    3. Off Topic
    4. Pflege des Betriebssystems
    5. Veraltetes System retten
      Homoran Global Moderator Administrators @syntetic last edited by
      @syntetic ich hab das mal hierhin geschoben
        syntetic @Homoran last edited by
        @homoran Danke dir!
          Homoran Global Moderator Administrators @syntetic last edited by Homoran
          @syntetic sagte in Veraltetes System retten:
          Debian 10
          ist seit Jahren tot!
          Jetzt funktioniert es nicht mehr.
          Da wird es schwer
          bitte als allererstes die Langfassung von iob diag in code-tags posten
            syntetic @Homoran last edited by syntetic
            ```bash
            Script v.2025-03-08
            *** BASE SYSTEM ***
               Static hostname: raspberrypiMitcho
                     Icon name: computer
              Operating System: Raspbian GNU/Linux 10 (buster)
                        Kernel: Linux 5.10.103-v7l+
                  Architecture: arm
            OS is similar to: debian
            Model           : Raspberry Pi 4 Model B Rev 1.2
            Docker          : false
            Virtualization  : none
            Kernel          : armv7l
            Userland        : 32 bit
            Systemuptime and Load:
             14:56:04 up 27 min,  2 users,  load average: 1.02, 0.94, 1.08
            CPU threads: 4
            *** LIFE CYCLE STATUS ***
            Unknown release codenamed 'buster'. Please check yourself if the Operating System is actively maintained.
            *** RASPBERRY THROTTLING ***
            Current issues:
            Previously detected issues:
            *** TIME AND TIMEZONES ***
                           Local time: Mon 2025-06-16 14:56:04 CEST
                       Universal time: Mon 2025-06-16 12:56:04 UTC
                             RTC time: n/a
                          NTP service: active
                      RTC in local TZ: no
            *** Users and Groups ***
            User that called 'iob diag':
            pi
            HOME=/home/pi
            GROUPS=pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
            iobroker
            HOME=/home/iobroker
            GROUPS=iobroker tty dialout audio video bluetooth gpio i2c
            *** DISPLAY-SERVER SETUP ***
            Display-Server: false
            Desktop:
            Terminal:       tty
            System is booting into 'graphical.target'. Usually a server is running in 'multi-user.target'. Please set BootTarget to 'multi-user.target' or run 'iobroker fix'
            *** MEMORY ***
            Mem:           3.8G        1.6G        1.4G         11M        829M        2.1G
            Swap:           99M          0B         99M
            Total:         3.9G        1.6G        1.5G
            Active iob-Instances:   17
                     3838 M total memory
                     1635 M used memory
                      443 M active memory
                     1891 M inactive memory
                     1373 M free memory
                      106 M buffer memory
                      722 M swap cache
                       99 M total swap
                        0 M used swap
                       99 M free swap
            top - 14:56:05 up 27 min,  2 users,  load average: 1.02, 0.94, 1.08
            Tasks: 164 total,   2 running, 162 sleeping,   0 stopped,   0 zombie
            %Cpu(s):  2.7 us,  5.5 sy,  0.0 ni, 91.8 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
            MiB Mem :   3838.7 total,   1374.9 free,   1633.9 used,    829.9 buff/cache
            MiB Swap:    100.0 total,    100.0 free,      0.0 used.   2077.6 avail Mem
            *** FAILED SERVICES ***
              UNIT                LOAD   ACTIVE SUB    DESCRIPTION
            * deconz-init.service loaded failed failed deCONZ: ZigBee gateway -- Initialisation
            * lightdm.service     loaded failed failed Light Display Manager
            LOAD   = Reflects whether the unit definition was properly loaded.
            ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
            SUB    = The low-level unit activation state, values depend on unit type.
            2 loaded units listed. Pass --all to see loaded but inactive units, too.
            To show all installed unit files use 'systemctl list-unit-files'.
            *** DMESG CRITICAL ERRORS ***
            No critical errors detected
            *** FILESYSTEM ***
            /dev/root      ext4      235G   30G  196G  14% /
            devtmpfs       devtmpfs  1.8G     0  1.8G   0% /dev
            tmpfs          tmpfs     1.9G  732K  1.9G   1% /dev/shm
            tmpfs          tmpfs     1.9G  8.6M  1.9G   1% /run
            tmpfs          tmpfs     1.9G     0  1.9G   0% /sys/fs/cgroup
            /dev/mmcblk0p1 vfat      253M   49M  204M  20% /boot
            tmpfs          tmpfs     384M     0  384M   0% /run/user/999
            tmpfs          tmpfs     384M     0  384M   0% /run/user/1000
            [Mon Jun 16 14:28:29 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=1 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=DC:A6:32:FC:5C:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=tty1 root=PARTUUID=d0d2e9f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
            [Mon Jun 16 14:28:30 2025] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
            [Mon Jun 16 14:28:30 2025] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
            [Mon Jun 16 14:28:33 2025] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
            Show mounted filesystems:
            TARGET        SOURCE         FSTYPE OPTIONS
            /             /dev/mmcblk0p2 ext4   rw,noatime
            |-/sys/fs/bpf none           bpf    rw,nosuid,nodev,noexec,relatime,mode=700
            `-/boot       /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
            /var:
            3.2G    /var/
            2.4G    /var/lib
            1.4G    /var/lib/unifi/db
            1.4G    /var/lib/unifi
            801M    /var/lib/mongodb
            Archived and active journals take up 8.0M in the file system.
