    4. Versionsinformationen Admin falsch
    • Lucifor1976
      Lucifor1976 last edited by
      Hier mal ein vollständiger Diag...
      ========== Start marking the full check here ===========
      Script v.2025-03-08
      *** BASE SYSTEM ***
       Static hostname: iobroker
             Icon name: computer-vm
               Chassis: vm 🖴
        Virtualization: kvm
                Kernel: Linux 6.1.0-10-amd64
          Architecture: x86-64
       Hardware Vendor: QEMU
        Hardware Model: Standard PC _Q35 + ICH9, 2009_
      Firmware Version: unknown
      OS is similar to:
      model name	: Intel(R) Xeon(R) CPU E5-2680 v4 @ 2.40GHz
      Docker          : false
      Virtualization  : kvm
      Kernel          : x86_64
      Userland        : 64 bit
      Systemuptime and Load:
       19:32:00 up  7:38,  2 users,  load average: 0.82, 0.78, 0.44
      CPU threads: 56
      *** LIFE CYCLE STATUS ***
      Operating System is the current Debian stable version codenamed 'bookworm'!
      *** TIME AND TIMEZONES ***
                     Local time: Thu 2025-06-05 19:32:00 CEST
                 Universal time: Thu 2025-06-05 17:32:00 UTC
                       RTC time: Thu 2025-06-05 17:32:00
                    NTP service: active
                RTC in local TZ: no
      *** Users and Groups ***
      User that called 'iob diag':
      iobroker
      HOME=/home/iobroker
      GROUPS=iobroker tty dialout audio video plugdev
      js-controller is not running
      A default user should be created! This user will be enabled to temporarily switch to root via 'sudo'!
      A root login is not required in most Linux Distributions.
      Run 'iobroker fix' or use the system tools to create a user.
      *** DISPLAY-SERVER SETUP ***
      Display-Server: false
      Desktop:
      Terminal: 	tty
      System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
      *** MEMORY ***
      Mem:             33G        812M         32G        868K        1.3G         32G
      Swap:           1.0G          0B        1.0G
      Total:           34G        812M         33G
      Active iob-Instances: 	1
              32075 M total memory
                773 M used memory
                737 M active memory
                185 M inactive memory
              30552 M free memory
                225 M buffer memory
                982 M swap cache
                976 M total swap
                  0 M used swap
                976 M free swap
      top - 19:32:01 up  7:38,  2 users,  load average: 0.82, 0.78, 0.44
      Tasks: 494 total,   1 running, 493 sleeping,   0 stopped,   0 zombie
      %Cpu(s):  0.0 us,  1.7 sy,  0.0 ni, 96.7 id,  0.0 wa,  0.0 hi,  0.0 si,  1.7 st
      MiB Mem :  32075.9 total,  30552.1 free,    774.2 used,   1208.1 buff/cache
      MiB Swap:    977.0 total,    977.0 free,      0.0 used.  31301.8 avail Mem
      *** FAILED SERVICES ***
        UNIT             LOAD   ACTIVE SUB    DESCRIPTION
      * iobroker.service loaded failed failed ioBroker Server
      LOAD   = Reflects whether the unit definition was properly loaded.
      ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
      SUB    = The low-level unit activation state, values depend on unit type.
      1 loaded units listed.
      *** DMESG CRITICAL ERRORS ***
      [sudo] password for iobroker:
      No critical errors detected
      *** FILESYSTEM ***
      udev           devtmpfs   16G     0   16G   0% /dev
      tmpfs          tmpfs     3.2G  856K  3.2G   1% /run
      /dev/vda2      ext4      124G   14G  105G  12% /
      tmpfs          tmpfs      16G     0   16G   0% /dev/shm
      tmpfs          tmpfs     5.0M     0  5.0M   0% /run/lock
      /dev/vda1      vfat      511M  5.9M  506M   2% /boot/efi
      tmpfs          tmpfs     3.2G     0  3.2G   0% /run/user/1001
      [Thu Jun  5 11:53:15 2025] EXT4-fs (vda2): mounted filesystem with ordered data mode. Quota mode: none.
