    4. Test Adapter shelly - ALPHA Versionen
    • mcm1957
      mcm1957 last edited by
      @gelberlemmy said in Test Adapter shelly - ALPHA Versionen:
      @mcm1957 Hallo, ich habe aktuell ein Problem mit meinem Shelly Adapter über MQTT. Ich würde jetzt tippen, dass es etwas mit der aktuellen Firmware zu tun hat. Egal welche Version vom Adapter ich nehme, bekomme ich folgende Nachrichten
      shelly.1
      2025-06-03 21:43:04.010	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) (false)
      shelly.1
      2025-06-03 21:42:54.016	info	[MQTT] Device with client id "shellyplus1-64b7080b3d78" connected from 192.168.171.80!
      shelly.1
      2025-06-03 21:42:45.727	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) (false)
      shelly.1
      2025-06-03 21:42:44.328	info	[MQTT] Client Close: (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) (false)
      shelly.1
      2025-06-03 21:42:44.311	error	[MQTT] Wrong MQTT authentification of client "shellypro3-2cbcbba79f0c"
      shelly.1
      2025-06-03 21:42:35.735	info	[MQTT] Device with client id "shellyplus1-441793a712a8" connected from 192.168.171.106!
      shelly.1
      2025-06-03 21:41:56.079	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) (false)
      shelly.1
      2025-06-03 21:41:48.497	info	[MQTT] Client Close: (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) (false)
      shelly.1
      2025-06-03 21:41:48.473	error	[MQTT] Wrong MQTT authentification of client "shellypro3-2cbcbba79f0c"
      shelly.1
      2025-06-03 21:41:46.083	info	[MQTT] Device with client id "shellyplus1-64b7080b3d78" connected from 192.168.171.80!
      shelly.1
      2025-06-03 21:41:42.097	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a712a8"
      shelly.1
      2025-06-03 21:41:42.057	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-64b7080b3d78"
      shelly.1
      2025-06-03 21:41:41.717	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
      shelly.1
      2025-06-03 21:41:41.333	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a712a8"
      shelly.1
      2025-06-03 21:41:41.333	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
      shelly.1
      2025-06-03 21:41:41.085	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
      shelly.1
      2025-06-03 21:41:41.048	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a712a8"
      shelly.1
      2025-06-03 21:41:40.871	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-64b7080b3d78"
      shelly.1
      2025-06-03 21:41:40.870	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
      shelly.1
      Es lief alles reibunsglos. Auch frage ich mich, warum hinter den IP Adressen im Text ein "!" steht.
      Anbei einmal ein Screenshot von einem Teilnehmer auf der Adapter Instanz.
      Hat da jemand einen Tipp ?
      Gruß André
      Das hat zwar nichts mit ALPHA Tests zu tun - derzeit läuft nicht mal einer - ABER:
      Kontrollier mal dein MQTT Passwort (und auch gleich den Username für MQTT).
      Bitte beachte, dass das Passwort am Shelly bei JEDER (!) Änderung der MQTT Einstellungen neu eingegeben werden muss. Und dass der Shelly nachher restartet werden muss.
      Falls du auch ein HTTP Passwort gesetzt hast, verwende für HTTP und MQTT unterschiedliche Usernames und Passwörter. (Hab keine Erklärung und auch noch icht expolizit getestet aber es gab eine diesbezügliche Meldung vin ein oder 2 User die meinten dass es bei identem Username / Passwortkombinationen für HTTP und MQTT Probleme gäbe).
      gelberlemmy 1 Reply Last reply Reply Quote 0
      • gelberlemmy
        gelberlemmy @mcm1957 last edited by
        @mcm1957 Danke, aber das habe ich alles bereits getan. Lese aber gerade im Shelly Forum, dass es bei Firmware Probleme gibt. Da haben einige, dass Sie sich nicht mal mehr an der CLoud anmelden kann. Suche gerade das Firmwarefile zum downgraden zum testen.
        • mcm1957
          mcm1957 @gelberlemmy last edited by
          @gelberlemmy
          • Welche Firmware hast du die die Probleme macht?
          • Wenn du einen Links ins Shelly Forum hast, dann post den gerne auch hier.
          • gelberlemmy
            gelberlemmy @mcm1957 last edited by gelberlemmy
            @mcm1957 Das ist die 1.6.2
            Auf allen Geräte unter dem Adapter sind auf 1.6.2 . Da scheint es wirklich ein Problem mit der Version zu geben.
            Der Post im Shelly Forum war leider für 1.5.0 und nicht für1.6.2.
