    4. Keine Anmeldung mehr möglich
    • U
      UweK @Thomas Braun last edited by
      @thomas-braun said in Keine Anmeldung mehr möglich:
      iob start admin
      Mit start admin
      Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
      permitted by applicable law.
      Last login: Thu May 29 18:31:44 2025 from 2001:4dd1:72e3:0:8dc6:6635:1158:cbf7
      Uwe@raspberrypi5:~ $ iob start admin
       Unable to increase LUA script timeout: Error auth NOT SUPPORTED
       Cannot determine Set feature status: Connection is closed.
      Server Cannot start inMem-objects on port 9001: Failed to lock DB file "/opt/iobroker/node_modules/iobroker.js-controller/admin/objects.jsonl"!
        Thomas Braun Most Active @UweK last edited by
        @uwek
        Keine Ahnung wo es da klemmt. Andere Funktionen reagieren wie?
        sudo apt update
        z. B.?
        • U
          Uwe@raspberrypi5:~ $ sudo apt update
          Get:2 http://deb.debian.org/debian-security bookworm-security InRelease [48.0 kB]
          Get:3 http://archive.raspberrypi.com/debian bookworm InRelease [55.0 kB]
          Get:4 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
          Get:5 http://deb.debian.org/debian-security bookworm-security/main armhf Packages [243 kB]
          Get:6 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [257 kB]
          Get:7 http://deb.debian.org/debian-security bookworm-security/main Translation-en [157 kB]
          Get:8 http://archive.raspberrypi.com/debian bookworm/main armhf Packages [539 kB]
          Get:9 http://archive.raspberrypi.com/debian bookworm/main arm64 Packages [537 kB]
          Ign:10 https://deb.nodesource.com/node_21.x nodistro InRelease
          Err:10 https://deb.nodesource.com/node_21.x nodistro InRelease
            Could not resolve 'proxy'
          Fetched 1,892 kB in 12s (156 kB/s)
          Reading package lists... Done
          Building dependency tree... Done
          1 package can be upgraded. Run 'apt list --upgradable' to see it.
          W: Failed to fetch https://deb.nodesource.com/node_21.x/dists/nodistro/InRelease  Could not resolve 'proxy'
          W: Some index files failed to download. They have been ignored, or old ones used instead.
          Was ist denn mit: "Could not resolve 'proxy'?
            @uwek sagte in Keine Anmeldung mehr möglich:
            Keine Ahnung. Ist ja dein Netzwerk.
            Proxy eingerichtet?
            BTW: nodejs@21 ist tot. Leg da eine Quelle für nodejs20 an und verwende das.
            • U
              Und wie, mit welchen Befehlen, legt man eine Quelle für nodejs20 an?
                @uwek
                Mach es per
                iob nodejs-update 20
                Kann aber sein, das es nicht funktioniert, weil da noch ein proxy auftaucht.
                • U
                  Stimmt, mit:
                  gibt es keine Reaktion.
                    @uwek
                    Versuch es mal mit
                    cd /home/iobroker
                    bash < ./.diag.sh
                    Zuvor vielleicht mal
                    cd /home/iobroker
                    bash < ./.fix.sh
                    versuchen.
                    • U
                      ========== Start marking the full check here ===========
                      ```bash
                      Script v.2025-03-08
                      *** BASE SYSTEM ***
                       Static hostname: raspberrypi5
                             Icon name: computer
                                Kernel: Linux 6.12.25+rpt-rpi-2712
                          Architecture: arm64
                      OS is similar to:
                      Model           : Raspberry Pi 5 Model B Rev 1.0
                      Docker          : false
                      Virtualization  : none
                      Kernel          : aarch64
                      Userland        : 64 bit
                      Systemuptime and Load:
                       20:02:13 up 1 day,  7:54,  3 users,  load average: 0.14, 0.11, 0.04
                      CPU threads: 4
                      *** LIFE CYCLE STATUS ***
                      Operating System is the current Debian stable version codenamed 'bookworm'!
