    4. [gelöst]SONOFF ZigBee 3.0 wird n. in Zigbee eingebunden
      Högi last edited by Högi
      *** BASE SYSTEM ***
       Static hostname: raspberrypi64bitbookworm
             Icon name: computer
                Kernel: Linux 6.12.25+rpt-rpi-v8
          Architecture: arm64
      OS is similar to:
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 64 bit
      Systemuptime and Load:
       20:35:21 up 59 min,  2 users,  load average: 0.23, 0.20, 0.27
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-05-22 20:35:21 CEST
                 Universal time: Thu 2025-05-22 18:35:21 UTC
                       RTC time: Thu 2025-05-22 18:35:21
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      josef
      HOME=/home/josef
      GROUPS=josef adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            4.0G        2.2G        1.3G        6.3M        554M        1.8G
      Swap:           536M          0B        536M
      Total:          4.5G        2.2G        1.8G
      Active iob-Instances:   23
               3791 M total memory
               2097 M used memory
               2147 M active memory
                256 M inactive memory
               1243 M free memory
                 50 M buffer memory
                478 M swap cache
                511 M total swap
                  0 M used swap
                511 M free swap
      top - 20:35:22 up 59 min,  2 users,  load average: 0.23, 0.20, 0.27
      Tasks: 235 total,   1 running, 234 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us, 16.7 sy,  0.0 ni, 83.3 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3791.4 total,   1243.5 free,   2097.5 used,    529.2 buff/cache
      MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1694.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs  1.6G     0  1.6G   0% /dev
      tmpfs          tmpfs     380M  6.0M  374M   2% /run
      /dev/mmcblk0p2 ext4       59G  7.1G   49G  13% /
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      /dev/mmcblk0p1 vfat      510M   57M  454M  12% /boot/firmware
      tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
      [Thu May 22 19:35:30 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:1C:58:B7 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=3907a7b3-02 rootfstype=ext4 fsck.repair=yes rootwait
      [Thu May 22 19:35:31 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
      [Thu May 22 19:35:33 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
      Show mounted filesystems:
      TARGET           SOURCE         FSTYPE OPTIONS
      /                /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      1.6G    /var/
      861M    /var/lib
      684M    /var/lib/piVCCU3
      617M    /var/lib/piVCCU3/rootfs
      288M    /var/lib/piVCCU3/rootfs/opt
      Archived and active journals take up 4.7M in the file system.
      /opt/iobroker/backups:
      1.8M    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      924M    /opt/iobroker/iobroker-data/
      836M    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      25M     /opt/iobroker/iobroker-data/objects.jsonl
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      19M     /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.02fc3820.js.map
      8.8M    /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e3882639474ef11b58fd08c8fcc3fa0-if00-port0
      *** ZigBee Settings ***
      Your zigbee.0 COM-Port is matching 'by-id'. Very good!
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.19.2
      /usr/bin/node           v20.19.2
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.31.0
      nodejs:
        Installed: 20.19.2-1nodesource1
        Candidate: 20.19.2-1nodesource1
        Version table:
       *** 20.19.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
              100 /var/lib/dpkg/status
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
           18.19.0+dfsg-6~deb12u1 500
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi64bitbookworm raspberrypi64bitbookworm (version: 7.0.6, hostname: raspberrypi64bitbookworm, alive, uptime: 3591)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.6.3
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi64bitbookworm                 -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.broadlink2.0             : broadlink2            : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.email.0                  : email                 : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.hm-rega.0                : hm-rega               : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.hm-rpc.0                 : hm-rpc                : raspberrypi64bitbookworm                 -  enabled, port: 0
      + system.adapter.hm-rpc.1                 : hm-rpc                : raspberrypi64bitbookworm                 -  enabled, port: 0
      + system.adapter.hm-rpc.2                 : hm-rpc                : raspberrypi64bitbookworm                 -  enabled, port: 0
      + system.adapter.iot.0                    : iot                   : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.pushover.0               : pushover              : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.shelly.0                 : shelly                : raspberrypi64bitbookworm                 -  enabled, port: 1882, bind: 0.0.0.0
