    4. Beta ioBroker.plenticore-g3
      mule @FernetMenta last edited by mule
      @fernetmenta
      Das Update startete um 0:45Uhr
      2025-03-28 00:46:06.004  - warn: plenticore-g3.0 (293579) get settings failed with code 503: [object Object]
      2025-03-28 00:46:59.494  - warn: plenticore-g3.0 (293579) API request failed with error {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.180","port":80}
      2025-03-28 00:46:59.495  - warn: plenticore-g3.0 (293579) Error: API request failed with error {"errno":-113,"code":"EHOSTUNREACH","syscall":"connect","address":"192.168.178.180","port":80}
      2025-03-28 00:47:14.746  - error: plenticore-g3.0 (293579) uncaught exception: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:47:14.747  - error: plenticore-g3.0 (293579) SyntaxError: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
          at JSON.parse (<anonymous>)
          at IncomingMessage.<anonymous> (/opt/iobroker/node_modules/iobroker.plenticore-g3/lib/plenticoreAPI.js:102:42)
          at IncomingMessage.emit (node:events:536:35)
          at endReadableNT (node:internal/streams/readable:1698:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
      2025-03-28 00:47:14.748  - error: plenticore-g3.0 (293579) Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:47:14.751  - info: plenticore-g3.0 (293579) terminating
      2025-03-28 00:47:14.752  - warn: plenticore-g3.0 (293579) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-03-28 00:47:15.255  - info: plenticore-g3.0 (293579) terminating
      2025-03-28 00:47:15.329  - error: host.iobroker instance system.adapter.plenticore-g3.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-03-28 00:47:15.329  - info: host.iobroker Restart adapter system.adapter.plenticore-g3.0 because enabled
      2025-03-28 00:47:46.060  - info: host.iobroker instance system.adapter.plenticore-g3.0 in version "0.0.7" (non-npm: FernetMenta/ioBroker.plenticore-g3#v0.0.7) started with pid 308438
      2025-03-28 00:47:47.643  - info: plenticore-g3.0 (308438) starting. Version 0.0.7 (non-npm: FernetMenta/ioBroker.plenticore-g3#v0.0.7) in /opt/iobroker/node_modules/iobroker.plenticore-g3, node: v20.19.0, js-controller: 7.0.6
      2025-03-28 00:47:47.714  - error: plenticore-g3.0 (308438) uncaught exception: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:47:47.715  - error: plenticore-g3.0 (308438) SyntaxError: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:47:47.716  - error: plenticore-g3.0 (308438) Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:47:47.724  - info: plenticore-g3.0 (308438) terminating
      2025-03-28 00:47:47.726  - warn: plenticore-g3.0 (308438) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-03-28 00:47:48.229  - info: plenticore-g3.0 (308438) terminating
      2025-03-28 00:47:48.317  - error: host.iobroker instance system.adapter.plenticore-g3.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-03-28 00:47:48.318  - info: host.iobroker Restart adapter system.adapter.plenticore-g3.0 because enabled
      2025-03-28 00:48:19.068  - info: host.iobroker instance system.adapter.plenticore-g3.0 in version "0.0.7" (non-npm: FernetMenta/ioBroker.plenticore-g3#v0.0.7) started with pid 308469
      2025-03-28 00:48:20.650  - info: plenticore-g3.0 (308469) starting. Version 0.0.7 (non-npm: FernetMenta/ioBroker.plenticore-g3#v0.0.7) in /opt/iobroker/node_modules/iobroker.plenticore-g3, node: v20.19.0, js-controller: 7.0.6
      2025-03-28 00:48:20.720  - error: plenticore-g3.0 (308469) uncaught exception: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:48:20.721  - error: plenticore-g3.0 (308469) SyntaxError: Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:48:20.722  - error: plenticore-g3.0 (308469) Unexpected token '<', "<!DOCTYPE "... is not valid JSON
      2025-03-28 00:48:20.732  - info: plenticore-g3.0 (308469) terminating
      2025-03-28 00:48:20.733  - warn: plenticore-g3.0 (308469) Terminated (UNCAUGHT_EXCEPTION): Without reason
      2025-03-28 00:48:21.235  - info: plenticore-g3.0 (308469) terminating
      2025-03-28 00:48:21.310  - error: host.iobroker instance system.adapter.plenticore-g3.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
      2025-03-28 00:48:21.311  - info: host.iobroker Restart adapter system.adapter.plenticore-g3.0 because enabled
      2025-03-28 00:48:21.311  - warn: host.iobroker Do not restart adapter system.adapter.plenticore-g3.0 because restart loop detected
      FernetMenta 1 Reply Last reply Reply Quote 0
      • FernetMenta
        FernetMenta @mule last edited by
        @mule sagte in Beta ioBroker.plenticore-g3:
        00:47:14.74
        Danke! Ich sehe den Fehler. Werde eine neue Version erstellen und das Update dann heute Abend bei mir testen.
        • FernetMenta
          FernetMenta @FernetMenta last edited by
          Neue Version 0.1.0 ist draußen. Für Updates habe ich eine admin Notification eingebaut, wenn es ein neues gibt und man nicht automatisch installieren gewählt hat.
            @fernetmenta Danke!
            • FernetMenta
              Der Adapter ist jetzt über das beta repo installierbar.
              V 1 Reply Last reply Reply Quote 2
              • V
                vmi @FernetMenta last edited by
                @fernetmenta danke für den Adapter.
