    4. Node-Red
    5. HUE Bewegungsmelder Roborock integr.
      peterfido @Aphofis last edited by
      @aphofis mit myTimeout könnte das so aussehen.
      Mehr mag ich auf dem Mäusekino nicht probieren, zumal Samsung oder Google die Stiftbedienung seit einigen Updates vermurkst haben.
              "id": "a42b83181f07f8d0",
              "type": "tab",
              "label": "Flow 8",
              "disabled": false,
              "info": "",
              "env": []
              "id": "1c8c0acba7c2bff2",
              "type": "inject",
              "z": "a42b83181f07f8d0",
              "name": "Test Bewegung",
              "props": [
                      "p": "payload.motion",
                      "v": "true",
                      "vt": "bool"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Bewegungsmelder",
              "x": 120,
              "y": 60,
              "wires": [
                      "8bf1e5067a6f0ad2",
                      "b0410acfcad1b37e"
              "id": "d1f2c8393ea7f683",
              "type": "debug",
              "name": "debug 3",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "targetType": "full",
              "statusVal": "",
              "statusType": "auto",
              "x": 1640,
              "y": 180,
              "wires": []
              "id": "8bf1e5067a6f0ad2",
              "type": "delay",
              "name": "",
              "pauseType": "delay",
              "timeout": "1",
              "timeoutUnits": "seconds",
              "rate": "1",
              "nbRateUnits": "1",
              "rateUnits": "second",
              "randomFirst": "1",
              "randomLast": "5",
              "randomUnits": "seconds",
              "drop": false,
              "allowrate": false,
              "outputs": 1,
              "x": 120,
              "y": 120,
              "wires": [
                      "a9f9b30b4f8999d0"
              "id": "a9f9b30b4f8999d0",
              "type": "change",
              "name": "motion:false",
              "rules": [
                      "t": "set",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 170,
              "y": 160,
              "wires": [
                      "b0410acfcad1b37e"
              "id": "7a509a8587332f14",
              "type": "switch",
              "name": "Schalter",
              "property": "stopp",
              "propertyType": "flow",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 820,
              "y": 80,
              "wires": [
                      "4d146d05efbc5d35"
              "id": "6adb99e531920623",
              "type": "change",
              "name": "Motion",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "payload.motion",
                      "tot": "msg"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 500,
              "y": 60,
              "wires": [
                      "9f0c88dad82d8633"
              "id": "9f83e7917ef2d8e2",
              "type": "comment",
              "name": "<< Bewegungsmelder |||||||||||||| Simulator  Beginn>>",
              "info": "",
              "x": 220,
              "y": 20,
              "wires": []
              "id": "0762e0ad3da83f0d",
              "type": "inject",
              "name": "Test 1000",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "Schalter_1000",
              "payload": "1000",
              "payloadType": "num",
              "x": 120,
              "y": 280,
              "wires": [
                      "d1051390faa881a3"
              "id": "bd795708de32c118",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "on",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 570,
              "y": 200,
              "wires": [
                      "a6a847c390a23b20"
              "id": "d1051390faa881a3",
              "type": "switch",
              "name": "1000?",
              "property": "payload",
              "propertyType": "msg",
              "rules": [
                      "t": "eq",
                      "v": "1000",
                      "vt": "num"
                      "t": "eq",
                      "v": "",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 290,
              "y": 300,
              "wires": [
                      "91fb51e7bf3d65f7"
              "id": "4d146d05efbc5d35",
              "type": "switch",
              "name": "Robi",
              "property": "BWM",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 950,
              "y": 80,
              "wires": [
                      "9cf97a8724bea369"
              "id": "32b9213c2fe970b0",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "stopp",
                      "pt": "flow",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 820,
              "y": 300,
              "wires": [
              "id": "0439088d7ec73749",
              "type": "change",
              "name": "löscheflow.stopp",
              "rules": [
                      "t": "set",
                      "p": "stopp",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1330,
              "y": 340,
              "wires": [
              "id": "550905a564f09176",
              "type": "function",
              "name": "Variablen Ini + Ausgabe",
              "func": "node.status({ text: msg.payload });\n\nreturn msg;",
              "outputs": 1,
              "timeout": 0,
              "noerr": 0,
              "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\n",
              "finalize": "",
              "libs": [],
              "x": 1490,
              "y": 260,
              "wires": [
                      "d1f2c8393ea7f683",
                      "e2721e4056e942e3"
              "id": "d7bd1efc606cfcad",
              "type": "ioBroker in",
              "name": "ioB Robi",
              "attrname": "payload",
              "topic": "*",
              "payloadType": "value",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "fireOnStart": "false",
              "outFormat": "MQTT",
              "x": 120,
              "y": 560,
              "wires": [
                      "b2f36db79c165583"
              "id": "b0410acfcad1b37e",
              "type": "function",
              "name": "Ausgang BWM",
              "func": "\nreturn msg;",
              "outputs": 1,
              "timeout": 0,
              "noerr": 0,
              "initialize": "",
              "finalize": "",
              "libs": [],
              "x": 320,
              "y": 60,
              "wires": [
                      "6adb99e531920623"
              "id": "e2721e4056e942e3",
              "type": "ioBroker out",
              "name": "ioBroker Lampe",
              "topic": "0_userdata.0.tests.Lampekueche",
              "ack": "false",
              "autoCreate": "true",
              "stateName": "Lampe_Kueche",
              "role": "light",
              "payloadType": "boolean",
              "readonly": "false",
              "stateUnit": "",
              "stateMin": "",
              "stateMax": "",
              "x": 1720,
              "y": 300,
              "wires": []
              "id": "7cfd7f7fba2e2d7a",
              "name": "ioB Schalter",
              "topic": "*",
              "onlyack": "",
              "func": "all",
              "gap": "",
              "x": 110,
              "y": 320,
              "wires": [
                      "d1051390faa881a3"
              "id": "91ef09f531fcc27b",
              "type": "inject",
              "name": "Test Robi = 5",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "5",
              "x": 130,
              "y": 440,
              "wires": [
                      "b2f36db79c165583"
              "id": "6db2cc2617ad5707",
              "type": "inject",
              "name": "Test Robi <> 5",
              "props": [
                      "p": "payload"
                      "p": "topic",
                      "vt": "str"
              "repeat": "",
              "crontab": "",
              "once": false,
              "onceDelay": 0.1,
              "topic": "",
              "payload": "6",
              "x": 130,
              "y": 500,
              "wires": [
                      "b2f36db79c165583"
              "id": "b2f36db79c165583",
              "type": "switch",
              "name": "5?",
              "rules": [
                      "t": "eq",
                      "v": "5",
                      "vt": "num"
                      "t": "neq",
                      "v": "5",
                      "vt": "num"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 310,
              "y": 500,
              "wires": [
                      "407e2e376c0ee370"
                      "5061312f43733426"
              "id": "407e2e376c0ee370",
              "type": "change",
              "name": "setze Flow.BWM",
              "rules": [
                      "t": "set",
                      "p": "BWM",
                      "pt": "flow",
                      "to": "true",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 680,
              "y": 480,
              "wires": [
                      "0650a4ab7aec40a1"
              "id": "5061312f43733426",
              "type": "change",
              "name": "lösche Flow.BWM",
              "rules": [
                      "t": "set",
                      "p": "BWM",
                      "pt": "flow",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 690,
              "y": 520,
              "wires": [
                      "0650a4ab7aec40a1"
              "id": "879b9060efcd163b",
              "type": "comment",
              "name": "evtl. gesperrt durch??",
              "info": "",
              "x": 880,
              "y": 40,
              "wires": []
              "id": "9f0c88dad82d8633",
              "type": "switch",
              "name": "nur true",
              "rules": [
                      "t": "true"
                      "t": "false"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 640,
              "y": 80,
              "wires": [
                      "7a509a8587332f14"
              "id": "0650a4ab7aec40a1",
              "type": "debug",
              "name": "debug 4",
              "active": false,
              "tosidebar": true,
              "console": false,
              "tostatus": false,
              "complete": "true",
              "statusVal": "",
              "x": 900,
              "y": 500,
              "wires": []
              "id": "f144b6f8b998c7f5",
              "type": "comment",
              "name": "<< Bewegungsmelder |||||||||||||| Simulator Ende >>",
              "info": "",
              "x": 220,
              "y": 220,
              "wires": []
              "id": "a6a847c390a23b20",
              "type": "mytimeout",
              "name": "45 sec",
              "outtopic": "",
              "outsafe": "on",
              "outwarning": "Warning",
              "outunsafe": "off",
              "warning": "5",
              "timer": "45",
              "debug": false,
              "ndebug": false,
              "ignoreCase": false,
              "repeat": false,
              "again": false,
              "x": 730,
              "y": 180,
              "wires": [
                      "25e12cdd5eeefe18"
              "id": "442af76f7b9f1d0a",
              "name": "3 sec",
              "outtopic": "",
              "outsafe": "on",
              "outunsafe": "off",
              "warning": "1",
              "timer": "3",
              "debug": false,
              "ndebug": false,
              "repeat": false,
              "again": false,
              "x": 1290,
              "y": 120,
              "wires": [
                      "01e10f79b058e94d"
              "id": "25e12cdd5eeefe18",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "on",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "off",
                      "fromt": "str",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 890,
              "y": 180,
              "wires": [
                      "d5e9baf2e985c341"
              "id": "d5e9baf2e985c341",
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "true"
                      "t": "false"
                      "t": "eq",
                      "v": "",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 3,
              "x": 1150,
              "y": 260,
              "wires": [
                      "550905a564f09176"
                      "550905a564f09176",
                      "0439088d7ec73749"
              "id": "d7c7e0bfb963466c",
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "true"
                      "t": "false"
                      "t": "eq",
                      "v": "",
                      "vt": "str"
              "checkall": "true",
              "repair": false,
              "outputs": 3,
              "x": 1550,
              "y": 40,
              "wires": [
                      "550905a564f09176"
                      "550905a564f09176"
              "id": "01e10f79b058e94d",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "on",
                      "fromt": "str",
                      "to": "true",
                      "tot": "bool"
                      "t": "change",
                      "p": "payload",
                      "pt": "msg",
                      "from": "off",
                      "fromt": "str",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1370,
              "y": 40,
              "wires": [
                      "d7c7e0bfb963466c"
              "id": "9cf97a8724bea369",
              "type": "change",
              "name": "",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "on",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 1130,
              "y": 80,
              "wires": [
                      "442af76f7b9f1d0a"
              "id": "91fb51e7bf3d65f7",
              "type": "ioBroker get",
              "name": "Lampe ist?",
              "errOnInvalidState": "nothing",
              "x": 430,
              "y": 300,
              "wires": [
                      "e1bc32d82926ab1a"
              "id": "e1bc32d82926ab1a",
              "type": "switch",
              "name": "",
              "rules": [
                      "t": "false"
                      "t": "true"
              "checkall": "true",
              "repair": false,
              "outputs": 2,
              "x": 570,
              "y": 360,
              "wires": [
                      "32b9213c2fe970b0",
                      "bd795708de32c118"
                      "407e2e376c0ee370",
                      "0439088d7ec73749",
                      "f8efa184517f5926",
                      "5ff36fd59f9b86a7"
              "id": "f8efa184517f5926",
              "type": "change",
              "name": "Alles auf Anfang",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "false",
                      "tot": "bool"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 880,
              "y": 420,
              "wires": [
                      "550905a564f09176"
              "id": "5ff36fd59f9b86a7",
              "type": "change",
              "name": "stop",
              "rules": [
                      "t": "set",
                      "p": "payload",
                      "pt": "msg",
                      "to": "stop",
                      "tot": "str"
              "action": "",
              "property": "",
              "from": "",
              "to": "",
              "reg": false,
              "x": 650,
              "y": 260,
              "wires": [
                      "a6a847c390a23b20",
                      "442af76f7b9f1d0a"
      Daher bitte selbst probieren und tüfteln, falls was nicht so läuft, wie gewollt.
      Aphofis 2 Replies Last reply Reply Quote 0
      • Aphofis
        Aphofis @peterfido last edited by
        @peterfido
        Also vielleicht mal die ganze Steuerung
        Philips Hue Schalter schaltet nur 1000/2000/3000/4000
        Dieses wird per virtuellen Schaltern realisiert
        Damit das überhaupt klappt mit an aus mit einem Befehl
        Sprich Schalter hat nicht true/false sondern nur 1000
        Wobei der Wert nach 200ms ca umschaltet auf 1002 was aber ignoriert wird.
        Die anderen drei Button werden für andere hue Lampen genutzt.
        Die Bewegungsmelder sollen die küchenbeleuchtung einschalten und nach 3 min. Ausschalten ist der Roboter unterwegs sprich nicht auf der ladestation sollen die BWM abgeschaltet werden. Wenn ich den Lichtschalter betätige soll dieser nach 45 min. Abgeschaltet werden sollte ich das Licht mal vergessen.
        Ist schon im Bad passiert und ist ja unnötig Strom Verbrauch. Weil wenn ich den Lichtschalter benutze soll das Licht schon an bleiben. Wäre nicht nötig wenn der BWM bei Wiederbewegung funktionieren würde
        Dazu muss denke ich aber die True/false Schaltung
        Träge gemacht werden. Dann würde die 45 min. Schaltung unnötig
        • Aphofis
          @peterfido
          Ich werde tüfteln
          • Aphofis
            @peterfido
            Scheint alles zu funktionieren. Nur Wiederbewegung hatte ich noch nicht getestet ob das Licht dann an bleibt oder erstmal aus geht und dann wieder eingeschaltet wird.
