    4. Test Adapter Philips-TV v0.2.x
    • integer63
      integer63 last edited by
      @AlCalzone:
      … aber da müssen wir mal experimentieren... `
      nur zu 😄
      • AlCalzone
        @integer63:
        nur zu 😄 `
        Du darfst!
          dali3 last edited by
          philips-tv.0	2018-01-30 21:09:55.226	debug	Could not initialize connection. Reason: No supported device/API version found at "192.168.0.87"
          philips-tv.0	2018-01-30 21:09:50.034	debug	testing APIv6
          philips-tv.0	2018-01-30 21:09:49.888	debug	testing APIv5
          philips-tv.0	2018-01-30 21:09:49.695	debug	testing APIv1
          philips-tv.0	2018-01-30 21:09:49.695	debug	detecting API version
          philips-tv.0	2018-01-30 21:09:49.693	debug	connection is ALIVE
          philips-tv.0	2018-01-30 21:09:49.616	debug	checking if connection is alive
          philips-tv.0	2018-01-30 21:09:49.614	debug	initializing connection to 192.168.0.87
          Philips PUS8700
          • AlCalzone
            @dali3:
            Philips PUS8700 `
            Sieht mir nach nem Timeout aus. Bitte neueste Version probieren, da gibts mehr Logs. Kannst du zum Vergleich auch mal die Links durchprobieren?
            http://192.168.0.87:1925/1/audio/volume
            http://192.168.0.87:1925/5/audio/volume
            https://192.168.0.87:1926/6/audio/volume
            • integer63
              Wow, ging sehr schnell auf grün:
              philips-tv.0	2018-01-30 21:16:50.936	debug	connection is ALIVE
              philips-tv.0	2018-01-30 21:16:50.846	debug	checking if connection is alive
              philips-tv.0	2018-01-30 21:16:40.753	debug	connection is ALIVE
              philips-tv.0	2018-01-30 21:16:40.712	debug	checking if connection is alive
              philips-tv.0	2018-01-30 21:16:30.654	debug	connection is ALIVE
              philips-tv.0	2018-01-30 21:16:30.577	debug	checking if connection is alive
              philips-tv.0	2018-01-30 21:16:20.516	debug	connection is ALIVE
              philips-tv.0	2018-01-30 21:16:20.418	debug	checking if connection is alive
              philips-tv.0	2018-01-30 21:16:10.373	debug	state with id philips-tv.0.info.connection updated: ack=true; val=true
              philips-tv.0	2018-01-30 21:16:10.372	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":true,"ack":true,"ts":1517343370356,"q":0,"from":"system.adapter.philips-tv.0","lc":1517343370356}
              philips-tv.0	2018-01-30 21:16:10.358	info	The TV at 192.168.11.118 is now reachable.
              philips-tv.0	2018-01-30 21:16:10.350	debug	TV has APIv5
              philips-tv.0	2018-01-30 21:16:10.294	debug	testing APIv5
              philips-tv.0	2018-01-30 21:16:10.157	debug	testing APIv1
              philips-tv.0	2018-01-30 21:16:10.156	debug	detecting API version
              philips-tv.0	2018-01-30 21:16:10.155	debug	connection is ALIVE
              philips-tv.0	2018-01-30 21:16:10.129	debug	state with id philips-tv.0.info.connection updated: ack=true; val=false
              philips-tv.0	2018-01-30 21:16:10.122	debug	redis pmessage io.philips-tv.0.* io.philips-tv.0.info.connection {"val":false,"ack":true,"ts":1517343370104,"q":0,"from":"system.adapter.philips-tv.0","lc":1517340176850}
              philips-tv.0	2018-01-30 21:16:10.078	debug	checking if connection is alive
              philips-tv.0	2018-01-30 21:16:10.068	debug	initializing connection to 192.168.11.118
              philips-tv.0	2018-01-30 21:16:09.992	info	starting. Version 0.3.0-alpha4 in /opt/iobroker/node_modules/iobroker.philips-tv, node: v6.11.4
              philips-tv.0	2018-01-30 21:16:09.935	info	States connected to redis: 192.168.11.33:6379
              philips-tv.0	2018-01-30 21:16:09.923	debug	statesDB connected
              philips-tv.0	2018-01-30 21:16:09.870	debug	objectDB connected
              • AlCalzone
                @integer63:
                Wow, ging sehr schnell auf grün: `
                Prima, das ist ein Haken mehr auf der Liste. Bitte mal beobachten ob das so bleibt.
                  http://192.168.0.87:1925/6/system
                  Not Found
                  The server has not found anything matching the request URI
                  You can get technical details here.
