    4. Kann keine Adapter aktualisieren
      Thomas Braun Most Active @K K 2 last edited by Thomas Braun
      @k-k-2
      Schalt den Desktop aus.
      Und lösche den npm Cache
      sudo -H -u iobrokee nom cache clear --force
      [Edit:]
      Ach, sehe ich ja gerade erst: buster
      Ist tot und muss ersetzt werden. Dann funktioniert vermutlich auch dein gcc wieder.
      Nawah tschaindsch ä runnink süstem...
      Mal wieder. Leute, haltet die Kisten auf einem aktuellen Stand!!
      K K 2 1 Reply Last reply Reply Quote 0
      • K K 2
        K K 2 @Thomas Braun last edited by
        @thomas-braun danke wieder für die schnelle Antwort, aber leider auch diesmal ohne Erfolg.
        per Raspi-config auf Console und den pi neugestartet, anschließen das npm clear.
        pi@nas:~ $ iobroker upgrade ble --debug
        This upgrade of "ble" will introduce the following changes:
        -> 0.13.4:
        Very experimental support for scanning on a remote host (#793)
        Another attempt at updating `noble`. Hopefully this version works now...
        -> 0.13.3:
        Updated `noble` again. This should fix the automatic rebuild after Node.js upgrades and the previous performance issues.
        -> 0.13.2:
        Downgraded the `noble` dependency again because of performance issues
        -> 0.13.1:
        Updated the `noble` dependency. This should fix the automatic rebuild after Node.js upgrades.
        Would you like to upgrade ble from @0.13.0 to @0.13.4 now? [(y)es, (n)o]: y
        Update ble from @0.13.0 to @0.13.4
        NPM version: 9.8.1
        Installing iobroker.ble@0.13.4... (System call)
        npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see https://github.com/request/request/issues/3142
        npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
        npm WARN deprecated har-validator@5.1.5: this library is no longer supported
        npm WARN deprecated dgram@1.0.1: npm is holding this package for security reasons. As it's a core Node module, we will not transfer it over to other users. You may safely remove the package from your dependencies.
        npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
        npm WARN deprecated debug@4.1.1: Debug versions >=3.2.0 <3.2.7 || >=4 <4.3.1 have a low-severity ReDos regression when used in a Node.js environment. It is recommended you upgrade to 3.2.7 or 4.3.1. (https://github.com/visionmedia/debug/issues/797)
        npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
        npm ERR! code 1
        npm ERR! git dep preparation failed
        npm ERR! command /usr/bin/node /usr/lib/node_modules/npm/bin/npm-cli.js install --force --cache=/home/iobroker/.npm --prefer-offline=false --prefer-online=false --offline=false --no-progress --no-save --no-audit --include=dev --include=peer --include=optional --no-package-lock-only --no-dry-run
        npm ERR! npm WARN using --force Recommended protections disabled.
        npm ERR! npm WARN deprecated urix@0.1.0: Please see https://github.com/lydell/urix#deprecated
        npm ERR! npm WARN deprecated source-map-url@0.4.1: See https://github.com/lydell/source-map-url#deprecated
        npm ERR! npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
        npm ERR! npm WARN deprecated resolve-url@0.2.1: https://github.com/lydell/resolve-url#deprecated
        npm ERR! npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
        npm ERR! npm ERR! code 1
        npm ERR! npm ERR! path /home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp
        npm ERR! npm ERR! command failed
        npm ERR! npm ERR! command sh -c (node install/libvips && node install/dll-copy && prebuild-install) || (node install/can-compile && node-gyp rebuild && node install/dll-copy)
        npm ERR! npm ERR! sharp: Using cached /home/iobroker/.npm/_libvips/libvips-8.14.5-linux-armv7.tar.br
        npm ERR! npm ERR! sharp: Integrity check passed for linux-armv7
        npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp/build� wird betreten
        npm ERR! npm ERR!   CC(target) Release/obj.target/nothing/../node-addon-api/nothing.o
        npm ERR! npm ERR! rm -f Release/obj.target/../node-addon-api/nothing.a Release/obj.target/../node-addon-api/nothing.a.ar-file-list; mkdir -p `dirname Release/obj.target/../node-addon-api/nothing.a`
        npm ERR! npm ERR! ar crs Release/obj.target/../node-addon-api/nothing.a @Release/obj.target/../node-addon-api/nothing.a.ar-file-list
        npm ERR! npm ERR!   COPY Release/nothing.a
        npm ERR! npm ERR!   TOUCH Release/obj.target/libvips-cpp.stamp
        npm ERR! npm ERR!   CXX(target) Release/obj.target/sharp-linux-armv7/src/common.o
