    4. Backup wiederherstellen auf js-controller 4.0
      Homoran Global Moderator Administrators @xT1GeRx last edited by
      @xt1gerx sagte in Backup wiederherstellen auf js-controller 4.0:
      Ich warte dann mal bis 20 Uhr ab und melde mich dann nochmals.
      was sagt denn iob logs --watch
      das müsste mittlerweile eigentlich fertig sein.
      • X
        @homoran ich habe mal die warnings rausgesucht. Die Liste ist aktuell über 1000 Zeilen Lang.
        2025-06-09 17:56:41.710  - error: admin.0 (2990) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
        2025-06-09 17:56:42.746  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user resarts it.
        2025-06-09 17:57:31.161  - warn: host.iobroker startInstance cannot find adapter "javascript@6.0.3". Try to install it... 1 attempt
        2025-06-09 18:00:28.860  - error: admin.0 (3429) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
        2025-06-09 18:00:29.853  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
        2025-06-09 18:11:13.453  - error: admin.0 (4020) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
        2025-06-09 18:11:13.455  - info: admin.0 (4020) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-06-09 18:11:13.768  - info: admin.0 (4020) Request actual repository...
        2025-06-09 18:11:14.024  - warn: admin.0 (4020) Cannot check node.js/npm version
        2025-06-09 18:11:14.048  - info: admin.0 (4020) terminating http server on port 8081
        2025-06-09 18:11:14.533  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
        2025-06-09 18:27:24.227  - error: admin.0 (4479) Cannot create web-server: TypeError: Cannot read properties of undefined (reading 'createServerAsync')
        2025-06-09 18:27:24.230  - info: admin.0 (4479) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        2025-06-09 18:27:24.501  - info: admin.0 (4479) Request actual repository...
        2025-06-09 18:27:24.778  - warn: admin.0 (4479) Cannot check node.js/npm version
        2025-06-09 18:27:25.039  - info: admin.0 (4479) terminating http server on port 8081
        2025-06-09 18:27:25.449  - info: host.iobroker Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
        2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user rest        arts it.
        2025-06-09 18:27:25.514  - info: host.iobroker Do not restart adapter system.adapter.admin.0 because desired by instance
        2025-06-09 18:27:26.456  - info: backitup.0 (4506) starting. Version 2.5.12 in /opt/iobroker/node_modules/iobroker.backitup, node: v20.19.2, js-controller: 4.0.23
        2025-06-09 18:27:26.557  - info: backitup.0 (4506) [iobroker] backup was activated at 02:30 every 1 day(s)
        Wie es aussieht gibt es ein Problem mit dem Admin Web Zugang oder?
          Homoran Global Moderator Administrators @xT1GeRx last edited by Homoran
          uninteressant!
          es geht um die gerade aktuellen Meldungen!
          die geposteten sind ja "uralt"
            Thomas Braun Most Active @xT1GeRx last edited by
            @xt1gerx
            Ist das Backup jetzt drin?
            Dann musst du jetzt den Rest in die Gegenwart holen.
            Inkl. des js-controllers@7 dann.
            • X
              @Thomas-Braun
              aktuell die letzten. Kann auch die komplette Liste einfügen?
              2025-06-09 18:27:24.286  - info: host.iobroker instance system.adapter.backitup.0 started with pid 4506
              2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
              • X
                xT1GeRx @Thomas Braun last edited by
                @thomas-braun ich würde sagen das das backup geladen ist. Verstehe ich das richtig, dass ich zuerst alles updaten soll bevor der Webzugang wieder geht? Wenn ja, hättest du mir eine sichere anleitung, bevor ich wieder was versaue?
                  @xt1gerx
                  Dann lass uns doch mal sehen, wo du da nun stehst.
                  iob diag
                  anschauen.
                  • X
                    @thomas-braun alles war rauskam
                    ========== Start marking the full check here ===========
                    ```bash
                    Script v.2025-03-08
                    *** BASE SYSTEM ***
                     Static hostname: iobroker
                           Icon name: computer
                              Kernel: Linux 6.12.25+rpt-rpi-v8
                        Architecture: arm64
                    OS is similar to:
                    Model           : Raspberry Pi 4 Model B Rev 1.2
                    Docker          : false
                    Virtualization  : none
                    Kernel          : aarch64
                    Userland        : 64 bit
                    Systemuptime and Load:
                     19:01:35 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
                    CPU threads: 4
                    *** LIFE CYCLE STATUS ***
                    Operating System is the current Debian stable version codenamed 'bookworm'!