                      *** RASPBERRY THROTTLING ***
                      Current issues:
                      Previously detected issues:
                      *** TIME AND TIMEZONES ***
                                     Local time: Thu 2025-05-29 20:02:13 CEST
                                 Universal time: Thu 2025-05-29 18:02:13 UTC
                                       RTC time: Thu 2025-05-29 18:02:13
                                    NTP service: active
                                RTC in local TZ: no
                      *** Users and Groups ***
                      User that called 'iob diag':
                      Uwe
                      HOME=/home/Uwe
                      GROUPS=Uwe adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                      js-controller is not running
                      *** DISPLAY-SERVER SETUP ***
                      Display-Server: false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Mem:            8.5G        341M        7.5G        5.5M        670M        8.1G
                      Swap:           209M          0B        209M
                      Total:          8.7G        341M        7.7G
                      Active iob-Instances:   0
                               8063 M total memory
                                325 M used memory
                                221 M active memory
                                433 M inactive memory
                               7182 M free memory
                                107 M buffer memory
                                531 M swap cache
                                199 M total swap
                                  0 M used swap
                                199 M free swap
                      top - 20:02:13 up 1 day,  7:54,  3 users,  load average: 0.14, 0.11, 0.04
                      Tasks: 173 total,   1 running, 172 sleeping,   0 stopped,   0 zombie
                      %Cpu(s):  0.0 us,  0.0 sy,  0.0 ni,100.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                      MiB Mem :   8063.7 total,   7181.7 free,    326.2 used,    639.3 buff/cache
                      MiB Swap:    200.0 total,    200.0 free,      0.0 used.   7737.5 avail Mem
                      *** FAILED SERVICES ***
                      0 loaded units listed.
                      *** DMESG CRITICAL ERRORS ***
                      No critical errors detected
                      *** FILESYSTEM ***
                      udev           devtmpfs  3.9G     0  3.9G   0% /dev
                      tmpfs          tmpfs     807M  5.3M  802M   1% /run
                      /dev/mmcblk0p2 ext4      117G  5.6G  106G   5% /
                      tmpfs          tmpfs     4.0G     0  4.0G   0% /dev/shm
                      tmpfs          tmpfs     5.0M   48K  5.0M   1% /run/lock
                      /dev/mmcblk0p1 vfat      510M   66M  445M  13% /boot/firmware
                      tmpfs          tmpfs     807M     0  807M   0% /run/user/1000
                      [Wed May 28 12:07:56 2025] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave  numa=fake=8 system_heap.max_order=0 smsc95xx.macaddr=2C:CF:67:32:63:A0 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000  console=ttyAMA10,115200 console=tty1 root=PARTUUID=8e8d8989-02 rootfstype=ext4 fsck.repair=yes rootwait cfg80211.ieee80211_regdom=DE
                      [Wed May 28 12:07:59 2025] EXT4-fs (mmcblk0p2): mounted filesystem 93c89e92-8f2e-4522-ad32-68faed883d2f ro with ordered data mode. Quota mode: none.
                      [Wed May 28 12:08:00 2025] EXT4-fs (mmcblk0p2): re-mounted 93c89e92-8f2e-4522-ad32-68faed883d2f r/w. Quota mode: none.
                      Show mounted filesystems:
                      TARGET           SOURCE         FSTYPE OPTIONS
                      /                /dev/mmcblk0p2 ext4   rw,noatime
                      `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,er
                      /var:
                      1.1G    /var/
                      450M    /var/log/journal/7955a11edc2a4908be4e0376b1ccf614
                      450M    /var/log
                      207M    /var/cache
                      Archived and active journals take up 449.5M in the file system.
                      /opt/iobroker/backups:
                      6.7M    /opt/iobroker/backups/
                      /opt/iobroker/iobroker-data:
                      845M    /opt/iobroker/iobroker-data/
                      746M    /opt/iobroker/iobroker-data/files
                      617M    /opt/iobroker/iobroker-data/files/javascript.admin
                      560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
                      558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
                      43M     /opt/iobroker/iobroker-data/objects.jsonl
                      24M     /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js.map
                      9.3M    /opt/iobroker/iobroker-data/files/modbus.admin/static/js/main.6a71b34c.js
                      8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
                      8.6M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/310.89a60ae1.chunk.js.map
                      USB-Devices by-id:
                      No Devices found 'by-id'
                      Zigbee Network Settings on your coordinator/in nvbackup are:
                      zigbee.X
                      Extended Pan ID:
                      *** MASKED ***
                      Pan ID:
                      *** MASKED ***
                      Channel:
                      *** MASKED ***
                      Network Key:
                      *** MASKED ***
                      To unmask the settings run 'iob diag --unmask'
                      *** NodeJS-Installation ***
                      /usr/bin/nodejs         v21.7.3
                      /usr/bin/node           v21.7.3
                      /usr/bin/npm            10.5.0
                      /usr/bin/npx            10.5.0
                      /usr/bin/corepack       0.25.2
                      nodejs:
                        Installed: 21.7.3-1nodesource1
                        Candidate: 21.7.3-1nodesource1
                        Version table:
                       *** 21.7.3-1nodesource1 600
                              500 https://deb.nodesource.com/node_21.x nodistro/main arm64 Packages
                              100 /var/lib/dpkg/status