      [Thu Jun  5 11:53:15 2025] EXT4-fs (vda2): re-mounted. Quota mode: none.
      Show mounted filesystems:
      TARGET      SOURCE    FSTYPE OPTIONS
      /           /dev/vda2 ext4   rw,relatime,errors=remount-ro
      `-/boot/efi /dev/vda1 vfat   rw,relatime,fmask=0077,dmask=0077,codepage=437,iocharset=ascii,shortname=mixed,utf8,errors=remount-ro
      /var:
      4.5G	/var/
      3.9G	/var/log
      3.8G	/var/log/journal/344d77984391492881db48d011483210
      479M	/var/cache
      Archived and active journals take up 3.3G in the file system.
      /opt/iobroker/backups:
      1.4G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      1.3G	/opt/iobroker/iobroker-data/
      1.1G	/opt/iobroker/iobroker-data/files
      241M	/opt/iobroker/iobroker-data/files/vis.0
      237M	/opt/iobroker/iobroker-data/files/vis-2.0
      208M	/opt/iobroker/iobroker-data/files/vis.0/images
      43M	/opt/iobroker/iobroker-data/objects.jsonl
      35M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.24f2bb56.js.map
      27M	/opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
      24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.f305bc29.js.map
      24M	/opt/iobroker/iobroker-data/files/vis-2/static/js/main.8e80ccb0.js.map
      USB-Devices by-id:
      /dev/serial/by-id/usb-Silicon_Labs_Sonoff_Zigbee_3.0_USB_Dongle_Plus_0001-if00-port0
      *** ZigBee Settings ***
      HINT:
      Your zigbee.0 COM-Port is NOT matching 'by-id'. Please check your setting:
      /dev/ttyUSB0
      Zigbee Network Settings on your coordinator/in nvbackup are:
      zigbee.X
      Extended Pan ID:
      *** MASKED ***
      Pan ID:
      *** MASKED ***
      Channel:
      *** MASKED ***
      Network Key:
      *** MASKED ***
      To unmask the settings run 'iob diag --unmask'
      *** NodeJS-Installation ***
      /usr/bin/nodejs 	v20.19.2
      /usr/bin/node 		v20.19.2
      /usr/bin/npm 		10.8.2
      /usr/bin/npx 		10.8.2
      /usr/bin/corepack 	0.31.0
      nodejs:
        Installed: 20.19.2-1nodesource1
        Candidate: 20.19.2-1nodesource1
        Version table:
       *** 20.19.2-1nodesource1 1001
              500 https://deb.nodesource.com/node_20.x nodistro/main amd64 Packages
              100 /var/lib/dpkg/status
           20.19.1-1nodesource1 1001
           20.19.0-1nodesource1 1001
           20.18.3-1nodesource1 1001
           20.18.2-1nodesource1 1001
           20.18.1-1nodesource1 1001
           20.18.0-1nodesource1 1001
           20.17.0-1nodesource1 1001
           20.16.0-1nodesource1 1001
           20.15.1-1nodesource1 1001
           20.15.0-1nodesource1 1001
           20.14.0-1nodesource1 1001
           20.13.1-1nodesource1 1001
           20.13.0-1nodesource1 1001
           20.12.2-1nodesource1 1001
           20.12.1-1nodesource1 1001
           20.12.0-1nodesource1 1001
           20.11.1-1nodesource1 1001
           20.11.0-1nodesource1 1001
           20.10.0-1nodesource1 1001
           20.9.0-1nodesource1 1001
           20.8.1-1nodesource1 1001
           20.8.0-1nodesource1 1001
           20.7.0-1nodesource1 1001
           20.6.1-1nodesource1 1001
           20.6.0-1nodesource1 1001
           20.5.1-1nodesource1 1001
           20.5.0-1nodesource1 1001
           20.4.0-1nodesource1 1001
           20.3.1-1nodesource1 1001
           20.3.0-1nodesource1 1001
           20.2.0-1nodesource1 1001
           20.1.0-1nodesource1 1001
           20.0.0-1nodesource1 1001
           18.19.0+dfsg-6~deb12u2 500
              500 http://deb.debian.org/debian bookworm/main amd64 Packages
           18.19.0+dfsg-6~deb12u1 500
              500 http://security.debian.org/debian-security bookworm-security/main amd64 Packages
      No problems detected
      Errors in npm tree: 0
      *** ioBroker-Installation ***
      ioBroker Status
      Server Configured backup period 7200000 is larger than the supported maximum of 35791 minutes. Defaulting to 120 minutes.