                Habe den Plenticore G3 L und bekomme leider folgende Fehlermeldung:
                2025-06-10 21:16:10.779	warn	Error: API request failed with error {"errno":-71,"code":"EPROTO","syscall":"write"}
                2025-06-10 21:16:10.777	warn	API request failed with error {"errno":-71,"code":"EPROTO","syscall":"write"}
                hier noch der debug:
                2025-06-10 21:26:11.110	debug	API connection closed
                plenticore-g3.0
                	2025-06-10 21:26:11.109	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                plenticore-g3.0
                	2025-06-10 21:26:10.578	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session fb772bd52e4683f947ad27f8fc4b55d4a51811cdf85fdd95f3eb2a8e92c9a873"},"rejectUnauthorized":false}
                plenticore-g3.0
                	2025-06-10 21:25:55.406	debug	API connection closed
                plenticore-g3.0
                	2025-06-10 21:25:55.406	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                plenticore-g3.0
                	2025-06-10 21:25:55.090	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session fb772bd52e4683f947ad27f8fc4b55d4a51811cdf85fdd95f3eb2a8e92c9a873"},"rejectUnauthorized":false}
                plenticore-g3.0
                	2025-06-10 21:25:39.912	debug	API connection closed
                • FernetMenta
                  FernetMenta @vmi last edited by FernetMenta
                  @vmi Ich bräuchte ein komplettes debug log, in dem der Fehler auftritt. Sonst kann man nicht feststellen, was diesen ausgelöst hat.
                  EDIT: Hattest du HTTPS auf Port 80 aktiviert?
                  • V
                    vmi @FernetMenta last edited by vmi
                    @fernetmenta
                    Nutze Port 80 ohne https
                    plenticore-g3.0
                    	2025-06-11 21:30:05.199	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:30:05.197	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:30:04.695	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:29:49.493	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:29:49.492	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:29:48.882	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:29:33.682	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:29:33.681	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:29:33.272	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:29:18.059	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:29:18.058	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:29:17.531	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:29:02.356	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:29:02.355	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:29:01.653	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:28:46.477	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:28:46.477	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:28:45.943	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:28:30.763	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:28:30.762	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                    plenticore-g3.0
                    	2025-06-11 21:28:30.285	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:28:30.105	info	logged in to plenticore
                    plenticore-g3.0
                    	2025-06-11 21:28:30.103	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:28:30.102	debug	Result of API request: code: 200, headers: [object Object], body: {"sessionId":"cb57eda45fc5a0086e113a33bd47fd67037420216a20c5b819088d47ea75ac31"}
                    plenticore-g3.0
                    	2025-06-11 21:28:30.052	debug	Sending post/put data to request: {"transactionId":"b03fd47d83abab210e40e222cdd96ab949d8829f71d9792a1219a056bd8fd9b4","iv":"d5kUM0Nz3Kl8R2D7CYBWyg==","tag":"7WKHWDp4j/DcQPPGA38uXw==","payload":"z7J01cHZedO1LVPE8ZbOgz2qjN+fqgdaSxyDg6ZFAWB43x4HBPcsxbdCe3xFN7Rjr13+OCLRsvMBq7+C+6kLnw=="}
                    plenticore-g3.0
                    	2025-06-11 21:28:30.050	debug	Making request to endpoint auth/create_session with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/auth/create_session","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:28:30.042	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:28:30.041	debug	Result of API request: code: 200, headers: [object Object], body: {"signature":"qY6swLaQwssJ8roYfKiIJXYqKeOaLO49RNNV9trfwEQ=","token":"982592a9dba5d525415d65b37bdf083f7403e5efe8cd1027c71a70c6b8812b8d"}
                    plenticore-g3.0
                    	2025-06-11 21:28:29.998	debug	Sending post/put data to request: {"transactionId":"b03fd47d83abab210e40e222cdd96ab949d8829f71d9792a1219a056bd8fd9b4","proof":"GFmMG2Y5275z7qDDih6w9Sc86znX3JH5v5za8pE4t+s="}
                    plenticore-g3.0
                    	2025-06-11 21:28:29.998	debug	Making request to endpoint auth/finish with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/auth/finish","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:28:29.575	debug	API connection closed
                    plenticore-g3.0
                    	2025-06-11 21:28:29.572	debug	Result of API request: code: 200, headers: [object Object], body: {"transactionId":"b03fd47d83abab210e40e222cdd96ab949d8829f71d9792a1219a056bd8fd9b4","nonce":"hD35Gofz0jF62hijp8QrXfpy4ukwADXJ","salt":"tBI8GkZ9+z4koNgs","rounds":29000}
                    plenticore-g3.0
                    	2025-06-11 21:28:29.425	debug	Sending post/put data to request: {"username":"user","nonce":"hD35Gofz0jF62hij"}
                    plenticore-g3.0
                    	2025-06-11 21:28:29.424	debug	Making request to endpoint auth/start with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/auth/start","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
                    plenticore-g3.0
                    	2025-06-11 21:28:29.331	info	starting. Version 0.1.2 in /opt/iobroker/node_modules/iobroker.plenticore-g3, node: v20.19.2, js-controller: 7.0.6
                    FernetMenta 2 Replies Last reply Reply Quote 0
                    • FernetMenta
                      @vmi kannst du die Instanz vom Adapter mal löschen und neu erstellen? Hattest du optionale Daten konfiguriert?