      + system.adapter.simple-api.0             : simple-api            : raspberrypi64bitbookworm                 -  enabled, port: 8087, bind: 192.168.178.150, run as: admin
      + system.adapter.sureflap.0               : sureflap              : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi64bitbookworm                 -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.tuya.0                   : tuya                  : raspberrypi64bitbookworm                 -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi64bitbookworm                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.zigbee.0                 : zigbee                : raspberrypi64bitbookworm                 -  enabled, port: /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e3882639474ef11b58fd08c8fcc3fa0-if00-port0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.3    , installed 7.6.3
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "broadlink2"   : 2.3.0    , installed 2.3.0
      Adapter    "deyeidc"      : 0.2.0    , installed 0.2.0
      Adapter    "email"        : 2.0.4    , installed 2.0.4
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "pushover"     : 4.1.0    , installed 4.1.0
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 9.2.0    , installed 9.2.0
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 7.0.8
      Adapter    "sureflap"     : 3.1.1    , installed 3.1.1
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 3.0.19
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Objects and States
      Objects:        13034
      States:         10197
      Hit:2 http://phoscon.de/apt/deconz generic InRelease
      Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
      Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:6 https://deb.nodesource.com/node_20.x nodistro InRelease
      Hit:7 https://apt.pivccu.de/piVCCU stable InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 10.0.3.1:53             0.0.0.0:*               LISTEN      0          6464       912/dnsmasq
      tcp        0      0 192.168.178.21:8701     0.0.0.0:*               LISTEN      1001       9054       2223/io.hm-rpc.1
      tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       7782       1800/io.shelly.0
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          6228       637/sshd: /usr/sbin
      tcp        0      0 192.168.178.21:2010     0.0.0.0:*               LISTEN      1001       10540      2287/io.hm-rpc.2
      tcp        0      0 192.168.178.21:42001    0.0.0.0:*               LISTEN      1001       9439       2202/io.hm-rpc.0
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       5437       625/iobroker.js-con
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       6247       625/iobroker.js-con
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       6124       2010/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       6307       687/io.admin.0
      tcp6       0      0 :::22                   :::*                    LISTEN      0          6230       637/sshd: /usr/sbin
      udp        0      0 10.0.3.1:53             0.0.0.0:*                           0          6463       912/dnsmasq
      udp        0      0 0.0.0.0:67              0.0.0.0:*                           0          6460       912/dnsmasq
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       7786       1679/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       7787       1679/io.tuya.0
      udp        0      0 0.0.0.0:15001           0.0.0.0:*                           1001       8263       960/io.broadlink2.0
      udp        0      0 0.0.0.0:33798           0.0.0.0:*                           104        6174       503/avahi-daemon: r
      udp        0      0 0.0.0.0:46187           0.0.0.0:*                           1001       8287       960/io.broadlink2.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6172       503/avahi-daemon: r
      udp        0      0 0.0.0.0:44317           0.0.0.0:*                           1001       7465       960/io.broadlink2.0
      udp6       0      0 :::40622                :::*                                104        6175       503/avahi-daemon: r
      udp6       0      0 :::5353                 :::*                                104        6173       503/avahi-daemon: r
      2025-05-22 20:18:28.783  - info: zigbee.0 (5204) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      2025-05-22 20:18:28.785  - info: zigbee.0 (5204) Starting Zigbee-Herdsman
      2025-05-22 20:18:55.193  - info: zigbee.0 (5204) Unable to obtain herdsman settings
      2025-05-22 20:18:55.345  - error: zigbee.0 (5204) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
      2025-05-22 20:18:55.347  - error: zigbee.0 (5204) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      2025-05-22 20:18:55.348  - error: zigbee.0 (5204) unhandled promise rejection: undefined
      2025-05-22 20:18:55.349  - error: zigbee.0 (5204) undefined
      2025-05-22 20:18:55.403  - info: zigbee.0 (5204) cleaned everything up...