            Leider finde aktuell ich keine Firmware zum Downgrade.Beim Linkgenerator habe ich irgendwie nicht den korrekten Typen gefunden. Oder ich bin ein wenig Blind...🤕
            • mcm1957
              @gelberlemmy
              Wenn möglich teste mal gegen den MQTT Adapter. Wenns dort auch nicht geht dann brauchen wir auf ioBroker Seite gra nicht suchen,
              • gelberlemmy
                @mcm1957 ich probiere das aus. Aber dann würde es ja zumindest hier her gehören, wenn die Version 1.6.2 nicht mit dem Shelly Adapter funktioniert.
                mcm1957 2 Replies Last reply Reply Quote 0
                • mcm1957
                  @gelberlemmy
                  Ja ja passt schon. Leg gerne alle Infos zum Problem da mal ab.
                  Und wenn sonst wer was dazu sagen kann - insbesondere dass bei ihm die Shelly FW 1.6.2 normal funktioniert BITTE MITTEILEN.
                  P.S.: Welche(r) Shelly Typ(en) ist/sind eigentlich bei dir betroffen?
                  B Peter V. 2 Replies Last reply Reply Quote 0
                    bommel_030 @mcm1957 last edited by
                    @mcm1957
                    Ich hab u.a. nen Shelly Uni Plus 1.6.2 mit dem Shelly Adapter 10.0.0 am laufen und habe keine Probleme.
                    • Peter V.
                      Peter V. @mcm1957 last edited by
                      @mcm1957
                      Mit der (alpha) Version 10 läuft ohne Probleme:
                      Shelly PlusPlugS : 1.6.2
                      Shelly PlusPlugS Gen3 : matter.123
                      Shelly PM Mini Gen2 : 1.6.2
                      Shelly PM Mini Gen3: 1.6.2
                      Shelly 1PM Mini Gen2 : 1.6.2
                      Shelly 1PM Mini Gen3 : 1.6.2
                      Shelly DoorWindow/Button : BLE (via PlusPlugS Gen2)
                      Shelly Plus2PM : 1.6.2
                      Shelly Pro 3 EM-CT63 : 1.6.2
                      Shelly 3EM63 Gen3 : 1.6.2
                      und diverse Shelly Plus HT / Shelly Buttons / Shelly Flood
                      demnächst:
                      Shelly 1 Mini Gen4 & Shelly 1PM Mini Gen4
                      Andreios 1 Reply Last reply Reply Quote 1
                      • mcm1957
                        @gelberlemmy
                        Nach dem letzten Comment dürfte da doch ein Problem bei deiner INstallation (oder beim Adapter) vorliegen.
                        Bitte verifiziere nochmals explizit die MQTT (nicht die HTTP) Username / Passwortkombinatio n und gib sie zumindest bei einem Shelly explizit neu ein uns reboote diesen zum Test.
                        • gelberlemmy
                          @mcm1957 Okay habe ich gemacht. Ich bekomme es nicht hin. Port geändert, anderen Shelly adapter abgeschaltet. MQTT Adapter deaktiviert.... Wenn ich ein Gerät in MQTT Adapter hänge, da wird dieser Datenpunkt auch angelegt. So habe jetzt wirklich rumgespielt. Ports geändert usw. Habe einmal einige Einstellungen gescreenshotet. Auch die Protokolle auf Debug gestellt. Das kam aus heiteren Himmel. Vorher hatte ich wirklich keine Probleme.
                          Folgende Geräte habe ich :
                          1xShelly 3 Pro
                          2x Shelly 1 plus
                          1x Shelly 1 plus pm
                          Screenshot 2025-06-04 180643.png Screenshot 2025-06-04 180654.png Screenshot 2025-06-04 180715.png
                          shelly.1
                          2025-06-04 18:08:35.931	debug	[MQTT Server] Close for 192.168.171.80 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:08:35.931	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:08:35.931	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: false
                          shelly.1
                          2025-06-04 18:08:35.931	debug	[BaseClient] Destroying (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1)
                          shelly.1
                          2025-06-04 18:08:35.931	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) (false)
                          shelly.1
                          2025-06-04 18:08:35.929	debug	[MQTT Server] End for 192.168.171.80 ((shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1))
                          shelly.1
                          2025-06-04 18:08:35.928	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: true
                          shelly.1
                          2025-06-04 18:08:35.926	debug	[onlineCheck] Checking shellypro3#2cbcbba79f0c#1 on 192.168.171.158:80
                          shelly.1
                          2025-06-04 18:08:35.551	debug	[deviceStatusUpdate] shellyplus1pm#a8032ab96a08#1: true
                          shelly.1
                          2025-06-04 18:08:35.548	debug	[onlineCheck] Checking shellyplus1pm#a8032ab96a08#1 on 192.168.171.51:80
                          shelly.1
                          2025-06-04 18:08:35.289	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: true
                          shelly.1
                          2025-06-04 18:08:35.285	debug	[onlineCheck] Checking shellyplus1#64b7080b3d78#1 on 192.168.171.80:80
                          shelly.1
                          2025-06-04 18:08:27.684	debug	[MQTT Server] Close for 192.168.171.106 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:08:27.684	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:08:27.684	debug	[deviceStatusUpdate] shellyplus1#441793a712a8#1: false
                          shelly.1
                          2025-06-04 18:08:27.684	debug	[BaseClient] Destroying (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1)
                          shelly.1
                          2025-06-04 18:08:27.683	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) (false)
                          shelly.1
                          2025-06-04 18:08:27.683	debug	[MQTT Server] End for 192.168.171.106 ((shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1))
                          shelly.1
                          2025-06-04 18:08:27.531	debug	[createObjects] Starting object creation of (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:08:25.936	info	[MQTT] Device with client id "shellyplus1-64b7080b3d78" connected from 192.168.171.80!