      iobroker is not running on this host.
      Objects type: jsonl
      States  type: jsonl
      Hosts:
      iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 497)
      Core adapters versions
      js-controller: 	7.0.6
      admin: 		7.6.17
      javascript: 	8.9.2
      nodejs modules from github: 	3
      +-- iobroker.icons-open-icon-library-png@0.1.3 (git+ssh://git@github.com/ioBroker/ioBroker.icons-open-icon-library-png.git#0847a79d713ee6725ccb6ccfb044c025b73ec946)
      | +-- samsungtv@0.0.0 (git+https://git@github.com/luca-saggese/samsungtv.git#7fc20107455414e2afb94022682e0787e8635550)
      | +-- syno@3.0.0 (git+https://git@github.com/MeisterTR/syno.git#0104a973d33fe332aa6b1ab5be7fe8c57d3c68b0)
      Adapter State
        system.adapter.admin.0.0                : admin                 : ioBrokerSlave                            -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.admin.1                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
        system.adapter.alexa2.0                 : alexa2                : iobroker                                 -  enabled
        system.adapter.awattar.0                : awattar               : iobroker                                 -  enabled
        system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
        system.adapter.device-reminder.0        : device-reminder       : iobroker                                 - disabled
        system.adapter.devices.0                : devices               : iobroker                                 - disabled
        system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
        system.adapter.energiefluss.0           : energiefluss          : iobroker                                 -  enabled
        system.adapter.enigma2.0                : enigma2               : iobroker                                 -  enabled
        system.adapter.enigma2.1                : enigma2               : iobroker                                 -  enabled
        system.adapter.fritzbox.0               : fritzbox              : iobroker                                 -  enabled
        system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
        system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
        system.adapter.hp-ilo.0                 : hp-ilo                : iobroker                                 -  enabled
        system.adapter.hp-ilo.1                 : hp-ilo                : iobroker                                 -  enabled
        system.adapter.hs100.0                  : hs100                 : iobroker                                 -  enabled
        system.adapter.hue-extended.0           : hue-extended          : iobroker                                 -  enabled
        system.adapter.ical.0                   : ical                  : iobroker                                 -  enabled
        system.adapter.ical.1                   : ical                  : iobroker                                 -  enabled
        system.adapter.icons-addictive-flavour-png.0: icons-addictive-flavour-png: iobroker                                 - disabled
        system.adapter.icons-material-svg.0     : icons-material-svg    : iobroker                                 - disabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : iobroker                                 - disabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : iobroker                                 - disabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: iobroker                                 - disabled
        system.adapter.icons-ultimate-png.0     : icons-ultimate-png    : iobroker                                 - disabled
        system.adapter.influxdb.0               : influxdb              : iobroker                                 - disabled, port: 8086
        system.adapter.influxdb.2               : influxdb              : iobroker                                 -  enabled, port: 8086
        system.adapter.info.0                   : info                  : iobroker                                 -  enabled
        system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
        system.adapter.lgtv.0                   : lgtv                  : iobroker                                 -  enabled
        system.adapter.linux-control.0          : linux-control         : iobroker                                 - disabled
