              zigbee.0
                              2025-05-21 15:36:38.520	info	terminating
                              zigbee.0
                              2025-05-21 15:36:38.519	info	Saved local configuration data
                              zigbee.0
                              2025-05-21 15:36:38.519	info	local config saved
                              zigbee.0
                              2025-05-21 15:36:38.519	info	cleaned everything up...
                              zigbee.0
                              2025-05-21 15:36:38.518	error	undefined
                              zigbee.0
                              2025-05-21 15:36:38.518	error	unhandled promise rejection: undefined
                              zigbee.0
                              2025-05-21 15:36:38.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                              zigbee.0
                              2025-05-21 15:36:38.517	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open /dev/ttyUSB0
                              zigbee.0
                              2025-05-21 15:36:38.507	info	Unable to obtain herdsman settings
                              zigbee.0
                              2025-05-21 15:36:38.393	info	Starting Zigbee-Herdsman
                              zigbee.0
                              2025-05-21 15:36:38.392	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
                              zigbee.0
                              2025-05-21 15:36:38.378	info	Starting Adapter npm ...
                              zigbee.0
                              2025-05-21 15:36:38.377	info	--- creating device debug ---
                              zigbee.0
                              2025-05-21 15:36:38.372	info	--> transmitPower : normal
                              zigbee.0
                              2025-05-21 15:36:38.369	info	init localConfig
                              zigbee.0
                              2025-05-21 15:36:38.361	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                              • Asgothian
                                @mr-x die Reihenfolge ist wichtig!
                                • Adapter anhalten
                                • 30 s warten
                                • Dateien kopieren
                                • Adapter starten.
                                Ansonsten überschreibt der Adapter beim Anhalten die Dateien.
                                  @asgothian
                                  Ja, lass es 28 sec gewesen sein, aber schnell war es nicht.
                                  Ich kann aber alles nochmal manuell löschen und neu installieren/kopieren etc.
                                  • Asgothian
                                    @mr-x bitte nichts löschen, einfach nur Adapter anhalten, Shepherd.dB und nvbackup.json wiederherstellen, Adapter starten.
                                    Und bitte schau mal was in der Shepherd.dB drin steht - das ist eine XML Datei.
                                    A.
                                      @asgothian
                                      ich habe die Dateien überschrieben und dann neu gestartet.
                                      Adapter wurde komplett grün, alle drei "Anzeigen".
                                      Dann habe ich den Stick ausgewählt und und neu gestartet und alles rot:
                                      schaue sofort nach der Datei.
                                      zigbee.0
                                      2025-05-21 17:32:19.530	info	terminating
                                      zigbee.0
                                      2025-05-21 17:32:19.031	error	Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:32:19.031	error	TypeError: Cannot read properties of undefined (reading 'database') at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:333:27) at DeviceEvent.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:30:25) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:54) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:627:24) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      zigbee.0
                                      2025-05-21 17:32:19.031	error	unhandled promise rejection: Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:32:19.031	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      2025-05-21 17:32:19.031	info	terminating
                                      zigbee.0
                                      2025-05-21 17:32:19.030	warn	Failed to stop zigbee during startup
                                      zigbee.0
                                      2025-05-21 17:32:19.030	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                                      zigbee.0
                                      2025-05-21 17:32:19.030	error	unable to call extension Method stop: Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:32:19.029	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      zigbee.0
                                      2025-05-21 17:32:19.029	info	terminating
                                      zigbee.0
                                      2025-05-21 17:32:19.028	info	Saved local configuration data
                                      zigbee.0
                                      2025-05-21 17:32:19.028	info	local config saved
                                      zigbee.0
                                      2025-05-21 17:32:19.027	info	cleaned everything up...
