    4. System portieren und Zigbee Stick gleichzeitig wechseln
      Mr.X @Asgothian last edited by
      @asgothian
      Wie erwähnt habe ich Zigbee nochmal neu auf ein frisches System installiert.
      Sogar den alten Stick dran gemacht.
      die drei Datein vom alten System rüber kopiert und die alten damit überschrieben.
      Beide ID´s vom alten System eingetragen.
      Und neu gestartet.
      Es waren keine Geräte vorhanden.
      zigbee.0
      2025-05-21 15:33:47.303	info	terminating
      zigbee.0
      2025-05-21 15:33:47.085	info	debug devices set to []
      zigbee.0
      2025-05-21 15:33:47.037	warn	Device 0x680ae2fffe71bc26 "HG06338" not found.
      zigbee.0
      2025-05-21 15:33:47.037	warn	Device 0xbc33acfffec5bc41 "HG06337" not found.
      zigbee.0
      2025-05-21 15:33:47.037	warn	Device 0xec1bbdfffed4fe44 "HG06338" not found.
      zigbee.0
      2025-05-21 15:33:47.037	warn	Device 0xbc33acfffe0ebd34 "HG06337" not found.
      zigbee.0
      2025-05-21 15:33:47.037	warn	Device 0xbc33acfffe0ebcf2 "HG06337" not found.
      zigbee.0
      2025-05-21 15:33:47.036	warn	Device 0x842e14fffe556652 "HG06338" not found.
      zigbee.0
      2025-05-21 15:33:47.035	warn	Device 0x5c0272fffecca442 "TS0201" not found.
      zigbee.0
      2025-05-21 15:33:47.026	warn	Device 0x2c1165fffe3f214c "HG08164" not found.
      zigbee.0
      2025-05-21 15:33:47.022	warn	Device 0x540f57fffe2b1fc5 "HG06620" not found.
      zigbee.0
      2025-05-21 15:33:47.021	warn	Device 0x588e81fffed4affa "TS0121_plug" not found.
      zigbee.0
      2025-05-21 15:33:47.021	warn	Device 0x842e14fffe3a4af8 "TS0121_plug" not found.
      zigbee.0
      2025-05-21 15:33:47.000	warn	Device 0x000b57fffec367c3 "LED1545G12" not found.
      zigbee.0
      2025-05-21 15:33:46.998	warn	Device 0xf0d1b80000148105 "4058075208414" not found.
      zigbee.0
      2025-05-21 15:33:46.998	warn	Device 0xf0d1b800001485c8 "4058075208414" not found.
      zigbee.0
      2025-05-21 15:33:46.997	warn	Device 0xf0d1b80000148327 "4058075208414" not found.
      zigbee.0
      2025-05-21 15:33:46.997	warn	Device 0xf0d1b800001482e1 "4058075208414" not found.
      zigbee.0
      2025-05-21 15:33:46.997	warn	Device 0xf0d1b80000148292 "4058075208414" not found.
      zigbee.0
      2025-05-21 15:33:46.996	warn	Device 0x7cb03eaa00aacf5b "AB32840" not found.
      zigbee.0
      2025-05-21 15:33:46.996	warn	Device 0x7cb03eaa00ae1974 "AB32840" not found.
      zigbee.0
      2025-05-21 15:33:46.995	warn	Device 0x7cb03eaa00ae1127 "AB32840" not found.
      zigbee.0
      2025-05-21 15:33:46.995	warn	Device 0x7cb03eaa00ae2265 "AB32840" not found.
      zigbee.0
      2025-05-21 15:33:46.995	warn	Device 0x04cf8cdf3c7d3acc "WXCJKG13LM" not found.
      zigbee.0
      2025-05-21 15:33:46.995	warn	Device 0x005043c9a3379498 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x005043c9a337968a "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x005043c90335618a "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x005043c903356313 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x005043c903383b13 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x005043c9a3311534 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x005043c903388f6d "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.994	warn	Device 0x0017880108b7ba14 "8718699673147" not found.
      zigbee.0
      2025-05-21 15:33:46.993	warn	Device 0x00158d000425298b "WSDCGQ01LM" not found.
      zigbee.0
      2025-05-21 15:33:46.993	warn	Device 0x00158d0004042192 "MCCGQ11LM" not found.
      zigbee.0
      2025-05-21 15:33:46.993	warn	Device 0x005043c903386694 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.993	warn	Device 0x00158d0003f045f4 "WSDCGQ11LM" not found.
      zigbee.0
      2025-05-21 15:33:46.993	warn	Device 0x00158d0004252ae8 "WSDCGQ01LM" not found.
      zigbee.0
      2025-05-21 15:33:46.993	warn	Device 0x00158d0004041f71 "MCCGQ11LM" not found.
      zigbee.0
      2025-05-21 15:33:46.992	warn	Device 0x005043c903241a3e "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.992	warn	Device 0x005043c903245474 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.992	warn	Device 0x005043c90324538e "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.992	warn	Device 0x005043c9032455a3 "HS1SA" not found.
