    4. Fehler Backitup Grafana
      minkhx @minkhx last edited by
      @minkhx Hmm, mit Node-Red wirds red, also wieder die Fehlermeldung.
      • simatec
        simatec Developer Most Active @minkhx last edited by
        @minkhx Wenn es Node_red kann keine Grafana Fehlermeldung ausgeben.
        Bitte den Debuglog vo Backup zeigen
          minkhx @simatec last edited by minkhx
          @simatec Jo, das hab ich hier irgendwo gelesen mit dem Ändern auf debug-state. Ich hab aber keine Ahnung, wo die log ist, dummerweise.
          Edit: Das hier?
          backitup.0
          	2025-05-23 22:33:30.863	error	[iobroker/grafana] cannot found Grafana Backup files
          Edit2:
          backitup.0
          	2025-05-23 22:33:32.824	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
          backitup.0
          backitup.0
          	2025-05-23 22:32:53.086	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
          backitup.0
          	2025-05-23 22:32:50.989	error	[iobroker/grafana] cannot found Grafana Backup files
          backitup.0
          	2025-05-23 22:27:49.895	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
          backitup.0
          	2025-05-23 22:27:47.936	error	[iobroker/grafana] cannot found Grafana Backup files
          host.flowbox
          	2025-05-23 22:27:27.556	warn	instance system.adapter.backitup.0 already running with pid 135751
          backitup.0
          	2025-05-23 22:27:05.581	warn	[iobroker/clean] No older backup files are deleted, because this backup was started manually
          backitup.0
          	2025-05-23 22:27:03.612	error	[iobroker/grafana] cannot found Grafana Backup files
          • simatec
            @minkhx Bitte den kompletten Log vom Backup posten
              @simatec Ja, klar, nicht das Protokoll, sondern den output...
              mit Haken bei ioB, influx und Grafana.
              22:45:23.952
              INFO
              gui
              Backup gestartet ...
              22:45:30.750
              DEBUG
              iobroker
              host.flowbox 193 objects saved
              22:45:30.828
              DEBUG
              iobroker
              host.flowbox 141 states saved
              22:45:30.846
              DEBUG
              iobroker
              host.flowbox "config.json" is valid
              22:45:30.881
              DEBUG
              iobroker
              host.flowbox "objects.jsonl" exists
              host.flowbox "states.jsonl" exists
              22:45:31.767
              DEBUG
              iobroker
              host.flowbox JSONL lines are valid
              22:45:31.777
              DEBUG
              iobroker
              host.flowbox The backup is valid!
              22:45:33.948
              DEBUG
              iobroker
              Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_45_24_backupiobroker.tar.gz
              22:45:33.993
              DEBUG
              iobroker
              This backup can only be restored with js-controller version 7.0 or higher
              22:45:34.986
              DEBUG
              iobroker
              done
              22:45:35.147
              DEBUG
              influxDB
              InfluxDB-Backup started ...
              22:45:35.194
              DEBUG
              influxDB
              Start InfluxDB Backup ...
              22:45:35.205
              DEBUG
              influxDB
              InfluxDB Backup tmp directory created
              22:45:35.222
              DEBUG
              influxDB
              Backup created: /opt/iobroker/backups/influxDB_2025_05_23-22_45_35_backupiobroker.tar.gz
              22:45:35.235
              DEBUG
              influxDB
              InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-22_45_35_backupiobroker" successfully deleted
              22:45:35.271
              DEBUG
              influxDB
              InfluxDB-Backup for is finish
              22:45:35.282
              DEBUG
              influxDB
              done
              22:45:36.486
              DEBUG
              grafana
              Created grafana_tmp directory: "/opt/iobroker/backups/grafana_tmp"
              22:45:36.502
              DEBUG
              grafana
              Created dashboard directory
              22:45:36.518
              DEBUG
              grafana
              Created folder directory
              22:45:36.521
              DEBUG
              grafana
              Created dashboards_manually_restore directory
              22:45:36.565
              DEBUG
              grafana
              Created datasource directory
              22:45:36.580
              DEBUG
              grafana
              Grafana is available ... Status: 200
              22:45:37.086
              DEBUG
              grafana
              Saved dashboard-folder mapping
              22:45:37.257
              DEBUG
              grafana
              start Grafana backup compress ...