        system.adapter.meross.0                 : meross                : iobroker                                 -  enabled
        system.adapter.mqtt.0                   : mqtt                  : iobroker                                 -  enabled, port: 1882, bind: 0.0.0.0
        system.adapter.nina.0                   : nina                  : iobroker                                 -  enabled
        system.adapter.node-red.0               : node-red              : iobroker                                 -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.nuki-extended.0          : nuki-extended         : iobroker                                 -  enabled
        system.adapter.nut.0                    : nut                   : iobroker                                 -  enabled
        system.adapter.pi-hole.0                : pi-hole               : iobroker                                 - disabled
        system.adapter.rest-api.0               : rest-api              : iobroker                                 -  enabled, port: 8093, bind: 0.0.0.0, run as: admin
        system.adapter.ring.0                   : ring                  : iobroker                                 -  enabled
        system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
        system.adapter.samsung.0                : samsung               : iobroker                                 -  enabled
        system.adapter.scenes.0                 : scenes                : iobroker                                 -  enabled
        system.adapter.shelly.0                 : shelly                : iobroker                                 -  enabled, port: 1881, bind: 0.0.0.0
        system.adapter.simple-api.0             : simple-api            : iobroker                                 -  enabled, port: 8087, bind: 0.0.0.0, run as: admin
        system.adapter.smartmeter.0             : smartmeter            : ioBrokerSlave                            -  enabled
        system.adapter.solarwetter.0            : solarwetter           : iobroker                                 - disabled
        system.adapter.sonoff.0                 : sonoff                : iobroker                                 -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.sourceanalytix.0         : sourceanalytix        : iobroker                                 -  enabled
        system.adapter.sql.0                    : sql                   : iobroker                                 - disabled, port: 3306
        system.adapter.synology.0               : synology              : iobroker                                 -  enabled, port: 5000
        system.adapter.synology.1               : synology              : iobroker                                 -  enabled, port: 5000
        system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
        system.adapter.telegram.0               : telegram              : iobroker                                 - disabled, port: 8443, bind: 0.0.0.0
        system.adapter.tr-064.0                 : tr-064                : iobroker                                 -  enabled
        system.adapter.trashschedule.0          : trashschedule         : iobroker                                 -  enabled
        system.adapter.tuya.0                   : tuya                  : iobroker                                 -  enabled
        system.adapter.tvspielfilm.0            : tvspielfilm           : iobroker                                 -  enabled
        system.adapter.unifi.0                  : unifi                 : iobroker                                 - disabled
        system.adapter.upnp.0                   : upnp                  : iobroker                                 -  enabled
        system.adapter.vis-2.0                  : vis-2                 : iobroker                                 -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : iobroker                                 -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
        system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : iobroker                                 - disabled
        system.adapter.vis-materialdesign.0     : vis-materialdesign    : iobroker                                 - disabled
        system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
        system.adapter.vis-weather.0            : vis-weather           : iobroker                                 - disabled
        system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
