    4. Fehler Backitup Grafana
      minkhx @minkhx last edited by
      @minkhx said in Fehler Backitup Grafana:
      @minkhx history enabled auf true setzen?
      Nee, erstmal lieber nicht:)
        @minkhx Hmm, mit Node-Red wirds red, also wieder die Fehlermeldung.
        • simatec
          simatec Developer Most Active @minkhx last edited by
          @minkhx Wenn es Node_red kann keine Grafana Fehlermeldung ausgeben.
          Bitte den Debuglog vo Backup zeigen
            minkhx @simatec last edited by minkhx
            @simatec Jo, das hab ich hier irgendwo gelesen mit dem Ändern auf debug-state. Ich hab aber keine Ahnung, wo die log ist, dummerweise.
            Edit: Das hier?
            backitup.0
            	2025-05-23 22:33:30.863	error	[iobroker/grafana] cannot found Grafana Backup files
            Edit2:
            backitup.0
            	2025-05-23 22:33:32.824	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
            backitup.0
            backitup.0
            	2025-05-23 22:32:53.086	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
            backitup.0
            	2025-05-23 22:32:50.989	error	[iobroker/grafana] cannot found Grafana Backup files
            backitup.0
            	2025-05-23 22:27:49.895	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
            backitup.0
            	2025-05-23 22:27:47.936	error	[iobroker/grafana] cannot found Grafana Backup files
            host.flowbox
            	2025-05-23 22:27:27.556	warn	instance system.adapter.backitup.0 already running with pid 135751
            backitup.0
            	2025-05-23 22:27:05.581	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
            backitup.0
            	2025-05-23 22:27:03.612	error	[iobroker/grafana] cannot found Grafana Backup files
            • simatec
              @minkhx Bitte den kompletten Log vom Backup posten
                @simatec Ja, klar, nicht das Protokoll, sondern den output...
                mit Haken bei ioB, influx und Grafana.
                22:45:23.952
                INFO
                gui
                Backup gestartet ...
                22:45:30.750
                DEBUG
                iobroker
                host.flowbox 193 objects saved
                22:45:30.828
                DEBUG
                iobroker
                host.flowbox 141 states saved
                22:45:30.846
                DEBUG
                iobroker
                host.flowbox "config.json" is valid
                22:45:30.881
                DEBUG
                iobroker
                host.flowbox "objects.jsonl" exists
                host.flowbox "states.jsonl" exists
                22:45:31.767
                DEBUG
                iobroker
                host.flowbox JSONL lines are valid
                22:45:31.777
                DEBUG
                iobroker
                host.flowbox The backup is valid!
                22:45:33.948
                DEBUG
                iobroker
                Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_45_24_backupiobroker.tar.gz
                22:45:33.993
                DEBUG
                iobroker
                This backup can only be restored with js-controller version 7.0 or higher
                22:45:34.986
                DEBUG
                iobroker
                done
                22:45:35.147
                DEBUG
                influxDB
                InfluxDB-Backup started ...
                22:45:35.194
                DEBUG
                influxDB
                Start InfluxDB Backup ...
                22:45:35.205
                DEBUG
                influxDB
                InfluxDB Backup tmp directory created
                22:45:35.222
                DEBUG
                influxDB
                Backup created: /opt/iobroker/backups/influxDB_2025_05_23-22_45_35_backupiobroker.tar.gz
                22:45:35.235
                DEBUG
                influxDB
                InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-22_45_35_backupiobroker" successfully deleted
                22:45:35.271
                DEBUG
                influxDB
                InfluxDB-Backup for is finish
                22:45:35.282
                DEBUG
                influxDB
                done
                22:45:36.486
                DEBUG
                grafana
                Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
                22:45:36.502
                DEBUG
                grafana
                Created dashboard directory
                22:45:36.518
                DEBUG
                grafana
                Created folder directory
                22:45:36.521
                DEBUG
                grafana
                Created dashboards_manually_restore directory
                22:45:36.565
                DEBUG
                grafana
                Created datasource directory
                22:45:36.580
                DEBUG
                grafana
                Grafana is available ... Status: 200
                22:45:37.086
                DEBUG
                grafana
                Saved dashboard-folder mapping
                22:45:37.257
                DEBUG
                grafana
                start Grafana backup compress ...
