    4. Adapter: ioBroker.unifi
    • Meister Mopper
      Meister Mopper @Guest last edited by
      @neuschwansteini sagte in Adapter: ioBroker.unifi:
      .. aber solange er noch laeuft..
      Manchmal liegt es ja auch nicht an der Lauffähigkeit des Adapters.
      Man weiß es ja: reboot tut gut!
      Ich hatte in den letzten Tagen ständig freezes beim Adapter.
      host.iobroker	2025-03-31 16:55:45.992	warn	Do not restart adapter system.adapter.unifi.0 because restart loop detected
      host.iobroker	2025-03-31 16:55:45.991	error	instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      unifi.0	2025-03-31 16:55:45.389	error	Cannot read properties of undefined (reading 'captureException')
      unifi.0	2025-03-31 16:55:45.389	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:269:22)
      unifi.0	2025-03-31 16:55:45.389	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      unifi.0	2025-03-31 16:55:45.388	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      unifi.0	2025-03-31 16:55:45.385	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:3120:16) at RedirectableRequest.emit (node:events:524:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:210:12) at listOnTimeout (node:internal/timers:581:17) at process.processTimers (node:internal/timers:519:7)
      host.ioroker	202-03-31 16:50:04.883	error	instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      unifi.0	2025-03-31 16:50:04.282	error	Cannot read properties of undefined (reading 'captureException')
      unifi.0	2025-03-31 16:50:04.282	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:269:22)
      unifi.0	2025-03-31 16:50:04.282	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      unifi.0	2025-03-31 16:50:04.281	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      unifi.0	2025-03-31 16:50:04.279	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:3120:16) at RedirectableRequest.emit (node:events:524:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:210:12) at listOnTimeout (node:internal/timers:581:17) at process.processTimers (node:internal/timers:519:7)
      host.iobroker	2025-03-31 16:48:41.304	error	instance system.adapter.unifi.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      unifi.0	2025-03-31 16:48:40.698	error	Cannot read properties of undefined (reading 'captureException')
      unifi.0	2025-03-31 16:48:40.697	error	TypeError: Cannot read properties of undefined (reading 'captureException') at Unifi.handleError (/opt/iobroker/node_modules/iobroker.unifi/main.js:243:53) at Unifi.updateUnifiData (/opt/iobroker/node_modules/iobroker.unifi/main.js:269:22)
      unifi.0	2025-03-31 16:48:40.697	error	unhandled promise rejection: Cannot read properties of undefined (reading 'captureException')
      unifi.0	2025-03-31 16:48:40.696	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      unifi.0	2025-03-31 16:48:40.693	error	[updateUnifiData-login site undefined] error: timeout of 10000ms exceeded, stack: AxiosError: timeout of 10000ms exceeded at RedirectableRequest.handleRequestTimeout (/opt/iobroker/node_modules/node-unifi/node_modules/axios/dist/node/axios.cjs:3120:16) at RedirectableRequest.emit (node:events:524:28) at Timeout.<anonymous> (/opt/iobroker/node_modules/follow-redirects/index.js:210:12) at listOnTimeout (node:internal/timers:581:17) at process.processTimers (node:internal/timers:519:7)
      Einfach mal beherzt die UDM PRO und den Vigor neu gestartet => Voilà, funktioniert wieder.
      Vielleicht hilft es ja auch anderen, die sich beim Haareraufen ertappen 😀 .
        Flopsi last edited by
        Läuft der Adapter noch ? Ich bekommen den leider nicht verbunden .....
        • wendy2702
          wendy2702 @Flopsi last edited by
          @flopsi laut dem letzten Post vor deinem lief er am 31.3.2025 noch.
          Was genau läuft denn bei dir nicht?
            Ich bekomme keine Verbindung hin, liegt aber an den Benutzern und das ich den Unifi Network server auf meine desktop PC installiert habe, zumindest vermute ich das.
            • wendy2702
              wendy2702 last edited by
              kann mir jemand sagen ob man das markierte Objekt steuern können sollte oder ob es nur eine Zustandsanzeige ist:
              • wendy2702
                @flopsi said in Adapter: ioBroker.unifi:
                Also ich habe mir den Adapter gestern mal installiert und nach Anlegen eines neuen User und eintragen der Daten in den Adapter hat dieser sich verbunden.