            /opt/iobroker/backups:
            4.0K    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            1.1G    /opt/iobroker/iobroker-data/
            816M    /opt/iobroker/iobroker-data/files
            617M    /opt/iobroker/iobroker-data/files/javascript.admin
            560M    /opt/iobroker/iobroker-data/files/javascript.admin/static
            558M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js
            71M     /opt/iobroker/iobroker-data/objects.jsonl
            24M     /opt/iobroker/iobroker-data/files/web.admin/static/js/main.135279a0.js.map
            23M     /opt/iobroker/iobroker-data/states.jsonl
            8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
            8.7M    /opt/iobroker/iobroker-data/files/javascript.admin/static/js/838.0aa41cb0.chunk.js.map
            USB-Devices by-id:
            /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
            *** ZigBee Settings ***
            Your zigbee.0 COM-Port is matching 'by-id'. Very good!
            Zigbee Network Settings on your coordinator/in nvbackup are:
            zigbee.X
            Extended Pan ID:
            *** MASKED ***
            Pan ID:
            *** MASKED ***
            Channel:
            *** MASKED ***
            Network Key:
            *** MASKED ***
            To unmask the settings run 'iob diag --unmask'
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v18.20.8
            /usr/bin/node           v18.20.8
            /usr/bin/npm            10.8.2
            /usr/bin/npx            10.8.2
            /usr/bin/corepack       0.32.0
            nodejs:
              Installed: 18.20.8-1nodesource1
              Candidate: 18.20.8-1nodesource1
              Version table:
             *** 18.20.8-1nodesource1 500
                    500 https://deb.nodesource.com/node_18.x nodistro/main armhf Packages
                    100 /var/lib/dpkg/status
                 18.20.6-1nodesource1 500
                 18.20.5-1nodesource1 500
                 18.20.4-1nodesource1 500
                 18.20.3-1nodesource1 500
                 18.20.2-1nodesource1 500
                 18.20.1-1nodesource1 500
                 18.20.0-1nodesource1 500
                 18.19.1-1nodesource1 500
                 18.19.0-1nodesource1 500
                 18.18.2-1nodesource1 500
                 18.18.1-1nodesource1 500
                 18.18.0-1nodesource1 500
                 18.17.1-1nodesource1 500
                 18.17.0-1nodesource1 500
                 18.16.1-1nodesource1 500
                 18.16.0-1nodesource1 500
                 18.15.0-1nodesource1 500
                 18.14.2-1nodesource1 500
                 18.14.1-1nodesource1 500
                 18.14.0-1nodesource1 500
                 18.13.0-1nodesource1 500
                 18.12.0-1nodesource1 500
                 18.11.0-1nodesource1 500
                 18.10.0-1nodesource1 500
                 18.9.1-1nodesource1 500
                 18.9.0-1nodesource1 500
                 18.8.0-1nodesource1 500
                 18.7.0-1nodesource1 500
                 18.6.0-1nodesource1 500
                 18.5.0-1nodesource1 500
                 18.4.0-1nodesource1 500
                 18.3.0-1nodesource1 500
                 18.2.0-1nodesource1 500
                 18.1.0-1nodesource1 500
                 18.0.0-1nodesource1 500
            No problems detected
            Errors in npm tree: 0
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Hosts:
            raspberrypiMitcho   raspberrypiMitcho (version: 7.0.6, hostname: raspberrypiMitcho, alive, uptime: 1478)
            Core adapters versions
            js-controller:  7.0.6
            admin:          7.6.17
            javascript:     8.8.3
            nodejs modules from github:     0
            Adapter State
            + system.adapter.accuweather.0            : accuweather           : raspberrypiMitcho                        -  enabled
            + system.adapter.admin.0                  : admin                 : raspberrypiMitcho                        -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : raspberrypiMitcho                        -  enabled
              system.adapter.flot.0                   : flot                  : raspberrypiMitcho                        -  enabled
            + system.adapter.history.0                : history               : raspberrypiMitcho                        -  enabled
              system.adapter.ical.0                   : ical                  : raspberrypiMitcho                        -  enabled
              system.adapter.ical.1                   : ical                  : raspberrypiMitcho                        -  enabled
              system.adapter.ical.2                   : ical                  : raspberrypiMitcho                        -  enabled
            + system.adapter.info.0                   : info                  : raspberrypiMitcho                        -  enabled