            Aber an sich tolle Steuerung. Wie und wo kann man sowas bloß lernen und dann auch noch auf einem Mäusekino. Ich sage mal Vielen vielen Dank.
            Aphofis 1 Reply Last reply Reply Quote 0
            • Aphofis
              Aphofis @Aphofis last edited by Aphofis
              So siehts jetzt aus und scheint zu laufen.
              Wie gesagt bis auf die wiederbewegung klappt nicht.
              Ganz ehrlich gesagt, ich wüsste nicht mal wo ich da ansetzen soll um die schaltung träge zu machen damit nicht beim BWM auf jedes false zwischen den true reagiert wird sondern wenn keine Ahnung wenn wirklich 10 sek zB. false ist das dann erst ein false gesendet wird
              Hab jetzt die Steuerung in Küche und Bad integriert und bin so auch erstmal zufrieden. nur die Wiederbewegung ist halt etwas doof das dass nicht klappt. Ist aber in Öffentlichen Toiletten und Restaurants auch so das bei einer Sitzung das Licht einmal aus geht und erst wenn man sich bewegt das Licht wieder an geht. Ganz schlecht ist es nur wenn nicht jedes Klo einen BWM hat und man mit Handy Taschenlampe die Sitzung beenden muss. Da ist es so zumindest schon mal ein Anfang.
                      "id": "b802892eed83e90f",
                      "type": "tab",
                      "label": "Flow 8",
                      "disabled": false,
                      "info": "",
                      "env": []
                      "id": "f00e20abd94ff43d",
                      "type": "junction",
                      "z": "b802892eed83e90f",
                      "x": 960,
                      "y": 320,
                      "wires": [
                              "141a052859674836",
                              "574a9f7ddc4f663b"
                      "id": "423ea0f1dc0e4d31",
                      "type": "junction",
                      "x": 1440,
                      "y": 300,
                      "wires": [
                              "ff32f89078260f0e",
                              "67e2e01a1266d1c3",
                              "e98816534075b0f5",
                              "21f36ea2695afe19",
                              "a695276a00fe8f61"
                      "id": "a2104cdffd7ca75f",
                      "type": "inject",
                      "props": [
                              "v": "true",
                              "vt": "bool"
                              "p": "topic",
                              "vt": "str"
                      "repeat": "",
                      "crontab": "",
                      "once": false,
                      "onceDelay": 0.1,
                      "x": 120,
                      "y": 60,
                      "wires": [
                              "a919a4c30d900c39",
                              "0150c15cf7b51170"
                      "id": "ed06e85de97289c8",
                      "type": "debug",
                      "name": "debug 3",
                      "active": false,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "complete": "true",
                      "statusVal": "",
                      "x": 1620,
                      "y": 140,
                      "wires": []
                      "id": "a919a4c30d900c39",
                      "type": "delay",
                      "name": "",
                      "timeout": "1",
                      "rate": "1",
                      "nbRateUnits": "1",
                      "randomFirst": "1",
                      "randomLast": "5",
                      "drop": false,
                      "allowrate": false,
                      "outputs": 1,
                      "x": 380,
                      "y": 140,
                      "wires": [
                              "bee64eb116d76ed1"
                      "id": "bee64eb116d76ed1",
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 390,
                      "y": 100,
                      "wires": [
                              "0150c15cf7b51170"
                      "id": "ab41883686b27cc0",
                      "type": "switch",
                      "name": "Schalter",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 860,
                      "y": 80,
                      "wires": [
                              "01fea99b98c641a3"
                      "id": "0395e4bbb7c67e21",
                      "type": "change",
                      "name": "Motion",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "tot": "msg"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 590,
                      "y": 80,
                      "wires": [
                              "d24a5429e472b18a"
                      "id": "59792b228df9eb30",
                      "type": "comment",
                      "info": "",
                      "x": 220,
                      "y": 20,
                      "wires": []
                      "id": "93f0d4c85ab42e59",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "on",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 590,
                      "y": 160,
                      "wires": [
                              "ed2607cafe826532"
                      "id": "e22b60db6265e908",
                      "type": "switch",
                      "name": "1000?",
                      "rules": [
                              "t": "eq",
                              "v": "1000",
                              "vt": "num"
                              "t": "eq",
                              "v": "",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 210,
                      "y": 320,
                      "wires": [
                              "6ae2e0e61f81faeb"
                      "id": "01fea99b98c641a3",
                      "type": "switch",
                      "name": "Robi",
                      "property": "BWM",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 990,
                      "y": 80,
                      "wires": [
                              "ba0aea0ff71ebc3d"
                      "id": "7eea52e80cbe51f0",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 680,
                      "y": 220,
                      "wires": [
                      "id": "574a9f7ddc4f663b",
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "stopp",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1280,
                      "y": 300,
                      "wires": [
                      "id": "331a07cfba2d7df1",
                      "type": "function",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "finalize": "",
                      "libs": [],
                      "x": 1410,
                      "y": 180,
                      "wires": [
                              "ed06e85de97289c8",
                              "423ea0f1dc0e4d31"
                      "id": "b9692c9131fb2ef5",
                      "name": "Robi",
                      "topic": "mihome-vacuum.0.info.state",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 50,
                      "y": 380,
                      "wires": [
                              "6b214a0a59b5e04a"
                      "id": "0150c15cf7b51170",
                      "type": "function",
                      "outputs": 1,
                      "timeout": 0,
                      "noerr": 0,
                      "initialize": "",
                      "finalize": "",
                      "libs": [],
                      "x": 440,
                      "y": 60,
                      "wires": [
                              "0395e4bbb7c67e21"
                      "id": "b6b4c157c31e3701",
                      "name": "KüSchalter",
                      "topic": "hue.0.Hue_GordonX.Küche_Schalter.buttonevent",
                      "onlyack": "",
                      "func": "all",
                      "gap": "",
                      "x": 60,
                      "y": 320,
                      "wires": [
                              "e22b60db6265e908"
                      "id": "6b214a0a59b5e04a",
                      "type": "switch",
                      "name": "8?",
                      "rules": [
                              "t": "eq",
                              "v": "8",
                              "vt": "num"
                              "t": "neq",
                              "v": "8",
                              "vt": "num"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 650,
                      "y": 380,
                      "wires": [
                              "7b9c0fa6e795af2d"
                              "ccadbb1ee1de29e6"
                      "id": "7b9c0fa6e795af2d",
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "BWM",
                              "pt": "flow",
                              "to": "true",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 810,
                      "y": 360,
                      "wires": [
                              "b117dac109d51b34"
                      "id": "ccadbb1ee1de29e6",
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "BWM",
                              "pt": "flow",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 810,
                      "y": 400,
                      "wires": [
                              "b117dac109d51b34"
                      "id": "558db419c5c37cca",
                      "type": "comment",
                      "info": "",
                      "x": 860,
                      "y": 40,
                      "wires": []
                      "id": "d24a5429e472b18a",
                      "type": "switch",
                      "name": "nur true",
                      "rules": [
                              "t": "true"
                              "t": "false"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 720,
                      "y": 80,
                      "wires": [
                              "ab41883686b27cc0"
                      "id": "b117dac109d51b34",
                      "type": "debug",
                      "name": "debug 4",
                      "active": false,
                      "tosidebar": true,
                      "console": false,
                      "tostatus": false,
                      "complete": "true",
                      "statusVal": "",
                      "x": 1100,
                      "y": 380,
                      "wires": []
                      "id": "d64f728f4f574f51",
                      "type": "comment",
                      "info": "",
                      "x": 190,
                      "y": 280,
                      "wires": []
                      "id": "91febc7692f9b822",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "on",
                              "fromt": "str",
                              "to": "true",
                              "tot": "bool"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "off",
                              "fromt": "str",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 930,
                      "y": 140,
                      "wires": [
                              "d303b6e1817d8b77"
                      "id": "d303b6e1817d8b77",
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "true"
                              "t": "false"
                              "t": "eq",
                              "v": "",
                              "vt": "str"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 1090,
                      "y": 120,
                      "wires": [
                              "331a07cfba2d7df1"
                              "331a07cfba2d7df1",
                              "574a9f7ddc4f663b"
                      "id": "b4e55cb04c30244e",
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "true"
                              "t": "false"
                              "t": "eq",
                              "v": "",
                              "vt": "str"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 3,
                      "x": 1630,
                      "y": 60,
                      "wires": [
                              "331a07cfba2d7df1"
                              "331a07cfba2d7df1"
                      "id": "90c9685b4a5344dc",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "on",
                              "fromt": "str",
                              "to": "true",
                              "tot": "bool"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "off",
                              "fromt": "str",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1470,
                      "y": 60,
                      "wires": [
                              "b4e55cb04c30244e"
                      "id": "ba0aea0ff71ebc3d",
                      "type": "change",
                      "name": "",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "on",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1150,
                      "y": 60,
                      "wires": [
                              "fa5f2b5bcd258a98"
                      "id": "6ae2e0e61f81faeb",
                      "name": "Virtuelle Lampe",
                      "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                      "x": 460,
                      "y": 320,
                      "wires": [
                              "cf3016a536d38a8d"
                      "id": "cf3016a536d38a8d",
                      "type": "switch",
                      "name": "",
                      "rules": [
                              "t": "false"
                              "t": "true"
                      "checkall": "true",
                      "repair": false,
                      "outputs": 2,
                      "x": 650,
                      "y": 320,
                      "wires": [
                              "7eea52e80cbe51f0",
                              "93f0d4c85ab42e59"
                              "7b9c0fa6e795af2d",
                              "87ec46662c49de4e",
                              "f00e20abd94ff43d"
                      "id": "141a052859674836",
                      "type": "change",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "false",
                              "tot": "bool"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1280,
                      "y": 340,
                      "wires": [
                              "331a07cfba2d7df1"
                      "id": "87ec46662c49de4e",
                      "type": "change",
                      "name": "stop",
                      "rules": [
                              "t": "set",
                              "p": "payload",
                              "pt": "msg",
                              "to": "stop",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 930,
                      "y": 280,
                      "wires": [
                              "ed2607cafe826532",
                              "fa5f2b5bcd258a98"
                      "id": "ed2607cafe826532",
                      "name": "45min.",
                      "outtopic": "",
                      "outsafe": "on",
                      "outunsafe": "off",
                      "warning": "10",
                      "timer": "2700",
                      "debug": false,
                      "ndebug": false,
                      "repeat": false,
                      "again": false,
                      "x": 770,
                      "y": 160,
                      "wires": [
                              "91febc7692f9b822"
                      "id": "fa5f2b5bcd258a98",
                      "name": "3Min.",
                      "outtopic": "",
                      "outsafe": "on",
                      "outunsafe": "off",
                      "warning": "10",
                      "timer": "180",
                      "debug": false,
                      "ndebug": false,
                      "repeat": false,
                      "again": false,
                      "x": 1310,
                      "y": 100,
                      "wires": [
                              "90c9685b4a5344dc"
                      "id": "802770af38c8534e",
                      "type": "hue-bridge-node",
                      "name": "Hue",
                      "bridge": "cbd54dbabf6f65be",
                      "autoupdates": true,
                      "skipglobalevents": false,
                      "initevents": false,
                      "x": 90,
                      "y": 220,
                      "wires": [
                              "2e0c2a67486c0ac7"
                      "id": "2e0c2a67486c0ac7",
                      "type": "hue-motion",
                      "name": "Küche Motion Sensor",
                      "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                      "skipevents": false,
                      "initevents": true,
                      "x": 140,
                      "y": 140,
                      "wires": [
                              "a919a4c30d900c39",
                              "0150c15cf7b51170"
                      "id": "21f36ea2695afe19",
                      "name": "U-rechts",
                      "topic": "tuya.0.bfb09eea5dad3699abyrbu.20",
                      "ack": "false",
                      "autoCreate": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1600,
                      "y": 360,
                      "wires": []
                      "id": "084e7114b7ed1c61",
                      "name": "Küche Decke",
                      "topic": "tuya.0.bfe4af976feb74d845vugp.1",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1730,
                      "y": 240,
                      "wires": []
                      "id": "ff32f89078260f0e",
                      "name": "Virtuel Switch 1",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1620,
                      "y": 300,
                      "wires": []
                      "id": "442c2ef743d9599f",
                      "type": "debug",
                      "name": "Küche",
                      "active": true,
                      "tosidebar": true,
                      "console": true,
                      "tostatus": false,
                      "complete": "payload",
                      "targetType": "msg",
                      "statusVal": "",
                      "x": 1620,
                      "y": 520,
                      "wires": []
                      "id": "67e2e01a1266d1c3",
                      "type": "delay",
                      "name": "100ms",
                      "timeout": "100",
                      "timeoutUnits": "milliseconds",
                      "rate": "1",
                      "nbRateUnits": "1",
                      "randomFirst": "1",
                      "randomLast": "5",
                      "drop": false,
                      "allowrate": false,
                      "outputs": 1,
                      "x": 1590,
                      "y": 240,
                      "wires": [
                              "084e7114b7ed1c61"
                      "id": "e98816534075b0f5",
                      "type": "change",
                      "name": "Küche",
                      "rules": [
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "1000",
                              "fromt": "str",
                              "to": "Küche",
                              "tot": "str"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "true",
                              "fromt": "bool",
                              "to": "Küche eingeschaltet",
                              "tot": "str"
                              "t": "change",
                              "p": "payload",
                              "pt": "msg",
                              "from": "false",
                              "fromt": "bool",
                              "to": "Küche ausgeschaltet",
                              "tot": "str"
                      "action": "",
                      "property": "",
                      "from": "",
                      "to": "",
                      "reg": false,
                      "x": 1490,
                      "y": 520,
                      "wires": [
                              "442c2ef743d9599f"
                      "id": "a695276a00fe8f61",
                      "name": "U-links",
                      "topic": "hue.0.Hue_GordonX.Küche_Unterschr_Links.on",
                      "ack": "false",
                      "stateName": "",
                      "role": "",
                      "payloadType": "",
                      "readonly": "",
                      "stateUnit": "",
                      "stateMin": "",
                      "stateMax": "",
                      "x": 1590,
                      "y": 440,
                      "wires": []
                      "id": "cbd54dbabf6f65be",
                      "type": "hue-bridge",
                      "name": "Hue GordonX",
                      "bridge": "192.168.0.8",
                      "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                      "worker": "10",
                      "disableupdates": false
                @aphofis Wenn Du die Laufzeit des Bewegungsmelders mit berücksichtigen möchtest, dann muss diese zyklisch abgefragt werden, und kommt dann zu der Laufzeit von drei Minuten dazu.
