========== Start marking the full check here ===========
Script v.2025-03-08
*** BASE SYSTEM ***
Static hostname: iobroker
Icon name: computer-vm
Chassis: vm 🖴
Virtualization: kvm
Kernel: Linux 6.1.0-10-amd64
Architecture: x86-64
Hardware Vendor: QEMU
Hardware Model: Standard PC _Q35 + ICH9, 2009_
Firmware Version: unknown
OS is similar to:
model name : Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
Docker : false
Virtualization : kvm
Kernel : x86_64
Userland : 64 bit
Systemuptime and Load:
19:32:00 up 7:38, 2 users, load average: 0.82, 0.78, 0.44
CPU threads: 56
*** LIFE CYCLE STATUS ***
Operating System is the current Debian stable version codenamed 'bookworm'!
*** TIME AND TIMEZONES ***
Local time: Thu 2025-06-05 19:32:00 CEST
Universal time: Thu 2025-06-05 17:32:00 UTC
RTC time: Thu 2025-06-05 17:32:00
NTP service: active
RTC in local TZ: no
*** Users and Groups ***
User that called 'iob diag':
iobroker
HOME=/home/iobroker
GROUPS=iobroker tty dialout audio video plugdev
js-controller is not running
A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
A root login is not required in most Linux Distributions.
Run 'iobroker fix' or use the system tools to create a user.
*** DISPLAY-SERVER SETUP ***
Display-Server: false
Desktop:
Terminal: tty
System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
*** MEMORY ***
total used free shared buff/cache available
Mem: 33G 812M 32G 868K 1.3G 32G
Swap: 1.0G 0B 1.0G
Total: 34G 812M 33G
Active iob-Instances: 1
32075 M total memory
773 M used memory
737 M active memory
185 M inactive memory
30552 M free memory
225 M buffer memory
982 M swap cache
976 M total swap
0 M used swap
976 M free swap
*** top - Table Of Processes ***
top - 19:32:01 up 7:38, 2 users, load average: 0.82, 0.78, 0.44
Tasks: 494 total, 1 running, 493 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.0 us, 1.7 sy, 0.0 ni, 96.7 id, 0.0 wa, 0.0 hi, 0.0 si, 1.7 st
MiB Mem : 32075.9 total, 30552.1 free, 774.2 used, 1208.1 buff/cache
MiB Swap: 977.0 total, 977.0 free, 0.0 used. 31301.8 avail Mem
*** FAILED SERVICES ***
* iobroker.service loaded failed failed ioBroker Server
LOAD = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB = The low-level unit activation state, values depend on unit type.
1 loaded units listed.
*** DMESG CRITICAL ERRORS ***
[sudo] password for iobroker:
No critical errors detected
*** FILESYSTEM ***
Filesystem Type Size Used Avail Use% Mounted on
udev devtmpfs 16G 0 16G 0% /dev
tmpfs tmpfs 3.2G 856K 3.2G 1% /run
/dev/vda2 ext4 124G 14G 105G 12% /
tmpfs tmpfs 16G 0 16G 0% /dev/shm
tmpfs tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/vda1 vfat 511M 5.9M 506M 2% /boot/efi
tmpfs tmpfs 3.2G 0 3.2G 0% /run/user/1001
[Thu Jun 5 11:53:15 2025] EXT4-fs (vda2): mounted filesystem with ordered data mode. Quota mode: none.
[Thu Jun 5 11:53:15 2025] EXT4-fs (vda2): re-mounted. Quota mode: none.
Show mounted filesystems:
TARGET SOURCE FSTYPE OPTIONS
/ /dev/vda2 ext4 rw,relatime,errors=remount-ro
`-/boot/efi /dev/vda1 vfat rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
/var:
4.5G /var/
3.9G /var/log
3.8G /var/log/journal/344d77984391492881db48d011483210
479M /var/cache
Archived and active journals take up 3.3G in the file system.
