    3. Off Topic
    4. Microcontroller
    5. ESP32-C6 Zigbee Support external converter Bitte um Hilfe
    • Jens G.
      Jens G. @Homoran last edited by
      so direkt nach Start des Adapters
      zigbee.0
      2025-05-20 19:49:07.335	warn	DeviceConfigure:0xa4c138f0cf2205e4 TS011F Failed to configure. --> ZCL command 0xa4c138f0cf2205e4/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
      admin.0
      2025-05-20 19:49:06.258	info	<== Disconnect system.user.admin from ::ffff:192.168.188.21
      admin.0
      maxcul.0
      2025-05-20 19:49:01.027	info	checkTimeIntervalFired
      zigbee.0
      2025-05-20 19:49:00.702	info	Timeout trying to configure 0xa4c138cb153fc055 ZG-227Z (starting CoM).
      zigbee.0
      2025-05-20 19:48:47.623	info	Handled all devices Queued for configuration.
      zigbee.0
      2025-05-20 19:48:42.624	info	Configuring 0xa4c138f0cf2205e4 TS011F_plug_1
      zigbee.0
      2025-05-20 19:48:42.623	info	DeviceConfigureQueue configuring 0xa4c138f0cf2205e4 TS011F
      zigbee.0
      2025-05-20 19:48:37.626	info	Configuring 0xa4c138cb153fc055 ZG-227Z
      zigbee.0
      2025-05-20 19:48:37.623	info	DeviceConfigureQueue configuring 0xa4c138cb153fc055 TS0601
      zigbee.0
      2025-05-20 19:48:36.520	info	Failed to ping 0xa4c138f0cf2205e4 TS011F
      zigbee.0
      2025-05-20 19:48:33.556	info	Failed to ping 0x7cb03eaa0a00c5df CLA60 TW OSRAM
      zigbee.0
      2025-05-20 19:48:33.363	warn	Device 0xf0f5bdfffe1027bc "ZBColorLightBulb" not found.
      zigbee.0
      2025-05-20 19:48:32.905	info	debug devices set to []
      zigbee.0
      2025-05-20 19:48:32.631	info	DeviceConfigure 0xa4c138f0cf2205e4 TS011F_plug_1 needed - Device added to Configuration Queue
      zigbee.0
      2025-05-20 19:48:32.620	info	DeviceConfigure 0xa4c138cb153fc055 ZG-227Z needed - Device added to Configuration Queue
      zigbee.0
      2025-05-20 19:48:32.590	info	Zigbee started
      zigbee.0
      2025-05-20 19:48:32.588	info	Currently 12 devices are joined:
      zigbee.0
      2025-05-20 19:48:32.587	info	0xf0f5bdfffe1027bc (addr 46627): Unsupported (model ZBColorLightBulb)(EndDevice)
      zigbee.0
      2025-05-20 19:48:32.585	info	0x0cae5ffffe82e3d6 (addr 32534): TS0207_repeater - Tuya Repeater (Router)
      zigbee.0
      2025-05-20 19:48:32.580	info	0xa4c138c634121179 (addr 19196): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      zigbee.0
      2025-05-20 19:48:32.574	info	0xa4c138f0cf2205e4 (addr 60744): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      zigbee.0
      2025-05-20 19:48:32.567	info	0xa4c13882aaaf7096 (addr 7741): TS0207_water_leak_detector_1 - Tuya Zigbee water flood sensor + 1m probe cable (EndDevice)
      zigbee.0
      2025-05-20 19:48:32.559	info	0xa4c138cb153fc055 (addr 19127): ZG-227Z - Tuya Temperature and humidity sensor (EndDevice)
      zigbee.0
      2025-05-20 19:48:32.411	info	0xe406bffffe38c827 (addr 603): ZBMINIR2 - SONOFF Zigbee smart switch (Router)
      zigbee.0
      2025-05-20 19:48:32.385	info	0xa4c1384e05b39d11 (addr 57525): TS011F_plug_1 - Tuya Smart plug (with power monitoring) (Router)
      zigbee.0
      2025-05-20 19:48:32.145	info	0x7cb03eaa0a00c5df (addr 56980): AC03642 - OSRAM SMART+ CLASSIC A 60 TW (Router)
      zigbee.0
      2025-05-20 19:48:32.128	info	0x00158d00051e85e8 (addr 16633): WSDCGQ11LM - Aqara Temperature and humidity sensor (EndDevice)
      zigbee.0
      2025-05-20 19:48:32.123	info	0x00158d0002732ad3 (addr 25672): RTCGQ11LM - Aqara Motion sensor (EndDevice)
      zigbee.0
      2025-05-20 19:48:32.113	info	0x00158d0002f7bc51 (addr 27407): WXKG01LM - Xiaomi Mi wireless switch (EndDevice)
      zigbee.0
      2025-05-20 19:48:31.985	info	Unable to disable LED, unsupported function.
