    3. Entwicklung
    4. Adapter Worx Landroid v3.x.x
    • Gargano
      Gargano last edited by
      Seit letzter Woche wird mein Account für 24h gesperrt ,wenn ich den Adapter starte. Auch die App geht dann nicht mehr.
      Ich hatte den Adapter auf 3.2.4 upgedatet . Seitdem der Fehler auch mit älteren Versionen .
      Hat noch jemand das Problem ?
      Hier der Log :
      worx.0
      2025-06-15 18:32:29.748	info	terminating
      worx.0
      2025-06-15 18:32:29.246	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
      worx.0
      2025-06-15 18:32:29.244	debug	Plugin sentry destroyed
      worx.0
      2025-06-15 18:32:29.243	info	terminating
      worx.0
      2025-06-15 18:32:29.241	info	Got terminate signal TERMINATE_YOURSELF
      worx.0
      2025-06-15 18:29:59.662	info	Start check devices object!
      worx.0
      2025-06-15 18:29:59.662	debug	Start refreshTokenInterval!
      worx.0
      2025-06-15 18:29:59.661	warn	No mower found to start mqtt
      worx.0
      2025-06-15 18:29:59.660	info	Start MQTT connection
      worx.0
      2025-06-15 18:29:59.641	error	"429 TOO MANY REQUESTS"
      worx.0
      2025-06-15 18:29:59.641	error	AxiosError: Request failed with status code 429
      worx.0
      2025-06-15 18:29:59.485	error	"429 TOO MANY REQUESTS"
      worx.0
      2025-06-15 18:29:59.485	error	AxiosError: Request failed with status code 429
      worx.0
      2025-06-15 18:29:59.315	info	Start login
      worx.0
      2025-06-15 18:29:59.314	debug	Session value: 0
      worx.0
      2025-06-15 18:29:59.312	error	"429 TOO MANY REQUESTS"
      worx.0
      2025-06-15 18:29:59.312	error	AxiosError: Request failed with status code 429
      worx.0
      2025-06-15 18:29:58.977	debug	Refresh token
      worx.0
      2025-06-15 18:29:58.976	debug	Use old session for refresh token!
      worx.0
      2025-06-15 18:29:58.976	debug	Old session {"token_type":"Bearer","expires_in":3600,"access_token":yyyyy
      worx.0
      2025-06-15 18:29:58.967	info	Login to worx
      worx.0
      2025-06-15 18:29:58.965	info	Changed timeout for edgecut to 5000
      worx.0
      2025-06-15 18:29:58.961	info	Use new aws-iot-device-sdk-v2.
      worx.0
      2025-06-15 18:29:58.773	debug	Server have not been changed!
      worx.0
      2025-06-15 18:29:58.770	debug	User and password have not been changed!
      worx.0
      2025-06-15 18:29:58.671	info	starting. Version 3.2.0 in /opt/iobroker/node_modules/iobroker.worx, node: v20.18.3, js-controller: 7.0.7
      worx.0
      2025-06-15 18:29:58.476	debug	Plugin sentry Initialize Plugin (enabled=true)
      worx.0
      2025-06-15 18:29:58.456	debug	States connected to redis: xxxx
      worx.0
      2025-06-15 18:29:58.452	debug	States create User PubSub Client
      worx.0
      2025-06-15 18:29:58.452	debug	States create System PubSub Client
      worx.0
      2025-06-15 18:29:58.449	debug	Redis States: Use Redis connection: xxxxx
      worx.0
      2025-06-15 18:29:58.442	debug	Objects connected to redis: xxxxx
      worx.0
      2025-06-15 18:29:58.439	debug	Objects client initialize lua scripts
      worx.0
      2025-06-15 18:29:58.380	debug	Objects create User PubSub Client
      worx.0
      2025-06-15 18:29:58.380	debug	Objects create System PubSub Client
      worx.0
      2025-06-15 18:29:58.379	debug	Objects client ready ... initialize now
      worx.0
      2025-06-15 18:29:58.367	debug	Redis Objects: Use Redis connection
      haselchen E 2 Replies Last reply Reply Quote 0
      • haselchen
        haselchen Most Active @Gargano last edited by
        @gargano
        Guck bitte hier und machen da auch weiter....
        https://forum.iobroker.net/topic/74380/adapter-worx-landroid-v3-x-x/239
          Homoran Global Moderator Administrators @haselchen last edited by
          @haselchen Danke!
          7ch hab's zusammengeführt
          Gargano 1 Reply Last reply Reply Quote 2
          • Gargano
            Gargano @Homoran last edited by
            @homoran Danke fürs Zusammenführen. Ich habs leider nicht gefunden.
              eve11 @Gargano last edited by eve11
              @gargano
              Bei mir das selbe Problem.
              Ich warte jetzt bis morgen und probiere es noch einmal.
              Nach 24 Stunden kann ich die App wieder starten, aber sobald ich den Adapter starte kommt die Fehlermeldung und die App geht nicht mehr. Alle Blockly Scripts habe ich deaktiviert.
              Berichte dann morgen wieder.
