    4. System & Admin Upgrade "exited with code 25" Start-Schleife?
      adarof @wendy2702 last edited by
      @wendy2702
      iob stop war vorher, dann das hier:
      hmersch@RoofServer:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller
      npm warn skipping integrity check for git dependency ssh://git@github.com/theknut/ioBroker.waterkotte-easycon.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/nbuenger/ioBroker.govee.git
      npm warn skipping integrity check for git dependency ssh://git@github.com/eifel-tech/ioBroker.syrconnect.git
      npm warn deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
      npm warn deprecated @npmcli/move-file@1.1.2: This functionality has been moved to @npmcli/fs
      npm warn deprecated inflight@1.0.6: This module is not supported, and leaks memory. Do not use it. Check out lru-cache if you want a good and tested way to coalesce async requests by a key value, which is much more comprehensive and powerful.
      npm warn deprecated lodash.get@4.4.2: This package is deprecated. Use the optional chaining (?.) operator instead.
      npm warn deprecated npmlog@6.0.2: This package is no longer supported.
      npm warn deprecated har-validator@5.1.5: this library is no longer supported
      npm warn deprecated rimraf@3.0.2: Rimraf versions prior to v4 are no longer supported
      npm warn deprecated are-we-there-yet@3.0.1: This package is no longer supported.
      npm warn deprecated q@1.1.2: You or someone you depend on is using Q, the JavaScript Promise library that gave JavaScript developers strong feelings about promises. They can almost certainly migrate to the native JavaScript promise now. Thank you literally everyone for joining me in this bet against the odds. Be excellent to each other.
      npm warn deprecated
      npm warn deprecated (For a CapTP with native promises, see @endo/eventual-send and @endo/captp)
      npm warn deprecated glob@7.2.3: Glob versions prior to v9 are no longer supported
      npm warn deprecated glob@8.1.0: Glob versions prior to v9 are no longer supported
      npm warn deprecated querystring@0.2.1: The querystring API is considered Legacy. new code should use the URLSearchParams API instead.
      npm warn deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
      npm warn deprecated multer@1.4.5-lts.2: Multer 1.x is impacted by a number of vulnerabilities, which have been patched in 2.x. You should upgrade to the latest 2.x version.
      npm warn deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
      npm warn deprecated gauge@4.0.4: This package is no longer supported.
      npm warn deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
      npm warn deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
      npm warn deprecated node-domexception@1.0.0: Use your platform's native DOMException instead
      npm warn deprecated sinon@15.2.0: 16.1.1
      added 1 package, and changed 1484 packages in 2m
      180 packages are looking for funding
        run `npm fund` for details
      hmersch@RoofServer:/opt/iobroker$ iob fix
      library: loaded
      Library version=2024-10-22
          Welcome to the ioBroker installation fixer!
          Script version: 205-02-02
          You might need to enter your password a couple of times.
          Installing prerequisites (1/5)
      OK:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
      OK:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
      OK:3 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
      OK:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
      OK:5 https://deb.nodesource.com/node_20.x nodistro InRelease
      OK:6 https://gcups-static.greencell.global/deb stable InRelease
      Holen:7 https://dl.cloudsmith.io/public/tvheadend/tvheadend/deb/ubuntu focal InRelease [4.418 B]
      Es wurden 4.418 B in 1 s geholt (5.136 B/s).
      Paketlisten werden gelesen… Fertig
      N: Das Laden der konfigurierten Datei »main/binary-i386/Packages« wird übersprungen, da das Depot »https://deb.nodesource.com/node_20.x nodistro InRelease« die Architektur »i386« nicht unterstützt.
          Checking ioBroker user and directory permissions (2/5)
      Created /etc/sudoers.d/iobroker
      Fixing directory permissions...
          Check and cleanup npm temporary directories (3/5)
      Done.
          Database maintenance (4/5)
      Checking for uncompressed JSONL databases... This might take a while!
      Compressing /opt/iobroker/iobroker-data/states.jsonl
      Compressing /opt/iobroker/iobroker-data/objects.jsonl
      Compressed 2 JSONL files. Done
          Checking autostart (5/5)
      ==== AUTHENTICATING FOR org.freedesktop.systemd1.manage-units ===
      Legitimierung ist zum Stoppen von »iobroker.service« notwendig.
      Multiple identities can be used for authentication:
       1.  user,,, (user)
       2.  hmersch
       4.  iobroker
      Choose identity to authenticate as (1-4): 2
      Password:
      ==== AUTHENTICATION COMPLETE ===
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      hmersch@RoofServer:/opt/iobroker$ sudo -H -u iobroker npm install iobroker.js-controller^C
      hmersch@RoofServer:/opt/iobroker$ iob start
      hmersch@RoofServer:/opt/iobroker$ iob update
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.3  [Updatable]
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "amazon-dash"  : 1.2.0    , installed 1.2.0
      Adapter    "backitup"     : 3.2.2    , installed 3.0.31 [Updatable]
      Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
      Adapter    "device-watcher": 2.12.1  , installed 2.12.1
      Adapter    "easee"        : 1.0.10   , installed 1.0.10
      Adapter    "email"        : 2.0.4    , installed 2.0.3  [Updatable]
      Adapter    "evcc"         : 0.1.1    , installed 0.2.2
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "hm-rega"      : 5.1.0    , installed 5.1.0
      Adapter    "hm-rpc"       : 2.0.2    , installed 2.0.2
      Adapter    "homeconnect"  : 1.4.3    , installed 1.4.3
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "javascript"   : 8.8.3    , installed 8.8.3
      Controller "js-controller": 7.0.6    , installed 7.0.7
      Adapter    "klf200"       : 1.3.5    , installed 1.3.5
      Adapter    "lg-thinq"     : 1.1.0    , installed 1.1.0
      Adapter    "material"     : 1.3.1    , installed 1.3.1
      Adapter    "mielecloudservice": 6.5.10, installed 6.5.10
      Adapter    "mobile"       : 1.0.1    , installed 1.0.1
      Adapter    "modbus"       : 6.3.2    , installed 6.3.2
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "opendtu"      : 3.1.0    , installed 3.1.0
      Adapter    "parser"       : 2.2.4    , installed 2.2.4
      Adapter    "rickshaw"     : 1.0.0    , installed 1.0.0
      Adapter    "sbfspot"      : 4.4.2    , installed 4.4.2
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "statistics"   : 2.4.0    , installed 2.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "text2command" : 3.0.3    , installed 3.0.3
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "wiegand-tcpip": 0.4.6    , installed 0.4.7
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Qix- created this issue in visionmedia/debug
      closed ReDos Vulnerability Regression Visibility Notice #797
      mikeal created this issue in request/request
      open Request’s Past, Present and Future #3142
        adarof @adarof last edited by adarof
        Ich sehe da auch immer viele "error instance system.adapter.sonoff.0 terminated with code 7 (ADAPTER_ALREADY_RUNNING)" von unterschiedlichsten Adaptern.
        Als ob iobroker alle Adapter mehrfach startet - was dann ja zu den Zugriffsproblemen führen könnte
        Jedenfalls hat das npm install & fix & start & update keine Änderung gebracht
        A wendy2702 2 Replies Last reply Reply Quote 0
          Kann ich das Hochfahren irgendwie manuell machen - und könnte das helfen?
          So grob stell ich mir das vor:
          a) "iob start no-adapter"
          b) "iob start admin.0"
          c) ...via Webinterface von Admin danach der Reihe nach alle anderen Adapter starten.
          • wendy2702
            wendy2702 @adarof last edited by
            @adarof mal ne Frage, hast du den Rechner mal neu gestartet?
              @wendy2702 Ja, einmal nach dem Ubuntu Update und auch gerade bevor ich Deine Idee mit dem "npm install & iob stop & iob fix & iob start & iob update" gemacht habe
                Thomas Braun Most Active @adarof last edited by
                @adarof
                iob stop all
                  adarof @Thomas Braun last edited by adarof
                  @thomas-braun Danke, stopped das mehr als einfach "iob stop" ?
                  Nun ist es wieder kaputt gegangen:
                  hmersch@RoofServer:/opt/iobroker$ iob stop all
                  The adapter "admin.0" was stopped.
                  The adapter "history.0" was stopped.
                  The adapter "javascript.0" was stopped.
                  The adapter "email.0" was stopped.
                  The adapter "sql.0" was stopped.
                  The adapter "telegram.0" was stopped.
                  The adapter "tr-064.0" was stopped.
                  The adapter "hm-rpc.0" was stopped.
                  The adapter "hm-rpc.1" was stopped.
                  The adapter "hm-rega.0" was stopped.
                  The adapter "ical.0" was stopped.
                  The adapter "unifi.0" was stopped.
                  The adapter "backitup.0" was stopped.
                  The adapter "sonoff.0" was stopped.
                  The adapter "hm-rpc.2" was stopped.
