    4. Test Adapter Philips-TV v0.2.x
    • N
      NemoN last edited by
      @AlCalzone:
      @integer63:
      PS: die richtige URL lautet: http://ip-des-tv:1925/5/system Schade, ein paar Posts drüber war es ohne die /5 angegeben. Ich hatte gehofft, dass man daran direkt die API-Version erkennen kann, ohne zu raten.
      URL:
      http://192.168.5.109:1925/system
      http://192.168.5.109:1925/6/system
      Response-Header:
      Accept-Ranges:bytes
      Access-Control-Allow-Origin:*
      Content-Encoding:gzip
      Content-Type:application/json; charset=UTF-8
      Date:Tue, 30 Jan 2018 11:40:03 GMT+00:00
      Server:Restlet-Framework/2.3.8
      Transfer-Encoding:chunked
      Content:
         "notifyChange":"http",
         "menulanguage":"German",
         "name":"PhilipsOLED",
         "country":"Germany",
         "serialnumber_encrypted":"xxx\n",
         "model_encrypted":"0TlSon\/ebQi9LfVUF1IE3ozM9uApFnbV2dcv2DgpJbE=\n",
         "deviceid_encrypted":"xxx\n",
         "nettvversion":"8.0.0",
         "epgsource":"one",
         "api_version":{
            "Major":6,
            "Minor":1,
            "Patch":0
         "featuring":{
            "jsonfeatures":{
               "editfavorites":[
                  "TVChannels",
                  "SatChannels"
               "recordings":[
                  "List",
                  "Schedule",
                  "Manage"
               "ambilight":[
                  "LoungeLight",
                  "Hue",
                  "Ambilight"
               "menuitems":[
                  "Setup_Menu"
               "textentry":[
                  "context_based",
                  "initial_string_available",
                  "editor_info_available"
               "applications":[
                  "TV_Apps",
                  "TV_Games",
                  "TV_Settings"
               "pointer":[
                  "not_available"
               "inputkey":[
                  "key"
               "activities":[
                  "intent"
               "channels":[
                  "preset_string"
               "mappings":[
                  "server_mapping"
            "systemfeatures":{
               "tvtype":"consumer",
               "content":[
                  "dmr",
                  "pvr"
               "tvsearch":"intent",
               "pairing_type":"digest_auth_pairing",
               "secured_transport":"true",
               "companion_screen":"true"
      • AlCalzone
        @NemoN:
        philips-tv.0	2018-01-30 12:34:03.943	debug	connection is DEAD. reason: Cannot read property 'username' of undefined
        Danke und nochmal bitte mit alpha-3 (selbe Quelle).
        • N
          @AlCalzone:
          Danke und nochmal bitte mit alpha-3 (selbe Quelle). `
          philips-tv.0	2018-01-30 14:10:44.835	debug	Could not initialize connection. Reason: No connection to host 192.168.5.109
          philips-tv.0	2018-01-30 14:10:44.835	debug	connection is DEAD. reason: Error: socket hang up
          philips-tv.0	2018-01-30 14:10:44.831	debug	checking if connection is alive
          philips-tv.0	2018-01-30 14:10:44.830	debug	testing APIv6
          philips-tv.0	2018-01-30 14:10:44.817	debug	connection is ALIVE
          philips-tv.0	2018-01-30 14:10:44.808	debug	checking if connection is alive
          philips-tv.0	2018-01-30 14:10:44.806	debug	testing APIv5
          philips-tv.0	2018-01-30 14:10:44.794	debug	connection is ALIVE
          philips-tv.0	2018-01-30 14:10:44.782	debug	checking if connection is alive
          philips-tv.0	2018-01-30 14:10:44.782	debug	testing APIv1
          philips-tv.0	2018-01-30 14:10:44.781	debug	detecting API version
          philips-tv.0	2018-01-30 14:10:44.780	debug	initializing connection to 192.168.5.109
          manueller aufruf von http://192.168.5.109:1925/6/system klappt weiterhin
          • AlCalzone
            @NemoN:
            manueller aufruf von http://192.168.5.109:1925/6/system klappt weiterhin `
            Danke, und selbes Spiel nochmal bitte. Ich glaube jetzt war es nur noch ein Tippfehler (https-Port 1925 statt 1926).