              22:45:37.275
              DEBUG
              grafana
              Try deleting the Grafana tmp directory: "/opt/iobroker/backups/grafana_tmp"
              22:45:37.290
              DEBUG
              grafana
              Grafana tmp directory "/opt/iobroker/backups/grafana_tmp" successfully deleted
              22:45:37.330
              ERROR
              grafana
              22:45:37.339
              DEBUG
              grafana
              done
              22:45:39.238
              WARN
              clean
              22:45:39.277
              DEBUG
              clean
              done
              22:45:39.402
              DEBUG
              historyHTML
              new history html values created
              22:45:39.495
              DEBUG
              historyHTML
              done
              22:45:39.660
              DEBUG
              historyJSON
              new history json values created
              22:45:39.705
              DEBUG
              historyJSON
              done
              22:45:42.176
              DEBUG
              notification
              done
              22:45:42.333
              INFO
              gui
              Das Backup wurde erfolgreich erstellt!
              EDIT:
              Z109-113 - Wenn der das immer deleted, kanner ja auch nix finden, oder? Vllt. ist das gar nicht so schlimm?
              • simatec
                simatec Developer Most Active @minkhx last edited by simatec
                @minkhx Wie sieht denn das Grafana Backup aus? Ist da was drin? Zeige mal den Log, wo es funktioniert hat. In dem Log steht ja nix zur Sicherung von Dashboards
                  @simatec Also das ist der log jetzt nur mit ioB-Haken:
                  22:51:11.771
                  INFO
                  gui
                  22:51:19.916
                  DEBUG
                  iobroker
                  22:51:20.040
                  DEBUG
                  iobroker
                  host.flowbox Validating backup ...
                  22:51:20.057
                  DEBUG
                  iobroker
                  22:51:21.114
                  DEBUG
                  iobroker
                  22:51:21.129
                  DEBUG
                  iobroker
                  22:51:23.131
                  DEBUG
                  iobroker
                  Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_51_14_backupiobroker.tar.gz
                  22:51:23.143
                  DEBUG
                  iobroker
                  22:51:24.233
                  DEBUG
                  iobroker
                  done
                  22:51:27.554
                  WARN
                  clean
                  22:51:27.597
                  DEBUG
                  clean
                  done
                  22:51:27.719
                  DEBUG
                  historyHTML
                  22:51:27.845
                  DEBUG
                  historyHTML
                  done
                  22:51:27.993
                  DEBUG
                  historyJSON
                  22:51:28.035
                  DEBUG
                  historyJSON
                  done
                  22:51:30.520
                  DEBUG
                  notification
                  done
                  22:51:30.666
                  INFO
                  gui
                  Das ist der log mit ioB- und Grafana-Haken:
                  22:52:04.644
                  INFO
                  gui
                  22:52:12.872
                  DEBUG
                  iobroker
                  22:52:12.988
                  DEBUG
                  iobroker
                  host.flowbox 140 states saved
                  22:52:13.003
                  DEBUG
                  iobroker
                  22:52:13.005
                  DEBUG
                  iobroker
                  22:52:14.017
                  DEBUG
                  iobroker
                  22:52:15.067
                  DEBUG
                  iobroker
                  Backup created: /opt/iobroker/backups/iobroker_2025_05_23-22_52_07_backupiobroker.tar.gz
                  22:52:15.111
                  DEBUG
                  iobroker
                  22:52:16.118
                  DEBUG
                  iobroker
                  done
                  22:52:17.522
                  DEBUG
                  grafana
                  Start Grafana Backup ...
                  22:52:17.537
                  DEBUG
                  grafana
                  22:52:17.543
                  DEBUG
                  grafana
                  22:52:17.547
                  DEBUG
                  grafana
                  22:52:17.549
                  DEBUG
                  grafana
                  22:52:17.602
                  DEBUG
                  grafana
                  start Grafana request ...
                  22:52:17.663
                  DEBUG
                  grafana
                  22:52:18.021
                  DEBUG
                  grafana
                  22:52:18.202
                  DEBUG
                  grafana
                  22:52:18.217
                  DEBUG
                  grafana
                  22:52:18.231
                  DEBUG
                  grafana
                  22:52:18.249
                  DEBUG
                  grafana
                  done
                  22:52:20.191
                  WARN
                  clean
                  22:52:20.234
                  DEBUG
                  clean
                  done
                  22:52:20.356
                  DEBUG
                  historyHTML
                  22:52:20.450
                  DEBUG
                  historyHTML
                  done
                  22:52:20.638
                  DEBUG
                  historyJSON
                  22:52:20.669
                  DEBUG
                  historyJSON
                  done
                  22:52:23.150
                  DEBUG
                  notification
                  done
                  22:52:23.303
                  INFO
                  gui
                  BTW:
                  Es gibt keine Dashboards, oh, oh, oh, sag nicht der ganze Tanz nur weil ich hier ins Blaue schieße. Ich wollte erstmal testen, ob das funzt.