                22:45:37.275
                DEBUG
                grafana
                Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
                22:45:37.290
                DEBUG
                grafana
                Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
                22:45:37.330
                ERROR
                grafana
                22:45:37.339
                DEBUG
                grafana
                done
                22:45:39.238
                WARN
                clean
                22:45:39.277
                DEBUG
                clean
                done
                22:45:39.402
                DEBUG
                historyHTML
                new history html values created
                22:45:39.495
                DEBUG
                historyHTML
                done
                22:45:39.660
                DEBUG
                historyJSON
                new history json values created
                22:45:39.705
                DEBUG
                historyJSON
                done
                22:45:42.176
                DEBUG
                notification
                done
                22:45:42.333
                INFO
                gui
                Das Backup wurde erfolgreich erstellt!
                EDIT:
                Z109-113 - Wenn der das immer deleted, kanner ja auch nix finden, oder? Vllt. ist das gar nicht so schlimm?
                • simatec
                  simatec Developer Most Active @minkhx last edited by simatec
                  @minkhx Wie sieht denn das Grafana Backup aus? Ist da was drin? Zeige mal den Log, wo es funktioniert hat. In dem Log steht ja nix zur Sicherung von Dashboards
                    @simatec Also das ist der log jetzt nur mit ioB-Haken:
                    22:51:11.771
                    INFO
                    gui
                    22:51:19.916
                    DEBUG
                    iobroker
                    22:51:20.040
                    DEBUG
                    iobroker
                    host.flowbox Validating backup ...
                    22:51:20.057
                    DEBUG
                    iobroker
                    22:51:21.114
                    DEBUG
                    iobroker
                    22:51:21.129
                    DEBUG
                    iobroker
                    22:51:23.131
                    DEBUG
                    iobroker
                    Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_51_14_backupiobroker.tar.gz
                    22:51:23.143
                    DEBUG
                    iobroker
                    22:51:24.233
                    DEBUG
                    iobroker
                    done
                    22:51:27.554
                    WARN
                    clean
                    22:51:27.597
                    DEBUG
                    clean
                    done
                    22:51:27.719
                    DEBUG
                    historyHTML
                    22:51:27.845
                    DEBUG
                    historyHTML
                    done
                    22:51:27.993
                    DEBUG
                    historyJSON
                    22:51:28.035
                    DEBUG
                    historyJSON
                    done
                    22:51:30.520
                    DEBUG
                    notification
                    done
                    22:51:30.666
                    INFO
                    gui
                    Das ist der log mit ioB- und Grafana-Haken:
                    22:52:04.644
                    INFO
                    gui
                    22:52:12.872
                    DEBUG
                    iobroker
                    22:52:12.988
                    DEBUG
                    iobroker
                    host.flowbox 140 states saved
                    22:52:13.003
                    DEBUG
                    iobroker
                    22:52:13.005
                    DEBUG
                    iobroker
                    22:52:14.017
                    DEBUG
                    iobroker
                    22:52:15.067
                    DEBUG
                    iobroker
                    Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_52_07_backupiobroker.tar.gz
                    22:52:15.111
                    DEBUG
                    iobroker
                    22:52:16.118
                    DEBUG
                    iobroker
                    done
                    22:52:17.522
                    DEBUG
                    grafana
                    Start Grafana Backup ...
                    22:52:17.537
                    DEBUG
                    grafana
                    22:52:17.543
                    DEBUG
                    grafana
                    22:52:17.547
                    DEBUG
                    grafana
                    22:52:17.549
                    DEBUG
                    grafana
                    22:52:17.602
                    DEBUG
                    grafana
                    start Grafana request ...
                    22:52:17.663
                    DEBUG
                    grafana
                    22:52:18.021
                    DEBUG
                    grafana
                    22:52:18.202
                    DEBUG
                    grafana
                    22:52:18.217
                    DEBUG
                    grafana
                    22:52:18.231
                    DEBUG
                    grafana
                    22:52:18.249
                    DEBUG
                    grafana
                    done
                    22:52:20.191
                    WARN
                    clean
                    22:52:20.234
                    DEBUG
                    clean
                    done
                    22:52:20.356
                    DEBUG
                    historyHTML
                    22:52:20.450
                    DEBUG
                    historyHTML
                    done
                    22:52:20.638
                    DEBUG
                    historyJSON
                    22:52:20.669
                    DEBUG
                    historyJSON
                    done
                    22:52:23.150
                    DEBUG
                    notification
                    done
                    22:52:23.303
                    INFO
                    gui
                    BTW:
                    Es gibt keine Dashboards, oh, oh, oh, sag nicht der ganze Tanz nur weil ich hier ins Blaue schieße. Ich wollte erstmal testen, ob das funzt.