            • N
              @AlCalzone:
              Danke, und selbes Spiel nochmal bitte. Ich glaube jetzt war es nur noch ein Tippfehler (https-Port 1925 statt 1926). `
              philips-tv.0	2018-01-30 14:45:32.768	debug	Could not initialize connection. Reason: No connection to host 192.168.5.109
              philips-tv.0	2018-01-30 14:45:32.767	debug	connection is DEAD. Reason: [undefined] Error: self signed certificate in certificate chain
              philips-tv.0	2018-01-30 14:45:32.673	debug	checking if connection is alive
              philips-tv.0	2018-01-30 14:45:32.672	debug	testing APIv6
              philips-tv.0	2018-01-30 14:45:32.656	debug	connection is ALIVE
              philips-tv.0	2018-01-30 14:45:32.647	debug	checking if connection is alive
              philips-tv.0	2018-01-30 14:45:32.645	debug	testing APIv5
              philips-tv.0	2018-01-30 14:45:32.634	debug	connection is ALIVE
              philips-tv.0	2018-01-30 14:45:32.616	debug	checking if connection is alive
              philips-tv.0	2018-01-30 14:45:32.616	debug	testing APIv1
              philips-tv.0	2018-01-30 14:45:32.616	debug	detecting API version
              philips-tv.0	2018-01-30 14:45:32.615	debug	initializing connection to 192.168.5.109
              probier mal bei den reqOps –> insecure: true einzufügen
              • AlCalzone
                Ein Tester, der die Lösung gleich mitliefert. So lobe ich mir das! Darfst gleich nochmal probieren 😄
                • integer63
                  integer63 last edited by
                  Also bei mir (/5) bleibt die Instanz auch noch bei gelb hängen - hier das Log:
                  philips-tv.0	2018-01-30 16:19:54.050	debug	Could not initialize connection. Reason: No connection to host 192.168.11.118
                  philips-tv.0	2018-01-30 16:19:54.048	debug	connection is DEAD. Reason: [undefined] Error: ESOCKETTIMEDOUT
                  philips-tv.0	2018-01-30 16:19:49.011	debug	checking if connection is alive
                  philips-tv.0	2018-01-30 16:19:49.008	debug	testing APIv5
                  philips-tv.0	2018-01-30 16:18:48.992	debug	connection is ALIVE
                  philips-tv.0	2018-01-30 16:18:46.770	debug	checking if connection is alive
                  philips-tv.0	2018-01-30 16:18:46.769	debug	testing APIv1
                  philips-tv.0	2018-01-30 16:18:46.769	debug	detecting API version
                  philips-tv.0	2018-01-30 16:18:46.768	debug	initializing connection to 192.168.11.118
                  philips-tv.0	2018-01-30 16:18:36.712	debug	Could not initialize connection. Reason: No connection to host 192.168.11.118
                  philips-tv.0	2018-01-30 16:18:36.709	debug	connection is DEAD. Reason: [undefined] Error: ESOCKETTIMEDOUT
                  philips-tv.0	2018-01-30 16:18:31.689	debug	state with id philips-tv.0.info.connection updated: ack=true; val=false
                  philips-tv.0	2018-01-30 16:18:31.682	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":false,"ack":true,"ts":1517325511663,"q":0,"from":"system.adapter.philips-tv.0","lc":1516915053497}
                  philips-tv.0	2018-01-30 16:18:31.639	debug	checking if connection is alive
                  philips-tv.0	2018-01-30 16:18:31.635	debug	testing APIv1
                  philips-tv.0	2018-01-30 16:18:31.634	debug	detecting API version
                  philips-tv.0	2018-01-30 16:18:31.626	debug	initializing connection to 192.168.11.118
                  philips-tv.0	2018-01-30 16:18:31.507	info	starting. Version 0.3.0-alpha3 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.11.4