      2025-05-22 20:18:55.405  - info: zigbee.0 (5204) local config saved
      2025-05-22 20:18:55.408  - info: zigbee.0 (5204) Saved local configuration data
      2025-05-22 20:18:55.409  - info: zigbee.0 (5204) terminating
      2025-05-22 20:18:55.412  - warn: zigbee.0 (5204) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-05-22 20:18:55.423  - error: zigbee.0 (5204) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
          at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/src/controller/controller.ts:315:35)
          at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33)
          at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24)
          at processTicksAndRejections (node:internal/process/task_queues:95:5)
          at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
      2025-05-22 20:18:55.427  - info: zigbee.0 (5204) terminating
      2025-05-22 20:18:55.914  - info: zigbee.0 (5204) terminating
      2025-05-22 20:18:56.099  - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
      2025-05-22 20:18:56.100  - error: host.raspberrypi64bitbookworm Caught by controller[0]: Error herdsman start
      2025-05-22 20:18:56.100  - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-05-22 20:18:56.100  - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
      2025-05-22 20:18:56.100  - warn: host.raspberrypi64bitbookworm Do not restart adapter system.adapter.zigbee.0 because restart loop detected
      vorab bitte ich um ein etwas Nachsicht, da ich auf die 70 zugehe und was
      Linux angeht einfach copy und paste Laie bin.
      Ich betreibe meine Hausautomation mit Iobroker und PVICCU3.
      Ich habe mein System neu aufsetzen müssen (10 Jahre lief alles sehr gut auch mit root rechten) und habe soweit alles wieder am laufen. Bin auf einen PI 4 umgezogen.
      Einzig am verzweifeln bin ich an der Einbindung von meines neuen SONOFF ZigBee 3.0 USB DONGLE PLUS in den Adapter zigbee.
      Nach der Eingabe (siehe Bild)
      bleibt der Adapter auf gelb und die Fehlermeldungen (siehe iob diag) erscheinen.
      Habe schon im Netz alles an Vorschlägen etc. probiert aber ich komme nicht weiter.
      Habe es auch mit einem Conbee2 versucht aber auch das ging nicht.
      Vielleicht liest ja Thomas Braun mit, von dem ich dank seiner Expertise viel gelernt habe 👍
      Ich glaube das Problem hängt mit der Installation von PVICCU3 zusammen.
      Auf github (https://github.com/alexreinert/piVCCU/blob/master/docs/setup/raspberrypi.md)
      musste ich bei der Installation Raspbarry PI unter Punkt 8 die alte Methode zur Netzwerkkonfiguration ändern mit folgenden Befehlen:
      sudo nmcli connection show --active
      sudo apt install bridge-utils
      sudo nmcli connection add ifname br0 type bridge con-name br0
      sudo nmcli connection add type bridge-slave ifname eth0 master br0
      Vielleicht wird hier etwas geblockt.
      Ich hoffe Ihr könnt mir helfen.
      Danke im Voraus
      Jupp
      P.S
      Da meine Frau nicht mehr so fit ist, muss ich sagen, das der Alltag mit Alexa und Sprachsteuerung uns das Leben viel einfacher macht.
      Und das ist auch vielleicht mal ein Thema. Wenn mir z.b. mal was passiert und das System
      stürzt ab und nichts geht mehr was dann?
      Ich habe eine Dokumentation mit allen Passwörtern meiner Frau übergeben,
      und einen mir bekannten Ansprechpartner, der sich auskennt, der dann aushelfen muss.
      Das mal zum Nachdenken für die jüngere Generation.
      • Asgothian
        Asgothian Developer last edited by Asgothian
        @högi
        • du musst unbedingt die panID anpassen - die ist so nicht gut. (16 stellige zahl, nicht 16 mal D
        • mach bitte folgendes:
          — zigbee Adapter anhalten
          — iobroker log löschen
          — zigbee Adapter starten
          — 120 Sekunden (plus/minus ein paar Sekunden ) warten.
          — log herunter laden
          — das herunter geladene log hier in code-tags posten.
        A.
          Högi @Asgothian last edited by Högi
          @asgothian
          hier die Ausgabe vom log.