                    *** RASPBERRY THROTTLING ***
                    Current issues:
                    Previously detected issues:
                    *** TIME AND TIMEZONES ***
                                   Local time: Mon 2025-06-09 19:01:35 CEST
                               Universal time: Mon 2025-06-09 17:01:35 UTC
                                     RTC time: n/a
                                  NTP service: active
                              RTC in local TZ: no
                    *** Users and Groups ***
                    User that called 'iob diag':
                    admin
                    HOME=/home/admin
                    GROUPS=admin adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    iobroker
                    HOME=/home/iobroker
                    GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                    *** DISPLAY-SERVER SETUP ***
                    Display-Server: false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            4.0G        385M        1.8G        6.2M        1.9G        3.6G
                    Swap:           536M          0B        536M
                    Total:          4.5G        385M        2.3G
                    Active iob-Instances:   2
                             3791 M total memory
                              367 M used memory
                              406 M active memory
                             1464 M inactive memory
                             1712 M free memory
                               99 M buffer memory
                             1693 M swap cache
                              511 M total swap
                                0 M used swap
                              511 M free swap
                    top - 19:01:36 up  2:30,  1 user,  load average: 0.37, 0.08, 0.03
                    Tasks: 165 total,   1 running, 164 sleeping,   0 stopped,   0 zombie
                    %Cpu(s):  0.0 us, 25.0 sy,  0.0 ni, 75.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                    MiB Mem :   3791.4 total,   1712.3 free,    367.5 used,   1793.1 buff/cache
                    MiB Swap:    512.0 total,    512.0 free,      0.0 used.   3423.9 avail Mem
                    *** FAILED SERVICES ***
                    0 loaded units listed.
                    *** DMESG CRITICAL ERRORS ***
                    No critical errors detected
                    *** FILESYSTEM ***
                    udev           devtmpfs  1.6G     0  1.6G   0% /dev
                    tmpfs          tmpfs     380M  5.9M  374M   2% /run
                    /dev/mmcblk0p2 ext4      117G  4.1G  107G   4% /
                    tmpfs          tmpfs     1.9G     0  1.9G   0% /dev/shm
                    /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
                    tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                    [Mon Jun  9 16:30:57 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm28        35.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  c        onsole=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
                    [Mon Jun  9 16:30:58 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                    [Mon Jun  9 16:31:00 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                    Show mounted filesystems:
                    TARGET           SOURCE         FSTYPE OPTIONS
                    /                /dev/mmcblk0p2 ext4   rw,noatime
                    `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                    /var:
                    889M    /var/
                    213M    /var/cache
                    208M    /var/cache/apt
                    164M    /var/lib
                    135M    /var/lib/apt/lists
                    Archived and active journals take up 4.7M in the file system.