                          shelly.1
                          2025-06-04 18:08:25.936	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:08:25.936	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:08:25.935	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":98,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1-64b7080b3d78/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1-64b7080b3d78","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:08:25.934	debug	[MQTT Server] New connection from 192.168.171.80
                          shelly.1
                          2025-06-04 18:08:19.926	debug	[createObjects] Starting object creation of (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:08:17.685	info	[MQTT] Device with client id "shellyplus1-441793a712a8" connected from 192.168.171.106!
                          shelly.1
                          2025-06-04 18:08:17.685	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:08:17.684	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:08:17.684	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":88,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"Deckenlampe WZ/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1-441793a712a8","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:08:17.683	debug	[MQTT Server] New connection from 192.168.171.106
                          shelly.1
                          2025-06-04 18:08:17.499	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1"]
                          shelly.1
                          2025-06-04 18:08:15.545	debug	[MQTT Server] Close for 192.168.171.158 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:08:15.545	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:08:15.545	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: false
                          shelly.1
                          2025-06-04 18:08:15.545	debug	[BaseClient] Destroying (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1)
                          shelly.1
                          2025-06-04 18:08:15.545	info	[MQTT] Client Close: (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) (false)
                          shelly.1
                          2025-06-04 18:08:15.544	debug	[MQTT Server] End for 192.168.171.158 ((shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1))
                          shelly.1
                          2025-06-04 18:08:07.558	debug	[createObjects] Starting object creation of (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:08:05.547	info	[MQTT] Device with client id "shellypro3-2cbcbba79f0c" connected from 192.168.171.158!
                          shelly.1
                          2025-06-04 18:08:05.547	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:08:05.547	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:08:05.547	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":96,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellypro3-2cbcbba79f0c/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellypro3-2cbcbba79f0c","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:08:05.546	debug	[MQTT Server] New connection from 192.168.171.158
                          shelly.1
                          2025-06-04 18:07:40.291	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellypro3#2cbcbba79f0c#1"]
                          shelly.1
                          2025-06-04 18:07:38.514	debug	[MQTT Server] Close for 192.168.171.51 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:07:38.514	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:38.514	debug	[deviceStatusUpdate] shellyplus1pm#a8032ab96a08#1: false
                          shelly.1
                          2025-06-04 18:07:38.514	debug	[BaseClient] Destroying (shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1)
                          shelly.1
                          2025-06-04 18:07:38.514	info	[MQTT] Client Close: (shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1) (false)
                          shelly.1
                          2025-06-04 18:07:38.513	debug	[MQTT Server] End for 192.168.171.51 ((shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1))
                          shelly.1
                          2025-06-04 18:07:35.598	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellyplus1pm#a8032ab96a08#1","shellypro3#2cbcbba79f0c#1"]
                          shelly.1
                          2025-06-04 18:07:35.311	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellyplus1pm#a8032ab96a08#1"]
                          shelly.1
                          2025-06-04 18:07:35.211	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1"]
                          shelly.1
                          2025-06-04 18:07:34.156	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: true
                          shelly.1
                          2025-06-04 18:07:34.155	debug	[onlineCheck] Checking shellypro3#2cbcbba79f0c#1 on 192.168.171.158:80
                          shelly.1
                          2025-06-04 18:07:33.762	debug	[deviceStatusUpdate] shellyplus1pm#a8032ab96a08#1: true
                          shelly.1
                          2025-06-04 18:07:33.755	debug	[onlineCheck] Checking shellyplus1pm#a8032ab96a08#1 on 192.168.171.51:80
                          shelly.1
                          2025-06-04 18:07:33.500	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: true
                          shelly.1
                          2025-06-04 18:07:33.497	debug	[onlineCheck] Checking shellyplus1#64b7080b3d78#1 on 192.168.171.80:80
                          shelly.1
                          2025-06-04 18:07:30.743	debug	[deviceStatusUpdate] Online devices: []
                          shelly.1
                          2025-06-04 18:07:30.648	debug	[createObjects] Starting object creation of (shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:07:28.783	debug	[MQTT Server] Close for 192.168.171.80 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:07:28.783	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:28.783	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: false
                          shelly.1
                          2025-06-04 18:07:28.783	debug	[BaseClient] Destroying (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1)
                          shelly.1
                          2025-06-04 18:07:28.783	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) (false)
                          shelly.1
                          2025-06-04 18:07:28.782	debug	[MQTT Server] End for 192.168.171.80 ((shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1))
                          shelly.1
                          2025-06-04 18:07:28.519	info	[MQTT] Device with client id "shellyplus1pm-a8032ab96a08" connected from 192.168.171.51!