                  philips-tv.0	2018-01-30 16:18:30.318	info	States connected to redis: 192.168.11.33:6379
                  philips-tv.0	2018-01-30 16:18:30.306	debug	statesDB connected
                  philips-tv.0	2018-01-30 16:18:30.252	debug	objectDB connected
                  • N
                    @AlCalzone:
                    Ein Tester, der die Lösung gleich mitliefert. So lobe ich mir das! Darfst gleich nochmal probieren 😄 `
                    leider immer noch…
                    philips-tv.0	2018-01-30 16:28:15.886	debug	Could not initialize connection. Reason: No connection to host 192.168.5.109
                    philips-tv.0	2018-01-30 16:28:15.886	debug	connection is DEAD. Reason: [undefined] Error: self signed certificate in certificate chain
                    philips-tv.0	2018-01-30 16:28:15.800	debug	checking if connection is alive
                    philips-tv.0	2018-01-30 16:28:15.797	debug	testing APIv6
                    philips-tv.0	2018-01-30 16:28:15.785	debug	connection is ALIVE
                    philips-tv.0	2018-01-30 16:28:15.776	debug	checking if connection is alive
                    philips-tv.0	2018-01-30 16:28:15.775	debug	testing APIv5
                    philips-tv.0	2018-01-30 16:28:15.761	debug	connection is ALIVE
                    philips-tv.0	2018-01-30 16:28:15.755	debug	checking if connection is alive
                    philips-tv.0	2018-01-30 16:28:15.755	debug	testing APIv1
                    philips-tv.0	2018-01-30 16:28:15.755	debug	detecting API version
                    philips-tv.0	2018-01-30 16:28:15.753	debug	initializing connection to 192.168.5.109
                    • AlCalzone
                      @integer63:
                      Also bei mir (/5) bleibt die Instanz auch noch bei gelb hängen - hier das Log: `
                      Danke auch dafür. Anscheinend frage ich den TV zu schnell an oder ähnliches - muss die Logik nochmal etwas überdenken.
                      • N
                        Evtl. klappt es wenn du die TV certificate als cabundle mit aufnimmst:
                        $ openssl s_client -connect 192.168.5.109:1926 -showcerts
                        CONNECTED(00000003)
                        depth=2 C = IN, ST = Karnataka, L = Bengaluru, O = TP VISION India Pvt. Ltd., OU = TP VISION, CN = www.tpvision.com
                        verify error:num=19:self signed certificate in certificate chain
                        Certificate chain
                         0 s:/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=Smart TV/CN=restfultv.tpvision.com
                           i:/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=Smart TV/CN=ca.tpvision.com
                        -----BEGIN CERTIFICATE-----
                        MIIEMjCCAxqgAwIBAgIJAJKPYEwkSq5tMA0GCSqGSIb3DQEBBQUAMIGGMQswCQYD
                        VQQGEwJJTjESMBAGA1UECBMJS2FybmF0YWthMRIwEAYDVQQHEwlCZW5nYWx1cnUx
                        IjAgBgNVBAoTGVRQIFZJU0lPTiBJbmRpYSBQdnQuIEx0ZC4xETAPBgNVBAsTCFNt
                        YXJ0IFRWMRgwFgYDVQQDEw9jYS50cHZpc2lvbi5jb20wHhcNMTUwNTE5MTA1MTUz
                        WhcNNDIxMDA0MTA1MTUzWjCBjTELMAkGA1UEBhMCSU4xEjAQBgNVBAgTCUthcm5h
                        dGFrYTESMBAGA1UEBxMJQmVuZ2FsdXJ1MSIwIAYDVQQKExlUUCBWSVNJT04gSW5k
                        aWEgUHZ0LiBMdGQuMREwDwYDVQQLEwhTbWFydCBUVjEfMB0GA1UEAxMWcmVzdGZ1
                        bHR2LnRwdmlzaW9uLmNvbTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEB
                        AMNtE5UcxOk3h3LpsIwNmuIs7pvG3XDDymH8qPf+PutUcxY5L2way++KnxaakN8k