          2025-05-22 22:05:30.312 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 13269
          2025-05-22 22:05:34.282 - info: zigbee.0 (13269) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
          2025-05-22 22:05:34.312 - info: zigbee.0 (13269) init localConfig
          2025-05-22 22:05:34.323 - info: zigbee.0 (13269) --> transmitPower : normal
          2025-05-22 22:05:34.339 - info: zigbee.0 (13269) delete old Backup files. keep only last 10
          2025-05-22 22:05:34.344 - info: zigbee.0 (13269) --- creating device debug ---
          2025-05-22 22:05:34.346 - info: zigbee.0 (13269) Starting Adapter npm ...
          2025-05-22 22:05:34.404 - info: zigbee.0 (13269) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
          2025-05-22 22:05:34.406 - info: zigbee.0 (13269) Starting Zigbee-Herdsman
          2025-05-22 22:05:48.281 - info: host.raspberrypi64bitbookworm "system.adapter.zigbee.0" disabled
          2025-05-22 22:05:48.286 - info: host.raspberrypi64bitbookworm stopInstance system.adapter.zigbee.0 (force=false, process=true)
          2025-05-22 22:05:48.294 - info: zigbee.0 (13269) Got terminate signal TERMINATE_YOURSELF
          2025-05-22 22:05:48.298 - info: zigbee.0 (13269) cleaned everything up...
          2025-05-22 22:05:48.299 - info: zigbee.0 (13269) local config saved
          2025-05-22 22:05:48.301 - info: zigbee.0 (13269) Saved local configuration data
          2025-05-22 22:05:48.302 - info: zigbee.0 (13269) terminating
          2025-05-22 22:05:48.304 - info: zigbee.0 (13269) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
          2025-05-22 22:05:48.405 - error: zigbee.0 (13269) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
          2025-05-22 22:05:48.416 - info: zigbee.0 (13269) terminating
          2025-05-22 22:05:48.452 - info: host.raspberrypi64bitbookworm stopInstance system.adapter.zigbee.0 send kill signal
          2025-05-22 22:05:48.806 - info: zigbee.0 (13269) terminating
          2025-05-22 22:05:48.982 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
          2025-05-22 22:12:25.154 - info: admin.0 (687) ==> Connected system.user.admin from ::ffff:192.168.178.102
          2025-05-22 22:17:25.242 - info: admin.0 (687) <== Disconnect system.user.admin from ::ffff:192.168.178.102
          2025-05-22 22:18:55.896 - info: host.raspberrypi64bitbookworm "system.adapter.zigbee.0" enabled
          2025-05-22 22:18:57.325 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 14090
          2025-05-22 22:19:01.371 - info: zigbee.0 (14090) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
          2025-05-22 22:19:01.402 - info: zigbee.0 (14090) init localConfig
          2025-05-22 22:19:01.412 - info: zigbee.0 (14090) --> transmitPower : normal
          2025-05-22 22:19:01.429 - info: zigbee.0 (14090) delete old Backup files. keep only last 10
          2025-05-22 22:19:01.433 - info: zigbee.0 (14090) --- creating device debug ---
          2025-05-22 22:19:01.436 - info: zigbee.0 (14090) Starting Adapter npm ...
          2025-05-22 22:19:01.492 - info: zigbee.0 (14090) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
          2025-05-22 22:19:01.494 - info: zigbee.0 (14090) Starting Zigbee-Herdsman
          2025-05-22 22:19:24.177 - info: admin.0 (687) ==> Connected system.user.admin from ::ffff:192.168.178.102
          2025-05-22 22:19:24.473 - error: zigbee.0 (14090) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-05-22 22:19:24.475 - error: zigbee.0 (14090) unhandled promise rejection: Cannot read properties of undefined (reading 'CleanupRequired')
          2025-05-22 22:19:24.804 - error: zigbee.0 (14090) TypeError: Cannot read properties of undefined (reading 'CleanupRequired')
          at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:155:97)
          at Zigbee. (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:20:48)
          at Zigbee.emit (node:events:536:35)
          at Zigbee.emit (node:domain:489:12)
          at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10953:34)
          at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:368:37)
          at processImmediate (node:internal/timers:483:21)
          2025-05-22 22:19:24.805 - error: zigbee.0 (14090) Cannot read properties of undefined (reading 'CleanupRequired')
          2025-05-22 22:19:24.865 - info: zigbee.0 (14090) cleaned everything up...