/opt/iobroker/backups:
1.4G /opt/iobroker/backups/
/opt/iobroker/iobroker-data:
1.3G /opt/iobroker/iobroker-data/
1.1G /opt/iobroker/iobroker-data/files
241M /opt/iobroker/iobroker-data/files/vis.0
237M /opt/iobroker/iobroker-data/files/vis-2.0
208M /opt/iobroker/iobroker-data/files/vis.0/images
43M /opt/iobroker/iobroker-data/objects.jsonl
35M /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
27M /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
24M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
24M /opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
USB-Devices by-id:
USB-Sticks - Avoid direct links to /dev/tty* in your adapter setups, please always prefer the links 'by-id':
/dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
*** ZigBee Settings ***
HINT:
Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
/dev/ttyUSB0
Zigbee Network Settings on your coordinator/in nvbackup are:
zigbee.X
Extended Pan ID:
*** MASKED ***
Pan ID:
*** MASKED ***
Channel:
*** MASKED ***
Network Key:
*** MASKED ***
To unmask the settings run 'iob diag --unmask'
*** NodeJS-Installation ***
/usr/bin/nodejs v20.19.2
/usr/bin/node v20.19.2
/usr/bin/npm 10.8.2
/usr/bin/npx 10.8.2
/usr/bin/corepack 0.31.0
nodejs:
Installed: 20.19.2-1nodesource1
Candidate: 20.19.2-1nodesource1
Version table:
*** 20.19.2-1nodesource1 1001
500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
100 /var/lib/dpkg/status
20.19.1-1nodesource1 1001
20.19.0-1nodesource1 1001
20.18.3-1nodesource1 1001
20.18.2-1nodesource1 1001
20.18.1-1nodesource1 1001
20.18.0-1nodesource1 1001
20.17.0-1nodesource1 1001
20.16.0-1nodesource1 1001
20.15.1-1nodesource1 1001
20.15.0-1nodesource1 1001
20.14.0-1nodesource1 1001
20.13.1-1nodesource1 1001
20.13.0-1nodesource1 1001
20.12.2-1nodesource1 1001
20.12.1-1nodesource1 1001
20.12.0-1nodesource1 1001
20.11.1-1nodesource1 1001
20.11.0-1nodesource1 1001
20.10.0-1nodesource1 1001
20.9.0-1nodesource1 1001
20.8.1-1nodesource1 1001
20.8.0-1nodesource1 1001
20.7.0-1nodesource1 1001
20.6.1-1nodesource1 1001
20.6.0-1nodesource1 1001
20.5.1-1nodesource1 1001
20.5.0-1nodesource1 1001
20.4.0-1nodesource1 1001
20.3.1-1nodesource1 1001
20.3.0-1nodesource1 1001
20.2.0-1nodesource1 1001
20.1.0-1nodesource1 1001
20.0.0-1nodesource1 1001
18.19.0+dfsg-6~deb12u2 500
500 http://deb.debian.org/debian bookworm/main amd64 Packages
18.19.0+dfsg-6~deb12u1 500
500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
No problems detected
Errors in npm tree: 0
*** ioBroker-Installation ***
ioBroker Status
Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
iobroker is not running on this host.
Objects type: jsonl
States type: jsonl
Hosts:
iobroker iobroker (version: 7.0.6, hostname: iobroker , alive, uptime: 497)
Core adapters versions
js-controller: 7.0.6
admin: 7.6.17
javascript: 8.9.2
nodejs modules from github: 3
+-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
| +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
| +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
Adapter State
system.adapter.admin.0.0 : admin : ioBrokerSlave - enabled, port: 8081, bind: 0.0.0.0, run as: admin
system.adapter.admin.1 : admin : iobroker - enabled, port: 8081, bind: 0.0.0.0, run as: admin
system.adapter.alexa2.0 : alexa2 : iobroker - enabled
system.adapter.awattar.0 : awattar : iobroker - enabled
system.adapter.backitup.0 : backitup : iobroker - enabled
system.adapter.device-reminder.0 : device-reminder : iobroker - disabled
system.adapter.devices.0 : devices : iobroker - disabled
system.adapter.discovery.0 : discovery : iobroker - enabled
system.adapter.energiefluss.0 : energiefluss : iobroker - enabled
system.adapter.enigma2.0 : enigma2 : iobroker - enabled