            + system.adapter.javascript.0             : javascript            : raspberrypiMitcho                        -  enabled
            + system.adapter.pi-hole.0                : pi-hole               : raspberrypiMitcho                        -  enabled
            + system.adapter.scenes.0                 : scenes                : raspberrypiMitcho                        -  enabled
            + system.adapter.shelly.0                 : shelly                : raspberrypiMitcho                        -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.shelly.1                 : shelly                : raspberrypiMitcho                        -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.telegram.0               : telegram              : raspberrypiMitcho                        -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.trashschedule.0          : trashschedule         : raspberrypiMitcho                        -  enabled
            + system.adapter.unifi.0                  : unifi                 : raspberrypiMitcho                        -  enabled
              system.adapter.vis.0                    : vis                   : raspberrypiMitcho                        -  enabled
            + system.adapter.web.0                    : web                   : raspberrypiMitcho                        -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            + system.adapter.yahka.0                  : yahka                 : raspberrypiMitcho                        -  enabled
            + system.adapter.zigbee.0                 : zigbee                : raspberrypiMitcho                        -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
            + instance is alive
            ioBroker-Repositories
            │ (index) │        name        │                           url                           │ auto upgrade │
            │    0    │ 'Stable (default)' │    'http://download.iobroker.net/sources-dist.json'     │    false     │
            │    1    │  'Beta (latest)'   │ 'http://download.iobroker.net/sources-dist-latest.json' │    false     │
            Active repo(s): Stable (default)
            Upgrade policy: none
            Installed ioBroker-Adapters
            Used repository: Stable (default)
            Adapter    "accuweather"  : 2.1.0    , installed 1.5.0  [Updatable]
            Adapter    "admin"        : 7.6.17   , installed 7.6.17
            Adapter    "backitup"     : 3.2.2    , installed 3.2.2
            Adapter    "flot"         : 1.12.0   , installed 1.11.0 [Updatable]
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "history"      : 3.0.1    , installed 2.2.4  [Updatable]
            Adapter    "ical"         : 1.16.1   , installed 1.16.1
            Adapter    "javascript"   : 8.9.2    , installed 8.8.3  [Updatable]
            Controller "js-controller": 7.0.6    , installed 7.0.6
            Adapter    "pi-hole"      : 1.3.6    , installed 1.3.6
            Adapter    "scenes"       : 3.2.3    , installed 2.3.9  [Updatable]
            Adapter    "shelly"       : 9.5.1    , installed 8.2.1  [Updatable]
            Adapter    "simple-api"   : 2.8.0    , installed 2.8.0
            Adapter    "socketio"     : 6.7.1    , installed 6.7.1
            Adapter    "telegram"     : 4.1.0    , installed 3.9.0  [Updatable]
            Adapter    "trashschedule": 3.3.0    , installed 3.3.0
            Adapter    "unifi"        : 0.7.0    , installed 0.7.0
            Adapter    "vis"          : 1.5.6    , installed 1.4.16 [Updatable]
            Adapter    "web"          : 7.0.8    , installed 6.2.5  [Updatable]
            Adapter    "ws"           : 2.6.2    , installed 2.6.2
            Adapter    "yahka"        : 1.0.3    , installed 1.0.3
            Adapter    "zigbee"       : 2.0.5    , installed 1.10.14 [Updatable]
            Objects and States
            Objects:        85977
            States:         63605
            W: GPG error: http://ftp.debian.org/debian bullseye-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
            E: The repository 'http://ftp.debian.org/debian bullseye-backports InRelease' is not signed.
            W: GPG error: http://deb.debian.org/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131 NO_PUBKEY 605C66F00D6C9793
            E: The repository 'http://deb.debian.org/debian bullseye InRelease' is not signed.
            W: GPG error: http://security.debian.org/debian-security bullseye-security InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 54404762BBB6E853 NO_PUBKEY BDE6D2B9216EC7A8
            E: The repository 'http://security.debian.org/debian-security bullseye-security InRelease' is not signed.
            W: GPG error: http://deb.debian.org/debian bullseye-updates InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 0E98404D386FA1D9 NO_PUBKEY 6ED0E7B82643E131
            E: The repository 'http://deb.debian.org/debian bullseye-updates InRelease' is not signed.