                  Please continue your visit at our home page.
                  http://192.168.0.87:1925/system
                  {"menulanguage":"German","name":"65PUS8700\/12","country":"Switzerland","serialnumber_encrypted":"cXxPJYO2Jd7cDIA2EVdcnlAJ7u3hHME1wGMcClXPKAw=\n","softwareversion_encrypted":"XYlnb20zZkKE3LL\/Vj3vwh+viBBi72vdK9ead64bFVE=\n","model_encrypted":"MaZqqUUf53LzdAflDuBMRtZDVgoCF0795oOzz3aR8EI=\n","deviceid_encrypted":"I1iDm1ydAOVzZ+Q8tqPbkZPy\/t9pDSwRgVKcKN2EHvk=\n","nettvversion":"5.2.0","epgsource":"ip","api_version":{"Major":5,"Minor":2,"Patch":0},"featuring":{"jsonfeatures":{"ambilight":["LoungeLight","Ambilight"],"textentry":["context_based","initial_string_available"],"inputkey":["key"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"activities":["intent"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","dms_tad"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true"}}}
                  http://192.168.0.87:1925/5/system
                  {"menulanguage":"German","name":"65PUS8700\/12","country":"Switzerland","serialnumber_encrypted":"r6JNErTrk01mgMdYKDrcZhO2h8wxGWbU3\/oCU1YabU4=\n","softwareversion_encrypted":"64nDPvAaqHDiAVZbDPMDvBovcPmyT\/USuWhpBxNi1vE=\n","model_encrypted":"gHBfHO0\/ZcUFiP\/AhZXqohTJArRKu74yN9NoyUSqlEk=\n","deviceid_encrypted":"q6Tjl9HOpRMEqHn37o9fmjiqWOfzhcbVBqw6E4R8Bz0=\n","nettvversion":"5.2.0","epgsource":"ip","api_version":{"Major":5,"Minor":2,"Patch":0},"featuring":{"jsonfeatures":{"ambilight":["LoungeLight","Ambilight"],"textentry":["context_based","initial_string_available"],"inputkey":["key"],"applications":["TV_Apps","TV_Games","TV_Settings"],"pointer":["not_available"],"activities":["intent"]},"systemfeatures":{"tvtype":"consumer","content":["dmr","dms_tad"],"tvsearch":"intent","pairing_type":"digest_auth_pairing","secured_transport":"true"}}}
                  Not Found
                  Habe aktuell die alpha4? (https://github.com/AlCalzone/ioBroker.p … /api-v5+v6 ?)
                  • N
                    NemoN last edited by
                    philips-tv.0	2018-01-30 21:37:45.671	warn	The TV at 192.168.5.109 needs to be paired before you can use the adapter. Go to the adapter config to continue!
                    philips-tv.0	2018-01-30 21:37:45.670	debug	TV has APIv6
                    philips-tv.0	2018-01-30 21:37:45.493	debug	testing APIv6
                    philips-tv.0	2018-01-30 21:37:45.392	debug	API test for v5 failed. Reason: [undefined] 404 - "\n\n \n\n\n
                    philips-tv.0	2018-01-30 21:37:45.365	debug	testing APIv5
                    philips-tv.0	2018-01-30 21:37:45.262	debug	API test for v1 failed. Reason: [undefined] 404 - "\n\n \n\n\n
                    philips-tv.0	2018-01-30 21:37:45.245	debug	testing APIv1
                    philips-tv.0	2018-01-30 21:37:45.245	debug	detecting API version
                    philips-tv.0	2018-01-30 21:37:45.245	debug	connection is ALIVE
                    philips-tv.0	2018-01-30 21:37:45.224	debug	checking if connection is alive
                    philips-tv.0	2018-01-30 21:37:45.222	debug	initializing connection to 192.168.5.109
                    er erkennt das noch nicht gepairt wurde. super 🙂
                    • AlCalzone
                      @dali3:
                      Habe aktuell die alpha4? (https://github.com/AlCalzone/ioBroker.p … /api-v5+v6 ?) `
                      Ja das passt, habe die Version bei den letzten Änderungen nicht mehr angepasst. Bist du etwa einer der Leute mit der 4. (anderen) API?
                      Kommt da was?
                      http://192.168.0.87:49154/nmrRenderingControl.xml
                        @AlCalzone:
                        @dali3:
                        Kommt da was?
                        http://192.168.0.87:49154/nmrRenderingControl.xml `
                        JA!
                        This XML file does not appear to have any style information associated with it. The document tree is shown below.
