    4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
      bolliy Developer @Vito666 last edited by bolliy
      @vito666 verwendest du blockly mit dem Funktionblock aktualisiere? Falls das zutrifft, dann nehme bitte den Funktionsblock steuere.
      Siehe https://github.com/bolliy/ioBroker.sun2000/wiki/Verarbeitung-der-Sollwerte
      Stephan
      V bahnuhr 2 Replies Last reply Reply Quote 0
      • V
        Vito666 @bolliy last edited by
        @bolliy Moin Stephan,
        danke, an der Stelle hatte ich genau den Fehler gemacht.
        Vito
        • bahnuhr
          bahnuhr Forum Testing Most Active @bolliy last edited by
          @bolliy
          Guten Morgen,
          könntest du noch einen "deviceStatus_Text" einbauen.
          z.B. nach diesem Schema:
          setState(SHI + id + ".DeviceStatus",           getU16(Buffer[id-1], 32089));
                  var deviceStatusName = "";
                  switch (getState(SHI + id + ".DeviceStatus").val) {
                      case 0: deviceStatusName = "Initializing";break;
                      case 1: deviceStatusName = "Detecting ISO";break;
                      case 2: deviceStatusName = "Detecting irradiation";break;
                      case 3: deviceStatusName = "Grid detecting";break;
                      case 256: deviceStatusName = "Starting";break;
                      case 512: deviceStatusName = "On grid";break;
                      case 513: deviceStatusName = "On grid Power limit";break;
                      case 514: deviceStatusName = "On grid self derating";break;
                      case 768: deviceStatusName = "Shutdown fault";break;
                      case 769: deviceStatusName = "Shutdown command";break;
                      case 770: deviceStatusName = "Shutdown OVGR";break;
                      case 771: deviceStatusName = "Shutdown communication disconnected";break;
                      case 772: deviceStatusName = "Shutdown power limit";break;
                      case 773: deviceStatusName = "Shutdown start manually";break;
                      case 774: deviceStatusName = "Shutdown DC switch OFF";break;
                      case 1025: deviceStatusName = "Grid dispatch cos(Phi)-P curve";break;
                      case 1026: deviceStatusName = "Grid dispatch Q-U curve";break;
                      case 1280: deviceStatusName = "Spot-check";break;
                      case 1281: deviceStatusName = "Spot-checking";break;
                      case 1536: deviceStatusName = "Inspecting";break;
                      case 1792: deviceStatusName = "AFCI self-check";break;
                      case 2048: deviceStatusName = "I V scanning";break;
                      case 2304: deviceStatusName =" DC input detection";break;
                      case 40960: deviceStatusName = "No irradiation";break;
                      default: deviceStatusName = "undefined";break;
                  setState(SHI + id + ".DeviceStatus_Text",  deviceStatusName);
          Wäre doch gut, wenn man anstatt der Nr. auch einen Text hätte.
          mfg
          Dieter
            bolliy Developer @bahnuhr last edited by
            @bahnuhr schau mal hier
            sun2000.0.inverter.0.derived.deviceStatus
            LG Stephan
            bahnuhr 1 Reply Last reply Reply Quote 1
            • bahnuhr
              @bolliy
              Ist ja nen Ding.
              Ich habe hier geschaut:
              sun2000.0.inverter.0.deviceStatus
              Aber dass bei derived auch was ist, hab ich nicht gefunden.
              ok, dann hat man Nr. als auch Text, an unterschiedlichen Stellen, aber gut.
                @bahnuhr der State sun2000.0.inverter.0.deviceStatus ist der eigentliche Wert aus dem WR. Die Werte im path derived sind die interpretierten bzw. abgeleiteten Informationen dazu.
                Stephan
                • bahnuhr
                  @bolliy
                  Ja, ist bei dem "noch" von mir genommenen Script grundsätzlich auch so.
                  Hatte nur das Script geändert und den Text genau unter die Nr. gesetzt.