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN      1000       21247      365/deCONZ
            tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      0          19905      699/lighttpd
            tcp        0      0 127.0.0.1:28017         0.0.0.0:*               LISTEN      116        19938      412/mongod
            tcp        0      0 0.0.0.0:40373           0.0.0.0:*               LISTEN      1001       35592      3752/io.yahka.0
            tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      999        19927      711/pihole-FTL
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          18877      620/sshd
            tcp        0      0 0.0.0.0:631             0.0.0.0:*               LISTEN      0          21255      354/cupsd
            tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       40311      3640/io.shelly.1
            tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      1000       21928      365/deCONZ
            tcp        0      0 127.0.0.1:42917         0.0.0.0:*               LISTEN      1001       38276      3752/io.yahka.0
            tcp        0      0 127.0.0.1:4711          0.0.0.0:*               LISTEN      999        21248      711/pihole-FTL
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       33096      2806/iobroker.js-co
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       31414      2806/iobroker.js-co
            tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      116        19193      412/mongod
            tcp6       0      0 :::80                   :::*                    LISTEN      0          19906      699/lighttpd
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       35888      2932/io.admin.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       39045      3778/io.web.0
            tcp6       0      0 :::53                   :::*                    LISTEN      999        19929      711/pihole-FTL
            tcp6       0      0 :::22                   :::*                    LISTEN      0          18879      620/sshd
            tcp6       0      0 :::631                  :::*                    LISTEN      0          21256      354/cupsd
            tcp6       0      0 :::8581                 :::*                    LISTEN      115        25620      936/hb-service
            tcp6       0      0 ::1:4711                :::*                    LISTEN      999        18175      711/pihole-FTL
            tcp6       0      0 :::51560                :::*                    LISTEN      115        25155      1167/homebridge
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       42490      3463/io.shelly.0
            udp        0      0 0.0.0.0:53              0.0.0.0:*                           999        19926      711/pihole-FTL
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          19208      462/dhcpcd
            udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          19936      530/cups-browsed
            udp        0      0 0.0.0.0:56962           0.0.0.0:*                           108        17171      362/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           115        25617      936/hb-service
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        17169      362/avahi-daemon: r
            udp        0      0 0.0.0.0:1900            0.0.0.0:*                           1000       21940      365/deCONZ
            udp6       0      0 :::53                   :::*                                999        19928      711/pihole-FTL
            udp6       0      0 :::5353                 :::*                                108        17170      362/avahi-daemon: r
            udp6       0      0 :::57104                :::*                                108        17172      362/avahi-daemon: r
            2025-06-16 14:41:41.792  - info: shelly.1 (3640) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-b0a73246f8c8 / shellyplus2pm#b0a73246f8c8#1) (false)
            2025-06-16 14:41:44.407  - info: shelly.1 (3640) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-10061cfb1860 / shellyplus2pm#10061cfb1860#1) (false)
            2025-06-16 14:41:45.413  - info: shelly.1 (3640) [MQTT] Client Close: (shellyplus2pm / shellyplus2pm-3ce90e2ea41c / shellyplus2pm#3ce90e2ea41c#1) (false)
            2025-06-16 14:41:47.548  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a732477aa4"
            2025-06-16 14:41:47.556  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-3ce90e2ea41c"
            2025-06-16 14:41:47.570  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-10061cfae058"
            2025-06-16 14:41:47.572  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-10061cfb1860"
            2025-06-16 14:41:47.633  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a73246f8c8"
            2025-06-16 14:41:47.635  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a73248b5c0"
            2025-06-16 14:41:50.600  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a7324738a8" connected!
            2025-06-16 14:41:53.896  - info: admin.0 (2932) <== Disconnect system.user.admin from ::ffff:192.168.2.101 javascript
            2025-06-16 14:42:33.274  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-10061cfae058" connected!
            2025-06-16 14:42:36.002  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a73248b5c0" connected!
            2025-06-16 14:42:39.308  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a732477aa4" connected!
            2025-06-16 14:42:40.254  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a73246f8c8" connected!
            2025-06-16 14:42:42.091  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-3ce90e2ea41c" connected!
            2025-06-16 14:42:43.763  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-10061cfb1860" connected!
            2025-06-16 14:42:49.306  - info: shelly.1 (3640) [MQTT] Client Close: 192.168.2.176 (shellyplus2pm / shellyplus2pm-b0a732477aa4 / shellyplus2pm#b0a732477aa4#1) (false)
            2025-06-16 14:42:49.741  - error: shelly.1 (3640) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
            2025-06-16 14:42:49.742  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a732477aa4"
            2025-06-16 14:42:50.250  - info: shelly.1 (3640) [MQTT] Client Close: 192.168.2.175 (shellyplus2pm / shellyplus2pm-b0a73246f8c8 / shellyplus2pm#b0a73246f8c8#1) (false)
            2025-06-16 14:42:50.259  - error: shelly.1 (3640) [MQTT] Error in function setMqttPrefixHttp (Gen 1) for (undefined / undefined / undefined): TypeError: Cannot read properties of undefined (reading 'replace')
            2025-06-16 14:42:50.260  - error: shelly.1 (3640) [MQTT] Unable to get mqttprefix of client with id "shellyplus2pm-b0a73246f8c8"
            2025-06-16 14:43:45.975  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a732477aa4" connected!
            2025-06-16 14:43:48.644  - info: shelly.1 (3640) [MQTT] Device with client id "shellyplus2pm-b0a73246f8c8" connected!
            Es funktioniert schon prinzipiell alles - bis auf die enphase Skripte jetzt.
            Homoran Thomas Braun 3 Replies Last reply Reply Quote 0
              das läuft auch nicht
              Bitte keine Illusionen!
              Das System ist hin!.
              Zieh schonmal ein aktuelles ioBroker Backup.
              mit gaaaanz viel Glück lässt dich das auf einem neu aufgesetzten aktuellen System wiederherstellen.
              Dazu gibt es schon keinerlei Unterstützung mehr.
                viel zu alt für neuere Adapter-Versionen
                die sind dermaßen alt, dass nicht einmal mehr Versionsinformationen zur Verfügung stehen, und daher fälschlicherweise 0 anstehende Updates angezeigt werden.
                Da bietet nämlich niemand mehr Updates an.