                        <scpd xmlns="urn:schemas-upnp-org:service-1-0"><specversion><major>1</major>
                        <minor>0</minor></specversion>
                        <servicestatetable><statevariable sendevents="no"><name>PresetNameList</name>
                        <datatype>string</datatype></statevariable>
                        <statevariable sendevents="yes"><name>LastChange</name>
                        <statevariable sendevents="no"><name>A_ARG_TYPE_Channel</name>
                        <allowedvaluelist><allowedvalue>Master</allowedvalue></allowedvaluelist></statevariable>
                        <statevariable sendevents="no"><name>A_ARG_TYPE_InstanceID</name>
                        <datatype>ui4</datatype></statevariable>
                        <statevariable sendevents="no"><name>A_ARG_TYPE_PresetName</name>
                        <allowedvaluelist><allowedvalue>FactoryDefaults</allowedvalue></allowedvaluelist></statevariable>
                        <statevariable sendevents="no"><name>Volume</name>
                        <datatype>ui2</datatype>
                        <allowedvaluerange><minimum>0</minimum>
                        <maximum>100</maximum>
                        <step>1</step></allowedvaluerange></statevariable>
                        <statevariable sendevents="no"><name>Mute</name>
                        <datatype>boolean</datatype></statevariable></servicestatetable>
                        <actionlist><action><name>ListPresets</name>
                        <argumentlist><argument><name>InstanceID</name>
                        <direction>in</direction>
                        <relatedstatevariable>A_ARG_TYPE_InstanceID</relatedstatevariable></argument>
                        <argument><name>CurrentPresetNameList</name>
                        <direction>out</direction>
                        <relatedstatevariable>PresetNameList</relatedstatevariable></argument></argumentlist></action>
                        <action><name>SelectPreset</name>
                        <argument><name>PresetName</name>
                        <relatedstatevariable>A_ARG_TYPE_PresetName</relatedstatevariable></argument></argumentlist></action>
                        <action><name>GetVolume</name>
                        <argument><name>Channel</name>
                        <relatedstatevariable>A_ARG_TYPE_Channel</relatedstatevariable></argument>
                        <argument><name>CurrentVolume</name>
                        <relatedstatevariable>Volume</relatedstatevariable></argument></argumentlist></action>
                        <action><name>SetVolume</name>
                        <argument><name>DesiredVolume</name>
                        <action><name>SetMute</name>
                        <argument><name>DesiredMute</name>
                        <relatedstatevariable>Mute</relatedstatevariable></argument></argumentlist></action>
                        <action><name>GetMute</name>
                        <argument><name>CurrentMute</name>
                        <relatedstatevariable>Mute</relatedstatevariable></argument></argumentlist></action></actionlist></scpd>
                        • AlCalzone
                          @dali3:
                          JA! `
                          Hm das geht bei mir aber auch und ich hab API v1. Mich wundert, dass beim Rest nix kommt. Kannst ja nochmal ein paar der Links in diesem Thread probieren - wenn da außer /system nix geht, musst du dich wohl noch etwas gedulden.
                          Aber jetzt ist erst mal Feierabend 🙂
                            @AlCalzone:
                            @dali3:
                            JA! `
                            Aber jetzt ist erst mal Feierabend 🙂 `
                            AlCalzone, hatte gestern auch Feierabend 🙂
                            Habe die Links jetzt zusammentragen und werde diese heute Abend zu Hause testen!
                            Liste IP:
                            • X= getestet
                            X [https://IPvomTV:1926/6/audio/volume](https://IPvomTV:1926/6/audio/volume)
                            X [http://IPvomTV:1925/5/audio/volume](http://IPvomTV:1925/5/audio/volume)
                            X [http://IPvomTV:1925/1/audio/volume](http://IPvomTV:1925/1/audio/volume)
                            X [http://IPvomTV:1925/system](http://IPvomTV:1925/system)
                            X [http://IPvomTV:1925/5/system](http://IPvomTV:1925/5/system)
                            X [http://IPvomTV:1925/6/system](http://IPvomTV:1925/6/system)
                            X [http://IPvomTV:49154/nmrRenderingControl.xml](http://IPvomTV:49154/nmrRenderingControl.xml)
                            [http://IPvomTV:49153/nmrRenderingControl.xml](http://IPvomTV:49153/nmrRenderingControl.xml)
                            [https://IPvomTV:1926/input/Key](https://IPvomTV:1926/input/Key)
                            [http://IPvomTV:49154/nmsDescription.xml](http://IPvomTV:49154/nmsDescription.xml)
                            [http://IPvomTV:49154/nmrAVTransport.xml](http://IPvomTV:49154/nmrAVTransport.xml)
                            [http://IPvomTV:49154/nmsContentDirectorySCPD.xml](http://IPvomTV:49154/nmsContentDirectorySCPD.xml)
                            [http://IPvomTV:49154/nmrConnectionManager.xml](http://IPvomTV:49154/nmrConnectionManager.xml)
                            Falls ich eine übersehen habe, bitte kurz mitteilen 🙂
                            Danke für deinen Einsatz!!!