                      EDIT: Die Fehlermeldung von oben kam dann nicht mehr?
                      • FernetMenta
                        @vmi vielleicht könntest du auch diese Version über npm installieren: 0.1.3-alpha.0
                        Ich habe ein debug log eingebaut, um zu sehen, warum der Adapter bei dir im init hängt.
                        • V
                          @fernetmenta
                          Einstellungen sind wie folgt
                          in den Objekten werden keine Datenpunkte erzeugt
                          Die beta über npm konnte ich lieder nicht installieren
                          • FernetMenta
                            @vmi bitte so die neue Version so installieren
                            FernetMenta V 2 Replies Last reply Reply Quote 0
                            • FernetMenta
                              @vmi und bitte poste auch das Objekt von: system.adapter.plenticore-g3.0
                              Bei mir sieht das z.B. so aus:
                                "common": {
                                  "name": "plenticore-g3",
                                  "version": "0.1.3-alpha.0",
                                  "titleLang": {
                                    "en": "KOSTAL Plenticore G3 API",
                                    "de": "Kostal Plenticore G3 API",
                                    "ru": "Kostal Plenticore G3 API",
                                    "pt": "Kostal Plenticore G3 API",
                                    "nl": "Kostal Plenticore G3 API",
                                    "fr": "API Kostal Plenicore G3",
                                    "it": "Kostal Plenticore G3 API",
                                    "es": "Kostal Plenticore G3 API",
                                    "pl": "Kostal Plenticore G3 API",
                                    "uk": "Kostal Plenicore G3 API",
                                    "zh-cn": "Kostal Plenticore G3 API"
                                  "desc": {
                                    "en": "Adapter to communicate with a KOSTAL Plenticore Plus via local network (non-modbus)",
                                    "de": "Adapter zur Kommunikation mit einem Kostal Plenticore Plus über lokales Netzwerk (Nicht-Modbus)",
                                    "ru": "Адаптер для общения с Kostal Plenticore Plus через локальную сеть (не модбус)",
                                    "pt": "Adaptador para se comunicar com um Kostal Plenticore Plus via rede local (não-Modbus)",
                                    "nl": "Adapter om te communiceren met een Kostal Plenticore plus via lokaal netwerk (niet-Modbus)",
                                    "fr": "Adaptateur pour communiquer avec un Plenticore plus kostal via le réseau local (non-modbus)",
                                    "it": "Adattatore per comunicare con un Kostal Plenticore Plus tramite rete locale (non modbus)",
                                    "es": "Adaptador para comunicarse con un Kostal Plenticore Plus a través de la red local (no Modbus)",
                                    "pl": "Adapter do komunikacji z Kostal Plenticore Plus za pośrednictwem sieci lokalnej (nie-Modbus)",
                                    "uk": "Адаптер для спілкування з Kostal Plenicore Plus через локальну мережу (не модбус)",
                                    "zh-cn": "适配器通过本地网络(非Modbus)与Kostal Plenticore Plus通信"
                                  "authors": [
                                    "fernetmenta <fernetmenta@online.de>"
                                  "keywords": [
                                    "kostal",
                                    "inverter",
                                    "plenticore",
                                    "api"
                                  "licenseInformation": {
                                    "type": "free",
                                    "license": "MIT"
                                  "platform": "Javascript/Node.js",
                                  "icon": "plenticore-g3.png",
                                  "enabled": true,
                                  "extIcon": "https://raw.githubusercontent.com/FernetMenta/ioBroker.plenticore-g3/main/admin/plenticore-g3.png",
                                  "readme": "https://github.com/FernetMenta/ioBroker.plenticore-g3/blob/main/README.md",
                                  "loglevel": "info",
                                  "tier": 3,
                                  "mode": "daemon",
                                  "type": "energy",
                                  "compact": true,
                                  "connectionType": "local",
                                  "dataSource": "poll",
                                  "adminUI": {
                                    "config": "materialize",
                                    "tab": "materialize"
                                  "eraseOnUpload": true,
                                  "dependencies": [
                                      "js-controller": ">=7.0.6"
                                  "globalDependencies": [
                                      "admin": ">=7.4.10"
                                  "installedFrom": "iobroker.plenticore-g3@0.1.3-alpha.0",
                                  "installedVersion": "0.1.3-alpha.0",
                                  "host": "iobroker"
                                "native": {
                                  "host": "plenticore",
                                  "port": "80",
                                  "https": false,
                                  "password": "6|UQY\u000b\rA\u0011",
                                  "pollinginterval": "15",
                                  "pdoptionals": "[{\"id\":\"devices:local:pv1/P\",\"description\":\"\",\"role\":\"\",\"preselected\":false,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0},{\"id\":\"devices:local:pv2/P\",\"description\":\"\",\"role\":\"\",\"preselected\":false,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0},{\"id\":\"scb:statistic:EnergyFlow/Statistic:Yield:Month\",\"description\":\"\",\"role\":\"\",\"preselected\":false,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0},{\"id\":\"scb:update/Update:Version\",\"description\":\"\",\"role\":\"value\",\"preselected\":true,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0},{\"id\":\"devices:local/Inverter:State\",\"description\":\"\",\"role\":\"\",\"preselected\":false,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0},{\"id\":\"devices:local/EM_State\",\"description\":\"\",\"role\":\"\",\"preselected\":false,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0},{\"id\":\"scb:system/System:State\",\"description\":\"\",\"role\":\"\",\"preselected\":false,\"unit\":\"\",\"type\":\"\",\"min\":0,\"max\":0}]",