                          shelly.1
                          2025-06-04 18:07:28.519	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:28.519	debug	[BaseClient] Destroying 192.168.171.51 (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:07:28.519	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":102,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1pm-a8032ab96a08/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1pm-a8032ab96a08","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:07:28.518	debug	[MQTT Server] New connection from 192.168.171.51
                          shelly.1
                          2025-06-04 18:07:21.253	debug	[createObjects] Starting object creation of (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:07:18.785	info	[MQTT] Device with client id "shellyplus1-64b7080b3d78" connected from 192.168.171.80!
                          shelly.1
                          2025-06-04 18:07:18.785	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:18.785	debug	[BaseClient] Destroying 192.168.171.80 (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:07:18.785	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":98,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1-64b7080b3d78/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1-64b7080b3d78","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:07:18.783	debug	[MQTT Server] New connection from 192.168.171.80
                          shelly.1
                          2025-06-04 18:07:18.214	debug	[MQTT Server] Close for 192.168.171.106 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:07:18.214	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:18.214	debug	[deviceStatusUpdate] shellyplus1#441793a712a8#1: false
                          shelly.1
                          2025-06-04 18:07:18.213	debug	[BaseClient] Destroying (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1)
                          shelly.1
                          2025-06-04 18:07:18.213	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) (false)
                          shelly.1
                          2025-06-04 18:07:18.213	debug	[MQTT Server] End for 192.168.171.106 ((shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1))
                          shelly.1
                          2025-06-04 18:07:11.051	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1"]
                          shelly.1
                          2025-06-04 18:07:10.242	debug	[createObjects] Starting object creation of (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:07:09.297	debug	[MQTT Server] Close for 192.168.171.158 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:07:09.297	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:09.297	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: false
                          shelly.1
                          2025-06-04 18:07:09.297	debug	[BaseClient] Destroying (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1)
                          shelly.1
                          2025-06-04 18:07:09.297	info	[MQTT] Client Close: (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) (false)
                          shelly.1
                          2025-06-04 18:07:09.296	debug	[MQTT Server] End for 192.168.171.158 ((shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1))
                          shelly.1
                          2025-06-04 18:07:08.224	info	[MQTT] Device with client id "shellyplus1-441793a712a8" connected from 192.168.171.106!
                          shelly.1
                          2025-06-04 18:07:08.224	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:07:08.223	debug	[BaseClient] Destroying 192.168.171.106 (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:07:08.223	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":88,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"Deckenlampe WZ/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1-441793a712a8","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:07:08.222	debug	[MQTT Server] New connection from 192.168.171.106
                          shelly.1
                          2025-06-04 18:07:00.592	debug	[createObjects] Starting object creation of (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:06:59.307	info	[MQTT] Device with client id "shellypro3-2cbcbba79f0c" connected from 192.168.171.158!