                              dali3 last edited by Negalein
                              so wie versprochen noch die offenen Punkte:
                               <statevariable sendevents="no"><name>AllowedTransformSettings</name>
                               <statevariable sendevents="no"><name>TransformSettings</name>
                               <action><name>GetAllowedTransforms</name>
                               <argument><name>CurrentAllowedTransformSettings</name>
                              <relatedstatevariable>AllowedTransformSettings</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetTransforms</name>
                               <argument><name>CurrentTransformValues</name>
                              <relatedstatevariable>TransformSettings</relatedstatevariable></argument></argumentlist></action>
                               <action><name>SetTransforms</name>
                               <argument><name>DesiredTransformValues</name>
                               <action><name>GetAllAvailableTransforms</name>
                               <argumentlist><argument><name>AllAllowedTransformSettings</name>
                              <relatedstatevariable>AllowedTransformSettings</relatedstatevariable></argument></argumentlist></action></actionlist></scpd>
                              Not Found
                              >! The server has not found anything matching the request URI
                              >! You can get technical details here.
                               <root xmlns="urn:schemas-upnp-org:device-1-0"><specversion><major>1</major>
                               <device><devicetype>urn:schemas-upnp-org:device:MediaServer:3</devicetype>
                              <friendlyname>65PUS8700/12</friendlyname>
                              <manufacturer>Royal Philips Electronics</manufacturer>
                              <manufacturerurl>http://www.philips.com</manufacturerurl>
                              <modeldescription>Philips TV Server</modeldescription>
                              <modelname>Philips TV Server</modelname>
                              <modelnumber>2k15Marvel</modelnumber>
                              <modelurl>http://www.philips.com/</modelurl>
                              <serialnumber>123456789-serial</serialnumber>
                              <udn>uuid:5AFEF00D-BABE-DADA-FA5A-b886870336ed</udn>
                              <upc>123456789123</upc>
                               <iconlist><icon><mimetype>image/png</mimetype>
                              <height>48</height>
                              <width>48</width>
                              <depth>24</depth>
                              <url>CP_logo_0.png</url></icon>
                              <height>120</height>
                              <width>120</width>
                              <depth>24</depth>
                              <url>CP_logo_1.png</url></icon>
                               <icon><mimetype>image/jpeg</mimetype>
                              <height>48</height>
                              <width>48</width>
                              <depth>24</depth>
                              <url>CP_logo_2.jpg</url></icon>
                              <width>120</width>
                              <depth>24</depth>
                              <url>CP_logo_3.jpg</url></icon></iconlist>
                               <servicelist><service><servicetype>urn:schemas-upnp-org:service:ContentDirectory:3</servicetype>
                              <serviceid>urn:upnp-org:serviceId:ContentDirectory</serviceid>
                              <controlurl>upnp/control/ContentDirectoryNmsO</controlurl>
                              <eventsuburl>upnp/event/ContentDirectoryNmsO</eventsuburl>
                              <scpdurl>nmsContentDirectorySCPD.xml</scpdurl></service>
                               <service><servicetype>urn:schemas-upnp-org:service:ConnectionManager:2</servicetype>
                              <serviceid>urn:upnp-org:serviceId:ConnectionManager</serviceid>
                              <controlurl>upnp/control/ConnectionManagerNmsO</controlurl>
                              <eventsuburl>upnp/event/ConnectionManagerNmsO</eventsuburl>
                              <scpdurl>nmsConnectionManagerSCPD.xml</scpdurl></service></servicelist></device></root>
                               <actionlist><action><name>Play</name>
                               <argument><name>Speed</name>
                              <relatedstatevariable>TransportPlaySpeed</relatedstatevariable></argument></argumentlist></action>
                               <action><name>Stop</name>
                              <relatedstatevariable>A_ARG_TYPE_InstanceID</relatedstatevariable></argument></argumentlist></action>
                               <action><name>Next</name>
                               <action><name>Previous</name>
                               <action><name>GetMediaInfo</name>
                               <argument><name>NrTracks</name>
                              <relatedstatevariable>NumberOfTracks</relatedstatevariable></argument>
                               <argument><name>MediaDuration</name>
                              <relatedstatevariable>CurrentMediaDuration</relatedstatevariable></argument>
                               <argument><name>CurrentURI</name>
                              <relatedstatevariable>AVTransportURI</relatedstatevariable></argument>
                               <argument><name>CurrentURIMetaData</name>
                              <relatedstatevariable>AVTransportURIMetaData</relatedstatevariable></argument>
                               <argument><name>NextURI</name>
                              <relatedstatevariable>NextAVTransportURI</relatedstatevariable></argument>
                               <argument><name>NextURIMetaData</name>
                              <relatedstatevariable>NextAVTransportURIMetaData</relatedstatevariable></argument>