                       "type": "tab",
                       "label": "Flow 8",
                       "disabled": false,
                       "info": "",
                       "env": []
                       "type": "junction",
                       "x": 1120,
                       "y": 660,
                       "wires": [
                               "141a052859674836",
                               "574a9f7ddc4f663b",
                               "b6322a40cf4557b3"
                       "type": "junction",
                       "x": 1960,
                       "y": 460,
                       "wires": [
                               "ff32f89078260f0e",
                               "67e2e01a1266d1c3",
                               "e98816534075b0f5",
                               "21f36ea2695afe19",
                               "a695276a00fe8f61"
                       "id": "ae8ceff406113f11",
                       "type": "junction",
                       "x": 1140,
                       "y": 260,
                       "wires": [
                               "ba0aea0ff71ebc3d"
                       "id": "256e4df028333ee3",
                       "type": "junction",
                       "x": 580,
                       "y": 60,
                       "wires": [
                               "6ae2e0e61f81faeb"
                       "id": "9c7c62ee37b6b12c",
                       "type": "junction",
                       "x": 540,
                       "y": 120,
                       "wires": [
                               "d24a5429e472b18a"
                       "id": "d96f128a59bdfbb4",
                       "type": "junction",
                       "x": 900,
                       "y": 440,
                       "wires": [
                               "84bd4ea1d044fea4",
                               "ed2607cafe826532"
                       "id": "84bd4ea1d044fea4",
                       "type": "junction",
                       "x": 980,
                       "y": 360,
                       "wires": [
                               "be66da991b562e24"
                       "id": "be66da991b562e24",
                       "type": "junction",
                       "x": 1280,
                       "y": 360,
                       "wires": [
                               "fa5f2b5bcd258a98"
                       "type": "inject",
                       "props": [
                               "v": "true",
                               "vt": "bool"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "x": 140,
                       "y": 380,
                       "wires": [
                               "a919a4c30d900c39",
                               "0150c15cf7b51170"
                       "type": "debug",
                       "name": "debug 3",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "statusVal": "",
                       "x": 2000,
                       "y": 360,
                       "wires": []
                       "type": "delay",
                       "name": "",
                       "timeout": "10",
                       "rate": "1",
                       "nbRateUnits": "1",
                       "randomFirst": "1",
                       "randomLast": "5",
                       "drop": false,
                       "allowrate": false,
                       "outputs": 1,
                       "x": 150,
                       "y": 460,
                       "wires": [
                               "bee64eb116d76ed1"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "pt": "msg",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 350,
                       "y": 460,
                       "wires": [
                               "0150c15cf7b51170"
                       "type": "switch",
                       "name": "Schalter",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 920,
                       "y": 260,
                       "wires": [
                               "01fea99b98c641a3"
                       "type": "change",
                       "name": "Motion",
                       "rules": [
                               "t": "set",
                               "p": "bewegung",
                               "pt": "flow",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 670,
                       "y": 320,
                       "wires": [
                       "type": "comment",
                       "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Beginn>>",
                       "info": "",
                       "x": 270,
                       "y": 300,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "on",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 710,
                       "y": 400,
                       "wires": [
                               "ed2607cafe826532"
                       "type": "switch",
                       "name": "1000?",
                       "rules": [
                               "t": "eq",
                               "v": "1000",
                               "vt": "num"
                               "t": "eq",
                               "v": "",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 250,
                       "y": 660,
                       "wires": [
                               "35f7a8f381fdb099"
                       "type": "switch",
                       "name": "Robi",
                       "property": "BWM",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 1050,
                       "y": 260,
                       "wires": [
                               "ae8ceff406113f11"
                       "type": "change",
                       "name": "setze stopp",
                       "rules": [
                               "t": "set",
                               "p": "stopp",
                               "pt": "flow",
                               "to": "true",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 890,
                       "y": 600,
                       "wires": [
                       "type": "change",
                       "name": "lösche stopp",
                       "rules": [
                               "t": "set",
                               "p": "stopp",
                               "pt": "flow",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1370,
                       "y": 600,
                       "wires": [
                       "type": "function",
                       "func": "node.status({ text: msg.payload });\n\n// Für Tests Beginn\nflow.set(\"lampe_ist\", msg.payload); // Zeile für Normalbetrieb auskommentieren\n// Für Tests Ende\n\nreturn msg;",
                       "outputs": 1,
                       "timeout": 0,
                       "noerr": 0,
                       "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\nflow.set(\"lampe_ist\", false);\n",
                       "finalize": "",
                       "libs": [],
                       "x": 1770,
                       "y": 380,
                       "wires": [
                               "ed06e85de97289c8",
                               "423ea0f1dc0e4d31"
                       "name": "Robi",
                       "onlyack": "",
                       "func": "all",
                       "gap": "",
                       "x": 90,
                       "y": 780,
                       "wires": [
                               "6b214a0a59b5e04a"
                       "type": "function",
                       "outputs": 1,
                       "timeout": 0,
                       "noerr": 0,
                       "initialize": "",
                       "finalize": "",
                       "libs": [],
                       "x": 360,
                       "y": 360,
                       "wires": [
                               "0395e4bbb7c67e21"
                       "onlyack": "",
                       "func": "all",
                       "gap": "",
                       "x": 100,
                       "y": 680,
                       "wires": [
                               "e22b60db6265e908"
                       "type": "switch",
                       "name": "8?",
                       "rules": [
                               "t": "eq",
                               "v": "8",
                               "vt": "num"
                               "t": "neq",
                               "v": "8",
                               "vt": "num"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 630,
                       "y": 780,
                       "wires": [
                               "7b9c0fa6e795af2d"
                               "ccadbb1ee1de29e6"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "BWM",
                               "pt": "flow",
                               "to": "true",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 850,
                       "y": 760,
                       "wires": [
                               "b117dac109d51b34"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "BWM",
                               "pt": "flow",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 850,
                       "y": 800,
                       "wires": [
                               "b117dac109d51b34"
                       "type": "comment",
                       "name": "evtl. gesperrt durch?? Beginn",
                       "info": "",
                       "x": 980,
                       "y": 220,
                       "wires": []
                       "type": "switch",
                       "name": "nur true",
                       "rules": [
                               "t": "true"
                               "t": "false"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 740,
                       "y": 240,
                       "wires": [
                               "ab41883686b27cc0"
                       "type": "debug",
                       "name": "debug 4",
                       "active": false,
                       "tosidebar": true,
                       "console": false,
                       "tostatus": false,
                       "complete": "true",
                       "statusVal": "",
                       "x": 1040,
                       "y": 760,
                       "wires": []
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "on",
                               "fromt": "str",
                               "to": "true",
                               "tot": "bool"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "off",
                               "fromt": "str",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1290,
                       "y": 400,
                       "wires": [
                               "d303b6e1817d8b77"
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "true"
                               "t": "false"
                               "t": "eq",
                               "v": "",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 3,
                       "x": 1470,
                       "y": 400,
                       "wires": [
                               "331a07cfba2d7df1"
                               "331a07cfba2d7df1",
                               "574a9f7ddc4f663b"
                       "type": "switch",
                       "name": "",
                       "rules": [
                               "t": "true"
                               "t": "false"
                               "t": "eq",
                               "v": "",
                               "vt": "str"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 3,
                       "x": 1770,
                       "y": 260,
                       "wires": [
                               "331a07cfba2d7df1"
                               "331a07cfba2d7df1"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "on",
                               "fromt": "str",
                               "to": "true",
                               "tot": "bool"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "off",
                               "fromt": "str",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1610,
                       "y": 260,
                       "wires": [
                               "b4e55cb04c30244e"
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "on",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1250,
                       "y": 260,
                       "wires": [
                               "fa5f2b5bcd258a98"
                       "x": 760,
                       "y": 100,
                       "wires": [
                               "dc4b3ed2e3d1a857"
                       "type": "switch",
                       "name": "true false",
                       "rules": [
                               "t": "false"
                               "t": "true"
                       "checkall": "true",
                       "repair": false,
                       "outputs": 2,
                       "x": 680,
                       "y": 660,
                       "wires": [
                               "7eea52e80cbe51f0",
                               "93f0d4c85ab42e59"
                               "7b9c0fa6e795af2d",
                               "87ec46662c49de4e",
                               "f00e20abd94ff43d"
                       "type": "change",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1380,
                       "y": 640,
                       "wires": [
                               "331a07cfba2d7df1"
                       "type": "change",
                       "name": "stop",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "stop",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1010,
                       "y": 640,
                       "wires": [
                               "d96f128a59bdfbb4"
                       "name": "45sek",
                       "outtopic": "",
                       "outsafe": "on",
                       "outunsafe": "off",
                       "warning": "10",
                       "timer": "45",
                       "debug": false,
                       "ndebug": false,
                       "repeat": false,
                       "again": false,
                       "x": 1090,
                       "y": 400,
                       "wires": [
                               "91febc7692f9b822"
                       "name": "10Sek",
                       "outtopic": "",
                       "outsafe": "on",
                       "outunsafe": "off",
                       "warning": "10",
                       "timer": "10",
                       "debug": false,
                       "ndebug": false,
                       "repeat": false,
                       "again": false,
                       "x": 1430,
                       "y": 260,
                       "wires": [
                               "90c9685b4a5344dc"
                       "name": "U-rechts",
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2140,
                       "y": 600,
                       "wires": []
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2210,
                       "y": 460,
                       "wires": []
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2160,
                       "y": 540,
                       "wires": []
                       "type": "debug",
                       "name": "Küche",
                       "active": true,
                       "tosidebar": true,
                       "console": true,
                       "tostatus": false,
                       "statusVal": "",
                       "x": 2160,
                       "y": 760,
                       "wires": []
                       "type": "delay",
                       "name": "100ms",
                       "timeout": "100",
                       "rate": "1",
                       "nbRateUnits": "1",
                       "randomFirst": "1",
                       "randomLast": "5",
                       "drop": false,
                       "allowrate": false,
                       "outputs": 1,
                       "x": 2070,
                       "y": 460,
                       "wires": [
                               "084e7114b7ed1c61"
                       "type": "change",
                       "name": "Küche",
                       "rules": [
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "1000",
                               "fromt": "str",
                               "to": "Küche",
                               "tot": "str"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "true",
                               "fromt": "bool",
                               "tot": "str"
                               "t": "change",
                               "p": "payload",
                               "pt": "msg",
                               "from": "false",
                               "fromt": "bool",
                               "tot": "str"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 2030,
                       "y": 760,
                       "wires": [
                               "442c2ef743d9599f"
                       "name": "U-links",
                       "ack": "false",
                       "stateName": "",
                       "role": "",
                       "payloadType": "",
                       "readonly": "",
                       "stateUnit": "",
                       "stateMin": "",
                       "stateMax": "",
                       "x": 2130,
                       "y": 680,
                       "wires": []
                       "name": "Hue",
                       "x": 130,
                       "y": 160,
                       "wires": [
                               "2e0c2a67486c0ac7"
                       "initevents": true,
                       "x": 360,
                       "y": 160,
                       "wires": [
                               "0395e4bbb7c67e21"
                       "id": "83e1205cab7afd75",
                       "type": "inject",
                       "name": "Takt",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "1",
                       "crontab": "",
                       "once": true,
                       "onceDelay": 0.1,
                       "topic": "Takt",
                       "payload": "true",
                       "payloadType": "bool",
                       "x": 130,
                       "y": 60,
                       "wires": [
                               "26a06677287b879b",
                               "256e4df028333ee3"
                       "id": "26a06677287b879b",
                       "type": "change",
                       "name": "",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "bewegung",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 350,
                       "y": 120,
                       "wires": [
                               "9c7c62ee37b6b12c"
                       "id": "c8bd53de95a27a58",
                       "type": "inject",
                       "name": "Test Schalter",
                       "props": [
                               "p": "payload"
                               "p": "topic",
                               "vt": "str"
                       "repeat": "",
                       "crontab": "",
                       "once": false,
                       "onceDelay": 0.1,
                       "topic": "",
                       "payload": "1000",
                       "x": 130,
                       "y": 600,
                       "wires": [
                               "e22b60db6265e908"
                       "id": "b6322a40cf4557b3",
                       "type": "change",
                       "name": "lösche bewegung",
                       "rules": [
                               "t": "set",
                               "p": "bewegung",
                               "pt": "flow",
                               "to": "false",
                               "tot": "bool"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 1390,
                       "y": 680,
                       "wires": [
                       "id": "35f7a8f381fdb099",
                       "type": "change",
                       "name": "lichtan?",
                       "rules": [
                               "t": "set",
                               "p": "payload",
                               "pt": "msg",
                               "to": "lampe_ist",
                               "tot": "flow"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 460,
                       "y": 660,
                       "wires": [
                               "cf3016a536d38a8d"
                       "id": "dc4b3ed2e3d1a857",
                       "type": "change",
                       "name": "Motion",
                       "rules": [
                               "t": "set",
                               "p": "lampe_ist",
                               "pt": "flow",
                               "to": "payload",
                               "tot": "msg"
                       "action": "",
                       "property": "",
                       "from": "",
                       "to": "",
                       "reg": false,
                       "x": 910,
                       "y": 100,
                       "wires": [
                       "id": "704f9134130a0c13",
                       "type": "comment",
                       "name": "Nötig für Simulation, da kein Tuya Ende",
                       "info": "",
                       "x": 830,
                       "y": 160,
                       "wires": []
                       "id": "105d29d40a2b08f3",
                       "type": "comment",
                       "name": "Nötig für Simulation, da kein Tuya Beginn",
                       "info": "",
                       "x": 840,
                       "y": 40,
                       "wires": []
                       "id": "2e246cc32c852ec4",
                       "type": "comment",
                       "name": "Nötig für Simulation, da kein Tuya",
                       "info": "",
                       "x": 470,
                       "y": 620,
                       "wires": []
                       "id": "5d18e186acebf108",
                       "type": "comment",
                       "info": "",
                       "x": 470,
                       "y": 720,
                       "wires": []
                       "id": "4208dd4576daa563",
                       "type": "comment",
                       "name": "<< Bewegungsmelder |||||||||||||| Simulator da kein Hue  Ende>>",
                       "info": "",
                       "x": 260,
                       "y": 520,
                       "wires": []
                       "id": "f6fea6b16f9005b0",
                       "type": "comment",
                       "name": "evtl. gesperrt durch?? Ende",
                       "info": "",
                       "x": 980,
                       "y": 320,
                       "wires": []
                       "worker": "10",
                • Aphofis
                  Aphofis @peterfido last edited by Aphofis
                  @peterfido
                  Mit der neuen Schaltung kann man per HUE schalter einmal zweimal klick nicht das licht ein und ausschalten es geht nur einschalten einschalten.