                                  "settingoptionals": "[{\"id\":\"devices:local/Generator:ShadowMgmt:Enable\",\"description\":\"\",\"preselected\":false,\"unit\":null,\"type\":\"byte\",\"min\":0,\"max\":7},{\"id\":\"devices:local/Battery:DynamicSoc:Enable\",\"description\":\"\",\"preselected\":false,\"unit\":null,\"type\":\"byte\",\"min\":0,\"max\":1},{\"id\":\"devices:local/Battery:SmartBatteryControl:Enable\",\"description\":\"\",\"preselected\":false,\"unit\":null,\"type\":\"byte\",\"min\":0,\"max\":1},{\"id\":\"devices:local/Battery:Strategy\",\"description\":\"\",\"preselected\":false,\"unit\":null,\"type\":\"byte\",\"min\":0,\"max\":2},{\"id\":\"devices:local/Battery:ModeHomeComsumption\",\"description\":\"\",\"preselected\":false,\"unit\":null,\"type\":\"byte\",\"min\":0,\"max\":1}]",
                                  "language": "en"
                                "type": "instance",
                                "instanceObjects": [
                                    "_id": "info",
                                    "type": "channel",
                                    "common": {
                                      "name": "Information"
                                    "native": {}
                                    "_id": "info.connection",
                                    "type": "state",
                                    "common": {
                                      "role": "indicator.connected",
                                      "name": "Device or service connected",
                                      "type": "boolean",
                                      "read": true,
                                      "write": false,
                                      "def": false
                                    "native": {}
                                    "_id": "processdata",
                                    "type": "channel",
                                    "common": {
                                    "native": {}
                                    "_id": "processdata.all-available",
                                    "type": "state",
                                    "common": {
                                      "role": "json",
                                      "name": "Available ProcessData IDs with presets",
                                      "type": "string",
                                      "read": true,
                                      "write": false
                                    "native": {}
                                    "_id": "settings",
                                    "type": "channel",
                                    "common": {
                                    "native": {}
                                    "_id": "settings.all-available",
                                    "type": "state",
                                    "common": {
                                      "role": "json",
                                      "name": "Available Setting IDs with presets",
                                      "type": "string",
                                      "read": true,
                                      "write": false
                                    "native": {}
                                "objects": [],
                                "protectedNative": [
                                  "password"
                                "encryptedNative": [
                                  "password"
                                "notifications": [
                                    "scope": "plenticore-g3",
                                    "name": {
                                      "en": "Kostal plenticore-g3 Adapter",
                                      "de": "Kostal plenticore-g3 Adapter",
                                      "ru": "Адаптер Kostal plenticore-g3",
                                      "pt": "Adaptador Kostal plenticore-g3",
                                      "nl": "Kostal plenticore-g3 Adapter",
                                      "fr": "Adaptateur Kostal plenticore-g3",
                                      "it": "Adattatore Kostal plenticore-g3",
                                      "es": "Adaptador Kostal plenticore-g3",
                                      "pl": "Adapter KOSTAL Plenticore- g3",
                                      "uk": "Конструкційно-г3 адаптер",
                                      "zh-cn": "Kostal pluticore-g3 适应器"
                                    "description": {
                                      "en": "These notifications represent news from your Kostal Plenticore inverter.",
                                      "de": "Diese Benachrichtigungen stellen Neuigkeiten von Ihrem Kostal Plenticore Wechselrichter dar.",
                                      "ru": "Эти уведомления представляют собой новости от инвертора Kostal Plenticore.",
                                      "pt": "Estas notificações representam notícias do seu inversor Kostal Plenticore.",
                                      "nl": "Deze meldingen vertegenwoordigen nieuws van uw Kostal Plenticore omvormer.",
                                      "fr": "Ces notifications représentent les nouvelles de votre inverseur Kostal Plenticore.",
                                      "it": "Queste notifiche rappresentano notizie dal tuo inverter Kostal Plenticore.",
                                      "es": "Estas notificaciones representan noticias de su inversor Kostal Plenticore.",
                                      "pl": "Powiadomienia te reprezentują wiadomości z inwertera Kostal Plenticore.",
                                      "uk": "Ці повідомлення представляють новини від вашого інвертора Kostal Plenticore.",
                                      "zh-cn": "这些通知代表了您Kostal Plenticore反转器的消息."