      zigbee.0
      2025-05-21 15:33:46.992	warn	Device 0x00158d0002a374e8 "MFKZQ01LM" not found.
      zigbee.0
      2025-05-21 15:33:46.991	warn	Device 0x84182600000f74b5 "AC03641" not found.
      zigbee.0
      2025-05-21 15:33:46.991	warn	Device 0x000b57fffec1f6ec "E1524/E1810" not found.
      zigbee.0
      2025-05-21 15:33:46.991	warn	Device 0x000b57fffe2b7dea "ICTC-G-1" not found.
      zigbee.0
      2025-05-21 15:33:46.991	warn	Device 0x000b57fffe9e650d "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
      zigbee.0
      2025-05-21 15:33:46.991	warn	Device 0x00158d00041cd4e6 "MCCGQ11LM" not found.
      zigbee.0
      2025-05-21 15:33:46.990	warn	Device 0x90fd9ffffe6d32bc "LED1546G12" not found.
      zigbee.0
      2025-05-21 15:33:46.987	info	terminating
      zigbee.0
      2025-05-21 15:33:46.966	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
      zigbee.0
      2025-05-21 15:33:46.802	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      zigbee.0
      2025-05-21 15:33:46.801	info	terminating
      zigbee.0
      2025-05-21 15:33:46.801	info	Saved local configuration data
      zigbee.0
      2025-05-21 15:33:46.801	info	local config saved
      zigbee.0
      2025-05-21 15:33:46.801	info	cleaned everything up...
      zigbee.0
      2025-05-21 15:33:46.800	error	undefined
      zigbee.0
      2025-05-21 15:33:46.800	error	unhandled promise rejection: undefined
      zigbee.0
      2025-05-21 15:33:46.800	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      zigbee.0
      2025-05-21 15:33:46.799	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open /dev/ttyUSB0
      zigbee.0
      2025-05-21 15:33:46.784	info	Unable to obtain herdsman settings
      zigbee.0
      2025-05-21 15:33:46.644	info	Starting Zigbee-Herdsman
      zigbee.0
      2025-05-21 15:33:46.643	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
      zigbee.0
      2025-05-21 15:33:46.619	info	Starting Adapter npm ...
      zigbee.0
      2025-05-21 15:33:46.618	info	--- creating device debug ---
      zigbee.0
      2025-05-21 15:33:46.614	info	--> transmitPower : normal
      zigbee.0
      2025-05-21 15:33:46.609	info	init localConfig
      zigbee.0
      2025-05-21 15:33:46.601	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        Mr.X last edited by
        Danach über Backup Adapter das Backup eingspielt und neu gestartet:
        Log-Größe: 8.7 KB
        zigbee.0
        Zeit
        debug
        Nachricht
        zigbee.0
        2025-05-21 15:36:39.021	info	terminating
        zigbee.0
        2025-05-21 15:36:38.764	info	debug devices set to []
        zigbee.0
        2025-05-21 15:36:38.717	warn	Device 0x680ae2fffe71bc26 "HG06338" not found.
        zigbee.0
        2025-05-21 15:36:38.717	warn	Device 0xbc33acfffec5bc41 "HG06337" not found.
        zigbee.0
        2025-05-21 15:36:38.717	warn	Device 0xec1bbdfffed4fe44 "HG06338" not found.
        zigbee.0
        2025-05-21 15:36:38.716	warn	Device 0xbc33acfffe0ebd34 "HG06337" not found.
        zigbee.0
        2025-05-21 15:36:38.716	warn	Device 0xbc33acfffe0ebcf2 "HG06337" not found.
        zigbee.0
        2025-05-21 15:36:38.716	warn	Device 0x842e14fffe556652 "HG06338" not found.
        zigbee.0
        2025-05-21 15:36:38.714	warn	Device 0x5c0272fffecca442 "TS0201" not found.
        zigbee.0
        2025-05-21 15:36:38.713	warn	Device 0x2c1165fffe3f214c "HG08164" not found.
        zigbee.0
        2025-05-21 15:36:38.710	warn	Device 0x540f57fffe2b1fc5 "HG06620" not found.
        zigbee.0
        2025-05-21 15:36:38.709	warn	Device 0x588e81fffed4affa "TS0121_plug" not found.
        zigbee.0
        2025-05-21 15:36:38.708	warn	Device 0x842e14fffe3a4af8 "TS0121_plug" not found.
        zigbee.0
        2025-05-21 15:36:38.688	warn	Device 0x000b57fffec367c3 "LED1545G12" not found.
        zigbee.0
        2025-05-21 15:36:38.687	warn	Device 0xf0d1b80000148105 "4058075208414" not found.
        zigbee.0
        2025-05-21 15:36:38.686	warn	Device 0xf0d1b800001485c8 "4058075208414" not found.
        zigbee.0
        2025-05-21 15:36:38.686	warn	Device 0xf0d1b80000148327 "4058075208414" not found.
        zigbee.0
        2025-05-21 15:36:38.686	warn	Device 0xf0d1b800001482e1 "4058075208414" not found.
        zigbee.0
        2025-05-21 15:36:38.686	warn	Device 0xf0d1b80000148292 "4058075208414" not found.