                  Das war in der vorherigen Schaltung korrekt da war jeder klick auf den schalter ein aus ein aus schalten.
                    @aphofis Guck Dir mal die Function genauer an. Da ist ein Bemerkungstext drin, dass eine Zeile auskommentiert werden soll, wenn es produktiv genutzt wird. Evtl. war es das dann schon. Ich habe die Hardware nicht da, und habe daher die Lampe mit der Function simuliert.
                    Es ist nicht einfach, da was zu "testen", was man nicht hat.
                    • Aphofis
                      @peterfido
                      Du meinst in der Variable !?
                      flow.set("lampe_ist", msg.payload);
                      Hatte ich auskommentiert, geht dann aber trotzdem nicht.
                        @aphofis Da kommt dann die Fehlersuche. Also ein Node, z.B. den vom Bewegungsmelder deaktivieren, und schauen, ob es dann in der Simulation läuft. Man kann auch das Topic setzen und am Ende auswerten, wer die Lampe eingeschaltet hat.
                        Die Abfrage der Lampe_ist kann auch von oben wieder weg und nach unten als Ersatz für den von mir mit "kein Tuya" 'eingerahmten' Block.
                        • Aphofis
                          @peterfido
                          Also es funktioniert soweit, doch wenn der Roboter status 5 hat und man in den BWM läuft geht trotzdem das Licht an und wenn man es dann per Schalter ausschalten will, muss man das 3-4 mal machen bis das licht aus bleibt. Wie man jetzt herausfindet wer nun das licht schaltet weiß ich nicht.
                                  "id": "a4c8574588c0de3c",
                                  "type": "change",
                                  "z": "f40fbc4eb5ac4f7a",
                                  "rules": [
                                          "t": "set",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 450,
                                  "y": 540,
                                  "wires": [
                                          "169c9cd74337485f"
                                  "id": "f6bc1b429099ca57",
                                  "type": "switch",
                                  "name": "Schalter",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 800,
                                  "y": 500,
                                  "wires": [
                                          "ee120a8678492945"
                                  "id": "f2bfa3e6a90d48ed",
                                  "type": "change",
                                  "name": "Motion",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "tot": "msg"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 610,
                                  "y": 500,
                                  "wires": [
                                          "a7c05960eac63d95"
                                  "id": "8803280db34eb22b",
                                  "type": "comment",
                                  "name": "Bewegungsmelder Simulator  Beginn",
                                  "info": "",
                                  "x": 160,
                                  "y": 420,
                                  "wires": []
                                  "id": "5925b1db569c695b",
                                  "type": "change",
                                  "name": "payload",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "on",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 620,
                                  "y": 540,
                                  "wires": [
                                          "5f9435538ec534ed"
                                  "id": "95fda7a91b84c03f",
                                  "type": "switch",
                                  "name": "1000?",
                                  "rules": [
                                          "t": "eq",
                                          "v": "1000",
                                          "vt": "num"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "num"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 250,
                                  "y": 600,
                                  "wires": [
                                          "ee5a65e2896d189b"
                                  "id": "ee120a8678492945",
                                  "type": "switch",
                                  "name": "Robi",
                                  "property": "BWM",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 810,
                                  "y": 460,
                                  "wires": [
                                          "8f4fcec5a545127f"
                                  "id": "3648551e97ec2cab",
                                  "type": "change",
                                  "name": "flow/stop",
                                  "rules": [
                                          "t": "set",
                                          "p": "stopp",
                                          "pt": "flow",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 620,
                                  "y": 580,
                                  "wires": [
                                  "id": "a8b609cc983f0b37",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "stopp",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1220,
                                  "y": 520,
                                  "wires": [
                                  "id": "0e43213215238d27",
                                  "type": "function",
                                  "name": "Variab.Ini + Ausg.",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "finalize": "",
                                  "libs": [],
                                  "x": 1430,
                                  "y": 460,
                                  "wires": [
                                          "f1be18a24ca143f6"
                                  "id": "6500453922363ac9",
                                  "name": "Robi",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 370,
                                  "y": 700,
                                  "wires": [
                                          "81fd4c871d668d04"
                                  "id": "169c9cd74337485f",
                                  "type": "function",
                                  "name": "Ausg.BWM",
                                  "outputs": 1,
                                  "timeout": 0,
                                  "noerr": 0,
                                  "initialize": "",
                                  "finalize": "",
                                  "libs": [],
                                  "x": 450,
                                  "y": 500,
                                  "wires": [
                                          "f2bfa3e6a90d48ed"
                                  "id": "c6d6a47028727285",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 80,
                                  "y": 600,
                                  "wires": [
                                          "95fda7a91b84c03f"
                                  "id": "81fd4c871d668d04",
                                  "type": "switch",
                                  "name": "8?",
                                  "rules": [
                                          "t": "eq",
                                          "v": "8",
                                          "vt": "num"
                                          "t": "neq",
                                          "v": "8",
                                          "vt": "num"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 490,
                                  "y": 680,
                                  "wires": [
                                          "638dc14da90f5eb4"
                                          "542b940ecfefa127"
                                  "id": "638dc14da90f5eb4",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "BWM",
                                          "pt": "flow",
                                          "to": "true",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 650,
                                  "y": 660,
                                  "wires": [
                                          "3803f5607daeb485"
                                  "id": "542b940ecfefa127",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "BWM",
                                          "pt": "flow",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 650,
                                  "y": 700,
                                  "wires": [
                                          "3803f5607daeb485"
                                  "id": "2bb3725204a30905",
                                  "type": "comment",
                                  "info": "",
                                  "x": 800,
                                  "y": 380,
                                  "wires": []
                                  "id": "a7c05960eac63d95",
                                  "type": "switch",
                                  "name": "nur true",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 640,
                                  "y": 460,
                                  "wires": [
                                          "f6bc1b429099ca57"
                                  "id": "3803f5607daeb485",
                                  "type": "debug",
                                  "name": "debug 9",
                                  "active": false,
                                  "tosidebar": true,
                                  "console": false,
                                  "tostatus": false,
                                  "complete": "true",
                                  "statusVal": "",
                                  "x": 820,
                                  "y": 680,
                                  "wires": []
                                  "id": "86ed2879e6ab1742",
                                  "type": "comment",
                                  "name": "Bewegungsmelder Simulator Ende",
                                  "info": "",
                                  "x": 160,
                                  "y": 560,
                                  "wires": []
                                  "id": "4deb5666bac8cf44",
                                  "type": "change",
                                  "name": "on/off",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "on",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "off",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 890,
                                  "y": 560,
                                  "wires": [
                                          "d2eeea8c88021d24"
                                  "id": "d2eeea8c88021d24",
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 3,
                                  "x": 1010,
                                  "y": 560,
                                  "wires": [
                                          "1584a54e77837dbd"
                                          "a8b609cc983f0b37",
                                          "1584a54e77837dbd"
                                  "id": "774f8f940a2c4c96",
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "true"
                                          "t": "false"
                                          "t": "eq",
                                          "v": "",
                                          "vt": "str"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 3,
                                  "x": 1190,
                                  "y": 460,
                                  "wires": [
                                          "0e43213215238d27"
                                          "0e43213215238d27"
                                  "id": "bcc31acbfde45d97",
                                  "type": "change",
                                  "name": "on/off",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "on",
                                          "fromt": "str",
                                          "to": "true",
                                          "tot": "bool"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "off",
                                          "fromt": "str",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 990,
                                  "y": 460,
                                  "wires": [
                                          "774f8f940a2c4c96"
                                  "id": "8f4fcec5a545127f",
                                  "type": "change",
                                  "name": "on",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "on",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 810,
                                  "y": 420,
                                  "wires": [
                                          "e8865a546b6ee97f"
                                  "id": "ee5a65e2896d189b",
                                  "x": 340,
                                  "y": 640,
                                  "wires": [
                                          "661eb84a02820976"
                                  "id": "661eb84a02820976",
                                  "type": "switch",
                                  "name": "",
                                  "rules": [
                                          "t": "false"
                                          "t": "true"
                                  "checkall": "true",
                                  "repair": false,
                                  "outputs": 2,
                                  "x": 430,
                                  "y": 580,
                                  "wires": [
                                          "a8a0cb4a1682f9f2",
                                          "3bd2c8cd8fbc4e0d"
                                          "638dc14da90f5eb4",
                                          "d5b7b0bf08213264",
                                          "8791ca72f579691c"
                                  "id": "3c6f79231d0fc04b",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1220,
                                  "y": 560,
                                  "wires": [
                                          "0e43213215238d27"
                                  "id": "d5b7b0bf08213264",
                                  "type": "change",
                                  "name": "stop",
                                  "rules": [
                                          "t": "set",
                                          "p": "payload",
                                          "pt": "msg",
                                          "to": "stop",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 610,
                                  "y": 620,
                                  "wires": [
                                          "5f9435538ec534ed",
                                          "9b6cc9d834347e2b"
                                  "id": "5f9435538ec534ed",
                                  "name": "10min.",
                                  "outtopic": "",
                                  "outsafe": "on",
                                  "outunsafe": "off",
                                  "warning": "10",
                                  "timer": "600",
                                  "debug": false,
                                  "ndebug": false,
                                  "repeat": false,
                                  "again": false,
                                  "x": 770,
                                  "y": 560,
                                  "wires": [
                                          "4deb5666bac8cf44"
                                  "id": "e8865a546b6ee97f",
                                  "name": "3Min.",
                                  "outtopic": "",
                                  "outsafe": "on",
                                  "outunsafe": "off",
                                  "warning": "10",
                                  "timer": "180",
                                  "debug": false,
                                  "ndebug": false,
                                  "repeat": false,
                                  "again": false,
                                  "x": 990,
                                  "y": 500,
                                  "wires": [
                                          "bcc31acbfde45d97"
                                  "id": "166ff2a331d49e9e",
                                  "name": "Hue",
                                  "x": 130,
                                  "y": 500,
                                  "wires": [
                                          "d500eca26ab86278"
                                  "id": "d500eca26ab86278",
                                  "name": "KüMo",
                                  "initevents": true,
                                  "x": 270,
                                  "y": 500,
                                  "wires": [
                                          "169c9cd74337485f",
                                          "a4c8574588c0de3c"
                                  "id": "631201f88292c2d6",
                                  "name": "U-rechts",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1320,
                                  "y": 740,
                                  "wires": []
                                  "id": "400b88291d913b81",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1330,
                                  "y": 620,
                                  "wires": []
                                  "id": "ce64922d78c18bb2",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1340,
                                  "y": 680,
                                  "wires": []
                                  "id": "b16aaa4000874ffd",
                                  "type": "debug",
                                  "name": "Küche",
                                  "active": true,
                                  "tosidebar": true,
                                  "console": true,
                                  "tostatus": false,
                                  "statusVal": "",
                                  "x": 1440,
                                  "y": 860,
                                  "wires": []
                                  "id": "f5195df37114b7de",
                                  "type": "change",
                                  "name": "Küche",
                                  "rules": [
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "1000",
                                          "fromt": "str",
                                          "to": "Küche",
                                          "tot": "str"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "true",
                                          "fromt": "bool",
                                          "tot": "str"
                                          "t": "change",
                                          "p": "payload",
                                          "pt": "msg",
                                          "from": "false",
                                          "fromt": "bool",
                                          "tot": "str"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 1310,
                                  "y": 860,
                                  "wires": [
                                          "b16aaa4000874ffd"
                                  "id": "08276b1f6580fc56",
                                  "name": "U-links",
                                  "ack": "false",
                                  "stateName": "",
                                  "role": "",
                                  "payloadType": "",
                                  "readonly": "",
                                  "stateUnit": "",
                                  "stateMin": "",
                                  "stateMax": "",
                                  "x": 1430,
                                  "y": 800,
                                  "wires": []
                                  "id": "587e1a24a2250226",
                                  "type": "inject",
                                  "name": "",
                                  "props": [
                                          "p": "payload"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "topic": "",
                                  "payload": "1000",
                                  "payloadType": "str",
                                  "x": 90,
                                  "y": 720,
                                  "wires": [
                                          "95fda7a91b84c03f"
                                  "id": "f3e6cb95fd339887",
                                  "name": "VIS-Küche",
                                  "topic": "0_userdata.0.GordonX-Home.0.Küche.VIS-Küche",
                                  "onlyack": "",
                                  "func": "all",
                                  "gap": "",
                                  "x": 80,
                                  "y": 660,
                                  "wires": [
                                          "95fda7a91b84c03f"
                                  "id": "3c0717cd3d6e108e",
                                  "type": "delay",
                                  "name": "100ms",
                                  "timeout": "100",
                                  "rate": "1",
                                  "nbRateUnits": "1",
                                  "randomFirst": "1",
                                  "randomLast": "5",
                                  "drop": false,
                                  "allowrate": false,
                                  "outputs": 1,
                                  "x": 1310,
                                  "y": 800,
                                  "wires": [
                                          "08276b1f6580fc56"
                                  "id": "805251b70f5d5a93",
                                  "type": "inject",
                                  "props": [
                                          "v": "true",
                                          "vt": "bool"
                                          "p": "topic",
                                          "vt": "str"
                                  "repeat": "",
                                  "crontab": "",
                                  "once": false,
                                  "onceDelay": 0.1,
                                  "x": 240,
                                  "y": 460,
                                  "wires": [
                                          "169c9cd74337485f",
                                          "e1f5f49327a29a8a"
                                  "id": "e1f5f49327a29a8a",
                                  "type": "change",
                                  "rules": [
                                          "t": "set",
                                          "pt": "msg",
                                          "to": "false",
                                          "tot": "bool"
                                  "action": "",
                                  "property": "",
                                  "from": "",
                                  "to": "",
                                  "reg": false,
                                  "x": 450,
                                  "y": 460,
                                  "wires": [
                                          "169c9cd74337485f"
                                  "id": "90f844739a331c64",
                                  "type": "junction",
                                  "x": 1060,
                                  "y": 600,
                                  "wires": [
                                          "3c6f79231d0fc04b",
                                          "a8b609cc983f0b37"
