    4. [HowTo] ioBroker Restore unter Linux durchführen
    • aXCell
      aXCell last edited by
      Nach der Neuinstallationn und dem Restore wie hier im Post #1 beschrieben, müllt sich das Log mit folgendem Inhalt voll:
      227
      Log-Größe: 507.7 KB
      Zeit
      Nachricht
      admin.0
      	2024-01-16 16:05:18.967	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:18.742	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:18.674	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:18.443	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:18.097	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:18.031	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:17.723	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:17.477	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:17.413	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:17.107	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:16.870	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:16.806	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:16.509	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:16.317	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:16.214	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:15.922	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:15.699	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:15.639	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:15.346	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      admin.0
      	2024-01-16 16:05:14.870	warn	Cannot read file ("backitup.admin"/"backitup.png"): Not exists
      admin.0
      	2024-01-16 16:05:14.859	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
      host.server
      	2024-01-16 16:01:07.236	warn	startInstance cannot find adapter "info@2.0.0". Try to install it... 1 attempt
      host.server
      	2024-01-16 16:01:01.625	warn	startInstance cannot find adapter "discovery@4.2.0". Try to install it... 1 attempt
      host.server
      	2024-01-16 16:00:48.446	warn	startInstance cannot find adapter "homekit-controller@0.5.9". Try to install it... 1 attempt
      host.server
      	2024-01-16 16:00:32.947	warn	startInstance cannot find adapter "roborock@0.4.4". Try to install it... 1 attempt
      host.server
      	2024-01-16 16:00:30.636	error	iobroker npm-install: The following apt-get packages could not be installed: pam-devel. Please install them manually.
      host.server
      	2024-01-16 16:00:30.636	error	iobroker npm-install: Cannot install "pam-devel": E: Unable to locate package pam-devel
      Also die Fehlermeldung zum fehlendem "Admin.png" laufen im sekundentakt hoch.
      Auch hat der BackItUp Adapter bzw. Menüpunkt in der linken Seitenleiste keine Grafik mehr und lässt sich nicht aufrufen.
      Ach so, ich habe den Restore NACH Installation des Redis Servers über die CLI durchgeführt.
      IOB Status:
      axcell@server:~$ iob status
      At least one iobroker host is running.
      Objects type: redis
      States  type: redis
      IOB diag:
      			v.2023-10-10
       Static hostname: server
             Icon name: computer-desktop
               Chassis: desktop
      Operating System: Ubuntu 22.04.3 LTS
                Kernel: Linux 5.15.0-91-generic
          Architecture: x86-64
       Hardware Vendor: Dell Inc.
        Hardware Model: OptiPlex 3050
      Installation: 		native
      Kernel: 		x86_64
      Userland: 		amd64
      Timezone: 		Europe/Berlin (CET, +0100)
      User-ID: 		1000
      X-Server: 		true
      Boot Target: 		graphical.target
      Pending OS-Updates: 	0
      Pending iob updates: 	0
      Nodejs-Installation: 	/usr/bin/nodejs 	v18.19.0
      			/usr/bin/node 		v18.19.0
      			/usr/bin/npm 		10.2.3
      			/usr/bin/npx 		10.2.3
      			/usr/bin/corepack 	0.22.0
      Recommended versions are nodejs 18.19.0 and npm 10.2.3
      MEMORY:
      Mem:             15G        941M         13G        399M        1.5G         14G
      Swap:           4.1G          0B        4.1G
      Total:           19G        941M         17G
      Active iob-Instances: 	15
      Active repo(s): stable
      ioBroker Core: 		js-controller 		5.0.17
      			admin 			6.12.0
      ioBroker Status: 	iobroker is running on this host.
      Objects type: redis
      States  type: redis
      + system.adapter.admin.0                  : admin                 : server                                   -  enabled, port: 8081, bind: 0.0.0.0 (SSL), run as: admin
      Objects: 		1868
      States: 		1514
      Size of iob-Database:
      4.4M	/opt/iobroker/iobroker-data/objects.jsonl
      128K	/opt/iobroker/iobroker-data/states.jsonl
      So erstmal aus meiner Laiensicht nnichts auffällig.