                  Thomas Braun Most Active @syntetic last edited by
                  @syntetic
                  ioBroker soweit wie es geht updaten, Backup vom ioBroker ziehen, Betriebssystem komplett NEU als 64Bit-Lite 'Booworm' (Debian 12) aufsetzen, Backup einspielen, künfitg nicht mehr nach dem schwachsinnigen 'Never tatsch a running süstäm' verfahren. Das ist ganz großer Bullshit.
                    @homoran sagte in Veraltetes System retten:
                    Jein, die sind so alt, dass keine aktuellen Schlüssel vorhanden sind und deswegen daraus keine Updates angezogen werden.
                    Man käme aber ohnehin mit der Aktion nicht auf eine ordentliche Basis. Bleibt nur die Neuinstallation von dem ganzen Sums.
                      syntetic @Thomas Braun last edited by
                      Ok, wir machen alles neu. Da ich mich echt gar nicht auskenne und mir alles anlesen muss, was ich dort mache, könnt ihr mich vielleicht da durch leiten.
                      Wäre schon gut, wenn ich den ioBroker wieder importieren könnte.
                        Thomas Braun Most Active @syntetic last edited by Thomas Braun
                        @syntetic
                        Was brauchst du konkret?
                        Ich werde dir nicht alles vorflüstern, du wirst um ein wenig Beschäftigen mit dem System nicht drumherumkommen.
                        RaspberryOS:
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        ioBroker:
                        https://www.iobroker.net/#de/documentation/install/linux.md
                        ioBroker-Backup via Backitup-Adapter einspielen.
                        Zu den anderen Diensten kann ich dir nichts sagen, muss der Admin von der Kiste ja wissen, was da warum wie installiert ist und wie man da Backups macht.
                          da gibt es nicht viel auszukennen!
                          Als erstes nimmst du eine neue gute SD-Karte.
                          Dann hast du für den Notfall immer noch die alte als Hardwarebackup.
                          Wobei ich nicht weiß ob das auch nur annähernd einen Sinn ergibt.
                          Dann
                          mit dem Backitup Adapter.
                          Das Ergebnis sicherst du außerhalb des RasPis
                          Die Infos für das OS und für ioB hat dir @Thomas-Braun schon verlinkt.
                          Wofür man einen
                          Printserver
                          auf einem Server benötigt erschließt sich mir nicht.
                          Ob und wie man die Konfig von pihole sichern kann weiß ich nicht.
                          wendy2702 1 Reply Last reply Reply Quote 1
                          • wendy2702
                            wendy2702 @Homoran last edited by
                            @homoran Printserver..
                            Vermutung: am PI hängt ein USB Drucker der über den Server im Netzwerk verfügbar gemacht wird.!?
                              syntetic @wendy2702 last edited by syntetic
                              So, erstmal tausend Dank an alle helfenden Köpfe, v.a. @Homoran und @Thomas-Braun. Ich habe ein Backup vom ioBroker per Backitup aufs NAS gespielt. Anschließend den Raspberry komplett neu installiert mit aktuellem OS, alle Updates gezogen und anschließend das Backup aufgespielt. Hat einige Zeit gedauert, aber es scheint tatsächlich alles zu funktionieren. Ich versuche, es in Zukunft aktuell zu halten und regelmäßige Updates zu machen.
                              @wendy2702 said in Veraltetes System retten:
                              Richtig, der Drucker kann kein AirPrint. Damit ich trotzdem über alle Geräte inkl. iPhones drucken kann, hab ich das per Printserver auf dem Raspberry gemacht.
                                klingt gut!
                                was sagt ein aktuelles iob diag?
                                  @homoran said in Veraltetes System retten:
                                  klingt gut!
                                  Ich hab ein bisschen Angst, dass du mir gleich wieder den Wind aus den Segeln nimmst, weil irgendwas nicht passt 😰
                                  Script v.2025-03-08
                                  *** BASE SYSTEM ***
                                         Icon name: computer
                                            Kernel: Linux 6.12.25+rpt-rpi-v8
                                      Architecture: arm64
                                  OS is similar to:
                                  Docker          : false
                                  Kernel          : aarch64
                                  Userland        : 64 bit
                                   21:39:01 up  2:52,  2 users,  load average: 1.11, 0.78, 0.82
                                  CPU threads: 4
                                  Operating System is the current Debian stable version codenamed 'bookworm'!