          2025-05-22 22:19:24.866 - info: zigbee.0 (14090) local config saved
          2025-05-22 22:19:24.868 - info: zigbee.0 (14090) Saved local configuration data
          2025-05-22 22:19:24.869 - info: zigbee.0 (14090) terminating
          2025-05-22 22:19:24.873 - warn: zigbee.0 (14090) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-05-22 22:19:24.920 - error: zigbee.0 (14090) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
          2025-05-22 22:19:24.927 - info: zigbee.0 (14090) terminating
          2025-05-22 22:19:25.007 - info: zigbee.0 (14090) List of port: [{"path":"/dev/ttyUSB0","manufacturer":"ITead","serialNumber":"2e3882639474ef11b58fd08c8fcc3fa0","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_2e3882639474ef11b58fd08c8fcc3fa0-if00-port0","vendorId":"10c4","productId":"ea60"},{"path":"/dev/ttyS0"}]
          2025-05-22 22:19:25.382 - info: zigbee.0 (14090) terminating
          2025-05-22 22:19:25.562 - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: TypeError: Cannot read properties of undefined (reading 'CleanupRequired')
          2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Commands.onMessage (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:155:97)
          2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Zigbee. (/opt/iobroker/node_modules/iobroker.zigbee/lib/commands.js:20:48)
          2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Zigbee.emit (node:events:536:35)
          2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Zigbee.emit (node:domain:489:12)
          2025-05-22 22:19:25.563 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at change (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/src/lib/adapter/adapter.ts:10953:34)
          2025-05-22 22:19:25.564 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at Immediate. (file:///opt/iobroker/node_modules/@iobroker/db-states-redis/src/lib/states/statesInRedisClient.ts:368:37)
          2025-05-22 22:19:25.564 - error: host.raspberrypi64bitbookworm Caught by controller[0]: at processImmediate (node:internal/timers:483:21)
          2025-05-22 22:19:25.564 - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2025-05-22 22:19:25.564 - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
          2025-05-22 22:19:56.435 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 14168
          2025-05-22 22:20:00.397 - info: zigbee.0 (14168) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
          2025-05-22 22:20:00.428 - info: zigbee.0 (14168) init localConfig
          2025-05-22 22:20:00.441 - info: zigbee.0 (14168) --> transmitPower : normal
          2025-05-22 22:20:00.460 - info: zigbee.0 (14168) delete old Backup files. keep only last 10
          2025-05-22 22:20:00.465 - info: zigbee.0 (14168) --- creating device debug ---
          2025-05-22 22:20:00.467 - info: zigbee.0 (14168) Starting Adapter npm ...
          2025-05-22 22:20:00.542 - info: zigbee.0 (14168) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
          2025-05-22 22:20:00.544 - info: zigbee.0 (14168) Starting Zigbee-Herdsman
          2025-05-22 22:20:26.959 - info: zigbee.0 (14168) Unable to obtain herdsman settings
          2025-05-22 22:20:27.179 - error: zigbee.0 (14168) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
          2025-05-22 22:20:27.181 - error: zigbee.0 (14168) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-05-22 22:20:27.182 - error: zigbee.0 (14168) unhandled promise rejection: undefined
          2025-05-22 22:20:27.183 - error: zigbee.0 (14168) undefined
          2025-05-22 22:20:27.240 - info: zigbee.0 (14168) cleaned everything up...