                  The adapter "ping.0" was stopped.
                  The adapter "homeconnect.0" was stopped.
                  The adapter "mielecloudservice.0" was stopped.
                  The adapter "wiegand-tcpip.0" was stopped.
                  The adapter "nut.0" was stopped.
                  The adapter "alexa2.0" was stopped.
                  The adapter "modbus.0" was stopped.
                  The adapter "modbus.1" was stopped.
                  The adapter "tuya.0" was stopped.
                  The adapter "evcc.0" was stopped.
                  The adapter "lg-thinq.0" was stopped.
                  The adapter "opendtu.0" was stopped.
                  The adapter "device-watcher.0" was stopped.
                  The adapter "discovery.0" was stopped.
                  The adapter "web.0" was stopped.
                  The adapter "mobile.0" was stopped.
                  The adapter "vis.0" was stopped.
                  The adapter "dwd.0" was stopped.
                  The adapter "icons-material-png.0" was stopped.
                  The adapter "icons-mfd-svg.0" was stopped.
                  The adapter "vis-timeandweather.0" was stopped.
                  The adapter "vis-fancyswitch.0" was stopped.
                  The adapter "vis-hqwidgets.0" was stopped.
                  The adapter "vis-metro.0" was stopped.
                  The adapter "vis-colorpicker.0" was stopped.
                  The adapter "icons-mfd-png.0" was stopped.
                  The adapter "vis-jqui-mfd.0" was stopped.
                  The adapter "flot.0" was stopped.
                  The adapter "vis-history.0" was stopped.
                  The adapter "vis-bars.0" was stopped.
                  The adapter "icons-addictive-flavour-png.0" was stopped.
                  The adapter "text2command.0" was stopped.
                  The adapter "daswetter.0" was stopped.
                  The adapter "vis-canvas-gauges.0" was stopped.
                  The adapter "material.0" was stopped.
                  The adapter "nina.0" was stopped.
                  The adapter "vis-rgraph.0" was stopped.
                  The adapter "rickshaw.0" was stopped.
                  The adapter "simple-api.0" was stopped.
                  The adapter "govee.0" was stopped.
                  The adapter "easee.1" was stopped.
                  The adapter "parser.0" was stopped.
                  The adapter "vw-connect.0" was stopped.
                  The adapter "statistics.0" was stopped.
                  hmersch@RoofServer:/opt/iobroker$ iob stop all^C
                   Cannot determine Lua scripts strategy: Connection is closed. ["cfg.o.system.host.RoofServer"]
                  Uncaught Rejection: Error [ERR_MODULE_NOT_FOUND]: Cannot find module '/opt/iobroker/node_modules/@iobroker/db-objects-jsonl/build/esm/index.js' imported from /opt/iobroker/node_modules/@iobroker/js-controller-cli/build/esm/lib/setup/dbConnection.js
                      at finalizeResolution (node:internal/modules/esm/resolve:283:11)
                      at moduleResolve (node:internal/modules/esm/resolve:952:10)
                      at defaultResolve (node:internal/modules/esm/resolve:1188:11)
                      at ModuleLoader.defaultResolve (node:internal/modules/esm/loader:642:12)
                      at #cachedDefaultResolve (node:internal/modules/esm/loader:591:25)
                      at ModuleLoader.resolve (node:internal/modules/esm/loader:574:38)
                      at ModuleLoader.getModuleJobForImport (node:internal/modules/esm/loader:236:38)
                      at ModuleLoader.import (node:internal/modules/esm/loader:539:34)
                      at defaultImportModuleDynamicallyForModule (node:internal/modules/esm/utils:215:31)
                      at importModuleDynamicallyCallback (node:internal/modules/esm/utils:254:12)
                  node:internal/modules/cjs/loader:1215
                    throw err;
                  Error: Cannot find module '/opt/iobroker/node_modules/iobroker.js-controller/iobroker.js'
                      at Module._resolveFilename (node:internal/modules/cjs/loader:1212:15)
                      at Module._load (node:internal/modules/cjs/loader:1043:27)
                      at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:164:12)
                      at node:internal/main/run_main_module:28:49 {
                    code: 'MODULE_NOT_FOUND',
                    requireStack: []
                  Node.js v20.19.2
                    throw err;
                    requireStack: []
                  Node.js v20.19.2
                    und ... ein paar sekunden später:
                    hmersch@RoofServer:/opt/iobroker$ iob status
                    Objects type: jsonl
                    States  type: jsonl
                    okay, davon kann ich dann "iob start admin.0" machen... oder auch nicht:
                    hmersch@RoofServer:/opt/iobroker$ iob start admin.0
                      throw err;
                      requireStack: []
                    nun ist es wieder kaputt und ich müsste mit "npm install .." loslegen?
                    Irgendwas ist da doch ganz ganz merkwürdig
                    Da läuft auch noch jede Menge bzw wird gestartet:
                    hmersch@RoofServer:/opt/iobroker$ ps aux |grep iobroker
                    iobroker   16132 76.8  3.3 11995472 543668 ?     Rsl  21:16   0:40 iobroker.js-controller
                    iobroker   16218 13.5  0.6 11741200 100672 ?     Sl   21:16   0:03 io.telegram.0
                    iobroker   16265 34.5  2.1 12091024 356848 ?     Sl   21:16   0:05 io.admin.0
                    iobroker   16287 16.5  0.6 11565564 103964 ?     Sl   21:16   0:01 io.history.0
                    iobroker   16331 41.2  0.6 11561820 102412 ?     Sl   21:17   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.ical/main.js --instance 0 --loglevel info
                    iobroker   16342  113  0.9 11603300 156264 ?     Rl   21:17   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/main.js --instance 0 --loglevel info
                    iobroker   16349 94.0  0.5 11559260 93536 ?      Rl   21:17   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.unifi/main.js --instance 0 --loglevel warn
                    iobroker   16358  136  0.5 11538412 85436 ?      Rl   21:17   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.email/build/main.js --instance 0 --loglevel info
                    hmersch    16380  0.0  0.0   9608  2428 pts/0    S+   21:17   0:00 grep --color=auto iobroker
                    Wer startet denn da noch was?
                    Gibt es unterschiedliche Wege, wie der iobroker Prozess gestartet wird und ich gehe beide wenn ich hier "iob start" macht?
                    Nach einem erneuten "iob stop all":
                    iobroker   16941 34.7  5.1 2045780 834000 ?      Rl   21:19   0:43 npm install @iobroker-javascript.0/klf-200-api@npm:klf-200-api@latest
                    hmersch    17589  0.0  0.0   9608  2348 pts/0    S+   21:21   0:00 grep --color=auto iobroker
                    ...und dann wird neu gestartet. Das "iob stop all" scheint bei mir also nicht zu stoppen sondern zu restarten.
                    Kann sich das jemand erklären?
                    wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                    • wendy2702
                      wendy2702 @adarof last edited by wendy2702
                      @adarof bei sauberer Installation bedeutet ein
                      iob stop
                      Das alles gestoppt wird.
                      Wenn du den stoppst, schaust das alle Prozesse beendet sind, dann den Rechner mal neu startest und mal direkt das log anschaust.
                      Edit: sieht fast so aus als wenn er die Adapter teilweise neu installiert. Vielleicht bist du auch nur zu ungeduldig
                      A 2 Replies Last reply Reply Quote 0
                        @adarof
                        systemctl stop iobroker.service
                          @wendy2702
                          hmersch@RoofServer:/opt/iobroker$ ps aux|grep iob
                          hmersch    18154  0.0  0.0   9476  2396 pts/0    S+   21:23   0:00 grep --color=auto iob
                          hmersch    18156  0.0  0.0   9476  2352 pts/0    S+   21:23   0:00 grep --color=auto iob
                          ... und nen reboot ...
                          hmersch@RoofServer:~$ ps aux|grep iob
                          iobroker    1429 77.2  3.4 12123260 557232 ?     Rsl  21:24   0:26 iobroker.js-controller
                          iobroker    2315 30.0  2.1 12082912 345432 ?     Rl   21:25   0:06 io.admin.0
                          iobroker    2362 14.5  0.6 11565428 106084 ?     Sl   21:25   0:02 io.history.0
                          iobroker    2540 37.5  1.0 11608208 164672 ?     Sl   21:25   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.javascript/main.js --instance 0 --loglevel info
                          iobroker    2548 28.7  0.6 11560052 97652 ?      Sl   21:25   0:02 /usr/bin/node /opt/iobroker/node_modules/iobroker.email/build/main.js --instance 0 --loglevel info
                          iobroker    2563 48.5  0.5 11562508 96880 ?      Sl   21:25   0:01 /usr/bin/node /opt/iobroker/node_modules/iobroker.sql/main.js --instance 0 --loglevel info
                          iobroker    2601  0.0  0.0      0     0 ?        Z    21:25   0:00 [sh] <defunct>
                          hmersch     2605  0.0  0.0   9608  2216 pts/0    R+   21:25   0:00 grep --color=auto iob
                          ... danach warten bis zum "absturz" und "iob logs"
                          Hm:
                          2025-05-27 21:27:41.438  - error: host.RoofServer Error: Could not determine controller directory
                              at getControllerDir (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:1833:11)
                              at Module.getPidsFileName (file:///opt/iobroker/node_modules/@iobroker/js-controller-common-db/build/esm/lib/common/tools.js:3368:22)
                              at Timeout._onTimeout (file:///opt/iobroker/node_modules/iobroker.js-controller/build/esm/main.js:2871:91)
                              at listOnTimeout (node:internal/timers:581:17)
                              at processTimers (node:internal/timers:519:7)
                            @thomas-braun Ah, danke - logisch, ja! Kommt sich das in die Quere mit "iob start" - also werden dann 2 Instanzen auf /opt/iobroker gestartet? Kann ich vielleicht den iobroker.service falsch eingerichtet haben?