                               <argument><name>PlayMedium</name>
                              <relatedstatevariable>PlaybackStorageMedium</relatedstatevariable></argument>
                               <argument><name>RecordMedium</name>
                              <relatedstatevariable>RecordStorageMedium</relatedstatevariable></argument>
                               <argument><name>WriteStatus</name>
                              <relatedstatevariable>RecordMediumWriteStatus</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetDeviceCapabilities</name>
                               <argument><name>PlayMedia</name>
                              <relatedstatevariable>PossiblePlaybackStorageMedia</relatedstatevariable></argument>
                               <argument><name>RecMedia</name>
                              <relatedstatevariable>PossibleRecordStorageMedia</relatedstatevariable></argument>
                               <argument><name>RecQualityModes</name>
                              <relatedstatevariable>PossibleRecordQualityModes</relatedstatevariable></argument></argumentlist></action>
                               <action><name>SetAVTransportURI</name>
                              <relatedstatevariable>AVTransportURIMetaData</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetCurrentTransportActions</name>
                               <argument><name>Actions</name>
                              <relatedstatevariable>CurrentTransportActions</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetTransportSettings</name>
                               <argument><name>PlayMode</name>
                              <relatedstatevariable>CurrentPlayMode</relatedstatevariable></argument>
                               <argument><name>RecQualityMode</name>
                              <relatedstatevariable>CurrentRecordQualityMode</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetTransportInfo</name>
                               <argument><name>CurrentTransportState</name>
                              <relatedstatevariable>TransportState</relatedstatevariable></argument>
                               <argument><name>CurrentTransportStatus</name>
                              <relatedstatevariable>TransportStatus</relatedstatevariable></argument>
                               <argument><name>CurrentSpeed</name>
                               <action><name>Pause</name>
                               <action><name>Seek</name>
                               <argument><name>Unit</name>
                              <relatedstatevariable>A_ARG_TYPE_SeekMode</relatedstatevariable></argument>
                               <argument><name>Target</name>
                              <relatedstatevariable>A_ARG_TYPE_SeekTarget</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetPositionInfo</name>
                               <argument><name>Track</name>
                              <relatedstatevariable>CurrentTrack</relatedstatevariable></argument>
                               <argument><name>TrackDuration</name>
                              <relatedstatevariable>CurrentTrackDuration</relatedstatevariable></argument>
                               <argument><name>TrackMetaData</name>
                              <relatedstatevariable>CurrentTrackMetaData</relatedstatevariable></argument>
                               <argument><name>TrackURI</name>
                              <relatedstatevariable>CurrentTrackURI</relatedstatevariable></argument>
                               <argument><name>RelTime</name>
                              <relatedstatevariable>RelativeTimePosition</relatedstatevariable></argument>
                               <argument><name>AbsTime</name>
                              <relatedstatevariable>AbsoluteTimePosition</relatedstatevariable></argument>
                               <argument><name>RelCount</name>
                              <relatedstatevariable>RelativeCounterPosition</relatedstatevariable></argument>
                               <argument><name>AbsCount</name>
                              <relatedstatevariable>AbsoluteCounterPosition</relatedstatevariable></argument></argumentlist></action></actionlist>
                               <servicestatetable><statevariable sendevents="no"><name>CurrentPlayMode</name>
                              <defaultvalue>NORMAL</defaultvalue>
                               <allowedvaluelist><allowedvalue>NORMAL</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>RecordStorageMedium</name>
                               <allowedvaluelist><allowedvalue>UNKNOWN</allowedvalue>
                              <allowedvalue>DV</allowedvalue>
                              <allowedvalue>MINI-DV</allowedvalue>
                              <allowedvalue>VHS</allowedvalue>
                              <allowedvalue>W-VHS</allowedvalue>
                              <allowedvalue>S-VHS</allowedvalue>
                              <allowedvalue>D-VHS</allowedvalue>
                              <allowedvalue>VHSC</allowedvalue>
                              <allowedvalue>VIDEO8</allowedvalue>
                              <allowedvalue>HI8</allowedvalue>
                              <allowedvalue>CD-ROM</allowedvalue>
                              <allowedvalue>CD-DA</allowedvalue>
                              <allowedvalue>CD-R</allowedvalue>
                              <allowedvalue>CD-RW</allowedvalue>
                              <allowedvalue>VIDEO-CD</allowedvalue>
                              <allowedvalue>SACD</allowedvalue>
                              <allowedvalue>MD-AUDIO</allowedvalue>
                              <allowedvalue>MD-PICTURE</allowedvalue>
                              <allowedvalue>DVD-ROM</allowedvalue>
                              <allowedvalue>DVD-VIDEO</allowedvalue>
                              <allowedvalue>DVD-R</allowedvalue>
                              <allowedvalue>DVD+RW</allowedvalue>