                                  "id": "f1be18a24ca143f6",
                                  "type": "junction",
                                  "x": 1160,
                                  "y": 680,
                                  "wires": [
                                          "ce64922d78c18bb2",
                                          "f5195df37114b7de",
                                          "631201f88292c2d6",
                                          "400b88291d913b81",
                                          "3c0717cd3d6e108e"
                                  "id": "1584a54e77837dbd",
                                  "type": "junction",
                                  "x": 1100,
                                  "y": 480,
                                  "wires": [
                                          "612158a90f7d1a23"
                                  "id": "e9a12ac84d11dd0e",
                                  "type": "junction",
                                  "x": 980,
                                  "y": 640,
                                  "wires": [
                                          "90f844739a331c64"
                                  "id": "a8a0cb4a1682f9f2",
                                  "type": "junction",
                                  "x": 540,
                                  "y": 560,
                                  "wires": [
                                          "5925b1db569c695b"
                                  "id": "3bd2c8cd8fbc4e0d",
                                  "type": "junction",
                                  "x": 540,
                                  "y": 580,
                                  "wires": [
                                          "3648551e97ec2cab"
                                  "id": "9b6cc9d834347e2b",
                                  "type": "junction",
                                  "x": 880,
                                  "y": 620,
                                  "wires": [
                                          "e8865a546b6ee97f"
                                  "id": "612158a90f7d1a23",
                                  "type": "junction",
                                  "x": 1260,
                                  "y": 480,
                                  "wires": [
                                          "0e43213215238d27"
                                  "id": "8791ca72f579691c",
                                  "type": "junction",
                                  "x": 560,
                                  "y": 640,
                                  "wires": [
                                          "e9a12ac84d11dd0e"
                                  "worker": "10",
                            @aphofis Das ist eine neue Variante. Meine "Simulation" des HUE Bewegungsmelders hast Du noch nicht verinnerlicht. Die ist rein für Tests, oder, wenn man wie ich keinen HUE BWM hat. Das ist nur für die Simulation zum Testen, und dann auch erst nach einer Zeit x vorgesehen. Jetzt wird zeitgleich payload.motion auf false gesetzt, auch wenn der HUE BWM meldet.
                            Ich habe es jetzt nicht importiert / ausprobiert.
                            Eine Idee:
                            Der HUE Bewegungsmelder geht seine eigenen Wege. Wenn das Licht nicht aus, bzw. gleich wieder an geht, könnte einer erkannten, oder noch anstehenden Bewegung geschuldet sein. Da könnte man eine Sperrvarable setzen, bzw. nur Änderungen durchlassen. Zumindest lief die von mir zuletzt gepostete Variante in meiner Testumgebung. Möglich, dass Dein BWM / Taster / Schalter da was unerwartetes losschickt.
                            Hier mein aufgeräumter Flow.
                                   "type": "tab",
                                   "label": "Flow 8",
                                   "disabled": false,
                                   "info": "",
                                   "env": []
                                   "type": "junction",
                                   "x": 1120,
                                   "y": 660,
                                   "wires": [
                                           "141a052859674836",
                                           "574a9f7ddc4f663b",
                                           "b6322a40cf4557b3"
                                   "type": "junction",
                                   "x": 1960,
                                   "y": 460,
                                   "wires": [
                                           "ff32f89078260f0e",
                                           "67e2e01a1266d1c3",
                                           "e98816534075b0f5",
                                           "21f36ea2695afe19",
                                           "a695276a00fe8f61"
                                   "type": "junction",
                                   "x": 1140,
                                   "y": 260,
                                   "wires": [
                                           "ba0aea0ff71ebc3d"
                                   "type": "junction",
                                   "x": 520,
                                   "y": 60,
                                   "wires": [
                                           "d24a5429e472b18a"
                                   "type": "junction",
                                   "x": 900,
                                   "y": 440,
                                   "wires": [
                                           "84bd4ea1d044fea4",
                                           "ed2607cafe826532"
                                   "type": "junction",
                                   "x": 980,
                                   "y": 360,
                                   "wires": [
                                           "be66da991b562e24"
                                   "type": "junction",
                                   "x": 1280,
                                   "y": 360,
                                   "wires": [
                                           "fa5f2b5bcd258a98"
                                   "id": "8355cf791b8a8b1b",
                                   "type": "junction",
                                   "x": 580,
                                   "y": 560,
                                   "wires": [
                                           "e22b60db6265e908"
                                   "id": "1ee1fe89c1628b34",
                                   "type": "junction",
                                   "x": 580,
                                   "y": 560,
                                   "wires": [
                                           "e22b60db6265e908"
                                   "id": "f3921b2658b5916c",
                                   "type": "junction",
                                   "x": 240,
                                   "y": 560,
                                   "wires": [
                                           "1ee1fe89c1628b34"
                                   "type": "inject",
                                   "props": [
                                           "v": "true",
                                           "vt": "bool"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "x": 140,
                                   "y": 380,
                                   "wires": [
                                           "a919a4c30d900c39",
                                           "0150c15cf7b51170"
                                   "type": "debug",
                                   "name": "debug 3",
                                   "active": true,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "complete": "true",
                                   "statusVal": "",
                                   "x": 2000,
                                   "y": 360,
                                   "wires": []
                                   "type": "delay",
                                   "name": "",
                                   "timeout": "30",
                                   "rate": "1",
                                   "nbRateUnits": "1",
                                   "randomFirst": "1",
                                   "randomLast": "5",
                                   "drop": false,
                                   "allowrate": false,
                                   "outputs": 1,
                                   "x": 150,
                                   "y": 460,
                                   "wires": [
                                           "bee64eb116d76ed1"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "pt": "msg",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 350,
                                   "y": 460,
                                   "wires": [
                                           "0150c15cf7b51170"
                                   "type": "switch",
                                   "name": "Schalter",
                                   "rules": [
                                           "t": "true"
                                           "t": "false"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 920,
                                   "y": 260,
                                   "wires": [
                                           "01fea99b98c641a3"
                                   "type": "change",
                                   "name": "Motion",
                                   "rules": [
                                           "t": "set",
                                           "p": "bewegung",
                                           "pt": "flow",
                                           "tot": "msg"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 670,
                                   "y": 320,
                                   "wires": [
                                   "type": "comment",
                                   "name": "Beginn << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                                   "info": "",
                                   "x": 280,
                                   "y": 300,
                                   "wires": []
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "on",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 710,
                                   "y": 400,
                                   "wires": [
                                           "ed2607cafe826532"
                                   "type": "switch",
                                   "name": "1000?",
                                   "rules": [
                                           "t": "eq",
                                           "v": "1000",
                                           "vt": "num"
                                           "t": "eq",
                                           "v": "",
                                           "vt": "num"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 310,
                                   "y": 660,
                                   "wires": [
                                           "6ae2e0e61f81faeb"
                                   "type": "switch",
                                   "name": "Robi",
                                   "property": "BWM",
                                   "rules": [
                                           "t": "true"
                                           "t": "false"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 1050,
                                   "y": 260,
                                   "wires": [
                                           "ae8ceff406113f11"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "stopp",
                                           "pt": "flow",
                                           "to": "true",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 890,
                                   "y": 600,
                                   "wires": [
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "stopp",
                                           "pt": "flow",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1370,
                                   "y": 600,
                                   "wires": [
                                   "type": "function",
                                   "outputs": 1,
                                   "timeout": 0,
                                   "noerr": 0,
                                   "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"BWM\", true);\nflow.set(\"bewegung\", false);\n",
                                   "finalize": "",
                                   "libs": [],
                                   "x": 1770,
                                   "y": 380,
                                   "wires": [
                                           "ed06e85de97289c8",
                                           "423ea0f1dc0e4d31"
                                   "name": "Robi",
                                   "onlyack": "",
                                   "func": "all",
                                   "gap": "",
                                   "x": 90,
                                   "y": 780,
                                   "wires": [
                                           "6b214a0a59b5e04a"
                                   "type": "function",
                                   "outputs": 1,
                                   "timeout": 0,
                                   "noerr": 0,
                                   "initialize": "",
                                   "finalize": "",
                                   "libs": [],
                                   "x": 360,
                                   "y": 360,
                                   "wires": [
                                           "0395e4bbb7c67e21"
                                   "onlyack": "",
                                   "func": "all",
                                   "gap": "",
                                   "x": 100,
                                   "y": 680,
                                   "wires": [
                                           "e22b60db6265e908"
                                   "type": "switch",
                                   "name": "8?",
                                   "rules": [
                                           "t": "eq",
                                           "v": "8",
                                           "vt": "num"
                                           "t": "neq",
                                           "v": "8",
                                           "vt": "num"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 630,
                                   "y": 780,
                                   "wires": [
                                           "7b9c0fa6e795af2d"
                                           "ccadbb1ee1de29e6"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "BWM",
                                           "pt": "flow",
                                           "to": "true",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 850,
                                   "y": 760,
                                   "wires": [
                                           "b117dac109d51b34"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "BWM",
                                           "pt": "flow",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 850,
                                   "y": 800,
                                   "wires": [
                                           "b117dac109d51b34"
                                   "type": "comment",
                                   "info": "",
                                   "x": 980,
                                   "y": 220,
                                   "wires": []
                                   "type": "switch",
                                   "name": "nur true",
                                   "rules": [
                                           "t": "true"
                                           "t": "false"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 740,
                                   "y": 240,
                                   "wires": [
                                           "ab41883686b27cc0"
                                   "type": "debug",
                                   "name": "debug 4",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": false,
                                   "tostatus": false,
                                   "complete": "true",
                                   "statusVal": "",
                                   "x": 1040,
                                   "y": 760,
                                   "wires": []
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "on",
                                           "fromt": "str",
                                           "to": "true",
                                           "tot": "bool"
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "off",
                                           "fromt": "str",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1290,
                                   "y": 400,
                                   "wires": [
                                           "d303b6e1817d8b77"
                                   "type": "switch",
                                   "name": "",
                                   "rules": [
                                           "t": "true"
                                           "t": "false"
                                           "t": "eq",
                                           "v": "",
                                           "vt": "str"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 3,
                                   "x": 1470,
                                   "y": 400,
                                   "wires": [
                                           "331a07cfba2d7df1"
                                           "331a07cfba2d7df1",
                                           "574a9f7ddc4f663b"
                                   "type": "switch",
                                   "name": "",
                                   "rules": [
                                           "t": "true"
                                           "t": "false"
                                           "t": "eq",
                                           "v": "",
                                           "vt": "str"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 3,
                                   "x": 1770,
                                   "y": 260,
                                   "wires": [
                                           "331a07cfba2d7df1"
                                           "331a07cfba2d7df1"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "on",
                                           "fromt": "str",
                                           "to": "true",
                                           "tot": "bool"
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "off",
                                           "fromt": "str",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1610,
                                   "y": 260,
                                   "wires": [
                                           "b4e55cb04c30244e"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "on",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1250,
                                   "y": 260,
                                   "wires": [
                                           "fa5f2b5bcd258a98"
                                   "x": 500,
                                   "y": 660,
                                   "wires": [
                                           "cf3016a536d38a8d"
                                   "type": "switch",
                                   "rules": [
                                           "t": "false"
                                           "t": "true"
                                   "checkall": "true",
                                   "repair": false,
                                   "outputs": 2,
                                   "x": 680,
                                   "y": 660,
                                   "wires": [
                                           "7eea52e80cbe51f0",
                                           "93f0d4c85ab42e59"
                                           "7b9c0fa6e795af2d",
                                           "87ec46662c49de4e",
                                           "f00e20abd94ff43d"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1380,
                                   "y": 640,
                                   "wires": [
                                           "331a07cfba2d7df1"
                                   "type": "change",
                                   "name": "stop",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "stop",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1010,
                                   "y": 640,
                                   "wires": [
                                           "d96f128a59bdfbb4"
                                   "name": "45sek",
                                   "outtopic": "",
                                   "outsafe": "on",
                                   "outunsafe": "off",
                                   "warning": "10",
                                   "timer": "60",
                                   "debug": false,
                                   "ndebug": false,
                                   "repeat": false,
                                   "again": false,
                                   "x": 1090,
                                   "y": 400,
                                   "wires": [
                                           "91febc7692f9b822"
                                   "name": "10Sek",
                                   "outtopic": "",
                                   "outsafe": "on",
                                   "outunsafe": "off",
                                   "warning": "10",
                                   "timer": "30",
                                   "debug": false,
                                   "ndebug": false,
                                   "repeat": false,
                                   "again": false,
                                   "x": 1430,
                                   "y": 260,
                                   "wires": [
                                           "90c9685b4a5344dc"
                                   "name": "U-rechts",
                                   "ack": "false",
                                   "stateName": "",
                                   "role": "",
                                   "payloadType": "",
                                   "readonly": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 2140,
                                   "y": 600,
                                   "wires": []
                                   "ack": "false",
                                   "stateName": "",
                                   "role": "",
                                   "payloadType": "",
                                   "readonly": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 2210,
                                   "y": 460,
                                   "wires": []
                                   "ack": "false",
                                   "stateName": "Simlulierte Lampe",
                                   "role": "value",
                                   "readonly": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 2160,
                                   "y": 540,
                                   "wires": []
                                   "type": "debug",
                                   "name": "Küche",
                                   "active": false,
                                   "tosidebar": true,
                                   "console": true,