                  A Former User @wendy2702 last edited by
                  @wendy2702 sagte in Adapter: ioBroker.unifi:
                  nein, enable geht leider nicht.
                  Steuern kannst du port_poe-cycle, port_poe-enabled, schau, so sieht das bei mir aus:
                  wendy2702 1 Reply Last reply Reply Quote 1
                  • wendy2702
                    wendy2702 @Guest last edited by
                    @neuschwansteini OK. Danke!
                      @wendy2702
                      gerne, und der Filter im Adapter sollte gesetzt sein, bei mir legt der Adapter ueber 70000 Objects an.. 😄
                      ok.. sind auch 30 Switche und 450 Devices.. ich filtere daher nur eine Handvoll Clients in der Whitelist.
                      • wendy2702
                        @neuschwansteini Ja,
                        da kommen reichlich Objekte zusammen. Ich habe erstmal versucht nur auf die Devices zu filtern.
                        Wegen der Optik im Darkmode dazu auch ein Issue geöffnet:
                        https://github.com/iobroker-community-adapters/ioBroker.unifi/issues/866
                        wendy2702 created this issue in iobroker-community-adapters/ioBroker.unifi
                        open If iob Admin is set to "dark mode" it's hard to read the filter setting tabs #866
                        • maximal1981
                          maximal1981 last edited by
                          kann es sein, dass man über den Adapter nur WLANs aktivieren/deaktivieren kann, aber keine networks bzw. VLANs?
                            loverz last edited by loverz
                            Kann mir jemand sagen, ob man über den Unify Adapter ein Objekt erhält, das eine erfolgreiche Authentifizierung anzeigt?
                            Brauche Info in ioBroker, wenn jemand die korrekte PIN eingegeben hat, ein korrekter NFC Tag präsentiert wurde, oder sich jemand per Gesichtserkennung erfolgreich authentifiziert hat.
                            Würde dann gerne die Türe per ioBroker (KNX-Adapter) öffnen.
                            Als Türklingel peile ich die neue G6 Pro Entry an:
                            https://store.ui.com/us/en/category/cameras-doorbells/collections/doorbell-entry/products/uvc-g6-pro-entry
                            • JackDaniel
                              JackDaniel last edited by
                              für das was du vorhast benötigst du den unifi adapter überhaupt nicht, wen dann wäre der protect adapter noch eher was für dich
                              der wird aber auch nicht wirklich benötigt, den du kannst das alles über den alarm-manager von protect/unifi und webhooks richtung iobroker lösen
                                loverz @JackDaniel last edited by loverz
                                @jackdaniel klingt gut.
                                Ich richte also in der Dream Machine einen "Alarm" bei erfolgreicher Authentifizierung ein.
                                Dieser sendet dann einen (wichtig: Netzwerk-internen) Webhook an meinen ioBroker, welcher diesen per Simple-API-Adapter auswertet.
                                Hab ich das richtig verstanden?
                                Dann sollte das ja ziemlich zuverlässig funktionieren.
                                • Q
                                  Qlink @loverz last edited by
                                  @loverz
                                  Genau, nutze auch die Webooks mit meiner G4 Pro.
                                  Funktioniert tadellos.
                                  Beste Grüße
                                    loverz @Qlink last edited by
                                    @qlink auch für die erfolgreiche Authentifizierung?
                                    Es ist sehr wichtig, dass ich erkennen kann, ob ein PIN richtig eingegeben wurde, oder die Gesichtserkennung erfolgreich war.
                                    Hiltex 1 Reply Last reply Reply Quote 0
                                    • Hiltex
                                      Hiltex @loverz last edited by
                                      @loverz ja, Protect bietet alle Möglichkeiten
                                        warp735 @Hiltex last edited by
                                        @hiltex
                                        Ich öffne so unser (auch KNX) Garagentor. Funktioniert super
                                          loverz @warp735 last edited by
                                          @warp735 super, danke für die Info.
                                          Frage mich, ob es irgendwelche Vorteile bringen würde, wenn ich die Tür doch per Unify öffne mit dem Doorhub:
                                          https://eu.store.ui.com/eu/en/category/door-access-hub/products/ua-hub-door
                                          • Q
                                            @loverz
                                            Vorteil: keine Abhängigkeit mehr von iobroker...
                                            unifi
                                            171
                                            1010
                                            386982