                        tqggw4lIbjuITfj9unrUJvnH32dvtAExWSz9+JV1SLllQhy28034F90SA4Bj39az
                        bmKlJZirtfsAmztks8PY7avtO0L+hUv324/5RcTXq77bg2Uw+UYn9uegj2qL6oxp
                        PWkuT4jFpvbOKax8YB3NZotHlsuk4+BJ/sxlKLOGC5buWzQt8N8jmvsAYx95P+lk
                        kTx+VJoixVoAf9ZPadvZXdWI9W/iMh/2FLjHbhZcadEpeDNQRCbxPxIhgNWiti4M
                        y3D37xV9tarQKKcx2Ql99QsCAwEAAaOBmTCBljAfBgNVHSMEGDAWgBRm9HKG4Yd9
                        YfbWbFry15vzoQm7sjAJBgNVHRMEAjAAMB0GA1UdDgQWBBSMBkCu30VU72xEjXeg
                        vIhOniiVnjBJBgNVHREEQjBAghZyZXN0ZnVsdHYudHB2aXNpb24uY29tghB4dHYu
                        dHB2aXNpb24uY29tghRkcm9pZHR2LnRwdmlzaW9uLmNvbTANBgkqhkiG9w0BAQUF
                        AAOCAQEAemrEIsY6w7C5xzG5+hqNQDdA0xuz/oTBXMoPB/JDh0fFpfM1UfHu3w3q
                        GwLGnnzS2cpQqVlwS1OIsgoEXDQDkdsaeZnn3aaMxsFAFl7FrSAn+CWAtgKijNHv
                        yoSSTLz8oAbz1R+N6HXxa7EO7uPFavMv6Zg3rbP0aIFBWUJk0xpdM4LWRaZ/Dyoh
                        af07S6UteuAZL+cAQbwk8ufqOnIm0KEuXTHud9ksNVgirvDGgUz3Zeu/7f3LDjqN
                        nh0RixJ0DhHLjU9+QKMtdsG6BqetRl+HwBuOkvSHxuQ98PEFc2ilrTLCxDgG9Fy9
                        fYxpdXpTvk7TLHrG1fSS/0c2ke0h5g==
                        -----END CERTIFICATE-----
                         1 s:/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=Smart TV/CN=ca.tpvision.com
                           i:/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=TP VISION/CN=www.tpvision.com
                        MIID6TCCAtGgAwIBAgIJALuxCxdWoriMMA0GCSqGSIb3DQEBBQUAMIGIMQswCQYD
                        IjAgBgNVBAoTGVRQIFZJU0lPTiBJbmRpYSBQdnQuIEx0ZC4xEjAQBgNVBAsTCVRQ
                        IFZJU0lPTjEZMBcGA1UEAxMQd3d3LnRwdmlzaW9uLmNvbTAeFw0xNTA1MTkxMDQ0
                        NTdaFw00MjEwMDQxMDQ0NTdaMIGGMQswCQYDVQQGEwJJTjESMBAGA1UECBMJS2Fy
                        bmF0YWthMRIwEAYDVQQHEwlCZW5nYWx1cnUxIjAgBgNVBAoTGVRQIFZJU0lPTiBJ
                        bmRpYSBQdnQuIEx0ZC4xETAPBgNVBAsTCFNtYXJ0IFRWMRgwFgYDVQQDEw9jYS50
                        cHZpc2lvbi5jb20wggEiMA0GCSqGSIb3DQEBAQUAA4IBDwAwggEKAoIBAQDEsHQM
                        +wsKhypGz+7TB9vhTIQOyUoUZqi64tL22I6r5GA9PF0lgYiV5JBksqBGr7FLI0rg
                        XNVhlb5J0XXZ+97JKgYJySJrZ49EJXQlPVR89wPbN1XB6EnbNQn9Q9xEfkUR0Btc
                        NnA3PHJUgGXSgJfLGVlDhSnf+2JEpY+9d5nKRyvTLj06Dwow4PsHhaj/xRkWtznb
                        RaKnpGG/XXrcvlMnGHTUERQSjWwlij4R7ZtktL+xah9B8qnkYOxu22fttVBhzEHJ
                        N67Ylwfphl+FxcWQig7KH/c9fntcMNvhUOpFnvRHKfb7RbO739gftTaaWtMK5RWX
                        FJiFaK4c18k7rDwlAgMBAAGjVjBUMB8GA1UdIwQYMBaAFJWDH8OSdYJhVqYcddUI
                        rFR+0EkxMB0GA1UdDgQWBBRm9HKG4Yd9YfbWbFry15vzoQm7sjASBgNVHRMBAf8E
                        CDAGAQH/AgEAMA0GCSqGSIb3DQEBBQUAA4IBAQCw4YWeHWQgps35qymTKi4kXJ2g
                        U0oEEjUbm3ZeDC/ZHUlzQxdgKf97wYbQKE+oA0N3N9sTmpaP0r4XpKSnVSdiI+T2
                        KjZCz5+AoiYLUBeTRiddUYJFAGCYtmMvwATSSa/ZWtDIZS/Dz86ogwMnvITAOyQD
                        LV69SPnZdJwPie3u/kB3TaLLd/qtCbkGv0ZftFi3t7MdCcyo3Bf2xdYO65LarbHp
                        62IyjmqXFE2l1WzwKm0MwlWb0BrW5spvRjd/MW0lC0MWoCbbiTwGj/jVzy+Czy2I
                        mJ90uz0h0g0wrUqgRxSNWW4utPJeghJqcmUJJPQHFvcXK/523n9hTF9JS0tj
                         2 s:/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=TP VISION/CN=www.tpvision.com
                        MIIEhjCCA26gAwIBAgIJAOWvBIoQYKDWMA0GCSqGSIb3DQEBBQUAMIGIMQswCQYD
                        IFZJU0lPTjEZMBcGA1UEAxMQd3d3LnRwdmlzaW9uLmNvbTAeFw0xNTA1MTkxMDIz
                        NDZaFw00MjEwMDQxMDIzNDZaMIGIMQswCQYDVQQGEwJJTjESMBAGA1UECBMJS2Fy