                                    "categories": [
                                        "category": "update",
                                        "name": {
                                          "en": "Plenticore update",
                                          "de": "Plenticore Update",
                                          "ru": "Обновление Plenticore",
                                          "pt": "Atualização do Plenticore",
                                          "nl": "Plenticore update",
                                          "fr": "Mise à jour Plenticore",
                                          "it": "Aggiornamento Plenticore",
                                          "es": "Actualización de Plenticore",
                                          "pl": "Aktualizacja instalacji",
                                          "uk": "Оновлення Plenticore",
                                          "zh-cn": "微量更新"
                                        "description": {
                                          "en": "A software update is available.",
                                          "de": "Ein Software-Update ist verfügbar",
                                          "ru": "Доступно обновление программного обеспечения",
                                          "pt": "Uma atualização de software está disponível",
                                          "nl": "Er is een software-update beschikbaar",
                                          "fr": "Une mise à jour logicielle est disponible",
                                          "it": "Un aggiornamento software è disponibile",
                                          "es": "Una actualización de software está disponible",
                                          "pl": "Aktualizacja oprogramowania jest dostępna",
                                          "uk": "Доступне оновлення програмного забезпечення",
                                          "zh-cn": "有软件更新"
                                        "regex": [],
                                        "limit": 1,
                                        "severity": "notify"
                                "_id": "system.adapter.plenticore-g3.0",
                                "acl": {
                                  "object": 1636,
                                  "owner": "system.user.admin",
                                "from": "system.host.iobroker.cli",
                                "user": "system.user.admin",
                                "ts": 1749791998322
                                HomeUser last edited by
                                @fernetmenta said in Beta ioBroker.plenticore-g3:
                                Einspeisung = Yield - Statistic:EnergyHomeBat - Statistic:EnergyHomePV
                                kurze Frage, weil ich gerade auch von dem alten Adapter umsteige und im neuen keinen Wert finde für folgenden alten:
                                EnergyFlow.EnergyToGridDay - Power sent to grid at current day
                                Gibt es den und ich finde ihn nicht oder muss man ihn gemäß Zitat selbst berechnen?
                                • FernetMenta
                                  FernetMenta @HomeUser last edited by
                                  @homeuser Muss man selber berechnen, siehe auch https://github.com/stegm/pykoplenti/blob/master/doc/virtual_process_data.md
                                  Ich selbst lese 2.8.0 vom Stromzähler.
                                  • V
                                    @fernetmenta
                                    habe die Version 0.1.3 alpha installiert
                                    Konfig wie folgt
                                    sonst keine Einstellungen geändert. Fehler wie gabt ... leider
                                    admin
                                    v7.6.17
                                    00
                                    Log-Größe: 27.9 MB
                                    Zeit
                                    plenticore-g3.0
                                    	2025-06-15 13:50:48.081	debug	init failed with error: TypeError: this[#adapter].log.warning is not a function
                                    plenticore-g3.0
                                    	2025-06-15 13:50:48.078	debug	API connection closed
                                    plenticore-g3.0
                                    	2025-06-15 13:50:48.077	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                                    plenticore-g3.0
                                    	2025-06-15 13:50:47.611	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session b685f313cc263037461a8e1eb58529eca1912111ff749c9cb978c5769bbffa9a"},"rejectUnauthorized":false}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:32.391	debug	init failed with error: TypeError: this[#adapter].log.warning is not a function
                                    plenticore-g3.0
                                    	2025-06-15 13:50:32.380	debug	API connection closed
                                    plenticore-g3.0
                                    	2025-06-15 13:50:32.379	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.639	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session b685f313cc263037461a8e1eb58529eca1912111ff749c9cb978c5769bbffa9a"},"rejectUnauthorized":false}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.425	info	logged in to plenticore
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.424	debug	API connection closed
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.423	debug	Result of API request: code: 200, headers: [object Object], body: {"sessionId":"b685f313cc263037461a8e1eb58529eca1912111ff749c9cb978c5769bbffa9a"}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.371	debug	Sending post/put data to request: {"transactionId":"fa036fd59e4c99f84577a3dda2298ffea7e505fff8be04e8ab1eba2c5a2c2112","iv":"FClMmYXO1ah+Zcdgwj1ZcQ==","tag":"aa20SmILsSfuOQCDXAZNIg==","payload":"gPvZidYs5JThX6o5XyvoikqFvvP/y/WkwzpeUIYeHMkYb3mdvjLET/0XWCutxYFk+autCXzUSyL3A/s2arNh2Q=="}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.369	debug	Making request to endpoint auth/create_session with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/auth/create_session","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.360	debug	API connection closed
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.359	debug	Result of API request: code: 200, headers: [object Object], body: {"signature":"jXjKZ16Y7WZ4rek5N7VtktIOBe9k1IjwI7g6PLZUp4Y=","token":"d2648dce1b04221df65a51bb2e8c0cb5f1985240acb98b39d61d12770ec7e115"}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.301	debug	Sending post/put data to request: {"transactionId":"fa036fd59e4c99f84577a3dda2298ffea7e505fff8be04e8ab1eba2c5a2c2112","proof":"8c6W3Lg0ly4ce97GMgjUYSV5+lPPpQ6uiOxqPY8LMS0="}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:31.300	debug	Making request to endpoint auth/finish with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/auth/finish","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:30.928	debug	API connection closed
                                    plenticore-g3.0
                                    	2025-06-15 13:50:30.925	debug	Result of API request: code: 200, headers: [object Object], body: {"transactionId":"fa036fd59e4c99f84577a3dda2298ffea7e505fff8be04e8ab1eba2c5a2c2112","nonce":"ggoWo9iNs9maRz7nj0RCL\/TS0TLjYue1","salt":"tBI8GkZ9+z4koNgs","rounds":29000}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:30.809	debug	Sending post/put data to request: {"username":"user","nonce":"ggoWo9iNs9maRz7n"}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:30.807	debug	Making request to endpoint auth/start with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/auth/start","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json"},"rejectUnauthorized":false}
                                    plenticore-g3.0
                                    	2025-06-15 13:50:30.697	info	starting. Version 0.1.3-alpha.0 in /opt/iobroker/node_modules/iobroker.plenticore-g3, node: v20.19.2, js-controller: 7.0.6
                                    plenticore-g3.0
                                    	2025-06-15 13:50:23.349	info	terminating
                                    plenticore-g3.0
                                    	2025-06-15 13:50:22.847	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                                    plenticore-g3.0
                                    	2025-06-15 13:50:22.845	info	terminating
                                    plenticore-g3.0
                                    	2025-06-15 13:50:22.842	info	Got terminate signal TERMINATE_YOURSELF
                                    FernetMenta 1 Reply Last reply Reply Quote 0
                                    • FernetMenta
                                      @vmi
                                      Aber durch das logging weiß ich jetzt woran es gelgen hat, dass das Init nicht durchlief. Build läuft gerade. 0.1.3 sollte so in 30min über das beta Repo installierbar sein. Damit werden auch warnings geloggt. Kannst du diese dann wieder hier posten?
