    3. Entwicklung
    4. Anker Adapter
    Anker Adapter
      erazorlee @ronny130286 last edited by
      @ronny130286
      Sieht so aus. Bei der Bank mit Smartmeter bekomme ich die Meldung nicht, bei der ohne schon.
        ronny130286 @erazorlee last edited by
        @erazorlee
        Wäre es möglich, das du mirdas RAW_JSON von der Solarbank wo es nicht geht zur Verfügung stellen könntest?
        Thomas Braun E 2 Replies Last reply Reply Quote 0
          Thomas Braun Most Active @ronny130286 last edited by
          @ronny130286
          Ich bin zwar nicht angesprochen, habe die Meldungen aber auch.
          RAW_JSON:
          {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"563.31","unit":"kwh"},{"type":"2","total":"561.62","unit":"kg"},{"type":"3","total":"225.33","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZV6Y60D12345678","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"100","bind_site_status":"","charging_power":"185","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"185","output_power":"185","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"1.00","updated_time":"2025-05-15 18:04:14","total_photovoltaic_power":"185","total_output_power":"185.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"185","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0},"use_time_excute_info":{"current_band":"0"}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"asdec432-abc6-45c0-bb93-cb80eb3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1,"user_scene_mode":0,"is_dynamic_price_down_grade":false,"aiems_profit":null,"switch_0w":0}
            ronny130286 @Thomas Braun last edited by ronny130286
            Danke dir 🙂
            Lösch es mal bitte wieder, weil deine SN sichtbar ist 😉 man weis ja nie
            Ich gucke durch und patche es:)
              Thomas Braun Most Active @ronny130286 last edited by Thomas Braun
              @ronny130286 sagte in Anker Adapter:
              Die hab ich verändert. Ist die S/N von wem anders dann... 🙂
              Und die site_id ist auch gefälscht.
                Sehr gut 😄
                  @ronny130286
                  Patch funktioniert, die Meldungen zum grid sind weg.
                  Jetzt ist mein LogFile auch wieder übersichtlich!
                  Danke schön!
                    Danke für das Feedback, ich lasse es mal noch bis nächste Woche im Beta Repo und mache dann eine Stable drauß (wenn es keine weitern Probleme gibt)
                      @ronny130286
                      sorry, war "urlaubusbedingt" nicht online.
                      Das Thema hat sich ja erledigt.
                      Danke für deinen Einsatz.
                        Tony H. last edited by
                        Gude,
                        Ich habe die Solix 3 pro in Betrieb, einmal kamen Daten rein aber es wird nichts so richtig aktualisiert. Hat einer ein Trick 17?
                        Thomas Braun R 2 Replies Last reply Reply Quote 0
                          Thomas Braun Most Active @Tony H. last edited by
                          @tony-h sagte in Anker Adapter:
                          Trick 16: Schau ins Log, vielleicht steht da was zu Trick 17 drin.
                            ronny130286 @Tony H. last edited by
                            @tony-h
                            Ein Trick gibt es da leider nicht, ich kann dir nur soviel sagen, dass nicht immer alle Daten aktualisiert werden, weil in der Anker Cloud auch keine neuen Daten zur Verfügung stehen.
                            Die Datenpunkten werden nur geändert, wenn es eine Aktualisierung gegeben hat.
                            Bspw. wird bei mir immer zuverlässig der Wert ankersolix2.0.xxxxxxxxxxxxxxx.home_load_power aktualisiert
                            Wenn man jedoch in der Anker App selbst guckt (zumindest ist es bei mir so) dann sieht man auch, dass das Diagramm nur alle 20min einen Wert bekommt.
                              gluecksmann last edited by
                              Hat jemand mal ein schönes Beispiel wie man das mit dem Energiefluss 2 Adapter visualisiert?
                              UweRLP 1 Reply Last reply Reply Quote 0
                                @ronny130286
                                Was denkst du, wann du das stable fertig hast?
                                  @erazorlee
                                  Ich spiele heute nochmal einen kleinen Patch ein, weil die Solix 3 einen neuen Wert liefert, der als String erkannt wird, allerdings ein bool ist.
                                  Wenn das alles chic ist, wird es Freitag oder Samstag zur Stable;)
                                    @ronny130286
                                    Mir scheint das in ein Install-Loop zu laufen:
                                    Adapter    "ankersolix2"  : 2.1.2    , installed 2.1.1  [Updatable]
                                    Wird jedenfalls nach erfolgreichem Update wieder zum Update vorgeschlagen.
                                    Hatten wir neulich bei anderen Adaptern schon mal.
                                    • mcm1957
                                      mcm1957 @Thomas Braun last edited by
                                      2.1.2 ist auf npm verfügbar. Die Version stimmt.
                                      Warum das nicht sauber installiert wird kann ich nicht sagen. Mit den Problemen vor ca 1 bis 2 Woichen ("Fantasieversionen") hat das definitiv nichts zu tun.
                                      Ev. mach ein Issue beim js-controller auf. Nehme an du installierst auf der commandline ( 🙂 ) - also kann da admin nicht mitspielen. Ev. schau was nun wirklich installiuert ist (npm paket / io-package.json Inhalt)
                                        Thomas Braun Most Active @mcm1957 last edited by
                                        @mcm1957
                                        Alles i.O.! Das war auf meinem Test-System (mit nodejs@22 und installiertem yahka).
                                        Und da klemmt es ja zur Zeit...
                                        yahka rausgekickt und das Update ging dann auch tatsächlich durch.
                                        • mcm1957
                                          OK - bei YAHKA und node 22 kriegst nen npm Fehler 🙂
                                          Und wie im anderen Posting geschrieben an unerwarteten Stellen 🙂 🙂 🙂
                                            @mcm1957 sagte in Anker Adapter:
                                            Aber nicht, wenn du andere Adapter installierst oder updatest. Das ist aber gemein! 🙂
                                            359
                                            87604
