    4. Test Adapter Shelly 10.0.0 (LATEST / BETA)
    • mcm1957
      mcm1957 last edited by
      @haus-automatisierung
      Uff ...
        reutli @haus-automatisierung last edited by
        unglaublich...! Dann ist ein DANKE noch mehr angezeigt!
        haselchen 1 Reply Last reply Reply Quote 1
        • haselchen
          haselchen Most Active @reutli last edited by haselchen
          @mcm1957
          Gerade das Update gefahren.
          Leider hat sich an der MQTT Meldung des Adapters nichts geändert.
          shelly.1	2025-04-15 12:38:11.433	error	[MQTT] Unable to get mqttprefix of client with id "shelly1pmmini"
          shelly.1	2025-04-15 12:38:11.393	error	[MQTT] Unable to get mqttprefix of client with id "shelly1mini"
          shelly.1	2025-04-15 12:38:11.374	error	[MQTT] Unable to get mqttprefix of client with id "shelly1mini"
          shelly.1	2025-04-15 12:38:11.372	error	[MQTT] Unable to get mqttprefix of client with id "shelly1pmminig3"
          shelly.1	2025-04-15 12:38:11.371	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus2pm"
          shelly.1	2025-04-15 12:38:11.331	error	[MQTT] Unable to get mqttprefix of client with id "shelly1pmmini"
          shelly.1	2025-04-15 12:38:11.080	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus2pm"
          shelly.1	2025-04-15 12:38:00.891	info	[MQTT] Client Close: (shelly1mini / shelly1mini / shelly1mini#) (false)
          shelly.1	2025-04-15 12:37:59.457	info	[MQTT] Client Close: (shellyplus2pm / shellyplus2pm / shellyplus2pm#) (false)
          shelly.1	2025-04-15 12:37:59.089	info	[MQTT] Client Close: (shelly1pmmini / shelly1pmmini / shelly1pmmini#) (false)
          shelly.1	2025-04-15 12:37:57.189	info	[MQTT] Client Close: (shelly1pmminig3 / shelly1pmminig3 / shelly1pmminig3#) (false)
          shelly.1	2025-04-15 12:37:50.925	info	[MQTT] Device with client id "shelly1mini-818" connected from 192.168.2.xxxx!
          shelly.1	2025-04-15 12:37:49.469	info	[MQTT] Device with client id "shellyplus2pm-18c" connected from 192.168.2.xxxx!
          shelly.1	2025-04-15 12:37:49.104	info	[MQTT] Device with client id "shelly1pmmini-e48" connected from 192.168.2.xxxx!
          shelly.1	2025-04-15 12:37:47.197	info	[MQTT] Device with client id "shelly1pmminig3-174" connected from 192.1682.xxxx!
          Erst Connect, dann Close dann Error nach dem Update.
          ID etc . gekürzt.
          • haus-automatisierung
            haus-automatisierung Developer Most Active @haselchen last edited by
            @haselchen An dem Thema wurde auch nicht gearbeitet, da niemand eine Umgebung bereitstellen kann, um den Fehler zu reproduzieren
            • haselchen
              haselchen Most Active @haus-automatisierung last edited by
              Ja, kann mich dunkel erinnern.
              Am Ende werden die Geräte wieder verbunden.
              Ist die Frage, ob das kosmetischer Natur im Log ist oder doch Auswirkungen aufs System hat.
              • mcm1957
                mcm1957 @haselchen last edited by
                Und schon wieder gibts eine neue Version zum Testen: 9.4.0 (ab morgen im LATEST / BETA).
                @haus-automatisierung hat Support für GEN 4 Geräte implementiert. Detaiuls siehe:
                https://github.com/iobroker-community-adapters/ioBroker.shelly?tab=readme-ov-file#generation-4-gen-4
                DANKE
                • mcm1957
                  mcm1957 @mcm1957 last edited by
                  Ab morgen steht eine neue BETA Version (9.5.0) im LATEST Repository zur Verfügung.
                  Es wurden wieder einige fehlende States bei existierenden Devices ergänzt sowie eine Reihe von noch nicht unterstützten Devices aufgenommen.
                  DANKE an alle die im ALPHA Test ein Feedback gegeben haben. Keine Angst - Nachschub zum ALPHA-Testen kommt bald...
                  • mcm1957
                    Ab morgen steht eine neue BETA Version (9.5.1) im LATEST Repository zur Verfügung.
                    Es wurden wieder einige fehlende States bei existierenden Devices, insbesondere dem Shelly Plus Uno, ergänzt.
                      mhuber @mcm1957 last edited by
                      @mcm1957 sagte in Test Adapter Shelly 9.5.x (LATEST / BETA):
                      Super danke echt cool was Du da leistest.