                            Aber auch wenn ich "systemctl stop iobroker.service" mache und danach "manuell" via "iob start" kommt es zum "Absturz" - und dabei sind immernoch "ADAPTER_ALREADY_RUNNING"-Meldungen im Log.
                            Irgendwas läuft da einfach doppelt
                              @wendy2702 Okay - vielleicht ... lass ich ihn dann mal über Nacht sich erholen. Mir fehlen gerade etwas auch die Ideen bzw das Hintergrundwissen um da bei fehlerhaften Verzeichniszugriffen, die aber eigentlich / kurz später da sind noch eine Idee zu haben.
                              Würde mich morgen melden und hoffen, dass Ihr weitere Ideen habt.
                              Dank Euch für heute abend
                                Faszinierenderweise hat es noch 2 mal Neugestartet und seit dem läuft es.
                                Bin nun ein paar Tage unterwegs und werde danach das Neustartverhalten dann nochmal eingehender untersuchen.
                                Ob das dann noch was mit dem System- und/oder Admin Upgrade zu tun hat ... werden wir später sehen
                                Danke Euch erstmal
                                  Ich habe nun beim Upgrade vom Javascript etwas genauer hingeschaut.
                                  $ iobroker upgrade javascript@8.9.2
                                  Update javascript from @8.8.3 to @8.9.2
                                  NPM version: 10.8.2
                                  Installing iobroker.javascript@8.9.2... (System call)
                                  changed 1525 packages in 3m194
                                  Ist das "normal", dass beim Updaten eines Adapters 1524 pakete geändert wurden und es dann halt auch entsprechend lange dauert?
                                  Gruss -
                                  Thomas Braun A 2 Replies Last reply Reply Quote 0
                                    Thomas Braun Most Active @adarof last edited by Thomas Braun
                                    @adarof
                                    Ja, ist möglich.
                                    Die Anzahl hat auch nicht unbedingt direkt mit dem fraglichen Adapter zu tun, npm schaut über den kompletten Baum nach erforderlichen Updates und Anpassungen.
                                    Meine Kiste:
                                    chad@chet:~ $ iobroker upgrade javascript@8.9.2
                                    BE CAREFUL: THIS IS A MAJOR DOWNGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                    Would you like to downgrade javascript from @9.0.2 to @8.9.2 now? [(y)es, (n)o]: y
                                    Update javascript from @9.0.2 to @8.9.2
                                    NPM version: 11.3.0
                                    added 17 packages, removed 1 package, and changed 1 package in 12s
                                      Danke - Hab nun nen 2. Adapter geupdated (eMail), da passierte auch nur 1 Paket.
                                        Ich muss das Thema leider nochmal aufnehmen.
                                        iobroker startet wieder nicht mehr bzw befindet sich in einer Start-Schleife
                                        Ich habe einen Adapter gelöscht, was dazu führte, dass es losging.
                                        Wieder scheint er "in er Runde" zu laufen - immer mal wieder zu starten. "iob logs" scheint auch erstmal erfolgreich hochzulaufen.
                                        1-2 Minuten später kommen dann viele "ADAPTER_ALREADY_RUNNING" Meldungen und der Admin ist wieder weg.
                                        Dabei sehe ich auch immer wieder Fehler von node, was Module nicht findet beim Aufruf von z.B. "iob logs" - und ne Sekunde später tut es wieder.
                                        Nach dem Boot tut es wieder erst wieder. Die Diagnose unten sieht auch gut aus - aber nach wenigen Minuten (bevor alles grün ist in den INstanzen) geht es wieder los und er startet neu.
                                        Wo könnte ich ansetzen?
                                        Ich vermute, dass es irgendwas mit dem Starten vom iob zu tun hat, was ich via "systemctl iobroker.service" starte.
                                        Kann es sein, dass mein starten per systemctl nicht der richtige Weg ist und sich "beisst" mit dem "eigenen neustarten" durch das Adapter-Entfernen?
                                        Gibt es eine Doku, wie ich den iobroker beim Booten starten sollte? Vielleicht habe ich da eine Altlast ...
                                        Gruss -
                                        Script v.2025-08-09
                                        *** BASE SYSTEM ***
                                        Operating System: Ubuntu 22.04.5 LTS
                                         Static hostname: RoofServer
                                               Icon name: computer-desktop
                                                 Chassis: desktop
                                                  Kernel: Linux 5.15.0-157-generic
                                            Architecture: x86-64
                                        OS is similar to: debian
                                        model name      : Intel(R) Core(TM) i3-5010U CPU @ 2.10GHz
                                        Docker          : false
                                        Virtualization  : none
                                        Kernel          : x86_64
                                        Userland        : 64 bit
                                        Systemuptime and Load:
                                         23:18:47 up 7 min,  1 user,  load average: 2.74, 2.92, 1.55
                                        CPU threads: 4
                                        *** LIFE CYCLE STATUS ***
                                        Operating System codenamed 'jammy' is an aging Ubuntu release! Please upgrade to the latest LTS release 'noble' in due time!
                                        *** TIME AND TIMEZONES ***
                                                       Local time: Mon 2025-10-06 23:18:47 CEST
                                                   Universal time: Mon 2025-10-06 21:18:47 UTC
                                                         RTC time: Mon 2025-10-06 21:18:48
                                                      NTP service: active
                                                  RTC in local TZ: no
                                        *** Users and Groups ***
                                        User that called 'iob diag':
                                        hmersch
                                        DERBY_HOME=/usr/lib/jvm/java-8-oracle/db
                                        JAVA_HOME=/usr/lib/jvm/java-8-oracle
                                        HOME=/home/hmersch
                                        GROUPS=hmersch dialout sudo sambashare user iobroker
                                        iobroker
                                        HOME=/home/iobroker
                                        GROUPS=iobroker tty dialout sudo audio video plugdev bluetooth
                                        *** DISPLAY-SERVER SETUP ***
                                        Display-Server:         false
                                        Display-Manager:        * gdm.service - GNOME Display Manager
                                        Desktop:
                                        Session:                tty
                                        *** MEMORY ***
                                        Mem:             15G        2.3G         10G        6.0M        3.1G         13G
                                        Swap:           2.0G          0B        2.0G
                                        Total:           17G        2.3G         12G
                                        Active iob-Instances:   8
                                                15875 M total memory
                                                 2337 M used memory
                                                 1408 M active memory
                                                 3644 M inactive memory
                                                10435 M free memory
                                                  354 M buffer memory
                                                 2748 M swap cache
                                                 2047 M total swap
                                                    0 M used swap
                                                 2047 M free swap
                                        top - 23:18:48 up 7 min,  1 user,  load average: 2.74, 2.92, 1.55
                                        Tasks: 214 total,   2 running, 212 sleeping,   0 stopped,   0 zombie
                                        %Cpu(s): 26.6 us,  6.2 sy,  0.0 ni, 67.2 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                        MiB Mem :  15875.2 total,  10432.4 free,   2340.2 used,   3102.5 buff/cache
                                        MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  13204.5 avail Mem
                                        *** FAILED SERVICES ***
                                          UNIT                 LOAD   ACTIVE SUB    DESCRIPTION
                                        * vncserver@1.service  loaded failed failed Remote desktop service (VNC)
                                        * wg-quick@VPN.service loaded failed failed WireGuard via wg-quick(8) for VPN
                                        LOAD   = Reflects whether the unit definition was properly loaded.
                                        ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
                                        SUB    = The low-level unit activation state, values depend on unit type.
                                        2 loaded units listed.