        system.adapter.weatherunderground.0     : weatherunderground    : iobroker                                 -  enabled
        system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.youtube.0                : youtube               : iobroker                                 -  enabled
        system.adapter.youtube.1                : youtube               : iobroker                                 -  enabled
        system.adapter.yr.0                     : yr                    : iobroker                                 -  enabled
        system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled, port: /dev/ttyUSB0
      + instance is alive
      ioBroker-Repositories
      Active repo(s): stable
      Upgrade policy: none
      Installed ioBroker-Adapters
      Used repository: stable
      Adapter    "admin"        : 7.6.17   , installed 7.6.17
      Adapter    "alarm"        : 3.7.0    , installed 3.7.0
      Adapter    "alexa2"       : 3.26.5   , installed 3.26.5
      Adapter    "awattar"      : 1.0.6    , installed 1.0.6
      Adapter    "backitup"     : 3.2.2    , installed 3.2.2
      Adapter    "device-reminder": 3.1.2  , installed 3.1.2
      Adapter    "e3dc-rscp"    : 1.4.2    , installed 1.4.2
      Adapter    "energiefluss" : 3.6.2    , installed 3.6.2
      Adapter    "enigma2"      : 2.2.3    , installed 2.2.3
      Adapter    "fritzbox"     : 0.6.0    , installed 0.6.0
      Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
      Adapter    "hmip"         : 1.27.0   , installed 1.27.0
      Adapter    "hp-ilo"       : 1.0.6    , installed 1.0.6
      Adapter    "hs100"        : 2.2.2    , installed 2.2.2
      Adapter    "ical"         : 1.16.1   , installed 1.16.1
      Adapter    "icons-material-svg": 0.1.0, installed 0.1.0
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.3
      Adapter    "javascript"   : 8.9.2    , installed 8.9.2
      Controller "js-controller": 7.0.6    , installed 7.0.6
      Adapter    "lgtv"         : 2.4.0    , installed 2.4.0
      Adapter    "linux-control": 1.1.5    , installed 1.1.5
      Adapter    "meross"       : 1.17.0   , installed 1.17.0
      Adapter    "mqtt"         : 6.1.2    , installed 6.1.2
      Adapter    "nina"         : 0.0.25   , installed 0.0.25
      Adapter    "node-red"     : 5.2.1    , installed 5.2.1
      Adapter    "nuki-extended": 2.7.0    , installed 2.7.0
      Adapter    "nut"          : 1.6.0    , installed 1.6.0
      Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
      Adapter    "rest-api"     : 2.0.3    , installed 2.0.3
      Adapter    "ring"         : 6.3.0    , installed 6.3.0
      Adapter    "rpi2"         : 2.4.0    , installed 2.3.1  [Updatable]
      Adapter    "samsung"      : 0.6.1    , installed 0.6.1
      Adapter    "scenes"       : 3.2.3    , installed 3.2.3
      Adapter    "shelly"       : 9.5.1    , installed 9.5.1
      Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
      Adapter    "socketio"     : 6.7.1    , installed 6.7.1
      Adapter    "solarwetter"  : 1.2.0    , installed 1.2.0
      Adapter    "sonoff"       : 3.1.2    , installed 3.1.2
      Adapter    "sql"          : 3.0.1    , installed 3.0.1
      Adapter    "synology"     : 3.1.0    , installed 3.1.0
      Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
      Adapter    "telegram"     : 4.1.0    , installed 4.1.0
      Adapter    "tr-064"       : 4.3.0    , installed 4.3.0
      Adapter    "trashschedule": 3.3.0    , installed 3.3.0
      Adapter    "tuya"         : 3.16.0   , installed 3.16.0
      Adapter    "tvspielfilm"  : 2.1.0    , installed 2.1.0
      Adapter    "unifi"        : 0.7.0    , installed 0.7.0
      Adapter    "upnp"         : 1.1.0    , installed 1.1.0
      Adapter    "vis-2"        : 2.9.64   , installed 2.9.64
      Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
      Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
      Adapter    "vis-weather"  : 2.5.11   , installed 2.5.11
      Adapter    "weatherunderground": 3.7.0, installed 3.7.0
      Adapter    "web"          : 7.0.8    , installed 7.0.8
      Adapter    "ws"           : 2.6.2    , installed 2.6.2
      Adapter    "youtube"      : 6.0.0    , installed 6.0.0
      Adapter    "yr"           : 5.3.0    , installed 5.3.0
      Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
      Server Objects 192.168.1.227:45994 Error from InMemDB: Error: ERROR setObject id=system.host.ioBrokerSlave: The database is not open!