      Wo setze ich nun an?
        Thomas Braun Most Active @aXCell last edited by Thomas Braun
        @axcell
        Kann es sein das du zu schnell bist und das Backup noch läuft?
        Davon ab: Server immer ohne Desktop betreiben.
        Das Paket 'pam-devel' gibt es nicht unter Debian, jedenfalls nicht unter dem Namen. Installier da
        sudo apt install libpam0g-dev
        aXCell 1 Reply Last reply Reply Quote 0
        • aXCell
          aXCell @Thomas Braun last edited by aXCell
          @thomas-braun sagte in [HowTo] ioBroker Restore unter Linux durchführen:
          @axcell
          Dann sagen wir einfach mal, es ist ein Desktop PC, der zusätzlich den ioBroker hostet, wegen der bemängelten GUI auf einem Server 😉 Aber mal ehrlich und blöd nachgefragt, können dadurch Konflikte auftreten wenn ein Server zusätzlich eine GUI betreibt?
          Der Befehl:
          ergibt nur:
          axcell@server:~$ sudo apt install libpam0g-dev
          [sudo] Passwort für axcell:
          Paketlisten werden gelesen… Fertig
          Abhängigkeitsbaum wird aufgebaut… Fertig
          Statusinformationen werden eingelesen… Fertig
          libpam0g-dev ist schon die neueste Version (1.4.0-11ubuntu2.3).
          0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
          Wegen dem "zu schnell", wenn die Konsole sagt, Restore erfolgreich und der Prozessor nichts mehr macht, also im IDLE dümpelt, dachte ich eigentlich, dass der Restore fertig und abgeschlossen ist.
          Wenn ich den iobroker laufen lasse, erzeugt er mir permanent LOG Einträge im Sekundentakt mit der oben angegebenen Meldung
          admin.0	2024-01-16 16:05:15.346	warn	Cannot read file ("admin.admin"/"admin.png"): Not exists
          P.S: So sieht es aktuell aus, meiner Meinung nach, nicht ganz korrekt.....
            @axcell sagte in [HowTo] ioBroker Restore unter Linux durchführen:
            Unter Umständen.
            Ein Server wird aus vielen verschiedenen Gründen ohne Gui betrieben. Alles was nicht unnötig mitrumpelt muss nicht gepflegt werden, kann nicht kaputt gehen und kann auch keine Sicherheitslücken haben. Der Rechnerbetrieb wird unnötig komplex.
            Serversoftware verfügt meist eh über ein CLI und kein GUI, du musst also eh ein Terminal füttern. Z.B. mit
            iob upload all
            aXCell 1 Reply Last reply Reply Quote 1
            • aXCell
              Ja ok, das mit den Sicherheitslücken macht Sinn.
              Ja, primär nutze ich ja auch das CLI, aber wenn es eben ein ausgedienter Laptop oder Desktop PC ist, der den ioBroker hostet, ist das ja auch zusätzlich nur erleichternd, wenn mal der SSH abgekackt ist oder die Netzwerkkarte aussteigt.
              Aber ok, ich will eine GUI auf einem Server nicht schön reden, du hast schon Recht.
              Ich habe zwischenzeitlich ich den BackItUp Adapter deinstalliert und neu installiert und das Backup neu angestossen, danach dann
              iob upload all
              ausgeführt, jetzt müllt sich das LOG zumindest nicht mehr mit Einträgen voll, die Adapter sind alle wieder installiert und scheinbar ist nun Ruhe.
              Ob es an "upload all" oder am neuen anstossen der Backupwiederherstellung nach re-installieren des Backitup lag / liegt, mag ich nicht beurteilen.
                Ich schon. Lag an fehlenden Dateien, die du nun per upload all wieder an den korrekten Platz geschoben hast.
                Und schalt den Desktop aus.
                sudo systemctl set-default multi-user.target
                aXCell 1 Reply Last reply Reply Quote 3
                • aXCell
                  Erledigt Chef 😉 und Danke!