      zigbee.0
      2025-05-20 19:48:31.983	info	Zigbee-Herdsman started successfully with Coordinator firmware version: zStack3x0 : 20230507 (2-1.2.7.1)
      zigbee.0
      2025-05-20 19:48:31.465	info	Starting Zigbee-Herdsman
      zigbee.0
      2025-05-20 19:48:31.461	info	Installed Version: iobroker.zigbee@3.0.1 (Converters 23.13.0 Herdsman 3.3.2)
      zigbee.0
      2025-05-20 19:48:31.440	info	Starting Adapter npm ...
      zigbee.0
      2025-05-20 19:48:31.433	info	--> transmitPower : high+
      zigbee.0
      2025-05-20 19:48:27.454	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"SHK","serialNumber":"868","pnpId":"usb-SHK_NANO_CUL_868-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB1","manufacturer":"ITead","serialNumber":"78c227e46ed8ed11ad85736162c613ac","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0","vendorId":"10c4","productId":"ea60"}]
      admin.0
      2025-05-20 19:48:27.192	info	==> Connected system.user.admin from ::ffff:192.168.188.21
      admin.0
      2025-05-20 19:47:39.912	info	<== Disconnect system.user.admin from ::ffff:192.168.188.21
      zigbee.0
      2025-05-20 19:47:37.963	info	List of port: [{"path":"/dev/ttyUSB0","manufacturer":"SHK","serialNumber":"868","pnpId":"usb-SHK_NANO_CUL_868-if00-port0","vendorId":"0403","productId":"6001"},{"path":"/dev/ttyUSB1","manufacturer":"ITead","serialNumber":"78c227e46ed8ed11ad85736162c613ac","pnpId":"usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_78c227e46ed8ed11ad85736162c613ac-if00-port0","vendorId":"10c4","productId":"ea60"}]
      • Asgothian
        Asgothian Developer @Jens G. last edited by Asgothian
        @jens-g Nein, ist es nicht. Das fehlt was.
        Beispiel wie es aussehen müsste:
        2025-05-20 19:50:06.463 - info: host.raspberrypi instance system.adapter.zigbee.0 in version "3.0.0" (non-npm: asgothian/ioBroker.zigbee#3.0.x_RC1) started with pid 3671847
        2025-05-20 19:50:07.362 - info: zigbee.0 (3671847) starting. Version 3.0.0 (non-npm: asgothian/ioBroker.zigbee#3.0.x_RC1) in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.1, js-controller: 7.0.6
        2025-05-20 19:50:07.378 - info: zigbee.0 (3671847) Adapter ready - starting subsystems. Adapter is running in info mode.
        2025-05-20 19:50:07.380 - warn: zigbee.0 (3671847) trying to add "m = require(../zigbee-herdsman-converters/dist/lib/modernExtend)" to sandbox
        2025-05-20 19:50:07.381 - warn: zigbee.0 (3671847) trying to add "type {DefinitionWithExtend} = require(../zigbee-herdsman-converters/dist/lib/types)" to sandbox
        2025-05-20 19:50:07.382 - error: zigbee.0 (3671847) converter does not export any converter array, please add 'module.exports' statement to /opt/iobroker/iobroker-data/zigbee_0/shelly.js
        2025-05-20 19:50:07.382 - info: zigbee.0 (3671847) Ignoring converter from module: /opt/iobroker/iobroker-data/zigbee_0/shelly.js - see warn messages for reason
        2025-05-20 19:50:07.383 - warn: zigbee.0 (3671847) Trying to run sandbox for /opt/iobroker/iobroker-data/zigbee_0/esp.js
        2025-05-20 19:50:07.386 - info: zigbee.0 (3671847) Model ZBColorLightBulb defined in external converter /opt/iobroker/iobroker-data/zigbee_0/esp.js
        2025-05-20 19:50:07.387 - info: zigbee.0 (3671847) added external converter using addExternalDefinition (0 ms)
        2025-05-20 19:50:07.387 - info: zigbee.0 (3671847) init localConfig
        2025-05-20 19:50:07.391 - info: zigbee.0 (3671847) --> transmitPower : normal
        2025-05-20 19:50:07.415 - info: zigbee.0 (3671847) delete old Backup files. keep only last 10
        2025-05-20 19:50:07.416 - info: zigbee.0 (3671847) --- creating device debug ---
        2025-05-20 19:50:07.417 - info: zigbee.0 (3671847) Starting Adapter npm ...
