    4. Test Adapter sun2000 v0.1.x - Huawei Wechselrichter
    • bahnuhr
      bahnuhr Forum Testing Most Active @bolliy last edited by
      @bolliy
      Guten Morgen,
      könntest du noch einen "deviceStatus_Text" einbauen.
      z.B. nach diesem Schema:
      setState(SHI + id + ".DeviceStatus",           getU16(Buffer[id-1], 32089));
              var deviceStatusName = "";
              switch (getState(SHI + id + ".DeviceStatus").val) {
                  case 0: deviceStatusName = "Initializing";break;
                  case 1: deviceStatusName = "Detecting ISO";break;
                  case 2: deviceStatusName = "Detecting irradiation";break;
                  case 3: deviceStatusName = "Grid detecting";break;
                  case 256: deviceStatusName = "Starting";break;
                  case 512: deviceStatusName = "On grid";break;
                  case 513: deviceStatusName = "On grid Power limit";break;
                  case 514: deviceStatusName = "On grid self derating";break;
                  case 768: deviceStatusName = "Shutdown fault";break;
                  case 769: deviceStatusName = "Shutdown command";break;
                  case 770: deviceStatusName = "Shutdown OVGR";break;
                  case 771: deviceStatusName = "Shutdown communication disconnected";break;
                  case 772: deviceStatusName = "Shutdown power limit";break;
                  case 773: deviceStatusName = "Shutdown start manually";break;
                  case 774: deviceStatusName = "Shutdown DC switch OFF";break;
                  case 1025: deviceStatusName = "Grid dispatch cos(Phi)-P curve";break;
                  case 1026: deviceStatusName = "Grid dispatch Q-U curve";break;
                  case 1280: deviceStatusName = "Spot-check";break;
                  case 1281: deviceStatusName = "Spot-checking";break;
                  case 1536: deviceStatusName = "Inspecting";break;
                  case 1792: deviceStatusName = "AFCI self-check";break;
                  case 2048: deviceStatusName = "I V scanning";break;
                  case 2304: deviceStatusName =" DC input detection";break;
                  case 40960: deviceStatusName = "No irradiation";break;
                  default: deviceStatusName = "undefined";break;
              setState(SHI + id + ".DeviceStatus_Text",  deviceStatusName);
      Wäre doch gut, wenn man anstatt der Nr. auch einen Text hätte.
      mfg
      Dieter
        bolliy Developer @bahnuhr last edited by
        @bahnuhr schau mal hier
        sun2000.0.inverter.0.derived.deviceStatus
        LG Stephan
        bahnuhr 1 Reply Last reply Reply Quote 1
        • bahnuhr
          @bolliy
          Ist ja nen Ding.
          Ich habe hier geschaut:
          sun2000.0.inverter.0.deviceStatus
          Aber dass bei derived auch was ist, hab ich nicht gefunden.
          ok, dann hat man Nr. als auch Text, an unterschiedlichen Stellen, aber gut.
            @bahnuhr der State sun2000.0.inverter.0.deviceStatus ist der eigentliche Wert aus dem WR. Die Werte im path derived sind die interpretierten bzw. abgeleiteten Informationen dazu.
            Stephan
            • bahnuhr
              @bolliy
              Ja, ist bei dem "noch" von mir genommenen Script grundsätzlich auch so.
              Hatte nur das Script geändert und den Text genau unter die Nr. gesetzt.
              • bahnuhr
                bahnuhr Forum Testing Most Active @bahnuhr last edited by
                @bolliy
                Ich bin gerade am umändern (von Script auf Adapter). Ist gar nicht so wenig was man ändern muss.
                Nochwas ist mir aufgefallen:
                Die Werte L1 + L2 + L3 müssten doch "activePower" ergeben. Beim Script was das rechnerisch richtig. Beim Adapter passt dies nicht.
                Liegt dies an unterschiedlichen Abfrageintervallen ?
                  bolliy Developer @bahnuhr last edited by bolliy
                  @bahnuhr ja,
                  activePower wird im high Interval ausgelesen. Die Phasen im low Interval.
                  bahnuhr 2 Replies Last reply Reply Quote 0
                  • bahnuhr
                    @bolliy
                    Wäre es sachlogisch, wenn man dies ändern würde.