                  Backup machen, restoren, ein bisschen cash rüberwachsen lassen und dann ioB fröhlich als Modbus-Watcher nutzen.
                  • simatec
                    @minkhx Hat dein Grafana denn keine Inhalte? Keine Datasource und keine Dashboards?
                      @simatec Äh, nope? Grade erst alles eingerichtet. Grafane stünde am Schluss von Allem bzw. habe ich noch nicht mal Sensordaten, welche ich fluxen und dann darstellen könnte.
                      Vllt. kann ich ja einen Systemdienst/Sensor loggen, wenn das erforderlich ist.
                      • simatec
                        @minkhx Richte das erstmal ein und dann setze den Hacken in Backitup. Du sicherst gerade ein System, das nicht vorhanden ist
                        M S 3 Replies Last reply Reply Quote 0
                          @simatec Ok, ich hatte am Anfang Influx als input gesetzt, aber noch keine Dashes angelegt. Ich versuch das mal. Mal sehen, was in influx so Verwertbares enthält.
                            @simatec
                            Hier der log mit ioB, flux, Grafana:
                            23:10:26.402
                            INFO
                            gui
                            23:10:34.540
                            DEBUG
                            iobroker
                            23:10:34.623
                            DEBUG
                            iobroker
                            23:10:34.688
                            DEBUG
                            iobroker
                            23:10:34.692
                            DEBUG
                            iobroker
                            23:10:35.634
                            DEBUG
                            iobroker
                            23:10:37.256
                            DEBUG
                            iobroker
                            Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_10_28_backupiobroker.tar.gz
                            23:10:37.257
                            DEBUG
                            iobroker
                            23:10:38.296
                            DEBUG
                            iobroker
                            done
                            23:10:38.465
                            DEBUG
                            influxDB
                            23:10:38.479
                            DEBUG
                            influxDB
                            23:10:38.575
                            DEBUG
                            influxDB
                            Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker.tar.gz
                            23:10:38.590
                            DEBUG
                            influxDB
                            Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker"
                            23:10:38.604
                            DEBUG
                            influxDB
                            InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_10_39_backupiobroker" successfully deleted
                            23:10:38.641
                            DEBUG
                            influxDB
                            23:10:38.643
                            DEBUG
                            influxDB
                            done
                            23:10:39.888
                            DEBUG
                            grafana
                            23:10:39.902
                            DEBUG
                            grafana
                            23:10:39.932
                            DEBUG
                            grafana
                            23:10:39.949
                            DEBUG
                            grafana
                            23:10:40.011
                            DEBUG
                            grafana
                            23:10:40.026
                            DEBUG
                            grafana
                            23:10:40.662
                            DEBUG
                            grafana
                            found Dashboard: tst-dashboard-gauge
                            23:10:40.978
                            DEBUG
                            grafana
                            23:10:41.178
                            DEBUG
                            grafana
                            23:10:46.208
                            DEBUG
                            grafana
                            Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_10_41_backupiobroker.tar.gz
                            23:10:46.223
                            DEBUG
                            grafana
                            23:10:46.265
                            DEBUG
                            grafana
                            done
                            23:10:48.183
                            WARN
                            clean
                            23:10:48.224
                            DEBUG
                            clean
                            done
                            23:10:48.353
                            DEBUG
                            historyHTML
                            23:10:48.452
                            DEBUG
                            historyHTML
                            done
                            23:10:48.640
                            DEBUG
                            historyJSON
                            23:10:48.681
                            DEBUG
                            historyJSON
                            done
                            23:10:51.151
                            DEBUG
                            notification
                            done
                            23:10:51.315
                            INFO
                            gui
                            Zusätzlich noch Node-Red:
                            23:11:50.291
                            INFO
                            gui
                            23:11:58.680
                            DEBUG
                            iobroker
                            23:11:58.775
                            DEBUG
                            iobroker
                            23:11:58.787
                            DEBUG
                            iobroker
                            23:11:59.757
                            DEBUG
                            iobroker
                            23:11:59.767
                            DEBUG
                            iobroker
                            23:12:01.472
                            DEBUG
                            iobroker
                            Backup created: /opt/iobroker/backups/iobroker_2025_05_23-23_11_52_backupiobroker.tar.gz
                            23:12:01.474
                            DEBUG
                            iobroker
                            23:12:02.514
                            DEBUG
                            iobroker
                            done
                            23:12:02.681
                            DEBUG
                            influxDB
                            23:12:02.683
                            DEBUG
                            influxDB