                                  Current issues:
                                                 Local time: Mon 2025-06-16 21:39:01 CEST
                                             Universal time: Mon 2025-06-16 19:39:01 UTC
                                                   RTC time: n/a
                                                NTP service: active
                                            RTC in local TZ: no
                                  mitcho
                                  HOME=/home/mitcho
                                  GROUPS=mitcho adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  iobroker
                                  HOME=/home/iobroker
                                  GROUPS=iobroker tty dialout audio video plugdev bluetooth gpio i2c
                                  Desktop:
                                  Terminal: 	tty
                                  *** MEMORY ***
                                  Mem:            4.0G        2.2G        303M        8.7M        1.6G        1.7G
                                  Swap:           536M          0B        536M
                                  Total:          4.5G        2.2G        840M
                                  Active iob-Instances: 	14
                                           3797 M total memory
                                           2131 M used memory
                                           2079 M active memory
                                           1211 M inactive memory
                                            289 M free memory
                                             67 M buffer memory
                                           1421 M swap cache
                                            511 M total swap
                                              0 M used swap
                                            511 M free swap
                                  top - 21:39:02 up  2:52,  2 users,  load average: 1.10, 0.78, 0.82
                                  Tasks: 193 total,   1 running, 192 sleeping,   0 stopped,   0 zombie
                                  %Cpu(s):  0.0 us, 20.0 sy,  0.0 ni, 80.0 id,  0.0 wa,  0.0 hi,  0.0 si,  0.0 st
                                  MiB Mem :   3797.4 total,    288.7 free,   2131.7 used,   1488.6 buff/cache
                                  MiB Swap:    512.0 total,    512.0 free,      0.0 used.   1665.8 avail Mem
                                  0 loaded units listed.
                                  *** FILESYSTEM ***
                                  udev           devtmpfs  1.6G     0  1.6G   0% /dev
                                  tmpfs          tmpfs     380M  5.9M  374M   2% /run
                                  /dev/mmcblk0p2 ext4      235G  4.5G  218G   3% /
                                  tmpfs          tmpfs     1.9G  2.5M  1.9G   1% /dev/shm
                                  /dev/mmcblk0p1 vfat      510M   56M  455M  11% /boot/firmware
                                  tmpfs          tmpfs     380M     0  380M   0% /run/user/1000
                                  [Mon Jun 16 18:46:23 2025] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 cgroup_disable=memory numa_policy=interleave snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0  numa=fake=2 system_heap.max_order=0 smsc95xx.macaddr=DC:A6:32:FC:5C:B2 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=bd7d57f9-02 rootfstype=ext4 fsck.repair=yes rootwait
                                  [Mon Jun 16 18:46:24 2025] EXT4-fs (mmcblk0p2): mounted filesystem d4cc7d63-da78-48ad-9bdd-64ffbba449a8 ro with ordered data mode. Quota mode: none.
                                  [Mon Jun 16 18:46:25 2025] EXT4-fs (mmcblk0p2): re-mounted d4cc7d63-da78-48ad-9bdd-64ffbba449a8 r/w. Quota mode: none.
                                  /                /dev/mmcblk0p2 ext4   rw,noatime,commit=600
                                  `-/boot/firmware /dev/mmcblk0p1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                                  /var:
                                  898M	/var/
                                  208M	/var/cache
                                  202M	/var/cache/apt
                                  164M	/var/lib
                                  135M	/var/lib/apt/lists
                                  Archived and active journals take up 4.7M in the file system.
                                  4.9M	/opt/iobroker/backups/
                                  289M	/opt/iobroker/iobroker-data/
                                  180M	/opt/iobroker/iobroker-data/files
                                  47M	/opt/iobroker/iobroker-data/files/admin.admin
                                  46M	/opt/iobroker/iobroker-data/files/admin.admin/custom/assets
                                  60M	/opt/iobroker/iobroker-data/objects.jsonl
                                  45M	/opt/iobroker/iobroker-data/states.jsonl
                                  24M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js.map
                                  8.4M	/opt/iobroker/iobroker-data/files/scenes.admin/static/js/main.c9369f6c.js
                                  8.1M	/opt/iobroker/iobroker-data/files/backitup.admin/assets/index-BFvcOIQE.js
                                  USB-Devices by-id:
                                  zigbee.X
                                  Extended Pan ID:
                                  *** MASKED ***
                                  Pan ID:
                                  *** MASKED ***
                                  Channel:
                                  *** MASKED ***
                                  Network Key:
                                  *** MASKED ***
                                  /usr/bin/nodejs 	v20.19.2
                                  /usr/bin/node 		v20.19.2
                                  /usr/bin/npm 		10.8.2
                                  /usr/bin/npx 		10.8.2
                                  /usr/bin/corepack 	0.31.0
                                  nodejs:
                                    Installed: 20.19.2-1nodesource1
                                    Candidate: 20.19.2-1nodesource1
                                    Version table:
                                   *** 20.19.2-1nodesource1 1001
                                          500 https://deb.nodesource.com/node_20.x nodistro/main arm64 Packages
                                       20.19.1-1nodesource1 1001
                                       20.19.0-1nodesource1 1001
                                       20.18.3-1nodesource1 1001
                                       20.18.2-1nodesource1 1001
                                       20.18.1-1nodesource1 1001
                                       20.18.0-1nodesource1 1001
                                       20.17.0-1nodesource1 1001