                                      Ich tippe, dass beim ersten init was schief ging und in diesem Objekt was falsche steht: system.adapter.plenticore-g3.0
                                      Könntest du das auch noch posten bitte? Findest du im Expertenmodus unter system:
                                      Oder 0.1.3 einfach über npm installieren. Sync mit beta repo kann evtl länger dauern:
                                      • V
                                        @fernetmenta
                                        hier das logging
                                        admin
                                        v7.6.17
                                        00
                                        Log-Größe: 50.6 MB
                                        Zeit
                                        plenticore-g3.0
                                        	2025-06-16 21:19:57.398	debug	API connection closed
                                        plenticore-g3.0
                                        	2025-06-16 21:19:57.398	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","settings":[{"id":"Battery:MinHomeComsumption","value":"50.0"},{"id":"Battery:MinSoc","value":"5"}]},{"moduleid":"scb:update","settings":[{"id":"Update:Method","value":"2"}]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:57.056	debug	Sending post/put data to request: [{"moduleid":"devices:local","settingids":["Battery:MinHomeComsumption","Battery:MinSoc"]},{"moduleid":"scb:update","settingids":["Update:Method"]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:57.055	debug	Making request to endpoint settings with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/settings","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cde746256f4f6ff8844f7c07702cf6cf2ed50620374aff481f36630ad79cc10e"},"rejectUnauthorized":false}
                                        plenticore-g3.0
                                        	2025-06-16 21:19:57.054	debug	API connection closed
                                        plenticore-g3.0
                                        	2025-06-16 21:19:57.054	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdata":[{"id":"Dc_P","unit":"","value":43.3035888671875},{"id":"Grid_P","unit":"","value":14.628982543945312},{"id":"Home_P","unit":"","value":20.923791885375977}]},{"moduleid":"devices:local:ac","processdata":[{"id":"P","unit":"","value":0.0}]},{"moduleid":"scb:statistic:EnergyFlow","processdata":[{"id":"Statistic:EnergyChargePv:Day","unit":"","value":0.0},{"id":"Statistic:EnergyHome:Day","unit":"","value":2927.833611990617},{"id":"Statistic:EnergyHomeBat:Day","unit":"","value":0.0},{"id":"Statistic:EnergyHomeGrid:Day","unit":"","value":2039.189476470627},{"id":"Statistic:EnergyHomePv:Day","unit":"","value":889.1730981303332},{"id":"Statistic:Yield:Day","unit":"","value":56885.6391719142}]},{"moduleid":"scb:update","processdata":[{"id":"Update:Version","unit":"","value":0.0}]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:56.699	debug	Sending post/put data to request: [{"moduleid":"devices:local","processdataids":["Grid_P","Dc_P","Home_P"]},{"moduleid":"devices:local:ac","processdataids":["P"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Yield:Day","Statistic:EnergyChargePv:Day","Statistic:EnergyHome:Day","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomePv:Day"]},{"moduleid":"scb:update","processdataids":["Update:Version"]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:56.698	debug	Making request to endpoint processdata with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cde746256f4f6ff8844f7c07702cf6cf2ed50620374aff481f36630ad79cc10e"},"rejectUnauthorized":false}
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.685	debug	API connection closed
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.685	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","settings":[{"id":"Battery:MinHomeComsumption","value":"50.0"},{"id":"Battery:MinSoc","value":"5"}]},{"moduleid":"scb:update","settings":[{"id":"Update:Method","value":"2"}]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.455	debug	Sending post/put data to request: [{"moduleid":"devices:local","settingids":["Battery:MinHomeComsumption","Battery:MinSoc"]},{"moduleid":"scb:update","settingids":["Update:Method"]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.454	debug	Making request to endpoint settings with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/settings","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cde746256f4f6ff8844f7c07702cf6cf2ed50620374aff481f36630ad79cc10e"},"rejectUnauthorized":false}
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.453	debug	API connection closed