                  C 1 Reply Last reply Reply Quote -1
                    Creatorhs @aXCell last edited by
                    nach einem Neuaufsetzen mit einer neuen SD-Karte komme ich nicht weiter. Meine Backups liegen auf Google Drive, leider findet Backitup die Dateien nicht.
                    Allerdings war ich schon in der Lage die iobroker-Backupdatei einzuspielen, die anderen (influx, javascripts usw) werden nicht mehr gefunden.
                    kann mir jemand helfen, wie ich an das Problem rangehen kann?
                    Friedhofsblond 1 Reply Last reply Reply Quote 0
                    • Friedhofsblond
                      Friedhofsblond @Creatorhs last edited by Friedhofsblond
                      @simatec
                      Moin,
                      ich mußte gerade ein Image von meinem Homeserver zurückspielen.
                      (Hatte nix mit dem IOBroker zu tun)
                      Also erstmal ein Backup vom IOB, Grafana, InfluxDB gemacht.
                      Dann Restore Image vom Server und erstmal alle Updates vom Debian und IOB gemacht.
                      Nach Reboot dann Restore vom IOB
                      • Dann InfluxDB
                      • Dann Grafana
                      Danach ware der sourceanalytix-Adapter nicht mehr da und auch keine aktuellen daten von der InfluxDB - nur die mit den paar Minuten nach dem Restore.
                      Also den sourceanalytix-Adapter nachinstalliert, nochmal Restore IOB-Backup.
                      Aber immer noch keine Daten in der InfluxDB.
                      Im Log stand sowas von DB gibt es schon Restore erfolgreich.
                      OK, also die InfluxDB komplett gelöscht und nochmal Restore InfluxDB.
                      Nun ist alles wieder schön.
                      Frage:
                      1. Werden Apps aus dem GIT nicht wiederhergestellt?
                      2. Ist das normal, daß man die InfluxDB vorher löschen muß?
                        Danke für die Antwort/en 😊
                      crunchip mcm1957 2 Replies Last reply Reply Quote 0
                      • Tobias Krüger
                        Tobias Krüger last edited by
                        ich lese hier gespannt mit, danke schon mal für die ganzen Tipps!
                        Ich hab mal eine Frage: Muss man die InfluxDB wirklich immer komplett löschen, bevor man ein Restore macht? Oder gibt’s da auch ’nen besseren Weg, damit nix verloren geht?
                        Würde mich freuen, wenn jemand kurz seine Erfahrung teilt!
                        Viele Grüße
                          crunchip Forum Testing Most Active @Friedhofsblond last edited by
                          @friedhofsblond bei adapter die per git installiert wurden, muss die Instanz manuell installiert werden
                          Zum Thema influxdb,
                          es sollte im Vorfeld keine angelegt sein, da diese automatisch angelegt wird.
                          • mcm1957
                            mcm1957 @Friedhofsblond last edited by
                            @friedhofsblond said in [HowTo] ioBroker Restore unter Linux durchführen:
                            ja
                            GITHUB Installationen werden auch nicht aktualisisert und keine Aktualisiserungen angezeigt.
                            Von direkten Installation von GitHub - insbesondere auf produktiven Systemen - wird explizit abgeraten.
                            GitHub Versionen können sich jederzeit (auch kurzfristig) ändern und durchaus auch in sich inkonsistent und fehlerhaft sein. Versionsangaben von GitHub Installationen sind Schall und Rauch da die Versionsnummer zumindest bei Verwendung der standardmäßigen Umgebung erst im Zuge der Releaseerstellung geändert wird.
                            Auf explizite Aufforderung durch den Entwickler kann eine GitHub Installation zur Fehlereingrenzung oder zum Test neuer Funktionalität - unter Inkaufnahme des erhöhten Risikos - natürlich erfolgen.
                            Adapter die nur via GitHub oder npm (also NICHT aus einem der beiden Repositories) installierbar sind sind mit erhöhter Vorsicht zu betrachten. Hier sollte der Entwickler drum ersucht werden eine Aufnahme in die Repositories zu veranlassen indem z.B. ein Issue im Adapterrepository erstellt wird.
                            backitup how-to restore restore backup
                            76
                            513
                            129303