                                        *** DMESG CRITICAL ERRORS ***
                                        No critical errors detected
                                        *** FILESYSTEM ***
                                        Filesystem     Type     Size  Used Avail Use% Mounted on
                                        tmpfs          tmpfs    1.6G  3.4M  1.6G   1% /run
                                        /dev/sdb1      ext4     458G   66G  369G  16% /
                                        tmpfs          tmpfs    7.8G  616K  7.8G   1% /dev/shm
                                        tmpfs          tmpfs    5.0M  4.0K  5.0M   1% /run/lock
                                        /dev/sda1      fuseblk  466G  401G   65G  87% /media/data
                                        /dev/sdc1      ext4     4.6T  4.0T  308G  93% /media/storage
                                        tmpfs          tmpfs    1.6G   96K  1.6G   1% /run/user/999
                                        tmpfs          tmpfs    1.6G  100K  1.6G   1% /run/user/1002
                                        [Mon Oct  6 23:11:48 2025] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        [Mon Oct  6 23:11:48 2025] EXT4-fs (sdb1): re-mounted. Opts: errors=remount-ro. Quota mode: none.
                                        [Mon Oct  6 23:11:51 2025] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
                                        Show mounted filesystems:
                                        TARGET                           SOURCE      FSTYPE   OPTIONS
                                        /                                /dev/sdb1   ext4     rw,relatime,errors=remount-ro
                                        |-/snap/core/17247               /dev/loop0  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core18/2947              /dev/loop1  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core18/2952              /dev/loop2  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/bare/5                   /dev/loop3  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core/17212               /dev/loop4  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core20/2599              /dev/loop5  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core22/2111              /dev/loop7  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core20/2669              /dev/loop6  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core24/1196              /dev/loop10 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core24/1151              /dev/loop9  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/core22/2133              /dev/loop8  squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-26-1604/104      /dev/loop11 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-26-1604/111      /dev/loop12 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-28-1804/194      /dev/loop13 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-28-1804/198      /dev/loop14 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-34-1804/93       /dev/loop17 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-38-2004/140      /dev/loop16 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-38-2004/143      /dev/loop18 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-42-2204/202        /dev/loop19 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-42-2204/226        /dev/loop20 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-3-34-1804/90       /dev/loop15 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-46-2404/117        /dev/loop21 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-46-2404/125        /dev/loop22 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-system-monitor/186 /dev/loop24 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gnome-system-monitor/193 /dev/loop23 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gtk-common-themes/1535   /dev/loop26 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/snapd/24792              /dev/loop29 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/mesa-2404/887            /dev/loop27 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/gtk-common-themes/1534   /dev/loop25 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/snapd/25202              /dev/loop30 squashfs ro,nodev,relatime,errors=continue
                                        |-/snap/mesa-2404/912            /dev/loop28 squashfs ro,nodev,relatime,errors=continue
                                        |-/media/data                    /dev/sda1   fuseblk  rw,relatime,user_id=0,group_id=0,allow_other,blksize=4096
                                        `-/media/storage                 /dev/sdc1   ext4     rw,nosuid,nodev,relatime
                                        /var:
                                        27G     /var/
                                        22G     /var/lib
                                        6.2G    /var/lib/mysql
                                        6.1G    /var/lib/snapd
                                        6.0G    /var/lib/unifi
                                        Archived and active journals take up 120.0M in the file system.
                                        /opt/iobroker/backups:
                                        2.5G    /opt/iobroker/backups/
                                        4.0K    /opt/iobroker/backups/redistmp
                                        /opt/iobroker/iobroker-data:
                                        824M    /opt/iobroker/iobroker-data/
                                        356M    /opt/iobroker/iobroker-data/files
                                        230M    /opt/iobroker/iobroker-data/backup-objects
                                        55M     /opt/iobroker/iobroker-data/files/material
                                        53M     /opt/iobroker/iobroker-data/files/material/static
                                        97M     /opt/iobroker/iobroker-data/states.jsonl
                                        63M     /opt/iobroker/iobroker-data/objects.jsonl
                                        41M     /opt/iobroker/iobroker-data/files/material/static/js/main.c5478f66.js.map
                                        28M     /opt/iobroker/iobroker-data/sqlite/sqlite.db
                                        24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                                        USB-Devices by-id:
                                        No Devices found 'by-id'
                                        *** ZigBee Settings ***
                                        Zigbee Network Settings on your coordinator/in nvbackup are:
                                        zigbee.X
                                        Extended Pan ID:
                                        *** MASKED ***
                                        Pan ID:
                                        *** MASKED ***
                                        Channel:
                                        *** MASKED ***
                                        Network Key:
                                        *** MASKED ***
                                        To unmask the settings run 'iob diag --unmask'
                                        *** NodeJS-Installation ***
                                        /usr/bin/nodejs         v20.19.5
                                        /usr/bin/node           v20.19.5
                                        /usr/bin/npm            10.8.2
                                        /usr/bin/npx            10.8.2
                                        /usr/bin/corepack       0.33.0
                                        nodejs:
                                          Installed: 20.19.5-1nodesource1
                                          Candidate: 20.19.5-1nodesource1
                                          Version table:
                                         *** 20.19.5-1nodesource1 1001
                                                500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
                                                100 /var/lib/dpkg/status
                                             20.19.4-1nodesource1 1001
                                             20.19.3-1nodesource1 1001
                                             20.19.2-1nodesource1 1001
                                             20.19.1-1nodesource1 1001
                                             20.19.0-1nodesource1 1001
                                             20.18.3-1nodesource1 1001
                                             20.18.2-1nodesource1 1001
                                             20.18.1-1nodesource1 1001
                                             20.18.0-1nodesource1 1001
                                             20.17.0-1nodesource1 1001
                                             20.16.0-1nodesource1 1001
                                             20.15.1-1nodesource1 1001
                                             20.15.0-1nodesource1 1001
                                             20.14.0-1nodesource1 1001
                                             20.13.1-1nodesource1 1001
                                             20.13.0-1nodesource1 1001
                                             20.12.2-1nodesource1 1001
                                             20.12.1-1nodesource1 1001
                                             20.12.0-1nodesource1 1001
                                             20.11.1-1nodesource1 1001
                                             20.11.0-1nodesource1 1001
                                             20.10.0-1nodesource1 1001
                                             20.9.0-1nodesource1 1001
                                             20.8.1-1nodesource1 1001
                                             20.8.0-1nodesource1 1001
                                             20.7.0-1nodesource1 1001
                                             20.6.1-1nodesource1 1001
                                             20.6.0-1nodesource1 1001
                                             20.5.1-1nodesource1 1001
                                             20.5.0-1nodesource1 1001
                                             20.4.0-1nodesource1 1001
                                             20.3.1-1nodesource1 1001
                                             20.3.0-1nodesource1 1001
                                             20.2.0-1nodesource1 1001
                                             20.1.0-1nodesource1 1001
                                             20.0.0-1nodesource1 1001
                                             12.22.9~dfsg-1ubuntu3.6 500
                                                500 http://de.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 Packages
                                                500 http://security.ubuntu.com/ubuntu jammy-security/universe amd64 Packages
                                             12.22.9~dfsg-1ubuntu3 500
                                                500 http://de.archive.ubuntu.com/ubuntu jammy/universe amd64 Packages
                                        No problems detected
                                        Errors in npm tree: 0
                                        Checking for nodejs vulnerability:
                                        *** ioBroker-Installation ***
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        Hosts:
                                        RoofServer          RoofServer (version: 7.0.7, hostname: RoofServer    , alive, uptime: 50)
                                        Core adapters versions
                                        js-controller:  7.0.7
                                        admin:          7.7.2
                                        javascript:     8.9.2
                                        nodejs modules from github:     1
                                        |   `-- xmlbuilder@0.4.2 invalid: "https://github.com/hobbyquaker/xmlbuilder-js/tarball/29fe5030dc6852007dc8d1bfd5109d75f8da58d5" from node_modules/homematic-xmlrpc
                                        Adapter State
                                          system.adapter.admin.0                  : admin                 : RoofServer                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                          system.adapter.alexa2.0                 : alexa2                : RoofServer                               -  enabled
                                        + system.adapter.backitup.0               : backitup              : RoofServer                               -  enabled
                                          system.adapter.daswetter.0              : daswetter             : RoofServer                               -  enabled
                                          system.adapter.device-watcher.0         : device-watcher        : RoofServer                               -  enabled