                          shelly.1
                          2025-06-04 18:06:59.307	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:59.307	debug	[BaseClient] Destroying 192.168.171.158 (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:59.307	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":96,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellypro3-2cbcbba79f0c/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellypro3-2cbcbba79f0c","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:06:59.306	debug	[MQTT Server] New connection from 192.168.171.158
                          shelly.1
                          2025-06-04 18:06:40.257	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96a08"
                          shelly.1
                          2025-06-04 18:06:39.868	debug	[setIP] New IP for device undefined: 192.168.171.51 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.868	debug	[MQTT] Last will for client id "shellyplus1pm-a8032ab96a08" saved: {"retain":true,"qos":0,"topic":"shellyplus1pm-a8032ab96a08/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.868	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.828	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
                          shelly.1
                          2025-06-04 18:06:39.535	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-64b7080b3d78"
                          shelly.1
                          2025-06-04 18:06:39.535	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96a08"
                          shelly.1
                          shelly.1
                          2025-06-04 18:06:39.534	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a712a8"
                          shelly.1
                          2025-06-04 18:06:39.531	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-64b7080b3d78"
                          shelly.1
                          2025-06-04 18:06:39.531	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a712a8"
                          shelly.1
                          2025-06-04 18:06:39.530	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1pm-a8032ab96a08"
                          shelly.1
                          2025-06-04 18:06:39.530	debug	[setIP] New IP for device undefined: 192.168.171.158 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.529	debug	[MQTT] Last will for client id "shellypro3-2cbcbba79f0c" saved: {"retain":true,"qos":0,"topic":"shellypro3-2cbcbba79f0c/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.529	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.418	debug	[setIP] New IP for device undefined: 192.168.171.80 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.418	debug	[MQTT] Last will for client id "shellyplus1-64b7080b3d78" saved: {"retain":true,"qos":0,"topic":"shellyplus1-64b7080b3d78/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.418	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.418	debug	[setIP] New IP for device undefined: 192.168.171.51 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.418	debug	[MQTT] Last will for client id "shellyplus1pm-a8032ab96a08" saved: {"retain":true,"qos":0,"topic":"shellyplus1pm-a8032ab96a08/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          shelly.1
                          shelly.1
                          shelly.1
                          2025-06-04 18:06:39.417	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.417	debug	[setIP] New IP for device undefined: 192.168.171.106 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.417	debug	[MQTT] Last will for client id "shellyplus1-441793a712a8" saved: {"retain":true,"qos":0,"topic":"Deckenlampe WZ/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.416	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.416	debug	[setIP] New IP for device undefined: 192.168.171.80 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.416	debug	[MQTT] Last will for client id "shellyplus1-64b7080b3d78" saved: {"retain":true,"qos":0,"topic":"shellyplus1-64b7080b3d78/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          shelly.1
                          2025-06-04 18:06:39.416	debug	[setIP] New IP for device undefined: 192.168.171.106 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.415	debug	[MQTT] Last will for client id "shellyplus1-441793a712a8" saved: {"retain":true,"qos":0,"topic":"Deckenlampe WZ/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.415	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.414	debug	[setIP] New IP for device undefined: 192.168.171.51 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.414	debug	[MQTT] Last will for client id "shellyplus1pm-a8032ab96a08" saved: {"retain":true,"qos":0,"topic":"shellyplus1pm-a8032ab96a08/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.414	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.414	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
                          shelly.1
                          2025-06-04 18:06:39.413	error	[MQTT] Unable to get mqttprefix of client with id "shellypro3-2cbcbba79f0c"
                          shelly.1
                          2025-06-04 18:06:39.372	error	[MQTT] Unable to get mqttprefix of client with id "shellyplus1-441793a712a8"
                          shelly.1
                          2025-06-04 18:06:39.026	debug	[setIP] New IP for device undefined: 192.168.171.158 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.025	debug	[MQTT] Last will for client id "shellypro3-2cbcbba79f0c" saved: {"retain":true,"qos":0,"topic":"shellypro3-2cbcbba79f0c/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.025	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:39.025	debug	[setIP] New IP for device undefined: 192.168.171.158 (source: MQTT connect)
                          shelly.1
                          shelly.1
                          shelly.1
                          2025-06-04 18:06:39.024	debug	[setIP] New IP for device undefined: 192.168.171.106 (source: MQTT connect)
                          shelly.1
                          2025-06-04 18:06:39.023	debug	[MQTT] Last will for client id "shellyplus1-441793a712a8" saved: {"retain":true,"qos":0,"topic":"Deckenlampe WZ/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}}
                          shelly.1
                          2025-06-04 18:06:39.023	debug	[createObjects] Finished object creation of (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:34.092	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellypro3#2cbcbba79f0c#1"]
                          shelly.1
                          2025-06-04 18:06:34.085	debug	[deviceStatusUpdate] Online devices: ["shellyplus1pm#a8032ab96a08#1","shellyplus1#64b7080b3d78#1","shellypro3#2cbcbba79f0c#1"]
                          shelly.1
