    4. ZigBee macht mich irre und will einfach nicht.
    • Lucifor1976
      Lucifor1976 @Asgothian last edited by Lucifor1976
      @asgothian
      Hello und guten Morgen,
      Ja die Osram war vorher im HUE Netzt, die ist ewig alt. Habs nur zum Testen eingebunden. Hab zwei Stück von den Dingern. Im HUE Netzt wollte sie zuletzt nicht mehr.
      Ja das Log ist leider voller Fehler:
      zigbee.1
      2797408 2025-06-13 10:08:22.536 warn ELEVATED:I02 (2f04) value generated '231' from device a4c138d13208d2b7 for 'Measured electrical potential value'
      zigbee.1
      2797408 2025-06-13 10:08:22.536 warn ELEVATED:I01 (2f04) message received '{"voltage":231}' from device a4c138d13208d2b7 type 'TS011F_plug_1'
      zigbee.1
      2797408 2025-06-13 10:08:22.533 warn ELEVATED:I01 (2f04) Zigbee Event of Type attributeReport from device 0xa4c138d13208d2b7, incoming event: {"type":"attributeReport","data":{"rmsVoltage":231},"linkquality":0,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":121,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.1
      2797408 2025-06-13 10:08:16.549 warn ELEVATED:I02 (17a1) value generated '232' from device a4c138d13208d2b7 for 'Measured electrical potential value'
      zigbee.1
      2797408 2025-06-13 10:08:16.549 warn ELEVATED:I01 (17a1) message received '{"voltage":232}' from device a4c138d13208d2b7 type 'TS011F_plug_1'
      zigbee.1
      2797408 2025-06-13 10:08:16.546 warn ELEVATED:I01 (17a1) Zigbee Event of Type attributeReport from device 0xa4c138d13208d2b7, incoming event: {"type":"attributeReport","data":{"rmsVoltage":232},"linkquality":0,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":120,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.1
      2797408 2025-06-13 10:08:04.612 warn ELEVATED:I02 (e8ff) value generated '231' from device a4c138d13208d2b7 for 'Measured electrical potential value'
      zigbee.1
      2797408 2025-06-13 10:08:04.612 warn ELEVATED:I01 (e8ff) message received '{"voltage":231}' from device a4c138d13208d2b7 type 'TS011F_plug_1'
      zigbee.1
      2797408 2025-06-13 10:08:04.607 warn ELEVATED:I01 (e8ff) Zigbee Event of Type attributeReport from device 0xa4c138d13208d2b7, incoming event: {"type":"attributeReport","data":{"rmsVoltage":231},"linkquality":0,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":119,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.1
      2797408 2025-06-13 10:07:31.542 warn ELEVATED:I02 (67d2) value generated '70' from device a4c138d13208d2b7 for 'Instantaneous measured electrical current'
      zigbee.1
      2797408 2025-06-13 10:07:31.541 warn ELEVATED:I01 (67d2) message received '{"current":70}' from device a4c138d13208d2b7 type 'TS011F_plug_1'
      zigbee.1
      2797408 2025-06-13 10:07:31.538 warn ELEVATED:I01 (67d2) Zigbee Event of Type attributeReport from device 0xa4c138d13208d2b7, incoming event: {"type":"attributeReport","data":{"rmsCurrent":70},"linkquality":0,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":116,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.1
      2797408 2025-06-13 10:07:22.520 warn ELEVATED:I02 (4494) value generated '232' from device a4c138d13208d2b7 for 'Measured electrical potential value'
      zigbee.1
      2797408 2025-06-13 10:07:22.520 warn ELEVATED:I01 (4494) message received '{"voltage":232}' from device a4c138d13208d2b7 type 'TS011F_plug_1'
      zigbee.1
      2797408 2025-06-13 10:07:22.516 warn ELEVATED:I01 (4494) Zigbee Event of Type attributeReport from device 0xa4c138d13208d2b7, incoming event: {"type":"attributeReport","data":{"rmsVoltage":232},"linkquality":0,"groupID":0,"cluster":"haElectricalMeasurement","meta":{"zclTransactionSequenceNumber":115,"frameControl":{"frameType":0,"manufacturerSpecific":false,"direction":1,"disableDefaultResponse":true,"reservedBits":0}},"endpoint_id":1}
      zigbee.1
      2797408 2025-06-13 10:07:19.532 warn ELEVATED:I02 (38e8) value generated '74' from device a4c138d13208d2b7 for 'Instantaneous measured electrical current'
      zigbee.1
      2797408 2025-06-13 10:07:19.532 warn ELEVATED:I01 (38e8) message received '{"current":74}' from device a4c138d13208d2b7 type 'TS011F_plug_1'
      Genau deswegen hab ich mich lange vor ZigBee gedrückt, Wenns brauchbare W-Lan Temperatur Sensoren gäbe, hätt ich damit vermutlich auch garnicht erst angefangen.