                                      zigbee.0
                                      2025-05-21 17:32:19.022	error	PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                                      zigbee.0
                                      2025-05-21 17:32:19.022	error	Error: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0. at new Controller (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:111:19) at ZigbeeController.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:25) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:233:27) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:71:37) at Zigbee.emit (node:events:536:35) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7810:12) at Zigbee._initAdapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7793:12)
                                      zigbee.0
                                      2025-05-21 17:32:19.020	error	unhandled promise rejection: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                                      zigbee.0
                                      2025-05-21 17:32:19.020	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      2025-05-21 17:32:19.018	info	--> transmitPower : normal
                                      zigbee.0
                                      2025-05-21 17:32:19.016	info	init localConfig
                                      zigbee.0
                                      2025-05-21 17:32:19.008	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                                      zigbee.0
                                      2025-05-21 17:31:50.216	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:49.717	error	Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:31:49.717	error	TypeError: Cannot read properties of undefined (reading 'database') at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:333:27) at DeviceEvent.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:30:25) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:54) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:627:24) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      zigbee.0
                                      2025-05-21 17:31:49.716	error	unhandled promise rejection: Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:31:49.716	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      2025-05-21 17:31:49.716	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:49.716	warn	Failed to stop zigbee during startup
                                      zigbee.0
                                      2025-05-21 17:31:49.716	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                                      zigbee.0
                                      2025-05-21 17:31:49.716	error	unable to call extension Method stop: Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:31:49.715	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      zigbee.0
                                      2025-05-21 17:31:49.714	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:49.714	info	Saved local configuration data
                                      zigbee.0
                                      2025-05-21 17:31:49.713	info	local config saved
                                      zigbee.0
                                      2025-05-21 17:31:49.713	info	cleaned everything up...
                                      zigbee.0
                                      2025-05-21 17:31:49.705	error	PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                                      zigbee.0
                                      2025-05-21 17:31:49.705	error	Error: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0. at new Controller (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:111:19) at ZigbeeController.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:25) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:233:27) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:71:37) at Zigbee.emit (node:events:536:35) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7810:12) at Zigbee._initAdapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7793:12)
                                      zigbee.0
                                      2025-05-21 17:31:49.704	error	unhandled promise rejection: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                                      zigbee.0
                                      2025-05-21 17:31:49.704	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      2025-05-21 17:31:49.702	info	--> transmitPower : normal
                                      zigbee.0
                                      2025-05-21 17:31:49.699	info	init localConfig
                                      zigbee.0
                                      2025-05-21 17:31:49.691	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                                      zigbee.0
                                      2025-05-21 17:31:20.091	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:19.593	error	Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:31:19.593	error	TypeError: Cannot read properties of undefined (reading 'database') at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:333:27) at DeviceEvent.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:30:25) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:54) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:627:24) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                                      zigbee.0
                                      2025-05-21 17:31:19.592	error	unhandled promise rejection: Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:31:19.592	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      2025-05-21 17:31:19.592	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:19.592	warn	Failed to stop zigbee during startup
                                      zigbee.0
                                      2025-05-21 17:31:19.592	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                                      zigbee.0
                                      2025-05-21 17:31:19.591	error	unable to call extension Method stop: Cannot read properties of undefined (reading 'database')
                                      zigbee.0
                                      2025-05-21 17:31:19.590	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                      zigbee.0
                                      2025-05-21 17:31:19.590	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:19.590	info	Saved local configuration data
                                      zigbee.0
                                      2025-05-21 17:31:19.589	info	local config saved
                                      zigbee.0
                                      2025-05-21 17:31:19.588	info	cleaned everything up...