        zigbee.0
        2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00aacf5b "AB32840" not found.
        zigbee.0
        2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00ae1974 "AB32840" not found.
        zigbee.0
        2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00ae1127 "AB32840" not found.
        zigbee.0
        2025-05-21 15:36:38.685	warn	Device 0x7cb03eaa00ae2265 "AB32840" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x04cf8cdf3c7d3acc "WXCJKG13LM" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x00158d00041d47f7 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x005043c9a3379498 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x005043c9a337968a "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x005043c90335618a "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x005043c903356313 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.684	warn	Device 0x005043c903383b13 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.683	warn	Device 0x005043c9a3311534 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.683	warn	Device 0x005043c903388f6d "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.683	warn	Device 0x0017880108b7ba14 "8718699673147" not found.
        zigbee.0
        2025-05-21 15:36:38.683	warn	Device 0x00158d000425298b "WSDCGQ01LM" not found.
        zigbee.0
        2025-05-21 15:36:38.683	warn	Device 0x00158d0004042192 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 15:36:38.683	warn	Device 0x005043c903386694 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.682	warn	Device 0x00158d0003f045f4 "WSDCGQ11LM" not found.
        zigbee.0
        2025-05-21 15:36:38.682	warn	Device 0x00158d0004252ae8 "WSDCGQ01LM" not found.
        zigbee.0
        2025-05-21 15:36:38.682	warn	Device 0x00158d0004041f71 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 15:36:38.682	warn	Device 0x005043c903241a3e "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.682	warn	Device 0x005043c903245474 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.682	warn	Device 0x005043c90324538e "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.681	warn	Device 0x005043c9032455a3 "HS1SA" not found.
        zigbee.0
        2025-05-21 15:36:38.681	warn	Device 0x00158d0002a374e8 "MFKZQ01LM" not found.
        zigbee.0
        2025-05-21 15:36:38.681	warn	Device 0x84182600000f74b5 "AC03641" not found.
        zigbee.0
        2025-05-21 15:36:38.681	warn	Device 0x000b57fffec1f6ec "E1524/E1810" not found.
        zigbee.0
        2025-05-21 15:36:38.681	warn	Device 0x000b57fffe2b7dea "ICTC-G-1" not found.
        zigbee.0
        2025-05-21 15:36:38.680	warn	Device 0x000b57fffe9e650d "ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2" not found.
        zigbee.0
        2025-05-21 15:36:38.680	warn	Device 0x00158d00041cd4e6 "MCCGQ11LM" not found.
        zigbee.0
        2025-05-21 15:36:38.680	warn	Device 0x90fd9ffffe6d32bc "LED1546G12" not found.
        zigbee.0
        2025-05-21 15:36:38.678	info	terminating
        zigbee.0
        2025-05-21 15:36:38.665	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at Controller.permitJoin (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:259:35) at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
        zigbee.0
        2025-05-21 15:36:38.520	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
        zigbee.0
        2025-05-21 15:36:38.520	info	terminating
        zigbee.0
        2025-05-21 15:36:38.519	info	Saved local configuration data
        zigbee.0
        2025-05-21 15:36:38.519	info	local config saved
        zigbee.0
        2025-05-21 15:36:38.519	info	cleaned everything up...
        zigbee.0
        2025-05-21 15:36:38.518	error	undefined
        zigbee.0
        2025-05-21 15:36:38.518	error	unhandled promise rejection: undefined
        zigbee.0
        2025-05-21 15:36:38.518	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
        zigbee.0
        2025-05-21 15:36:38.517	error	Starting zigbee-herdsman problem : Error: No such file or directory, cannot open /dev/ttyUSB0
        zigbee.0
        2025-05-21 15:36:38.507	info	Unable to obtain herdsman settings
        zigbee.0
        2025-05-21 15:36:38.393	info	Starting Zigbee-Herdsman
        zigbee.0
        2025-05-21 15:36:38.392	info	Installed Version: iobroker.zigbee@2.0.5 (Converters 23.6.0 Herdsman 3.5.2)
        zigbee.0
        2025-05-21 15:36:38.378	info	Starting Adapter npm ...
        zigbee.0
        2025-05-21 15:36:38.377	info	--- creating device debug ---
        zigbee.0
        2025-05-21 15:36:38.372	info	--> transmitPower : normal
        zigbee.0
        2025-05-21 15:36:38.369	info	init localConfig
        zigbee.0
        2025-05-21 15:36:38.361	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
        • Asgothian
          Asgothian Developer @Mr.X last edited by
          @mr-x die Reihenfolge ist wichtig!
          • Adapter anhalten
          • 30 s warten
          • Dateien kopieren
          • Adapter starten.
          Ansonsten überschreibt der Adapter beim Anhalten die Dateien.
            @asgothian
            Ja, lass es 28 sec gewesen sein, aber schnell war es nicht.
            Ich kann aber alles nochmal manuell löschen und neu installieren/kopieren etc.
            • Asgothian
              @mr-x bitte nichts löschen, einfach nur Adapter anhalten, Shepherd.dB und nvbackup.json wiederherstellen, Adapter starten.
