    3. Einsteigerfragen
    4. Einbindung von Geräten
    5. Gelöst: Neues BK von Solakon
    • wendy2702
      wendy2702 @michihorn last edited by
      @michihorn such Funktion
      https://forum.iobroker.net/topic/67363/apsystems-ez1-m/6
        michihorn @wendy2702 last edited by
        @wendy2702 Hallöchen
        ja den habe ich schon gefunden, in den Objekten ist nicht viel zu sehen.
        ap-systems-ez1.0
        2025-06-09 17:34:37.426	info	onOffStatus: undefined
        ap-systems-ez1.0
        2025-06-09 17:34:37.424	info	maxPower: undefined
        ap-systems-ez1.0
        2025-06-09 17:34:37.414	info	alarmInfo: undefined
        ap-systems-ez1.0
        2025-06-09 17:34:37.406	info	outputData: undefined
        ap-systems-ez1.0
        2025-06-09 17:34:37.401	info	deviceInfo: undefined
        ap-systems-ez1.0
        2025-06-09 17:34:37.080	info	url: http://192.168.178.153:8050/getMaxPower
        ap-systems-ez1.0
        2025-06-09 17:34:37.074	info	url: http://192.168.178.153:8050/getOnOff
        ap-systems-ez1.0
        2025-06-09 17:34:37.066	info	url: http://192.168.178.153:8050/getAlarm
        ap-systems-ez1.0
        2025-06-09 17:34:37.064	info	url: http://192.168.178.153:8050/getOutputData
        ap-systems-ez1.0
        2025-06-09 17:34:37.062	info	url: http://192.168.178.153:8050/getDeviceInfo
        ap-systems-ez1.0
        2025-06-09 17:33:37.322	info	maxPower: undefined
        ap-systems-ez1.0
        2025-06-09 17:33:37.320	info	onOffStatus: undefined
        ap-systems-ez1.0
        2025-06-09 17:33:37.310	info	alarmInfo: undefined
        ap-systems-ez1.0
        2025-06-09 17:33:37.308	info	outputData: undefined
        ap-systems-ez1.0
        2025-06-09 17:33:37.302	info	deviceInfo: undefined
        ap-systems-ez1.0
        2025-06-09 17:33:37.082	info	url: http://192.168.178.153:8050/getMaxPower
        ap-systems-ez1.0
        2025-06-09 17:33:37.075	info	url: http://192.168.178.153:8050/getOnOff
        ap-systems-ez1.0
        2025-06-09 17:33:37.068	info	url: http://192.168.178.153:8050/getAlarm
        ap-systems-ez1.0
        2025-06-09 17:33:37.064	info	url: http://192.168.178.153:8050/getOutputData
        ap-systems-ez1.0
        2025-06-09 17:33:37.061	info	url: http://192.168.178.153:8050/getDeviceInfo
        wendy2702 liv-in-sky 2 Replies Last reply Reply Quote 0
        • wendy2702
          wendy2702 @michihorn last edited by wendy2702
          @michihorn stell das loggen mal auf Debug, da sieht man unter Umständen mehr
          Edit: und bekommst du was zurück wenn du einen der Links mal im Browser aufrufst?
            liv-in-sky @michihorn last edited by liv-in-sky
            @michihorn zeig mal dein script, das die werte ausgeben soll
            bei mir sieht das zb so aus:
              michihorn @liv-in-sky last edited by
              @liv-in-sky So weit bin ich noch gar nicht, ich wollte nur die Daten des Adapters erstmal sehen. Ein Script habe noch nicht.
                michihorn @wendy2702 last edited by michihorn
                @wendy2702 Ich war s
                ja schon auf Silly....selbst wenn ich die Http.... in den Browser stecke kommt nichts
                Verbindung fehlgeschlagen
                In der APP klappt aber alles
                • wendy2702
                  @michihorn läuft dein iobroker im Docker oder wie ist der installiert?
                  Zeig mal
                  iob diag
                  Edit: überlesen, im browser kommt nichts? Ip stimmt?
                    @michihorn
                    Ist es ein ez1
                    Wenn ich in der App auf lokal umstelle kann ich die App nicht mehr nutzen
                    Hat du das gemacht
                      @liv-in-sky Bislang habe ich nur die APP vor Solakon genutzt, die zeigt tatsächlich Werte.
                      Ich habe nun die APP AP EasyPower geladen. Eine Verbindung per Bluetooth klappt nicht, die behauptet ich müsse eine Bluetooth Freigabe für die APP erteilen.
                      Mein Gerät ist eine EZ1-M
                        @wendy2702 Die IP wird so in der Fritzbox angeziegt
                          @michihorn
                          in easy power sieht das so aus:
                          APsystems EZ1 Local API - Documentation.pdf
                            Homoran Global Moderator Administrators @liv-in-sky last edited by
                            @liv-in-sky sagte in Neues BK von Solakon:
                            @michihorn
                            Weißer Adler auf weißem Hintergrund?
                              @michihorn sagte in Neues BK von Solakon:
                              das ist ein android thema - ist bluetooth ein ?
                              die app von solakon kenn ich nicht - evtl nutzt die schon bluetooth - solokon ist eigentlich ein verkäufer - verstehe nicht, dass die eine eigene app haben - aber eine verbindung von iobroker mit dem ez1-m müßte nur über "lokal" funktionieren
                              nutze ich mit akku für null-einspeisung - funktioniert sehr stabil
                                michihorn @liv-in-sky last edited by michihorn
                                Ja klar, hab auch mal neu Scannen lassen...wird aber nicht gefunden
                                  @michihorn
                                  kannst du den ez1-m nochmal resetten und neu in der apsystem app anmelden ?
                                    @michihorn der bluetooth mode wird auch nicht aktiv sein, da du schon in der solakon app registriert bist. die solakon app kann nicht auf lokal umschalten - kannst du den wechstlrichter aus der solakon app löschen ? evtl musst du mit solakon selbst telefonieren und die fragen, wie man das genau macht - ich vermute, der WR ist über wlan mit der sola. app verbunden - soweit ich weiß, kann man den wechselrichter nicht resetten, so dass er wieder in bluetooth mode geht
                                      @liv-in-sky Ich habe gerade ein anderes Handy probiert, der Wechselrichter wurde gefunden. Die APP wurde mit dem Wechselrichter verbunden: Wie kann ich jetzt auf Local umschalten? Ich habe die APP Version 1.4.7
                                        @michihorn
                                        habe oben bei den bildern ein pdf drin
                                          Das sieht bei mir anders aus:
                                            @michihorn
                                            bringt dir das was ?
                                            https://www.frickelpiet.de/apsystems_ez1
                                            1.2k
                                            81.1k
                                            2257