                                       20.16.0-1nodesource1 1001
                                       20.15.1-1nodesource1 1001
                                       20.15.0-1nodesource1 1001
                                       20.14.0-1nodesource1 1001
                                       20.13.1-1nodesource1 1001
                                       20.13.0-1nodesource1 1001
                                       20.12.2-1nodesource1 1001
                                       20.12.1-1nodesource1 1001
                                       20.12.0-1nodesource1 1001
                                       20.11.1-1nodesource1 1001
                                       20.11.0-1nodesource1 1001
                                       20.10.0-1nodesource1 1001
                                       20.9.0-1nodesource1 1001
                                       20.8.1-1nodesource1 1001
                                       20.8.0-1nodesource1 1001
                                       20.7.0-1nodesource1 1001
                                       20.6.1-1nodesource1 1001
                                       20.6.0-1nodesource1 1001
                                       20.5.1-1nodesource1 1001
                                       20.5.0-1nodesource1 1001
                                       20.4.0-1nodesource1 1001
                                       20.3.1-1nodesource1 1001
                                       20.3.0-1nodesource1 1001
                                       20.2.0-1nodesource1 1001
                                       20.1.0-1nodesource1 1001
                                       20.0.0-1nodesource1 1001
                                       18.19.0+dfsg-6~deb12u2 500
                                       18.19.0+dfsg-6~deb12u1 500
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  Hosts:
                                  raspberrypi         raspberrypi (version: 7.0.6, hostname: raspberrypi   , alive, uptime: 9063)
                                  admin: 		7.6.17
                                  javascript: 	8.9.2
                                  Adapter State
                                  + system.adapter.accuweather.0            : accuweather           : raspberrypi                              -  enabled
                                  + system.adapter.admin.0                  : admin                 : raspberrypi                              -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                  + system.adapter.backitup.0               : backitup              : raspberrypi                              -  enabled
                                    system.adapter.flot.0                   : flot                  : raspberrypi                              - disabled
                                    system.adapter.history.0                : history               : raspberrypi                              - disabled
                                    system.adapter.ical.0                   : ical                  : raspberrypi                              -  enabled
                                    system.adapter.ical.1                   : ical                  : raspberrypi                              -  enabled
                                    system.adapter.ical.2                   : ical                  : raspberrypi                              -  enabled
                                    system.adapter.info.0                   : info                  : raspberrypi                              -  enabled
                                  + system.adapter.javascript.0             : javascript            : raspberrypi                              -  enabled
                                  + system.adapter.pi-hole.0                : pi-hole               : raspberrypi                              -  enabled
                                    system.adapter.scenes.0                 : scenes                : raspberrypi                              - disabled
                                  + system.adapter.shelly.0                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.shelly.1                 : shelly                : raspberrypi                              -  enabled, port: 1882, bind: 0.0.0.0
                                  + system.adapter.telegram.0               : telegram              : raspberrypi                              -  enabled, port: 8443, bind: 0.0.0.0
                                  + system.adapter.trashschedule.0          : trashschedule         : raspberrypi                              -  enabled
                                  + system.adapter.unifi.0                  : unifi                 : raspberrypi                              -  enabled
                                    system.adapter.vis.0                    : vis                   : raspberrypi                              - disabled
                                  + system.adapter.web.0                    : web                   : raspberrypi                              -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                  + system.adapter.yahka.0                  : yahka                 : raspberrypi                              -  enabled
                                  + system.adapter.zigbee.0                 : zigbee                : raspberrypi                              -  enabled, port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231102161149-if00
                                  + instance is alive
                                  Adapter    "accuweather"  : 2.1.0    , installed 2.1.0
                                  Adapter    "javascript"   : 8.9.2    , installed 8.9.2
                                  Adapter    "scenes"       : 3.2.3    , installed 3.2.3
                                  Adapter    "shelly"       : 9.5.1    , installed 9.5.1
                                  Adapter    "socketio"     : 6.7.1    , installed 7.0.8
                                  Adapter    "telegram"     : 4.1.0    , installed 4.1.0
                                  Adapter    "web"          : 7.0.8    , installed 7.0.8
                                  Adapter    "zigbee"       : 2.0.5    , installed 2.0.5
                                  Objects and States
                                  Objects: 	86932
                                  States: 	64365
                                  Hit:2 http://deb.debian.org/debian-security bookworm-security InRelease
                                  Hit:3 http://deb.debian.org/debian bookworm-updates InRelease
                                  Hit:4 http://archive.raspberrypi.com/debian bookworm InRelease
                                  Hit:5 https://deb.nodesource.com/node_20.x nodistro InRelease
                                  Reading package lists...