      Ja, beide Screens sind vom gleichen Netzt, ich habe vorhin den Coordinator eine Etage nach oben verfrachtet, der ist nun in der E-Werkstatt. Jetzt werden alle Geräte als off angezeigt, lassen sich schalten, sogar schnell und Problemlos, die Temperatursensoren geben allerdings keine Werte.
      Ich war, bin und werde wohl immer auf Kriegsfuß mit ZigBee sein .. 😞
      • Asgothian
        Asgothian Developer @Lucifor1976 last edited by Asgothian
        @lucifor1976 sagte in ZigBee macht mich irre und will einfach nicht.:
        @asgothian
        Schmeiss die Osram aus dem Netz - die macht da nur ärger !
        Nein - du hast bei mindestens 1 Gerät das Debugging eingeschaltet. Bitte ausschalten, und dann nochmal schauen (bug icon auf der Kachel ist grün oder orange)
        Dann versuch nochmal zu schalten und schau nach ob es Meldungen gibt (kann bis zu 20 s dauern ab dem Schalt-Zeitpunkt)
        Bitte das Netz öffnen und die Sensoren triggern (taste daran kurz drücken) - das Batterie-betriebene Sensoren nicht mit bekommen wenn der Koordinator bewegt wird ist (leider) normal. Die kommen wieder - das kann aber einige Zeit dauern da sie erst einmal mit bekommen müssen das das Netz anders ist - und zum Stromsparen sind sie fast immer offline.
        A.
        Lucifor1976 1 Reply Last reply Reply Quote 0
        • Lucifor1976
          @asgothian
          Nach einen Trigger der Sensoren, ist einer wieder da, der andere nicht.
          Schalten einer Steckdose hier im Wohnzimmer geht dauert aber ewig. Also knapp an die 30 Sekunden und wird als Offline angezeigt.
          Fehler im Log gibt es auch, die Debugs hab ich abgeschaltet.
          Achja, und die Osram ist raus...
          zigbee.1
          2797408 2025-06-13 11:08:15.839 error Send command to 0xa4c138d13208d2b7 failed with no error code (Timeout - 38437 - 1 - 31 - 6 - 11 after 10000ms)
          zigbee.1
          2797408 2025-06-13 11:07:47.078 error Send command to 0xa4c138d13208d2b7 failed with no error code (Timeout - 38437 - 1 - 30 - 6 - 11 after 10000ms)
          zigbee.1
          2797408 2025-06-13 11:07:42.369 info List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS0"}]
          zigbee.1
          2797408 2025-06-13 11:07:23.729 error Send command to 0xa4c138d13208d2b7 failed with no error code (Timeout - 38437 - 1 - 29 - 6 - 11 after 10000ms)
          zigbee.1
          2797408 2025-06-13 11:07:03.932 info List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS0"}]
          zigbee.1
          2797408 2025-06-13 11:05:53.302 info List of port: [{"path":"/dev/ttyS1"},{"path":"/dev/ttyS2"},{"path":"/dev/ttyS3"},{"path":"/dev/ttyS0"}]
          zigbee.1
          2797408 2025-06-13 11:01:56.033 info Stopping to ping 0xa4c138d13208d2b7 TS011F after 195 ping attempts
          Was meinst du mit "netzt öffnen" ?
          • BananaJoe
            BananaJoe Most Active last edited by
            Ideal wäre das jeweils Gerät immer da anzulernen wo es auch im Einsatz ist.
            Beim Wechsel bei mir zwischen 2 ZigBee Koordinatoren/Netzen brauchte das manchmal dann zwar auch mal mehr al einen versuch, dafür war es danach immer stabil.
            Ich setze auch Steckdosen und Alarmsirenen als Repeater ein. Als ich eine neuere Generation von Steckdosen eingesetzt hatte, hatten die sich zuerst so gar nicht integriert bzw. die wurden nicht richtig genutzt, da hatte ich mich schon ziemlich geärgert.
            Als ich allerdings ein paar Tage später geschaut hatte, war alles Tip Top und wie gewünscht.
            Also: Geduld. Gerate wegen der Batteriegeräte ist das ganze kein Echtzeitsystem. Aber stromsparsamer als WLAN auf jeden Fall.
            • Asgothian
              Lucifor1976 MartinP 2 Replies Last reply Reply Quote 0
              • Lucifor1976
                @asgothian sagte in ZigBee macht mich irre und will einfach nicht.:
                Danke 🙂
                • Lucifor1976
                  Lucifor1976 @BananaJoe last edited by
                  @bananajoe sagte in ZigBee macht mich irre und will einfach nicht.:
                  Das hatte ich weiter oben gefragt da war hies es dann koppeln nur am Koordinator..