                    /opt/iobroker/backups:
                    11M     /opt/iobroker/backups/
                    /opt/iobroker/iobroker-data:
                    198M    /opt/iobroker/iobroker-data/
                    169M    /opt/iobroker/iobroker-data/files
                    48M     /opt/iobroker/iobroker-data/files/javascript.admin
                    47M     /opt/iobroker/iobroker-data/files/admin.admin
                    46M     /opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                    26M     /opt/iobroker/iobroker-data/objects.jsonl
                    12M     /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js.map
                    8.1M    /opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                    6.2M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/790.1eb1f33b.chunk.js
                    4.6M    /opt/iobroker/iobroker-data/files/javascript.admin/vs/language/typescript/tsWorker.js
                    USB-Devices by-id:
                    /dev/serial/by-id/usb-Texas_Instruments_TI_CC2531_USB_CDC___0X00124B001CDD3476-if00
                    *** ZigBee Settings ***
                    Zigbee Network Settings on your coordinator/in nvbackup are:
                    zigbee.X
                    Extended Pan ID:
                    *** MASKED ***
                    Pan ID:
                    *** MASKED ***
                    Channel:
                    *** MASKED ***
                    Network Key:
                    *** MASKED ***
                    To unmask the settings run 'iob diag --unmask'
                    *** NodeJS-Installation ***
                    /usr/bin/nodejs         v20.19.2
                    /usr/bin/node           v20.19.2
                    /usr/bin/npm            10.8.2
                    /usr/bin/npx            10.8.2
                    /usr/bin/corepack       0.31.0
                    nodejs:
                      Installed: 20.19.2-1nodesource1
                      Candidate: 20.19.2-1nodesource1
                      Version table:
                     *** 20.19.2-1nodesource1 1001
                            500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                            100 /var/lib/dpkg/status
                         20.19.1-1nodesource1 1001
                         20.19.0-1nodesource1 1001
                         20.18.3-1nodesource1 1001
                         20.18.2-1nodesource1 1001
                         20.18.1-1nodesource1 1001
                         20.18.0-1nodesource1 1001
                         20.17.0-1nodesource1 1001
                         20.16.0-1nodesource1 1001
                         20.15.1-1nodesource1 1001
                         20.15.0-1nodesource1 1001
                         20.14.0-1nodesource1 1001
                         20.13.1-1nodesource1 1001
                         20.13.0-1nodesource1 1001
                         20.12.2-1nodesource1 1001
                         20.12.1-1nodesource1 1001
                         20.12.0-1nodesource1 1001
                         20.11.1-1nodesource1 1001
                         20.11.0-1nodesource1 1001
                         20.10.0-1nodesource1 1001
                         20.9.0-1nodesource1 1001
                         20.8.1-1nodesource1 1001
                         20.8.0-1nodesource1 1001
                         20.7.0-1nodesource1 1001
                         20.6.1-1nodesource1 1001
                         20.6.0-1nodesource1 1001
                         20.5.1-1nodesource1 1001
                         20.5.0-1nodesource1 1001
                         20.4.0-1nodesource1 1001
                         20.3.1-1nodesource1 1001
                         20.3.0-1nodesource1 1001
                         20.2.0-1nodesource1 1001
                         20.1.0-1nodesource1 1001
                         20.0.0-1nodesource1 1001
                         18.19.0+dfsg-6~deb12u2 500
                         18.19.0+dfsg-6~deb12u1 500
                    No problems detected
                    Errors in npm tree: 0
                    *** ioBroker-Installation ***
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    Hosts:
                    iobroker            iobroker (version: 4.0.23, hostname: iobroker      , alive, uptime: 2058)
                    Core adapters versions
                    admin:          6.3.5
                    javascript:     6.0.3
                    nodejs modules from github:     0
                    Adapter State
                      system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : iobroker                                 -  enabled
                      system.adapter.birthdays.0              : birthdays             : iobroker                                 - disabled
                      system.adapter.daswetter.0              : daswetter             : iobroker                                 - disabled
                      system.adapter.discovery.0              : discovery             : iobroker                                 - disabled
                      system.adapter.dwd.0                    : dwd                   : iobroker                                 - disabled
                      system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 - disabled
                      system.adapter.hmip.0                   : hmip                  : iobroker                                 - disabled
                      system.adapter.hue.0                    : hue                   : iobroker                                 - disabled, port: 443
                      system.adapter.javascript.0             : javascript            : iobroker                                 - disabled
                      system.adapter.pollenflug.0             : pollenflug            : iobroker                                 - disabled