                          2025-06-04 18:06:33.382	debug	[deviceStatusUpdate] Online devices: ["shellyplus1pm#a8032ab96a08#1","shellyplus1#64b7080b3d78#1"]
                          shelly.1
                          2025-06-04 18:06:32.808	debug	[MQTT Server] Close for 192.168.171.51 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:06:32.805	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:32.805	debug	[deviceStatusUpdate] shellyplus1pm#a8032ab96a08#1: false
                          shelly.1
                          2025-06-04 18:06:32.804	debug	[BaseClient] Destroying (shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1)
                          shelly.1
                          2025-06-04 18:06:32.804	info	[MQTT] Client Close: (shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1) (false)
                          shelly.1
                          2025-06-04 18:06:32.803	debug	[MQTT Server] End for 192.168.171.51 ((shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1))
                          shelly.1
                          2025-06-04 18:06:32.487	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: true
                          shelly.1
                          2025-06-04 18:06:32.485	debug	[onlineCheck] Checking shellypro3#2cbcbba79f0c#1 on 192.168.171.158:80
                          shelly.1
                          2025-06-04 18:06:32.311	debug	[deviceStatusUpdate] shellyplus1pm#a8032ab96a08#1: true
                          shelly.1
                          2025-06-04 18:06:32.308	debug	[onlineCheck] Checking shellyplus1pm#a8032ab96a08#1 on 192.168.171.51:80
                          shelly.1
                          2025-06-04 18:06:31.887	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: true
                          shelly.1
                          2025-06-04 18:06:31.879	debug	[onlineCheck] Checking shellyplus1#64b7080b3d78#1 on 192.168.171.80:80
                          shelly.1
                          2025-06-04 18:06:26.140	debug	[deviceStatusUpdate] Online devices: ["shellyplus1pm#a8032ab96a08#1"]
                          shelly.1
                          2025-06-04 18:06:24.853	debug	[createObjects] Starting object creation of (shellyplus1pm / shellyplus1pm-a8032ab96a08 / shellyplus1pm#a8032ab96a08#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:06:24.314	debug	[MQTT Server] Close for 192.168.171.80 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:06:24.314	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:24.314	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: false
                          shelly.1
                          2025-06-04 18:06:24.314	debug	[BaseClient] Destroying (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1)
                          shelly.1
                          2025-06-04 18:06:24.314	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) (false)
                          shelly.1
                          2025-06-04 18:06:24.313	debug	[MQTT Server] End for 192.168.171.80 ((shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1))
                          shelly.1
                          2025-06-04 18:06:22.807	info	[MQTT] Device with client id "shellyplus1pm-a8032ab96a08" connected from 192.168.171.51!
                          shelly.1
                          2025-06-04 18:06:22.807	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:22.807	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:22.807	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":102,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1pm-a8032ab96a08/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1pm-a8032ab96a08","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:06:22.806	debug	[MQTT Server] New connection from 192.168.171.51
                          shelly.1
                          2025-06-04 18:06:15.767	debug	[createObjects] Starting object creation of (shellyplus1 / shellyplus1-64b7080b3d78 / shellyplus1#64b7080b3d78#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:06:14.321	info	[MQTT] Device with client id "shellyplus1-64b7080b3d78" connected from 192.168.171.80!
                          shelly.1
                          2025-06-04 18:06:14.321	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:14.321	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:06:14.321	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":98,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellyplus1-64b7080b3d78/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1-64b7080b3d78","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:06:14.320	debug	[MQTT Server] New connection from 192.168.171.80
                          shelly.1
                          2025-06-04 18:06:08.615	debug	[MQTT Server] Close for 192.168.171.106 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:06:08.615	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:08.615	debug	[deviceStatusUpdate] shellyplus1#441793a712a8#1: false
                          shelly.1
                          2025-06-04 18:06:08.615	debug	[BaseClient] Destroying (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1)
                          shelly.1
                          2025-06-04 18:06:08.615	info	[MQTT] Client Close: (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) (false)
                          shelly.1
                          2025-06-04 18:06:08.614	debug	[MQTT Server] End for 192.168.171.106 ((shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1))
                          shelly.1
                          2025-06-04 18:06:02.704	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellyplus1pm#a8032ab96a08#1"]
                          shelly.1
                          2025-06-04 18:06:01.409	debug	[MQTT Server] Close for 192.168.171.158 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:06:01.409	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:06:01.408	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: false
                          shelly.1
                          2025-06-04 18:06:01.408	debug	[BaseClient] Destroying (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1)
                          shelly.1
                          2025-06-04 18:06:01.408	info	[MQTT] Client Close: (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) (false)
                          shelly.1
                          2025-06-04 18:06:01.407	debug	[MQTT Server] End for 192.168.171.158 ((shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1))
                          shelly.1
                          2025-06-04 18:06:00.522	debug	[createObjects] Starting object creation of (shellyplus1 / shellyplus1-441793a712a8 / shellyplus1#441793a712a8#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:05:58.624	info	[MQTT] Device with client id "shellyplus1-441793a712a8" connected from 192.168.171.106!