                                      zigbee.0
                                      2025-05-21 17:31:19.583	error	PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                                      zigbee.0
                                      2025-05-21 17:31:19.583	error	Error: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0. at new Controller (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:111:19) at ZigbeeController.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:25) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:233:27) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:71:37) at Zigbee.emit (node:events:536:35) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7810:12) at Zigbee._initAdapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7793:12)
                                      zigbee.0
                                      2025-05-21 17:31:19.582	error	unhandled promise rejection: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                                      zigbee.0
                                      2025-05-21 17:31:19.582	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                      zigbee.0
                                      2025-05-21 17:31:19.579	info	--> transmitPower : normal
                                      zigbee.0
                                      2025-05-21 17:31:19.577	info	init localConfig
                                      zigbee.0
                                      2025-05-21 17:31:19.569	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                                      zigbee.0
                                      2025-05-21 17:31:15.569	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:15.498	info	Closing Zigbee network, 0 seconds remaining
                                      zigbee.0
                                      2025-05-21 17:31:15.291	info	Closing Zigbee network, 0 seconds remaining
                                      zigbee.0
                                      2025-05-21 17:31:15.069	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                      zigbee.0
                                      2025-05-21 17:31:15.069	info	terminating
                                      zigbee.0
                                      2025-05-21 17:31:15.068	info	Saved local configuration data
                                      zigbee.0
                                      2025-05-21 17:31:15.068	info	local config saved
                                      zigbee.0
                                      2025-05-21 17:31:15.068	info	cleaned everything up...
                                      zigbee.0
                                      2025-05-21 17:31:15.067	info	Got terminate signal TERMINATE_YOURSELF
                                      zigbee.0
                                      2025-05-21 17:31:15.003	info	DeviceConfigure successful 0x90fd9ffffe6d32bc LED1546G12
                                      zigbee.0
                                      2025-05-21 17:31:14.353	info	Failed to ping 0xa4c13866fb0b8f27 undefined
                                      zigbee.0
                                      2025-05-21 17:31:13.591	info	Failed to ping 0x000b57fffec367c3 TRADFRI bulb E27 WS opal 980lm
                                      zigbee.0
                                      2025-05-21 17:31:13.034	info	Failed to ping 0x680ae2fffe71bc26 TS011F
                                      zigbee.0
                                      2025-05-21 17:31:12.296	info	Failed to ping 0xbc33acfffec5bc41 TS011F
                                      zigbee.0
                                      2025-05-21 17:31:11.682	info	Failed to ping 0xf0d1b80000148105 B40 TW Z3
                                      zigbee.0
                                      2025-05-21 17:31:10.936	warn	DeviceConfigure:0x842e14fffe556652 TS011F Failed to configure. --> ZCL command 0x842e14fffe556652/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                                      zigbee.0
                                      2025-05-21 17:31:10.654	info	Configuring 0x000b57fffe2b7dea ICTC-G-1
                                      zigbee.0
                                      2025-05-21 17:31:10.653	info	DeviceConfigureQueue configuring 0x000b57fffe2b7dea TRADFRI wireless dimmer
                                      zigbee.0
                                      2025-05-21 17:31:05.660	info	DeviceConfigure successful 0x000b57fffe9e650d ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2
                                      zigbee.0
                                      2025-05-21 17:31:05.653	info	Configuring 0x000b57fffe9e650d ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2
                                      zigbee.0
                                      2025-05-21 17:31:05.653	info	DeviceConfigureQueue configuring 0x000b57fffe9e650d TRADFRI transformer 30W
                                      zigbee.0
                                      2025-05-21 17:31:00.671	info	DeviceConfigure successful 0x00158d00041cd4e6 MCCGQ11LM
                                      zigbee.0
                                      2025-05-21 17:31:00.653	info	Configuring 0x00158d00041cd4e6 MCCGQ11LM
                                      zigbee.0
                                      2025-05-21 17:31:00.653	info	DeviceConfigureQueue configuring 0x00158d00041cd4e6 lumi.sensor_magnet.aq2
                                      zigbee.0
                                      2025-05-21 17:30:55.653	info	Configuring 0x90fd9ffffe6d32bc LED1546G12
                                      zigbee.0