                  • bahnuhr
                    bahnuhr Forum Testing Most Active @bahnuhr last edited by
                    @bolliy
                    Ich bin gerade am umändern (von Script auf Adapter). Ist gar nicht so wenig was man ändern muss.
                    Nochwas ist mir aufgefallen:
                    Die Werte L1 + L2 + L3 müssten doch "activePower" ergeben. Beim Script was das rechnerisch richtig. Beim Adapter passt dies nicht.
                    Liegt dies an unterschiedlichen Abfrageintervallen ?
                      bolliy Developer @bahnuhr last edited by bolliy
                      @bahnuhr ja,
                      activePower wird im high Interval ausgelesen. Die Phasen im low Interval.
                      • bahnuhr
                        @bolliy
                        Wäre es sachlogisch, wenn man dies ändern würde.
                        Denn rechnerisch müsste dies passen.
                          @bahnuhr ja,
                          dann müsste man die Stromstärken und Spannungen auch ins high Interval verlegen, was ggf. die modbus Schnittstelle überfordern würde...
                          • bahnuhr
                            @bolliy
                            noch was:
                            battery.runningStatus
                            müsste doch auch eine Nr. sein, die vom WR kommt. (analog deviseStatus)
                            also so:
                                   switch (getState(SHI + id + ".Battery.RunningStatus").val) {
                                        case 0: Battery_RunningStatus = "offline";break;
                                        case 1: Battery_RunningStatus = "standby";break;
                                        case 2: Battery_RunningStatus = "running";break;
                                        case 3: Battery_RunningStatus = "fault";break;
                                        case 4: Battery_RunningStatus = "sleepmode";break;
                                        default: Battery_RunningStatus = "undefined";break;
                                    setState(SHI + id + ".Battery.RunningStatus_Text",  Battery_RunningStatus);
                            Hier erscheint aber jetzt unter battery der Text.
                            Müsste denn nach der Logik der Text nicht auch unter derived stehen ?
                            • bahnuhr
                              @bolliy sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                              @bahnuhr ja,
                              würde ich sachlogisch richtiger finden. Per Script gab es da keine modbus Schnittstellen Probleme.
                                @bahnuhr ja hast recht. Ist aber aus historischen Gründen nicht angepasst worden ...
                                • bahnuhr
                                  @bolliy
                                  Sätze wie: "hab ich schon immer so gemacht" sind nicht gut 😉
                                  T'schuldigung; bin gerade intensiv am Testen. Deshalb nerve ich am Feiertag ein bisschen 😉
                                    @bahnuhr da sehr viele Daten abgerufen werden und einige User eine sehr kleinen Intervall wünschen, kommt es zu verzögerungen - gerade wenn man mehrere WR über den SDongle ausliest.
                                      @bahnuhr kein Problem 👍 Sofern du hierzu eine Anpassung wünscht, würde ich dich bitten ein issue im github aufzumachen.
                                      • bahnuhr
                                        bahnuhr Forum Testing Most Active @bolliy last edited by bahnuhr
                                        issue im github
                                        mach ich.
                                        edit: angelegt:
                                        https://github.com/bolliy/ioBroker.sun2000/issues/174
                                        bahnuhr created this issue in bolliy/ioBroker.sun2000
                                        closed active Power; Summe aus L1+L2+L3 #174
                                        • bahnuhr
                                          @bolliy
                                          noch ne Frage.
                                          Auf git steht:
                                          Wenn man nun ein neues Modul mit diesen 21 kw kaufen möchte, funktioniert dies dann nicht ?
                                          • bahnuhr
                                            Und noch ne Frage:
                                            auf git steht:
                                            Klicke ich auf wiki kommt:
                                            Das passt nicht zusammen.
                                            Ich habe bei mir:
                                            und bekomme die Daten einwandfrei ausgelesen.
                                            Nach deiner Definition müsste aber doch meine V zu alt sein.
                                            richtig ?
                                            oder anders; was würde jetzt nicht funktionieren ?
                                            adapter emma huawei inverter luna2000 modbus tcp modbus-proxy sdongle smartlogger sun2000
                                            84
                                            1025
                                            248583
