    3. Einsteigerfragen
    4. Installation
    5. Adapter
    Adapter
      arnold @Homoran last edited by
      ```bash
      Script v.2025-02-02
      *** BASE SYSTEM ***
        Static hostname: raspberrypi4-iob
              Icon name: computer
       Operating System: Raspbian GNU/Linux 11 (bullseye)
                 Kernel: Linux 6.1.21-v8+
           Architecture: arm64
      OS is similar to: debian
      Model           : Raspberry Pi 4 Model B Rev 1.1
      Docker          : false
      Virtualization  : none
      Kernel          : aarch64
      Userland        : 32 bit
      Systemuptime and Load:
      12:13:04 up 21:19,  2 users,  load average: 1.00, 0.59, 0.68
      CPU threads: 4
      *** LIFE CYCLE STATUS ***
      Debian 'bullseye' is the current oldstable version. Please upgrade to the latest stable release 'bookworm' in due time!
      *** RASPBERRY THROTTLING ***
      Current issues:
      Previously detected issues:
      *** TIME AND TIMEZONES ***
                    Local time: Tue 2025-02-18 12:13:04 CET
                Universal time: Tue 2025-02-18 11:13:04 UTC
                      RTC time: n/a
                   NTP service: active
               RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      pi
      HOME=/home/pi
      GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            3.8G        2.0G        925M        0.0K        889M        1.9G
      Swap:            99M          0B         99M
      Total:          3.9G        2.0G        1.0G
      Active iob-Instances:   29
              3794 M total memory
              1979 M used memory
              2162 M active memory
               356 M inactive memory
               925 M free memory
                59 M buffer memory
               830 M swap cache
                99 M total swap
                 0 M used swap
                99 M free swap
      top - 12:13:05 up 21:19,  2 users,  load average: 1.00, 0.59, 0.68
      Tasks: 200 total,   1 running, 199 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  2.8 us,  2.8 sy,  0.0 ni, 94.4 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
      MiB Mem :   3794.3 total,    925.5 free,   1979.4 used,    889.4 buff/cache
      MiB Swap:    100.0 total,    100.0 free,      0.0 used.   1853.0 avail Mem
      *** FAILED SERVICES ***
      0 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      No critical errors detected
      *** FILESYSTEM ***
      /dev/root      ext4       29G   18G   11G  63% /
      devtmpfs       devtmpfs  1.7G     0  1.7G   0% /dev
      tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
      tmpfs          tmpfs     759M  896K  758M   1% /run
      /dev/mmcblk0p1 vfat      253M   51M  202M  20% /boot
      tmpfs          tmpfs     380M   16K  380M   1% /run/user/1000
      [Mon Feb 17 14:54:02 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:40:6D:89 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=c2ae5e61-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
      [Mon Feb 17 14:54:03 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
      [Mon Feb 17 14:54:03 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
      [Mon Feb 17 14:54:06 2025] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET  SOURCE         FSTYPE OPTIONS
      /       /dev/mmcblk0p2 ext4   rw,noatime
      `-/boot /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
      /var:
      6.5G    /var/
      3.2G    /var/cache/apt/archives
      3.2G    /var/cache/apt
      3.2G    /var/cache
      3.1G    /var/log
      Archived and active journals take up 2.9G in the file system.