        2025-05-20 19:50:07.427 - info: zigbee.0 (3671847) Installed Version: asgothian/ioBroker.zigbee#3.0.x_RC1 (Converters 23.13.0 Herdsman 3.3.2)
        2025-05-20 19:50:07.428 - info: zigbee.0 (3671847) Starting Zigbee-Herdsman
        2025-05-20 19:50:07.785 - info: zigbee.0 (3671847) Zigbee-Herdsman started successfully with Coordinator firmware version: zStack3x0 : 20210708 (2-1.2.7.1)
        2025-05-20 19:50:07.785 - info: zigbee.0 (3671847) Unable to disable LED, unsupported function.
        Seis Drum:
        Bitte den externen Konverter anpassen:
        modernExtend = require("zigbee-herdsman-converters/lib/modernExtend");
        module.exports = [
            zigbeeModel: ['ZBColorLightBulb'], // Anpassen an das tats  chliche Modell
            model: 'ZBColorLightBulb',
            vendor: 'Espressif',
            description: 'ESP32-C6 RGB LED',
            extend: [modernExtend.light({colorTemp: {range: [150, 500]}, color: true})],}
        asgothian created this issue in asgothian/ioBroker.zigbee
        closed Follow main #3
        Jens G. 1 Reply Last reply Reply Quote 0
        • Jens G.
          Jens G. @Asgothian last edited by Jens G.
          @asgothian
          Leuchtet trotzdem nicht, wird zwar alles exposed, aber nichts poassiert. Geht wieder zurück das scheint ja entweder Defekt oder nicht kompatibel zu sein.
          Schnauze voll, trotzdem ganz großes Danke für eure Hilfe, klappt leider nicht!!!
          Aktuelle fehlermeldungen von Zigbee:
          zigbee.0
          2025-05-20 20:06:32.782	error	Send command to 0xf0f5bdfffe1027bc failed with no error code (undefined)
          zigbee.0
          2025-05-20 20:05:06.779	warn	Unable to copy icon from device definition, looked at img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/ZBColorLightBulb.png and /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png
          zigbee.0
          2025-05-20 20:05:06.775	warn	Unable to copy icon from device definition, looked at img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/ZBColorLightBulb.png and /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png
          zigbee.0
          2025-05-20 20:05:06.415	warn	Unable to copy icon from device definition, looked at img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/ZBColorLightBulb.png and /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png
          zigbee.0
          2025-05-20 20:05:06.410	warn	Unable to copy icon from device definition, looked at img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png, /opt/iobroker/iobroker-data/zigbee_0/ZBColorLightBulb.png and /opt/iobroker/iobroker-data/zigbee_0/img/ZBColorLightBulb.png```
          • Asgothian
            @jens-g sagte in ESP32-C6 Zigbee Support external converter Bitte um Hilfe:
            Das kann sein, muss aber nicht
            Die Tatsache das es nicht geht liegt daran das die Firmware sich scheinbar nicht an die 'normalen' Regeln des Zigbee Protokolls hält. (Link)
            Kann man das hin bekommen ? Sicher
            Kann man das in den ioBroker integrieren ? Sicher
            Geht das ohne das Du dich mit den Details auseinander setzt ? Sicher nicht
            Was du noch tun kannst:
            • Konfiguration öffnen
            • Entwickler-Tab öffnen
            • ausprobieren über welche der in deinem Screenshot aufgelisteten Clustern du welche der Attribute des Gerätes auslesen / ansteuern kannst.
            Da kann ich Dich aber nicht 'durch führen' - da musst du dich selber einlesen. Die unterstützten Cluster werden vom Gerät gemeldet. Die Definition der Cluster ist in dem oben verlinkten Dokument nachlesbar. Auch welche Attribute es gibt und was sie tun sollen.
            A.
            Nachtrag: Eingene Firmware Schreiben ist nicht trivial, und erfordert einiges an Spezialwissen, sowie gesonderte Hardware mit der du verifizieren kannst was denn wirklich passiert.
            Jens G. 1 Reply Last reply Reply Quote 1
            • Jens G.