          2025-05-22 22:20:27.241 - info: zigbee.0 (14168) local config saved
          2025-05-22 22:20:27.243 - info: zigbee.0 (14168) Saved local configuration data
          2025-05-22 22:20:27.244 - info: zigbee.0 (14168) terminating
          2025-05-22 22:20:27.247 - warn: zigbee.0 (14168) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-05-22 22:20:27.256 - error: zigbee.0 (14168) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
          2025-05-22 22:20:27.263 - info: zigbee.0 (14168) terminating
          2025-05-22 22:20:27.749 - info: zigbee.0 (14168) terminating
          2025-05-22 22:20:27.965 - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2025-05-22 22:20:27.966 - error: host.raspberrypi64bitbookworm Caught by controller[1]: Error herdsman start
          2025-05-22 22:20:27.967 - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2025-05-22 22:20:27.967 - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
          2025-05-22 22:20:58.998 - info: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 in version "2.0.5" started with pid 14246
          2025-05-22 22:20:59.706 - info: admin.0 (687) <== Disconnect system.user.admin from ::ffff:192.168.178.102
          2025-05-22 22:21:03.058 - info: zigbee.0 (14246) starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
          2025-05-22 22:21:03.090 - info: zigbee.0 (14246) init localConfig
          2025-05-22 22:21:03.100 - info: zigbee.0 (14246) --> transmitPower : normal
          2025-05-22 22:21:03.116 - info: zigbee.0 (14246) delete old Backup files. keep only last 10
          2025-05-22 22:21:03.122 - info: zigbee.0 (14246) --- creating device debug ---
          2025-05-22 22:21:03.123 - info: zigbee.0 (14246) Starting Adapter npm ...
          2025-05-22 22:21:03.181 - info: zigbee.0 (14246) Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
          2025-05-22 22:21:03.184 - info: zigbee.0 (14246) Starting Zigbee-Herdsman
          2025-05-22 22:21:29.603 - info: zigbee.0 (14246) Unable to obtain herdsman settings
          2025-05-22 22:21:29.785 - error: zigbee.0 (14246) Starting zigbee-herdsman problem : Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
          2025-05-22 22:21:29.788 - error: zigbee.0 (14246) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
          2025-05-22 22:21:29.789 - error: zigbee.0 (14246) unhandled promise rejection: undefined
          2025-05-22 22:21:29.790 - error: zigbee.0 (14246) undefined
          2025-05-22 22:21:29.852 - info: zigbee.0 (14246) cleaned everything up...
          2025-05-22 22:21:29.854 - info: zigbee.0 (14246) local config saved
          2025-05-22 22:21:29.856 - info: zigbee.0 (14246) Saved local configuration data
          2025-05-22 22:21:29.857 - info: zigbee.0 (14246) terminating
          2025-05-22 22:21:29.859 - warn: zigbee.0 (14246) Terminated (UNCAUGHT_EXCEPTION): Without reason
          2025-05-22 22:21:29.867 - error: zigbee.0 (14246) Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin')
          2025-05-22 22:21:29.875 - info: zigbee.0 (14246) terminating
          2025-05-22 22:21:30.363 - info: zigbee.0 (14246) terminating
          2025-05-22 22:21:30.561 - error: host.raspberrypi64bitbookworm Caught by controller[0]: This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). The promise rejected with the reason:
          2025-05-22 22:21:30.562 - error: host.raspberrypi64bitbookworm Caught by controller[0]: Error herdsman start
          2025-05-22 22:21:30.563 - error: host.raspberrypi64bitbookworm instance system.adapter.zigbee.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
          2025-05-22 22:21:30.563 - info: host.raspberrypi64bitbookworm Restart adapter system.adapter.zigbee.0 because enabled
          2025-05-22 22:21:30.563 - warn: host.raspberrypi64bitbookworm Do not restart adapter system.adapter.zigbee.0 because restart loop detected
          Die pan id habe ich geändert: 1437834385923494
          @högi So ich habe jetzt noch folgendes probiert.
          1.) aktuelle Firmware auf den Sonoff coordinator aufgespielt.
          2.) Kpl neu raspberry pi os lite (64bit) Debian Bookworm aufgesetzt und
          Iobroker mit : curl -sSLf https://iobroker.net/install.sh | bash -
          installiert.
          3.) Zigbee Adapter 2.0.5 installiert.
          4.) Coordinator wird unter /dev/serial/by-id angezeigt:
          5.)Pan ID 16 stellig vergeben.
          6.) Zigbee Adapter Version 2.0.4 probiert.