                                          system.adapter.discovery.0              : discovery             : RoofServer                               -  enabled
                                          system.adapter.dwd.0                    : dwd                   : RoofServer                               -  enabled
                                          system.adapter.easee.1                  : easee                 : RoofServer                               -  enabled
                                          system.adapter.email.0                  : email                 : RoofServer                               -  enabled
                                          system.adapter.evcc.0                   : evcc                  : RoofServer                               -  enabled, port: 7070
                                          system.adapter.flot.0                   : flot                  : RoofServer                               -  enabled
                                          system.adapter.govee.0                  : govee                 : RoofServer                               -  enabled
                                        + system.adapter.ham.0                    : ham                   : RoofServer                               -  enabled
                                          system.adapter.history.0                : history               : RoofServer                               -  enabled
                                        + system.adapter.hm-rega.0                : hm-rega               : RoofServer                               -  enabled
                                        + system.adapter.hm-rpc.0                 : hm-rpc                : RoofServer                               -  enabled, port: 18701
                                        + system.adapter.hm-rpc.1                 : hm-rpc                : RoofServer                               -  enabled, port: 12001
                                          system.adapter.hm-rpc.2                 : hm-rpc                : RoofServer                               -  enabled, port: 0
                                          system.adapter.homeconnect.0            : homeconnect           : RoofServer                               -  enabled
                                          system.adapter.ical.0                   : ical                  : RoofServer                               -  enabled
                                          system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: RoofServer                               -  enabled
                                          system.adapter.icons-material-png.0     : icons-material-png    : RoofServer                               -  enabled
                                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : RoofServer                               -  enabled
                                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : RoofServer                               -  enabled
                                          system.adapter.javascript.0             : javascript            : RoofServer                               -  enabled
                                          system.adapter.klf200.0                 : klf200                : RoofServer                               -  enabled
                                        + system.adapter.lg-thinq.0               : lg-thinq              : RoofServer                               -  enabled
                                          system.adapter.material.0               : material              : RoofServer                               -  enabled
                                          system.adapter.matter.0                 : matter                : RoofServer                               -  enabled
                                          system.adapter.mielecloudservice.0      : mielecloudservice     : RoofServer                               -  enabled
                                          system.adapter.mobile.0                 : mobile                : RoofServer                               -  enabled
                                          system.adapter.modbus.0                 : modbus                : RoofServer                               -  enabled
                                          system.adapter.modbus.1                 : modbus                : RoofServer                               -  enabled
                                          system.adapter.modbus.2                 : modbus                : RoofServer                               -  enabled
                                          system.adapter.nina.0                   : nina                  : RoofServer                               -  enabled
                                          system.adapter.nut.0                    : nut                   : RoofServer                               -  enabled
                                          system.adapter.opendtu.0                : opendtu               : RoofServer                               -  enabled
                                          system.adapter.parser.0                 : parser                : RoofServer                               -  enabled
                                          system.adapter.ping.0                   : ping                  : RoofServer                               -  enabled
                                          system.adapter.pvforecast.0             : pvforecast            : RoofServer                               -  enabled
                                          system.adapter.rickshaw.0               : rickshaw              : RoofServer                               -  enabled
                                          system.adapter.simple-api.0             : simple-api            : RoofServer                               -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
                                          system.adapter.sonoff.0                 : sonoff                : RoofServer                               -  enabled, port: 1883, bind: 192.168.66.75
                                          system.adapter.sql.0                    : sql                   : RoofServer                               -  enabled, port: 0
                                          system.adapter.statistics.0             : statistics            : RoofServer                               -  enabled
                                          system.adapter.telegram-menu.0          : telegram-menu         : RoofServer                               -  enabled
                                          system.adapter.telegram.0               : telegram              : RoofServer                               -  enabled, port: 8443, bind: 0.0.0.0
                                          system.adapter.text2command.0           : text2command          : RoofServer                               - disabled
                                        + system.adapter.tr-064.0                 : tr-064                : RoofServer                               -  enabled
                                          system.adapter.tuya.0                   : tuya                  : RoofServer                               -  enabled
                                          system.adapter.unifi.0                  : unifi                 : RoofServer                               -  enabled
                                          system.adapter.vis-bars.0               : vis-bars              : RoofServer                               -  enabled
                                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : RoofServer                               -  enabled
                                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : RoofServer                               -  enabled
                                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : RoofServer                               -  enabled
                                          system.adapter.vis-history.0            : vis-history           : RoofServer                               -  enabled
                                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : RoofServer                               -  enabled
                                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : RoofServer                               -  enabled
                                          system.adapter.vis-metro.0              : vis-metro             : RoofServer                               -  enabled
                                          system.adapter.vis-rgraph.0             : vis-rgraph            : RoofServer                               -  enabled
                                          system.adapter.vis-timeandweather.0     : vis-timeandweather    : RoofServer                               -  enabled
                                          system.adapter.vis.0                    : vis                   : RoofServer                               -  enabled
                                          system.adapter.vw-connect.0             : vw-connect            : RoofServer                               -  enabled
                                          system.adapter.web.0                    : web                   : RoofServer                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                          system.adapter.wiegand-tcpip.0          : wiegand-tcpip         : RoofServer                               -  enabled, port: 60000, bind: 192.168.66.75
                                        + instance is alive
                                        ioBroker-Repositories
                                        │ (index) │ name      │ url        │ auto upgrade │
                                        │ 0       │ 'sources' │ 'conf/sources-dist.json'        │ false        │
                                        │ 1       │ 'online'  │ 'https://raw.githubusercontent.com/ioBroker/ioBroker.repositories/master/sources-dist.json' │ false        │
                                        │ 2       │ 'stable'  │ 'http://download.iobroker.net/sources-dist.json'                                            │ false        │
                                        │ 3       │ 'beta'    │ 'http://download.iobroker.net/sources-dist-latest.json'                                     │ false        │
                                        Active repo(s): stable
                                        Upgrade policy: none
                                        Installed ioBroker-Adapters
                                        Adapter    "admin"        : 7.7.2    , installed 7.7.2
                                        Adapter    "alexa2"       : 3.27.3   , installed 3.27.3
                                        Adapter    "backitup"     : 3.3.5    , installed 3.3.5
                                        Adapter    "device-watcher": 2.13.1  , installed 2.13.1
                                        Adapter    "email"        : 2.0.4    , installed 2.0.4
                                        Adapter    "evcc"         : 0.2.3    , installed 0.2.3
                                        Adapter    "ical"         : 1.17.0   , installed 1.17.0
                                        Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                        Controller "js-controller": 7.0.7    , installed 7.0.7
                                        Adapter    "lg-thinq"     : 1.1.2    , installed 1.1.2
                                        Adapter    "matter"       : 0.5.2    , installed 0.5.2
                                        Adapter    "pvforecast"   : 5.0.0    , installed 5.0.0
                                        Adapter    "sonoff"       : 3.2.1    , installed 3.2.1
                                        Adapter    "telegram-menu": 2.4.4    , installed 2.4.4
                                        Objects and States
                                        Objects:        56519
                                        States:         48038
                                        Hit:1 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                        Hit:2 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                                        Get:3 https://dl.cloudsmith.io/public/tvheadend/tvheadend/deb/ubuntu focal InRelease [11.0 kB]
                                        Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                                        Hit:5 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                                        Get:6 https://dl.evcc.io/public/evcc/stable/deb/ubuntu jammy InRelease
                                        Hit:7 https://deb.nodesource.com/node_20.x nodistro InRelease
                                        Hit:8 https://ppa.launchpadcontent.net/deadsnakes/ppa/ubuntu jammy InRelease
                                        Hit:9 https://gcups-static.greencell.global/deb stable InRelease
                                        Fetched 22.6 kB in 1s (15.8 kB/s)
                                        Reading package lists...