                           21.7.2-1nodesource1 600
                           21.7.1-1nodesource1 600
                           21.7.0-1nodesource1 600
                           21.6.2-1nodesource1 600
                           21.6.1-1nodesource1 600
                           21.6.0-1nodesource1 600
                           21.5.0-1nodesource1 600
                           21.4.0-1nodesource1 600
                           21.3.0-1nodesource1 600
                           21.2.0-1nodesource1 600
                           21.1.0-1nodesource1 600
                           21.0.0-1nodesource1 600
                           18.19.0+dfsg-6~deb12u2 500
                           18.19.0+dfsg-6~deb12u1 500
                      No problems detected
                      Errors in npm tree: 0
                      *** ioBroker-Installation ***
                      ioBroker Status
                      Hosts:
                      Core adapters versions
                      js-controller:  7.0.6
                      admin:          7.6.17
                      javascript:     "javascript" not found
                      nodejs modules from github:     0
                      Adapter State
                      ioBroker-Repositories
                      Installed ioBroker-Adapters
                      Objects and States
                      Objects:        14
                      States:         3
                      Ign:1 https://deb.nodesource.com/node_21.x nodistro InRelease
                      Hit:2 http://archive.raspberrypi.com/debian bookworm InRelease
                      Hit:3 http://deb.debian.org/debian bookworm InRelease
                      Hit:4 http://deb.debian.org/debian-security bookworm-security InRelease
                      Hit:5 http://deb.debian.org/debian bookworm-updates InRelease
                      Err:1 https://deb.nodesource.com/node_21.x nodistro InRelease
                      Pending Updates: 1
                      *** Listening Ports ***
                      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          5579       793/sshd: /usr/sbin
                      tcp6       0      0 :::22                   :::*                    LISTEN      0          5581       793/sshd: /usr/sbin
                      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        6402       677/avahi-daemon: r
                      udp        0      0 0.0.0.0:56843           0.0.0.0:*                           104        6404       677/avahi-daemon: r
                      udp6       0      0 :::5353                 :::*                                104        6403       677/avahi-daemon: r
                      udp6       0      0 fe80::9f5b:17ea:875:546 :::*                                0          1683       754/NetworkManager
                      udp6       0      0 :::33400                :::*                                104        6405       677/avahi-daemon: r
                      2025-05-29 20:03:38.051  - warn: host.raspberrypi5-Server Objects 127.0.0.1:56276 Error from InMemDB: Error: auth NOT SUPPORTED
                          at RedisHandler._handleCommand (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:141:40)
                          at Resp.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:59:45)
                          at Resp.emit (node:events:519:28)
                          at Resp.write (/opt/iobroker/node_modules/respjs/index.js:129:12)
                          at Socket.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-base/build/esm/lib/redisHandler.js:69:23)
                          at Socket.emit (node:events:519:28)
                          at addChunk (node:internal/streams/readable:559:12)
                          at readableAddChunkPushByteMode (node:internal/streams/readable:510:3)
                          at Readable.push (node:internal/streams/readable:390:5)
                          at TCP.onStreamRead (node:internal/stream_base_commons:190:23)
                      2025-05-29 20:03:38.359  - warn: host.raspberrypi5-Server Objects 127.0.0.1:56286 Error from InMemDB: Error: auth NOT SUPPORTED
                      2025-05-29 20:04:07.001  - error: host.raspberrypi5 No connection to databases possible, restart
                      2025-05-29 20:04:07.004  - info: host.raspberrypi5 iobroker _restart
                      2025-05-29 20:04:07.511  - info: host.raspberrypi5 iobroker Starting node restart.js
                      iob diag has finished.
                      Uwe@raspberrypi5:/home/iobroker $
                      • U
                        UweK @UweK last edited by
                        @Thomas-Braun
                        Leider sagt mir das alles nicht so viel.
                        Zum Schluß sehe ich ein error. No connection to database.
                        • U
                          @Thomas-Braun
                          Schreiben sie gerne nochmal, wenn es ihre Zeit erlaubt.
                          Ich melde mich nun erstmal ab und schaue morgen nochmal hier vorbei.
                            @uwek
                            Den fix zuvor auch ausgeführt?
                            Kiste mal sauber neugestartet?
                              Thomas Braun Most Active last edited by
                              @uwek
                              Ich würde behaupten, da hat es aus irgendwelchen Gründen die Datenbank zerlegt. Zück dein Backup und installier es nochmal neu.
                                @thomas-braun sagte in Keine Anmeldung mehr möglich:
                                @uwek
                                @UweK
                                ich fürchte das wird mit nodejs v21 zusammenhängen können.
                                Also Basis komplett neu installieren, dann iobroker und zuletzt das Backup wiederherstellen
                                U 1 Reply Last reply Reply Quote 1
                                • U
                                  UweK @Homoran last edited by
                                  @Homoran
                                  @Thomas-Braun
                                  Danke für die Unterstützung und Zuarbeit.
                                  Ich werde alles von Grund auf neu installieren, und das Backup vom Dienstag einspielen.
                                  Dann denke ich, wird es wieder laufen.
                                  865