                    Backup machen, restoren, ein bisschen cash rüberwachsen lassen und dann ioB fröhlich als Modbus-Watcher nutzen.
                    • simatec
                      @minkhx Hat dein Grafana denn keine Inhalte? Keine Datasource und keine Dashboards?
                        @simatec Äh, nope? Grade erst alles eingerichtet. Grafane stünde am Schluss von Allem bzw. habe ich noch nicht mal Sensordaten, welche ich fluxen und dann darstellen könnte.
                        Vllt. kann ich ja einen Systemdienst/Sensor loggen, wenn das erforderlich ist.
                        • simatec
                          @minkhx Richte das erstmal ein und dann setze den Hacken in Backitup. Du sicherst gerade ein System, das nicht vorhanden ist
                          M S 3 Replies Last reply Reply Quote 0
                            @simatec Ok, ich hatte am Anfang Influx als input gesetzt, aber noch keine Dashes angelegt. Ich versuch das mal. Mal sehen, was in influx so Verwertbares enthält.
                              @simatec
                              Hier der log mit ioB, flux, Grafana:
                              23:10:26.402
                              INFO
                              gui
                              23:10:34.540
                              DEBUG
                              iobroker
                              23:10:34.623
                              DEBUG
                              iobroker
                              23:10:34.688
                              DEBUG
                              iobroker
                              23:10:34.692
                              DEBUG
                              iobroker
                              23:10:35.634
                              DEBUG
                              iobroker
                              23:10:37.256
                              DEBUG
                              iobroker
                              Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_10_28_backupiobroker.tar.gz
                              23:10:37.257
                              DEBUG
                              iobroker
                              23:10:38.296
                              DEBUG
                              iobroker
                              done
                              23:10:38.465
                              DEBUG
                              influxDB
                              23:10:38.479
                              DEBUG
                              influxDB
                              23:10:38.575
                              DEBUG
                              influxDB
                              Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker.tar.gz
                              23:10:38.590
                              DEBUG
                              influxDB
                              Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker"
                              23:10:38.604
                              DEBUG
                              influxDB
                              InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker" successfully deleted
                              23:10:38.641
                              DEBUG
                              influxDB
                              23:10:38.643
                              DEBUG
                              influxDB
                              done
                              23:10:39.888
                              DEBUG
                              grafana
                              23:10:39.902
                              DEBUG
                              grafana
                              23:10:39.932
                              DEBUG
                              grafana
                              23:10:39.949
                              DEBUG
                              grafana
                              23:10:40.011
                              DEBUG
                              grafana
                              23:10:40.026
                              DEBUG
                              grafana
                              23:10:40.662
                              DEBUG
                              grafana
                              found Dashboard: tst-dashboard-gauge
                              23:10:40.978
                              DEBUG
                              grafana
                              23:10:41.178
                              DEBUG
                              grafana
                              23:10:46.208
                              DEBUG
                              grafana
                              Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_10_41_backupiobroker.tar.gz
                              23:10:46.223
                              DEBUG
                              grafana
                              23:10:46.265
                              DEBUG
                              grafana
                              done
                              23:10:48.183
                              WARN
                              clean
                              23:10:48.224
                              DEBUG
                              clean
                              done
                              23:10:48.353
                              DEBUG
                              historyHTML
                              23:10:48.452
                              DEBUG
                              historyHTML
                              done
                              23:10:48.640
                              DEBUG
                              historyJSON
                              23:10:48.681
                              DEBUG
                              historyJSON
                              done
                              23:10:51.151
                              DEBUG
                              notification
                              done
                              23:10:51.315
                              INFO
                              gui
                              Zusätzlich noch Node-Red:
                              23:11:50.291
                              INFO
                              gui
                              23:11:58.680
                              DEBUG
                              iobroker
                              23:11:58.775
                              DEBUG
                              iobroker
                              23:11:58.787
                              DEBUG
                              iobroker
                              23:11:59.757
                              DEBUG
                              iobroker
                              23:11:59.767
                              DEBUG
                              iobroker
                              23:12:01.472
                              DEBUG
                              iobroker
                              Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_11_52_backupiobroker.tar.gz
                              23:12:01.474
                              DEBUG
                              iobroker
                              23:12:02.514
                              DEBUG
                              iobroker
                              done
                              23:12:02.681
                              DEBUG
                              influxDB
                              23:12:02.683