                          shelly.1
                          2025-06-04 18:05:58.624	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:05:58.624	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:05:58.623	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":88,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"Deckenlampe WZ/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellyplus1-441793a712a8","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:05:58.622	debug	[MQTT Server] New connection from 192.168.171.106
                          shelly.1
                          2025-06-04 18:05:53.005	debug	[createObjects] Starting object creation of (shellypro3 / shellypro3-2cbcbba79f0c / shellypro3#2cbcbba79f0c#1) for mode: <not set>
                          shelly.1
                          2025-06-04 18:05:51.418	info	[MQTT] Device with client id "shellypro3-2cbcbba79f0c" connected from 192.168.171.158!
                          shelly.1
                          2025-06-04 18:05:51.418	debug	[MQTT] Destroying
                          shelly.1
                          2025-06-04 18:05:51.418	debug	[BaseClient] Destroying (undefined / undefined / undefined)
                          shelly.1
                          2025-06-04 18:05:51.418	debug	[MQTT] Client connected: {"cmd":"connect","retain":false,"qos":0,"dup":false,"length":96,"topic":null,"payload":null,"protocolId":"MQTT","protocolVersion":4,"will":{"retain":true,"qos":0,"topic":"shellypro3-2cbcbba79f0c/online","payload":{"type":"Buffer","data":[102,97,108,115,101]}},"clean":true,"keepalive":60,"clientId":"shellypro3-2cbcbba79f0c","username":"Clients","password":{"type":"Buffer","data":[76,97,108,101,108,105,115,115,121,49,52]}}
                          shelly.1
                          2025-06-04 18:05:51.416	debug	[MQTT Server] New connection from 192.168.171.158
                          shelly.1
                          2025-06-04 18:05:32.222	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellyplus1pm#a8032ab96a08#1","shellypro3#2cbcbba79f0c#1"]
                          shelly.1
                          2025-06-04 18:05:31.859	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1","shellyplus1pm#a8032ab96a08#1"]
                          shelly.1
                          2025-06-04 18:05:31.555	debug	[deviceStatusUpdate] Online devices: ["shellyplus1#64b7080b3d78#1"]
                          shelly.1
                          2025-06-04 18:05:30.854	debug	[deviceStatusUpdate] shellypro3#2cbcbba79f0c#1: true
                          shelly.1
                          2025-06-04 18:05:30.853	debug	[onlineCheck] Checking shellypro3#2cbcbba79f0c#1 on 192.168.171.158:80
                          shelly.1
                          2025-06-04 18:05:30.298	debug	[deviceStatusUpdate] shellyplus1pm#a8032ab96a08#1: true
                          shelly.1
                          2025-06-04 18:05:30.295	debug	[onlineCheck] Checking shellyplus1pm#a8032ab96a08#1 on 192.168.171.51:80
                          shelly.1
                          2025-06-04 18:05:30.212	debug	[deviceStatusUpdate] shellyplus1#64b7080b3d78#1: true
                          shelly.1
                          2025-06-04 18:05:30.208	debug	[onlineCheck] Checking shellyplus1#64b7080b3d78#1 on 192.168.171.80:80
                          shelly.1
                          2025-06-04 18:05:24.448	debug	[deviceStatusUpdate] Online devices: []
                          shelly.1
                          2025-06-04 18:05:23.155	debug	[MQTT Server] Close for 192.168.171.51 ((undefined / undefined / undefined))
                          shelly.1
                          2025-06-04 18:05:23.155	debug	[MQTT] Destroying
                          Peter V. mcm1957 2 Replies Last reply Reply Quote 0
                          • Peter V.
                            Peter V. @gelberlemmy last edited by Peter V.
                            @gelberlemmy
                            Meine Geräte sind über die FritzBox ins Inet gesperrt, daher ohne Passwort.
                            Ich teste mal mit Passwort, evtl gibts da Probleme.
                            Update: ShellyPlusPlugS (Gen2) getestet mit Passwort, funktioniert ohne Probleme.
                            mcm1957 gelberlemmy 2 Replies Last reply Reply Quote 0
                            • mcm1957
                              mcm1957 @Peter V. last edited by
                              @peter-v
                              ein mqtt user und passwort wird IMMER benötigt.