                              <allowedvalue>DVD-RW</allowedvalue>
                              <allowedvalue>DVD-RAM</allowedvalue>
                              <allowedvalue>DVD-AUDIO</allowedvalue>
                              <allowedvalue>DAT</allowedvalue>
                              <allowedvalue>LD</allowedvalue>
                              <allowedvalue>HDD</allowedvalue>
                              <allowedvalue>MICRO-MV</allowedvalue>
                              <allowedvalue>NETWORK</allowedvalue>
                              <allowedvalue>NONE</allowedvalue>
                              <allowedvalue>NOT_IMPLEMENTED</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>RelativeTimePosition</name>
                               <statevariable sendevents="no"><name>CurrentTrackURI</name>
                               <statevariable sendevents="no"><name>CurrentTrackDuration</name>
                               <statevariable sendevents="no"><name>CurrentRecordQualityMode</name>
                               <allowedvaluelist><allowedvalue>0:EP</allowedvalue>
                              <allowedvalue>1:LP</allowedvalue>
                              <allowedvalue>2:SP</allowedvalue>
                              <allowedvalue>0:BASIC</allowedvalue>
                              <allowedvalue>1:MEDIUM</allowedvalue>
                              <allowedvalue>2:HIGH</allowedvalue>
                               <statevariable sendevents="no"><name>CurrentMediaDuration</name>
                               <statevariable sendevents="no"><name>AbsoluteCounterPosition</name>
                              <datatype>i4</datatype></statevariable>
                               <statevariable sendevents="no"><name>RelativeCounterPosition</name>
                               <statevariable sendevents="no"><name>AVTransportURI</name>
                               <statevariable sendevents="no"><name>TransportState</name>
                               <allowedvaluelist><allowedvalue>STOPPED</allowedvalue>
                              <allowedvalue>PAUSED_PLAYBACK</allowedvalue>
                              <allowedvalue>PAUSED_RECORDING</allowedvalue>
                              <allowedvalue>PLAYING</allowedvalue>
                              <allowedvalue>RECORDING</allowedvalue>
                              <allowedvalue>TRANSITIONING</allowedvalue>
                              <allowedvalue>NO_MEDIA_PRESENT</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>CurrentTrackMetaData</name>
                               <statevariable sendevents="no"><name>NextAVTransportURI</name>
                               <statevariable sendevents="no"><name>PossibleRecordQualityModes</name>
                               <statevariable sendevents="no"><name>CurrentTrack</name>
                              <maximum>4294967295</maximum>
                               <statevariable sendevents="no"><name>AbsoluteTimePosition</name>
                               <statevariable sendevents="no"><name>NextAVTransportURIMetaData</name>
                               <statevariable sendevents="no"><name>PlaybackStorageMedium</name>
                               <statevariable sendevents="no"><name>RecordMediumWriteStatus</name>
                               <allowedvaluelist><allowedvalue>WRITABLE</allowedvalue>
                              <allowedvalue>PROTECTED</allowedvalue>
                              <allowedvalue>NOT_WRITABLE</allowedvalue>
                               <statevariable sendevents="no"><name>PossiblePlaybackStorageMedia</name>
                               <statevariable sendevents="no"><name>AVTransportURIMetaData</name>
                               <statevariable sendevents="no"><name>NumberOfTracks</name>
                              <maximum>4294967295</maximum></allowedvaluerange></statevariable>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_SeekMode</name>
                               <allowedvaluelist><allowedvalue>ABS_TIME</allowedvalue>
                              <allowedvalue>REL_TIME</allowedvalue>
                              <allowedvalue>TRACK_NR</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_SeekTarget</name>
                               <statevariable sendevents="no"><name>PossibleRecordStorageMedia</name>
                               <statevariable sendevents="no"><name>TransportStatus</name>
                               <allowedvaluelist><allowedvalue>OK</allowedvalue>
                              <allowedvalue>ERROR_OCCURRED</allowedvalue>
                              <allowedvalue>UNKNOWN</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>TransportPlaySpeed</name>
                               <allowedvaluelist><allowedvalue>1</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>CurrentTransportActions</name>
                              <datatype>string</datatype></statevariable></servicestatetable></scpd>
                              http://IPvomTV:49154/nmsContentDirectorySCPD.…
                               <actionlist><action><name>GetSearchCapabilities</name>
                               <argumentlist><argument><name>SearchCaps</name>
                              <relatedstatevariable>SearchCapabilities</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetSortCapabilities</name>
                               <argumentlist><argument><name>SortCaps</name>
                              <relatedstatevariable>SortCapabilities</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetSystemUpdateID</name>
                               <argumentlist><argument><name>Id</name>
                              <relatedstatevariable>SystemUpdateID</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetServiceResetToken</name>
                               <argumentlist><argument><name>ResetToken</name>
                              <relatedstatevariable>ServiceResetToken</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetFeatureList</name>