          at RedisHandler.<anonymous> (file:///opt/iobroker/node_modules/@iobroker/db-objects-jsonl/src/lib/objects/objectsInMemServerRedis.js:574:63)
          at RedisHandler.emit (node:events:524:28)
          at RedisHandler.emit (node:domain:489:12)
          at Immediate._onImmediate (file:///opt/iobroker/node_modules/@iobroker/db-base/src/lib/redisHandler.ts:210:37)
          at processImmediate (node:internal/timers:483:21)
      Objects and States
      Objects: 	42824
      States: 	35049
      Hit:2 http://security.debian.org/debian-security bookworm-security InRelease
      Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
      Hit:4 https://deb.nodesource.com/node_20.x nodistro InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1080            0.0.0.0:*               LISTEN      1002       449562     335199/nc
      tcp        0      0 0.0.0.0:111             0.0.0.0:*               LISTEN      0          29708      1/init
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          60534      1124/sshd: /usr/sbi
      tcp6       0      0 :::111                  :::*                    LISTEN      0          29709      1/init
      tcp6       0      0 :::22                   :::*                    LISTEN      0          60536      1124/sshd: /usr/sbi
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          51225      1065/dhclient
      udp        0      0 0.0.0.0:111             0.0.0.0:*                           0          16394      1/init
      udp6       0      0 :::111                  :::*                                0          20508      1/init
      2025-06-05 19:30:46.231  - error: host.iobroker Caught by controller[1]:   syscall: 'connect',
      2025-06-05 19:30:46.232  - error: host.iobroker Caught by controller[1]:   address: '192.168.1.214',
      2025-06-05 19:30:46.232  - error: host.iobroker Caught by controller[1]:   port: 9999
      2025-06-05 19:30:46.232  - error: host.iobroker Caught by controller[1]: }
      2025-06-05 19:30:46.232  - info: host.iobroker instance system.adapter.hs100.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:46.952  - info: host.iobroker instance system.adapter.vis-inventwo.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:46.969  - info: host.iobroker instance system.adapter.sourceanalytix.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.018  - info: host.iobroker instance system.adapter.upnp.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.018  - info: host.iobroker instance system.adapter.nut.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.035  - info: host.iobroker instance system.adapter.admin.1 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.062  - info: host.iobroker instance system.adapter.alexa2.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.105  - info: host.iobroker instance system.adapter.hue-extended.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.105  - info: host.iobroker instance system.adapter.info.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.133  - info: host.iobroker instance system.adapter.rest-api.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.162  - info: host.iobroker instance system.adapter.simple-api.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.179  - info: host.iobroker instance system.adapter.vis-2.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:47.330  - warn: host.iobroker instance system.adapter.sonoff.0 terminated due to SIGKILL
      2025-06-05 19:30:47.330  - info: host.iobroker instance system.adapter.sonoff.0 terminated with code null ()
      2025-06-05 19:30:48.078  - info: tuya.0 (327743) terminating
      2025-06-05 19:30:48.079  - info: tuya.0 (327743) Terminated (NO_ERROR): Without reason
      2025-06-05 19:30:48.716  - info: host.iobroker instance system.adapter.tuya.0 terminated with code 0 (NO_ERROR)
      2025-06-05 19:30:49.108  - info: meross.0 (327206) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      2025-06-05 19:30:49.737  - info: host.iobroker instance system.adapter.meross.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      2025-06-05 19:30:49.737  - info: host.iobroker All instances are stopped.
      2025-06-05 19:30:49.761  - info: host.iobroker terminated
        Thomas Braun Most Active @Lucifor1976 last edited by
        @lucifor1976 sagte in Versionsinformationen Admin falsch:
        Leg dir einen User abseits von 'admin', 'root', 'iobroker' oder sonstwas an. Dein Vorname ist z. B. ein guter username.
        Schalt den multi-user-Modus ein.
        iob del admin.0.0
        sagt?
        Die Instanz smartmeter.0 läuft auch noch auf dem Host ioBrokerSlave
        BTW: Hostnames schreibt man am besten in Kleinbuchstaben.
          @thomas-braun sagte in Versionsinformationen Admin falsch:
          sagt?
          da bin ich gespannt!