                      Eine Kleine Frage zu "ATTENTION: Reworked configuration of inputs could effect some devices." kann man sagen bei welchen Devices und was genau Du mit "inputs" meinst? Ich hab so viele shellys und soviel automatisiert über IOB, KNX....würde mir leichter fallen zu wissen worauf ich achten muss. Generell schalte ich nur ein/aus, zeitgesteuert und messe Strom
                      • mcm1957
                        mcm1957 @mhuber last edited by
                        @mhuber said in Test Adapter Shelly 9.5.x (LATEST / BETA):
                        Leider nein. Konkret ist mir keine Änderung bekannt. Da ich aber weder alle Shelly Modelle besitze und auch nicht alle testen kann ich leider nicht sagen ob / wo es unerwünschte Änderungen gegeben hat. Ich hoffe nirgends - aber ich bin nicht sicher. Allerdinsg haben ca 1000 Installationen im LATEST / BETA Test keine Probleme gemeldet.
                        • mcm1957
                          FYI
                          hat eine neue Release 10.0.0 mit Änderungen / Erweiterungen im BLE Bereich (Reduktion des Speicherbedarfs am Shelly, BLE Encryption) veröffentlicht. DANKE
                          Die neue Release sollte im Laufe des morgigen Tages im LATEST / BETA Repository verfügbar sein. Detail siehe Changelog im README.md.
                          • mcm1957
                            Nachtrag:
                            wenn ich es richtig gesehen habe benötigt die neue Shelly Adapterversion (10.0.0) auch eine erneuerte Version des BLE Scripts. Nin aber nicht sicher ob ich alles richtig gesehen habe. Daher bitte nur mal als Hinweis mit Vorbehalt sehen.
                            haus-automatisierung Fabio 2 Replies Last reply Reply Quote 0
                              haus-automatisierung Developer Most Active @mcm1957 last edited by
                              @mcm1957 sagte in Test Adapter Shelly 10.0.0 (LATEST / BETA):
                              Bitte immer in die Doku schauen, da steht genau, welche Adapter-Version welches Script braucht: https://github.com/iobroker-community-adapters/ioBroker.shelly/blob/master/docs/en/ble-devices.md
                              • Fabio
                                Fabio @mcm1957 last edited by
                                Guten Abend @mcm1957 @haus-automatisierung
                                leider läuft das bei mir aber nicht. Version 10.0.0 plus V1.0 Script.
                                Das heißt wenn ich auf einen Shelly Button einen klick mache steht im Scripting des Shelly Blu Gateway invalid Charakter. Vielleicht kann das einer mal bitte prüfen.
                                Mit der 9.5.1 und dem dazugehörenden Script v0.5 läuft es wieder.
                                Herzliche Grüße aus Köln
                                Fabio
                                haus-automatisierung 1 Reply Last reply Reply Quote 1
                                  haus-automatisierung Developer Most Active @Fabio last edited by
                                  @fabio sagte in Test Adapter Shelly 10.0.0 (LATEST / BETA):
                                  Kannst Du einen Issue mit dem genauen Fehler erstellen? Also Zeile im Script usw.
                                  Fabio 1 Reply Last reply Reply Quote 1
                                  • Fabio
                                    Fabio @haus-automatisierung last edited by Fabio
                                    @haus-automatisierung guten morgen ja mache ich, lass mir etwas Zeit das es mein Produktivsytem ist. So ist erledigt.
                                    Herzliche Grüße
                                    Fabio
                                    https://github.com/iobroker-community-adapters/ioBroker.shelly/issues/1196
                                    sansonifabio created this issue in iobroker-community-adapters/ioBroker.shelly
                                    closed Version 10.0.0 Shelly Adapter Script Version 1.0 Schalter klicks werden nicht übertragen #1196
                                    • mcm1957
                                      mcm1957 @Fabio last edited by
                                      @fabio
                                      Danke fürs Issue.
                                      Bin nicht 100% sicher ABER entferne bitte mal die Zeile
                                      'console.log('Received ' + JSON.stringify(unpackedData));'
                                      und gib ein Feedback ob das dann funktioniert. Die Zeilt dürfte ein Relikt von 0.5.x sein. Die Variable unpackedData gibts nicht mehr.
                                      Alternativ wart auf ein Feedback von @haus-automatisierung - er ist da eindeutig der Spezialist.
                                      • Fabio
                                        @mcm1957 läuft wieder, ich Danke dir/euch ganz herzlich. 👍
                                        Fabio
                                        31.7k
                                        79.8k
                                        mcm1957 shelly
                                        1003