                                        Pending Updates: 0
                                        *** Listening Ports ***
                                        tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       52337      5865/io.hm-rpc.1
                                        tcp        0      0 0.0.0.0:59905           0.0.0.0:*               LISTEN      0          31120      1834/rpc.mountd
                                        tcp        0      0 0.0.0.0:2049            0.0.0.0:*               LISTEN      0          32072      -
                                        tcp        0      0 127.0.0.1:53            0.0.0.0:*               LISTEN      999        33966      2228/pihole-FTL
                                        tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      101        26953      1120/systemd-resolv
                                        tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       50601      5843/io.hm-rpc.0
                                        tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      124        32769      1564/mysqld
                                        tcp        0      0 0.0.0.0:9981            0.0.0.0:*               LISTEN      0          28331      1856/tvheadend
                                        tcp        0      0 0.0.0.0:9982            0.0.0.0:*               LISTEN      0          28334      1856/tvheadend
                                        tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       49857      5752/io.hm-rpc.2
                                        tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      124        28292      1564/mysqld
                                        tcp        0      0 127.0.0.1:3493          0.0.0.0:*               LISTEN      0          28276      1711/upsd
                                        tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          28038      1435/cupsd
                                        tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       44990      5116/iobroker.js-co
                                        tcp        0      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       44993      5116/iobroker.js-co
                                        tcp        0      0 127.0.0.1:35747         0.0.0.0:*               LISTEN      0          28141      1454/containerd
                                        tcp        0      0 0.0.0.0:993             0.0.0.0:*               LISTEN      0          32248      1767/dovecot
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          30737      1517/sshd: /usr/sbi
                                        tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          31631      2204/lighttpd
                                        tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          14822      1/init
                                        tcp        0      0 0.0.0.0:143             0.0.0.0:*               LISTEN      0          32246      1767/dovecot
                                        tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN      0          31538      2176/smbd
                                        tcp        0      0 127.0.0.1:27117         0.0.0.0:*               LISTEN      126        34043      2263/bin/mongod
                                        tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN      0          31537      2176/smbd
                                        tcp        0      0 0.0.0.0:57815           0.0.0.0:*               LISTEN      128        31079      1810/rpc.statd
                                        tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      125        28072      1438/mongod
                                        tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        33977      2228/pihole-FTL
                                        tcp        0      0 192.168.66.75:9983      0.0.0.0:*               LISTEN      0          32917      1856/tvheadend
                                        tcp        0      0 0.0.0.0:46345           0.0.0.0:*               LISTEN      0          31060      1834/rpc.mountd
                                        tcp        0      0 192.168.66.75:1883      0.0.0.0:*               LISTEN      1001       49529      5712/io.sonoff.0
                                        tcp        0      0 0.0.0.0:46585           0.0.0.0:*               LISTEN      0          32106      -
                                        tcp        0      0 0.0.0.0:45669           0.0.0.0:*               LISTEN      0          31097      1834/rpc.mountd
                                        tcp        0      0 192.168.66.75:53        0.0.0.0:*               LISTEN      999        33964      2228/pihole-FTL
                                        tcp6       0      0 fd16:f83a:ca:76b2:8e:53 :::*                    LISTEN      999        35842      2228/pihole-FTL
                                        tcp6       0      0 :::44039                :::*                    LISTEN      0          31127      1834/rpc.mountd
                                        tcp6       0      0 :::3389                 :::*                    LISTEN      127        31783      1542/xrdp
                                        tcp6       0      0 :::51825                :::*                    LISTEN      0          31114      1834/rpc.mountd
                                        tcp6       0      0 fe80::ee2c:259e:69f8:53 :::*                    LISTEN      999        33970      2228/pihole-FTL
                                        tcp6       0      0 :::2049                 :::*                    LISTEN      0          32094      -
                                        tcp6       0      0 fd16:f83a:ca:76b2:a0:53 :::*                    LISTEN      999        35084      2228/pihole-FTL
                                        tcp6       0      0 ::1:4711                :::*                    LISTEN      999        32527      2228/pihole-FTL
                                        tcp6       0      0 :::8754                 :::*                    LISTEN      997        33911      1992/fr24feed
                                        tcp6       0      0 :::631                  :::*                    LISTEN      0          28039      1435/cupsd
                                        tcp6       0      0 :::8843                 :::*                    LISTEN      126        36292      1557/java
                                        tcp6       0      0 :::8880                 :::*                    LISTEN      126        36919      1557/java
                                        tcp6       0      0 fd16:f83a:ca:76b2:45:53 :::*                    LISTEN      999        35040      2228/pihole-FTL
                                        tcp6       0      0 :::993                  :::*                    LISTEN      0          32249      1767/dovecot
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          30739      1517/sshd: /usr/sbi
                                        tcp6       0      0 :::80                   :::*                    LISTEN      0          31630      2204/lighttpd
                                        tcp6       0      0 :::111                  :::*                    LISTEN      0          18915      1/init
                                        tcp6       0      0 :::143                  :::*                    LISTEN      0          32247      1767/dovecot
                                        tcp6       0      0 :::139                  :::*                    LISTEN      0          31536      2176/smbd
                                        tcp6       0      0 :::8443                 :::*                    LISTEN      126        36289      1557/java
                                        tcp6       0      0 :::445                  :::*                    LISTEN      0          31535      2176/smbd
                                        tcp6       0      0 fe80::bee1:cabf:72ba:53 :::*                    LISTEN      999        33968      2228/pihole-FTL
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       47765      5356/io.admin.0
                                        tcp6       0      0 :::8080                 :::*                    LISTEN      126        36918      1557/java
                                        tcp6       0      0 :::6789                 :::*                    LISTEN      126        40016      1557/java
                                        tcp6       0      0 :::7070                 :::*                    LISTEN      141        33714      1770/evcc
                                        tcp6       0      0 ::1:3350                :::*                    LISTEN      0          28007      1469/xrdp-sesman
                                        tcp6       0      0 fd16:f83a:ca:76b2:87:53 :::*                    LISTEN      999        35070      2228/pihole-FTL
                                        tcp6       0      0 :::46787                :::*                    LISTEN      0          32109      -
                                        tcp6       0      0 :::54419                :::*                    LISTEN      128        31091      1810/rpc.statd
                                        tcp6       0      0 ::1:53                  :::*                    LISTEN      999        33972      2228/pihole-FTL
                                        tcp6       0      0 :::36907                :::*                    LISTEN      0          31083      1834/rpc.mountd
                                        udp        0      0 0.0.0.0:46048           0.0.0.0:*                           128        31070      1810/rpc.statd
                                        udp        0      0 172.16.100.9:5353       0.0.0.0:*                           1001       48948      5780/io.tr-064.0
                                        udp        0      0 192.168.66.75:5353      0.0.0.0:*                           1001       48947      5780/io.tr-064.0
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           141        33686      1770/evcc
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           116        27813      1307/avahi-daemon:
                                        udp        0      0 127.0.0.1:53            0.0.0.0:*                           999        33965      2228/pihole-FTL
                                        udp        0      0 192.168.66.75:53        0.0.0.0:*                           999        33963      2228/pihole-FTL
                                        udp        0      0 127.0.0.53:53           0.0.0.0:*                           101        26952      1120/systemd-resolv
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          32771      1428/dhcpcd
                                        udp        0      0 0.0.0.0:57445           0.0.0.0:*                           997        33493      1992/fr24feed
                                        udp        0      0 0.0.0.0:49258           0.0.0.0:*                           0          32105      -
                                        udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          18914      1/init
                                        udp        0      0 172.17.255.255:137      0.0.0.0:*                           0          39525      1782/nmbd
                                        udp        0      0 172.17.0.1:137          0.0.0.0:*                           0          39524      1782/nmbd
                                        udp        0      0 192.168.66.255:137      0.0.0.0:*                           0          28529      1782/nmbd
                                        udp        0      0 192.168.66.75:137       0.0.0.0:*                           0          28528      1782/nmbd