              @asgothian
              Aha, warum muss man eigentlich nach jedem Neustart des Zigbee Adapters die Hardware bzw. den Stick manuell starten? das war bei 2.0.5 noch nicht so
              • Asgothian
                @jens-g muss man nicht. Doku (oder auch das Readme) lesen - da gibts einen Haken in der Konfiguration 🙂
                A.
                • Jens G.
                  @asgothian
                  Danke, habe ich doch glatt übersehen.
                  Übrigens meine beiden ESP32 C6 Module heißen nanoESP32-C6 V1 vllt. deswegen inkompatibel!.
                  MartinP A 2 Replies Last reply Reply Quote 0
                  • MartinP
                    MartinP @Jens G. last edited by
                    @asgothian
                    Jetzt haben die Geheimdienste einen Fingerabdruck von Dir ;🕵️‍♂️ 🕵️‍♂️ 🕵️‍♂️
                    • Jens G.
                      Jens G. @MartinP last edited by
                      @martinp Laber doch kein Müll, der ist eh unbrauchbar 😂
                        AlexHaxe @Jens G. last edited by
                        @jens-g said in ESP32-C6 Zigbee Support external converter Bitte um Hilfe:
                        @asgothian
                        Halte ich für ein Gerücht, denn bei mir funktioniert der "nanoESP32-C6 V1.0" wunderbar als Zigbee-Gerät. Allerdings als Drucksensor mit einem druckempfindlichen Widerstand (FSR) in einer Spannungsteiler-Schaltung.
                        Als "Firmware" dient ein minimal modifiziertes "Pressure-Flow" Beispiel-Programm, welches der ESP Bibliothek beiliegt. Die Modifikation bestand im Entfernen des "Flow"-Teils aus dem Code.
                        • Jens G.
                          Jens G. @AlexHaxe last edited by Jens G.
                          @alexhaxe Funktioniert bei mir trotzdem nicht, wird immer als ZBLightBulb angezeigt, egal mit welchem Beispiel scheint wohl defekt zu sein. Immer das gleiche sollte als Zigbee temp Sensor angezeigt werden, aber wieder nur ZBLightBulb, damit eindeutig defekt
                            Oder das Gerät wurde nicht vollständig aus Koordinator / iobroker entfernt und wird anhand seiner ID dem alten Namen zugeordnet, und zeigt deshalb nichts anderes an. Ich meine mich zu erinnern, dass das ein bisschen hartnäckig war, weiß aber nicht mehr genau, wie ich es gelöst habe.
                            • Asgothian
                              Asgothian Developer last edited by
                              @jens-g das was der Adapter meldet hängt davon ab welche ID die Firmware lieft. Das kann man im zigbee adapter prüfen wenn man auf das (i) auf der kachelrückseite clickt. Da steht dann auch welche Cluster die Firmware unterstützt.
                              A.
                              • Jens G.
                                @asgothian Das mag sein, aber trotz geänderter ID bzw. modelname im Sketch immer das gleiche. Habe ich definitiv komplett gelöscht auch keine Reste mehr in der shepard.db vorhanden. Wie kann ich denn nun mit diesen Cluistern einen externen converter bauen damit es als temp sensor erkannt wird und nicht ständig ZBLightBulb heißt?.
                                Habe dieses Beispiel verwendet:
                                // Copyright 2024 Espressif Systems (Shanghai) PTE LTD
                                // Licensed under the Apache License, Version 2.0 (the "License");
                                // you may not use this file except in compliance with the License.
                                // You may obtain a copy of the License at
                                //     http://www.apache.org/licenses/LICENSE-2.0
                                // Unless required by applicable law or agreed to in writing, software
                                // distributed under the License is distributed on an "AS IS" BASIS,
                                // WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
                                // See the License for the specific language governing permissions and
                                // limitations under the License.
                                 * @brief This example demonstrates Zigbee temperature sensor.
                                 * The example demonstrates how to use Zigbee library to create a end device temperature sensor.
                                 * The temperature sensor is a Zigbee end device, which is controlled by a Zigbee coordinator.
                                 * Proper Zigbee mode must be selected in Tools->Zigbee mode
                                 * and also the correct partition scheme must be selected in Tools->Partition Scheme.
                                 * Please check the README.md for instructions and more detailed description.