                    Denn rechnerisch müsste dies passen.
                      @bahnuhr ja,
                      dann müsste man die Stromstärken und Spannungen auch ins high Interval verlegen, was ggf. die modbus Schnittstelle überfordern würde...
                      • bahnuhr
                        @bolliy
                        noch was:
                        battery.runningStatus
                        müsste doch auch eine Nr. sein, die vom WR kommt. (analog deviseStatus)
                        also so:
                               switch (getState(SHI + id + ".Battery.RunningStatus").val) {
                                    case 0: Battery_RunningStatus = "offline";break;
                                    case 1: Battery_RunningStatus = "standby";break;
                                    case 2: Battery_RunningStatus = "running";break;
                                    case 3: Battery_RunningStatus = "fault";break;
                                    case 4: Battery_RunningStatus = "sleepmode";break;
                                    default: Battery_RunningStatus = "undefined";break;
                                setState(SHI + id + ".Battery.RunningStatus_Text",  Battery_RunningStatus);
                        Hier erscheint aber jetzt unter battery der Text.
                        Müsste denn nach der Logik der Text nicht auch unter derived stehen ?
                        • bahnuhr
                          @bolliy sagte in Test Adapter sun2000 v0.1.x - Huawei Wechselrichter:
                          @bahnuhr ja,
                          würde ich sachlogisch richtiger finden. Per Script gab es da keine modbus Schnittstellen Probleme.
                            @bahnuhr ja hast recht. Ist aber aus historischen Gründen nicht angepasst worden ...
                            • bahnuhr
                              @bolliy
                              Sätze wie: "hab ich schon immer so gemacht" sind nicht gut 😉
                              T'schuldigung; bin gerade intensiv am Testen. Deshalb nerve ich am Feiertag ein bisschen 😉
                                @bahnuhr da sehr viele Daten abgerufen werden und einige User eine sehr kleinen Intervall wünschen, kommt es zu verzögerungen - gerade wenn man mehrere WR über den SDongle ausliest.
                                  @bahnuhr kein Problem 👍 Sofern du hierzu eine Anpassung wünscht, würde ich dich bitten ein issue im github aufzumachen.
                                  • bahnuhr
                                    bahnuhr Forum Testing Most Active @bolliy last edited by bahnuhr
                                    issue im github
                                    mach ich.
                                    edit: angelegt:
                                    https://github.com/bolliy/ioBroker.sun2000/issues/174
                                    bahnuhr created this issue in bolliy/ioBroker.sun2000
                                    closed active Power; Summe aus L1+L2+L3 #174
                                    • bahnuhr
                                      @bolliy
                                      noch ne Frage.
                                      Auf git steht:
                                      Wenn man nun ein neues Modul mit diesen 21 kw kaufen möchte, funktioniert dies dann nicht ?
                                      • bahnuhr
                                        Und noch ne Frage:
                                        auf git steht:
                                        Klicke ich auf wiki kommt:
                                        Das passt nicht zusammen.
                                        Ich habe bei mir:
                                        und bekomme die Daten einwandfrei ausgelesen.
                                        Nach deiner Definition müsste aber doch meine V zu alt sein.
                                        richtig ?
                                        oder anders; was würde jetzt nicht funktionieren ?
                                          @bahnuhr was meinst du mit 21kw? Meinst du eine Batteriemodul mit 21kWh Kapazität?
                                          Wird bestimmt funktionieren - was ich aber noch nicht getestet habe.
                                            @bahnuhr damit die modbus Abfrage funktioniert, wird mind. 00SPC133 benötigt. Die 10SPC121 wird empfohlen. Andere Versionen werden natürlich auch funktionieren. Es gab aber mit den aktuellen Versionen Probleme. Deshalb lieber eine Version vor der 10SPC200 nehmen.
                                            B bahnuhr 2 Replies Last reply Reply Quote 0
                                            adapter emma huawei inverter luna2000 modbus tcp modbus-proxy sdongle smartlogger sun2000
                                            84
                                            1042
                                            275865