              Und bitte schau mal was in der Shepherd.dB drin steht - das ist eine XML Datei.
              A.
                @asgothian
                ich habe die Dateien überschrieben und dann neu gestartet.
                Adapter wurde komplett grün, alle drei "Anzeigen".
                Dann habe ich den Stick ausgewählt und und neu gestartet und alles rot:
                schaue sofort nach der Datei.
                zigbee.0
                2025-05-21 17:32:19.530	info	terminating
                zigbee.0
                2025-05-21 17:32:19.031	error	Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:32:19.031	error	TypeError: Cannot read properties of undefined (reading 'database') at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:333:27) at DeviceEvent.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:30:25) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:54) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:627:24) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                zigbee.0
                2025-05-21 17:32:19.031	error	unhandled promise rejection: Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:32:19.031	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-05-21 17:32:19.031	info	terminating
                zigbee.0
                2025-05-21 17:32:19.030	warn	Failed to stop zigbee during startup
                zigbee.0
                2025-05-21 17:32:19.030	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                zigbee.0
                2025-05-21 17:32:19.030	error	unable to call extension Method stop: Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:32:19.029	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee.0
                2025-05-21 17:32:19.029	info	terminating
                zigbee.0
                2025-05-21 17:32:19.028	info	Saved local configuration data
                zigbee.0
                2025-05-21 17:32:19.028	info	local config saved
                zigbee.0
                2025-05-21 17:32:19.027	info	cleaned everything up...
                zigbee.0
                2025-05-21 17:32:19.022	error	PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                zigbee.0
                2025-05-21 17:32:19.022	error	Error: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0. at new Controller (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:111:19) at ZigbeeController.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:25) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:233:27) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:71:37) at Zigbee.emit (node:events:536:35) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7810:12) at Zigbee._initAdapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7793:12)
                zigbee.0
                2025-05-21 17:32:19.020	error	unhandled promise rejection: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                zigbee.0
                2025-05-21 17:32:19.020	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-05-21 17:32:19.018	info	--> transmitPower : normal
                zigbee.0
                2025-05-21 17:32:19.016	info	init localConfig
                zigbee.0
                2025-05-21 17:32:19.008	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                zigbee.0
                2025-05-21 17:31:50.216	info	terminating
                zigbee.0
                2025-05-21 17:31:49.717	error	Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:31:49.717	error	TypeError: Cannot read properties of undefined (reading 'database') at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:333:27) at DeviceEvent.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:30:25) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:54) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:627:24) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                zigbee.0
                2025-05-21 17:31:49.716	error	unhandled promise rejection: Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:31:49.716	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-05-21 17:31:49.716	info	terminating
                zigbee.0
                2025-05-21 17:31:49.716	warn	Failed to stop zigbee during startup
                zigbee.0
                2025-05-21 17:31:49.716	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                zigbee.0
                2025-05-21 17:31:49.716	error	unable to call extension Method stop: Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:31:49.715	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee.0
                2025-05-21 17:31:49.714	info	terminating
                zigbee.0
                2025-05-21 17:31:49.714	info	Saved local configuration data
                zigbee.0
                2025-05-21 17:31:49.713	info	local config saved
                zigbee.0
                2025-05-21 17:31:49.713	info	cleaned everything up...
                zigbee.0
                2025-05-21 17:31:49.705	error	PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                zigbee.0
                2025-05-21 17:31:49.705	error	Error: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0. at new Controller (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:111:19) at ZigbeeController.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:25) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:233:27) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:71:37) at Zigbee.emit (node:events:536:35) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7810:12) at Zigbee._initAdapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7793:12)
                zigbee.0
                2025-05-21 17:31:49.704	error	unhandled promise rejection: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                zigbee.0
                2025-05-21 17:31:49.704	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-05-21 17:31:49.702	info	--> transmitPower : normal
                zigbee.0
                2025-05-21 17:31:49.699	info	init localConfig
                zigbee.0
                2025-05-21 17:31:49.691	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                zigbee.0
                2025-05-21 17:31:20.091	info	terminating
                zigbee.0
                2025-05-21 17:31:19.593	error	Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:31:19.593	error	TypeError: Cannot read properties of undefined (reading 'database') at ZigbeeController.getClients (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:333:27) at DeviceEvent.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zbDeviceEvent.js:30:25) at ZigbeeController.callExtensionMethod (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:319:54) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:627:24) at Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:41) at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                zigbee.0
                2025-05-21 17:31:19.592	error	unhandled promise rejection: Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:31:19.592	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-05-21 17:31:19.592	info	terminating
                zigbee.0
                2025-05-21 17:31:19.592	warn	Failed to stop zigbee during startup
                zigbee.0
                2025-05-21 17:31:19.592	error	Failed to open the network: TypeError: Cannot read properties of undefined (reading 'permitJoin') at ZigbeeController.permitJoin (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:659:33) at ZigbeeController.stop (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:634:24) at process.processTicksAndRejections (node:internal/process/task_queues:95:5) at async Zigbee.onUnload (/opt/iobroker/node_modules/iobroker.zigbee/main.js:1037:17)
                zigbee.0
                2025-05-21 17:31:19.591	error	unable to call extension Method stop: Cannot read properties of undefined (reading 'database')
                zigbee.0
                2025-05-21 17:31:19.590	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                zigbee.0
                2025-05-21 17:31:19.590	info	terminating
                zigbee.0
                2025-05-21 17:31:19.590	info	Saved local configuration data
                zigbee.0
                2025-05-21 17:31:19.589	info	local config saved
                zigbee.0
                2025-05-21 17:31:19.588	info	cleaned everything up...