                        bmRpYSBQdnQuIEx0ZC4xEjAQBgNVBAsTCVRQIFZJU0lPTjEZMBcGA1UEAxMQd3d3
                        LnRwdmlzaW9uLmNvbTCCASIwDQYJKoZIhvcNAQEBBQADggEPADCCAQoCggEBAN1K
                        RSih+/TTPcfWSoCgZnNd9pSCeYGVeCo0eYazxRWcWr32KPOhzmBrBVJFG9jL0/sQ
                        XgFMvCoFoh2uQhjiL5fiBzk4tYzrFV15a2+x+PsTu7j0C6zpuxo8JQ3+47wwNqZi
                        SOWg9cViSSboTKVx+UGtWiuj17ucYspeuHNEvz/WKwhOmx53tONnkhlbgk+3CKKe
                        1yrBZhx1itqLTM+7f2n++TQyym51OHFQPAYfuBsxjcF2EZrlUs9ptSc6lobm3yGw
                        PV7TD4fY63a72+rr6Kkp0UcNNywWEcmxs3IWXbFK1NWzY3n7UiP8ZLBAl2Uke4YV
                        xkGSyVz+H2NAUwLPP7UCAwEAAaOB8DCB7TAdBgNVHQ4EFgQUlYMfw5J1gmFWphx1
                        1QisVH7QSTEwgb0GA1UdIwSBtTCBsoAUlYMfw5J1gmFWphx11QisVH7QSTGhgY6k
                        gYswgYgxCzAJBgNVBAYTAklOMRIwEAYDVQQIEwlLYXJuYXRha2ExEjAQBgNVBAcT
                        CUJlbmdhbHVydTEiMCAGA1UEChMZVFAgVklTSU9OIEluZGlhIFB2dC4gTHRkLjES
                        MBAGA1UECxMJVFAgVklTSU9OMRkwFwYDVQQDExB3d3cudHB2aXNpb24uY29tggkA
                        5a8EihBgoNYwDAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQUFAAOCAQEAvK4VcTLu
                        8xaSCC5+LAvl8VkFIA3cEDOiZrAh1acpQA+prGnawDjP74dJeFPgxvbL3rsnOoDz
                        w0OumnQGZDD/vWFTBF3Yua8o/Aq8klvAWHzd3NH9ECydtyP1PreT2i49ulmc2LCO
                        gvpqZt88RItS67+P7Or9FtYL3X0CwjyjBF67oRXLoW0l4i6Ig3txkvMWd1KkHIqr
                        VMR/CW1XcmVFE0BUp8y70zI/UFLMTPbBtkMBuSGGt4WJVGyqud9VX7VJ2O8QcVmF
                        ynRq1DdD57esAUCv4h9ARawnfmBrPffytglpNxn2ca7+JVL0k/X71wpr6NAXwVZZ
                        nCj6DjKWcKBAwg==
                        Server certificate
                        subject=/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=Smart TV/CN=restfultv.tpvision.com
                        issuer=/C=IN/ST=Karnataka/L=Bengaluru/O=TP VISION India Pvt. Ltd./OU=Smart TV/CN=ca.tpvision.com
                        No client certificate CA names sent
                        Peer signing digest: SHA512
                        Server Temp Key: ECDH, P-256, 256 bits
                        SSL handshake has read 3756 bytes and written 434 bytes
                        New, TLSv1/SSLv3, Cipher is ECDHE-RSA-AES256-GCM-SHA384
                        Server public key is 2048 bit
                        Secure Renegotiation IS supported
                        Compression: NONE
                        Expansion: NONE
                        No ALPN negotiated
                        SSL-Session:
                            Protocol  : TLSv1.2
                            Cipher    : ECDHE-RSA-AES256-GCM-SHA384
                            Session-ID: AC638C487B764881D53A5FCAE795C2ED4B7FFAFE801643B355573C29A865A8E1
                            Session-ID-ctx:
                            Master-Key: 94CF9091085C539CA03BEC64CD7D6E57A8575440CA5D11EFE070CCF36A07C6DD58B40354A62AB3C04E4B1DD2145B9FEE
                            Key-Arg   : None
                            PSK identity: None
                            PSK identity hint: None
                            SRP username: None
                            Start Time: 1517327925
                            Timeout   : 300 (sec)
                            Verify return code: 19 (self signed certificate in certificate chain)
                        • AlCalzone
                          Habe jetzt den Verbindungs-Check umgestellt und eine andere Option wegen der Zertifikate probiert. Bitte nochmal wie gehabt die neueste Version installieren und testen.