                  Klappt aber auch nicht, wenn ich hier im Wohnzimmer die Kopplung starte und ein Gerät hunzufügen will es nicht, gehe ich in Reichweite des Koordinators, gehts sofort...
                  Wir fahren gleich nach Ikea.. Ich beroge mir noch 4 Steckdosen und 3 Trapelvieh Lampen..
                  Mal sehen was darus wird...
                  • Lucifor1976
                    Lucifor1976 @Lucifor1976 last edited by
                    Achja, und erstmal ein herzlichen Danke an alle dir mir hier versuchen zu helfen 🙂
                    • MartinP
                      MartinP @Asgothian last edited by
                      Ich hatte neulich Zickigkeit mit Zigbee2Mqtt...
                      Da hatte ich diese Anmerkung in der Konfigurationsoberfläche nicht ernst genommen:
                      Da war vorher 22 eingestellt, und da gab es immer wieder Probleme mit Pairing ...
                      Werde wohl nur noch die ZLL Channels 11,15,20 und 25 verwenden...
                      ZLL ist wohl eine Abkürzung für Zigbee-Light-Link
                      https://www.silabs.com/documents/public/user-guides/ug103-09-fundamentals-zll.pdf
                      • Lucifor1976
                        Lucifor1976 @MartinP last edited by
                        @martinp
                        Bei mir ist es Kanal 25, der war nach einen Scan am wenigsten belegte.
                        Lucifor1976 1 Reply Last reply Reply Quote 1
                        • Lucifor1976
                          Was soll ich sagen, kauft man brauchbaren Kram (der muss nicht teuer sein)
                          klappts auch mit dem Nachbarn....
                          • MartinP
                            MartinP @Lucifor1976 last edited by
                            @lucifor1976 Drei Geräte aus dem Netz gefallen = "klappt"?
                            oder sind die hardwaremäßig ausgeschaltet /stromlos?
                            • Lucifor1976
                              Lucifor1976 @MartinP last edited by Lucifor1976
                              @martinp
                              Fast, das sind "DeeLink zigbee Steckdosen" und gehören auf eine möglicherweise existierende schwarze Liste.
                              Die funktionieren als Endgeräte "An/Aus" zu mehr taugen die nicht. Vielleicht kann man die umflashen.
                              Sie funktionieren, geben aber Müll bei Stromwerten aus, und können offensichtlich nicht routen und werden als offline angezeigt.
                              Die Ikea Steckdosen und Lampen machen einen super Job und haben direkt ein brauchbares Mesh aufgebaut.
                              Auch das Koppeln über die Router funktioniert einwandfrei...
                              Die Sensoren verbinde ich gerade neu und auch diese liefern jetzt Daten..
                                Homoran Global Moderator Administrators @Lucifor1976 last edited by
                                sind sie!
                                @homoran sagte in ZigBee macht mich irre und will einfach nicht.:
                                Kann das sein
                                ich kann leider nichts aus den Screenshot zitieren, aber da steht "not supported"!
                                • Lucifor1976
                                  Lucifor1976 @Homoran last edited by
                                  Ja ja, ich habs verstanden 😉
                                  Ich überlege noch ob ich sie zurückschicke oder mich damit beschäftige und versuche eine andere Firmware drauf zu bekommen.
                                  • Lucifor1976
                                    Ich habe noch eine Frage.
                                    Gibt es eine Möglichkeit die Zigbee Devices in die Alexa zu bekommen?
                                    Winni 1 Reply Last reply Reply Quote 0
                                    • Winni
                                      Winni @Lucifor1976 last edited by
                                      @lucifor1976 ja, schau hier:
                                      https://www.iobroker.net/#en/adapters/adapterref/iobroker.iot/README.md
                                      • Lucifor1976
                                        Lucifor1976 @Winni last edited by
                                        @winni sagte in ZigBee macht mich irre und will einfach nicht.:
                                        Danke, brauch ich ein Pro Abo dazu? Auf der seite steht das Assistenten mit der Free Version möglich sind?
                                        Die Readme im Adapter sagt aber Pro?
                                        Winni Lucifor1976 2 Replies Last reply Reply Quote 0
                                        • Winni
                                          Winni @Lucifor1976 last edited by Winni
                                          @lucifor1976 wenn ich mich nicht irre, sind 20 Abfragen am Tag ohne Abo möglich.
                                          PS: Mit dem Abo unterstützt auch die Macher von iobroker 😉
                                          • Lucifor1976
                                            Du hast Recht 🙂
                                            Ich seh mir das ein paar Tage an, wenn das gut läuft (für mich) wird bezahlt...
                                            BananaJoe 1 Reply Last reply Reply Quote 1
                                            1395