                zigbee.0
                2025-05-21 17:31:19.583	error	PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                zigbee.0
                2025-05-21 17:31:19.583	error	Error: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0. at new Controller (/opt/iobroker/node_modules/zigbee-herdsman/dist/controller/controller.js:111:19) at ZigbeeController.configure (/opt/iobroker/node_modules/iobroker.zigbee/lib/zigbeecontroller.js:146:25) at Zigbee.onReady (/opt/iobroker/node_modules/iobroker.zigbee/main.js:233:27) at Zigbee.<anonymous> (/opt/iobroker/node_modules/iobroker.zigbee/main.js:71:37) at Zigbee.emit (node:events:536:35) at Zigbee._callReadyHandler (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7810:12) at Zigbee._initAdapter (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/cjs/lib/adapter/adapter.js:7793:12)
                zigbee.0
                2025-05-21 17:31:19.582	error	unhandled promise rejection: PanID must have a value of 0x0001 (1) - 0xFFFE (65534), got 0.
                zigbee.0
                2025-05-21 17:31:19.582	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                zigbee.0
                2025-05-21 17:31:19.579	info	--> transmitPower : normal
                zigbee.0
                2025-05-21 17:31:19.577	info	init localConfig
                zigbee.0
                2025-05-21 17:31:19.569	info	starting. Version 2.0.5 in /opt/iobroker/node_modules/iobroker.zigbee, node: v20.19.2, js-controller: 7.0.6
                zigbee.0
                2025-05-21 17:31:15.569	info	terminating
                zigbee.0
                2025-05-21 17:31:15.498	info	Closing Zigbee network, 0 seconds remaining
                zigbee.0
                2025-05-21 17:31:15.291	info	Closing Zigbee network, 0 seconds remaining
                zigbee.0
                2025-05-21 17:31:15.069	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                zigbee.0
                2025-05-21 17:31:15.069	info	terminating
                zigbee.0
                2025-05-21 17:31:15.068	info	Saved local configuration data
                zigbee.0
                2025-05-21 17:31:15.068	info	local config saved
                zigbee.0
                2025-05-21 17:31:15.068	info	cleaned everything up...
                zigbee.0
                2025-05-21 17:31:15.067	info	Got terminate signal TERMINATE_YOURSELF
                zigbee.0
                2025-05-21 17:31:15.003	info	DeviceConfigure successful 0x90fd9ffffe6d32bc LED1546G12
                zigbee.0
                2025-05-21 17:31:14.353	info	Failed to ping 0xa4c13866fb0b8f27 undefined
                zigbee.0
                2025-05-21 17:31:13.591	info	Failed to ping 0x000b57fffec367c3 TRADFRI bulb E27 WS opal 980lm
                zigbee.0
                2025-05-21 17:31:13.034	info	Failed to ping 0x680ae2fffe71bc26 TS011F
                zigbee.0
                2025-05-21 17:31:12.296	info	Failed to ping 0xbc33acfffec5bc41 TS011F
                zigbee.0
                2025-05-21 17:31:11.682	info	Failed to ping 0xf0d1b80000148105 B40 TW Z3
                zigbee.0
                2025-05-21 17:31:10.936	warn	DeviceConfigure:0x842e14fffe556652 TS011F Failed to configure. --> ZCL command 0x842e14fffe556652/1 genBasic.read(["manufacturerName","zclVersion","appVersion","modelId","powerSource",65534], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"writeUndiv":false}) failed (Data request failed with error: 'No network route' (205))
                zigbee.0
                2025-05-21 17:31:10.654	info	Configuring 0x000b57fffe2b7dea ICTC-G-1
                zigbee.0
                2025-05-21 17:31:10.653	info	DeviceConfigureQueue configuring 0x000b57fffe2b7dea TRADFRI wireless dimmer
                zigbee.0
                2025-05-21 17:31:05.660	info	DeviceConfigure successful 0x000b57fffe9e650d ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2
                zigbee.0
                2025-05-21 17:31:05.653	info	Configuring 0x000b57fffe9e650d ICPSHC24-30EU-IL-1/ICPSHC24-10EU-IL-2
                zigbee.0
                2025-05-21 17:31:05.653	info	DeviceConfigureQueue configuring 0x000b57fffe9e650d TRADFRI transformer 30W
                zigbee.0
                2025-05-21 17:31:00.671	info	DeviceConfigure successful 0x00158d00041cd4e6 MCCGQ11LM
                zigbee.0