          7.) USB 0,5 m Verlängerung benutzt
          8.)Raspberry USB 2.0 und USB 3.0 benutzt.
          Alles hat nichts geholfen. Instanz bleibt rot.
          Bin mit meinem Latein am Ende.😧
          • Asgothian
            Asgothian Developer @Högi last edited by
            @högi du musst schon systematisch vorgehen. Bei dem geposteten Log ist dieser Eintrag entscheidend:
            Dieses bedeutet das
            • die serielle Schnittstelle geöffnet wurde (erfolgreich)
            • keine Kommunikation zur Firmware entsteht.
            Genau das musst du dir bei den einzelnen Versuchen anschauen.
            Bevor du da aber loslegst, bitte noch einmal verifizieren :
            Bitte noch einmal verifizieren - hast du einen Sonoff Dongle P oder Dongle E (steht auf dem Gerät selber drauf.
            A.
              @asgothian Ich habe den Sonoff Dongle P
                arteck Developer Most Active @Högi last edited by
                @högi sagte in SONOFF ZigBee 3.0 wird nicht in Iobroker Zigbee eingebunden:
                und welche Firmware hast du da aufgespielt.. zeigmal den link
                  Högi @arteck last edited by Högi
                  @arteck
                  Über diesen link:https://github.com/Koenkk/Z-Stack-firmware/blob/master/coordinator/Z-Stack_3.x.0/bin/CC1352P2_CC2652P_launchpad_coordinator_20240710.zip
                  Und nach dieser Anleitung die Firmware aufgespielt:
                  https://haus-automatisierung.com/hardware/sonoff/2022/01/11/sonoff-zigbee-usb-dongle-plus.html
                    Walter Weiss last edited by
                    @Högi
                    das der Zigbee-Stick in Verbindung mit der pivccu3 nicht gefunden wurde, hat ich auch schon.
                    Bei mir hat der CUx-Daemon von der pivccu3 die USB-Schnittstelle für den Zigbee-Stick blockiert.
                    Dies kann man verhindern, wenn man in der Pivccu3-Oberfläche in der Systemsteuerung unter CUx-Daemon das Setup anwählt und dort am Ende folgenden Eintrag ergänzt:
                    TTYASSIGN=ttyACM0:NC
                    und das Setup dann speichert.
                    Danach alles neu starten.
                    Ich hoffe es hilft.
                      Högi @Walter Weiss last edited by
                      @walter-weiss Ich habe das auch probiert und es hat sich nichts geändert.
                      Hatte ja mal testweise System nur mit Iobroker aufgesetzt und der Stick ließ sich
                      auch nicht einbinden.
                      Ich habe den Stick über Amazon gekauft und in den Rezessionen gelesen, das
                      auch defekte Sticks auch ausgeliefert wurden.
                      Bekomme Montag einen neuen Stick.
                      Dann bin ich gespannt.
                        Högi @Högi last edited by
                        @högi
                        So Problem gelöst und danke an Walter Weiss.
                        Das mit dem CUx-Daemon von der pivccu3 hat mich zur Lösung geführt.
                        Aber zuvor, der erste Sonoff coordinator war wirklich kaputt.
                        Nach dem ich den neuen Sonoff Stick in die Zigbee Instanz einbinden wollte war die Enttäuschung groß und ich wollte schon allen hinschmeißen.
                        Als ich aber den CUx-Daemon von der pivccu3 gestoppt habe, siehe da
                        den Zigbee Adapter wurde grün.
                        Danach habe ich TTYASSIGN=ttyACM0:NC im CUx-Daemon eingetragen
                        aber das hat auch nicht funktioniert.
                        Danach TTYASSIGN=ttyttyUSB0 :NC eingetragen und alles läuft reibungslos.
                        Mein Gott schwere Geburt
                        Danke an Alle
                          Walter Weiss @Högi last edited by
                          @högi
                          Entschuldigung, ich hätte noch darauf hinweisen sollen, dass auf unterschiedlichen Systemen die USB-Schnittstellen unterschiedlich benannt werden. ich poste nicht so oft. Aber wieder was dazugelernt. Aber schön dass es geklappt hat.
                          305