                               <argumentlist><argument><name>FeatureList</name>
                              <relatedstatevariable>FeatureList</relatedstatevariable></argument></argumentlist></action>
                               <action><name>Browse</name>
                               <argumentlist><argument><name>ObjectID</name>
                              <relatedstatevariable>A_ARG_TYPE_ObjectID</relatedstatevariable></argument>
                               <argument><name>BrowseFlag</name>
                              <relatedstatevariable>A_ARG_TYPE_BrowseFlag</relatedstatevariable></argument>
                               <argument><name>Filter</name>
                              <relatedstatevariable>A_ARG_TYPE_Filter</relatedstatevariable></argument>
                               <argument><name>StartingIndex</name>
                              <relatedstatevariable>A_ARG_TYPE_Index</relatedstatevariable></argument>
                               <argument><name>RequestedCount</name>
                              <relatedstatevariable>A_ARG_TYPE_Count</relatedstatevariable></argument>
                               <argument><name>SortCriteria</name>
                              <relatedstatevariable>A_ARG_TYPE_SortCriteria</relatedstatevariable></argument>
                               <argument><name>Result</name>
                              <relatedstatevariable>A_ARG_TYPE_Result</relatedstatevariable></argument>
                               <argument><name>NumberReturned</name>
                               <argument><name>TotalMatches</name>
                               <argument><name>UpdateID</name>
                              <relatedstatevariable>A_ARG_TYPE_UpdateID</relatedstatevariable></argument></argumentlist></action>
                               <action><name>X_BrowseByLetter</name>
                               <argument><name>StartingLetter</name>
                              <relatedstatevariable>A_ARG_TYPE_BrowseLetter</relatedstatevariable></argument>
                              <relatedstatevariable>A_ARG_TYPE_Index</relatedstatevariable></argument></argumentlist></action>
                               <action><name>X_Philips_PauseStream</name>
                               <argumentlist><argument><name>Result</name>
                              <relatedstatevariable>X_Philips_A_ARG_TYPE_Result</relatedstatevariable></argument></argumentlist></action>
                               <action><name>X_Philips_ResumeStream</name>
                               <action><name>X_Philips_JumpToPosition</name>
                               <argumentlist><argument><name>PositionFlag</name>
                              <relatedstatevariable>X_Philips_A_ARG_TYPE_PositionFlag</relatedstatevariable></argument>
                               <argument><name>Position</name>
                              <relatedstatevariable>X_Philips_A_ARG_Position</relatedstatevariable></argument>
                               <action><name>X_Philips_GetPlaybackPosition</name>
                              <relatedstatevariable>X_Philips_A_ARG_Position</relatedstatevariable></argument></argumentlist></action>
                               <action><name>X_Philips_GetTimeShiftInfo</name>
                               <argumentlist><argument><name>BufferDuration</name>
                              <relatedstatevariable>X_Philips_A_ARG_TYPE_BufferedDuration</relatedstatevariable></argument>
                               <argument><name>CurrentPosition</name>
                               <argument><name>MaxDuration</name>
                              <relatedstatevariable>X_Philips_A_ARG_TYPE_MaxDuration</relatedstatevariable></argument>
                              <relatedstatevariable>X_Philips_A_ARG_TYPE_Result</relatedstatevariable></argument></argumentlist></action></actionlist>
                               <servicestatetable><statevariable sendevents="yes"><name>TransferIDs</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_ObjectID</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_Result</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_BrowseFlag</name>
                               <allowedvaluelist><allowedvalue>BrowseMetadata</allowedvalue>
                              <allowedvalue>BrowseDirectChildren</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_BrowseLetter</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_Filter</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_SortCriteria</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_Index</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_Count</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_UpdateID</name>
                               <statevariable sendevents="no"><name>SearchCapabilities</name>
                               <statevariable sendevents="no"><name>SortCapabilities</name>
                               <statevariable sendevents="yes"><name>SystemUpdateID</name>
                               <statevariable sendevents="no"><name>ServiceResetToken</name>
                               <statevariable sendevents="yes"><name>ContainerUpdateIDs</name>
                               <statevariable sendevents="no"><name>FeatureList</name>
                               <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_Result</name>
                               <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_PositionFlag</name>
                               <statevariable sendevents="no"><name>X_Philips_A_ARG_Position</name>
                               <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_BufferedDuration</name>
                               <statevariable sendevents="no"><name>X_Philips_A_ARG_TYPE_MaxDuration</name>
                               <actionlist><action><name>GetProtocolInfo</name>
                               <argumentlist><argument><name>Source</name>
                              <relatedstatevariable>SourceProtocolInfo</relatedstatevariable></argument>