system.adapter.enigma2.1 : enigma2 : iobroker - enabled
system.adapter.fritzbox.0 : fritzbox : iobroker - enabled
system.adapter.fullybrowser.0 : fullybrowser : iobroker - disabled
system.adapter.hmip.0 : hmip : iobroker - enabled
system.adapter.hp-ilo.0 : hp-ilo : iobroker - enabled
system.adapter.hp-ilo.1 : hp-ilo : iobroker - enabled
system.adapter.hs100.0 : hs100 : iobroker - enabled
system.adapter.hue-extended.0 : hue-extended : iobroker - enabled
system.adapter.ical.0 : ical : iobroker - enabled
system.adapter.ical.1 : ical : iobroker - enabled
system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker - disabled
system.adapter.icons-material-svg.0 : icons-material-svg : iobroker - disabled
system.adapter.icons-mfd-png.0 : icons-mfd-png : iobroker - disabled
system.adapter.icons-mfd-svg.0 : icons-mfd-svg : iobroker - disabled
system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker - disabled
system.adapter.icons-ultimate-png.0 : icons-ultimate-png : iobroker - disabled
system.adapter.influxdb.0 : influxdb : iobroker - disabled, port: 8086
system.adapter.influxdb.2 : influxdb : iobroker - enabled, port: 8086
system.adapter.info.0 : info : iobroker - enabled
system.adapter.javascript.0 : javascript : iobroker - enabled
system.adapter.lgtv.0 : lgtv : iobroker - enabled
system.adapter.linux-control.0 : linux-control : iobroker - disabled
system.adapter.meross.0 : meross : iobroker - enabled
system.adapter.mqtt.0 : mqtt : iobroker - enabled, port: 1882, bind: 0.0.0.0
system.adapter.nina.0 : nina : iobroker - enabled
system.adapter.node-red.0 : node-red : iobroker - enabled, port: 1880, bind: 0.0.0.0
system.adapter.nuki-extended.0 : nuki-extended : iobroker - enabled
system.adapter.nut.0 : nut : iobroker - enabled
system.adapter.pi-hole.0 : pi-hole : iobroker - disabled
system.adapter.rest-api.0 : rest-api : iobroker - enabled, port: 8093, bind: 0.0.0.0, run as: admin
system.adapter.ring.0 : ring : iobroker - enabled
system.adapter.rpi2.0 : rpi2 : iobroker - disabled
system.adapter.samsung.0 : samsung : iobroker - enabled
system.adapter.scenes.0 : scenes : iobroker - enabled
system.adapter.shelly.0 : shelly : iobroker - enabled, port: 1881, bind: 0.0.0.0
system.adapter.simple-api.0 : simple-api : iobroker - enabled, port: 8087, bind: 0.0.0.0, run as: admin
system.adapter.smartmeter.0 : smartmeter : ioBrokerSlave - enabled
system.adapter.solarwetter.0 : solarwetter : iobroker - disabled
system.adapter.sonoff.0 : sonoff : iobroker - enabled, port: 1883, bind: 0.0.0.0
system.adapter.sourceanalytix.0 : sourceanalytix : iobroker - enabled
system.adapter.sql.0 : sql : iobroker - disabled, port: 3306
system.adapter.synology.0 : synology : iobroker - enabled, port: 5000
system.adapter.synology.1 : synology : iobroker - enabled, port: 5000
system.adapter.tankerkoenig.0 : tankerkoenig : iobroker - enabled
system.adapter.telegram.0 : telegram : iobroker - disabled, port: 8443, bind: 0.0.0.0
system.adapter.tr-064.0 : tr-064 : iobroker - enabled
system.adapter.trashschedule.0 : trashschedule : iobroker - enabled
system.adapter.tuya.0 : tuya : iobroker - enabled
system.adapter.tvspielfilm.0 : tvspielfilm : iobroker - enabled
system.adapter.unifi.0 : unifi : iobroker - disabled
system.adapter.upnp.0 : upnp : iobroker - enabled
system.adapter.vis-2.0 : vis-2 : iobroker - enabled
system.adapter.vis-google-fonts.0 : vis-google-fonts : iobroker - enabled
system.adapter.vis-icontwo.0 : vis-icontwo : iobroker - disabled
system.adapter.vis-inventwo.0 : vis-inventwo : iobroker - enabled
system.adapter.vis-material-advanced.0 : vis-material-advanced : iobroker - disabled
system.adapter.vis-materialdesign.0 : vis-materialdesign : iobroker - disabled