                      system.adapter.pushover.0               : pushover              : iobroker                                 - disabled
                      system.adapter.rpi2.0                   : rpi2                  : iobroker                                 - disabled
                      system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 - disabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : iobroker                                 - disabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : iobroker                                 - disabled
                      system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 - disabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : iobroker                                 - disabled
                      system.adapter.vis-timeandweather.0     : vis-timeandweather    : iobroker                                 - disabled
                      system.adapter.vis.0                    : vis                   : iobroker                                 - disabled
                      system.adapter.web.0                    : web                   : iobroker                                 - disabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.zigbee.0                 : zigbee                : iobroker                                 - disabled
                    + instance is alive
                    ioBroker-Repositories
                    Active repo(s): stable
                    Installed ioBroker-Adapters
                    Used repository: stable
                    Adapter    "admin"        : 7.6.17   , installed 6.3.5  [Updatable]
                    Adapter    "backitup"     : 3.2.2    , installed 2.5.12 [Updatable]
                    Adapter    "birthdays"    : 4.0.0    , installed 2.2.0  [Updatable]
                    Adapter    "daswetter"    : 3.2.3    , installed 3.1.7  [Updatable]
                    Adapter    "discovery"    : 5.0.0    , installed 3.1.0  [Updatable]
                    Adapter    "dwd"          : 2.8.5    , installed 2.8.3  [Updatable]
                    Adapter    "fullybrowser" : 3.1.1    , installed 2.1.2  [Updatable]
                    Adapter    "hmip"         : 1.27.0   , installed 1.20.0 [Updatable]
                    Adapter    "hue"          : 3.16.1   , installed 3.7.1  [Updatable]
                    Adapter    "javascript"   : 8.9.2    , installed 6.0.3  [Updatable]
                    Controller "js-controller": 7.0.6    , installed 4.0.23 [Updatable]
                    Adapter    "pollenflug"   : 2.0.0    , installed 1.0.6  [Updatable]
                    Adapter    "pushover"     : 4.1.0    , installed 3.0.3  [Updatable]
                    Adapter    "rpi2"         : 2.4.0    , installed 1.3.2  [Updatable]
                    Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
                    Adapter    "socketio"     : 6.7.1    , installed 4.2.0  [Updatable]
                    Adapter    "tankerkoenig" : 3.4.0    , installed 2.1.1  [Updatable]
                    Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
                    Adapter    "vis-hqwidgets": 1.5.1    , installed 1.3.0  [Updatable]
                    Adapter    "vis-icontwo"  : 1.11.0   , installed 0.90.0 [Updatable]
                    Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.1  [Updatable]
                    Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.0.12 [Updatable]
                    Adapter    "web"          : 7.0.8    , installed 4.3.0  [Updatable]
                    Adapter    "ws"           : 2.6.2    , installed 1.3.0  [Updatable]
                    Adapter    "zigbee"       : 2.0.5    , installed 1.8.10 [Updatable]
                    Objects and States
                    Objects:        8811
                    States:         7998
                    Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                    Hit:3 http://archive.raspberrypi.com/debian bookworm InRelease
                    Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                    Reading package lists... Done
                    Pending Updates: 48
                    2025-06-09 18:27:17.755  - info: host.iobroker hostname: iobroker, node: v20.19.2
                    2025-06-09 18:27:17.757  - info: host.iobroker ip addresses: 192.168.178.37 2003:d0:6700:2e00:d638:5401:7be0:ba73 fe80::76d4:1422:ca5b:b545
                    2025-06-09 18:27:19.448  - info: host.iobroker connected to Objects and States
                    2025-06-09 18:27:19.500  - info: host.iobroker added notifications configuration of host
                    2025-06-09 18:27:20.179  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeCurrent"
                    2025-06-09 18:27:20.181  - info: host.iobroker 22 instances found
                    2025-06-09 18:27:20.218  - info: host.iobroker starting 2 instances
                    2025-06-09 18:27:20.313  - info: host.iobroker Delete state "system.host.iobroker.versions.nodeNewest"
                    2025-06-09 18:27:20.328  - info: host.iobroker instance system.adapter.admin.0 started with pid 4479
                    2025-06-09 18:27:20.340  - info: host.iobroker Some obsolete host states deleted.
                    2025-06-09 18:27:22.763  - info: admin.0 (4479) starting. Version 6.3.5 in /opt/iobroker/node_modules/iobroker.admin, node: v20.19.2, js-controller: 4.0.23
                    2025-06-09 18:27:22.809  - info: admin.0 (4479) requesting all states
                    2025-06-09 18:27:22.810  - info: admin.0 (4479) requesting all objects
                    2025-06-09 18:27:24.173  - info: admin.0 (4479) received all objects
                    2025-06-09 18:27:25.514  - error: host.iobroker instance system.adapter.admin.0 terminated by request of the instance itself and will not be restarted, before user res        tarts it.
                    iob diag has finished.