                                      2025-05-21 17:30:55.652	info	DeviceConfigureQueue configuring 0x90fd9ffffe6d32bc TRADFRI bulb E27 WS clear 950lm
                                      zigbee.0
                                      2025-05-21 17:30:55.228	info	Failed to ping 0xf0d1b800001485c8 B40 TW Z3
                                      zigbee.0
                                      2025-05-21 17:30:54.736	info	Failed to ping 0xf0d1b80000148327 B40 TW Z3
                                      zigbee.0
                                      2025-05-21 17:30:54.734	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","pnpId":"usb-Texas_Instruments_CC2538_USB_CDC-if00","vendorId":"0451","productId":"16c8"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
                                      zigbee.0
                                      2025-05-21 17:30:54.225	info	Failed to ping 0xf0d1b800001482e1 B40 TW Z3
                                      zigbee.0
                                      2025-05-21 17:30:53.726	info	Failed to ping 0xf0d1b80000148292 B40 TW Z3
                                      zigbee.0
                                      2025-05-21 17:30:53.224	info	Failed to ping 0x7cb03eaa00aacf5b Classic B40 TW - LIGHTIFY
                                      zigbee.0
                                      2025-05-21 17:30:52.724	info	Failed to ping 0x7cb03eaa00ae1974 Classic B40 TW - LIGHTIFY
                                      zigbee.0
                                      2025-05-21 17:30:52.223	info	Failed to ping 0x7cb03eaa00ae1127 Classic B40 TW - LIGHTIFY
                                      zigbee.0
                                      2025-05-21 17:30:51.722	info	Failed to ping 0x7cb03eaa00ae2265 Classic B40 TW - LIGHTIFY
                                      zigbee.0
                                      2025-05-21 17:30:51.224	info	Failed to ping 0xec1bbdfffed4fe44 TS011F
                                      zigbee.0
                                      2025-05-21 17:30:50.723	info	Failed to ping 0x588e81fffed4affa TS0121
                                      zigbee.0
                                      2025-05-21 17:30:50.652	info	Configuring 0x842e14fffe556652 HG06338
                                      zigbee.0
                                      2025-05-21 17:30:50.651	info	DeviceConfigureQueue configuring 0x842e14fffe556652 TS011F
                                      zigbee.0
                                      2025-05-21 17:30:50.235	info	Failed to ping 0x0017880108b7ba14 LWA001
                                      zigbee.0
                                      2025-05-21 17:30:50.223	info	Failed to ping 0x842e14fffe3a4af8 TS0121
                                      zigbee.0
                                      2025-05-21 17:30:49.804	info	Failed to ping 0xbc33acfffe0ebd34 TS011F
                                      zigbee.0
                                      2025-05-21 17:30:49.195	info	Failed to ping 0xbc33acfffe0ebcf2 TS011F
                                      zigbee.0
                                      2025-05-21 17:30:49.017	info	Failed to ping 0x84182600000f74b5 Classic A60 W clear - LIGHTIFY
                                      zigbee.0
                                      2025-05-21 17:30:47.980	info	Failed to ping 0x540f57fffe2b1fc5 TS0101
                                      zigbee.0
                                      2025-05-21 17:30:47.918	info	Failed to ping 0x000b57fffe9e650d TRADFRI transformer 30W
                                      zigbee.0
                                      2025-05-21 17:30:47.099	info	Failed to ping 0x90fd9ffffe6d32bc TRADFRI bulb E27 WS clear 950lm
                                      zigbee.0
                                      2025-05-21 17:30:46.872	info	copied /tmp/WSDCGQ01LM.png to img/WSDCGQ01LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.829	info	copied /tmp/TS0201.png to img/TS0201.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.826	warn	error removing /tmp/HG08164.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG08164.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.826	warn	error removing /tmp/LED1545G12.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/LED1545G12.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.826	warn	error removing /tmp/HG06337.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG06337.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.826	warn	error removing /tmp/4058075208414.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/4058075208414.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.825	info	copied /tmp/HG08164.png to img/HG08164.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.825	info	copied /tmp/LED1545G12.png to img/LED1545G12.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.825	info	copied /tmp/HG06337.png to img/HG06337.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.824	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.821	info	Failed to ping 0x842e14fffe556652 TS011F
                                      zigbee.0
                                      2025-05-21 17:30:46.782	warn	error removing /tmp/4058075208414.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/4058075208414.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.782	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.781	warn	error removing /tmp/4058075208414.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/4058075208414.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.781	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.678	warn	error removing /tmp/MCCGQ11LM.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/MCCGQ11LM.png"}