system.adapter.vis-timeandweather.0 : vis-timeandweather : iobroker - disabled
system.adapter.vis-weather.0 : vis-weather : iobroker - disabled
system.adapter.vis.0 : vis : iobroker - enabled
system.adapter.weatherunderground.0 : weatherunderground : iobroker - enabled
system.adapter.web.0 : web : iobroker - enabled, port: 8082, bind: 0.0.0.0, run as: admin
system.adapter.youtube.0 : youtube : iobroker - enabled
system.adapter.youtube.1 : youtube : iobroker - enabled
system.adapter.yr.0 : yr : iobroker - enabled
system.adapter.zigbee.0 : zigbee : iobroker - disabled, port: /dev/ttyUSB0
+ instance is alive
ioBroker-Repositories
│ (index) │ name │ url │ auto upgrade │
│ 0 │ 'stable' │ 'http://download.iobroker.net/sources-dist.json' │ false │
│ 1 │ 'beta' │ 'http://download.iobroker.net/sources-dist-latest.json' │ false │
Active repo(s): stable
Upgrade policy: none
Installed ioBroker-Adapters
Used repository: stable
Adapter "admin" : 7.6.17 , installed 7.6.17
Adapter "alarm" : 3.7.0 , installed 3.7.0
Adapter "alexa2" : 3.26.5 , installed 3.26.5
Adapter "awattar" : 1.0.6 , installed 1.0.6
Adapter "backitup" : 3.2.2 , installed 3.2.2
Adapter "device-reminder": 3.1.2 , installed 3.1.2
Adapter "devices" : 1.1.5 , installed 1.1.5
Adapter "discovery" : 5.0.0 , installed 5.0.0
Adapter "e3dc-rscp" : 1.4.2 , installed 1.4.2
Adapter "energiefluss" : 3.6.2 , installed 3.6.2
Adapter "enigma2" : 2.2.3 , installed 2.2.3
Adapter "fritzbox" : 0.6.0 , installed 0.6.0
Adapter "fullybrowser" : 3.1.1 , installed 3.1.1
Adapter "hmip" : 1.27.0 , installed 1.27.0
Adapter "hp-ilo" : 1.0.6 , installed 1.0.6
Adapter "hs100" : 2.2.2 , installed 2.2.2
Adapter "ical" : 1.16.1 , installed 1.16.1
Adapter "icons-addictive-flavour-png": 0.1.0, installed 0.1.0
Adapter "icons-material-svg": 0.1.0, installed 0.1.0
Adapter "icons-mfd-png": 1.2.1 , installed 1.2.1
Adapter "icons-mfd-svg": 1.2.0 , installed 1.2.0
Adapter "icons-open-icon-library-png": 0.1.2, installed 0.1.3
Adapter "icons-ultimate-png": 1.0.1, installed 1.0.1
Adapter "influxdb" : 4.0.2 , installed 4.0.2
Adapter "javascript" : 8.9.2 , installed 8.9.2
Controller "js-controller": 7.0.6 , installed 7.0.6
Adapter "lgtv" : 2.4.0 , installed 2.4.0
Adapter "linux-control": 1.1.5 , installed 1.1.5
Adapter "meross" : 1.17.0 , installed 1.17.0
Adapter "mqtt" : 6.1.2 , installed 6.1.2
Adapter "nina" : 0.0.25 , installed 0.0.25
Adapter "node-red" : 5.2.1 , installed 5.2.1
Adapter "nuki-extended": 2.7.0 , installed 2.7.0
Adapter "nut" : 1.6.0 , installed 1.6.0
Adapter "pi-hole" : 1.3.6 , installed 1.3.6
Adapter "rest-api" : 2.0.3 , installed 2.0.3
Adapter "ring" : 6.3.0 , installed 6.3.0
Adapter "rpi2" : 2.4.0 , installed 2.3.1 [Updatable]
Adapter "samsung" : 0.6.1 , installed 0.6.1
Adapter "scenes" : 3.2.3 , installed 3.2.3
Adapter "shelly" : 9.5.1 , installed 9.5.1
Adapter "simple-api" : 2.8.0 , installed 2.8.0
Adapter "socketio" : 6.7.1 , installed 6.7.1
Adapter "solarwetter" : 1.2.0 , installed 1.2.0
Adapter "sonoff" : 3.1.2 , installed 3.1.2
Adapter "sql" : 3.0.1 , installed 3.0.1
Adapter "synology" : 3.1.0 , installed 3.1.0
Adapter "tankerkoenig" : 3.4.0 , installed 3.4.0
Adapter "telegram" : 4.1.0 , installed 4.1.0
Adapter "tr-064" : 4.3.0 , installed 4.3.0
Adapter "trashschedule": 3.3.0 , installed 3.3.0
Adapter "tuya" : 3.16.0 , installed 3.16.0
Adapter "tvspielfilm" : 2.1.0 , installed 2.1.0
Adapter "unifi" : 0.7.0 , installed 0.7.0
Adapter "upnp" : 1.1.0 , installed 1.1.0
Adapter "vis" : 1.5.6 , installed 1.5.6
Adapter "vis-2" : 2.9.64 , installed 2.9.64
Adapter "vis-google-fonts": 1.0.4 , installed 1.0.4
Adapter "vis-icontwo" : 1.11.0 , installed 1.11.0
Adapter "vis-inventwo" : 3.3.5 , installed 3.3.5