                                   "tostatus": false,
                                   "statusVal": "",
                                   "x": 2160,
                                   "y": 760,
                                   "wires": []
                                   "type": "delay",
                                   "name": "100ms",
                                   "timeout": "100",
                                   "rate": "1",
                                   "nbRateUnits": "1",
                                   "randomFirst": "1",
                                   "randomLast": "5",
                                   "drop": false,
                                   "allowrate": false,
                                   "outputs": 1,
                                   "x": 2070,
                                   "y": 460,
                                   "wires": [
                                           "084e7114b7ed1c61"
                                   "type": "change",
                                   "name": "Küche",
                                   "rules": [
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "1000",
                                           "fromt": "str",
                                           "to": "Küche",
                                           "tot": "str"
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "true",
                                           "fromt": "bool",
                                           "tot": "str"
                                           "t": "change",
                                           "p": "payload",
                                           "pt": "msg",
                                           "from": "false",
                                           "fromt": "bool",
                                           "tot": "str"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 2030,
                                   "y": 760,
                                   "wires": [
                                           "442c2ef743d9599f"
                                   "name": "U-links",
                                   "ack": "false",
                                   "stateName": "",
                                   "role": "",
                                   "payloadType": "",
                                   "readonly": "",
                                   "stateUnit": "",
                                   "stateMin": "",
                                   "stateMax": "",
                                   "x": 2130,
                                   "y": 680,
                                   "wires": []
                                   "name": "Hue",
                                   "x": 130,
                                   "y": 160,
                                   "wires": [
                                           "2e0c2a67486c0ac7"
                                   "initevents": true,
                                   "x": 360,
                                   "y": 160,
                                   "wires": [
                                           "0395e4bbb7c67e21"
                                   "type": "inject",
                                   "name": "Takt",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "1",
                                   "crontab": "",
                                   "once": true,
                                   "onceDelay": 0.1,
                                   "topic": "Takt",
                                   "payload": "true",
                                   "x": 130,
                                   "y": 60,
                                   "wires": [
                                           "26a06677287b879b"
                                   "type": "change",
                                   "name": "",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "bewegung",
                                           "tot": "flow"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 370,
                                   "y": 60,
                                   "wires": [
                                           "9c7c62ee37b6b12c"
                                   "type": "inject",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "1000",
                                   "x": 130,
                                   "y": 520,
                                   "wires": [
                                           "64bf8df5efc25d40",
                                           "f3921b2658b5916c"
                                   "type": "change",
                                   "rules": [
                                           "t": "set",
                                           "p": "bewegung",
                                           "pt": "flow",
                                           "to": "false",
                                           "tot": "bool"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 1390,
                                   "y": 680,
                                   "wires": [
                                   "type": "comment",
                                   "name": "Ende << Für Simulation Für Simulation Für Simulation Für Simulation >>",
                                   "info": "",
                                   "x": 270,
                                   "y": 580,
                                   "wires": []
                                   "type": "comment",
                                   "info": "",
                                   "x": 980,
                                   "y": 320,
                                   "wires": []
                                   "id": "64bf8df5efc25d40",
                                   "type": "delay",
                                   "name": "200 ms",
                                   "timeout": "200",
                                   "rate": "1",
                                   "nbRateUnits": "1",
                                   "randomFirst": "1",
                                   "randomLast": "5",
                                   "drop": false,
                                   "allowrate": false,
                                   "outputs": 1,
                                   "x": 300,
                                   "y": 520,
                                   "wires": [
                                           "d628f1137cfb08c1"
                                   "id": "d628f1137cfb08c1",
                                   "type": "change",
                                   "name": "1002",
                                   "rules": [
                                           "t": "set",
                                           "p": "payload",
                                           "pt": "msg",
                                           "to": "1002",
                                           "tot": "num"
                                   "action": "",
                                   "property": "",
                                   "from": "",
                                   "to": "",
                                   "reg": false,
                                   "x": 430,
                                   "y": 520,
                                   "wires": [
                                           "8355cf791b8a8b1b"
                                   "id": "9a70fab410cfbdae",
                                   "type": "inject",
                                   "name": "Test Robi 8",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "8",
                                   "x": 120,
                                   "y": 840,
                                   "wires": [
                                           "6b214a0a59b5e04a"
                                   "id": "10a3703ea5e9c5fd",
                                   "type": "inject",
                                   "name": "Test Robi 5",
                                   "props": [
                                           "p": "payload"
                                           "p": "topic",
                                           "vt": "str"
                                   "repeat": "",
                                   "crontab": "",
                                   "once": false,
                                   "onceDelay": 0.1,
                                   "topic": "",
                                   "payload": "5",
                                   "x": 120,
                                   "y": 900,
                                   "wires": [
                                           "6b214a0a59b5e04a"
                                   "worker": "10",
                            • Aphofis
                              @peterfido
                              Also soweit funktionierts nur irgend etwas schaltet mitten drin nach klick schalter die lampen ab
                              hab schon paar debug nodes angehängt finde aber nicht wer das macht.
                              Wenn man nach der selbst abschaltung dann in den BWM läuft geht das licht wieder an.
                              Wenn man also schalter schaltet geht das licht nach paar sekunden alleine aus und es kommt keine debug ausgabe. geht man in den BWM gehts licht wieder an und bleibt auch für eingestellte zeit an und bei wiederbewegung blitzt das licht einmal kurz und ist dann aber wieder an.
                              BWM / Roboter Sauger funktioniert soweit.
                                      "id": "cd388a27e1177b2a",
                                      "type": "tab",
                                      "label": "Flow 8",
                                      "disabled": false,
                                      "info": "",
                                      "env": []
                                      "id": "c858be985d04ff23",
                                      "type": "junction",
                                      "z": "cd388a27e1177b2a",
                                      "x": 680,
                                      "y": 560,
                                      "wires": [
                                              "e52cacfb28f4eef0",
                                              "d4243e5842d002b7",
                                              "f4dd19c85bec8f67"
                                      "id": "49ed5c100ffadbfb",
                                      "type": "junction",
                                      "x": 1060,
                                      "y": 600,
                                      "wires": [
                                              "3da3568f5cb1d905",
                                              "d9b21aa55e80ae44",
                                              "c9f5b344739be161",
                                              "a0d644333024864d"
                                      "id": "6b29472d446bd70a",
                                      "type": "junction",
                                      "x": 680,
                                      "y": 320,
                                      "wires": [
                                              "1f6129972520dbc9",
                                              "2cf7c09b18238747"
                                      "id": "97a52cd45dee491f",
                                      "type": "junction",
                                      "x": 1060,
                                      "y": 460,
                                      "wires": [
                                              "49ed5c100ffadbfb"
                                      "id": "17a82c94f393c061",
                                      "type": "junction",
                                      "x": 160,
                                      "y": 520,
                                      "wires": [
                                              "34daca3383213026"
                                      "id": "f2c58fd53288296d",
                                      "type": "debug",
                                      "name": "debug 3",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "targetType": "full",
                                      "statusVal": "",
                                      "statusType": "auto",
                                      "x": 1400,
                                      "y": 420,
                                      "wires": []
                                      "id": "25ad2bdbb9a6a3f2",
                                      "type": "change",
                                      "name": "motion:false",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload.motion",
                                              "pt": "msg",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 310,
                                      "y": 420,
                                      "wires": [
                                              "c5344e2d70758330"
                                      "id": "6fa8c560705cd84b",
                                      "type": "switch",
                                      "name": "Schalter",
                                      "property": "stopp",
                                      "propertyType": "flow",
                                      "rules": [
                                              "t": "true"
                                              "t": "false"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 2,
                                      "x": 560,
                                      "y": 280,
                                      "wires": [
                                              "e5b4dd5e0fdf55b3"
                                      "id": "7cade0980ce23b6f",
                                      "type": "change",
                                      "name": "Motion",
                                      "rules": [
                                              "t": "set",
                                              "p": "bewegung",
                                              "pt": "flow",
                                              "to": "payload.motion",
                                              "tot": "msg"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 470,
                                      "y": 320,
                                      "wires": [
                                      "id": "1d02d4d287c62d8d",
                                      "type": "change",
                                      "name": "set payload",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "on",
                                              "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 610,
                                      "y": 360,
                                      "wires": [
                                              "1f6129972520dbc9"
                                      "id": "edd034e0ac4e9dbd",
                                      "type": "switch",
                                      "name": "1000?",
                                      "rules": [
                                              "t": "eq",
                                              "v": "1000",
                                              "vt": "num"
                                              "t": "eq",
                                              "v": "",
                                              "vt": "num"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 2,
                                      "x": 230,
                                      "y": 460,
                                      "wires": [
                                              "b3cf3d5c5932a0f1"
                                      "id": "e5b4dd5e0fdf55b3",
                                      "type": "switch",
                                      "name": "Robi",
                                      "property": "BWM",
                                      "rules": [
                                              "t": "true"
                                              "t": "false"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 2,
                                      "x": 690,
                                      "y": 280,
                                      "wires": [
                                              "eb53173feca16754"
                                      "id": "6ad2e1e41e7eba3d",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "stopp",
                                              "pt": "flow",
                                              "to": "true",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 630,
                                      "y": 460,
                                      "wires": [
                                      "id": "d4243e5842d002b7",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "stopp",
                                              "pt": "flow",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 830,
                                      "y": 560,
                                      "wires": [
                                      "id": "0649103700725132",
                                      "type": "function",
                                      "outputs": 1,
                                      "timeout": 0,
                                      "noerr": 0,
                                      "finalize": "",
                                      "libs": [],
                                      "x": 1170,
                                      "y": 420,
                                      "wires": [
                                              "f2c58fd53288296d",
                                              "97a52cd45dee491f"
                                      "id": "5b195fc1f7acb5c0",
                                      "name": "Robi",
                                      "onlyack": "",
                                      "func": "all",
                                      "gap": "",
                                      "x": 110,
                                      "y": 600,
                                      "wires": [
                                              "7f79db16bb82a357"
                                      "id": "c5344e2d70758330",
                                      "type": "function",
                                      "outputs": 1,
                                      "timeout": 0,
                                      "noerr": 0,
                                      "initialize": "",
                                      "finalize": "",
                                      "libs": [],
                                      "x": 300,
                                      "y": 380,
                                      "wires": [
                                              "7cade0980ce23b6f"
                                      "id": "d4e6916ec6660771",
                                      "onlyack": "",
                                      "func": "all",
                                      "gap": "",
                                      "x": 80,
                                      "y": 460,
                                      "wires": [
                                              "edd034e0ac4e9dbd"
                                      "id": "7f79db16bb82a357",
                                      "type": "switch",
                                      "name": "8?",
                                      "property": "payload",
                                      "propertyType": "msg",
                                      "rules": [
                                              "t": "eq",
                                              "v": "8",
                                              "vt": "num"
                                              "t": "neq",
                                              "v": "8",
                                              "vt": "num"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 2,
                                      "x": 230,
                                      "y": 600,
                                      "wires": [
                                              "34daca3383213026"
                                              "9725d7651f53e931"
                                      "id": "34daca3383213026",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "BWM",
                                              "pt": "flow",
                                              "to": "true",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 410,
                                      "y": 580,
                                      "wires": [
                                              "3d95821769504d11"
                                      "id": "9725d7651f53e931",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "BWM",
                                              "pt": "flow",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 410,
                                      "y": 620,
                                      "wires": [
                                              "3d95821769504d11"
                                      "id": "6a9e975c8a2cb22e",
                                      "type": "switch",
                                      "name": "nur true",
                                      "rules": [
                                              "t": "true"
                                              "t": "false"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 2,
                                      "x": 420,
                                      "y": 280,
                                      "wires": [
                                              "6fa8c560705cd84b"
                                      "id": "3d95821769504d11",
                                      "type": "debug",
                                      "name": "debug 4",
                                      "active": false,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "true",
                                      "statusVal": "",
                                      "x": 580,
                                      "y": 600,
                                      "wires": []
                                      "id": "19d59c4b02bc1d4e",
                                      "type": "change",
                                      "name": "true/on/false/off",
                                      "rules": [
                                              "t": "change",
                                              "p": "payload",
                                              "pt": "msg",
                                              "from": "on",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "p": "payload",
                                              "pt": "msg",
                                              "from": "off",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 820,
                                      "y": 440,
                                      "wires": [
                                              "2b6788c8f61bc75d"
                                      "id": "2b6788c8f61bc75d",
                                      "type": "switch",
                                      "name": "",
                                      "rules": [
                                              "t": "true"
                                              "t": "false"
                                              "t": "eq",
                                              "v": "",
                                              "vt": "str"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 3,
                                      "x": 830,
                                      "y": 500,
                                      "wires": [
                                              "0649103700725132",
                                              "22f763e23b4b426d"
                                              "0649103700725132",
                                              "d4243e5842d002b7",
                                              "078d3cdea12da58a"
                                      "id": "81379b4c78eb5084",
                                      "type": "switch",
                                      "name": "",