                              DEBUG
                              influxDB
                              23:12:02.725
                              DEBUG
                              influxDB
                              23:12:02.845
                              DEBUG
                              influxDB
                              Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker.tar.gz
                              23:12:02.865
                              DEBUG
                              influxDB
                              Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker"
                              23:12:02.869
                              DEBUG
                              influxDB
                              InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker" successfully deleted
                              23:12:02.874
                              DEBUG
                              influxDB
                              23:12:02.912
                              DEBUG
                              influxDB
                              done
                              23:12:04.180
                              DEBUG
                              grafana
                              23:12:04.186
                              DEBUG
                              grafana
                              23:12:04.193
                              DEBUG
                              grafana
                              23:12:04.214
                              DEBUG
                              grafana
                              23:12:04.227
                              DEBUG
                              grafana
                              23:12:04.234
                              DEBUG
                              grafana
                              23:12:04.332
                              DEBUG
                              grafana
                              23:12:04.346
                              DEBUG
                              grafana
                              23:12:05.041
                              DEBUG
                              grafana
                              23:12:05.355
                              DEBUG
                              grafana
                              23:12:05.529
                              DEBUG
                              grafana
                              23:12:10.600
                              DEBUG
                              grafana
                              Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_12_06_backupiobroker.tar.gz
                              23:12:10.605
                              DEBUG
                              grafana
                              23:12:10.622
                              DEBUG
                              grafana
                              23:12:10.661
                              DEBUG
                              grafana
                              done
                              23:12:11.383
                              DEBUG
                              nodered
                              Created nodered tmp directory
                              23:12:11.401
                              DEBUG
                              nodered
                              Node-Red tmp copy finish
                              23:12:11.427
                              DEBUG
                              nodered
                              Backup created: /opt/iobroker/backups/nodered.0_2025_05_23-23_12_12_backupiobroker.tar.gz
                              23:12:11.438
                              DEBUG
                              nodered
                              Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                              23:12:11.441
                              DEBUG
                              nodered
                              node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                              23:12:11.494
                              DEBUG
                              nodered
                              done
                              23:12:12.652
                              WARN
                              clean
                              23:12:12.693
                              DEBUG
                              clean
                              done
                              23:12:12.824
                              DEBUG
                              historyHTML
                              23:12:12.923
                              DEBUG
                              historyHTML
                              done
                              23:12:13.131
                              DEBUG
                              historyJSON
                              23:12:13.171
                              DEBUG
                              historyJSON
                              done
                              23:12:15.641
                              DEBUG
                              notification
                              done
                              23:12:15.791
                              INFO
                              gui
                              Das funzt auch mit DNS statt IP.
                              Oh, srry, mein Fehler. Ich hab da iwie die Fehlermeldung ganz anders interpretiert...
                              Das Dash ist zwar leer bzw. visualisiert "keine Daten", aber das reicht scheinbar erstmal.
                              Backitup ist durchdacht und zweckmäßig, brauche ich:) Ich lass euch was cash rüberwachsen.
                                SabineT @simatec last edited by
                                @simatec es wäre praktisch, wenn es für das "Grafana Backup" auch so einen Knopf "JETZT SICHERN" geben würde, wie bei ioBroker oder Homematic. Gerade wenn man testen will, ob das Backup funktioniert.
                                • simatec
                                  simatec Developer Most Active @SabineT last edited by
                                  @sabinet das ist nicht geplant. Backups wie Grafana, zigbee und Co sind zusätzliche Backup Optionen zum ioBroker Backup
                                    saeft_2003 Most Active @simatec last edited by
                                    @simatec
                                    Hi. Mit der 3.3.5 funktioniert das grafana backup nicht mehr. Es fehlt die Möglichkeit den Benutzernamen und das Passwort einzugeben. Nach einem downgrad auf 3.2.2 funktioniert wieder alles wie gewohnt.
                                    Ist der Fehler bekannt?
                                    • simatec
                                      simatec Developer Most Active @saeft_2003 last edited by
                                      @saeft_2003 Benutzername und Passwort werden nicht mehr benötigt... Der Token übernimmt alles
                                        @simatec
                                        Geht aber nicht bei mir. Langt ein normaler viewer token?
                                        • simatec
                                          @saeft_2003 nein immer ein Admin Token. Steht auch so in der Doku
                                          S 1 Reply Last reply Reply Quote 2
                                            @simatec
                                            Ok danke bis jetzt hatte es mit dem viewer token funktioniert. Ich probiere jetzt den admin…
                                            6351