      /opt/iobroker/backups:
      4.0K    /opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G    /opt/iobroker/iobroker-data/
      1.1G    /opt/iobroker/iobroker-data/files
      617M    /opt/iobroker/iobroker-data/files/javascript.admin
      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
      38M     /opt/iobroker/iobroker-data/files/iot.admin/static/js/main.d3d286bd.js.map
      27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
      24M     /opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
      23M     /opt/iobroker/iobroker-data/objects.jsonl
      USB-Devices by-id:
      /dev/serial/by-id/usb-ITead_Sonoff_Zigbee_3.0_USB_Dongle_Plus_96afdeed50c8eb118ac2c4c3de5b81b4-if00-port0
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      *** NodeJS-Installation ***
      /usr/bin/nodejs         v20.18.3
      /usr/bin/node           v20.18.3
      /usr/bin/npm            10.8.2
      /usr/bin/npx            10.8.2
      /usr/bin/corepack       0.30.0
      nodejs:
       Installed: 20.18.3-1nodesource1
       Candidate: 20.18.3-1nodesource1
       Version table:
      *** 20.18.3-1nodesource1 1001
             500 https://deb.nodesource.com/node_20.x nodistro/main armhf Packages
             100 /var/lib/dpkg/status
          20.18.2-1nodesource1 1001
          20.18.1-1nodesource1 1001
          20.18.0-1nodesource1 1001
          20.17.0-1nodesource1 1001
          20.16.0-1nodesource1 1001
          20.15.1-1nodesource1 1001
          20.15.0-1nodesource1 1001
          20.14.0-1nodesource1 1001
          20.13.1-1nodesource1 1001
          20.13.0-1nodesource1 1001
          20.12.2-1nodesource1 1001
          20.12.1-1nodesource1 1001
          20.12.0-1nodesource1 1001
          20.11.1-1nodesource1 1001
          20.11.0-1nodesource1 1001
          20.10.0-1nodesource1 1001
          20.9.0-1nodesource1 1001
          20.8.1-1nodesource1 1001
          20.8.0-1nodesource1 1001
          20.7.0-1nodesource1 1001
          20.6.1-1nodesource1 1001
          20.6.0-1nodesource1 1001
          20.5.1-1nodesource1 1001
          20.5.0-1nodesource1 1001
          20.4.0-1nodesource1 1001
          20.3.1-1nodesource1 1001
          20.3.0-1nodesource1 1001
          20.2.0-1nodesource1 1001
          20.1.0-1nodesource1 1001
          20.0.0-1nodesource1 1001
          12.22.12~dfsg-1~deb11u5 500
             500 http://raspbian.raspberrypi.org/raspbian bullseye/main armhf Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      raspberrypi4-iob    raspberrypi4-iob (version: 7.0.6, hostname: raspberrypi4-iob, alive, uptime: 75426)
      Core adapters versions
      js-controller:  7.0.6
      admin:          7.4.10
      javascript:     8.8.3
      nodejs modules from github:     0
      Adapter State
      + system.adapter.admin.0                  : admin                 : raspberrypi4-iob                         -  enabled, port: 6030, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.alexa2.0                 : alexa2                : raspberrypi4-iob                         -  enabled
      + system.adapter.backitup.0               : backitup              : raspberrypi4-iob                         -  enabled
      + system.adapter.ble.0                    : ble                   : raspberrypi4-iob                         -  enabled
       system.adapter.cloud.0                  : cloud                 : raspberrypi4-iob                         - disabled
       system.adapter.daswetter.0              : daswetter             : raspberrypi4-iob                         -  enabled
      + system.adapter.discovery.0              : discovery             : raspberrypi4-iob                         -  enabled
       system.adapter.dwd.0                    : dwd                   : raspberrypi4-iob                         -  enabled
       system.adapter.flot.0                   : flot                  : raspberrypi4-iob                         - disabled
       system.adapter.ical.0                   : ical                  : raspberrypi4-iob                         -  enabled
       system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: raspberrypi4-iob                         - disabled
      + system.adapter.influxdb.0               : influxdb              : raspberrypi4-iob                         -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : raspberrypi4-iob                         -  enabled
      + system.adapter.iot.0                    : iot                   : raspberrypi4-iob                         -  enabled