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.452	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdata":[{"id":"Dc_P","unit":"","value":31.17264747619629},{"id":"Grid_P","unit":"","value":10.357355117797852},{"id":"Home_P","unit":"","value":6.385263919830322}]},{"moduleid":"devices:local:ac","processdata":[{"id":"P","unit":"","value":0.0}]},{"moduleid":"scb:statistic:EnergyFlow","processdata":[{"id":"Statistic:EnergyChargePv:Day","unit":"","value":0.0},{"id":"Statistic:EnergyHome:Day","unit":"","value":2927.833611990617},{"id":"Statistic:EnergyHomeBat:Day","unit":"","value":0.0},{"id":"Statistic:EnergyHomeGrid:Day","unit":"","value":2039.189476470627},{"id":"Statistic:EnergyHomePv:Day","unit":"","value":889.1730981303332},{"id":"Statistic:Yield:Day","unit":"","value":56885.6391719142}]},{"moduleid":"scb:update","processdata":[{"id":"Update:Version","unit":"","value":0.0}]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.289	debug	Sending post/put data to request: [{"moduleid":"devices:local","processdataids":["Grid_P","Dc_P","Home_P"]},{"moduleid":"devices:local:ac","processdataids":["P"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Yield:Day","Statistic:EnergyChargePv:Day","Statistic:EnergyHome:Day","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomePv:Day"]},{"moduleid":"scb:update","processdataids":["Update:Version"]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:41.289	debug	Making request to endpoint processdata with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cde746256f4f6ff8844f7c07702cf6cf2ed50620374aff481f36630ad79cc10e"},"rejectUnauthorized":false}
                                        plenticore-g3.0
                                        	2025-06-16 21:19:26.278	debug	API connection closed
                                        plenticore-g3.0
                                        	2025-06-16 21:19:26.277	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","settings":[{"id":"Battery:MinHomeComsumption","value":"50.0"},{"id":"Battery:MinSoc","value":"5"}]},{"moduleid":"scb:update","settings":[{"id":"Update:Method","value":"2"}]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:26.048	debug	Sending post/put data to request: [{"moduleid":"devices:local","settingids":["Battery:MinHomeComsumption","Battery:MinSoc"]},{"moduleid":"scb:update","settingids":["Update:Method"]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:26.048	debug	Making request to endpoint settings with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/settings","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cde746256f4f6ff8844f7c07702cf6cf2ed50620374aff481f36630ad79cc10e"},"rejectUnauthorized":false}
                                        plenticore-g3.0
                                        	2025-06-16 21:19:26.046	debug	API connection closed
                                        plenticore-g3.0
                                        	2025-06-16 21:19:26.045	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdata":[{"id":"Dc_P","unit":"","value":30.215829849243164},{"id":"Grid_P","unit":"","value":6.787362575531006},{"id":"Home_P","unit":"","value":2.8782525062561035}]},{"moduleid":"devices:local:ac","processdata":[{"id":"P","unit":"","value":0.0}]},{"moduleid":"scb:statistic:EnergyFlow","processdata":[{"id":"Statistic:EnergyChargePv:Day","unit":"","value":0.0},{"id":"Statistic:EnergyHome:Day","unit":"","value":2927.833611990617},{"id":"Statistic:EnergyHomeBat:Day","unit":"","value":0.0},{"id":"Statistic:EnergyHomeGrid:Day","unit":"","value":2039.189476470627},{"id":"Statistic:EnergyHomePv:Day","unit":"","value":889.1730981303332},{"id":"Statistic:Yield:Day","unit":"","value":56885.6391719142}]},{"moduleid":"scb:update","processdata":[{"id":"Update:Version","unit":"","value":0.0}]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:25.741	debug	Sending post/put data to request: [{"moduleid":"devices:local","processdataids":["Grid_P","Dc_P","Home_P"]},{"moduleid":"devices:local:ac","processdataids":["P"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Yield:Day","Statistic:EnergyChargePv:Day","Statistic:EnergyHome:Day","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomePv:Day"]},{"moduleid":"scb:update","processdataids":["Update:Version"]}]
                                        plenticore-g3.0
                                        	2025-06-16 21:19:25.740	debug	Making request to endpoint processdata with data {"method":"POST","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session cde746256f4f6ff8844f7c07702cf6cf2ed50620374aff481f36630ad79cc10e"},"rejectUnauthorized":false}
                                        jetzt scheint es zu gehen 🙂 Danke
                                        Herzlichen Dank für den schnellen und super Support.
                                        • FernetMenta
                                          FernetMenta @vmi last edited by
                                          @vmi könntest du bitte das ganze log posten? Da müsste nach dem Start ein warn log drin stehen.