                                        udp        0      0 0.0.0.0:137             0.0.0.0:*                           0          28507      1782/nmbd
                                        udp        0      0 172.17.255.255:138      0.0.0.0:*                           0          39527      1782/nmbd
                                        udp        0      0 172.17.0.1:138          0.0.0.0:*                           0          39526      1782/nmbd
                                        udp        0      0 192.168.66.255:138      0.0.0.0:*                           0          28531      1782/nmbd
                                        udp        0      0 192.168.66.75:138       0.0.0.0:*                           0          28530      1782/nmbd
                                        udp        0      0 0.0.0.0:138             0.0.0.0:*                           0          28508      1782/nmbd
                                        udp        0      0 0.0.0.0:57958           0.0.0.0:*                           0          31041      1834/rpc.mountd
                                        udp        0      0 127.0.0.1:714           0.0.0.0:*                           0          31054      1810/rpc.statd
                                        udp        0      0 0.0.0.0:33803           0.0.0.0:*                           116        27815      1307/avahi-daemon:
                                        udp        0      0 0.0.0.0:58414           0.0.0.0:*                           137        36902      1856/tvheadend
                                        udp        0      0 0.0.0.0:50843           0.0.0.0:*                           0          31117      1834/rpc.mountd
                                        udp        0      0 239.255.255.250:1900    0.0.0.0:*                           137        36899      1856/tvheadend
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           141        33702      1770/evcc
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           141        33698      1770/evcc
                                        udp        0      0 0.0.0.0:1900            0.0.0.0:*                           141        33694      1770/evcc
                                        udp        0      0 0.0.0.0:34837           0.0.0.0:*                           0          31094      1834/rpc.mountd
                                        udp        0      0 192.168.66.75:60001     0.0.0.0:*                           1001       53293      5974/io.wiegand-tcp
                                        udp        0      0 0.0.0.0:60833           0.0.0.0:*                           0          28479      -
                                        udp6       0      0 :::5353                 :::*                                141        33687      1770/evcc
                                        udp6       0      0 :::5353                 :::*                                116        27814      1307/avahi-daemon:
                                        udp6       0      0 192.168.66.75:47634     :::*                                126        39059      1557/java
                                        udp6       0      0 :::39845                :::*                                128        31088      1810/rpc.statd
                                        udp6       0      0 172.16.100.9:48512      :::*                                126        39058      1557/java
                                        udp6       0      0 :::40813                :::*                                0          31111      1834/rpc.mountd
                                        udp6       0      0 fd16:f83a:ca:76b2:8e:53 :::*                                999        35841      2228/pihole-FTL
                                        udp6       0      0 fd16:f83a:ca:76b2:a0:53 :::*                                999        35083      2228/pihole-FTL
                                        udp6       0      0 fd16:f83a:ca:76b2:87:53 :::*                                999        35069      2228/pihole-FTL
                                        udp6       0      0 fd16:f83a:ca:76b2:45:53 :::*                                999        35039      2228/pihole-FTL
                                        udp6       0      0 ::1:53                  :::*                                999        33971      2228/pihole-FTL
                                        udp6       0      0 fe80::ee2c:259e:69f8:53 :::*                                999        33969      2228/pihole-FTL
                                        udp6       0      0 fe80::bee1:cabf:72ba:53 :::*                                999        33967      2228/pihole-FTL
                                        udp6       0      0 :::111                  :::*                                0          14823      1/init
                                        udp6       0      0 :::49339                :::*                                0          31124      1834/rpc.mountd
                                        udp6       0      0 :::50537                :::*                                0          31073      1834/rpc.mountd
                                        udp6       0      0 :::10001                :::*                                126        39060      1557/java
                                        udp6       0      0 :::35238                :::*                                116        27816      1307/avahi-daemon:
                                        udp6       0      0 :::3478                 :::*                                126        38067      1557/java
                                        udp6       0      0 :::60833                :::*                                0          28480      -
                                        udp6       0      0 172.17.0.1:52790        :::*                                126        39057      1557/java
                                        udp6       0      0 :::36599                :::*                                0          32108      -
                                        2025-10-06 23:20:47.804  - info: sql.0 (5697) enabled logging of modbus.0.inputRegisters.30513_Gesamtertrag, Alias=false, WriteNulls=false
                                        2025-10-06 23:20:47.818  - info: sql.0 (5697) enabled logging of opendtu.0.total.yieldday, Alias=false, WriteNulls=false
                                        2025-10-06 23:20:47.819  - info: sql.0 (5697) enabled logging of opendtu.0.total.yieldtotal, Alias=false, WriteNulls=false
                                        2025-10-06 23:20:47.935  - info: host.RoofServer instance scheduled system.adapter.dwd.0 */5 * * * *
                                        2025-10-06 23:20:47.950  - info: host.RoofServer instance system.adapter.dwd.0 in version "2.8.5" started with pid 7645
                                        2025-10-06 23:20:50.700  - silly: ham.0 (6110) States user redis pmessage ham.0.*/ham.0.Beet-Einfahrt.Accessory-Information.Identify:{"val":false,"ack":true,"ts":1759785648591,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747852584702}
                                        2025-10-06 23:20:50.700  - info: ham.0 (6110) stateChange ham.0.Beet-Einfahrt.Accessory-Information.Identify {"val":false,"ack":true,"ts":1759785648591,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747852584702}
                                        2025-10-06 23:20:51.579  - debug: ham.0 (6110) Mapped Common for Beet-Einfahrt.Accessory-Information.Manufacturer: {"type":"string","read":true,"write":false,"role":"text"}
                                        2025-10-06 23:20:51.579  - info: ham.0 (6110) updateState Beet-Einfahrt.Accessory-Information.Manufacturer: value = Orbit /common= {"type":"string","read":true,"write":false,"role":"text","name":"Manufacturer","unit":""}
                                        2025-10-06 23:20:52.440  - info: sql.0 (5697) enabled logging of modbus.0.inputRegisters.30517_Tag_Energie, Alias=false, WriteNulls=false
                                        2025-10-06 23:20:53.648  - debug: ham.0 (6110) updateState Beet-Einfahrt.Accessory-Information.Manufacturer: set postponed value = Orbit
                                        2025-10-06 23:20:58.360  - silly: ham.0 (6110) States user redis pmessage ham.0.*/ham.0.Beet-Einfahrt.Accessory-Information.Manufacturer:{"val":"Orbit","ack":true,"ts":1759785622363,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747852583679}
                                        2025-10-06 23:20:58.360  - info: ham.0 (6110) stateChange ham.0.Beet-Einfahrt.Accessory-Information.Manufacturer {"val":"Orbit","ack":true,"ts":1759785622363,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747852583679}
                                        2025-10-06 23:20:58.688  - debug: ham.0 (6110) Mapped Common for Beet-Einfahrt.Accessory-Information.Model: {"type":"string","read":true,"write":false,"role":"text"}
                                        2025-10-06 23:20:58.688  - info: ham.0 (6110) updateState Beet-Einfahrt.Accessory-Information.Model: value = HT25-0000 /common= {"type":"string","read":true,"write":false,"role":"text","name":"Model","unit":""}
                                        2025-10-06 23:20:58.854  - info: sql.0 (5697) enabled logging of modbus.0.inputRegisters.30775_Wirkleistung_Gesamt, Alias=false, WriteNulls=false
                                        2025-10-06 23:20:59.825  - debug: ham.0 (6110) updateState Beet-Einfahrt.Accessory-Information.Model: set postponed value = HT25-0000
                                        2025-10-06 23:21:00.611  - info: vis.0 (6967) starting. Version 1.5.6 in /opt/iobroker/node_modules/iobroker.vis, node: v20.19.5, js-controller: 7.0.7
                                        2025-10-06 23:21:00.621  - info: sql.0 (5697) enabled logging of modbus.1.holdingRegisters.1068_soc, Alias=false, WriteNulls=false
                                        2025-10-06 23:21:00.627  - silly: ham.0 (6110) States user redis pmessage ham.0.*/ham.0.Beet-Einfahrt.Accessory-Information.Model:{"val":"HT25-0000","ack":true,"ts":1759785622365,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747852583681}
                                        2025-10-06 23:21:00.628  - info: ham.0 (6110) stateChange ham.0.Beet-Einfahrt.Accessory-Information.Model {"val":"HT25-0000","ack":true,"ts":1759785622365,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1747852583681}
                                        2025-10-06 23:21:00.863  - debug: ham.0 (6110) Mapped Common for Beet-Einfahrt.Accessory-Information.Name: {"type":"string","read":true,"write":false,"role":"text"}
                                        2025-10-06 23:21:00.863  - info: ham.0 (6110) updateState Beet-Einfahrt.Accessory-Information.Name: value = Beet Einfahrt /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                        2025-10-06 23:21:02.193  - debug: ham.0 (6110) updateState Beet-Einfahrt.Accessory-Information.Name: set postponed value = Beet Einfahrt
                                        2025-10-06 23:21:02.241  - info: sql.0 (5697) enabled logging of modbus.1.holdingRegisters.1069_energy_counter_ac_to_dc, Alias=false, WriteNulls=false
                                          @adarof sagte in System & Admin Upgrade "exited with code 25" Start-Schleife?:
                                          Falsch. Den ioBroker startet man per
                                          iob start|stop|restart
                                            @thomas-braun Okay, danke.
                                            Ich hab ihn nun per "systemctl stop iobroker.service" gestoppet und per "iob start" gestartet.
                                            Er startet trotzdem wieder nur teilweise - war wieder da und ist wieder weg.
                                            Hast Du noch eine Idee?