          • Lucifor1976
            iob del admin.0.0
            Neuer User = check
            Multiuser = check
            oben genanntes ergab:
            meinname@iobroker:/home/iobroker$ iob del admin.0.0
            iobroker del <adapter>.<instance>
            Remove adapter instance
            Options:
            --help Show help [boolean]
            --custom Remove instance custom attribute from all objects [boolean]
            Ich mach nochmal ein upgrade, bin mir aber sicher das der Fehler nicht weg ist.
              Homoran Global Moderator Administrators @Lucifor1976 last edited by Homoran
              @lucifor1976 bitte code-tags verwenden!
              Was ist Kommentar und was ist die Ausgabe?
              ich auch, daher
              NEIN!
              • Lucifor1976
                Das ist der Prompt: iob del admin.0.0
                und das die Ausgabe:
                Options:
                Upgrade geht eh nicht, der Fehler bleibt.
                Cannot check dependencies: Invalid version of "admin". Installed "4.1.10", required ">=7.4.10
                  Dann stell dich auch in das home des neuen users...
                    MCU @Thomas Braun last edited by
                    iob del admin.0.0
                    Das gibt es nicht. Wenn dann
                     iob del admin.0
                      das wird an der falschen Nomenklatur deiner ID liegen.
                      da passiert wohl nichts im Hintergrund
                        Thomas Braun Most Active @MCU last edited by
                        @mcu sagte in Versionsinformationen Admin falsch:
                        Besser: Das sollte es nicht geben. Im fraglichen System ist die Instanz aber so aufgeführt. Warum auch immer.
                          @thomas-braun Hängt es evtl mit dem Slavesystem zusammen?
                          mcm1957 Thomas Braun 2 Replies Last reply Reply Quote 0
                          • mcm1957
                            mcm1957 @MCU last edited by
                            @apollon77
                            Hast du da ne Idee wgen der krummen id (admin.0.0 - mit ZWEI nullen)?
                              @mcu
                              Den Slave gibt es wohl auch nur noch als Fragment.
                              Die Frage ist, wie ist der abgeräumt worden?
                              Ich würde mal versuchen, den admin komplett rauszuwerfen
                              iob del admin
                              Vielleicht bekommt man das damit sauber.
                              @Lucifor1976 :
                              Den gibt es dann auch nicht mehr und es ist ein Überbleibsel?
                              • Lucifor1976
                                Mit sicherheit, ich habe des Slave aber vorher ordnungsgemäß aus dem System geworfen.
                                iobroker host remove ioBrokerSlave
                                Diese Prozedur mache ich seit Jahren, Host remove, beide Systeme updaten, Host wieder einfügen.
                                Vor ein paar Monaten dann dieser Fehler mit der falschen Admin Version.
                                Heute hats dann den Master komplett zerschossen 😞
                                • Lucifor1976
                                  Ich hab es mit Hängen und Würgen wieder hinbekommen,
                                  der Slave wurde nicht korrekt entfernt, Nachdem ich erneut den Slave entfernt habe, ist plötzlich ein Adapter mit 4.x auf dem Master aufgetaucht, der liess sich jedoch nicht löschen. Hatte dann aber seltsamerweise die aktuelle Verionsnummer. Die Instanz ist nun deaktiviert und hat, warum auch immer die Bezeichnung Admin.0.0.
                                  Den Slave von Grund auf neu aufgezogen und wieder hinzugefügt und nun läuft alles wieder und ist auf dem aktuellen Stand.
                                  Jemand eine Idee wie ich den verweisten Eintrag entfernt bekomme?
                                  Erledigt: Hab ihn in "System.Admin.0.0" gefunden, den Baum gelöscht, verweister Eintrag weg.
                                    @lucifor1976
                                    Dann schau dir jetzt nochmal die Ausgabe von
                                    iob diag
                                    im Ganzen an, ob das nun alles stimmig ist.
                                    403