                                 * Created by Jan Procházka (https://github.com/P-R-O-C-H-Y/)
                                #ifndef ZIGBEE_MODE_ED
                                #error "Zigbee end device mode is not selected in Tools->Zigbee mode"
                                #endif
                                #include "Zigbee.h"
                                /* Zigbee temperature sensor configuration */
                                #define TEMP_SENSOR_ENDPOINT_NUMBER 10
                                uint8_t button = BOOT_PIN;
                                // Optional Time cluster variables
                                struct tm timeinfo;
                                struct tm *localTime;
                                int32_t timezone;
                                ZigbeeTempSensor zbTempSensor = ZigbeeTempSensor(TEMP_SENSOR_ENDPOINT_NUMBER);
                                /************************ Temp sensor *****************************/
                                static void temp_sensor_value_update(void *arg) {
                                  for (;;) {
                                    // Read temperature sensor value
                                    float tsens_value = temperatureRead();
                                    Serial.printf("Updated temperature sensor value to %.2f°C\r\n", tsens_value);
                                    // Update temperature value in Temperature sensor EP
                                    zbTempSensor.setTemperature(tsens_value);
                                    delay(1000);
                                /********************* Arduino functions **************************/
                                void setup() {
                                  Serial.begin(115200);
                                  // Init button switch
                                  pinMode(button, INPUT_PULLUP);
                                  // Optional: set Zigbee device name and model
                                  zbTempSensor.setManufacturerAndModel("Espressif", "ZigbeeTempSensor");
                                  // Set minimum and maximum temperature measurement value (10-50°C is default range for chip temperature measurement)
                                  zbTempSensor.setMinMaxValue(10, 50);
                                  // Optional: Set tolerance for temperature measurement in °C (lowest possible value is 0.01°C)
                                  zbTempSensor.setTolerance(1);
                                  // Optional: Time cluster configuration (default params, as this device will revieve time from coordinator)
                                  zbTempSensor.addTimeCluster();
                                  // Add endpoint to Zigbee Core
                                  Zigbee.addEndpoint(&zbTempSensor);
                                  Serial.println("Starting Zigbee...");
                                  // When all EPs are registered, start Zigbee in End Device mode
                                  if (!Zigbee.begin()) {
                                    Serial.println("Zigbee failed to start!");
                                    Serial.println("Rebooting...");
                                    ESP.restart();
                                  } else {
                                    Serial.println("Zigbee started successfully!");
                                  Serial.println("Connecting to network");
                                  while (!Zigbee.connected()) {
                                    Serial.print(".");
                                    delay(100);
                                  Serial.println();
                                  // Optional: If time cluster is added, time can be read from the coordinator
                                  timeinfo = zbTempSensor.getTime();
                                  timezone = zbTempSensor.getTimezone();
                                  Serial.println("UTC time:");
                                  Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
                                  time_t local = mktime(&timeinfo) + timezone;
                                  localTime = localtime(&local);
                                  Serial.println("Local time with timezone:");
                                  Serial.println(localTime, "%A, %B %d %Y %H:%M:%S");
                                  // Start Temperature sensor reading task
                                  xTaskCreate(temp_sensor_value_update, "temp_sensor_update", 2048, NULL, 10, NULL);
                                  // Set reporting interval for temperature measurement in seconds, must be called after Zigbee.begin()
                                  // min_interval and max_interval in seconds, delta (temp change in 0,1 °C)
                                  // if min = 1 and max = 0, reporting is sent only when temperature changes by delta
                                  // if min = 0 and max = 10, reporting is sent every 10 seconds or temperature changes by delta
                                  // if min = 0, max = 10 and delta = 0, reporting is sent every 10 seconds regardless of temperature change
                                  zbTempSensor.setReporting(1, 0, 1);
                                void loop() {
                                  // Checking button for factory reset
                                  if (digitalRead(button) == LOW) {  // Push button pressed
                                    // Key debounce handling
                                    delay(100);
                                    int startTime = millis();
                                    while (digitalRead(button) == LOW) {
                                      delay(50);
                                      if ((millis() - startTime) > 3000) {
                                        // If key pressed for more than 3secs, factory reset Zigbee and reboot
                                        Serial.println("Resetting Zigbee to factory and rebooting in 1s.");
                                        delay(1000);
                                        Zigbee.factoryReset();
                                    zbTempSensor.reportTemperature();
                                  delay(100);
                                So nun habe ich endgültig die Schnauze voll kann geschlossen werden hier, kein Interesse mehr!!!
                                • Asgothian
                                  @jens-g deine Entscheidung. Allerdings merkt sich der Adapter durchaus den “Namen” des Gerätes - nicht aber die ID, die für die Ansteuerung verantwortlich ist. Das mit dem Posten der Info Anzeige (nach deinen Änderungen) war ernst gemeint.
                                  Das was du als externen Konverter von mir bekommen hattest war dürneine Lampe, nicht für einen Sensor.
                                  A.
                                  3055