                                            Script v.2025-08-09
                                            *** BASE SYSTEM ***
                                                     Chassis: desktop
                                            Docker          : false
                                            Kernel          : x86_64
                                            Userland        : 64 bit
                                             23:40:14 up 28 min,  1 user,  load average: 3.35, 2.87, 2.59
                                            CPU threads: 4
                                                           Local time: Mon 2025-10-06 23:40:14 CEST
                                                       Universal time: Mon 2025-10-06 21:40:14 UTC
                                                             RTC time: Mon 2025-10-06 21:40:14
                                                          NTP service: active
                                                      RTC in local TZ: no
                                            hmersch
                                            HOME=/home/hmersch
                                            iobroker
                                            HOME=/home/iobroker
                                            Desktop:
                                            Session:                tty
                                            *** MEMORY ***
                                            Mem:             15G        3.6G        7.7G        7.0M        4.5G         11G
                                            Swap:           2.0G          0B        2.0G
                                            Total:           17G        3.6G        9.8G
                                            Active iob-Instances:   17
                                                     3606 M used memory
                                                     2809 M active memory
                                                     4837 M inactive memory
                                                     7733 M free memory
                                                      494 M buffer memory
                                                     4041 M swap cache
                                                     2047 M total swap
                                                        0 M used swap
                                                     2047 M free swap
                                            top - 23:40:15 up 28 min,  1 user,  load average: 3.35, 2.87, 2.59
                                            Tasks: 232 total,   2 running, 230 sleeping,   0 stopped,   0 zombie
                                            %Cpu(s): 31.2 us,  7.8 sy,  0.0 ni, 57.8 id,  3.1 wa,  0.0 hi,  0.0 si,  0.0 st
                                            MiB Mem :  15875.2 total,   7728.5 free,   3611.3 used,   4535.4 buff/cache
                                            MiB Swap:   2048.0 total,   2048.0 free,      0.0 used.  11925.8 avail Mem
                                            *** FILESYSTEM ***
                                            tmpfs          tmpfs    1.6G  3.6M  1.6G   1% /run
                                            /var:
                                            27G     /var/
                                            22G     /var/lib
                                            6.2G    /var/lib/mysql
                                            6.1G    /var/lib/snapd
                                            6.0G    /var/lib/unifi
                                            715M    /opt/iobroker/iobroker-data/
                                            40M     /opt/iobroker/iobroker-data/objects.jsonl
                                            20M     /opt/iobroker/iobroker-data/objects.json.migrated
                                            USB-Devices by-id:
                                            zigbee.X
                                            Extended Pan ID:
                                            *** MASKED ***
                                            Pan ID:
                                            *** MASKED ***
                                            Channel:
                                            *** MASKED ***
                                            Network Key:
                                            *** MASKED ***
                                            /usr/bin/npm            10.8.2
                                            /usr/bin/npx            10.8.2
                                            nodejs:
                                              Version table:
                                            ioBroker Status
                                            Objects type: jsonl
                                            States  type: jsonl
                                            Hosts:
                                            RoofServer          RoofServer (version: 7.0.7, hostname: RoofServer    , alive, uptime: 95)
                                            admin:          7.7.2
                                            javascript:     8.9.2
                                            Adapter State
                                            + system.adapter.admin.0                  : admin                 : RoofServer                               -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                            + system.adapter.device-watcher.0         : device-watcher        : RoofServer                               -  enabled
                                            + system.adapter.discovery.0              : discovery             : RoofServer                               -  enabled
                                            + system.adapter.email.0                  : email                 : RoofServer                               -  enabled
                                            + system.adapter.evcc.0                   : evcc                  : RoofServer                               -  enabled, port: 7070
                                            + system.adapter.history.0                : history               : RoofServer                               -  enabled
                                            + system.adapter.ical.0                   : ical                  : RoofServer                               -  enabled
                                              system.adapter.klf200.0                 : klf200                : RoofServer                               - disabled
                                            + system.adapter.modbus.2                 : modbus                : RoofServer                               -  enabled
                                            + system.adapter.opendtu.0                : opendtu               : RoofServer                               -  enabled
                                            + system.adapter.sonoff.0                 : sonoff                : RoofServer                               -  enabled, port: 1883, bind: 192.168.66.75
                                            + system.adapter.sql.0                    : sql                   : RoofServer                               -  enabled, port: 0
                                            + system.adapter.telegram.0               : telegram              : RoofServer                               -  enabled, port: 8443, bind: 0.0.0.0
                                            + system.adapter.unifi.0                  : unifi                 : RoofServer                               -  enabled
                                            + system.adapter.web.0                    : web                   : RoofServer                               -  enabled, port: 8082, bind: 0.0.0.0 (SSL), run as: admin
                                            + instance is alive
                                            Objects and States
                                            Objects:        56520
                                            States:         48083
                                            Hit:1 http://de.archive.ubuntu.com/ubuntu jammy InRelease
                                            Hit:2 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
                                            Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
                                            Hit:4 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
                                            Get:5 https://dl.cloudsmith.io/public/tvheadend/tvheadend/deb/ubuntu focal InRelease [11.0 kB]
                                            Hit:7 https://ppa.launchpadcontent.net/deadsnakes/ppa/ubuntu jammy InRelease
                                            Hit:8 https://deb.nodesource.com/node_20.x nodistro InRelease
                                            Fetched 22.6 kB in 2s (14.0 kB/s)
                                            Pending Updates: 0
                                            tcp        0      0 0.0.0.0:12001           0.0.0.0:*               LISTEN      1001       95435      14803/io.hm-rpc.1
                                            tcp        0      0 0.0.0.0:18701           0.0.0.0:*               LISTEN      1001       93314      14773/io.hm-rpc.0
                                            tcp        0      0 0.0.0.0:2010            0.0.0.0:*               LISTEN      1001       92718      14713/io.hm-rpc.2
                                            tcp        0      0 0.0.0.0:9001            0.0.0.0:*               LISTEN      1001       90248      14157/iobroker.js-c
                                            tcp        2      0 0.0.0.0:9000            0.0.0.0:*               LISTEN      1001       88014      14157/iobroker.js-c
                                            tcp        0      0 192.168.66.75:1883      0.0.0.0:*               LISTEN      1001       92606      14696/io.sonoff.0
                                            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       91375      14505/io.admin.0
                                            udp        0      0 172.16.100.9:5353       0.0.0.0:*                           1001       91737      14751/io.tr-064.0
                                            udp        0      0 192.168.66.75:5353      0.0.0.0:*                           1001       91736      14751/io.tr-064.0
                                            udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       95557      15293/io.tuya.0
                                            udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       95558      15293/io.tuya.0
                                            udp        0      0 0.0.0.0:32874           0.0.0.0:*                           997        81063      1992/fr24feed
                                            udp        0      0 192.168.66.75:60001     0.0.0.0:*                           1001       93595      14892/io.wiegand-tc
                                            2025-10-06 23:41:28.440  - info: host.RoofServer instance system.adapter.govee.0 in version "0.0.5" started with pid 16344
                                            2025-10-06 23:41:31.406  - warn: daswetter.0 (16235) slow connection to states DB. Still waiting ...
                                            2025-10-06 23:41:31.608  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Temperature.Current-Temperature {"val":19.4,"ack":true,"ts":1759786842504,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1759536915369}
                                            2025-10-06 23:41:32.613  - info: ham.0 (15263) updateChannel Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled: name = Blink Hand Kamera Motion Enabled
                                            2025-10-06 23:41:32.671  - info: sql.0 (14670) changed history configuration to pin detected datatype for modbus.1.holdingRegisters.1088_PV-sensor_power
                                            2025-10-06 23:41:33.171  - info: host.RoofServer instance system.adapter.device-watcher.0 in version "2.13.1" started with pid 16833
                                            2025-10-06 23:41:33.676  - info: host.RoofServer instance system.adapter.modbus.2 in version "6.3.2" started with pid 16963
                                            2025-10-06 23:41:35.248  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.Name: value = Blink Hand Kamera Motion Enabled /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                            2025-10-06 23:41:35.916  - info: host.RoofServer instance system.adapter.easee.1 in version "1.0.10" started with pid 16988
                                            2025-10-06 23:41:39.336  - warn: evcc.0 (16260) slow connection to states DB. Still waiting ...
                                            2025-10-06 23:41:41.145  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.Name {"val":"Blink Hand Kamera Motion Enabled","ack":true,"ts":1759786839343,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1757794096554}
                                            2025-10-06 23:41:41.205  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.On: value = true /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                                            2025-10-06 23:41:42.498  - info: host.RoofServer instance system.adapter.parser.0 in version "2.2.4" started with pid 17012
                                            2025-10-06 23:41:44.982  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Motion-Enabled.On {"val":true,"ack":true,"ts":1759786842565,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1757794096588}
                                            2025-10-06 23:41:45.101  - info: host.RoofServer instance system.adapter.discovery.0 in version "5.0.0" started with pid 17038
                                            2025-10-06 23:41:45.393  - info: ham.0 (15263) updateChannel Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode: name = Blink Hand Kamera Privacy Mode
                                            2025-10-06 23:41:46.657  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode.Name: value = Blink Hand Kamera Privacy Mode /common= {"type":"string","read":true,"write":false,"role":"text","name":"Name","unit":""}
                                            2025-10-06 23:41:46.802  - info: host.RoofServer instance system.adapter.vw-connect.0 in version "0.6.0" started with pid 17073
                                            2025-10-06 23:41:47.506  - info: host.RoofServer instance system.adapter.statistics.0 in version "2.4.0" started with pid 17089
                                            2025-10-06 23:41:48.345  - info: host.RoofServer instance system.adapter.web.0 in version "7.0.8" started with pid 17096
                                            2025-10-06 23:41:49.664  - info: host.RoofServer instance system.adapter.matter.0 in version "0.5.2" started with pid 17111
                                            2025-10-06 23:41:49.666  - info: ham.0 (15263) stateChange ham.0.Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode.Name {"val":"Blink Hand Kamera Privacy Mode","ack":true,"ts":1759786839495,"q":0,"from":"system.adapter.ham.0","user":"system.user.admin","lc":1757794096658}
                                            2025-10-06 23:41:50.052  - info: ham.0 (15263) updateState Blink-Blink-Hand-Kamera.Blink-Hand-Kamera-Privacy-Mode.On: value = false /common= {"type":"boolean","read":true,"write":true,"role":"switch","name":"On","unit":""}
                                            2025-10-06 23:41:51.953  - info: tuya.0 (15293) bf918b83061a3f9b54rm6b: Error on Reconnect (1): connection timed out
                                            2025-10-06 23:41:52.030  - info: host.RoofServer instance system.adapter.telegram-menu.0 in version "2.4.4" started with pid 17129
                                            A Thomas Braun 2 Replies Last reply Reply Quote 0
                                            1.0k
                                            2324