                              Peter V. 1 Reply Last reply Reply Quote 2
                                keineAhnungvonProgrmieren @mcm1957 last edited by
                                @mcm1957
                                Ich bin mir nicht sicher ob mein Problem hier richtig ist. Ich habe die Aktuelle version (V9.5.1) des Shelly adapters installiert. Bei meinem Shelly2PM Gen2 mit Addon werden zwar die Datenpunkte angelegt aber die Werte werden nicht aktualisiert ( überall 0) einbindung ist via Mqtt. Die restlichen Funktionen funktionieren, es sind nur die Addon daten betroffen.
                                Bisher habe ich den adapter neugestartet, unter objekte den shelly gelöscht ( anschliesend reeboot des Shelly) alle datenpunkte wurden wieder neu angelegt, leider alles ohne den gewünschten effekt. mit den MQTT einstellungen in der weboberfläche des shelly gespielt ( MQTT passwort immer wieder neu eingetragen)
                                Danke für die Hilfe
                                • gelberlemmy
                                  gelberlemmy @Peter V. last edited by
                                  @peter-v okay danke. Ich glaube, ich werde die Instanz einfach noch einmal entfernen und neu aufsetzen. Neustart vom IOBroker hat auch keine Wirkung gezeigt. Das kann ein echt wahnsinnig machen…
                                  • mcm1957
                                    @gelberlemmy
                                    Zumindest auf dem Bild
                                    https://forum.iobroker.net/assets/uploads/files/1749053259231-screenshot-2025-06-04-180654.png
                                    hast du im Adapter Prot 1888 und im Shelly port 1882 eingestellt. Das kann so nicht gehen.
                                    Ebenso würde ich empfehlen Listen on all Ports zu aktivieren wenn es in deinem Setup keinen besonderen Grund gibt den Adapter auf ein Netzwerk zu beschränken:
                                    • mcm1957
                                      mcm1957 @keineAhnungvonProgrmieren last edited by
                                      @keineahnungvonprogrmieren said in Test Adapter shelly - ALPHA Versionen:
                                      @mcm1957
                                      Danke für die Hilfe
                                      Na ja - mit einer ALPHA Version hat das Problem nichts zu tun. Ergo ja, nicht wirklich richtig,
                                      ABER such ma mal...
                                      Welcher Shelly ist das genau? Bitte um die device ID. Ich vermute mal shellyplus2pm... (Shelly2PM Gen2 hab ich als offizielle bezeichnung im Moment nicht gefunden).
                                      Wenn ich es richtig verstanden habe funktioniert die Kommunikation mit dem Grundgerät (Shelly2PM Gen2) einwandfrei. Es werden States angelegt und aktualisisert. OK?
                                      Wenn das stimmt, dann muss die MQTT Config mal OK sein.
                                      Für das AddOn sollten die entsprechenden States (ext.*) immer angelegt werden. Ich vermute das werden sie.
                                      Hast du die addOn Komponenten im Shelly eingerichtet und funktionieren sie dort? Was hast du am addOn angeschlossen?
                                        @mcm1957 said in Test Adapter shelly - ALPHA Versionen:
                                        @mcm1957
                                        Danke für die Hilfe
                                        ABER such ma mal...
                                        Ok, sorry fürs falsche Posten und danke fürs trotzdem helfen.
                                        Du Hast mich richitg verstanden, Grundgerät Funktioniert, es ist der Plus2PM der Gen2. Ich benutze die Voltmeter funktion um einen Drucksensor via Spannungsteiler auszulesen ( Füllstandserfassung Zisterne)
                                        Die Datenpunkte werden angelegt aber nicht "beschrieben"
                                        So habe ich die MQTT einstellungen aktuell:
                                        mcm1957 fuzzy1955 2 Replies Last reply Reply Quote 0
                                        • mcm1957
                                          Also ich hab im Moment keine Ahnung wos da klemmt. Sieht eigentlich alles gut aus.
                                          Bitte erstell mal ein Log mit Level DEBUG und poste den Output von http://device-ip/rpc/Shelly.GetStatus
                                          ABER MOMENT MAL:
                                          Ändert sich der Spannungswert? Wenn ich mich richtig erinnere haben die Shellies eine (zumindest beim Uni einstellbare) Hysterese u die sich der Spannungswert ändern muss damit er gesendet wird. Kannst du das mal beobachten / testen?
                                            ABER MOMENT MAL:
                                            F..... genau das wars. die Hysterese ist auf dem kleinsten wert 0,1V da die Zisterne gerade oberkannte ist hat sich der wert nicht aktualisiert.
                                            Habe den sensor kurz raus und wieder rein dann hat sich der wert aktualisiert.
                                            Jetzt funktioniert wieder alles.
                                            Vielen Dank
                                            mcm1957 shelly
                                            15
                                            137
                                            14634
