    3. Entwicklung
    4. Anker Adapter
    Anker Adapter
      Thomas Braun Most Active @ronny130286 last edited by
      @ronny130286
      Ich bin zwar nicht angesprochen, habe die Meldungen aber auch.
      RAW_JSON:
      {"home_info":{"home_name":"Home","home_img":"","charging_power":"0.00","power_unit":"W"},"solar_list":[],"pps_info":{"pps_list":[],"total_charging_power":"0.00","power_unit":"W","total_battery_power":"0.00","updated_time":"","pps_status":0},"statistics":[{"type":"1","total":"563.31","unit":"kwh"},{"type":"2","total":"561.62","unit":"kg"},{"type":"3","total":"225.33","unit":"€"}],"topology_type":"1","solarbank_info":{"solarbank_list":[{"device_pn":"A17C0","device_sn":"AZV6Y60D12345678","device_name":"Solarbank E1600","device_img":"https://public-aiot-fra-prod.s3.dualstack.eu-central-1.amazonaws.com/anker-power/public/product/2024/05/10/iot-admin/FycLLqjHpYf0Bdab/20230719-144818.png","battery_power":"100","bind_site_status":"","charging_power":"185","power_unit":"W","charging_status":"1","status":"1","wireless_type":"1","main_version":"","photovoltaic_power":"185","output_power":"185","create_time":1721841629,"set_load_power":"","sub_package_num":0,"output_cutoff_data":10,"is_display":true,"bat_charge_power":"0"}],"total_charging_power":"0","power_unit":"W","charging_status":"0","total_battery_power":"1.00","updated_time":"2025-05-15 18:04:14","total_photovoltaic_power":"185","total_output_power":"185.00","display_set_power":false,"battery_discharge_power":"0","ac_power":"0","to_home_load":"0","is_display_data":true,"solar_power_1":"0","solar_power_2":"0","solar_power_3":"0","solar_power_4":"0","other_input_power":"0","micro_inverter_power":"185","micro_inverter_power_limit":"0","micro_inverter_low_power_limit":"0","grid_to_battery_power":"0","pei_heating_power":"0","backup_info":{"start_time":0,"end_time":0,"full_time":0},"use_time_excute_info":{"current_band":"0"}},"retain_load":"150W","scene_mode":0,"home_load_power":"0","updated_time":"01-01-0001 00:00:00","power_site_type":2,"site_id":"asdec432-abc6-45c0-bb93-cb80eb3bcc29","powerpanel_list":[],"grid_info":null,"is_downgrade":false,"error_code":0,"smart_plug_info":null,"feature_switch":null,"other_loads_power":"0","priority_discharge_switch":0,"display_priority_discharge_tips":0,"priority_discharge_upgrade_devices":"","style_id":0,"is_show_priority_discharge":1,"user_scene_mode":0,"is_dynamic_price_down_grade":false,"aiems_profit":null,"switch_0w":0}
        ronny130286 @Thomas Braun last edited by ronny130286
        Danke dir 🙂
        Lösch es mal bitte wieder, weil deine SN sichtbar ist 😉 man weis ja nie
        Ich gucke durch und patche es:)
          Thomas Braun Most Active @ronny130286 last edited by Thomas Braun
          @ronny130286 sagte in Anker Adapter:
          Die hab ich verändert. Ist die S/N von wem anders dann... 🙂
          Und die site_id ist auch gefälscht.
            Sehr gut 😄
              @ronny130286
              Patch funktioniert, die Meldungen zum grid sind weg.
              Jetzt ist mein LogFile auch wieder übersichtlich!
              Danke schön!
                Danke für das Feedback, ich lasse es mal noch bis nächste Woche im Beta Repo und mache dann eine Stable drauß (wenn es keine weitern Probleme gibt)
                  erazorlee @ronny130286 last edited by
                  @ronny130286
                  sorry, war "urlaubusbedingt" nicht online.
                  Das Thema hat sich ja erledigt.
                  Danke für deinen Einsatz.
                    Tony H. last edited by
                    Gude,
                    Ich habe die Solix 3 pro in Betrieb, einmal kamen Daten rein aber es wird nichts so richtig aktualisiert. Hat einer ein Trick 17?