                                          • V
                                            vmi @FernetMenta last edited by
                                            @fernetmenta
                                            plenticore-g3.0
                                            	2025-06-16 21:31:36.349	debug	Making request to endpoint settings with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/settings","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session 16fdeb71db17a0b930ccd25eebb0f78b7d4a37955f6b9394bf4d7f01037298a8"},"rejectUnauthorized":false}
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.744	warn	preset not found in list: {preset.id}
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.742	warn	preset not found in list: {preset.id}
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.729	debug	API connection closed
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.724	debug	Result of API request: code: 200, headers: [object Object], body: [{"moduleid":"devices:local","processdataids":["Bat2Grid_P","BatDetection","Dc_P","DigitalIn","DigitalOut","EM_State","Grid2Bat_P","Grid_L1_I","Grid_L1_P","Grid_L2_I","Grid_L2_P","Grid_L3_I","Grid_L3_P","Grid_P","Grid_Q","Grid_S","HomeBat_P","HomeGrid_P","HomeOwn_P","HomePv_P","Home_P","Inverter:State","Iso_R","LimitEvuAbs","LimitEvuRel","PV2Bat_P","WorkTime","WorkTimeESB"]},{"moduleid":"devices:local:ac","processdataids":["CosPhi","Frequency","InvIn_P","InvOut_P","L1_I","L1_P","L1_U","L2_I","L2_P","L2_U","L3_I","L3_P","L3_U","P","Q","ResidualCDc_I","S"]},{"moduleid":"devices:local:cancom","processdataids":[]},{"moduleid":"devices:local:powermeter","processdataids":["CosPhi","Exp_E","Exp_EQ","Exp_ES","Frequency","Imp_E","Imp_EQ","Imp_ES","L1_I","L1_P","L1_Q","L1_S","L1_U","L2_I","L2_P","L2_Q","L2_S","L2_U","L3_I","L3_P","L3_Q","L3_S","L3_U","P","Q","S"]},{"moduleid":"devices:local:pv1","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv2","processdataids":["I","P","U"]},{"moduleid":"devices:local:pv3","processdataids":["I","P","U"]},{"moduleid":"scb:diagnostics","processdataids":[]},{"moduleid":"scb:event","processdataids":["ErrMc","ErrSFH","Event:ActiveAckCnt","Event:ActiveAckCode","Event:ActiveErrorCnt","Event:ActiveWarningCnt"]},{"moduleid":"scb:export","processdataids":["FtpConActive","PortalConActive"]},{"moduleid":"scb:network:ProcessData","processdataids":[]},{"moduleid":"scb:pemanager","processdataids":["PEM:Charging","PEM:Tarif:ChargingPrice","PEM:Tarif:ChargingStrategy","PEM:Tarif:CurrentPrice"]},{"moduleid":"scb:statistic:EnergyFlow","processdataids":["Statistic:Autarky:Day","Statistic:Autarky:Month","Statistic:Autarky:Total","Statistic:Autarky:Year","Statistic:CO2Saving:Day","Statistic:CO2Saving:Month","Statistic:CO2Saving:Total","Statistic:CO2Saving:Year","Statistic:EnergyChargeGrid:Day","Statistic:EnergyChargeGrid:Month","Statistic:EnergyChargeGrid:Total","Statistic:EnergyChargeGrid:Year","Statistic:EnergyChargeInvIn:Day","Statistic:EnergyChargeInvIn:Month","Statistic:EnergyChargeInvIn:Total","Statistic:EnergyChargeInvIn:Year","Statistic:EnergyChargePv:Day","Statistic:EnergyChargePv:Month","Statistic:EnergyChargePv:Total","Statistic:EnergyChargePv:Year","Statistic:EnergyDischarge:Day","Statistic:EnergyDischarge:Month","Statistic:EnergyDischarge:Total","Statistic:EnergyDischarge:Year","Statistic:EnergyDischargeGrid:Day","Statistic:EnergyDischargeGrid:Month","Statistic:EnergyDischargeGrid:Total","Statistic:EnergyDischargeGrid:Year","Statistic:EnergyHome:Day","Statistic:EnergyHome:Month","Statistic:EnergyHome:Total","Statistic:EnergyHome:Year","Statistic:EnergyHomeBat:Day","Statistic:EnergyHomeBat:Month","Statistic:EnergyHomeBat:Total","Statistic:EnergyHomeBat:Year","Statistic:EnergyHomeGrid:Day","Statistic:EnergyHomeGrid:Month","Statistic:EnergyHomeGrid:Total","Statistic:EnergyHomeGrid:Year","Statistic:EnergyHomeOwn:Total","Statistic:EnergyHomePv:Day","Statistic:EnergyHomePv:Month","Statistic:EnergyHomePv:Total","Statistic:EnergyHomePv:Year","Statistic:EnergyPv1:Day","Statistic:EnergyPv1:Month","Statistic:EnergyPv1:Total","Statistic:EnergyPv1:Year","Statistic:EnergyPv2:Day","Statistic:EnergyPv2:Month","Statistic:EnergyPv2:Total","Statistic:EnergyPv2:Year","Statistic:EnergyPv3:Day","Statistic:EnergyPv3:Month","Statistic:EnergyPv3:Total","Statistic:EnergyPv3:Year","Statistic:OwnConsumptionRate:Day","Statistic:OwnConsumptionRate:Month","Statistic:OwnConsumptionRate:Total","Statistic:OwnConsumptionRate:Year","Statistic:Yield:Day","Statistic:Yield:Month","Statistic:Yield:Total","Statistic:Yield:Year"]},{"moduleid":"scb:system","processdataids":["System:Props:BatOptions","System:Props:Battery","System:Props:CeiInputSupport","System:Props:DigOutMode","System:Props:ExtBatCtrl","System:Props:HWversion","System:Props:InverterGen","System:Props:Lmg","System:Props:Pv","System:Props:RSE","System:Props:ShadowMgmt","System:Props:WlanSupport","System:State"]},{"moduleid":"scb:update","processdataids":["Update:Progress","Update:Status","Update:StatusTime","Update:Version"]}]
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.444	debug	Making request to endpoint processdata with data {"method":"GET","port":"80","host":"192.168.178.81","path":"/api/v1/processdata","headers":{"User-Agent":"Mozilla/5.0 (X11; Linux x86_64; rv:71.0) Gecko/20100101 Firefox/71.0","Content-Type":"application/json","Authorization":"Session 16fdeb71db17a0b930ccd25eebb0f78b7d4a37955f6b9394bf4d7f01037298a8"},"rejectUnauthorized":false}
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.198	info	logged in to plenticore
                                            plenticore-g3.0
                                            	2025-06-16 21:31:35.196	debug	API connection closed
                                            3953