                                      "rules": [
                                              "t": "true"
                                              "t": "false"
                                              "t": "eq",
                                              "v": "",
                                              "vt": "str"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 3,
                                      "x": 970,
                                      "y": 380,
                                      "wires": [
                                              "0649103700725132",
                                              "cada2da2ed2bfaf6"
                                              "0649103700725132",
                                              "c38db948a076700c"
                                      "id": "6d74347a2369c9b1",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "change",
                                              "p": "payload",
                                              "pt": "msg",
                                              "from": "on",
                                              "fromt": "str",
                                              "to": "true",
                                              "tot": "bool"
                                              "t": "change",
                                              "p": "payload",
                                              "pt": "msg",
                                              "from": "off",
                                              "fromt": "str",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 970,
                                      "y": 320,
                                      "wires": [
                                              "81379b4c78eb5084"
                                      "id": "eb53173feca16754",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "on",
                                              "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 850,
                                      "y": 280,
                                      "wires": [
                                              "2cf7c09b18238747"
                                      "id": "b3cf3d5c5932a0f1",
                                      "name": "Virt Lampe",
                                      "attrname": "payload",
                                      "payloadType": "value",
                                      "x": 330,
                                      "y": 520,
                                      "wires": [
                                              "fe9075ec01f6e19a"
                                      "id": "fe9075ec01f6e19a",
                                      "type": "switch",
                                      "rules": [
                                              "t": "false"
                                              "t": "true"
                                      "checkall": "true",
                                      "repair": false,
                                      "outputs": 2,
                                      "x": 440,
                                      "y": 460,
                                      "wires": [
                                              "6ad2e1e41e7eba3d",
                                              "1d02d4d287c62d8d"
                                              "6fda00babbc6c3cf",
                                              "c858be985d04ff23",
                                              "17a82c94f393c061"
                                      "id": "e52cacfb28f4eef0",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 840,
                                      "y": 600,
                                      "wires": [
                                              "0649103700725132",
                                              "0e6b80937690ec94"
                                      "id": "6fda00babbc6c3cf",
                                      "type": "change",
                                      "name": "stop",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "stop",
                                              "tot": "str"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 610,
                                      "y": 320,
                                      "wires": [
                                              "6b29472d446bd70a"
                                      "id": "1f6129972520dbc9",
                                      "type": "mytimeout",
                                      "name": "45min",
                                      "outtopic": "",
                                      "outsafe": "on",
                                      "outwarning": "Warning",
                                      "outunsafe": "off",
                                      "warning": "10",
                                      "timer": "2700",
                                      "debug": false,
                                      "ndebug": false,
                                      "ignoreCase": false,
                                      "repeat": false,
                                      "again": false,
                                      "x": 810,
                                      "y": 380,
                                      "wires": [
                                              "19d59c4b02bc1d4e"
                                      "id": "2cf7c09b18238747",
                                      "name": "3min",
                                      "outtopic": "",
                                      "outsafe": "on",
                                      "outunsafe": "off",
                                      "warning": "10",
                                      "timer": "90",
                                      "debug": false,
                                      "ndebug": false,
                                      "repeat": false,
                                      "again": false,
                                      "x": 810,
                                      "y": 320,
                                      "wires": [
                                              "6d74347a2369c9b1"
                                      "id": "c9f5b344739be161",
                                      "type": "ioBroker out",
                                      "name": "U-rechts",
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1200,
                                      "y": 600,
                                      "wires": []
                                      "id": "eb0a77e50a594126",
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1330,
                                      "y": 480,
                                      "wires": []
                                      "id": "3da3568f5cb1d905",
                                      "ack": "false",
                                      "autoCreate": "true",
                                      "role": "value",
                                      "payloadType": "boolean",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1220,
                                      "y": 540,
                                      "wires": []
                                      "id": "d9b21aa55e80ae44",
                                      "type": "delay",
                                      "name": "100ms",
                                      "pauseType": "delay",
                                      "timeout": "100",
                                      "rate": "1",
                                      "nbRateUnits": "1",
                                      "rateUnits": "second",
                                      "randomFirst": "1",
                                      "randomLast": "5",
                                      "randomUnits": "seconds",
                                      "drop": false,
                                      "allowrate": false,
                                      "outputs": 1,
                                      "x": 1190,
                                      "y": 480,
                                      "wires": [
                                              "eb0a77e50a594126"
                                      "id": "a0d644333024864d",
                                      "name": "U-links",
                                      "ack": "false",
                                      "stateName": "",
                                      "role": "",
                                      "payloadType": "",
                                      "readonly": "",
                                      "stateUnit": "",
                                      "stateMin": "",
                                      "stateMax": "",
                                      "x": 1190,
                                      "y": 660,
                                      "wires": []
                                      "id": "749bbf25ef1c6f5d",
                                      "name": "Hue",
                                      "x": 90,
                                      "y": 320,
                                      "wires": [
                                              "7e046925a0149339"
                                      "id": "7e046925a0149339",
                                      "initevents": true,
                                      "x": 280,
                                      "y": 320,
                                      "wires": [
                                              "7cade0980ce23b6f"
                                      "id": "6744591312f4367c",
                                      "type": "inject",
                                      "name": "Takt",
                                      "props": [
                                              "p": "payload"
                                              "p": "topic",
                                              "vt": "str"
                                      "repeat": "1",
                                      "crontab": "",
                                      "once": true,
                                      "onceDelay": 0.1,
                                      "topic": "Takt",
                                      "payload": "true",
                                      "x": 90,
                                      "y": 280,
                                      "wires": [
                                              "19d0869e86da09b3"
                                      "id": "19d0869e86da09b3",
                                      "type": "change",
                                      "name": "",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "bewegung",
                                              "tot": "flow"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 250,
                                      "y": 280,
                                      "wires": [
                                              "6a9e975c8a2cb22e"
                                      "id": "f4dd19c85bec8f67",
                                      "type": "change",
                                      "rules": [
                                              "t": "set",
                                              "p": "bewegung",
                                              "pt": "flow",
                                              "to": "false",
                                              "tot": "bool"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 850,
                                      "y": 640,
                                      "wires": [
                                      "id": "14cbab0539105d58",
                                      "type": "change",
                                      "name": "1002",
                                      "rules": [
                                              "t": "set",
                                              "p": "payload",
                                              "pt": "msg",
                                              "to": "1000",
                                              "tot": "num"
                                      "action": "",
                                      "property": "",
                                      "from": "",
                                      "to": "",
                                      "reg": false,
                                      "x": 110,
                                      "y": 380,
                                      "wires": [
                                              "edd034e0ac4e9dbd"
                                      "id": "cada2da2ed2bfaf6",
                                      "type": "debug",
                                      "name": "debug 8",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "complete": "false",
                                      "statusVal": "",
                                      "x": 1300,
                                      "y": 280,
                                      "wires": []
                                      "id": "c38db948a076700c",
                                      "type": "debug",
                                      "name": "debug 17",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 1300,
                                      "y": 320,
                                      "wires": []
                                      "id": "0e6b80937690ec94",
                                      "type": "debug",
                                      "name": "debug 18",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 1200,
                                      "y": 800,
                                      "wires": []
                                      "id": "078d3cdea12da58a",
                                      "type": "debug",
                                      "name": "debug 19",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 1200,
                                      "y": 760,
                                      "wires": []
                                      "id": "22f763e23b4b426d",
                                      "type": "debug",
                                      "name": "debug 20",
                                      "active": true,
                                      "tosidebar": true,
                                      "console": false,
                                      "tostatus": false,
                                      "statusVal": "",
                                      "x": 1200,
                                      "y": 720,
                                      "wires": []
                                      "worker": "10",
                                peterfido @Aphofis last edited by
                                @aphofis
                                Das hier sollte anzeigen, wer da wo den Schaltbefehl gibt:
                                       "type": "tab",
                                       "label": "Flow 8",
                                       "disabled": false,
                                       "info": "",
                                       "env": []
                                       "type": "junction",
                                       "x": 1120,
                                       "y": 660,
                                       "wires": [
                                               "141a052859674836",
                                               "574a9f7ddc4f663b",
                                               "b6322a40cf4557b3"
                                       "type": "junction",
                                       "x": 1960,
                                       "y": 460,
                                       "wires": [
                                               "ff32f89078260f0e",
                                               "67e2e01a1266d1c3",
                                               "e98816534075b0f5",
                                               "21f36ea2695afe19",
                                               "a695276a00fe8f61"
                                       "type": "junction",
                                       "x": 1140,
                                       "y": 260,
                                       "wires": [
                                               "ba0aea0ff71ebc3d"
                                       "type": "junction",
                                       "x": 520,
                                       "y": 60,
                                       "wires": [
                                               "d24a5429e472b18a"
                                       "type": "junction",
                                       "x": 900,
                                       "y": 440,
                                       "wires": [
                                               "84bd4ea1d044fea4",
                                               "ed2607cafe826532"
                                       "type": "junction",
                                       "x": 980,
                                       "y": 360,
                                       "wires": [
                                               "be66da991b562e24"
                                       "type": "junction",
                                       "x": 1280,
                                       "y": 360,
                                       "wires": [
                                               "fa5f2b5bcd258a98"
                                       "type": "junction",
                                       "x": 580,
                                       "y": 560,
                                       "wires": [
                                               "e22b60db6265e908"
                                       "type": "junction",
                                       "x": 580,
                                       "y": 560,
                                       "wires": [
                                               "e22b60db6265e908"
                                       "type": "junction",
                                       "x": 240,
                                       "y": 560,
                                       "wires": [
                                               "1ee1fe89c1628b34"
                                       "type": "inject",
                                       "z": "b802892eed83e90f",
                                       "name": "Test Bewegung",
                                       "props": [
                                               "v": "true",
                                               "vt": "bool"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "Bewegungsmelder",
                                       "x": 140,
                                       "y": 380,
                                       "wires": [
                                               "a919a4c30d900c39",
                                               "0150c15cf7b51170"
                                       "type": "debug",
                                       "name": "debug 3",
                                       "active": true,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 2000,
                                       "y": 360,
                                       "wires": []
                                       "type": "delay",
                                       "name": "",
                                       "timeout": "30",
                                       "timeoutUnits": "seconds",
                                       "rate": "1",
                                       "nbRateUnits": "1",
                                       "randomFirst": "1",
                                       "randomLast": "5",
                                       "drop": false,
                                       "allowrate": false,
                                       "outputs": 1,
                                       "x": 150,
                                       "y": 460,
                                       "wires": [
                                               "bee64eb116d76ed1"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "pt": "msg",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 350,
                                       "y": 460,
                                       "wires": [
                                               "0150c15cf7b51170"
                                       "type": "switch",
                                       "name": "Schalter",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 920,
                                       "y": 260,
                                       "wires": [
                                               "01fea99b98c641a3"
                                       "type": "change",
                                       "name": "Motion",
                                       "rules": [
                                               "t": "set",
                                               "p": "bewegung",
                                               "pt": "flow",
                                               "tot": "msg"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 670,
                                       "y": 320,
                                       "wires": [
                                       "type": "comment",
                                       "info": "",
                                       "x": 280,
                                       "y": 300,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "on",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 710,
                                       "y": 400,
                                       "wires": [
                                               "ed2607cafe826532"
                                       "type": "switch",
                                       "name": "1000?",
                                       "rules": [
                                               "t": "eq",
                                               "v": "1000",
                                               "vt": "num"
                                               "t": "eq",
                                               "v": "",
                                               "vt": "num"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 270,
                                       "y": 660,
                                       "wires": [
                                               "6ae2e0e61f81faeb"
                                       "type": "switch",
                                       "name": "Robi",
                                       "property": "robi",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 1050,
                                       "y": 260,
                                       "wires": [
                                               "ae8ceff406113f11"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "stopp",
                                               "pt": "flow",
                                               "to": "true",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 950,
                                       "y": 600,
                                       "wires": [
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "stopp",
                                               "pt": "flow",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1370,
                                       "y": 600,
                                       "wires": [
                                       "type": "function",
                                       "name": "Variablen Ini + Ausgabe",
                                       "func": "if(msg.payload){\n    msg.topic = msg.topic + \": Licht ein\";\n}else{\n    msg.topic = msg.topic + \": Licht aus\";\n}\n\nmsg.topic += \", robi:\" + flow.get(\"robi\");\nnode.status({ text: msg.topic });\n\nreturn msg;",
                                       "outputs": 1,
                                       "timeout": 0,
                                       "noerr": 0,
                                       "initialize": "// Der Code hier wird ausgeführt,\n// wenn der Node gestartet wird\n\nflow.set(\"stopp\", false);\nflow.set(\"robi\", true);\nflow.set(\"bewegung\", false);\n",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 1770,