                          • integer63
                            Na, das sieht doch schon mal ganz vielversprechend aus 😄
                            Es dauert zwar recht lange, aber die Instanz wird grün (ups, jetzt auch mit dem richtigen Screenshot):
                            Und in den Objekten ist auch was zu sehen:
                            Und hier noch das Log:
                            philips-tv.0	2018-01-30 18:44:51.394	debug	connection is ALIVE
                            philips-tv.0	2018-01-30 18:44:51.362	debug	checking if connection is alive
                            philips-tv.0	2018-01-30 18:43:41.284	debug	connection is ALIVE
                            philips-tv.0	2018-01-30 18:43:41.246	debug	checking if connection is alive
                            philips-tv.0	2018-01-30 18:42:31.196	debug	connection is ALIVE
                            philips-tv.0	2018-01-30 18:42:31.151	debug	checking if connection is alive
                            philips-tv.0	2018-01-30 18:41:21.074	debug	connection is ALIVE
                            philips-tv.0	2018-01-30 18:41:20.980	debug	checking if connection is alive
                            philips-tv.0	2018-01-30 18:41:10.975	debug	state with id philips-tv.0.volume updated: ack=true; val=14
                            philips-tv.0	2018-01-30 18:41:10.974	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.volume {"val":14,"ack":true,"ts":1517334070967,"q":0,"from":"system.adapter.philips-tv.0","lc":1517334070967}
                            philips-tv.0	2018-01-30 18:41:10.963	debug	object with id philips-tv.0.volume updated
                            philips-tv.0	2018-01-30 18:41:10.949	debug	state with id philips-tv.0.muted updated: ack=true; val=false
                            philips-tv.0	2018-01-30 18:41:10.948	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.muted {"val":false,"ack":true,"ts":1517334070944,"q":0,"from":"system.adapter.philips-tv.0","lc":1517334070944}
                            philips-tv.0	2018-01-30 18:41:10.938	debug	object with id philips-tv.0.muted updated
                            philips-tv.0	2018-01-30 18:41:10.874	debug	state with id philips-tv.0.info.connection updated: ack=true; val=true
                            philips-tv.0	2018-01-30 18:41:10.873	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":true,"ack":true,"ts":1517334070840,"q":0,"from":"system.adapter.philips-tv.0","lc":1517334070840}
                            philips-tv.0	2018-01-30 18:41:10.843	info	The TV at 192.168.11.118 is now reachable.