                      @xt1gerx
                      Also alles updatebar.
                      Mit dem System selber anfangen:
                      iob stop
                      sudo apt update && sudo apt full-upgrade
                      sudo reboot
                      Dann den ioBroker in Angriff nehmen:
                      iob update
                      iob upgrade all
                      Das wird vermutlich nicht ohne Fehlermeldungen durchlaufen. Aber egal.
                      Dann
                      iob stop
                      iob upgrade self
                      iob start
                      iob update
                      iob upgrade all
                      versuchen. Wenn das nicht in einem Rutsch den js-controller@7 auf die Kiste spült, dann versuchen wir es mit Schriten über js-controller@5 und @6.
                      • X
                        @thomas-braun Hat alles geklappt. Js auf 7 und node v20. Alle Updates ohne Fehlermeldung. Komme überall drauf und alles ist vorhanden wie davor.
                        VIELEN VIELEN DANK für deine Hilfe und Zeit @thomas-braun 🎉
                          @xt1gerx
                          Gut gut.
                          Dann zeig mal zum Abschluß nochmal ein
                          iob diag
                          Für die Zukunft: Lass das System nicht mehr versumpfen.
                          Man muss nicht eine Version x.0 am ersten Tag installieren, aber eine x.1 sollte man dann schon beizeiten mitnehmen.
                          X 1 Reply Last reply Reply Quote 1
                          • X
                            ```bash
                            Script v.2025-03-08
                            *** BASE SYSTEM ***
                                   Icon name: computer
                                Architecture: arm64
                            OS is similar to:
                            Docker          : false
                            Kernel          : aarch64
                            Userland        : 64 bit
                             20:21:41 up  1:02,  1 user,  load average: 0.22, 0.21, 0.20
                            CPU threads: 4
                            Current issues:
                                           Local time: Mon 2025-06-09 20:21:42 CEST
                                       Universal time: Mon 2025-06-09 18:21:42 UTC
                                             RTC time: n/a
                                          NTP service: active
                                      RTC in local TZ: no
                            admin
                            HOME=/home/admin
                            iobroker
                            HOME=/home/iobroker
                            Desktop:
                            Terminal:       tty
                            *** MEMORY ***
                            Mem:            4.0G        1.4G        1.0G        6.2M        1.7G        2.6G
                            Swap:           536M          0B        536M
                            Total:          4.5G        1.4G        1.5G
                            Active iob-Instances:   15
                                     3797 M total memory
                                     1357 M used memory
                                     1340 M active memory
                                     1294 M inactive memory
                                      958 M free memory
                                       72 M buffer memory
                                     1501 M swap cache
                                      511 M total swap
                                        0 M used swap
                                      511 M free swap
                            top - 20:21:42 up  1:02,  1 user,  load average: 0.22, 0.21, 0.20
                            Tasks: 179 total,   1 running, 178 sleeping,   0 stopped,   0 zombie
                            %Cpu(s): 16.7 us, 16.7 sy,  0.0 ni, 66.7 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                            MiB Mem :   3797.4 total,    956.8 free,   1359.0 used,   1574.6 buff/cache
                            MiB Swap:    512.0 total,    512.0 free,      0.0 used.   2438.4 avail Mem
                            *** FILESYSTEM ***
                            /dev/mmcblk0p2 ext4      117G  4.2G  107G   4% /
                            [Mon Jun  9 19:19:06 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_h                                     eadphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:B9:D2:87 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size                                     =0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=ed3ceec2-02 rootfstype=ext4 fsck.repair=yes rootwait
                            [Mon Jun  9 19:19:07 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                            [Mon Jun  9 19:19:08 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                            /var:
                            890M    /var/
                            214M    /var/cache
                            208M    /var/cache/apt
                            164M    /var/lib
                            235M    /opt/iobroker/iobroker-data/
                            194M    /opt/iobroker/iobroker-data/files
                            32M     /opt/iobroker/iobroker-data/objects.jsonl
                            27M     /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js.map
                            9.2M    /opt/iobroker/iobroker-data/files/tankerkoenig.admin/build/index.js
                            8.9M    /opt/iobroker/iobroker-data/states.jsonl
                            USB-Devices by-id:
                            zigbee.X
                            Extended Pan ID:
                            *** MASKED ***
                            Pan ID:
                            *** MASKED ***
                            Channel:
                            *** MASKED ***
                            Network Key:
                            *** MASKED ***
                            /usr/bin/npm            10.8.2
                            /usr/bin/npx            10.8.2
                            nodejs:
                              Version table:
                            ioBroker Status
                            Objects type: jsonl
                            States  type: jsonl
                            Hosts:
                            iobroker            iobroker (version: 7.0.6, hostname: iobroker      , alive, uptime: 3429)
                            js-controller:  7.0.6
                            admin:          7.6.17
                            javascript:     8.9.2
                            Adapter State
                            + system.adapter.admin.0                  : admin                 : iobroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                              system.adapter.birthdays.0              : birthdays             : iobroker                                 -  enabled
                              system.adapter.daswetter.0              : daswetter             : iobroker                                 -  enabled
                            + system.adapter.discovery.0              : discovery             : iobroker                                 -  enabled
                              system.adapter.dwd.0                    : dwd                   : iobroker                                 -  enabled
                            + system.adapter.fullybrowser.0           : fullybrowser          : iobroker                                 -  enabled
                            + system.adapter.hmip.0                   : hmip                  : iobroker                                 -  enabled
                            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 443
                            + system.adapter.javascript.0             : javascript            : iobroker                                 -  enabled
                            + system.adapter.pollenflug.0             : pollenflug            : iobroker                                 -  enabled
                            + system.adapter.pushover.0               : pushover              : iobroker                                 -  enabled
                            + system.adapter.rpi2.0                   : rpi2                  : iobroker                                 -  enabled
                            + system.adapter.tankerkoenig.0           : tankerkoenig          : iobroker                                 -  enabled
                            + system.adapter.vis-inventwo.0           : vis-inventwo          : iobroker                                 -  enabled
                              system.adapter.vis.0                    : vis                   : iobroker                                 -  enabled
                            + system.adapter.web.0                    : web                   : iobroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                            + system.adapter.zigbee.0                 : zigbee                : iobroker                                 -  enabled
                            + instance is alive
                            + system.adapter.hue.0                    : hue                   : iobroker                                 -  enabled, port: 400
                            Upgrade policy: none
                            Adapter    "admin"        : 7.6.17   , installed 7.6.17
                            Adapter    "backitup"     : 3.2.2    , installed 3.2.2
                            Adapter    "birthdays"    : 4.0.0    , installed 4.0.0
                            Adapter    "daswetter"    : 3.2.3    , installed 3.2.3
                            Adapter    "fullybrowser" : 3.1.1    , installed 3.1.1
                            Adapter    "hmip"         : 1.27.0   , installed 1.27.0
                            Adapter    "hue"          : 3.16.1   , installed 3.16.1
                            Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                            Controller "js-controller": 7.0.6    , installed 7.0.6
                            Adapter    "pollenflug"   : 2.0.0    , installed 2.0.0
                            Adapter    "pushover"     : 4.1.0    , installed 4.1.0
                            Adapter    "rpi2"         : 2.4.0    , installed 2.4.0
                            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
                            Adapter    "tankerkoenig" : 3.4.0    , installed 3.4.0
                            Adapter    "vis-icontwo"  : 1.11.0   , installed 1.11.0
                            Adapter    "vis-inventwo" : 3.3.5    , installed 3.3.5
                            Adapter    "vis-jqui-mfd" : 1.1.1    , installed 1.1.1
                            Adapter    "web"          : 7.0.8    , installed 7.0.8
                            Adapter    "ws"           : 2.6.2    , installed 2.6.2
                            Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                            Objects and States
                            Objects:        8929
                            States:         8070
                            Pending Updates: 1
                            Danke nochmals. Ich werde es jetzt nicht mehr schleifen lassen mit den Updates.
                              Pending Updates: 1
                              Da hängt noch was im Update.
                              sudo apt update
                              • X
                                @thomas-braun ist mir nicht aufgefallen. Danke. Erledigt.
                                admin@iobroker:~ $ sudo apt update
                                Building dependency tree... Done
                                All packages are up to date.
                                614