      + system.adapter.iqontrol.0               : iqontrol              : raspberrypi4-iob                         -  enabled
      + system.adapter.javascript.0             : javascript            : raspberrypi4-iob                         -  enabled
      + system.adapter.mihome-vacuum.0          : mihome-vacuum         : raspberrypi4-iob                         -  enabled, port: 54321
      + system.adapter.mqtt.0                   : mqtt                  : raspberrypi4-iob                         -  enabled, port: 1885, bind: 0.0.0.0
       system.adapter.openweathermap.0         : openweathermap        : raspberrypi4-iob                         -  enabled
      + system.adapter.parcel.0                 : parcel                : raspberrypi4-iob                         -  enabled
      + system.adapter.ping.0                   : ping                  : raspberrypi4-iob                         -  enabled
      + system.adapter.rpi2.0                   : rpi2                  : raspberrypi4-iob                         -  enabled
      + system.adapter.scenes.0                 : scenes                : raspberrypi4-iob                         -  enabled
      + system.adapter.simple-api.0             : simple-api            : raspberrypi4-iob                         -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
      + system.adapter.sonoff.1                 : sonoff                : raspberrypi4-iob                         -  enabled, port: 1884, bind: 0.0.0.0
      + system.adapter.sourceanalytix.0         : sourceanalytix        : raspberrypi4-iob                         -  enabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : raspberrypi4-iob                         -  enabled
      + system.adapter.telegram.0               : telegram              : raspberrypi4-iob                         -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : raspberrypi4-iob                         -  enabled
      + system.adapter.tr-064.0                 : tr-064                : raspberrypi4-iob                         -  enabled
      + system.adapter.trashschedule.0          : trashschedule         : raspberrypi4-iob                         -  enabled
       system.adapter.vis.0                    : vis                   : raspberrypi4-iob                         - disabled
      + system.adapter.volumio.0                : volumio               : raspberrypi4-iob                         -  enabled
      + system.adapter.web.0                    : web                   : raspberrypi4-iob                         -  enabled, port: 6032, bind: 0.0.0.0 (SSL), run as: admin
      + system.adapter.wled.0                   : wled                  : raspberrypi4-iob                         -  enabled
       system.adapter.worx.0                   : worx                  : raspberrypi4-iob                         - disabled
      + system.adapter.zigbee.0                 : zigbee                : raspberrypi4-iob                         -  enabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Instances
      Used repository: stable
      Adapter    "admin"        : 7.4.10   , installed 7.4.10
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "backitup"     : 3.0.31   , installed 3.0.31
      Adapter    "ble"          : 0.14.0   , installed 0.14.0
      Adapter    "daswetter"    : 3.2.2    , installed 3.1.15 [Updatable]
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "iot"          : 3.3.0    , installed 3.3.0
      Adapter    "iqontrol"     : 3.0.0    , installed 3.0.0
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "mihome-vacuum": 4.2.0    , installed 4.2.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "openweathermap": 1.1.2   , installed 1.1.2
      Adapter    "rpi2"         : 2.3.1    , installed 1.3.2  [Updatable]
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.0.0    , installed 4.0.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "volumio"      : 0.2.0    , installed 0.2.0
      Adapter    "wled"         : 0.7.2    , installed 0.7.2
      Adapter    "worx"         : 3.1.1    , installed 3.1.1
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "zigbee"       : 1.10.14  , installed 1.10.14
      Objects and States
      Objects:        12083
      States:         10918
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian stretch InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 963FA27710458545
      W: Failed to fetch https://repos.influxdata.com/debian/dists/stretch/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
      W: Some index files failed to download. They have been ignored, or old ones used instead.