                2025-05-21 17:31:00.653	info	Configuring 0x00158d00041cd4e6 MCCGQ11LM
                zigbee.0
                2025-05-21 17:31:00.653	info	DeviceConfigureQueue configuring 0x00158d00041cd4e6 lumi.sensor_magnet.aq2
                zigbee.0
                2025-05-21 17:30:55.653	info	Configuring 0x90fd9ffffe6d32bc LED1546G12
                zigbee.0
                2025-05-21 17:30:55.652	info	DeviceConfigureQueue configuring 0x90fd9ffffe6d32bc TRADFRI bulb E27 WS clear 950lm
                zigbee.0
                2025-05-21 17:30:55.228	info	Failed to ping 0xf0d1b800001485c8 B40 TW Z3
                zigbee.0
                2025-05-21 17:30:54.736	info	Failed to ping 0xf0d1b80000148327 B40 TW Z3
                zigbee.0
                2025-05-21 17:30:54.734	info	List of port: [{"path":"/dev/ttyACM0","manufacturer":"Texas Instruments","pnpId":"usb-Texas_Instruments_CC2538_USB_CDC-if00","vendorId":"0451","productId":"16c8"},{"path":"/dev/ttyS0"},{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"}]
                zigbee.0
                2025-05-21 17:30:54.225	info	Failed to ping 0xf0d1b800001482e1 B40 TW Z3
                zigbee.0
                2025-05-21 17:30:53.726	info	Failed to ping 0xf0d1b80000148292 B40 TW Z3
                zigbee.0
                2025-05-21 17:30:53.224	info	Failed to ping 0x7cb03eaa00aacf5b Classic B40 TW - LIGHTIFY
                zigbee.0
                2025-05-21 17:30:52.724	info	Failed to ping 0x7cb03eaa00ae1974 Classic B40 TW - LIGHTIFY
                zigbee.0
                2025-05-21 17:30:52.223	info	Failed to ping 0x7cb03eaa00ae1127 Classic B40 TW - LIGHTIFY
                zigbee.0
                2025-05-21 17:30:51.722	info	Failed to ping 0x7cb03eaa00ae2265 Classic B40 TW - LIGHTIFY
                zigbee.0
                2025-05-21 17:30:51.224	info	Failed to ping 0xec1bbdfffed4fe44 TS011F
                zigbee.0
                2025-05-21 17:30:50.723	info	Failed to ping 0x588e81fffed4affa TS0121
                zigbee.0
                2025-05-21 17:30:50.652	info	Configuring 0x842e14fffe556652 HG06338
                zigbee.0
                2025-05-21 17:30:50.651	info	DeviceConfigureQueue configuring 0x842e14fffe556652 TS011F
                zigbee.0
                2025-05-21 17:30:50.235	info	Failed to ping 0x0017880108b7ba14 LWA001
                zigbee.0
                2025-05-21 17:30:50.223	info	Failed to ping 0x842e14fffe3a4af8 TS0121
                zigbee.0
                2025-05-21 17:30:49.804	info	Failed to ping 0xbc33acfffe0ebd34 TS011F
                zigbee.0
                2025-05-21 17:30:49.195	info	Failed to ping 0xbc33acfffe0ebcf2 TS011F
                zigbee.0
                2025-05-21 17:30:49.017	info	Failed to ping 0x84182600000f74b5 Classic A60 W clear - LIGHTIFY
                zigbee.0
                2025-05-21 17:30:47.980	info	Failed to ping 0x540f57fffe2b1fc5 TS0101
                zigbee.0
                2025-05-21 17:30:47.918	info	Failed to ping 0x000b57fffe9e650d TRADFRI transformer 30W
                zigbee.0
                2025-05-21 17:30:47.099	info	Failed to ping 0x90fd9ffffe6d32bc TRADFRI bulb E27 WS clear 950lm
                zigbee.0
                2025-05-21 17:30:46.872	info	copied /tmp/WSDCGQ01LM.png to img/WSDCGQ01LM.png.
                zigbee.0
                2025-05-21 17:30:46.829	info	copied /tmp/TS0201.png to img/TS0201.png.
                zigbee.0
                2025-05-21 17:30:46.826	warn	error removing /tmp/HG08164.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG08164.png"}
                zigbee.0
                2025-05-21 17:30:46.826	warn	error removing /tmp/LED1545G12.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/LED1545G12.png"}
                zigbee.0
                2025-05-21 17:30:46.826	warn	error removing /tmp/HG06337.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG06337.png"}
                zigbee.0
                2025-05-21 17:30:46.826	warn	error removing /tmp/4058075208414.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/4058075208414.png"}
                zigbee.0
                2025-05-21 17:30:46.825	info	copied /tmp/HG08164.png to img/HG08164.png.
                zigbee.0
                2025-05-21 17:30:46.825	info	copied /tmp/LED1545G12.png to img/LED1545G12.png.
                zigbee.0
                2025-05-21 17:30:46.825	info	copied /tmp/HG06337.png to img/HG06337.png.