                            philips-tv.0	2018-01-30 18:41:10.833	debug	TV has APIv5
                            philips-tv.0	2018-01-30 18:40:10.258	debug	testing APIv5
                            philips-tv.0	2018-01-30 18:39:10.146	debug	testing APIv1
                            philips-tv.0	2018-01-30 18:39:10.146	debug	detecting API version
                            philips-tv.0	2018-01-30 18:39:10.144	debug	connection is ALIVE
                            philips-tv.0	2018-01-30 18:39:10.084	debug	state with id philips-tv.0.info.connection updated: ack=true; val=false
                            philips-tv.0	2018-01-30 18:39:10.077	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":false,"ack":true,"ts":1517333950075,"q":0,"from":"system.adapter.philips-tv.0","lc":1516915053497}
                            philips-tv.0	2018-01-30 18:39:10.051	debug	checking if connection is alive
                            philips-tv.0	2018-01-30 18:39:10.042	debug	initializing connection to 192.168.11.118
                            philips-tv.0	2018-01-30 18:39:09.965	info	starting. Version 0.3.0-alpha4 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.11.4
                            philips-tv.0	2018-01-30 18:39:09.907	info	States connected to redis: 192.168.11.33:6379
                            philips-tv.0	2018-01-30 18:39:09.896	debug	statesDB connected
                            philips-tv.0	2018-01-30 18:39:09.842	debug	objectDB connected
                            Danke für die viele Mühe!
                            • N
                              philips-tv.02018-01-30 19:41:30.623debugCould not initialize connection. Reason: No supported device/API version found at "192.168.5.109"philips-tv.02018-01-30 19:41:30.519debugtesting APIv6philips-tv.02018-01-30 19:41:30.399debugtesting APIv5philips-tv.02018-01-30 19:41:30.287debugtesting APIv1philips-tv.02018-01-30 19:41:30.287debugdetecting API versionphilips-tv.02018-01-30 19:41:30.285debugconnection is ALIVEphilips-tv.02018-01-30 19:41:30.274debugchecking if connection is alivephilips-tv.02018-01-30 19:41:30.272debuginitializing connection to 192.168.5.109philips-tv.02018-01-30 19:41:20.220debugCould not initialize connection. Reason: No supported device/API version found at "192.168.5.109"philips-tv.02018-01-30 19:41:20.117debugtesting APIv6philips-tv.02018-01-30 19:41:19.997debugtesting APIv5
                              Gesendet von meinem SM-G935F mit Tapatalk
                              • AlCalzone
                                @integer63:
                                Es dauert zwar recht lange, aber die Instanz wird grün (ups, jetzt auch mit dem richtigen Screenshot): `
                                Yay! Die Pause von ca. 1 Minute heißt dass da was mit dem Timeout noch nicht stimmt. Ich versuch das zu ändern.
                                @NemoN:
                                Sind wir schon mal nen Schritt weiter 🙂 Aber der API-Check passt noch nicht.
                                Edit: Ihr dürft beide nochmal updaten!
                                • integer63
                                  Hmm, ein kleiner Rückschritt …
                                  philips-tv.0	2018-01-30 20:24:52.272	debug	Could not initialize connection. Reason: No connection to host 192.168.11.118
                                  philips-tv.0	2018-01-30 20:24:52.270	debug	connection is DEAD. Reason: [undefined] Error: ESOCKETTIMEDOUT
                                  philips-tv.0	2018-01-30 20:24:47.210	debug	checking if connection is alive
                                  philips-tv.0	2018-01-30 20:24:47.209	debug	initializing connection to 192.168.11.118
                                  philips-tv.0	2018-01-30 20:24:37.197	debug	Could not initialize connection. Reason: No supported device/API version found at "192.168.11.118"
                                  philips-tv.0	2018-01-30 20:24:37.070	debug	testing APIv6
                                  philips-tv.0	2018-01-30 20:24:31.958	debug	testing APIv5
                                  philips-tv.0	2018-01-30 20:24:26.839	debug	testing APIv1
                                  philips-tv.0	2018-01-30 20:24:26.835	debug	detecting API version
                                  philips-tv.0	2018-01-30 20:24:26.833	debug	connection is ALIVE
                                  philips-tv.0	2018-01-30 20:24:26.753	debug	checking if connection is alive
                                  philips-tv.0	2018-01-30 20:24:26.750	debug	initializing connection to 192.168.11.118
                                  philips-tv.0	2018-01-30 20:24:16.685	debug	Could not initialize connection. Reason: No connection to host 192.168.11.118
                                  philips-tv.0	2018-01-30 20:24:16.684	debug	connection is DEAD. Reason: [undefined] Error: ESOCKETTIMEDOUT
                                  philips-tv.0	2018-01-30 20:24:11.645	debug	checking if connection is alive
                                  philips-tv.0	2018-01-30 20:24:11.643	debug	initializing connection to 192.168.11.118
                                  philips-tv.0	2018-01-30 20:24:01.577	debug	Could not initialize connection. Reason: No connection to host 192.168.11.118