                                       "y": 380,
                                       "wires": [
                                               "ed06e85de97289c8",
                                               "423ea0f1dc0e4d31"
                                       "type": "ioBroker in",
                                       "name": "Robi",
                                       "onlyack": "",
                                       "func": "rbe-preinitvalue",
                                       "gap": "",
                                       "fireOnStart": "true",
                                       "outFormat": "MQTT",
                                       "x": 90,
                                       "y": 780,
                                       "wires": [
                                               "6b214a0a59b5e04a"
                                       "type": "function",
                                       "name": "Ausgang BWM",
                                       "func": "\nreturn msg;",
                                       "outputs": 1,
                                       "timeout": 0,
                                       "noerr": 0,
                                       "initialize": "",
                                       "finalize": "",
                                       "libs": [],
                                       "x": 360,
                                       "y": 360,
                                       "wires": [
                                               "0395e4bbb7c67e21"
                                       "onlyack": "",
                                       "func": "all",
                                       "gap": "",
                                       "fireOnStart": "false",
                                       "x": 100,
                                       "y": 680,
                                       "wires": [
                                               "e22b60db6265e908"
                                       "type": "switch",
                                       "name": "8?",
                                       "rules": [
                                               "t": "eq",
                                               "v": "8",
                                               "vt": "num"
                                               "t": "neq",
                                               "v": "8",
                                               "vt": "num"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 630,
                                       "y": 780,
                                       "wires": [
                                               "7b9c0fa6e795af2d"
                                               "ccadbb1ee1de29e6"
                                       "type": "change",
                                       "name": "setze Flow.robi",
                                       "rules": [
                                               "t": "set",
                                               "p": "robi",
                                               "pt": "flow",
                                               "to": "true",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 840,
                                       "y": 760,
                                       "wires": [
                                               "b117dac109d51b34"
                                       "type": "change",
                                       "name": "lösche Flow.robi",
                                       "rules": [
                                               "t": "set",
                                               "p": "robi",
                                               "pt": "flow",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 840,
                                       "y": 800,
                                       "wires": [
                                               "b117dac109d51b34"
                                       "type": "comment",
                                       "info": "",
                                       "x": 980,
                                       "y": 220,
                                       "wires": []
                                       "type": "switch",
                                       "name": "nur true",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 720,
                                       "y": 240,
                                       "wires": [
                                               "ab41883686b27cc0"
                                       "type": "debug",
                                       "name": "debug 4",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": false,
                                       "tostatus": false,
                                       "complete": "true",
                                       "statusVal": "",
                                       "x": 1040,
                                       "y": 760,
                                       "wires": []
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "on",
                                               "fromt": "str",
                                               "to": "true",
                                               "tot": "bool"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "off",
                                               "fromt": "str",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1290,
                                       "y": 400,
                                       "wires": [
                                               "d303b6e1817d8b77"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                               "t": "eq",
                                               "v": "",
                                               "vt": "str"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 3,
                                       "x": 1470,
                                       "y": 400,
                                       "wires": [
                                               "331a07cfba2d7df1"
                                               "331a07cfba2d7df1",
                                               "574a9f7ddc4f663b"
                                       "type": "switch",
                                       "name": "",
                                       "rules": [
                                               "t": "true"
                                               "t": "false"
                                               "t": "eq",
                                               "v": "",
                                               "vt": "str"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 3,
                                       "x": 1770,
                                       "y": 260,
                                       "wires": [
                                               "331a07cfba2d7df1"
                                               "331a07cfba2d7df1"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "on",
                                               "fromt": "str",
                                               "to": "true",
                                               "tot": "bool"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "off",
                                               "fromt": "str",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1610,
                                       "y": 260,
                                       "wires": [
                                               "b4e55cb04c30244e"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "on",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1250,
                                       "y": 260,
                                       "wires": [
                                               "fa5f2b5bcd258a98"
                                       "type": "ioBroker get",
                                       "errOnInvalidState": "nothing",
                                       "x": 440,
                                       "y": 660,
                                       "wires": [
                                               "f8d92d8cb9d60184"
                                       "type": "switch",
                                       "rules": [
                                               "t": "false"
                                               "t": "true"
                                       "checkall": "true",
                                       "repair": false,
                                       "outputs": 2,
                                       "x": 760,
                                       "y": 660,
                                       "wires": [
                                               "7eea52e80cbe51f0",
                                               "93f0d4c85ab42e59"
                                               "7b9c0fa6e795af2d",
                                               "87ec46662c49de4e",
                                               "f00e20abd94ff43d"
                                       "type": "change",
                                       "name": "Alles auf Anfang",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1380,
                                       "y": 640,
                                       "wires": [
                                               "331a07cfba2d7df1"
                                       "type": "change",
                                       "name": "stop",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "stop",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1070,
                                       "y": 640,
                                       "wires": [
                                               "d96f128a59bdfbb4"
                                       "name": "45sek",
                                       "outtopic": "Schalter 1000",
                                       "outsafe": "on",
                                       "outunsafe": "off",
                                       "warning": "10",
                                       "timer": "60",
                                       "debug": false,
                                       "ndebug": false,
                                       "repeat": false,
                                       "again": false,
                                       "x": 1090,
                                       "y": 400,
                                       "wires": [
                                               "91febc7692f9b822"
                                       "name": "10Sek",
                                       "outtopic": "BWM",
                                       "outsafe": "on",
                                       "outunsafe": "off",
                                       "warning": "10",
                                       "timer": "30",
                                       "debug": false,
                                       "ndebug": false,
                                       "repeat": false,
                                       "again": false,
                                       "x": 1430,
                                       "y": 260,
                                       "wires": [
                                               "90c9685b4a5344dc"
                                       "name": "U-rechts",
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2140,
                                       "y": 600,
                                       "wires": []
                                       "ack": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2210,
                                       "y": 460,
                                       "wires": []
                                       "topic": "0_userdata.0.GordonX-Home.0.Küche.Virtueller_Schalter_1",
                                       "ack": "false",
                                       "role": "value",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2160,
                                       "y": 540,
                                       "wires": []
                                       "type": "debug",
                                       "name": "Küche",
                                       "active": false,
                                       "tosidebar": true,
                                       "console": true,
                                       "tostatus": false,
                                       "statusVal": "",
                                       "x": 2160,
                                       "y": 760,
                                       "wires": []
                                       "type": "delay",
                                       "name": "100ms",
                                       "timeout": "100",
                                       "rate": "1",
                                       "nbRateUnits": "1",
                                       "randomFirst": "1",
                                       "randomLast": "5",
                                       "drop": false,
                                       "allowrate": false,
                                       "outputs": 1,
                                       "x": 2070,
                                       "y": 460,
                                       "wires": [
                                               "084e7114b7ed1c61"
                                       "type": "change",
                                       "name": "Küche",
                                       "rules": [
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "1000",
                                               "fromt": "str",
                                               "to": "Küche",
                                               "tot": "str"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "true",
                                               "fromt": "bool",
                                               "tot": "str"
                                               "t": "change",
                                               "p": "payload",
                                               "pt": "msg",
                                               "from": "false",
                                               "fromt": "bool",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 2030,
                                       "y": 760,
                                       "wires": [
                                               "442c2ef743d9599f"
                                       "name": "U-links",
                                       "ack": "false",
                                       "autoCreate": "false",
                                       "stateName": "",
                                       "role": "",
                                       "payloadType": "",
                                       "readonly": "",
                                       "stateUnit": "",
                                       "stateMin": "",
                                       "stateMax": "",
                                       "x": 2130,
                                       "y": 680,
                                       "wires": []
                                       "id": "802770af38c8534e",
                                       "type": "hue-bridge-node",
                                       "name": "Hue",
                                       "bridge": "cbd54dbabf6f65be",
                                       "autoupdates": true,
                                       "skipglobalevents": false,
                                       "initevents": false,
                                       "x": 130,
                                       "y": 160,
                                       "wires": [
                                               "2e0c2a67486c0ac7"
                                       "id": "2e0c2a67486c0ac7",
                                       "type": "hue-motion",
                                       "name": "Küche Motion Sensor",
                                       "sensorid": "7529c8d8-9f5c-451d-ba56-70cacda84564",
                                       "skipevents": false,
                                       "initevents": true,
                                       "x": 360,
                                       "y": 160,
                                       "wires": [
                                               "0395e4bbb7c67e21"
                                       "type": "inject",
                                       "name": "Takt",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "1",
                                       "crontab": "",
                                       "once": true,
                                       "onceDelay": 0.1,
                                       "topic": "Takt",
                                       "payload": "true",
                                       "x": 130,
                                       "y": 60,
                                       "wires": [
                                               "26a06677287b879b"
                                       "type": "change",
                                       "name": "",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "bewegung",
                                               "tot": "flow"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 370,
                                       "y": 60,
                                       "wires": [
                                               "9c7c62ee37b6b12c"
                                       "type": "inject",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "1000",
                                       "payloadType": "num",
                                       "x": 130,
                                       "y": 520,
                                       "wires": [
                                               "64bf8df5efc25d40",
                                               "f3921b2658b5916c"
                                       "type": "change",
                                       "rules": [
                                               "t": "set",
                                               "p": "bewegung",
                                               "pt": "flow",
                                               "to": "false",
                                               "tot": "bool"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 1390,
                                       "y": 680,
                                       "wires": [
                                       "type": "comment",
                                       "info": "",
                                       "x": 270,
                                       "y": 580,
                                       "wires": []
                                       "type": "comment",
                                       "info": "",
                                       "x": 980,
                                       "y": 320,
                                       "wires": []
                                       "type": "delay",
                                       "name": "200 ms",
                                       "timeout": "200",
                                       "timeoutUnits": "milliseconds",
                                       "rate": "1",
                                       "nbRateUnits": "1",
                                       "randomFirst": "1",
                                       "randomLast": "5",
                                       "drop": false,
                                       "allowrate": false,
                                       "outputs": 1,
                                       "x": 300,
                                       "y": 520,
                                       "wires": [
                                               "d628f1137cfb08c1"
                                       "type": "change",
                                       "name": "1002",
                                       "rules": [
                                               "t": "set",
                                               "p": "payload",
                                               "pt": "msg",
                                               "to": "1002",
                                               "tot": "num"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 430,
                                       "y": 520,
                                       "wires": [
                                               "8355cf791b8a8b1b"
                                       "type": "inject",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "8",
                                       "x": 120,
                                       "y": 840,
                                       "wires": [
                                               "6b214a0a59b5e04a"
                                       "type": "inject",
                                       "props": [
                                               "p": "payload"
                                               "p": "topic",
                                               "vt": "str"
                                       "repeat": "",
                                       "crontab": "",
                                       "once": false,
                                       "onceDelay": 0.1,
                                       "topic": "",
                                       "payload": "5",
                                       "x": 120,
                                       "y": 900,
                                       "wires": [
                                               "6b214a0a59b5e04a"
                                       "id": "f8d92d8cb9d60184",
                                       "type": "change",
                                       "name": "topic",
                                       "rules": [
                                               "t": "set",
                                               "p": "topic",
                                               "pt": "msg",
                                               "to": "Schalter 1000",
                                               "tot": "str"
                                       "action": "",
                                       "property": "",
                                       "from": "",
                                       "to": "",
                                       "reg": false,
                                       "x": 610,
                                       "y": 660,
                                       "wires": [
                                               "cf3016a536d38a8d"
                                       "id": "cbd54dbabf6f65be",
                                       "type": "hue-bridge",
                                       "name": "Hue GordonX",
                                       "bridge": "192.168.0.8",
                                       "key": "SlfyXwpcaEvRN0d1DU2JrrOlwrm9Debhhm9A4E-d",
                                       "worker": "10",
                                       "disableupdates": false
                                Im Prinzip kann alles so bleiben. Evtl. Hue nebst Motion Sensor einrichten. Der BWM Simulator tut nix, wenn man nicht die Inject-Node davon klickt. Das gleiche beim Test Schalter. Lass die drin, dann ist die Chance größer, dass ich Deine Exporte importiere und teste.
                                • Aphofis
                                  @peterfido
                                  bin beim Testen, mal sehen was dabei raus kommt.
                                  • Aphofis
                                    Also das immer wieder das Licht eingeschaltet wird wenn man in den BWM läuft und dann per Schalter ausschalten will und dieses 2-3 mal machen musste bis das Licht aus bleibt, lag am HUE Node. Die Globale Aktualisierungsmitteilungen auf diesem Node ignorieren, musste angehakt sein. Jetzt läuft die Steuerung tadellos.
                                    81.1k
                                    1990