                            23:12:02.725
                            DEBUG
                            influxDB
                            23:12:02.845
                            DEBUG
                            influxDB
                            Backup created: /opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker.tar.gz
                            23:12:02.865
                            DEBUG
                            influxDB
                            Try deleting the InfluxDB tmp directory: "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker"
                            23:12:02.869
                            DEBUG
                            influxDB
                            InfluxDB tmp directory "/opt/iobroker/backups/influxDB_2025_05_23-23_12_03_backupiobroker" successfully deleted
                            23:12:02.874
                            DEBUG
                            influxDB
                            23:12:02.912
                            DEBUG
                            influxDB
                            done
                            23:12:04.180
                            DEBUG
                            grafana
                            23:12:04.186
                            DEBUG
                            grafana
                            23:12:04.193
                            DEBUG
                            grafana
                            23:12:04.214
                            DEBUG
                            grafana
                            23:12:04.227
                            DEBUG
                            grafana
                            23:12:04.234
                            DEBUG
                            grafana
                            23:12:04.332
                            DEBUG
                            grafana
                            23:12:04.346
                            DEBUG
                            grafana
                            23:12:05.041
                            DEBUG
                            grafana
                            23:12:05.355
                            DEBUG
                            grafana
                            23:12:05.529
                            DEBUG
                            grafana
                            23:12:10.600
                            DEBUG
                            grafana
                            Backup created: /opt/iobroker/backups/grafana_2025_05_23-23_12_06_backupiobroker.tar.gz
                            23:12:10.605
                            DEBUG
                            grafana
                            23:12:10.622
                            DEBUG
                            grafana
                            23:12:10.661
                            DEBUG
                            grafana
                            done
                            23:12:11.383
                            DEBUG
                            nodered
                            Created nodered tmp directory
                            23:12:11.401
                            DEBUG
                            nodered
                            Node-Red tmp copy finish
                            23:12:11.427
                            DEBUG
                            nodered
                            Backup created: /opt/iobroker/backups/nodered.0_2025_05_23-23_12_12_backupiobroker.tar.gz
                            23:12:11.438
                            DEBUG
                            nodered
                            Try deleting the old node-red tmp directory: "/opt/iobroker/backups/noderedtmp0"
                            23:12:11.441
                            DEBUG
                            nodered
                            node-red tmp directory "/opt/iobroker/backups/noderedtmp0" successfully deleted
                            23:12:11.494
                            DEBUG
                            nodered
                            done
                            23:12:12.652
                            WARN
                            clean
                            23:12:12.693
                            DEBUG
                            clean
                            done
                            23:12:12.824
                            DEBUG
                            historyHTML
                            23:12:12.923
                            DEBUG
                            historyHTML
                            done
                            23:12:13.131
                            DEBUG
                            historyJSON
                            23:12:13.171
                            DEBUG
                            historyJSON
                            done
                            23:12:15.641
                            DEBUG
                            notification
                            done
                            23:12:15.791
                            INFO
                            gui
                            Das funzt auch mit DNS statt IP.
                            Oh, srry, mein Fehler. Ich hab da iwie die Fehlermeldung ganz anders interpretiert...
                            Das Dash ist zwar leer bzw. visualisiert "keine Daten", aber das reicht scheinbar erstmal.
                            Backitup ist durchdacht und zweckmäßig, brauche ich:) Ich lass euch was cash rüberwachsen.
                              SabineT @simatec last edited by
                              @simatec es wäre praktisch, wenn es für das "Grafana Backup" auch so einen Knopf "JETZT SICHERN" geben würde, wie bei ioBroker oder Homematic. Gerade wenn man testen will, ob das Backup funktioniert.
                              • simatec
                                simatec Developer Most Active @SabineT last edited by
                                @sabinet das ist nicht geplant. Backups wie Grafana, zigbee und Co sind zusätzliche Backup Optionen zum ioBroker Backup
                                  saeft_2003 Most Active @simatec last edited by
                                  @simatec
                                  Hi. Mit der 3.3.5 funktioniert das grafana backup nicht mehr. Es fehlt die Möglichkeit den Benutzernamen und das Passwort einzugeben. Nach einem downgrad auf 3.2.2 funktioniert wieder alles wie gewohnt.
                                  Ist der Fehler bekannt?
                                  • simatec
                                    simatec Developer Most Active @saeft_2003 last edited by
                                    @saeft_2003 Benutzername und Passwort werden nicht mehr benötigt... Der Token übernimmt alles
                                      @simatec
                                      Geht aber nicht bei mir. Langt ein normaler viewer token?
                                      • simatec
                                        @saeft_2003 nein immer ein Admin Token. Steht auch so in der Doku
                                        S 1 Reply Last reply Reply Quote 2
                                          @simatec
                                          Ok danke bis jetzt hatte es mit dem viewer token funktioniert. Ich probiere jetzt den admin…
                                          6333