                    Thomas Braun R 2 Replies Last reply Reply Quote 0
                      Thomas Braun Most Active @Tony H. last edited by
                      @tony-h sagte in Anker Adapter:
                      Trick 16: Schau ins Log, vielleicht steht da was zu Trick 17 drin.
                        ronny130286 @Tony H. last edited by
                        @tony-h
                        Ein Trick gibt es da leider nicht, ich kann dir nur soviel sagen, dass nicht immer alle Daten aktualisiert werden, weil in der Anker Cloud auch keine neuen Daten zur Verfügung stehen.
                        Die Datenpunkten werden nur geändert, wenn es eine Aktualisierung gegeben hat.
                        Bspw. wird bei mir immer zuverlässig der Wert ankersolix2.0.xxxxxxxxxxxxxxx.home_load_power aktualisiert
                        Wenn man jedoch in der Anker App selbst guckt (zumindest ist es bei mir so) dann sieht man auch, dass das Diagramm nur alle 20min einen Wert bekommt.
                          gluecksmann last edited by
                          Hat jemand mal ein schönes Beispiel wie man das mit dem Energiefluss 2 Adapter visualisiert?
                          UweRLP 1 Reply Last reply Reply Quote 0
                            @ronny130286
                            Was denkst du, wann du das stable fertig hast?
                              @erazorlee
                              Ich spiele heute nochmal einen kleinen Patch ein, weil die Solix 3 einen neuen Wert liefert, der als String erkannt wird, allerdings ein bool ist.
                              Wenn das alles chic ist, wird es Freitag oder Samstag zur Stable;)
                                @ronny130286
                                Mir scheint das in ein Install-Loop zu laufen:
                                Adapter    "ankersolix2"  : 2.1.2    , installed 2.1.1  [Updatable]
                                Wird jedenfalls nach erfolgreichem Update wieder zum Update vorgeschlagen.
                                Hatten wir neulich bei anderen Adaptern schon mal.
                                • mcm1957
                                  mcm1957 @Thomas Braun last edited by
                                  2.1.2 ist auf npm verfügbar. Die Version stimmt.
                                  Warum das nicht sauber installiert wird kann ich nicht sagen. Mit den Problemen vor ca 1 bis 2 Woichen ("Fantasieversionen") hat das definitiv nichts zu tun.
                                  Ev. mach ein Issue beim js-controller auf. Nehme an du installierst auf der commandline ( 🙂 ) - also kann da admin nicht mitspielen. Ev. schau was nun wirklich installiuert ist (npm paket / io-package.json Inhalt)
                                    Thomas Braun Most Active @mcm1957 last edited by
                                    @mcm1957
                                    Alles i.O.! Das war auf meinem Test-System (mit nodejs@22 und installiertem yahka).
                                    Und da klemmt es ja zur Zeit...
                                    yahka rausgekickt und das Update ging dann auch tatsächlich durch.
                                    • mcm1957
                                      OK - bei YAHKA und node 22 kriegst nen npm Fehler 🙂
                                      Und wie im anderen Posting geschrieben an unerwarteten Stellen 🙂 🙂 🙂
                                        @mcm1957 sagte in Anker Adapter:
                                        Aber nicht, wenn du andere Adapter installierst oder updatest. Das ist aber gemein! 🙂
                                        • mcm1957
                                          hmm
                                          Beim Update von backitup kam ein Fehler (lt. Diskussion in Telegram oder so - habs nicht mehr im Kopf).
                                          Ist aber jedenfalls hier OT.
                                            Mumpitz last edited by
                                            Hallo Ronny,
                                            vielen Dank für den Anker-Adapter. Klasse Arbeit.
                                            Habe seit heute eine Solix 3 Pro im Einsatz und wollte einen Max-Wert für den Datenpunkt ankersolix2.0.xxxxxxx.solarbank_info.battery_discharge_power über den Statistics-Adapter einbauen. Statistics sagt bei dem Wert aber, dass es weder Boolean noch Number ist und lässt mich dann die Einstellungen für Min/Max-Werte nicht auswählen.
                                            Bei anderen Werten funktioniert es aber. Zum Beispiel für:
                                            statistics.0.temp.minmax.ankersolix2.0.xxxxxxxx.solarbank_info.total_charging_power.dayMax
                                            Wäre toll, wenn du da mal schauen könntes.
                                            Viele Grüße
                                            Uwe
                                            359
                                            87618