                Lucky_ESA Developer Most Active @eve11 last edited by
                @eve11 sagte in Adapter Worx Landroid v3.x.x:
                @gargano
                Wenn das wirklich so ist dann bitte erst in der Instanz Einstellungen den roten Button drücken. Schau dann zur Sicherheit nach, ob das State worx.0.loginInfo wirklich leer ist.
                Gruß//Lucky
                  eve11 @Lucky_ESA last edited by
                  @lucky_esa
                  Wenn ich den Button "Sitzungsdaten löschen" betätige wird an diesem State nichts verändert.
                  Sollte ich mal den ganzen Adapter deinstallieren und wieder installieren ?
                  Gargano 1 Reply Last reply Reply Quote 0
                  • Gargano
                    Gargano @eve11 last edited by
                    @eve11 Hab gerade neu installiert, muss trotzdem die 24 Stunden abwarten, da er keine Daten holen kann.
                      @gargano
                      Ich denke bevor die 24 Stunden nicht abgelaufen sind, wird eine Adapter Neuinstallation nichts bringen
                        @gargano
                        Das ist korrekt.
                        • N
                          NewPaint2 @arteck last edited by
                          @arteck Nein, das war auch mein erster Gedanke. Habs nur auf meinem Telefon als App und nur eine Instanz im IOB laufen. Ich warte mal ob sich was ändert wenn die Sperrung aufgehoben ist. Scripte zum Abrufen über Worx habe ich nicht am Laufen, ich nutze nur die States für 2 Sonoff NSPanels. Das sollte aber eigentlich nicht neue Daten abfordern. Wie gesagt ich warte mal die Sperrung ab, bis jetzt läuft er ja trotz Sperrung über meinen Rasen.
                            arteck Developer Most Active @NewPaint2 last edited by
                            @newpaint2 sagte in Adapter Worx Landroid v3.x.x:
                            warum sollte er nicht laufen.. es geht ja nur um den Zugriff auf die Server..
                            • EvilEls
                              EvilEls last edited by
                              Selbes 429 Problem be mir mit v3.2.4
                              Ich glaube aber nicht, dass es am Adapter liegt.
                              Habe Adapter und App ~48h nicht benutzt. Roboter aus.
                              Dann habe ich über App den Mähplan und Rasen geändert um API Zugriffe zu provozieren. Schon beim dritten Versuch die Mähzeiten zu verändern wurde ich geblockt.
                              Kein Adapter an zu der Zeit.
                              Gargano haselchen E 3 Replies Last reply Reply Quote 0
                              • Gargano
                                Gargano @EvilEls last edited by
                                @evilels Hat jemand schon beim Worx Service nachgefragt, ob die etwas geändert haben ?
                                • haselchen
                                  haselchen Most Active @Gargano last edited by haselchen
                                  @gargano
                                  Was sollte das bringen ?
                                  Bei mir läuft alles tutti.
                                  2 mal die App in Benutzung plus Blockly Skript.
                                  Guckt mal bei euch wie @Lucky_ESA schon schrieb, ob da nicht zu viele Abfragen, wo auch immer, bei euch sind.
                                  Oder einfach mal die App oder das Skript 2 Tage unbenutzt lassen.
                                  • haselchen
                                    haselchen Most Active @EvilEls last edited by
                                    @evilels
                                    Das hat ja nix mit dem Adapter zu tun.
                                    Ein App Problem solltest Du mit dem Support klären.
                                      eve11 @EvilEls last edited by eve11
                                      @evilels
                                      Ich konnte dies nun auch nachvollziehen. Ich habe alles bezgl. Worx im IoBroker deaktiviert. Nach 48 Stunden habe ich jetzt die App nur für 1 Minute geöffnet. Nach 2 x aktualisieren in der App bin ich wieder geblockt.
                                      Komisch ist es aber schon, dass dies genau dann aufgetreten ist, nachdem ich von 3.2.2 auf 3.2.3 ein Update installiert habe.
                                        eve11 last edited by eve11
                                        Kennt jemand die Mail Adresse vom Worx App support ?
                                        Vielen Dank
                                        Hat sich erledigt:
                                        app-support@positecgroup.com
                                          Ich habe jetzt mal versucht mich auf der Homepage von Worx anzumelden.
                                          Auf der Arbeit konnte ich mich anmelden nachdem ich von der App geblockt wurde.
                                          Zuhause bekomme ich auch die selbe Fehlermeldung.
                                          Ich habe es versucht auf unterschiedlichen Computern als auch Browser. Immer die selbe Meldung. Ich musste aber nie
                                          meine Anmeldedaten eingeben. Wieso muss ich nirgends im Browser auf der Worx Homepage meine Daten eingeben ?
                                          Wird dies irgendwie von Google synchronisiert ?
                                          Dr. Bakterius L 2 Replies Last reply Reply Quote 0
                                          • Dr. Bakterius
                                            Dr. Bakterius Most Active @eve11 last edited by
                                            @eve11 Möglicherweise ist die IP auf einer Art Sperrliste?
                                            EvilEls 1 Reply Last reply Reply Quote 0
                                            788
                                            123681