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Get:3 https://repos.influxdata.com/debian stretch InRelease [12.9 kB]
      Get:4 https://packages.grafana.com/oss/deb stable InRelease [7661 B]
      Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      Err:3 https://repos.influxdata.com/debian stretch InRelease
      Err:4 https://packages.grafana.com/oss/deb stable InRelease
      Fetched 12.9 kB in 2s (8527 B/s)
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          3446135    31835/cupsd
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       125115     32448/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       125110     32448/iobroker.js-c
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       741193     2813/io.mqtt.0
      tcp        0      0 0.0.0.0:1884            0.0.0.0:*               LISTEN      1001       698309     21776/io.sonoff.1
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       741192     2813/io.mqtt.0
      tcp        0      0 0.0.0.0:5900            0.0.0.0:*               LISTEN      0          15767      580/vncserver-x11-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          15744      590/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        11814      566/influxd
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        16638      566/influxd
      tcp6       0      0 :::8087                 :::*                    LISTEN      1001       124790     513/io.simple-api.0
      tcp6       0      0 :::6032                 :::*                    LISTEN      1001       965306     9664/io.web.0
      tcp6       0      0 :::6030                 :::*                    LISTEN      1001       790240     18553/io.admin.0
      tcp6       0      0 :::5900                 :::*                    LISTEN      0          15766      580/vncserver-x11-c
      tcp6       0      0 :::22                   :::*                    LISTEN      0          15746      590/sshd: /usr/sbin
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          3446134    31835/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      115        16561      547/grafana-server
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          13290      499/dhcpcd
      udp        0      0 0.0.0.0:53421           0.0.0.0:*                           1001       126162     32601/io.mihome-vac
      udp        0      0 0.0.0.0:56186           0.0.0.0:*                           108        11686      425/avahi-daemon: r
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       128197     782/io.wled.0
      udp        0      0 192.168.178.80:5353     0.0.0.0:*                           1001       126562     32718/io.tr-064.0
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11684      425/avahi-daemon: r
      udp6       0      0 :::36846                :::*                                108        11687      425/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          16434      499/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        11685      425/avahi-daemon: r
      2025-02-18 12:12:44.623  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:12:45.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
      2025-02-18 12:12:45.538  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
      2025-02-18 12:12:47.720  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:12:48.888  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:02.402  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:04.448  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:05.713  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
      2025-02-18 12:13:07.632  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:08.730  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:15.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
      2025-02-18 12:13:22.227  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:24.286  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:25.907  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
      2025-02-18 12:13:27.392  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:28.487  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:41.848  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:43.927  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:45.382  - error: volumio.0 (681) Connection to Volumio host (192.168.178.34) failed: AxiosError: timeout of 1000ms exceeded
      2025-02-18 12:13:46.107  - warn: mihome-vacuum.0 (32601) State value to set for "mihome-vacuum.0.control.fan_power" has value "90" less than min "101"
      2025-02-18 12:13:46.558  - info: javascript.0 (16002) Stopping script script.js.common.Heizung_Winter_-10-0_Grad_24h_Probe
      2025-02-18 12:13:47.005  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 15(sonoff-1-5837/68:C6:3A:A3:36:CD) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:13:48.209  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 17(dlanwireless/BC:F2:AF:D2:50:77) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:14:01.674  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 4(PC-Markus/2C:41:38:A9:DC:8E) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
      2025-02-18 12:14:03.717  - info: tr-064.0 (32718) forEachConfiguredDevice: in GetSpecificHostEntry 9(dlanwireless/F4:06:8D:22:EA:27) device seems offline but we never saw it since adapter was started:Error: sendSOAPActionRequest Error action=GetSpecificHostEntry serviceType=urn:dslforum-org:service:Hosts:1: 500 - {"code":500}
        A Former User @arnold last edited by
        @arnold
        Ich schlage vor, bevor du an dem toten System (Debian Bullseye, wird nicht mehr supported) weiter arbeitest, nimm ne neue SD Karte, installier Debian Bookworm in der Lite-Version 64bit, dann installierst du die BS-Updates, Curl, dann eine Zeile fuer iobroker zum installieren, reboot, dann ein restore vom aktuellen Backup und du bist erstmal wieder save.
        Dann kann man auch nach weiteren Fehlern suchen, die vielleicht mitgeschleppt wurden, meistens sind die mit dem Update schon behoben.