Adapter "vis-material-advanced": 1.7.4, installed 1.7.4
Adapter "vis-materialdesign": 0.5.9, installed 0.5.9
Adapter "vis-timeandweather": 1.2.2, installed 1.2.2
Adapter "vis-weather" : 2.5.11 , installed 2.5.11
Adapter "weatherunderground": 3.7.0, installed 3.7.0
Adapter "web" : 7.0.8 , installed 7.0.8
Adapter "ws" : 2.6.2 , installed 2.6.2
Adapter "youtube" : 6.0.0 , installed 6.0.0
Adapter "yr" : 5.3.0 , installed 5.3.0
Adapter "zigbee" : 2.0.5 , installed 2.0.5
Server Objects 192.168.1.227:45994 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerSlave: The database is not open!
at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-jsonl/src/lib/objects/objectsInMemServerRedis.js:574:63)
at RedisHandler.emit (node:events:524:28)
at RedisHandler.emit (node:domain:489:12)
at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37)
at processImmediate (node:internal/timers:483:21)
Objects and States
Objects: 42824
States: 35049
Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
Reading package lists...
Pending Updates: 0
*** Listening Ports ***
Proto Recv-Q Send-Q Local Address Foreign Address State User Inode PID/Program name
tcp 0 0 0.0.0.0:1080 0.0.0.0:* LISTEN 1002 449562 335199/nc
tcp 0 0 0.0.0.0:111 0.0.0.0:* LISTEN 0 29708 1/init
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 0 60534 1124/sshd: /usr/sbi
tcp6 0 0 :::111 :::* LISTEN 0 29709 1/init
tcp6 0 0 :::22 :::* LISTEN 0 60536 1124/sshd: /usr/sbi
udp 0 0 0.0.0.0:68 0.0.0.0:* 0 51225 1065/dhclient
udp 0 0 0.0.0.0:111 0.0.0.0:* 0 16394 1/init
udp6 0 0 :::111 :::* 0 20508 1/init
2025-06-05 19:30:46.231 - error: host.iobroker Caught by controller[1]: syscall: 'connect',
2025-06-05 19:30:46.232 - error: host.iobroker Caught by controller[1]: address: '192.168.1.214',
2025-06-05 19:30:46.232 - error: host.iobroker Caught by controller[1]: port: 9999
2025-06-05 19:30:46.232 - error: host.iobroker Caught by controller[1]: }
2025-06-05 19:30:46.232 - info: host.iobroker instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:46.952 - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:46.969 - info: host.iobroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.018 - info: host.iobroker instance system.adapter.upnp.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.018 - info: host.iobroker instance system.adapter.nut.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.035 - info: host.iobroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.062 - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.105 - info: host.iobroker instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.105 - info: host.iobroker instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.133 - info: host.iobroker instance system.adapter.rest-api.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.162 - info: host.iobroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.179 - info: host.iobroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:47.330 - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGKILL
2025-06-05 19:30:47.330 - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
2025-06-05 19:30:48.078 - info: tuya.0 (327743) terminating
2025-06-05 19:30:48.079 - info: tuya.0 (327743) Terminated (NO_ERROR): Without reason
2025-06-05 19:30:48.716 - info: host.iobroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
2025-06-05 19:30:49.108 - info: meross.0 (327206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
2025-06-05 19:30:49.737 - info: host.iobroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
2025-06-05 19:30:49.737 - info: host.iobroker All instances are stopped.
2025-06-05 19:30:49.761 - info: host.iobroker terminated