                               <argument><name>Sink</name>
                              <relatedstatevariable>SinkProtocolInfo</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetCurrentConnectionIDs</name>
                               <argumentlist><argument><name>ConnectionIDs</name>
                              <relatedstatevariable>CurrentConnectionIDs</relatedstatevariable></argument></argumentlist></action>
                               <action><name>GetCurrentConnectionInfo</name>
                               <argumentlist><argument><name>ConnectionID</name>
                              <relatedstatevariable>A_ARG_TYPE_ConnectionID</relatedstatevariable></argument>
                               <argument><name>RcsID</name>
                              <relatedstatevariable>A_ARG_TYPE_RcsID</relatedstatevariable></argument>
                               <argument><name>AVTransportID</name>
                              <relatedstatevariable>A_ARG_TYPE_AVTransportID</relatedstatevariable></argument>
                               <argument><name>ProtocolInfo</name>
                              <relatedstatevariable>A_ARG_TYPE_ProtocolInfo</relatedstatevariable></argument>
                               <argument><name>PeerConnectionManager</name>
                              <relatedstatevariable>A_ARG_TYPE_ConnectionManager</relatedstatevariable></argument>
                               <argument><name>PeerConnectionID</name>
                               <argument><name>Direction</name>
                              <relatedstatevariable>A_ARG_TYPE_Direction</relatedstatevariable></argument>
                               <argument><name>Status</name>
                              <relatedstatevariable>A_ARG_TYPE_ConnectionStatus</relatedstatevariable></argument></argumentlist></action></actionlist>
                               <servicestatetable><statevariable sendevents="yes"><name>SourceProtocolInfo</name>
                               <statevariable sendevents="yes"><name>SinkProtocolInfo</name>
                               <statevariable sendevents="yes"><name>CurrentConnectionIDs</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionStatus</name>
                              <allowedvalue>ContentFormatMismatch</allowedvalue>
                              <allowedvalue>InsufficientBandwidth</allowedvalue>
                              <allowedvalue>UnreliableChannel</allowedvalue>
                              <allowedvalue>Unknown</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionManager</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_Direction</name>
                               <allowedvaluelist><allowedvalue>Input</allowedvalue>
                              <allowedvalue>Output</allowedvalue></allowedvaluelist></statevariable>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_ProtocolInfo</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_ConnectionID</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_AVTransportID</name>
                               <statevariable sendevents="no"><name>A_ARG_TYPE_RcsID</name>
                              <datatype>i4</datatype></statevariable></servicestatetable></scpd>
                              • wendy2702
                                wendy2702 last edited by
                                @dali3:
                                http://IPvomTV:49153/nmrRenderingControl.xml `
                                Kannst du die vielleicht noch in "SPOILER" verpacken!?
                                Erleichtert das scrollen 😉
                                  @wendy2702:
                                  @dali3:
                                  Erleichtert das scrollen 😉 `
                                  So eingepackt, danke für den Input 🙂
                                  • AlCalzone
                                    Danke für die Logs, das scheint aktuell keine unterstützte API zu sein. Falls du Lust hast, kannst du dich mal in Google austoben. Für sachdienliche Hinweise zur Einbindung bin ich dankbar 😄
                                      Ist diese Seite schob bekannt?
                                      http://jointspace.sourceforge.net/proje … c/API.html
                                      Bzw.
                                      https://github.com/stevenle/googletv-anymote ?
                                      • AlCalzone
                                        @dali3:
                                        Bzw.
                                        https://github.com/stevenle/googletv-anymote ? `
                                        1. ja, darauf bauen die aktuellen API-Implementationen
                                        2. nein, funktiniert das mit deinem TV? Bzw kannst du herausfinden, ob der auf dieses "anymote" Protokoll setzt?
                                          @AlCalzone:
                                          @dali3:
                                          Bzw.
                                          2. nein, funktiniert das mit deinem TV? Bzw kannst du herausfinden, ob der auf dieses "anymote" Protokoll setzt? `
                                          Ich werde es dieses Weekend probieren, leider sind meine Programmierkenntnisse sehr begrenzt 🙂
                                            Mater1984 last edited by
                                            Ich habe ebenfalls einen TV mit API v6
                                            Das Pairing manuell funktioniert. Dort habe ich jetzt Username und Passwort ausgelesen
                                            Kann man das schon manuell in der Settings Datei eintragen?
                                            Was muss denn noch am Admin Modul geändert werden?
                                            Viele Grüße
                                            1.0k
                                            philips philips tv
                                            84
                                            550
                                            131218