                                  philips-tv.0	2018-01-30 20:24:01.575	debug	connection is DEAD. Reason: [undefined] Error: ESOCKETTIMEDOUT
                                  philips-tv.0	2018-01-30 20:23:56.502	debug	checking if connection is alive
                                  philips-tv.0	2018-01-30 20:23:56.501	debug	initializing connection to 192.168.11.118
                                  philips-tv.0	2018-01-30 20:23:46.495	debug	Could not initialize connection. Reason: No connection to host 192.168.11.118
                                  philips-tv.0	2018-01-30 20:23:46.493	debug	connection is DEAD. Reason: [undefined] Error: ESOCKETTIMEDOUT
                                  philips-tv.0	2018-01-30 20:23:41.406	debug	checking if connection is alive
                                  philips-tv.0	2018-01-30 20:23:41.405	debug	initializing connection to 192.168.11.118
                                  philips-tv.0	2018-01-30 20:23:31.393	debug	Could not initialize connection. Reason: No supported device/API version found at "192.168.11.118"
                                  philips-tv.0	2018-01-30 20:23:31.151	debug	testing APIv6
                                  philips-tv.0	2018-01-30 20:23:26.020	debug	testing APIv5
                                  philips-tv.0	2018-01-30 20:23:20.884	debug	testing APIv1
                                  philips-tv.0	2018-01-30 20:23:20.883	debug	detecting API version
                                  philips-tv.0	2018-01-30 20:23:20.882	debug	connection is ALIVE
                                  philips-tv.0	2018-01-30 20:23:20.854	debug	state with id philips-tv.0.info.connection updated: ack=true; val=false
                                  philips-tv.0	2018-01-30 20:23:20.847	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":false,"ack":true,"ts":1517340200829,"q":0,"from":"system.adapter.philips-tv.0","lc":1517340176850}
                                  philips-tv.0	2018-01-30 20:23:20.803	debug	checking if connection is alive
                                  philips-tv.0	2018-01-30 20:23:20.794	debug	initializing connection to 192.168.11.118
                                  philips-tv.0	2018-01-30 20:23:20.717	info	starting. Version 0.3.0-alpha4 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.11.4
                                  philips-tv.0	2018-01-30 20:23:20.659	info	States connected to redis: 192.168.11.33:6379
                                  philips-tv.0	2018-01-30 20:23:20.648	debug	statesDB connected
                                  philips-tv.0	2018-01-30 20:23:20.594	debug	objectDB connected
                                  • AlCalzone
                                    ESOCKETTIMEDOUT heißt, dein Fernseher mag irgendwas nicht. Es gibt ein paar Möglichkeiten, das zu beheben, aber da müssen wir mal experimentieren…
                                    • integer63
                                      @AlCalzone:
                                      … aber da müssen wir mal experimentieren... `
                                      nur zu 😄
                                      • AlCalzone
                                        @integer63:
                                        nur zu 😄 `
                                        Du darfst!
                                          dali3 last edited by
                                          philips-tv.0	2018-01-30 21:09:55.226	debug	Could not initialize connection. Reason: No supported device/API version found at "192.168.0.87"
                                          philips-tv.0	2018-01-30 21:09:50.034	debug	testing APIv6
                                          philips-tv.0	2018-01-30 21:09:49.888	debug	testing APIv5
                                          philips-tv.0	2018-01-30 21:09:49.695	debug	testing APIv1
                                          philips-tv.0	2018-01-30 21:09:49.695	debug	detecting API version
                                          philips-tv.0	2018-01-30 21:09:49.693	debug	connection is ALIVE
                                          philips-tv.0	2018-01-30 21:09:49.616	debug	checking if connection is alive
                                          philips-tv.0	2018-01-30 21:09:49.614	debug	initializing connection to 192.168.0.87
                                          Philips PUS8700
                                          • AlCalzone
                                            @dali3:
                                            Philips PUS8700 `
                                            Sieht mir nach nem Timeout aus. Bitte neueste Version probieren, da gibts mehr Logs. Kannst du zum Vergleich auch mal die Links durchprobieren?
                                            http://192.168.0.87:1925/1/audio/volume
                                            http://192.168.0.87:1925/5/audio/volume
                                            https://192.168.0.87:1926/6/audio/volume
                                            philips philips tv
                                            84
                                            550
                                            131274