                zigbee.0
                2025-05-21 17:30:46.824	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                zigbee.0
                2025-05-21 17:30:46.821	info	Failed to ping 0x842e14fffe556652 TS011F
                zigbee.0
                2025-05-21 17:30:46.782	warn	error removing /tmp/4058075208414.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/4058075208414.png"}
                zigbee.0
                2025-05-21 17:30:46.782	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                zigbee.0
                2025-05-21 17:30:46.781	warn	error removing /tmp/4058075208414.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/4058075208414.png"}
                zigbee.0
                2025-05-21 17:30:46.781	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                zigbee.0
                2025-05-21 17:30:46.678	warn	error removing /tmp/MCCGQ11LM.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/MCCGQ11LM.png"}
                zigbee.0
                zigbee.0
                2025-05-21 17:30:46.678	warn	error removing /tmp/HG06337.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG06337.png"}
                zigbee.0
                2025-05-21 17:30:46.677	warn	error removing /tmp/HG06337.png : {"errno":-2,"code":"ENOENT","syscall":"lstat","path":"/tmp/HG06337.png"}
                zigbee.0
                2025-05-21 17:30:46.676	info	copied /tmp/TS0121_plug.png to img/TS0121_plug.png.
                zigbee.0
                2025-05-21 17:30:46.676	info	copied /tmp/WXCJKG13LM.png to img/WXCJKG13LM.png.
                zigbee.0
                2025-05-21 17:30:46.676	info	copied /tmp/4058075208414.png to img/4058075208414.png.
                zigbee.0
                2025-05-21 17:30:46.676	info	copied /tmp/WSDCGQ11LM.png to img/WSDCGQ11LM.png.
                zigbee.0
                2025-05-21 17:30:46.676	info	copied /tmp/HG08164.png to img/HG08164.png.
                zigbee.0
                2025-05-21 17:30:46.676	info	copied /tmp/8718699673147.png to img/8718699673147.png.
                zigbee.0
                2025-05-21 17:30:46.675	info	copied /tmp/AB32840.png to img/AB32840.png.
                zigbee.0
                2025-05-21 17:30:46.675	info	copied /tmp/ICTC-G-1.png to img/ICTC-G-1.png.
                zigbee.0
                2025-05-21 17:30:46.675	info	copied /tmp/HS1SA.png to img/HS1SA.png.
                zigbee.0
                2025-05-21 17:30:46.675	info	copied /tmp/MFKZQ01LM.png to img/MFKZQ01LM.png.
                zigbee.0
                2025-05-21 17:30:46.675	info	copied /tmp/LED1546G12.png to img/LED1546G12.png.
                zigbee.0
                2025-05-21 17:30:46.674	info	copied /tmp/HG06620.png to img/HG06620.png.
                zigbee.0
                2025-05-21 17:30:46.674	info	copied /tmp/AC03641.png to img/AC03641.png.
                zigbee.0
                2025-05-21 17:30:46.674	info	copied /tmp/LED1545G12.png to img/LED1545G12.png.
                zigbee.0
                2025-05-21 17:30:46.674	info	copied /tmp/E1524-E1810.png to img/E1524-E1810.png.
                zigbee.0
                2025-05-21 17:30:46.674	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                zigbee.0
                2025-05-21 17:30:46.673	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                zigbee.0
                2025-05-21 17:30:46.673	info	copied /tmp/HG06337.png to img/HG06337.png.
                zigbee.0
                zigbee.0
                2025-05-21 17:30:46.673	info	copied /tmp/E1524-E1810.png to img/E1524-E1810.png.
                zigbee.0
                2025-05-21 17:30:46.672	info	copied /tmp/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png to img/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png.
                zigbee.0
                2025-05-21 17:30:46.665	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                zigbee.0
                2025-05-21 17:30:46.643	info	copied /tmp/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png to img/ICPSHC24-30EU-IL-1-ICPSHC24-10EU-IL-2.png.
                zigbee.0
                2025-05-21 17:30:46.643	info	copied /tmp/MCCGQ11LM.png to img/MCCGQ11LM.png.
                zigbee.0
                2025-05-21 17:30:46.643	info	copied /tmp/HG06337.png to img/HG06337.png.
                zigbee.0
                2025-05-21 17:30:46.510	warn	Device 0xa4c13866fb0b8f27 "undefined" not found.
                zigbee.0
                2025-05-21 17:30:46.488	info	not downloading /tmp/LED1545G12.png - file exists
                zigbee.0
                2025-05-21 17:30:46.488	info	not downloading /tmp/HG08164.png - file exists
                zigbee.0
                2025-05-21 17:30:46.487	info	not downloading /tmp/HG06337.png - file exists
                zigbee.0
                2025-05-21 17:30:46.487	info	not downloading /tmp/4058075208414.png - file exists
                zigbee.0
                zigbee.0
                zigbee.0
                2025-05-21 17:30:46.311	info	not downloading /tmp/MCCGQ11LM.png - file exists
                zigbee.0
                  @asgothian sagte in System portieren und Zigbee Stick gleichzeitig wechseln:
                  A.
                  womit kann ich die aufmachen, damit das sinnvoll aussieht?
                  Da steht seeeehr viel drin, kenne mich damit aber leider niht aus.