        npm ERR! npm ERR! make: Verzeichnis �/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp/build� wird verlassen
        npm ERR! npm ERR! prebuild-install warn install No prebuilt binaries found (target=7 runtime=napi arch=arm libc= platform=linux)
        npm ERR! npm ERR! gyp info it worked if it ends with ok
        npm ERR! npm ERR! gyp info using node-gyp@9.4.0
        npm ERR! npm ERR! gyp info using node@18.18.2 | linux | arm
        npm ERR! npm ERR! gyp info find Python using Python version 3.7.3 found at "/usr/bin/python3"
        npm ERR! npm ERR! gyp info spawn /usr/bin/python3
        npm ERR! npm ERR! gyp info spawn args [
        npm ERR! npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
        npm ERR! npm ERR! gyp info spawn args   'binding.gyp',
        npm ERR! npm ERR! gyp info spawn args   '-f',
        npm ERR! npm ERR! gyp info spawn args   'make',
        npm ERR! npm ERR! gyp info spawn args   '-I',
        npm ERR! npm ERR! gyp info spawn args   '/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp/build/config.gypi',
        npm ERR! npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
        npm ERR! npm ERR! gyp info spawn args   '/home/iobroker/.cache/node-gyp/18.18.2/include/node/common.gypi',
        npm ERR! npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
        npm ERR! npm ERR! gyp info spawn args   '-Dvisibility=default',
        npm ERR! npm ERR! gyp info spawn args   '-Dnode_root_dir=/home/iobroker/.cache/node-gyp/18.18.2',
        npm ERR! npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
        npm ERR! npm ERR! gyp info spawn args   '-Dnode_lib_file=/home/iobroker/.cache/node-gyp/18.18.2/<(target_arch)/node.lib',
        npm ERR! npm ERR! gyp info spawn args   '-Dmodule_root_dir=/home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp',
        npm ERR! npm ERR! gyp info spawn args   '-Dnode_engine=v8',
        npm ERR! npm ERR! gyp info spawn args   '--depth=.',
        npm ERR! npm ERR! gyp info spawn args   '--no-parallel',
        npm ERR! npm ERR! gyp info spawn args   '--generator-output',
        npm ERR! npm ERR! gyp info spawn args   'build',
        npm ERR! npm ERR! gyp info spawn args   '-Goutput_dir=.'
        npm ERR! npm ERR! gyp info spawn args ]
        npm ERR! npm ERR! gyp info spawn make
        npm ERR! npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
        npm ERR! npm ERR! g++: error: unrecognized command line option '-std=gnu++17'
        npm ERR! npm ERR! make: *** [sharp-linux-armv7.target.mk:142: Release/obj.target/sharp-linux-armv7/src/common.o] Fehler 1
        npm ERR! npm ERR! gyp ERR! build error
        npm ERR! npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
        npm ERR! npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
        npm ERR! npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
        npm ERR! npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
        npm ERR! npm ERR! gyp ERR! System Linux 5.10.103-v7l+
        npm ERR! npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
        npm ERR! npm ERR! gyp ERR! cwd /home/iobroker/.npm/_cacache/tmp/git-cloneDEg5tT/node_modules/sharp
        npm ERR! npm ERR! gyp ERR! node -v v18.18.2
        npm ERR! npm ERR! gyp ERR! node-gyp -v v9.4.0
        npm ERR! npm ERR! gyp ERR! not ok
        npm ERR!
        npm ERR! npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T09_45_21_571Z-debug-0.log
        npm ERR! A complete log of this run can be found in: /home/iobroker/.npm/_logs/2023-10-19T09_42_41_438Z-debug-0.log
        upload [5] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/.eslintrc.js .eslintrc.js application/javascript
        upload [4] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/ble.png ble.png image/png
        upload [3] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js build/index.js application/javascript
        upload [2] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/build/index.js.map build/index.js.map application/json
        upload [1] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/index_m.html index_m.html text/html
        upload [0] ble.admin /opt/iobroker/node_modules/iobroker.ble/admin/style.css style.css text/css
        mikeal created this issue in request/request
        open Request’s Past, Present and Future #3142
        Qix- created this issue in visionmedia/debug
        closed ReDos Vulnerability Regression Visibility Notice #797
          @k-k-2
          Siehe Edit oben. Die Kiste ist zu alt. Aktualisieren, am besten gleich mit Bookworm neuaufsetzen. Ohne Desktop.