                                      zigbee.0
                                      zigbee.0
                                      2025-05-21 17:30:46.678	warn	error removing /tmp/HG06337.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG06337.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.677	warn	error removing /tmp/HG06337.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG06337.png"}
                                      zigbee.0
                                      2025-05-21 17:30:46.676	info	copied /tmp/TS0121_plug.png to img/TS0121_plug.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.676	info	copied /tmp/WXCJKG13LM.png to img/WXCJKG13LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.676	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.676	info	copied /tmp/WSDCGQ11LM.png to img/WSDCGQ11LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.676	info	copied /tmp/HG08164.png to img/HG08164.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.676	info	copied /tmp/8718699673147.png to img/8718699673147.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.675	info	copied /tmp/AB32840.png to img/AB32840.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.675	info	copied /tmp/ICTC-G-1.png to img/ICTC-G-1.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.675	info	copied /tmp/HS1SA.png to img/HS1SA.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.675	info	copied /tmp/MFKZQ01LM.png to img/MFKZQ01LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.675	info	copied /tmp/LED1546G12.png to img/LED1546G12.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.674	info	copied /tmp/HG06620.png to img/HG06620.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.674	info	copied /tmp/AC03641.png to img/AC03641.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.674	info	copied /tmp/LED1545G12.png to img/LED1545G12.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.674	info	copied /tmp/E1524-E1810.png to img/E1524-E1810.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.674	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.673	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.673	info	copied /tmp/HG06337.png to img/HG06337.png.
                                      zigbee.0
                                      zigbee.0
                                      2025-05-21 17:30:46.673	info	copied /tmp/E1524-E1810.png to img/E1524-E1810.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.672	info	copied /tmp/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png to img/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.665	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.643	info	copied /tmp/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png to img/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.643	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.643	info	copied /tmp/HG06337.png to img/HG06337.png.
                                      zigbee.0
                                      2025-05-21 17:30:46.510	warn	Device 0xa4c13866fb0b8f27 "undefined" not found.
                                      zigbee.0
                                      2025-05-21 17:30:46.488	info	not downloading /tmp/LED1545G12.png - file exists
                                      zigbee.0
                                      2025-05-21 17:30:46.488	info	not downloading /tmp/HG08164.png - file exists
                                      zigbee.0
                                      2025-05-21 17:30:46.487	info	not downloading /tmp/HG06337.png - file exists
                                      zigbee.0
                                      2025-05-21 17:30:46.487	info	not downloading /tmp/4058075208414.png - file exists
                                      zigbee.0
                                      zigbee.0
                                      zigbee.0
                                      2025-05-21 17:30:46.311	info	not downloading /tmp/MCCGQ11LM.png - file exists
                                      zigbee.0
                                        Mr.X @Asgothian last edited by
                                        A.
                                        womit kann ich die aufmachen, damit das sinnvoll aussieht?
                                        Da steht seeeehr viel drin, kenne mich damit aber leider niht aus.
                                        • Asgothian
                                          @mr-x laut den Fehlermeldungen hast du keine Einträge für panID und extPanID in der Konfiguration. Da passt etwas nicht zusammen.
                                          Mein Vorschlag - wir treffen uns auf dem iobroker discord - dann können wir das im Dialog gemeinsam gerade biegen. Dieses scheibchenweise wird so nicht einfach werden. Ich hätte dafür heute Zeit.
                                          A.
                                            @asgothian
                                            Kann ich verstehen. Und gebe dir recht.
                                            Nur kamen vorhin die Kinder nach Hause und die prios haben sich verschoben.
                                            Ich habe erstmal hier nachgelesen was discord ist u d mich angemeldeten.
                                            Morgen schaue ich es mit genauer an und wie es im Browser läuft mit chatten und ggf screen share.
                                            Wenn ich soweit bin würde ich mich gerne mal bei dir melden, wenn das Angebot noch steht.
                                            Hast du irgendwelche geeigneten Tage oder Zeiten in denen es passt?
                                            Danke und Grüße
                                            1025