                  • Asgothian
                    @mr-x laut den Fehlermeldungen hast du keine Einträge für panID und extPanID in der Konfiguration. Da passt etwas nicht zusammen.
                    Mein Vorschlag - wir treffen uns auf dem iobroker discord - dann können wir das im Dialog gemeinsam gerade biegen. Dieses scheibchenweise wird so nicht einfach werden. Ich hätte dafür heute Zeit.
                    A.
                      @asgothian
                      Kann ich verstehen. Und gebe dir recht.
                      Nur kamen vorhin die Kinder nach Hause und die prios haben sich verschoben.
                      Ich habe erstmal hier nachgelesen was discord ist u d mich angemeldeten.
                      Morgen schaue ich es mit genauer an und wie es im Browser läuft mit chatten und ggf screen share.
                      Wenn ich soweit bin würde ich mich gerne mal bei dir melden, wenn das Angebot noch steht.
                      Hast du irgendwelche geeigneten Tage oder Zeiten in denen es passt?
                      Danke und Grüße
                        @mr-x Mit dem Lan Koordinator kann der Slave in Rente gehen, ja. Du brauchst einfach nur eine weitere zigbee Instanz auf dem Master der dann den LAN Koordinator in der Garage anspricht.
                        Zum Thema Umzug vom Zigbee:
                        so wie es aussieht solltest du einfach folgendes machen können:
                        • Zigbee Instanz im Container installieren. Wichtig: nicht starten. Sollte sie automatisch gestartet werden - anhalten.
                        • von deiner bestehenden Installation die Dateien shepherd.db (und sofern vorhanden) nvbackup.json und dev_names.json in das Datenverzeichnis der neuen Zigbee Instanz kopieren liegt unter /opt/iobroker/iobroker-data/zigbee_x (wobei x die Instanz Nummer ist)
                        • Konfiguration des Adapters öffnen, die Werte sonder alten Instanz eintragen. Einzig den Port musst du anpassen
                          -- bei Verwendung des Sonoff Sticks da das 'device' eintragen an das du den USB Stick weitergereicht hast.
                          Wichtig: Entgegen der Aussage von @Thomas-Braun ist es in diesem Setup Sinnvoll einfach das erzeugte Device zu nehmen (/dev/ttyUSB0 oder so) und nicht das Device unter /dev/serial/by-id) - Grund dafür ist das die Weiterleitung an den Container ja bereits auf der USB ID basiert. Damit ist also sichergestellt das immer nur das für den Container vorgesehene USB Gerät weiter gegeben wird. Solltest Du in der Zukunft also den Stick austauschen, müsstest Du nur die Weiterleitung an den Container anpassen.
                          -- Bei Verwendung des Cod.M Lan Koordinators muss da tcp://<IP>:<PORT> rein.Die Werte für IP und Port findest du im Web-Interface des Cod.M
                        • Adapter auf der alten Installation anhalten und USB Stick abziehen Dieser Schritt ist Wichtig, incl. des Abziehen des Koordinators.
                        • Adapter starten. Wenn alles korrekt konfiguriert ist sollte der Adapter durchstarten und auch gleich alle Geräte Ansteuern können. In einzelfaellen kann es notwendig sein Geräte neu zu konfigurieren (ueber die Kachel).
                        auf die gleiche Methode kannst du die Zigbee-Instanz vom Slave auf den neuen ioBroker übertragen (manuell)
                        Generell würde ich Dir empfehlen die 3.0.1 aus dem Latest zu installieren, da sie gegenüber der aktuellen 2.0.5 aus dem Stable einige Vorteile bietet, incl. detaillierter Anleitung zur Konfiguration (im Readme auf Github verlinkt)
                        A.
                        @Asgothian, vielen Dank für dienen Support via Discord
                        Für alle Suchenden hier noch eine kurze Anmerkung.
                        Nachdem der Adapter zum ersten mal wieder neu gestartet wurde, kann es STUNDEN dauern, bis das Netzwerk wieder hergestellt werden kann.
                        Hat bei mir mit den meisten Geräten geklappt.
                        Also am besten über Nacht laufen lassen.
                        • Asgothian
                          Asgothian Developer @Mr.X last edited by Asgothian
                          @mr-x sagte in System portieren und Zigbee Stick gleichzeitig wechseln:
                          Zu dieser Anmerkung noch ein wenig Kontext:
                          • Adapter Neustart mit identischer Hardware an gleicher Stelle zeigt dieses Verhalten nicht. Nach wenigen Minuten sollte alles laufen.
                          • Adapter Neustart mit ausgetauschtem Koordinator an gleicher Stelle wie der originale Koordinator zeigt dieses Verhalten, allerdings mit deutlich weniger Zeit zur Reorganisation - nach etwa 1 Stunde sollte alles laufen.
                          • Adapter Neusstart mit ausgetauschtem oder gleichem Koordinator an anderer Stelle zeigt dieses Verhalten. Je nach Abstand zwischen dem neuen und dem alten Standort kann es bis zu 24h Dauern bis das Netz sich neu organisiert hat.
                          A.
                          1022