          • K K 2
            @thomas-braun ok danke, hab ein schnelles upgrade auf bullseye gemacht und iobroker re-installiert, sowie backup übernommen. Jetzt sieht es gut aus.
              @k-k-2
              Ich sag ja: Zu alt. Ich wäre allerdings bis Bookworm gegangen. 'Bullseye' läuft ja auch schon wieder aus, im Sommer '24 ist da auch Schicht.
              • K K 2
                @thomas-braun ein schritt nach den anderen. so kann ich davon jetzt erstmal ein image ziehen und dann weiter machen
                madjack84 1 Reply Last reply Reply Quote 0
                • madjack84
                  madjack84 @K K 2 last edited by madjack84
                  Hello,
                  ich hab kürzlich aufgrund eines Zigbee Themas das Beta repo benutzt. Nach der Rückstellung auf stable sehe ich keine Adapter Updates mehr.
                  Ich nutze Ubuntu LTS 20.04, v20.19.0
                  Was ist hier die richtige Maßnahme? einen iobroker fix?
                  Was erwartet ihr wenn ich Ubuntu auf 22.04. update um das System zu pflegen? juckt das iobroker in irgendeiner Abhängigkeit? Ich möchte nicht 2 Fehler gleichzeitig konstruieren, aber laut diesem Thread hier könnte das ein Thema sein. Ich tippe aber, dass bei der Beta Umstellung was hängen geblieben ist. Nen Stromausfall (siehe Thread hier) gab es zwischendurch auch 😕
                  wendy2702 Thomas Braun 2 Replies Last reply Reply Quote 0
                  • wendy2702
                    wendy2702 @madjack84 last edited by
                    @madjack84 Zeig doch mal die Ausgabe von
                    iob diag
                      Thomas Braun Most Active @madjack84 last edited by Thomas Braun
                      @madjack84
                      deconz sagt doch ein Update an?
                      Dann wird es höchste Zeit zu upgraden.
                      Ich würde allerdings eher zum Original raten: Debian.
                      madjack84 1 Reply Last reply Reply Quote 1
                      • madjack84
                        madjack84 @Thomas Braun last edited by
                        @thomas-braun Ja das ist seit geraumer Zeit der einzige Adapter.
                        ich hatte oben in den Benachrichtigungen eine ganze Latte an updatebaren Adaptern gelesen und daher drauf geschlossen, dass keine Updates rein kamen.... Gerade hab ich aber fest gestellt, dass ich 2 weitere Update sehe und die Benachrichtigungen weniger sind.
                        Grund: Die Benachrichtigungen waren noch aus dem BETA repo 😞 und ich hatte schon auf stable umgestellt.
                        Daher: Vielleicht die Benachrichtigungen nach jeder Installation neu laden um sowas zu vermeiden. Und ja, den timestamp hab ich gesehen. Beispielsweise hatte ich aber hier den Admin vor dem Neustart installiert.
                        @wendy2702 : Danke für den Tip. Diag kannte ich bisher nicht. hab ich gemacht. Fix durchgeführt und neu gestartet.
                        Da stehen mir zu viel Details und IPs grade drin 😕 da das System zu laufen scheint, freue ich mich erstmal und lass den log weg, wenns ok ist.
                        Aber nochmals DANKE!
                        Thomas Braun Codierknecht 2 Replies Last reply Reply Quote 0
                          @madjack84 sagte in Kann keine Adapter aktualisieren:
                          Da steht höchstens in den letzten 25 Zeilen je nachdem irgendwas persönliches drin.
                          IPs aus deinem eigenen Netz sind z. B. komplett egal. Private IPs werden nicht geroutet. Und wer ohnehin schon in deinem Netz ist, der kann sich per nmap eh alles anschauen.
                          Das sind wieder die typischen 'Lügen' einer GUI. Die Ausgaben im Terminal sind immer richtig.
                          • Codierknecht
                            Codierknecht Developer Most Active @madjack84 last edited by
                            @thomas-braun sagte in Kann keine Adapter aktualisieren:
                            Um es etwas einfacher auszudrücken: Die IP's sehen bei uns allen gleich oder zumindest ähnlich aus. In der Regel sowas wie 192.168.178.xxx.
                            An diese IP's kommst Du nur aus Deinem privaten Netz. Damit kann niemand etwas anfangen. Es sei denn, da ist schon jemand in Deinem Netz. Aber dann hast Du ganz andere Probleme 😉
                            Und genau auf die Details kommt es an, um ein System beurteilen zu können.
                            da das System zu laufen scheint ... und lass den log weg
                            Ob da künftig Probleme zu erwarten sind, könnte man im Log erkennen.
                            75
                            8460