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      995        9798       1936/pihole-FTL
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          1847       600/sshd: /usr/sbin
                                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      995        11311      1936/pihole-FTL
                                  tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      995        9797       1936/pihole-FTL
                                  tcp        0      0 127.0.0.1:33217         0.0.0.0:*               LISTEN      1001       207245     4857/io.yahka.0
                                  tcp        0      0 0.0.0.0:34815           0.0.0.0:*               LISTEN      1001       207236     4857/io.yahka.0
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       32916      3698/iobroker.js-co
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       31951      3698/iobroker.js-co
                                  tcp        0      0 0.0.0.0:1882            0.0.0.0:*               LISTEN      1001       33376      3853/io.shelly.1
                                  tcp6       0      0 :::443                  :::*                    LISTEN      995        9800       1936/pihole-FTL
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          1849       600/sshd: /usr/sbin
                                  tcp6       0      0 :::53                   :::*                    LISTEN      995        11313      1936/pihole-FTL
                                  tcp6       0      0 :::80                   :::*                    LISTEN      995        9799       1936/pihole-FTL
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       33298      3915/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       31487      3716/io.admin.0
                                  udp        0      0 0.0.0.0:36765           0.0.0.0:*                           104        4545       461/avahi-daemon: r
                                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           995        11310      1936/pihole-FTL
                                  udp        0      0 0.0.0.0:123             0.0.0.0:*                           995        11407      1936/pihole-FTL
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           104        4543       461/avahi-daemon: r
                                  udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       34178      3846/io.shelly.0
                                  udp6       0      0 :::57251                :::*                                104        4546       461/avahi-daemon: r
                                  udp6       0      0 :::53                   :::*                                995        11312      1936/pihole-FTL
                                  udp6       0      0 :::123                  :::*                                995        8894       1936/pihole-FTL
                                  udp6       0      0 :::5353                 :::*                                104        4544       461/avahi-daemon: r
                                  2025-06-16 21:14:31.745  - error: javascript.0 (3728) Script script.js.Überwachung.PV_Anlage_Datenabfrage is calling setState more than 1000 times per minute! Stopping Script now! Please check your script!
                                  2025-06-16 21:14:31.746  - info: javascript.0 (3728) Stopping script script.js.Überwachung.PV_Anlage_Datenabfrage
                                  2025-06-16 21:22:14.125  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                                  2025-06-16 21:22:16.405  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                                  2025-06-16 21:22:17.802  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                                  2025-06-16 21:22:19.028  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                                  2025-06-16 21:22:22.685  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                                  2025-06-16 21:22:23.134  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                                  2025-06-16 21:22:26.223  - info: admin.0 (3716) ==> Connected system.user.admin from ::ffff:192.168.2.185
                                  2025-06-16 21:22:36.173  - info: admin.0 (3716) <== Disconnect system.user.admin from ::ffff:192.168.2.185 admin
                                  2025-06-16 21:30:00.092  - info: host.raspberrypi instance system.adapter.ical.1 in version "1.16.1" started with pid 7005
                                  2025-06-16 21:30:04.144  - info: host.raspberrypi instance system.adapter.ical.2 in version "1.16.1" started with pid 7016
                                  2025-06-16 21:30:05.707  - info: ical.1 (7005) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
                                  2025-06-16 21:30:08.147  - info: ical.1 (7005) processing URL: Geburtstage http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7obrJTyh7JrvM5W7hWbXKYV98z6u1ArEpUzT0Qfx8u5BCClYRNKct5WlBkEJoZzDg4
                                  2025-06-16 21:30:08.445  - info: host.raspberrypi instance system.adapter.ical.0 in version "1.16.1" started with pid 7031
                                  2025-06-16 21:30:11.141  - info: ical.2 (7016) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
                                  2025-06-16 21:30:14.810  - info: ical.1 (7005) Terminated (NO_ERROR): Without reason
                                  2025-06-16 21:30:15.279  - info: ical.2 (7016) processing URL: Termine http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7oYOZ-wGjmsa5xf0_Job--v
                                  2025-06-16 21:30:15.370  - info: host.raspberrypi instance system.adapter.ical.1 having pid 7005 terminated with code 0 (NO_ERROR)
                                  2025-06-16 21:30:16.034  - info: ical.0 (7031) starting. Version 1.16.1 in /opt/iobroker/node_modules/iobroker.ical, node: v20.19.2, js-controller: 7.0.6
                                  2025-06-16 21:30:17.850  - info: ical.0 (7031) processing URL: Abfallkalender http://p71-caldav.icloud.com/published/2/MTY1NjczOTQ5MjcxNjU2N1M3_x2pI3on2b849KhyJ7p4SoafHZSRCZlAgdEYtjMS7V69VebAe4k5Fje7F1AUj1kDgxQWHADWcnNrtdAr7CU
                                  2025-06-16 21:30:20.594  - info: ical.2 (7016) Terminated (NO_ERROR): Without reason
                                  2025-06-16 21:30:21.141  - info: host.raspberrypi instance system.adapter.ical.2 having pid 7016 terminated with code 0 (NO_ERROR)
                                  2025-06-16 21:30:23.177  - info: ical.0 (7031) Terminated (NO_ERROR): Without reason
                                  2025-06-16 21:30:23.713  - info: host.raspberrypi instance system.adapter.ical.0 having pid 7031 terminated with code 0 (NO_ERROR)
                                    Nö, passt soweit. Bring vis noch auf Stand.
                                      wenn, dann nur um dir zu helfen.
                                      Aber ich sehe nichts, lediglich
                                      hat es da gehakt?
                                        hat es da gehakt?
                                        Nein. Schon erledigt.
                                          @syntetic
                                          Das würde ich mir aber anschauen:
                                          S Homoran 2 Replies Last reply Reply Quote 1
                                            @thomas-braun said in Veraltetes System retten:
                                            @syntetic
                                            Ich wollte das Abfrageintervall auf 10 Sekunden verkürzen. Das mochte er offenbar nicht. Bei 1 Minute gibts keine Probleme.
                                            81.1k
                                            1636