        Iobroker haste ja relativ aktuell.
          arnold @Guest last edited by
          @ilovegym said in Adapter:
          Bookworm
          werde demnächst auf Bookworm umstellen (neu Installation )aber da ict noch Grafana und Influxdb
          da bekomme ich Fehler bei Telegram
          Backitup:
          Ihr Backup wurde nicht vollständig erstellt. Bitte überprüfen Sie die Fehler!!
          grafana: {"message":"Request failed with status code 500","name":"AxiosError","stack":"AxiosError: Request failed with status code 500\n    at settle (/opt/iobroker/node_modules/axios/lib/core/settle.js:19:12)\n    at IncomingMessage.handleStreamEnd (/opt/iobroker/node_modules/axios/lib/adapters/http.js:599:11)\n    at IncomingMessage.emit (node:events:530:35)\n    at IncomingMessage.emit (node:domain:489:12)\n    at endReadableNT (node:internal/streams/readable:1698:12)\n    at processTicksAndRejections (node:internal/process/task_queues:82:21)\n    at Axios.request (/opt/iobroker/node_modules/axios/lib/core/Axios.js:45:41)\n    at processTicksAndRejections (node:internal/process/task_queues:95:5)\n    at /opt/iobroker/node_modules/iobroker.backitup/lib/scripts/36-grafana.js:67:43","config":{"transitional":{"silentJSONParsing":true,"forcedJSONParsing":true,"clarifyTimeoutError":false},"adapter":["xhr","http","fetch"],"transformRequest":[null],"transformResponse":[null],"timeout":0,"xsrfCookieName":"XSRF-TOKEN","xsrfHeaderName":"X-XSRF-TOKEN","maxContentLength":-1,"maxBodyLength":-1,"env":{},"headers":{"Accept":"application/json, text/plain, */*","Authorization":"Bearer ****","User-Agent":"axios/1.7.9","Accept-Encoding":"gzip, compress, deflate, br"},"method":"get","url":"http://192.168.178.80:3000/api/search","responseType":"json","httpsAgent":{"_events":{},"_eventsCount":2,"_maxListeners":100,"defaultPort":443,"protocol":"https:","options":{"rejectUnauthorized":true,"noDelay":true,"path":null},"requests":{},"sockets":{},"freeSockets":{},"keepAliveMsecs":1000,"keepAlive":false,"maxSockets":null,"maxFreeSockets":256,"scheduling":"lifo","maxTotalSockets":null,"totalSocketCount":0,"maxCachedSessions":100,"_sessionCache":{"map":{},"list":[]}}},"code":"ERR_BAD_RESPONSE","status":500}
            A Former User @arnold last edited by A Former User
            @arnold
            ist Grafana und Influx etwa auch auf dem iobroker-Host installiert?
            Falls ja, dann mach davon auch ein backup und installier das auch neu. Wuerde ich aber aufm anderen Host installieren, alles auf einen, hat viele Nachteile..
            Edit:
            Grafana und Influx kannste auch ohne Backitup Adapter sichern, da musste du halt mal schauen, wo es klemmt.. oder nimm dafuer halt ein aelteres Backup, wo es noch funktioniert hat..
            • SMS
              SMS last edited by
              Hi
              bei mir werden die nichtinstallierten Adapter nicht angezeigt. Woran kann das liegen?
              Filter sind keine gesetzt.
              Danke!
                Thomas Braun Most Active @SMS last edited by
                @sms sagte in Adapter:
                Daran vermutlich:
                Filtern Sie die Adapter, um andere zu sehen. Es gibt 612 mehr
                Im Admin werden nicht mehr alle 600 angezeigt, ist zu viel Last.
                SMS 1 Reply Last reply Reply Quote 0
                • SMS
                  SMS @Thomas Braun last edited by
                  @thomas-braun Es werden aber nur meine 60 installierten Adapter angezeigt.
                    Thomas Braun Most Active @SMS last edited by Thomas Braun
                    @sms Richtig, es werden nur noch deine Adapter angezeigt, wenn du mehr als (ich glaube) 50 installiert hast. Wenn du weniger hast werden die ersten nicht installierten Adapter bis 50 noch angezeigt.
                    • SMS
                      @thomas-braun OK! In der Listenansicht sehe ich dann alle?
                        @sms
                        Keine Ahnung.
                        Ich schau eh immer hier:
                        https://download.iobroker.net/list.html
                        • SMS
                          @thomas-braun Danke!
                          81.1k
                          37
                          3406
